Hello, I have two custom boards, the first one uses a CC1310F128RHB, the second one a CC1310F128RGZR.
I have a problem with the second one: the code works well without the debugger, but if I try to debug, it remains blocked on the RF_runCmd called during the EasyLink_init function.
Have you got any suggestion to investigate about this problem?
The big difference between the two schematics is that the working one has mounted the 32-KHz oscillatore, the other one no.
Please, should this be a problem for debugging? If yes, is there a way to debug the code without the oscillator?
Thanks in advance for your help, Andrea.
