Other Parts Discussed in Thread: CC1101, CC2500
I need to know how many hopping channels are used for the SimpleLink Long Range DSSS radio format?
In Section 6.3.1; Table 6-1, page 65 of the CC1352R data sheet under the SimpleLink Long Range column, the DSSS feature has "1:2, 1:4 and 1:8" what do the ratios mean?
Here is a listing of the radio settings in our code.
// Parameter summary
// RX Address0: 0xAA
// RX Address1: 0xBB
// RX Address Mode: No address check
// Frequency: 907.00000 MHz
// Data Format: Serial mode disable
// Deviation: 5.000 kHz
// Packet Length Config: Variable
// Max Packet Length: 255
// Packet Length: 20
// Packet Data: 255
// Preamble Count: 2 Bytes
// Preamble Mode: Send 0 as the first preamble bit
// RX Filter BW: 34.1 kHz
// Symbol Rate: 19.99969 kBaud
// Packet Data: 255
// Sync Word: 0x00000000
// Sync Word Length: 32 Bits
// TX Power: 14 dBm (requires define CCFG_FORCE_VDDR_HH = 1 in ccfg.c, see CC13xx/CC26xx Technical Reference Manual)
// Whitening: CC1101/CC2500 compatible
