Part Number: CC1310
Tool/software: Linux
問題一:
我有去增加 flag MT_MSG_TYPE_areq_frag_data 可以增加到256 byte 資料
/* process the message */_
if(pMsg->m_type == MT_MSG_TYPE_areq ||pMsg->m_type == MT_MSG_TYPE_areq_frag_data )
process_areq(pMsg);
請問要如何修改才能支援到2048Byte 資料.
問題二.
關於CC1310 uart check sum error.
我有修改SDK如下
1. vim components/api/src/api_mac.c
if(pMsg->m_type == MT_MSG_TYPE_areq)
process_areq(pMsg);
process_areq(pMsg);
2. vim collector.cfg
; Reporting Interval - in milliseconds to be set on connected devices using
; configuration request messages
;config-reporting-interval = 90000
config-reporting-interval = 100
; Polling interval in milliseconds to be set on connected devices using
; configuration request messages. Must be greater than or equal to default
; polling interval set on sensor devices
;config-polling-interval = 6000
config-polling-interval = 100
3.
vim config.h
/*! Polling interval in milliseconds */
//#define CONFIG_POLLING_INTERVAL 1000
/*! PAN Advertisement Solicit trickle timer duration in milliseconds */
#define CONFIG_PAN_ADVERT_SOLICIT_CLK_DURATION 6000
/*! PAN Config Solicit trickle timer duration in milliseconds */
#define CONFIG_PAN_CONFIG_SOLICIT_CLK_DURATION 6000
/*! Default Reporting Interval - in milliseconds */
//#define CONFIG_REPORTING_INTERVAL 1000
vim sensor.c
/* Reporting Interval Min and Max (in milliseconds) */
//#define MIN_REPORTING_INTERVAL 1000
#define MAX_REPORTING_INTERVAL 360000
/* Polling Interval Min and Max (in milliseconds) */
//#define MIN_POLLING_INTERVAL 1000
#define MAX_POLLING_INTERVAL 10000
4. vim smsg.h
/*! Length of the tempSensor portion of the sensor data message */
//#define SMSGS_SENSOR_TEMP_LEN 4
#define SMSGS_SENSOR_TEMP_LEN 200
紅色部分是客戶修改的地方,主要是要讓傳輸變快和資料變大.
100ms 傳一次200byte資料
但是會出現這個錯誤
root@beaglebone:~/ti154stack_linux_x64_2_03_00_06/prebuilt/prebuilt#
/collector_log.txtti154stack_linux_x64_2_03_00_06/prebuilt/prebuilt# tail -f bin
5393.412: 00000000: fe d6 42 85 02 - |..B.. |
5393.484: ERROR: uart: chksum error
5393.484: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5393.484: 00000000: fe d6 42 85 02 - |..B.. |
5393.600: ERROR: uart: chksum error
5393.600: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5393.600: 00000000: fe 03 c2 85 20 - |.... |
5393.679: ERROR: uart: chksum error
5393.679: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5393.680: 00000000: fe 03 c2 85 20 - |.... |
5393.735: ERROR: uart: chksum error
5393.735: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x0c 0x42 0x91 0x02]
5393.735: 00000000: fe 0c 42 91 02 - |..B.. |
5393.795: ERROR: uart: chksum error
5393.795: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5393.796: 00000000: fe 03 c2 85 20 - |.... |
5393.855: ERROR: uart: chksum error
5393.856: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x0c 0x42 0x91 0x02]
5393.856: 00000000: fe 0c 42 91 02 - |..B.. |
5393.936: ERROR: uart: chksum error
5393.936: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x0c 0x42 0x91 0x02]
5393.937: 00000000: fe 0c 42 91 02 - |..B.. |
5393.998: ERROR: uart: chksum error
5393.999: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5393.999: 00000000: fe 03 c2 85 20 - |.... |
5394.056: ERROR: uart: chksum error
5394.057: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5394.057: 00000000: fe 03 c2 85 20 - |.... |
5394.115: ERROR: uart: chksum error
5394.115: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5394.115: 00000000: fe 03 c2 85 20 - |.... |
5394.194: ERROR: uart: chksum error
5394.194: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5394.194: 00000000: fe 03 c2 85 20 - |.... |
5394.258: ERROR: uart: chksum error
5394.259: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5394.259: 00000000: fe 03 c2 85 20 - |.... |
5394.348: ERROR: uart: chksum error
5394.348: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5394.348: 00000000: fe d6 42 85 02 - |..B.. |
5394.405: ERROR: uart: chksum error
5394.406: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5394.406: 00000000: fe 03 c2 85 20 - |.... |
5394.471: ERROR: uart: chksum error
