RTOS/CC1310: Drastic changes in temperature cause chip frequency calibration to fail
Part Number: CC1310
Tool/software: TI-RTOS
Hi,Team
During the high and low temperature test, I encountered a problem that the chip communication failed for a while, but it was solved by using the cmd_Fs command in the main loop. Technical support tells me that it is due to the temperature change, I wonder if the frequency calibration failure will cause the timer to count incorrectly? Or some other crystal-related problems?
Thank you!
