WL1807MOD: WL1807MOD disconnection
Part Number: WL1807MOD
Other Parts Discussed in Thread: WL1271, WL1837, AM4378, AM4372
our system use WL1807 and OS : Debian 11, when add stress for thermal testing, It is easy to disconnect when ping with AP. and fter disconnection the IP will disappear, it needs to be restarted to recover.
please help us to find out solution, Thank you.
  • log_20230504.logattached is log file, thank you.
    Can you please let us know the details of stress thermal testing including the range of ambient temperature ?
    In the Normal Temperature and only run iperf3 (For Throughput), it still cause the disconnection,  and need to restart the system to resolve this situation.
    Thank you.
    upload the kernel msg when WL1807 disconnects. This is tested in normal environment.
    At disconnecting, the kernel hang and dump mmc2 regs as following msg
    Do you need any further messages?
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc (haidar@haidar-linux) (arm-none-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 PREEMPT_RT Wed Apr 19 14:01:38 CST 2023
    [    0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [    0.000000] OF: fdt: Machine model: TI AM437x EMU200
    [    0.000000] Memory policy: Data cache writeback
    [    0.000000] cma: Reserved 48 MiB at 0xbd000000
    [    0.000000] Zone ranges:
    [    0.000000]   Normal   [mem 0x0000000080000000-0x00000000afffffff]
    [    0.000000]   HighMem  [mem 0x00000000b0000000-0x00000000bfffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x00000000bfffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000bfffffff]
    [    0.000000] On node 0 totalpages: 262144
    [    0.000000]   Normal zone: 1728 pages used for memmap
    [    0.000000]   Normal zone: 0 pages reserved
    [    0.000000]   Normal zone: 196608 pages, LIFO batch:63
    [    0.000000]   HighMem zone: 65536 pages, LIFO batch:15
    [    0.000000] CPU: All CPU(s) started in SVC mode.
    [    0.000000] AM437x ES1.2 (neon)
    [    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
    [    0.000000] pcpu-alloc: [0] 0
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 260416
    [    0.000000] Kernel command line: console=ttyO0,115200n8 root=PARTUUID=2ff1f17b-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] Memory: 973760K/1048576K available (9216K kernel code, 722K rwdata, 3244K rodata, 1024K init, 274K bss, 25664K reserved, 49152K cma-reserved, 212992K highmem)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU event tracing is enabled.
    [    0.000000] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
    [    0.000000] rcu: 	RCU_SOFTIRQ processing moved to rcuc kthreads.
    [    0.000000] 	No expedited grace period (rcu_normal_after_boot).
    [    0.000000] 	Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] L2C: platform modifies aux control register: 0x0e030000 -> 0x3e430000
    [    0.000000] L2C: DT/platform modifies aux control register: 0x0e030000 -> 0x3e430000
    [    0.000000] L2C-310 enabling early BRESP for Cortex-A9
    [    0.000000] OMAP L2C310: ROM does not support power control setting
    [    0.000000] L2C-310 dynamic clock gating disabled, standby mode disabled
    [    0.000000] L2C-310 cache controller enabled, 16 ways, 256 kB
    [    0.000000] L2C-310: CACHE_ID 0x410000c9, AUX_CTRL 0x4e430000
    [    0.000000] random: get_random_bytes called from start_kernel+0x31c/0x4dc with crng_init=0
    [    0.000000] TI gptimer clocksource: always-on /ocp@44000000/interconnect@44c00000/segment@200000/target-module@31000
    [    0.000001] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
    [    0.000019] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
    [    0.000139] OMAP clocksource: 32k_counter at 32768 Hz
    [    0.000145] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
    [    0.000385] TI gptimer clockevent: 24000000 Hz at /ocp@44000000/interconnect@48000000/segment@0/target-module@40000
    [    0.001396] Console: colour dummy device 80x30
    [    0.001436] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
    [    0.001442] This ensures that you still see kernel messages. Please
    [    0.001445] update your kernel commandline.
    [    0.001472] Calibrating delay loop... 1987.37 BogoMIPS (lpj=9936896)
    [    0.058074] pid_max: default: 32768 minimum: 301
    [    0.058207] LSM: Security Framework initializing
    [    0.058280] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.058307] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.059318] CPU: Testing write buffer coherency: ok
    [    0.059377] CPU0: Spectre v2: using BPIALL workaround
    [    0.060326] Setting up static identity map for 0x80100000 - 0x80100060
    [    0.060479] rcu: Hierarchical SRCU implementation.
    [    0.060845] EFI services will not be available.
    [    0.061381] devtmpfs: initialized
    [    0.074726] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
    [    0.074939] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.074971] futex hash table entries: 256 (order: 1, 8192 bytes, linear)
    [    0.078349] pinctrl core: initialized pinctrl subsystem
    [    0.079078] DMI not present or invalid.
    [    0.079546] NET: Registered protocol family 16
    [    0.081519] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.088951] thermal_sys: Registered thermal governor 'fair_share'
    [    0.088965] thermal_sys: Registered thermal governor 'bang_bang'
    [    0.088970] thermal_sys: Registered thermal governor 'step_wise'
    [    0.088973] thermal_sys: Registered thermal governor 'user_space'
    [    0.826892] No ATAGs?
    [    0.826915] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
    [    0.826924] hw-breakpoint: maximum watchpoint size is 4 bytes.
    [    0.851949] reg-fixed-voltage fixed-regulator-wlen: GPIO lookup for consumer (null)
    [    0.851968] reg-fixed-voltage fixed-regulator-wlen: using device tree for GPIO lookup
    [    0.851986] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/fixed-regulator-wlen[0]'
    [    0.852027] reg-fixed-voltage fixed-regulator-wlen: No GPIO consumer (null) found
    [    0.852959] iommu: Default domain type: Translated
    [    0.855062] SCSI subsystem initialized
    [    0.855667] pps_core: LinuxPPS API ver. 1 registered
    [    0.855675] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.855697] PTP clock support registered
    [    0.855755] EDAC MC: Ver: 3.0.0
    [    0.858480] clocksource: Switched to clocksource dmtimer
    [    0.866643] NET: Registered protocol family 2
    [    0.866996] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.868725] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 14336 bytes, linear)
    [    0.868820] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
    [    0.868903] TCP bind hash table entries: 8192 (order: 5, 196608 bytes, linear)
    [    0.869674] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.869925] UDP hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.870068] UDP-Lite hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.870413] NET: Registered protocol family 1
    [    0.871106] RPC: Registered named UNIX socket transport module.
    [    0.871119] RPC: Registered udp transport module.
    [    0.871123] RPC: Registered tcp transport module.
    [    0.871127] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.871140] PCI: CLS 0 bytes, default 64
    [    0.873093] Initialise system trusted keyrings
    [    0.873394] workingset: timestamp_bits=14 max_order=18 bucket_order=4
    [    0.877774] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.878793] NFS: Registering the id_resolver key type
    [    0.878835] Key type id_resolver registered
    [    0.878842] Key type id_legacy registered
    [    0.878928] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.878935] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.878975] ntfs: driver 2.1.32 [Flags: R/O].
    [    0.879560] Key type asymmetric registered
    [    0.879573] Asymmetric key parser 'x509' registered
    [    0.879640] bounce: pool size: 64 pages
    [    0.879696] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.879704] io scheduler mq-deadline registered
    [    0.879711] io scheduler kyber registered
    [    1.005753] gpio gpiochip0: (gpio-0-31): added GPIO chardev (254:0)
    [    1.005867] gpio gpiochip0: registered GPIOs 0 to 31 on gpio-0-31
    [    1.006095] OMAP GPIO hardware version 0.1
    [    1.188941] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
    [    1.220978] gpio gpiochip1: (gpio-32-63): added GPIO chardev (254:1)
    [    1.221078] gpio gpiochip1: registered GPIOs 32 to 63 on gpio-32-63
    [    1.253109] gpio gpiochip2: (gpio-64-95): added GPIO chardev (254:2)
    [    1.253224] gpio gpiochip2: registered GPIOs 64 to 95 on gpio-64-95
    [    1.299599] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
    [    1.299626] edma 49000000.dma: TI EDMA DMA engine driver
    [    1.336360] pinctrl-single 44e10800.pinmux: 199 pins, size 796
    [    1.389455] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    1.393011] omap8250 44e09000.serial: No clock speed specified: using default: 48000000
    [    1.393843] omap8250 44e09000.serial: GPIO lookup for consumer rs485-term
    [    1.393856] omap8250 44e09000.serial: using device tree for GPIO lookup
    [    1.393876] of_get_named_gpiod_flags: can't parse 'rs485-term-gpios' property of node '/ocp@44000000/interconnect@44c00000/segment@200000/target-module@9000/serial@0[0]'
    [    1.393919] of_get_named_gpiod_flags: can't parse 'rs485-term-gpio' property of node '/ocp@44000000/interconnect@44c00000/segment@200000/target-module@9000/serial@0[0]'
    [    1.393947] omap8250 44e09000.serial: using lookup tables for GPIO lookup
    [    1.393955] omap8250 44e09000.serial: No GPIO consumer rs485-term found
    [    1.393996] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 56, base_baud = 3000000) is a 8250
    [    1.394131] printk: console [ttyS0] enabled
    [    1.394973] omap8250 481aa000.serial: No clock speed specified: using default: 48000000
    [    1.395706] omap8250 481aa000.serial: GPIO lookup for consumer rs485-term
    [    1.395718] omap8250 481aa000.serial: using device tree for GPIO lookup
    [    1.395734] of_get_named_gpiod_flags: can't parse 'rs485-term-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@100000/target-module@aa000/serial@0[0]'
    [    1.395771] of_get_named_gpiod_flags: can't parse 'rs485-term-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@100000/target-module@aa000/serial@0[0]'
