Other Parts Discussed in Thread: CC1190,
We are working with a CC1310 + CC1190 design at 915 MHz. Due to physical constraints on our design, we are unable to follow a reference design layout
as far as trace lengths, pad sizes, etc. We are also evaluating a few possible antennas. This means that some tuning optimization will be needed.
We must maximize both Rx sensitivity and Tx power performance in our design. Several impedance-matching component values in the Evaluation Model
(CC1190 datasheet SWRR064) and the USA CC1310-CC1190 Reference Design (SWRA517) differ, and both documents note the importance of the
impedance matching and following the reference design layout for achieving optimized performance. The CC1190 datasheet shows a couple of Smith Chart
impedance measurements as seen from the connectors on the SWRR064 Evaluation Model, but that isn't particularly helpful for starting a new design.
The CC1310-CC1190 USA design (SWRA517) does not quantify any impedances. This makes it difficult to know how to tune the system to optimize for a
different layout, different antenna, etc. Is there any specification or guidance for what the optimum impedances should be as seen from the CC1190 RF pins
(PA_OUT, PA_IN, LNA_OUT, LNA_IN)?
The early versions of our product used the 1310 but we are now transitioning to the 1312. Does the 1312 have different impedance numbers than the 1310?
Victor
