CC1310: CC1310 15.4 Stack OAD using with EasyLink
Part Number: CC1310
Hi, I'm currently using something similar to "sensor_oad" and "bim_offchip" example project showed in the above picture.
Now, I would like to switch to EasyLink. do you think it is possible to do?
Since the Sensor is running bootloader before entering the application program, I want to know how to set the application project that begins at which the bootloader is pointing to.
Thank you,
Larry