    [    1.395797] omap8250 481aa000.serial: using lookup tables for GPIO lookup
    [    1.395805] omap8250 481aa000.serial: No GPIO consumer rs485-term found
    [    1.395845] 481aa000.serial: ttyS5 at MMIO 0x481aa000 (irq = 68, base_baud = 3000000) is a 8250
    [    1.398989] omap_rng 48310000.rng: Random Number Generator ver. 20
    [    1.408716] random: fast init done
    [    1.408979] random: crng init done
    [    1.421687] brd: module loaded
    [    1.432715] loop: module loaded
    [    1.449471] mdio_bus fixed-0: GPIO lookup for consumer reset
    [    1.449489] mdio_bus fixed-0: using lookup tables for GPIO lookup
    [    1.449496] mdio_bus fixed-0: No GPIO consumer reset found
    [    1.458388] mdio_bus 4a101000.mdio: GPIO lookup for consumer reset
    [    1.458404] mdio_bus 4a101000.mdio: using device tree for GPIO lookup
    [    1.458422] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp@44000000/interconnect@4a000000/segment@0/target-module@100000/switch@0/mdio@1000[0]'
    [    1.458456] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp@44000000/interconnect@4a000000/segment@0/target-module@100000/switch@0/mdio@1000[0]'
    [    1.458622] mdio_bus 4a101000.mdio: using lookup tables for GPIO lookup
    [    1.458632] mdio_bus 4a101000.mdio: No GPIO consumer reset found
    [    1.518526] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
    [    1.519743] mdio_bus 4a101000.mdio:05: GPIO lookup for consumer reset
    [    1.519759] mdio_bus 4a101000.mdio:05: using device tree for GPIO lookup
    [    1.519789] mdio_bus 4a101000.mdio:05: No GPIO consumer reset found
    [    1.520885] cpsw-switch 4a100000.switch: initialized cpsw ale version 1.4
    [    1.520900] cpsw-switch 4a100000.switch: ALE Table size 1024
    [    1.520994] cpsw-switch 4a100000.switch: cpts: overflow check period 500 (jiffies)
    [    1.521007] cpsw-switch 4a100000.switch: CPTS: ref_clk_freq:250000000 calc_mult:2147483648 calc_shift:29 error:0 nsec/sec
    [    1.521071] cpsw-switch 4a100000.switch: Detected MACID = 50:65:83:e0:52:b0
    [    1.521104] cpsw-switch 4a100000.switch: Detected MACID = 50:65:83:e0:52:b2
    [    1.523069] cpsw-switch 4a100000.switch: initialized (regs 0x4a100000, pool size 256) hw_ver:0019010F 1.15 (0)
    [    1.523851] PPP generic driver version 2.4.2
    [    1.524110] PPP BSD Compression module registered
    [    1.524118] PPP Deflate Compression module registered
    [    1.524135] PPP MPPE Compression module registered
    [    1.524141] NET: Registered protocol family 24
    [    1.526725] omap_rtc 44e3e000.rtc: char device (252:0)
    [    1.526757] omap_rtc 44e3e000.rtc: registered as rtc0
    [    1.526796] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01T00:00:00 UTC (946684800)
    [    1.526819] omap_rtc 44e3e000.rtc: GPIO lookup for consumer wp
    [    1.526826] omap_rtc 44e3e000.rtc: using device tree for GPIO lookup
    [    1.526845] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/interconnect@44c00000/segment@200000/target-module@3e000/rtc@0[0]'
    [    1.526887] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/interconnect@44c00000/segment@200000/target-module@3e000/rtc@0[0]'
    [    1.526915] omap_rtc 44e3e000.rtc: using lookup tables for GPIO lookup
    [    1.526922] omap_rtc 44e3e000.rtc: No GPIO consumer wp found
    [    1.527540] i2c /dev entries driver
    [    1.530583] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [    1.531644] sdhci: Secure Digital Host Controller Interface driver
    [    1.531652] sdhci: Copyright(c) Pierre Ossman
    [    1.532710] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.534051] sdhci-omap 48060000.mmc: GPIO lookup for consumer cd
    [    1.534063] sdhci-omap 48060000.mmc: using device tree for GPIO lookup
    [    1.534094] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@60000/mmc@0[0]' - status (0)
    [    1.534178] gpio gpiochip1: Persistence not supported for GPIO 21
    [    1.534194] omap_gpio 481ae000.gpio: Could not set line 21 debounce to 200000 microseconds (-22)
    [    1.534203] sdhci-omap 48060000.mmc: Got CD GPIO
    [    1.534210] sdhci-omap 48060000.mmc: GPIO lookup for consumer wp
    [    1.534215] sdhci-omap 48060000.mmc: using device tree for GPIO lookup
    [    1.534228] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@60000/mmc@0[0]'
    [    1.534257] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@60000/mmc@0[0]'
    [    1.534282] sdhci-omap 48060000.mmc: using lookup tables for GPIO lookup
    [    1.534288] sdhci-omap 48060000.mmc: No GPIO consumer wp found
    [    1.534425] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator
    [    1.535445] sdhci-omap 481d8000.mmc: GPIO lookup for consumer wp
    [    1.535461] sdhci-omap 481d8000.mmc: using device tree for GPIO lookup
    [    1.535477] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@100000/target-module@d8000/mmc@0[0]'
    [    1.535514] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@100000/target-module@d8000/mmc@0[0]'
    [    1.535539] sdhci-omap 481d8000.mmc: using lookup tables for GPIO lookup
    [    1.535546] sdhci-omap 481d8000.mmc: No GPIO consumer wp found
    [    1.535667] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
    [    1.536707] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/emu_sysg[0]' - status (0)
    [    1.536795] gpio gpiochip0: Persistence not supported for GPIO 12
    [    1.536805] gpio-12 (?): no flags found for gpios
    [    1.536949] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/emu_sysr[0]' - status (0)
    [    1.536975] gpio gpiochip0: Persistence not supported for GPIO 15
    [    1.536982] gpio-15 (?): no flags found for gpios
    [    1.537071] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/emu_usbg[0]' - status (0)
    [    1.537092] gpio gpiochip0: Persistence not supported for GPIO 13
    [    1.537098] gpio-13 (?): no flags found for gpios
    [    1.537717] sdhci-omap 47810000.mmc: GPIO lookup for consumer wp
    [    1.537731] sdhci-omap 47810000.mmc: using device tree for GPIO lookup
    [    1.537746] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/target-module@47810000/mmc@0[0]'
    [    1.537775] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/target-module@47810000/mmc@0[0]'
    [    1.537795] sdhci-omap 47810000.mmc: using lookup tables for GPIO lookup
    [    1.537802] sdhci-omap 47810000.mmc: No GPIO consumer wp found
    [    1.537935] sdhci-omap 47810000.mmc: supply vqmmc not found, using dummy regulator
    [    1.541611] NET: Registered protocol family 10
    [    1.542970] Segment Routing with IPv6
    [    1.543055] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    1.543768] NET: Registered protocol family 17
    [    1.544186] Key type dns_resolver registered
    [    1.544927] omap_voltage_late_init: Voltage driver support not added
    [    1.545519] printk: console [ttyS0]: printing thread started
    [    1.545582] Loading compiled-in X.509 certificates
    [    1.601362] reg-fixed-voltage fixed-regulator-wlen: GPIO lookup for consumer (null)
    [    1.601383] reg-fixed-voltage fixed-regulator-wlen: using device tree for GPIO lookup
    [    1.601401] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/fixed-regulator-wlen[0]'
    [    1.601447] reg-fixed-voltage fixed-regulator-wlen: No GPIO consumer (null) found
    [    1.603051] i2c i2c-0: GPIO lookup for consumer scl
    [    1.603067] i2c i2c-0: using device tree for GPIO lookup
    [    1.603087] of_get_named_gpiod_flags: can't parse 'scl-gpios' property of node '/ocp@44000000/interconnect@44c00000/segment@200000/target-module@b000/i2c@0[0]'
    [    1.603119] of_get_named_gpiod_flags: can't parse 'scl-gpio' property of node '/ocp@44000000/interconnect@44c00000/segment@200000/target-module@b000/i2c@0[0]'
    [    1.603145] i2c i2c-0: using lookup tables for GPIO lookup
    [    1.603152] i2c i2c-0: No GPIO consumer scl found
    [    1.603171] i2c i2c-0: GPIO lookup for consumer sda
    [    1.603176] i2c i2c-0: using device tree for GPIO lookup
    [    1.603187] of_get_named_gpiod_flags: can't parse 'sda-gpios' property of node '/ocp@44000000/interconnect@44c00000/segment@200000/target-module@b000/i2c@0[0]'
    [    1.603214] of_get_named_gpiod_flags: can't parse 'sda-gpio' property of node '/ocp@44000000/interconnect@44c00000/segment@200000/target-module@b000/i2c@0[0]'
    [    1.603237] i2c i2c-0: using lookup tables for GPIO lookup
    [    1.603242] i2c i2c-0: No GPIO consumer sda found
    [    1.639128] tps65218-pwrbutton: Failed to locate of_node [id: -2]
    [    1.639452] tps65218-gpio: Failed to locate of_node [id: -2]
    [    1.653565] omap_i2c 44e0b000.i2c: bus 0 rev0.12 at 100 kHz
    [    1.654538] gpio gpiochip3: (gpio-96-127): added GPIO chardev (254:3)
    [    1.654649] gpio gpiochip3: registered GPIOs 96 to 127 on gpio-96-127
    [    1.660845] gpio gpiochip4: (gpio-128-159): added GPIO chardev (254:4)
    [    1.660943] gpio gpiochip4: registered GPIOs 128 to 159 on gpio-128-159
    [    1.662092] gpio gpiochip5: (gpio-160-191): added GPIO chardev (254:5)
    [    1.662197] gpio gpiochip5: registered GPIOs 160 to 191 on gpio-160-191
    [    1.682852] omap_reset_deassert: timedout waiting for gfx:0
    [    1.682934] ti-sysc: probe of 5600fe00.target-module failed with error -110
    [    1.684328] mdio_bus 4a101000.mdio: GPIO lookup for consumer reset
    [    1.684342] mdio_bus 4a101000.mdio: using device tree for GPIO lookup
    [    1.684373] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp@44000000/interconnect@4a000000/segment@0/target-module@100000/switch@0/mdio@1000[0]'
    [    1.684409] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp@44000000/interconnect@4a000000/segment@0/target-module@100000/switch@0/mdio@1000[0]'
    [    1.684439] mdio_bus 4a101000.mdio: using lookup tables for GPIO lookup
    [    1.684446] mdio_bus 4a101000.mdio: No GPIO consumer reset found
    [    1.738713] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
    [    1.761283] mdio_bus 4a101000.mdio:05: GPIO lookup for consumer reset
    [    1.761299] mdio_bus 4a101000.mdio:05: using device tree for GPIO lookup
    [    1.761333] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/ocp@44000000/interconnect@4a000000/segment@0/target-module@100000/switch@0/mdio@1000/ethernet-phy@5[0]' - status (0)
    [    1.761437] gpio gpiochip3: Persistence not supported for GPIO 28
    [    1.779136] mdio_bus 4a101000.mdio:04: GPIO lookup for consumer reset
