Part Number: CC1310
Tool/software: TI-RTOS
Hey guys,
not sure if this is the correct sub-forum to post. I use sensor collector example with CC1310 sensors and launchpads. The sniffer is also a CC1310 launchpad. Increasing the distance between sensor node and causes the sniffer messages to contain a lot of BAD FCS and sometimes [BADFORMED PACKAGE].
The RSSI value of the uppermost message was -77dbm and was not acknowledged by the collector which was lying next to the sniffer.
1. What exactly does BAD FCS tell me? Is this a CRC issue?
2. Sometimes the collector acknowledges such messages. Can the collector make any use of the message and its content or is it discarding the message, if this frame check fails?
kind regards
Slev1n
