The solution is omap3630+wl1271+TQM679002 which is on board chip, not module.
When we do wlan calibration according to "Tx BIT procedure", the log is
Could not create FILE!!! !!!!
Entering FillMACAddressToNVS
Segmentation fault
The detail command and log is listed:
# tiwlan_cu
ERROR - IpcWpa_Sockets_Open - can't connect the socket
Connection to supplicant failed
user_main, start
\> Driver/, Connection/, Management/, Show/, Privacy/, scAn/, roaminG/, qOs/, po
Wer/, eVents/, Bt coexsistance/, Report/, dEbug/, biT/, aboUt, Quit
/ w p 1 l 2 f 2
.../poWer> set_Power_mode, set_powersave_powerLevel, set_deFault_powerlevel, set
_doZe_mode_in_auto, traffic_Thresholds, eNable, Disable, set_dcO_itrim
/ t r h 0 7
.../biT> Bip/, Radio debug/
.../Radio debug> Get hdk version, cHannel tune, Tx debug/, rx Statistics/
Channel tune of channel 7 was performed OK
/ t b b 375 128 0
.../Bip> update Buffer calref point, Tx bip, Rx bip/, set nvs Version
BufferCalReferencePoint was configured succesfully
/ t b t 1 0 0 0 0 0 0 0
Segmentation fault
Would you give us some advice? thank you!