    [    1.779153] mdio_bus 4a101000.mdio:04: using device tree for GPIO lookup
    [    1.779185] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/ocp@44000000/interconnect@4a000000/segment@0/target-module@100000/switch@0/mdio@1000/ethernet-phy@4[0]' - status (0)
    [    1.779288] gpio gpiochip5: Persistence not supported for GPIO 10
    [    1.788733] davinci_mdio 4a101000.mdio: phy[4]: device 4a101000.mdio:04, driver Micrel KSZ9031 Gigabit PHY
    [    1.788749] davinci_mdio 4a101000.mdio: phy[5]: device 4a101000.mdio:05, driver Micrel KSZ9031 Gigabit PHY
    [    1.790400] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/emu_sysg[0]' - status (0)
    [    1.790441] gpio gpiochip0: Persistence not supported for GPIO 12
    [    1.790449] gpio-12 (?): no flags found for gpios
    [    1.790652] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/emu_sysr[0]' - status (0)
    [    1.790676] gpio gpiochip0: Persistence not supported for GPIO 15
    [    1.790682] gpio-15 (?): no flags found for gpios
    [    1.790771] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/emu_usbg[0]' - status (0)
    [    1.790794] gpio gpiochip0: Persistence not supported for GPIO 13
    [    1.790801] gpio-13 (?): no flags found for gpios
    [    1.790910] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/emu_user1g[0]' - status (0)
    [    1.790980] gpio gpiochip4: Persistence not supported for GPIO 2
    [    1.790988] gpio-130 (?): no flags found for gpios
    [    1.791085] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/emu_user3g[0]' - status (0)
    [    1.791108] gpio gpiochip3: Persistence not supported for GPIO 29
    [    1.791115] gpio-125 (?): no flags found for gpios
    [    1.791362] reg-fixed-voltage fixed-regulator-wlen: GPIO lookup for consumer (null)
    [    1.791371] reg-fixed-voltage fixed-regulator-wlen: using device tree for GPIO lookup
    [    1.791385] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/fixed-regulator-wlen[0]'
    [    1.791416] of_get_named_gpiod_flags: parsed 'gpio' property of node '/fixed-regulator-wlen[0]' - status (0)
    [    1.791438] gpio gpiochip5: Persistence not supported for GPIO 29
    [    1.792426] sdhci-omap 48060000.mmc: GPIO lookup for consumer cd
    [    1.792441] sdhci-omap 48060000.mmc: using device tree for GPIO lookup
    [    1.792470] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@60000/mmc@0[0]' - status (0)
    [    1.792557] gpio gpiochip1: Persistence not supported for GPIO 21
    [    1.792573] omap_gpio 481ae000.gpio: Could not set line 21 debounce to 200000 microseconds (-22)
    [    1.792583] sdhci-omap 48060000.mmc: Got CD GPIO
    [    1.792590] sdhci-omap 48060000.mmc: GPIO lookup for consumer wp
    [    1.792596] sdhci-omap 48060000.mmc: using device tree for GPIO lookup
    [    1.792609] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@60000/mmc@0[0]'
    [    1.792638] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@60000/mmc@0[0]'
    [    1.792664] sdhci-omap 48060000.mmc: using lookup tables for GPIO lookup
    [    1.792671] sdhci-omap 48060000.mmc: No GPIO consumer wp found
    [    1.792820] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator
    [    1.797026] sdhci-omap 481d8000.mmc: GPIO lookup for consumer wp
    [    1.797046] sdhci-omap 481d8000.mmc: using device tree for GPIO lookup
    [    1.797064] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@100000/target-module@d8000/mmc@0[0]'
    [    1.797104] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@100000/target-module@d8000/mmc@0[0]'
    [    1.797130] sdhci-omap 481d8000.mmc: using lookup tables for GPIO lookup
    [    1.797138] sdhci-omap 481d8000.mmc: No GPIO consumer wp found
    [    1.797300] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
    [    1.799441] sdhci-omap 47810000.mmc: GPIO lookup for consumer wp
    [    1.799458] sdhci-omap 47810000.mmc: using device tree for GPIO lookup
    [    1.799475] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/target-module@47810000/mmc@0[0]'
    [    1.799509] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/target-module@47810000/mmc@0[0]'
    [    1.799530] sdhci-omap 47810000.mmc: using lookup tables for GPIO lookup
    [    1.799538] sdhci-omap 47810000.mmc: No GPIO consumer wp found
    [    1.799699] sdhci-omap 47810000.mmc: supply vqmmc not found, using dummy regulator
    [    1.832904] mmc1: SDHCI controller on 481d8000.mmc [481d8000.mmc] using External DMA
    [    1.838570] mmc2: SDHCI controller on 47810000.mmc [47810000.mmc] using External DMA
    [    1.839338] mmc0: SDHCI controller on 48060000.mmc [48060000.mmc] using External DMA
    [    1.840160] Waiting for root device PARTUUID=2ff1f17b-02...
    [    1.847194] sdhci-omap 47810000.mmc: card claims to support voltages below defined range
    [    1.915010] mmc1: new high speed MMC card at address 0001
    [    1.925792] mmcblk1: mmc1:0001 MMC32G 29.1 GiB
    [    1.926308] mmcblk1boot0: mmc1:0001 MMC32G partition 1 4.00 MiB
    [    1.926809] mmcblk1boot1: mmc1:0001 MMC32G partition 2 4.00 MiB
    [    1.927135] mmcblk1rpmb: mmc1:0001 MMC32G partition 3 4.00 MiB, chardev (244:0)
    [    1.930078]  mmcblk1: p1 p2
    [    1.985140] mmc2: new high speed SDIO card at address 0001
    [    2.107953] EXT4-fs (mmcblk1p2): recovery complete
    [    2.120490] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    2.120585] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    2.122326] devtmpfs: mounted
    [    2.124149] Freeing unused kernel memory: 1024K
    [    2.124328] Run /sbin/init as init process
    [    2.124333]   with arguments:
    [    2.124336]     /sbin/init
    [    2.124338]   with environment:
    [    2.124341]     HOME=/
    [    2.124344]     TERM=linux
    [    2.483607] systemd[1]: System time before build time, advancing clock.
    [    2.558445] systemd[1]: systemd 247.3-7+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
    [    2.559353] systemd[1]: Detected architecture arm.
    [    2.613066] systemd[1]: Set hostname to <adlink>.
    [    4.225702] systemd[1]: Queued start job for default target Graphical Interface.
    [    4.228203] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    4.228236] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    4.242410] systemd[1]: Created slice system-getty.slice.
    [    4.290955] systemd[1]: Created slice system-modprobe.slice.
    [    4.321204] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [    4.350537] systemd[1]: Created slice User and Session Slice.
    [    4.379334] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    4.409246] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    4.439191] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
    [    4.439611] systemd[1]: Reached target Local Encrypted Volumes.
    [    4.469171] systemd[1]: Reached target Paths.
    [    4.498989] systemd[1]: Reached target Slices.
    [    4.528895] systemd[1]: Reached target Swap.
    [    4.560346] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    4.589785] systemd[1]: Listening on Syslog Socket.
    [    4.619377] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    4.676518] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    4.677804] systemd[1]: Listening on Journal Socket (/dev/log).
    [    4.729912] systemd[1]: Listening on Journal Socket.
    [    4.765073] systemd[1]: Listening on udev Control Socket.
    [    4.799633] systemd[1]: Listening on udev Kernel Socket.
    [    4.829564] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
    [    4.835364] systemd[1]: Mounting POSIX Message Queue File System...
    [    4.888826] systemd[1]: Mounting NFSD configuration filesystem...
    [    4.934903] systemd[1]: Mounting RPC Pipe File System...
    [    4.979355] systemd[1]: Mounting Kernel Debug File System...
    [    5.009671] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
    [    5.010062] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
    [    5.010816] systemd[1]: Condition check resulted in Create list of static device nodes for the current kernel being skipped.
    [    5.017850] systemd[1]: Starting Load Kernel Module configfs...
    [    5.105470] systemd[1]: Starting Load Kernel Module drm...
    [    5.155568] systemd[1]: Starting Load Kernel Module fuse...
    [    5.205235] systemd[1]: Started Nameserver information manager.
    [    5.280821] systemd[1]: Reached target Network (Pre).
    [    5.311998] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
    [    5.334279] systemd[1]: Starting Journal Service...
    [    5.391819] systemd[1]: Starting Load Kernel Modules...
    [    5.425307] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    5.515546] systemd[1]: Starting Coldplug All udev Devices...
    [    5.600318] systemd[1]: Mounted POSIX Message Queue File System.
    [    5.650078] systemd[1]: proc-fs-nfsd.mount: Mount process exited, code=exited, status=32/n/a
    [    5.650124] systemd[1]: proc-fs-nfsd.mount: Failed with result 'exit-code'.
    [    5.651896] systemd[1]: Failed to mount NFSD configuration filesystem.
    [    5.678697] usbcore: registered new interface driver usbfs
    [    5.678783] usbcore: registered new interface driver hub
    [    5.678870] usbcore: registered new device driver usb
    [    5.689257] xr_usb_serial_common: loading out-of-tree module taints kernel.
    [    5.691381] usbcore: registered new interface driver cdc_xr_usb_serial
    [    5.691394] xr_usb_serial_common: Exar/MxL USB UART (serial port) driver version 1D
    [    5.832616] systemd[1]: Dependency failed for NFS server and services.
    [    5.868950] systemd[1]: Dependency failed for NFSv4 ID-name mapping service.
    [    5.932763] systemd[1]: nfs-idmapd.service: Job nfs-idmapd.service/start failed with result 'dependency'.
    [    5.932872] systemd[1]: Dependency failed for NFS Mount Daemon.
    [    5.994220] systemd[1]: nfs-mountd.service: Job nfs-mountd.service/start failed with result 'dependency'.
    [    5.994320] systemd[1]: nfs-server.service: Job nfs-server.service/start failed with result 'dependency'.
    [    5.996208] systemd[1]: Mounted RPC Pipe File System.
    [    6.040123] systemd[1]: Mounted Kernel Debug File System.
    [    6.111713] systemd[1]: modprobe@configfs.service: Succeeded.
    [    6.119067] systemd[1]: Finished Load Kernel Module configfs.
    [    6.181201] systemd[1]: modprobe@drm.service: Succeeded.
    [    6.189059] systemd[1]: Finished Load Kernel Module drm.
