Tool/software: TI-RTOS
I have been working on making orphan scan work on my custom designed cc1310 board acting as a sensor and a launchpad as a collector. There is a good difference in. the RSSI levels of my custom designed board and the launchpad but somehow they are working with each other. Sensor sending to collector and vice-versa. Although when I remove the collector and the sensor tries to send orphan scan request, it just does not get re-associated with the collector. The same firmware has been tested with a launchpad[sensor] and other launchpad[collector]. Does it have to do anything with the RX sensitivity of my custom designed boards? If an active scan is working fine then how come an orphan scan be any different? Any inputs in this regard will be appreciated.
Thanks & Regards
