what is the max current which the IO port can pulled? Is it 8mA?
Customer need 20mA. Can the connect 2 or 3 IOs togeterh to get the 20mA?
Regards, Holger
Regards, Holger
ok. The other questions is how many GPIOs can I drive with 8mA at the same time. Eg. if I drive 10 GPIOs with 8mA then I have 80mA running through the chip. Is this ok?
Regards, Holger
Hello TER,
this is understood. Customer want to drive a LED with the ports. He needs as much current as possible, he don't care about the CMOS level. In this case can he go over the 4mA/8mA?
Regards, Holger