    [    6.241115] systemd[1]: modprobe@fuse.service: Succeeded.
    [    6.254711] systemd[1]: Finished Load Kernel Module fuse.
    [    6.293344] systemd[1]: Finished Load Kernel Modules.
    [    6.331577] systemd[1]: Finished Remount Root and Kernel File Systems.
    [    6.369882] systemd[1]: Started Journal Service.
    [    6.869745] systemd-journald[134]: Received client request to flush runtime journal.
    [    6.898403] systemd-journald[134]: File /var/log/journal/7543c031571a4b9682570c838d2fb5f8/system.journal corrupted or uncleanly shut down, renaming and replacing.
    [   13.571623] remoteproc remoteproc0: wkup_m3 is available
    [   15.140229] remoteproc remoteproc0: powering up wkup_m3
    [   15.145821] remoteproc remoteproc0: Direct firmware load for am335x-pm-firmware.elf failed with error -2
    [   15.145854] remoteproc remoteproc0: request_firmware failed: -2
    [   15.145864] wkup_m3_ipc 44e11324.wkup_m3_ipc: rproc_boot failed
    [   19.608871] omap-sham 53100000.sham: hw accel on OMAP rev 0.0
    [   19.610822] omap-aes 53501000.aes: OMAP AES hw accel rev: 0.1
    [   19.614104] omap-des 53701000.des: OMAP DES hw accel rev: 0.33
    [   19.644267] omap-sham 53100000.sham: will run requests pump with realtime priority
    [   19.644521] omap-aes 53501000.aes: will run requests pump with realtime priority
    [   19.644886] omap-des 53701000.des: will run requests pump with realtime priority
    [   20.580964] PM: Cannot get wkup_m3_ipc handle
    [   21.095101] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [   26.037725] PM: Cannot get wkup_m3_ipc handle
    [   26.052463] PM: Cannot get wkup_m3_ipc handle
    [   26.199014] PM: Cannot get wkup_m3_ipc handle
    [   26.348051] PM: Cannot get wkup_m3_ipc handle
    [   26.363604] PM: Cannot get wkup_m3_ipc handle
    [   26.381634] remoteproc remoteproc1: 54434000.pru is available
    [   26.382287] PM: Cannot get wkup_m3_ipc handle
    [   26.382897] remoteproc remoteproc2: 54438000.pru is available
    [   26.410356] remoteproc remoteproc3: 54474000.pru is available
    [   26.425438] PM: Cannot get wkup_m3_ipc handle
    [   26.429383] remoteproc remoteproc4: 54478000.pru is available
    [   26.430035] PM: Cannot get wkup_m3_ipc handle
    [   26.473438] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [   26.486741] cpsw-switch 4a100000.switch eth0: renamed from eto1
    [   26.595795] cpsw-switch 4a100000.switch eth1: renamed from eto0
    [   27.366802] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
    [   27.367046] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 1
    [   27.367922] xhci-hcd xhci-hcd.5.auto: hcc params 0x0238f06d hci version 0x100 quirks 0x0000000002010010
    [   27.386571] xhci-hcd xhci-hcd.5.auto: irq 94, io mem 0x48390000
    [   27.387119] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [   27.387137] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   27.387146] usb usb1: Product: xHCI Host Controller
    [   27.387152] usb usb1: Manufacturer: Linux 5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc xhci-hcd
    [   27.387158] usb usb1: SerialNumber: xhci-hcd.5.auto
    [   27.400201] hub 1-0:1.0: USB hub found
    [   27.400315] hub 1-0:1.0: 1 port detected
    [   27.400888] PM: Cannot get wkup_m3_ipc handle
    [   27.410022] PM: Cannot get wkup_m3_ipc handle
    [   27.410305] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
    [   27.410333] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 2
    [   27.410356] xhci-hcd xhci-hcd.5.auto: Host supports USB 3.0 SuperSpeed
    [   27.419694] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [   27.419854] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [   27.419867] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   27.419876] usb usb2: Product: xHCI Host Controller
    [   27.419883] usb usb2: Manufacturer: Linux 5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc xhci-hcd
    [   27.419888] usb usb2: SerialNumber: xhci-hcd.5.auto
    [   27.420926] hub 2-0:1.0: USB hub found
    [   27.440425] hub 2-0:1.0: 1 port detected
    [   27.441082] PM: Cannot get wkup_m3_ipc handle
    [   27.441680] PM: Cannot get wkup_m3_ipc handle
    [   27.442059] PM: Cannot get wkup_m3_ipc handle
    [   27.442550] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
    [   27.442597] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 3
    [   27.457060] xhci-hcd xhci-hcd.6.auto: hcc params 0x0238f06d hci version 0x100 quirks 0x0000000002010010
    [   27.471056] xhci-hcd xhci-hcd.6.auto: irq 95, io mem 0x483d0000
    [   27.471608] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [   27.471625] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   27.471635] usb usb3: Product: xHCI Host Controller
    [   27.471641] usb usb3: Manufacturer: Linux 5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc xhci-hcd
    [   27.471647] usb usb3: SerialNumber: xhci-hcd.6.auto
    [   27.472597] hub 3-0:1.0: USB hub found
    [   27.472657] hub 3-0:1.0: 1 port detected
    [   27.473204] PM: Cannot get wkup_m3_ipc handle
    [   27.473778] PM: Cannot get wkup_m3_ipc handle
    [   27.474016] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
    [   27.474040] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 4
    [   27.474062] xhci-hcd xhci-hcd.6.auto: Host supports USB 3.0 SuperSpeed
    [   27.494735] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
    [   27.494899] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [   27.494914] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   27.494922] usb usb4: Product: xHCI Host Controller
    [   27.494929] usb usb4: Manufacturer: Linux 5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc xhci-hcd
    [   27.495072] usb usb4: SerialNumber: xhci-hcd.6.auto
    [   27.495932] hub 4-0:1.0: USB hub found
    [   27.495989] hub 4-0:1.0: 1 port detected
    [   27.520356] PM: Cannot get wkup_m3_ipc handle
    [   27.603825] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [   27.698609] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [   27.878989] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
    [   27.879015] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [   27.922894] hub 1-1:1.0: USB hub found
    [   27.923804] hub 1-1:1.0: 4 ports detected
    [   27.988111] PM: Cannot get wkup_m3_ipc handle
    [   28.298599] usb 1-1.2: new full-speed USB device number 3 using xhci-hcd
    [   28.429757] usb 1-1.2: New USB device found, idVendor=04e2, idProduct=1412, bcdDevice= 0.03
    [   28.429784] usb 1-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [   28.544792] cdc_xr_usb_serial 1-1.2:1.0: USB_device_id idVendor:04e2, idProduct 1412
    [   28.544819] cdc_xr_usb_serial 1-1.2:1.0: This device cannot do calls on its own. It is not a modem.
    [   28.544829] cdc_xr_usb_serial 1-1.2:1.0: The data interface has switched endpoints
    [   28.544834] cdc_xr_usb_serial 1-1.2:1.0: interfaces are valid
    [   28.544850] cdc_xr_usb_serial 1-1.2:1.0: epwrite->bEndpointAddress =1
    [   28.546588] cdc_xr_usb_serial 1-1.2:1.0: ttyXR_USB_SERIAL0: USB XR_USB_SERIAL device
    [   28.550150] gpio gpiochip6: GPIO integer space overlap, cannot add chip
    [   28.550171] gpiochip_add_data_with_key: GPIOs 0..9 (1-1.2:1.0) failed to register, -16
    [   28.550188] gpio gpiochip6: GPIO integer space overlap, cannot add chip
    [   28.550194] gpiochip_add_data_with_key: GPIOs 10..19 (1-1.2:1.0) failed to register, -16
    [   28.550207] gpio gpiochip6: GPIO integer space overlap, cannot add chip
    [   28.550213] gpiochip_add_data_with_key: GPIOs 20..29 (1-1.2:1.0) failed to register, -16
    [   28.550224] gpio gpiochip6: GPIO integer space overlap, cannot add chip
    [   28.550229] gpiochip_add_data_with_key: GPIOs 30..39 (1-1.2:1.0) failed to register, -16
    [   28.550240] gpio gpiochip6: GPIO integer space overlap, cannot add chip
    [   28.550246] gpiochip_add_data_with_key: GPIOs 40..49 (1-1.2:1.0) failed to register, -16
    [   28.550257] gpio gpiochip6: GPIO integer space overlap, cannot add chip
    [   28.550262] gpiochip_add_data_with_key: GPIOs 50..59 (1-1.2:1.0) failed to register, -16
    [   28.550273] gpio gpiochip6: GPIO integer space overlap, cannot add chip
    [   28.550278] gpiochip_add_data_with_key: GPIOs 60..69 (1-1.2:1.0) failed to register, -16
    [   28.550288] gpio gpiochip6: GPIO integer space overlap, cannot add chip
    [   28.550294] gpiochip_add_data_with_key: GPIOs 70..79 (1-1.2:1.0) failed to register, -16
    [   28.550305] gpio gpiochip6: GPIO integer space overlap, cannot add chip
    [   28.550310] gpiochip_add_data_with_key: GPIOs 80..89 (1-1.2:1.0) failed to register, -16
    [   28.550321] gpio gpiochip6: GPIO integer space overlap, cannot add chip
    [   28.550326] gpiochip_add_data_with_key: GPIOs 90..99 (1-1.2:1.0) failed to register, -16
    [   28.550336] gpio gpiochip6: GPIO integer space overlap, cannot add chip
    [   28.550342] gpiochip_add_data_with_key: GPIOs 100..109 (1-1.2:1.0) failed to register, -16
    [   28.550352] gpio gpiochip6: GPIO integer space overlap, cannot add chip
    [   28.550358] gpiochip_add_data_with_key: GPIOs 110..119 (1-1.2:1.0) failed to register, -16
    [   28.550369] gpio gpiochip6: GPIO integer space overlap, cannot add chip
    [   28.550374] gpiochip_add_data_with_key: GPIOs 120..129 (1-1.2:1.0) failed to register, -16
    [   28.550384] gpio gpiochip6: GPIO integer space overlap, cannot add chip
    [   28.550389] gpiochip_add_data_with_key: GPIOs 130..139 (1-1.2:1.0) failed to register, -16
    [   28.550400] gpio gpiochip6: GPIO integer space overlap, cannot add chip
    [   28.550405] gpiochip_add_data_with_key: GPIOs 140..149 (1-1.2:1.0) failed to register, -16
    [   28.550416] gpio gpiochip6: GPIO integer space overlap, cannot add chip
    [   28.551168] gpiochip_add_data_with_key: GPIOs 150..159 (1-1.2:1.0) failed to register, -16
    [   28.551213] gpio gpiochip6: GPIO integer space overlap, cannot add chip
    [   28.551222] gpiochip_add_data_with_key: GPIOs 160..169 (1-1.2:1.0) failed to register, -16
    [   28.551235] gpio gpiochip6: GPIO integer space overlap, cannot add chip
    [   28.551241] gpiochip_add_data_with_key: GPIOs 170..179 (1-1.2:1.0) failed to register, -16
    [   28.551252] gpio gpiochip6: GPIO integer space overlap, cannot add chip
    [   28.551258] gpiochip_add_data_with_key: GPIOs 180..189 (1-1.2:1.0) failed to register, -16
    [   28.551269] gpio gpiochip6: GPIO integer space overlap, cannot add chip
    [   28.551274] gpiochip_add_data_with_key: GPIOs 190..199 (1-1.2:1.0) failed to register, -16
    [   28.554647] gpio gpiochip6: (1-1.2:1.0): added GPIO chardev (254:6)
    [   28.554838] gpio gpiochip6: registered GPIOs 200 to 209 on 1-1.2:1.0
    [   28.554854] cdc_xr_usb_serial 1-1.2:1.0: gpiochip200 added
    [   28.555452] cdc_xr_usb_serial 1-1.2:1.2: USB_device_id idVendor:04e2, idProduct 1412
    [   28.555470] cdc_xr_usb_serial 1-1.2:1.2: This device cannot do calls on its own. It is not a modem.
