Hello Team,
Could you help us please with our customer's questions.
As described in datasheet CC1120 should support (at 433 MHz):
1) 1,2 Kbps, 20Khz BW, sensitivity -117 dBm
2) 50 Kbps, 100Khz BW, sensitivity -109 dBm
With this settings in SmartRF they run tests:
1) Real sensitivity is -117 dBm as in datasheet;
2) Real sensitivity is just -99 dBm instead of -109dBm.
The questions:
1) Where could be the problem in second case?
2) Are there any advanced manual for RFStudio and CC1120's registers or just datasheet?
In SmartRF you can change very limited amout of registers.
3) What settings should be configured in SmartRF to support -109 dBm sensitivity for 50 Kbps and 100Khz BW?
If you need any additional information - please ask.
This is urgent case for the customer.
BR,
Ilya.
