CC1352R: CC1352R sensor is rejoining with collector after erased collector details
Part Number: CC1352R
Hi All,
I am working on  SDK 3.1 version sesnor_sm and collector_sm examples.
sensor is joined in network and sensor sending data to collector.
I erased  sensor using uniflash tool(All Unprotected Sectors and Necessary Sectors Only (Retain untouched content within sector) )and i flashed sensor code.
After flash the sensor code, it is rejoined with collector. How it is rejoined with collector after collector details erased from sensor????
  • Hello Mamatha,
    Can you Erase entire flash button before flashing and make sure "ALL Unprotected Sectors" checked before flashing. I just tested on my end and it worked.
    Make sure uniflash is updated and the database is updated (these options can be found in the settings menu).
    AB