    [   28.555481] cdc_xr_usb_serial 1-1.2:1.2: The data interface has switched endpoints
    [   28.555486] cdc_xr_usb_serial 1-1.2:1.2: interfaces are valid
    [   28.555503] cdc_xr_usb_serial 1-1.2:1.2: epwrite->bEndpointAddress =2
    [   28.555868] PM: Cannot get wkup_m3_ipc handle
    [   28.571443] PM: Cannot get wkup_m3_ipc handle
    [   28.606008] cdc_xr_usb_serial 1-1.2:1.2: ttyXR_USB_SERIAL1: USB XR_USB_SERIAL device
    [   28.610654] gpio gpiochip7: GPIO integer space overlap, cannot add chip
    [   28.610675] gpiochip_add_data_with_key: GPIOs 0..9 (1-1.2:1.2) failed to register, -16
    [   28.610692] gpio gpiochip7: GPIO integer space overlap, cannot add chip
    [   28.610698] gpiochip_add_data_with_key: GPIOs 10..19 (1-1.2:1.2) failed to register, -16
    [   28.610710] gpio gpiochip7: GPIO integer space overlap, cannot add chip
    [   28.610716] gpiochip_add_data_with_key: GPIOs 20..29 (1-1.2:1.2) failed to register, -16
    [   28.610728] gpio gpiochip7: GPIO integer space overlap, cannot add chip
    [   28.610733] gpiochip_add_data_with_key: GPIOs 30..39 (1-1.2:1.2) failed to register, -16
    [   28.610745] gpio gpiochip7: GPIO integer space overlap, cannot add chip
    [   28.610750] gpiochip_add_data_with_key: GPIOs 40..49 (1-1.2:1.2) failed to register, -16
    [   28.610761] gpio gpiochip7: GPIO integer space overlap, cannot add chip
    [   28.610766] gpiochip_add_data_with_key: GPIOs 50..59 (1-1.2:1.2) failed to register, -16
    [   28.610778] gpio gpiochip7: GPIO integer space overlap, cannot add chip
    [   28.610783] gpiochip_add_data_with_key: GPIOs 60..69 (1-1.2:1.2) failed to register, -16
    [   28.610795] gpio gpiochip7: GPIO integer space overlap, cannot add chip
    [   28.610799] gpiochip_add_data_with_key: GPIOs 70..79 (1-1.2:1.2) failed to register, -16
    [   28.610811] gpio gpiochip7: GPIO integer space overlap, cannot add chip
    [   28.610815] gpiochip_add_data_with_key: GPIOs 80..89 (1-1.2:1.2) failed to register, -16
    [   28.610827] gpio gpiochip7: GPIO integer space overlap, cannot add chip
    [   28.610832] gpiochip_add_data_with_key: GPIOs 90..99 (1-1.2:1.2) failed to register, -16
    [   28.610843] gpio gpiochip7: GPIO integer space overlap, cannot add chip
    [   28.610848] gpiochip_add_data_with_key: GPIOs 100..109 (1-1.2:1.2) failed to register, -16
    [   28.610859] gpio gpiochip7: GPIO integer space overlap, cannot add chip
    [   28.610864] gpiochip_add_data_with_key: GPIOs 110..119 (1-1.2:1.2) failed to register, -16
    [   28.610874] gpio gpiochip7: GPIO integer space overlap, cannot add chip
    [   28.610880] gpiochip_add_data_with_key: GPIOs 120..129 (1-1.2:1.2) failed to register, -16
    [   28.610890] gpio gpiochip7: GPIO integer space overlap, cannot add chip
    [   28.610895] gpiochip_add_data_with_key: GPIOs 130..139 (1-1.2:1.2) failed to register, -16
    [   28.610906] gpio gpiochip7: GPIO integer space overlap, cannot add chip
    [   28.610911] gpiochip_add_data_with_key: GPIOs 140..149 (1-1.2:1.2) failed to register, -16
    [   28.610922] gpio gpiochip7: GPIO integer space overlap, cannot add chip
    [   28.610927] gpiochip_add_data_with_key: GPIOs 150..159 (1-1.2:1.2) failed to register, -16
    [   28.610938] gpio gpiochip7: GPIO integer space overlap, cannot add chip
    [   28.610943] gpiochip_add_data_with_key: GPIOs 160..169 (1-1.2:1.2) failed to register, -16
    [   28.610954] gpio gpiochip7: GPIO integer space overlap, cannot add chip
    [   28.610959] gpiochip_add_data_with_key: GPIOs 170..179 (1-1.2:1.2) failed to register, -16
    [   28.610970] gpio gpiochip7: GPIO integer space overlap, cannot add chip
    [   28.610974] gpiochip_add_data_with_key: GPIOs 180..189 (1-1.2:1.2) failed to register, -16
    [   28.610985] gpio gpiochip7: GPIO integer space overlap, cannot add chip
    [   28.610990] gpiochip_add_data_with_key: GPIOs 190..199 (1-1.2:1.2) failed to register, -16
    [   28.611000] gpio gpiochip7: GPIO integer space overlap, cannot add chip
    [   28.611005] gpiochip_add_data_with_key: GPIOs 200..209 (1-1.2:1.2) failed to register, -16
    [   28.611224] gpio gpiochip7: (1-1.2:1.2): added GPIO chardev (254:7)
    [   28.611337] gpio gpiochip7: registered GPIOs 210 to 219 on 1-1.2:1.2
    [   28.611349] cdc_xr_usb_serial 1-1.2:1.2: gpiochip210 added
    [   28.612171] PM: Cannot get wkup_m3_ipc handle
    [   28.933613] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
    [   28.947106] wlcore: loaded
    [   33.132521] cpsw-switch 4a100000.switch: starting ndev. mode: dual_mac
    [   33.249765] Micrel KSZ9031 Gigabit PHY 4a101000.mdio:04: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=4a101000.mdio:04, irq=POLL)
    [  126.537718] cpsw-switch 4a100000.switch: starting ndev. mode: dual_mac
    [  126.669767] Micrel KSZ9031 Gigabit PHY 4a101000.mdio:05: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=4a101000.mdio:05, irq=POLL)
    [  130.800165] cpsw-switch 4a100000.switch eth1: Link is Up - 1Gbps/Full - flow control off
    [  130.800235] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
    [  201.842792] wlcore: using inverted interrupt logic: 8
    [  201.943550] wlcore: PHY firmware version: Rev 8.2.0.0.245
    [  202.069255] wlcore: firmware booted (Rev 8.9.0.0.86)
    [  211.840582] wlan0: authenticate with 54:b8:0a:13:1e:66
    [  211.856498] wlan0: send auth to 54:b8:0a:13:1e:66 (try 1/3)
    [  211.878825] wlan0: authenticated
    [  211.889868] wlan0: associate with 54:b8:0a:13:1e:66 (try 1/3)
    [  211.899025] wlan0: RX AssocResp from 54:b8:0a:13:1e:66 (capab=0x431 status=0 aid=2)
    [  211.939430] wlan0: associated
    [  212.034324] cryptd: max_cpu_qlen set to 1000
    [  212.183257] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
    [  212.186473] wlcore: Association completed.
    [ 1009.758487] mmc2: Timeout waiting for hardware interrupt.
