CC3220SF-LAUNCHXL: Cannot connect to Azure IoT Hub using x509 Self Signed Certificates
Part Number: CC3220SF-LAUNCHXL
Other Parts Discussed in Thread: CC3220SF
I am using the following versions of SDK's:
Azure CC32xx IoT Plugin: 4.10.01.01
Simplelink CC32xx SDK: 4.10.00.07
I am trying to run IoT Hub Client Sample MQTT example by using a device id which has been created for Self Signed Certificates by giving respective connection string and certificates.
I have used IoTHubDeviceClient_LL_SetOption to set the x509certificate and private key.
But the device fails to connect to IoT Hub.
Can I please know if the Azure IoT Plugin given for CC3220SF has the support for x.509 certificates? If so, Can you please help me in connecting to IoT hub using x509 Self Signed Certificates.
Note: I have also tried to run HTTP example which also failed to connect.
Kishore.
