HI,
When using one of the GPIO pins to control an externa; front end (PA and LNA), can you guarantee that the PA_ON (GPIO codes 23 or 25) will not be de-asserted before the final byte (usuallty the added CRC) has been completely flushed from the CC1125? Or should I add some delay to this signal to ensure that the PA remains on for a short while after this pin is de-asserted, and if som what should this delay be?
Ian