    [ 1009.758505] mmc2: sdhci: ============ SDHCI REGISTER DUMP ===========
    [ 1009.758511] mmc2: sdhci: Sys addr:  0x00000000 | Version:  0x00003101
    [ 1009.758519] mmc2: sdhci: Blk size:  0x00000100 | Blk cnt:  0x00000001
    [ 1009.758524] mmc2: sdhci: Argument:  0x20c22900 | Trn mode: 0x00000013
    [ 1009.758530] mmc2: sdhci: Present:   0x01f70a06 | Host ctl: 0x00000002
    [ 1009.758536] mmc2: sdhci: Power:     0x0000000f | Blk gap:  0x00000000
    [ 1009.758541] mmc2: sdhci: Wake-up:   0x00000000 | Clock:    0x00000087
    [ 1009.758546] mmc2: sdhci: Timeout:   0x0000000d | Int stat: 0x00000000
    [ 1009.758550] mmc2: sdhci: Int enab:  0x027f000b | Sig enab: 0x027f000b
    [ 1009.758556] mmc2: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [ 1009.758561] mmc2: sdhci: Caps:      0x05e10080 | Caps_1:   0x00000000
    [ 1009.758567] mmc2: sdhci: Cmd:       0x0000353a | Max curr: 0x00000000
    [ 1009.758572] mmc2: sdhci: Resp[0]:   0x00001000 | Resp[1]:  0x00000000
    [ 1009.758577] mmc2: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
    [ 1009.758581] mmc2: sdhci: Host ctl2: 0x00000000
    [ 1009.758585] mmc2: sdhci: ============================================
    [ 1009.758879] ------------[ cut here ]------------
    [ 1009.758888] WARNING: CPU: 0 PID: 666 at drivers/net/wireless/ti/wlcore/sdio.c:78 wl12xx_sdio_raw_read+0x104/0x160 [wlcore_sdio]
    [ 1009.758931] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1009.759051] CPU: 0 PID: 666 Comm: irq/93-wl18xx Tainted: G           O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1009.759063] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1009.759077] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1009.759109] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1009.759138] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [ 1009.759153] [<c09a0a50>] (warn_slowpath_fmt) from [<bf057354>] (wl12xx_sdio_raw_read+0x104/0x160 [wlcore_sdio])
    [ 1009.759182] [<bf057354>] (wl12xx_sdio_raw_read [wlcore_sdio]) from [<bf284428>] (wlcore_rx+0x1d0/0x760 [wlcore])
    [ 1009.759597] [<bf284428>] (wlcore_rx [wlcore]) from [<bf278868>] (wlcore_irq_locked+0x478/0x714 [wlcore])
    [ 1009.759827] [<bf278868>] (wlcore_irq_locked [wlcore]) from [<bf27af14>] (wlcore_irq+0xd8/0x1a8 [wlcore])
    [ 1009.760040] [<bf27af14>] (wlcore_irq [wlcore]) from [<c016b67c>] (irq_thread_fn+0x1c/0x78)
    [ 1009.760177] [<c016b67c>] (irq_thread_fn) from [<c016b8f4>] (irq_thread+0x108/0x260)
    [ 1009.760197] [<c016b8f4>] (irq_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1009.760220] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1009.760237] Exception stack(0xc28abfb0 to 0xc28abff8)
    [ 1009.760245] bfa0:                                     00000000 00000000 00000000 00000000
    [ 1009.760254] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1009.760261] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1009.760267] ---[ end trace 0000000000000002 ]---
    [ 1010.118558] wl1271_sdio mmc2:0001:2: sdio read failed (-110)
    [ 1010.118586] ------------[ cut here ]------------
    [ 1010.118590] WARNING: CPU: 0 PID: 666 at drivers/net/wireless/ti/wlcore/main.c:803 wl12xx_queue_recovery_work+0x68/0x6c [wlcore]
    [ 1010.118988] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1010.119107] CPU: 0 PID: 666 Comm: irq/93-wl18xx Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1010.119119] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1010.119133] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1010.119166] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1010.119194] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [ 1010.119210] [<c09a0a50>] (warn_slowpath_fmt) from [<bf27a7d0>] (wl12xx_queue_recovery_work+0x68/0x6c [wlcore])
    [ 1010.119374] [<bf27a7d0>] (wl12xx_queue_recovery_work [wlcore]) from [<bf27afc8>] (wlcore_irq+0x18c/0x1a8 [wlcore])
    [ 1010.119596] [<bf27afc8>] (wlcore_irq [wlcore]) from [<c016b67c>] (irq_thread_fn+0x1c/0x78)
    [ 1010.119735] [<c016b67c>] (irq_thread_fn) from [<c016b8f4>] (irq_thread+0x108/0x260)
    [ 1010.119753] [<c016b8f4>] (irq_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1010.119776] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1010.119792] Exception stack(0xc28abfb0 to 0xc28abff8)
    [ 1010.119801] bfa0:                                     00000000 00000000 00000000 00000000
    [ 1010.119809] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1010.119816] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1010.119822] ---[ end trace 0000000000000003 ]---
    [ 1010.200662] ------------[ cut here ]------------
    [ 1010.200676] WARNING: CPU: 0 PID: 1046 at drivers/net/wireless/ti/wlcore/main.c:803 wl12xx_queue_recovery_work+0x68/0x6c [wlcore]
    [ 1010.201094] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1010.201215] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1010.201228] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1010.201237] Workqueue: pm pm_runtime_work
    [ 1010.201274] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1010.201301] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1010.201329] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [ 1010.201345] [<c09a0a50>] (warn_slowpath_fmt) from [<bf27a7d0>] (wl12xx_queue_recovery_work+0x68/0x6c [wlcore])
    [ 1010.201515] [<bf27a7d0>] (wl12xx_queue_recovery_work [wlcore]) from [<bf27ae28>] (wlcore_runtime_suspend+0x144/0x158 [wlcore])
    [ 1010.201738] [<bf27ae28>] (wlcore_runtime_suspend [wlcore]) from [<c064d698>] (__rpm_callback+0xf8/0x160)
    [ 1010.201864] [<c064d698>] (__rpm_callback) from [<c064d754>] (rpm_callback+0x54/0x80)
    [ 1010.201879] [<c064d754>] (rpm_callback) from [<c064e360>] (rpm_suspend+0xe8/0x4c8)
    [ 1010.201894] [<c064e360>] (rpm_suspend) from [<c064eb14>] (pm_runtime_work+0xac/0xb8)
    [ 1010.201909] [<c064eb14>] (pm_runtime_work) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1010.201940] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1010.201958] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1010.201980] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1010.201996] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1010.202004] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1010.202012] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1010.202019] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1010.202025] ---[ end trace 0000000000000004 ]---
    [ 1012.121433] sched: RT throttling activated
    [ 1012.358553] wlcore: WARNING Enable for recovery failed
    [ 1012.358576] wlcore: Hardware recovery in progress. FW ver: Rev 8.9.0.0.86
    [ 1012.358594] wlcore: down
    [ 1012.358654] wlcore: down
    [ 1012.361028] ieee80211 phy0: Hardware restart was requested
    [ 1012.701664] wlcore: using inverted interrupt logic: 8
    [ 1014.153555] ------------[ cut here ]------------
    [ 1014.153570] WARNING: CPU: 0 PID: 1046 at drivers/net/wireless/ti/wlcore/sdio.c:123 wl12xx_sdio_raw_write+0x140/0x15c [wlcore_sdio]
    [ 1014.153617] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1014.153738] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1014.153750] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1014.153759] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1014.155118] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1014.155154] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1014.155184] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [ 1014.155201] [<c09a0a50>] (warn_slowpath_fmt) from [<bf057234>] (wl12xx_sdio_raw_write+0x140/0x15c [wlcore_sdio])
    [ 1014.155234] [<bf057234>] (wl12xx_sdio_raw_write [wlcore_sdio]) from [<bf287f28>] (wlcore_boot_upload_firmware+0x174/0x4a4 [wlcore])
    [ 1014.155628] [<bf287f28>] (wlcore_boot_upload_firmware [wlcore]) from [<bf175fcc>] (wl18xx_boot+0x910/0xd6c [wl18xx])
    [ 1014.155968] [<bf175fcc>] (wl18xx_boot [wl18xx]) from [<bf279de8>] (wl1271_op_add_interface+0x6d4/0x9c8 [wlcore])
    [ 1014.156170] [<bf279de8>] (wl1271_op_add_interface [wlcore]) from [<bf1dcf10>] (drv_add_interface+0x2c/0x7c [mac80211])
    [ 1014.157228] [<bf1dcf10>] (drv_add_interface [mac80211]) from [<bf213cc0>] (ieee80211_reconfig+0x2e8/0xf00 [mac80211])
    [ 1014.158049] [<bf213cc0>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1014.184634] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1014.186102] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1014.186124] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1014.186148] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1014.186166] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1014.186175] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1014.186183] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1014.186190] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1014.186197] ---[ end trace 0000000000000005 ]---
    [ 1014.418543] wl1271_sdio mmc2:0001:2: sdio write failed (-110)
    [ 1015.899210] mmc2: tried to HW reset card, got error -16
    [ 1017.500010] ------------[ cut here ]------------
    [ 1017.500027] WARNING: CPU: 0 PID: 1046 at drivers/net/wireless/ti/wlcore/sdio.c:123 wl12xx_sdio_raw_write+0x140/0x15c [wlcore_sdio]
    [ 1017.500078] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1017.500199] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1017.500212] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1017.500221] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1017.501578] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1017.501612] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1017.501642] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [ 1017.501658] [<c09a0a50>] (warn_slowpath_fmt) from [<bf057234>] (wl12xx_sdio_raw_write+0x140/0x15c [wlcore_sdio])
    [ 1017.501693] [<bf057234>] (wl12xx_sdio_raw_write [wlcore_sdio]) from [<bf280d5c>] (wlcore_set_partition+0xd4/0x510 [wlcore])
    [ 1017.502104] [<bf280d5c>] (wlcore_set_partition [wlcore]) from [<bf2753a8>] (wl12xx_set_power_on+0x7c/0x168 [wlcore])
    [ 1017.502328] [<bf2753a8>] (wl12xx_set_power_on [wlcore]) from [<bf279518>] (wl12xx_chip_wakeup+0x28/0x224 [wlcore])
    [ 1017.502543] [<bf279518>] (wl12xx_chip_wakeup [wlcore]) from [<bf279dd0>] (wl1271_op_add_interface+0x6bc/0x9c8 [wlcore])
    [ 1017.502756] [<bf279dd0>] (wl1271_op_add_interface [wlcore]) from [<bf1dcf10>] (drv_add_interface+0x2c/0x7c [mac80211])
    [ 1017.503683] [<bf1dcf10>] (drv_add_interface [mac80211]) from [<bf213cc0>] (ieee80211_reconfig+0x2e8/0xf00 [mac80211])
    [ 1017.504488] [<bf213cc0>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1017.505259] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1017.505684] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1017.505703] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1017.505725] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1017.505742] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1017.505750] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1017.505759] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1017.505766] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1017.505772] ---[ end trace 0000000000000006 ]---
    [ 1017.858519] wl1271_sdio mmc2:0001:2: sdio write failed (-16)
    [ 1019.320165] mmc2: tried to HW reset card, got error -16
    [ 1020.929444] ------------[ cut here ]------------
    [ 1020.929461] WARNING: CPU: 0 PID: 1046 at drivers/net/wireless/ti/wlcore/sdio.c:123 wl12xx_sdio_raw_write+0x140/0x15c [wlcore_sdio]
    [ 1020.929515] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1020.929638] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1020.929650] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1020.929660] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1020.931042] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1020.931076] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1020.931105] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [ 1020.931122] [<c09a0a50>] (warn_slowpath_fmt) from [<bf057234>] (wl12xx_sdio_raw_write+0x140/0x15c [wlcore_sdio])
    [ 1020.931156] [<bf057234>] (wl12xx_sdio_raw_write [wlcore_sdio]) from [<bf280d5c>] (wlcore_set_partition+0xd4/0x510 [wlcore])
    [ 1020.931580] [<bf280d5c>] (wlcore_set_partition [wlcore]) from [<bf2753a8>] (wl12xx_set_power_on+0x7c/0x168 [wlcore])
    [ 1020.931804] [<bf2753a8>] (wl12xx_set_power_on [wlcore]) from [<bf279518>] (wl12xx_chip_wakeup+0x28/0x224 [wlcore])
    [ 1020.932016] [<bf279518>] (wl12xx_chip_wakeup [wlcore]) from [<bf279dd0>] (wl1271_op_add_interface+0x6bc/0x9c8 [wlcore])
    [ 1020.932227] [<bf279dd0>] (wl1271_op_add_interface [wlcore]) from [<bf1dcf10>] (drv_add_interface+0x2c/0x7c [mac80211])
    [ 1020.933153] [<bf1dcf10>] (drv_add_interface [mac80211]) from [<bf213cc0>] (ieee80211_reconfig+0x2e8/0xf00 [mac80211])
    [ 1020.933969] [<bf213cc0>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1020.934741] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1020.935167] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1020.935186] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1020.935209] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1020.935225] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1020.935234] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1020.935242] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1020.935249] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1020.935255] ---[ end trace 0000000000000007 ]---
    [ 1021.288515] wl1271_sdio mmc2:0001:2: sdio write failed (-16)
    [ 1021.987085] wlcore: ERROR firmware boot failed despite 3 retries
    [ 1021.987109] ------------[ cut here ]------------
    [ 1021.987113] WARNING: CPU: 0 PID: 1046 at net/mac80211/util.c:2385 ieee80211_reconfig+0xc38/0xf00 [mac80211]
    [ 1021.988469] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1022.001651] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1022.001666] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1022.001675] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1022.002950] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1022.002985] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1022.003016] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [ 1022.003033] [<c09a0a50>] (warn_slowpath_fmt) from [<bf214610>] (ieee80211_reconfig+0xc38/0xf00 [mac80211])
    [ 1022.003562] [<bf214610>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1022.004354] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1022.004782] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1022.004803] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1022.004825] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1022.004842] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1022.004850] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1022.004858] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1022.004866] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1022.004872] ---[ end trace 0000000000000008 ]---
    [ 1022.268508] ------------[ cut here ]------------
    [ 1022.268522] WARNING: CPU: 0 PID: 1046 at net/mac80211/driver-ops.c:97 drv_remove_interface+0x88/0x8c [mac80211]
    [ 1022.269951] p2p-dev-wlan0: Failed check-sdata-in-driver check, flags: 0x0
