working with CC1352R I have the next question:
Is the CC1352R support 100% ASK (OOK) modulation for 433MHz (proprietary RF) with 19.2 kbit/s data rate?
Ilian
Ilian
I believe so. We have only tested and provided register settings for 4.8 kbps but you should be able to use the same principle as covered here:
https://e2e.ti.com/support/wireless-connectivity/sub-1-ghz/f/156/t/576254?CC1310-OOK-mode-at-20-kbps
Note that the address for the overrides may be different for the device you are looking at compared to those used in the post I linked to. If you want to test this I need to check.
Hi TER,
I am going to test it.
If you can add additional information will be very helpful.
Ilian
