Is there any Software Flow Control built into the UART driver for the CC1352? If not, are you aware of any open-source solutions for the same?
Warm regards,
Samyukta
Warm regards,
Samyukta
Sorry should have been clearer, I was asking about Xon/Xoff Software flow control not hardware flow control using RTS/CTS pins. We only have Rx/Tx pins on the UART.
XON/OFF is similar to MRDY/SRDY in simple_np example so you can refer to it to revise your application accordingly.
