Our customer use CC113L, and the frequece need 915MHz. Now refer CC113LEM 868/915 MHz Reference Design.
The question is how to change to 915MHz? Which 2 discrete component and change to what value?
By changing 2 discrete component values, this antenna can also be matched to 915MHz.
www.ti.com/.../cc113lem-868-915-rd
A small and compact PCB helix antenna that will be useful for applications requiring a high antenna efficiency in a compact area. The 868 MHz PCB helix antenna is only 19 x 12 mm (L x W) and has an efficiency ~70 %. By changing 2 discrete component values, this antenna can also be matched to 915MHz.
Walsh
