LAUNCHXL-CC1352R1: Run time frequency change
Part Number: LAUNCHXL-CC1352R1
 We are using TI 15.4 stack collector and sensor projects. In the collector code, after flashing and the collector is powered on with 868 Mhz Frequency band. After forming the network can we update the frequency band to 915Mhz runtime?
Note: Here no sensors are added to the network.
If yes, can you please guide how can we implement to change frequency band run time.