5394.471: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5394.471: 00000000: fe 03 c2 85 20 - |.... |
5394.535: ERROR: uart: chksum error
5394.535: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5394.536: 00000000: fe 03 c2 85 20 - |.... |
5394.632: ERROR: uart: chksum error
5394.632: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5394.632: 00000000: fe 03 c2 85 20 - |.... |
5394.727: ERROR: uart: chksum error
5394.728: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5394.728: 00000000: fe 03 c2 85 20 - |.... |
5394.816: ERROR: uart: chksum error
5394.816: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5394.817: 00000000: fe d6 42 85 02 - |..B.. |
5394.887: ERROR: uart: chksum error
5394.887: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5394.888: 00000000: fe d6 42 85 02 - |..B.. |
5394.956: ERROR: uart: chksum error
5394.957: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5394.957: 00000000: fe 03 c2 85 20 - |.... |
5395.027: ERROR: uart: chksum error
5395.028: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5395.028: 00000000: fe 03 c2 85 20 - |.... |
5395.087: ERROR: uart: chksum error
5395.087: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5395.088: 00000000: fe 03 c2 85 20 - |.... |
5395.174: ERROR: uart: chksum error
5395.174: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5395.174: 00000000: fe d6 42 85 02 - |..B.. |
5395.248: ERROR: uart: chksum error
5395.249: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x0c 0x42 0x91 0x02]
5395.249: 00000000: fe 0c 42 91 02 - |..B.. |
5395.354: ERROR: uart: chksum error
5395.354: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5395.354: 00000000: fe 03 c2 85 20 - |.... |
5395.437: ERROR: uart: chksum error
5395.437: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5395.438: 00000000: fe 03 c2 85 20 - |.... |
5395.536: ERROR: uart: chksum error
5395.537: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5395.537: 00000000: fe 03 c2 85 20 - |.... |
5395.607: ERROR: uart: chksum error
5395.608: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5395.608: 00000000: fe 03 c2 85 20 - |.... |
5395.685: ERROR: uart: chksum error
5395.685: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5395.685: 00000000: fe 03 c2 85 20 - |.... |
5395.785: ERROR: uart: chksum error
5395.786: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5395.786: 00000000: fe 03 c2 85 20 - |.... |
5395.858: ERROR: uart: chksum error
5395.858: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x0c 0x42 0x91 0x02]
5395.859: 00000000: fe 0c 42 91 02 - |..B.. |
5395.952: ERROR: uart: chksum error
5395.952: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5395.953: 00000000: fe d6 42 85 02 - |..B.. |
5396.036: ERROR: uart: chksum error
5396.037: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5396.037: 00000000: fe d6 42 85 02 - |..B.. |
5396.096: ERROR: uart: chksum error
5396.096: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x0c 0x42 0x91 0x02]
5396.096: 00000000: fe 0c 42 91 02 - |..B.. |
5396.156: ERROR: uart: chksum error
5396.157: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5396.157: 00000000: fe 03 c2 85 20 - |.... |
5396.218: ERROR: uart: chksum error
5396.218: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x0c 0x42 0x91 0x02]
5396.218: 00000000: fe 0c 42 91 02 - |..B.. |
5396.272: ERROR: uart: chksum error
5396.273: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x0c 0x42 0x91 0x02]
5396.273: 00000000: fe 0c 42 91 02 - |..B.. |
5396.374: ERROR: uart: chksum error
5396.375: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5396.375: 00000000: fe 03 c2 85 20 - |.... |
5396.450: ERROR: uart: chksum error
5396.451: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5396.451: 00000000: fe 03 c2 85 20 - |.... |
5396.504: ERROR: uart: chksum error
5396.505: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5396.505: 00000000: fe d6 42 85 02 - |..B.. |
5396.591: ERROR: uart: chksum error
5396.592: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5396.592: 00000000: fe 03 c2 85 20 - |.... |
