Part Number: CC1350STK
This doc contains the paragraphe:
Attention
Do not use the Rename option found inside CCS to rename your project. This may change certain build parameters and not others, which can lead to build errors and is irreversible.
To rename a project, you should use the Copy and paste options found inside CCS. As you Paste the project, you have the option of choosing a new project name. This process is to be repeated for the target project and its dependencies.
After pasting both project, you need to modify the target project’s properties and update its “Project Reference” (need to show advanced settings) to only select newly pasted dependency project.
Questions:
1) why are the two projects ? I understand that I copy / paste empty and give the copy - the target project - a new name. But from now on , only the target project matters ?
2) which dependencies ?
Peter