    [ 1022.269959] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1022.270077] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1022.270091] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1022.270101] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1022.270642] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1022.270675] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1022.270704] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [ 1022.270721] [<c09a0a84>] (warn_slowpath_fmt) from [<bf1dd074>] (drv_remove_interface+0x88/0x8c [mac80211])
    [ 1022.271201] [<bf1dd074>] (drv_remove_interface [mac80211]) from [<bf1f1890>] (ieee80211_do_stop+0x5d0/0x8a8 [mac80211])
    [ 1022.271992] [<bf1f1890>] (ieee80211_do_stop [mac80211]) from [<bf0bffb8>] (cfg80211_stop_p2p_device+0x58/0x150 [cfg80211])
    [ 1022.273431] [<bf0bffb8>] (cfg80211_stop_p2p_device [cfg80211]) from [<bf0c0224>] (cfg80211_shutdown_all_interfaces+0x98/0xe0 [cfg80211])
    [ 1022.273920] [<bf0c0224>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1022.274845] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1022.275647] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1022.276075] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1022.276095] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1022.276118] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1022.276133] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1022.276141] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1022.276150] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1022.276157] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1022.276163] ---[ end trace 0000000000000009 ]---
    [ 1022.628567] wlan0: deauthenticating from 54:b8:0a:13:1e:66 by local choice (Reason: 3=DEAUTH_LEAVING)
    [ 1022.628605] ------------[ cut here ]------------
    [ 1022.628609] WARNING: CPU: 0 PID: 1046 at net/mac80211/driver-ops.h:172 ieee80211_bss_info_change_notify+0xf4/0x178 [mac80211]
    [ 1022.630021] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [ 1022.630027] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1022.630147] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1022.630160] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1022.630170] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1022.630692] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1022.630724] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1022.630752] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [ 1022.630770] [<c09a0a84>] (warn_slowpath_fmt) from [<bf1db2c0>] (ieee80211_bss_info_change_notify+0xf4/0x178 [mac80211])
    [ 1022.631239] [<bf1db2c0>] (ieee80211_bss_info_change_notify [mac80211]) from [<bf21e6e0>] (ieee80211_set_disassoc+0x70/0x478 [mac80211])
    [ 1022.632029] [<bf21e6e0>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1022.632798] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1022.634254] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1022.634732] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1022.635190] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1022.635646] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1022.636099] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1022.636367] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1022.636395] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1022.636409] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1022.636424] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1022.636676] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1022.637675] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1022.659572] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1022.661023] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1022.661046] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1022.661068] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1022.661085] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1022.661094] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1022.661102] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1022.661109] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1022.661116] ---[ end trace 000000000000000a ]---
    [ 1023.048504] ------------[ cut here ]------------
    [ 1023.048518] WARNING: CPU: 0 PID: 1046 at net/mac80211/driver-ops.h:633 __ieee80211_flush_queues+0x144/0x148 [mac80211]
    [ 1023.049860] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [ 1023.049867] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1023.049988] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1023.050001] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1023.050011] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1023.050543] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1023.050577] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1023.050606] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [ 1023.050622] [<c09a0a84>] (warn_slowpath_fmt) from [<bf212b60>] (__ieee80211_flush_queues+0x144/0x148 [mac80211])
    [ 1023.051099] [<bf212b60>] (__ieee80211_flush_queues [mac80211]) from [<bf21e8e8>] (ieee80211_set_disassoc+0x278/0x478 [mac80211])
    [ 1023.051891] [<bf21e8e8>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1023.052657] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1023.054113] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1023.054593] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1023.055049] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1023.055507] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1023.055959] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1023.056226] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1023.056252] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1023.056266] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1023.056280] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1023.056528] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1023.057526] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1023.058340] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1023.078565] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1023.078620] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1023.078642] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1023.078660] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1023.078668] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1023.078677] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1023.078684] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1023.078691] ---[ end trace 000000000000000b ]---
    [ 1023.438568] ------------[ cut here ]------------
    [ 1023.438584] WARNING: CPU: 0 PID: 1046 at net/mac80211/driver-ops.c:335 drv_ampdu_action+0x90/0xa4 [mac80211]
    [ 1023.439985] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [ 1023.439991] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1023.440110] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1023.440125] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1023.440134] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1023.440662] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1023.440695] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1023.440725] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [ 1023.440741] [<c09a0a84>] (warn_slowpath_fmt) from [<bf1dda4c>] (drv_ampdu_action+0x90/0xa4 [mac80211])
    [ 1023.441222] [<bf1dda4c>] (drv_ampdu_action [mac80211]) from [<bf1eae04>] (___ieee80211_stop_rx_ba_session+0xbc/0x18c [mac80211])
    [ 1023.442009] [<bf1eae04>] (___ieee80211_stop_rx_ba_session [mac80211]) from [<bf1e8e20>] (ieee80211_sta_tear_down_BA_sessions+0x50/0x11c [mac80211])
    [ 1023.442773] [<bf1e8e20>] (ieee80211_sta_tear_down_BA_sessions [mac80211]) from [<bf1df084>] (__sta_info_destroy_part1+0x38/0x20c [mac80211])
    [ 1023.443529] [<bf1df084>] (__sta_info_destroy_part1 [mac80211]) from [<bf1e2174>] (__sta_info_flush+0xe0/0x1bc [mac80211])
    [ 1023.444291] [<bf1e2174>] (__sta_info_flush [mac80211]) from [<bf21e714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [ 1023.445061] [<bf21e714>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1023.445826] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1023.447293] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1023.447775] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1023.448230] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1023.469438] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1023.470406] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1023.470688] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1023.470716] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1023.470729] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1023.470743] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1023.470997] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1023.472862] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1023.473756] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1023.474186] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1023.474207] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1023.474227] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1023.474243] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1023.474253] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1023.474261] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1023.474269] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1023.474276] ---[ end trace 000000000000000c ]---
    [ 1023.948529] wlan0: HW problem - can not stop rx aggregation for 54:b8:0a:13:1e:66 tid 0
    [ 1023.948584] ------------[ cut here ]------------
    [ 1023.948589] WARNING: CPU: 0 PID: 1046 at net/mac80211/driver-ops.h:514 __sta_info_destroy_part1+0x1b0/0x20c [mac80211]
    [ 1023.949958] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [ 1023.949965] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1023.950085] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1023.950100] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1023.950109] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1023.950638] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1023.950669] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1023.950698] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [ 1023.950715] [<c09a0a84>] (warn_slowpath_fmt) from [<bf1df1fc>] (__sta_info_destroy_part1+0x1b0/0x20c [mac80211])
    [ 1023.951191] [<bf1df1fc>] (__sta_info_destroy_part1 [mac80211]) from [<bf1e2174>] (__sta_info_flush+0xe0/0x1bc [mac80211])
    [ 1023.951973] [<bf1e2174>] (__sta_info_flush [mac80211]) from [<bf21e714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [ 1023.952750] [<bf21e714>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1023.953515] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1023.954958] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1023.955439] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1023.955899] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1023.956357] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1023.956810] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1023.957076] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1023.957103] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1023.957116] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1023.957130] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1023.957381] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1023.958378] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1023.978832] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1023.980295] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1023.980315] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1023.980339] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1023.980357] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1023.980366] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1023.980375] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1023.980382] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1023.980389] ---[ end trace 000000000000000d ]---
    [ 1024.368504] ------------[ cut here ]------------
    [ 1024.368517] WARNING: CPU: 0 PID: 1046 at net/mac80211/driver-ops.c:118 drv_sta_state+0x26c/0x2cc [mac80211]
    [ 1024.369886] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [ 1024.369892] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1024.370013] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1024.370027] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1024.370036] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1024.370565] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1024.370599] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1024.370629] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [ 1024.370645] [<c09a0a84>] (warn_slowpath_fmt) from [<bf1dd2e4>] (drv_sta_state+0x26c/0x2cc [mac80211])
    [ 1024.371118] [<bf1dd2e4>] (drv_sta_state [mac80211]) from [<bf1e05a8>] (sta_info_move_state+0x1d0/0x2c4 [mac80211])
    [ 1024.371900] [<bf1e05a8>] (sta_info_move_state [mac80211]) from [<bf1e1e80>] (__sta_info_destroy_part2+0x19c/0x1d8 [mac80211])
    [ 1024.372665] [<bf1e1e80>] (__sta_info_destroy_part2 [mac80211]) from [<bf1e21d0>] (__sta_info_flush+0x13c/0x1bc [mac80211])
    [ 1024.373434] [<bf1e21d0>] (__sta_info_flush [mac80211]) from [<bf21e714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [ 1024.374200] [<bf21e714>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1024.374966] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1024.376433] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1024.376914] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1024.377371] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1024.377827] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1024.378281] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1024.399451] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1024.399521] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1024.399536] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1024.399551] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1024.400308] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1024.402220] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1024.403102] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1024.403533] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1024.403552] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1024.403573] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1024.403590] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1024.403598] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1024.403607] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1024.403614] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1024.403622] ---[ end trace 000000000000000e ]---
    [ 1024.758506] ------------[ cut here ]------------
    [ 1024.758518] WARNING: CPU: 0 PID: 1046 at net/mac80211/sta_info.c:1069 __sta_info_destroy_part2+0x1d4/0x1d8 [mac80211]
    [ 1024.759875] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1024.759996] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1024.760010] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1024.760020] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1024.760544] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1024.760579] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1024.760608] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [ 1024.760625] [<c09a0a50>] (warn_slowpath_fmt) from [<bf1e1eb8>] (__sta_info_destroy_part2+0x1d4/0x1d8 [mac80211])