5396.672: ERROR: uart: chksum error
5396.673: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5396.673: 00000000: fe 03 c2 85 20 - |.... |
5396.734: ERROR: uart: chksum error
5396.734: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5396.735: 00000000: fe d6 42 85 02 - |..B.. |
5396.793: ERROR: uart: chksum error
5396.793: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5396.794: 00000000: fe d6 42 85 02 - |..B.. |
5396.879: ERROR: uart: chksum error
5396.880: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5396.880: 00000000: fe 03 c2 85 20 - |.... |
5396.944: ERROR: uart: chksum error
5396.944: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5396.944: 00000000: fe 03 c2 85 20 - |.... |
5397.095: ERROR: uart: chksum error
5397.096: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5397.096: 00000000: fe d6 42 85 02 - |..B.. |
5397.153: ERROR: uart: chksum error
5397.154: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5397.154: 00000000: fe d6 42 85 02 - |..B.. |
5397.221: ERROR: uart: chksum error
5397.221: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x0c 0x42 0x91 0x02]
5397.221: 00000000: fe 0c 42 91 02 - |..B.. |
5397.279: ERROR: uart: chksum error
5397.280: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5397.280: 00000000: fe 03 c2 85 20 - |.... |
5397.350: ERROR: uart: chksum error
5397.350: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5397.351: 00000000: fe 03 c2 85 20 - |.... |
5397.434: ERROR: uart: chksum error
5397.435: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5397.435: 00000000: fe 03 c2 85 20 - |.... |
5397.498: ERROR: uart: chksum error
5397.498: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5397.498: 00000000: fe d6 42 85 02 - |..B.. |
5397.605: ERROR: uart: chksum error
5397.606: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5397.606: 00000000: fe 03 c2 85 20 - |.... |
5397.668: ERROR: uart: chksum error
5397.668: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x0c 0x42 0x91 0x02]
5397.668: 00000000: fe 0c 42 91 02 - |..B.. |
5397.730: ERROR: uart: chksum error
5397.730: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x0c 0x42 0x91 0x02]
5397.730: 00000000: fe 0c 42 91 02 - |..B.. |
5397.784: ERROR: uart: chksum error
5397.784: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5397.785: 00000000: fe 03 c2 85 20 - |.... |
5397.844: ERROR: uart: chksum error
5397.844: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5397.844: 00000000: fe 03 c2 85 20 - |.... |
5397.899: ERROR: uart: chksum error
5397.899: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x0c 0x42 0x91 0x02]
5397.900: 00000000: fe 0c 42 91 02 - |..B.. |
5397.951: ERROR: uart: chksum error
5397.952: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5397.952: 00000000: fe d6 42 85 02 - |..B.. |
5398.004: ERROR: uart: chksum error
5398.004: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5398.004: 00000000: fe 03 c2 85 20 - |.... |
5398.072: ERROR: uart: chksum error
5398.072: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5398.072: 00000000: fe 03 c2 85 20 - |.... |
5398.140: ERROR: uart: chksum error
5398.140: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5398.140: 00000000: fe 03 c2 85 20 - |.... |
5398.224: ERROR: uart: chksum error
5398.224: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5398.225: 00000000: fe d6 42 85 02 - |..B.. |
5398.301: ERROR: uart: chksum error
5398.302: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5398.302: 00000000: fe 03 c2 85 20 - |.... |
5398.400: ERROR: uart: chksum error
5398.401: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5398.401: 00000000: fe 03 c2 85 20 - |.... |
5398.473: ERROR: uart: chksum error
5398.473: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x0c 0x42 0x91 0x02]
5398.474: 00000000: fe 0c 42 91 02 - |..B.. |
5398.548: ERROR: uart: chksum error
5398.548: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5398.549: 00000000: fe 03 c2 85 20 - |.... |
5398.632: ERROR: uart: chksum error
