Other Parts Discussed in Thread: WL1837
can you tell me what all data rates are supported in 40MHz by the WL1837 module ?
Hi, please consult section 3.2.3 https://www.ti.com/lit/ug/swru423a/swru423a.pdf
this is just an explanation of how it works with double the throuhgput right ? my question is does what all data rates in 2.4GHz the 40MHz channel bandwitdh is supported ? when i test in 40MHz for MCS8 to MCS15, i am not seeing any transmission using the calibration tools
i am using below commands, This was asked by the certification body how to test 40MHz, if for MCS8 to MCS15 in 2.4GHz 40MHz is not supported i need to convey them the same
Band 2.4GHz, 40MHz Primary Upper
calibrator wlan0 wl18xx_plt stop_tx
calibrator wlan0 wl18xx_plt tune_channel 7 0 2
calibrator wlan0 wl18xx_plt set_tx_power 20000 0 0 7 1 0 0 1 0 0 0 0
calibrator wlan0 wl18xx_plt start_tx 300 20 4000 0 0 0 0 0 00:11:22:33:44:55 01:02:03:04:05:06 1
it works from 12 to 19
