SDK verision: simplelink_cc13x2_26x2_sdk_3_40_00_02
sysconfig verison: 1.4.0+1234
I try to use SysConfig in CCS to configure the IO of my application. but I have some doubts:
1. open SysConfig, I find RF STACKS have three items, I want quick to use sdk to connect other devices, but sdk only have EasyLink. How to quick start ?
TI 15.4
EasyLink
Custom
2. use SysConfig add uart , it will generate ti_devices_config.c, ti_drivers_config.c, ti_drivers_config.h, syscfg_c_rov.xs and untitled.syscfg. Do I need all of these files?
if I generate all the files, how to use these file to create custom application
3. use SysConfig generate *.syscfg's format is different from SDK demo syscfg, Is I use the way not right?
-------------------------------------------------------------------------------------------------------------------generate---------------------------------------------------------------------------------------------------------------
* Copyright (c) 2018-2019, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// @cliArgs --board /ti/boards/CC1312R1_LAUNCHXL
* uartecho.syscfg
/* ======== RTOS ======== */
var RTOS = scripting.addModule("/ti/drivers/RTOS");
RTOS.name = "TI-RTOS";
/* ======== GPIO ======== */
var GPIO = scripting.addModule("/ti/drivers/GPIO");
var gpio = GPIO.addInstance();
gpio.$hardware = system.deviceData.board.components.LED0;
gpio.$name = "CONFIG_GPIO_LED_0";
/* ======== UART ======== */
var UART = scripting.addModule("/ti/drivers/UART");
var uart = UART.addInstance();
uart.$hardware = system.deviceData.board.components.XDS110UART;
uart.$name = "CONFIG_UART_0";