5398.632: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5398.632: 00000000: fe d6 42 85 02 - |..B.. |
5398.696: ERROR: uart: chksum error
5398.697: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x0c 0x42 0x91 0x02]
5398.697: 00000000: fe 0c 42 91 02 - |..B.. |
5398.772: ERROR: uart: chksum error
5398.772: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5398.772: 00000000: fe 03 c2 85 20 - |.... |
5398.907: ERROR: uart: chksum error
5398.908: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5398.908: 00000000: fe d6 42 85 02 - |..B.. |
5398.969: ERROR: uart: chksum error
5398.970: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x0c 0x42 0x91 0x02]
5398.970: 00000000: fe 0c 42 91 02 - |..B.. |
5399.029: ERROR: uart: chksum error
5399.029: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5399.029: 00000000: fe 03 c2 85 20 - |.... |
5399.104: ERROR: uart: chksum error
5399.105: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5399.105: 00000000: fe 03 c2 85 20 - |.... |
5399.177: ERROR: uart: chksum error
5399.178: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5399.178: 00000000: fe 03 c2 85 20 - |.... |
5399.237: ERROR: uart: chksum error
5399.237: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5399.237: 00000000: fe d6 42 85 02 - |..B.. |
5399.300: ERROR: uart: chksum error
5399.300: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x0c 0x42 0x91 0x02]
5399.301: 00000000: fe 0c 42 91 02 - |..B.. |
5399.381: ERROR: uart: chksum error
5399.381: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5399.381: 00000000: fe d6 42 85 02 - |..B.. |
5399.453: ERROR: uart: chksum error
5399.453: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5399.453: 00000000: fe 03 c2 85 20 - |.... |
5399.506: ERROR: uart: chksum error
5399.506: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5399.506: 00000000: fe d6 42 85 02 - |..B.. |
5399.595: ERROR: uart: chksum error
5399.596: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5399.596: 00000000: fe d6 42 85 02 - |..B.. |
5399.719: ERROR: uart: chksum error
5399.720: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5399.720: 00000000: fe 03 c2 85 20 - |.... |
5399.788: ERROR: uart: chksum error
5399.788: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5399.789: 00000000: fe 03 c2 85 20 - |.... |
5399.862: ERROR: uart: chksum error
5399.863: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5399.864: 00000000: fe d6 42 85 02 - |..B.. |
5399.920: ERROR: uart: chksum error
5399.921: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x0c 0x42 0x91 0x02]
5399.921: 00000000: fe 0c 42 91 02 - |..B.. |
5399.999: ERROR: uart: chksum error
5400.000: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5400.000: 00000000: fe 03 c2 85 20 - |.... |
5400.093: ERROR: uart: chksum error
5400.094: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5400.094: 00000000: fe d6 42 85 02 - |..B.. |
5400.164: ERROR: uart: chksum error
5400.164: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5400.164: 00000000: fe 03 c2 85 20 - |.... |
5400.223: ERROR: uart: chksum error
5400.224: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x0c 0x42 0x91 0x02]
5400.224: 00000000: fe 0c 42 91 02 - |..B.. |
5400.281: ERROR: uart: chksum error
5400.281: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5400.281: 00000000: fe 03 c2 85 20 - |.... |
5400.367: ERROR: uart: chksum error
5400.368: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5400.368: 00000000: fe 03 c2 85 20 - |.... |
5400.458: ERROR: uart: chksum error
5400.458: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5400.458: 00000000: fe 03 c2 85 20 - |.... |
5400.542: ERROR: uart: chksum error
5400.543: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5400.543: 00000000: fe 03 c2 85 20 - |.... |
5400.642: ERROR: uart: chksum error
5400.643: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5400.643: 00000000: fe 03 c2 85 20 - |.... |
5400.750: ERROR: uart: chksum error
5400.750: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5400.750: 00000000: fe 03 c2 85 20 - |.... |
5400.845: ERROR: uart: chksum error
