Hi Experts,
Good day
Our customer is asking how to clear the external flash memory MX25R3235FM1IL0 from this LaunchPad
Please advise.
Josel
Hi Experts,
Good day
Please advise.
Josel
Hi Jan,
Is this referring to the external flash memory which is the MX25R3235FM1IL0 (U9 in the Launchpad)?
Josel
Hi Jan,
Thank you.
In the datasheet, How about "Pressing the (SW4) and toggling RESET (SW1) restores the factory default image on the serial flash. This can be used to recover a corrupted serial flash, provided the s-flash was programmed with a recovery image." is this also referring to the external sFlash?
CC3235 SimpleLink Wi-Fi® LaunchPad
Development Kit Hardware (ti.com)
Can we use this to reset or clear the external sFlash memory (MX25xxx) ?
Josel
Hi Josel,
This feature does not clear content sFlash. It returns filesystem at sFlash into state which was programmed by Uniflash. But this feature need to be explicitly enabled during initial programming of image.
Can you describe what your customer really needs (it may not be same thing what is questioning)?
Jan
