Tool/software: TI-RTOS
We have built CC1310-based modules and now ready to go for FCC and CE certification with a test lab. May I know what firmware should I use to pass both?
There seem to be an example in the SDK with a MACRO named CERTIFICATION_TEST_MODE to be enabled to pass FCC. Would it be sufficient to flash the modules with that example and send over to the lab?
There is also a WB-DSS SmartRF studio setting that I found on this forum that seems to comply with the FCC.
Which of the two approaches would be better? We are aiming at 14dBm transmission level.
Looking forward to some help.
MM