5400.845: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xfe 0xd6 0x42 0x85]
5400.845: 00000000: fe fe d6 42 85 - |...B. |
5400.902: ERROR: uart: chksum error
5400.903: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5400.903: 00000000: fe 03 c2 85 20 - |.... |
5401.020: ERROR: uart: chksum error
5401.021: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5401.021: 00000000: fe 03 c2 85 20 - |.... |
5401.148: ERROR: uart: chksum error
5401.154: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5401.154: 00000000: fe d6 42 85 02 - |..B.. |
5401.241: ERROR: uart: chksum error
5401.241: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5401.242: 00000000: fe d6 42 85 02 - |..B.. |
5401.366: ERROR: uart: chksum error
5401.366: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5401.367: 00000000: fe 03 c2 85 20 - |.... |
5401.422: ERROR: uart: chksum error
5401.423: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x0c 0x42 0x91 0x02]
5401.423: 00000000: fe 0c 42 91 02 - |..B.. |
5401.497: ERROR: uart: chksum error
5401.498: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5401.498: 00000000: fe 03 c2 85 20 - |.... |
5401.556: ERROR: uart: chksum error
5401.556: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5401.556: 00000000: fe 03 c2 85 20 - |.... |
5401.614: ERROR: uart: chksum error
5401.614: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5401.615: 00000000: fe 03 c2 85 20 - |.... |
5401.716: ERROR: uart: chksum error
5401.717: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5401.717: 00000000: fe 03 c2 85 20 - |.... |
5401.812: ERROR: uart: chksum error
5401.813: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5401.813: 00000000: fe 03 c2 85 20 - |.... |
5401.893: ERROR: uart: chksum error
5401.893: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5401.894: 00000000: fe d6 42 85 02 - |..B.. |
5401.949: ERROR: uart: chksum error
5401.950: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5401.950: 00000000: fe 03 c2 85 20 - |.... |
5402.094: ERROR: uart: chksum error
5402.095: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5402.095: 00000000: fe d6 42 85 02 - |..B.. |
5402.184: ERROR: uart: chksum error
5402.185: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5402.185: 00000000: fe d6 42 85 02 - |..B.. |
5402.283: ERROR: uart: chksum error
5402.284: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5402.284: 00000000: fe d6 42 85 02 - |..B.. |
5402.351: ERROR: uart: chksum error
5402.352: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x0c 0x42 0x91 0x02]
5402.352: 00000000: fe 0c 42 91 02 - |..B.. |
5402.403: ERROR: uart: chksum error
5402.404: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5402.404: 00000000: fe d6 42 85 02 - |..B.. |
5402.463: ERROR: uart: chksum error
5402.463: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x0c 0x42 0x91 0x02]
5402.463: 00000000: fe 0c 42 91 02 - |..B.. |
5402.560: ERROR: uart: chksum error
5402.560: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5402.560: 00000000: fe d6 42 85 02 - |..B.. |
5402.617: ERROR: uart: chksum error
5402.618: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x0c 0x42 0x91 0x02]
5402.618: 00000000: fe 0c 42 91 02 - |..B.. |
5402.676: ERROR: uart: chksum error
5402.676: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5402.676: 00000000: fe 03 c2 85 20 - |.... |
5402.770: ERROR: uart: chksum error
5402.770: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5402.770: 00000000: fe 03 c2 85 20 - |.... |
5402.856: ERROR: uart: chksum error
5402.857: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0xd6 0x42 0x85 0x02]
5402.857: 00000000: fe d6 42 85 02 - |..B.. |
5402.917: ERROR: uart: chksum error
5402.917: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5402.917: 00000000: fe 03 c2 85 20 - |.... |
5403.021: ERROR: uart: chksum error
5403.021: ERROR: ERROR: incomming-msg msg(567a2) nbytes=5 len=0 [ 0xfe 0x03 0xc2 0x85 0x20]
5403.022: 00000000: fe 03 c2 85 20 - |....
請問要如何fix 這個bug.
If you have any question please let me know,
Hacker Hsu,
0952067531,