    [ 1024.761100] [<bf1e1eb8>] (__sta_info_destroy_part2 [mac80211]) from [<bf1e21d0>] (__sta_info_flush+0x13c/0x1bc [mac80211])
    [ 1024.761887] [<bf1e21d0>] (__sta_info_flush [mac80211]) from [<bf21e714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [ 1024.762658] [<bf21e714>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1024.763424] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1024.764860] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1024.765345] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1024.765800] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1024.766256] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1024.766711] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1024.766979] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1024.767006] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1024.767021] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1024.767035] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1024.767285] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1024.768287] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1024.789925] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1024.791346] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1024.791367] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1024.791390] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1024.791408] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1024.791417] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1024.791426] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1024.791432] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1024.791440] ---[ end trace 000000000000000f ]---
    [ 1025.178553] ------------[ cut here ]------------
    [ 1025.178567] WARNING: CPU: 0 PID: 1046 at net/mac80211/driver-ops.h:248 ieee80211_key_replace+0x750/0x798 [mac80211]
    [ 1025.179959] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [ 1025.179967] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1025.180088] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1025.180102] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1025.180112] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1025.180648] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1025.180683] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1025.180711] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [ 1025.180728] [<c09a0a84>] (warn_slowpath_fmt) from [<bf20ec20>] (ieee80211_key_replace+0x750/0x798 [mac80211])
    [ 1025.181202] [<bf20ec20>] (ieee80211_key_replace [mac80211]) from [<bf20fa4c>] (ieee80211_free_sta_keys+0xa4/0xd8 [mac80211])
    [ 1025.181985] [<bf20fa4c>] (ieee80211_free_sta_keys [mac80211]) from [<bf1e1d10>] (__sta_info_destroy_part2+0x2c/0x1d8 [mac80211])
    [ 1025.182758] [<bf1e1d10>] (__sta_info_destroy_part2 [mac80211]) from [<bf1e21d0>] (__sta_info_flush+0x13c/0x1bc [mac80211])
    [ 1025.183522] [<bf1e21d0>] (__sta_info_flush [mac80211]) from [<bf21e714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [ 1025.184289] [<bf21e714>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1025.185058] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1025.186513] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1025.186994] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1025.187452] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1025.187913] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1025.188367] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1025.208517] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1025.208578] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1025.208593] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1025.208607] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1025.209331] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1025.211443] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1025.212690] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1025.213142] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1025.213162] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1025.213184] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1025.213202] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1025.213210] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1025.213218] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1025.213225] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1025.213233] ---[ end trace 0000000000000010 ]---
    [ 1025.688519] wlan0: failed to remove key (0, 54:b8:0a:13:1e:66) from hardware (-5)
    [ 1025.688731] ------------[ cut here ]------------
    [ 1025.688737] WARNING: CPU: 0 PID: 1046 at net/mac80211/sta_info.c:1086 __sta_info_destroy_part2+0x138/0x1d8 [mac80211]
    [ 1025.690090] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1025.690211] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1025.690224] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1025.690233] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1025.690770] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1025.690804] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1025.690834] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [ 1025.690849] [<c09a0a50>] (warn_slowpath_fmt) from [<bf1e1e1c>] (__sta_info_destroy_part2+0x138/0x1d8 [mac80211])
    [ 1025.691324] [<bf1e1e1c>] (__sta_info_destroy_part2 [mac80211]) from [<bf1e21d0>] (__sta_info_flush+0x13c/0x1bc [mac80211])
    [ 1025.692115] [<bf1e21d0>] (__sta_info_flush [mac80211]) from [<bf21e714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [ 1025.692886] [<bf21e714>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1025.693657] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1025.695116] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1025.695591] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1025.696044] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1025.696500] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1025.696956] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1025.697221] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1025.697247] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1025.697261] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1025.697274] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1025.697525] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1025.718668] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1025.720520] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1025.720978] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1025.720998] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1025.721021] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1025.721039] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1025.721049] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1025.721057] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1025.721065] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1025.721072] ---[ end trace 0000000000000011 ]---
    [ 1026.078518] ------------[ cut here ]------------
    [ 1026.078530] WARNING: CPU: 0 PID: 1046 at net/mac80211/sta_info.c:1094 __sta_info_destroy_part2+0x190/0x1d8 [mac80211]
    [ 1026.079897] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1026.080020] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1026.080033] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1026.080044] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1026.080566] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1026.080599] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1026.080628] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [ 1026.080644] [<c09a0a50>] (warn_slowpath_fmt) from [<bf1e1e74>] (__sta_info_destroy_part2+0x190/0x1d8 [mac80211])
    [ 1026.081129] [<bf1e1e74>] (__sta_info_destroy_part2 [mac80211]) from [<bf1e21d0>] (__sta_info_flush+0x13c/0x1bc [mac80211])
    [ 1026.081910] [<bf1e21d0>] (__sta_info_flush [mac80211]) from [<bf21e714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [ 1026.082680] [<bf21e714>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1026.083448] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1026.084879] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1026.085365] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1026.085823] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1026.086279] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1026.086732] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1026.086999] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1026.087026] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1026.087040] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1026.087055] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1026.087306] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1026.088312] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1026.109890] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1026.111327] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1026.111349] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1026.111371] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1026.111389] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1026.111398] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1026.111406] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1026.111413] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1026.111420] ---[ end trace 0000000000000012 ]---
    [ 1026.468504] ------------[ cut here ]------------
    [ 1026.468517] WARNING: CPU: 0 PID: 1046 at net/mac80211/driver-ops.h:561 sta_set_sinfo+0xb54/0xba0 [mac80211]
    [ 1026.469929] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [ 1026.469936] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1026.470054] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1026.470067] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1026.470076] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1026.470619] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1026.470652] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1026.470682] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [ 1026.470697] [<c09a0a84>] (warn_slowpath_fmt) from [<bf1e1c98>] (sta_set_sinfo+0xb54/0xba0 [mac80211])
    [ 1026.471170] [<bf1e1c98>] (sta_set_sinfo [mac80211]) from [<bf1e1d98>] (__sta_info_destroy_part2+0xb4/0x1d8 [mac80211])
    [ 1026.471957] [<bf1e1d98>] (__sta_info_destroy_part2 [mac80211]) from [<bf1e21d0>] (__sta_info_flush+0x13c/0x1bc [mac80211])
    [ 1026.472726] [<bf1e21d0>] (__sta_info_flush [mac80211]) from [<bf21e714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [ 1026.473496] [<bf21e714>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1026.474261] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1026.475728] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1026.476214] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1026.476671] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1026.477125] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1026.477578] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1026.477845] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1026.477872] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1026.477886] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1026.477900] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1026.478147] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1026.499933] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1026.501763] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1026.502229] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1026.502249] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1026.502272] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1026.502289] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1026.502297] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1026.502305] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1026.502313] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1026.502320] ---[ end trace 0000000000000013 ]---
    [ 1026.858751] ------------[ cut here ]------------
    [ 1026.858765] WARNING: CPU: 0 PID: 1046 at net/mac80211/sta_info.c:272 sta_info_free+0x70/0x118 [mac80211]
    [ 1026.860183] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1026.860304] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1026.860318] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1026.860328] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1026.860860] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1026.860894] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1026.860922] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [ 1026.860938] [<c09a0a50>] (warn_slowpath_fmt) from [<bf1e070c>] (sta_info_free+0x70/0x118 [mac80211])
    [ 1026.861422] [<bf1e070c>] (sta_info_free [mac80211]) from [<bf1e21d0>] (__sta_info_flush+0x13c/0x1bc [mac80211])
    [ 1026.862209] [<bf1e21d0>] (__sta_info_flush [mac80211]) from [<bf21e714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [ 1026.862983] [<bf21e714>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1026.863750] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1026.865194] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1026.865672] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1026.866127] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1026.866585] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1026.867037] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1026.867303] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1026.867330] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1026.867345] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1026.867360] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1026.867609] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1026.889013] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1026.890819] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1026.891281] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1026.891301] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1026.891324] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1026.891341] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1026.891350] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1026.891359] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1026.891366] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1026.891373] ---[ end trace 0000000000000014 ]---
    [ 1027.368504] ------------[ cut here ]------------
    [ 1027.368517] WARNING: CPU: 0 PID: 1046 at net/mac80211/sta_info.c:275 sta_info_free+0xb4/0x118 [mac80211]
    [ 1027.370323] sta_info_move_state() returned -5
    [ 1027.370335] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1027.370454] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1027.370466] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1027.370475] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1027.371289] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1027.371323] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1027.371352] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [ 1027.371367] [<c09a0a84>] (warn_slowpath_fmt) from [<bf1e0750>] (sta_info_free+0xb4/0x118 [mac80211])
    [ 1027.371854] [<bf1e0750>] (sta_info_free [mac80211]) from [<bf1e21d0>] (__sta_info_flush+0x13c/0x1bc [mac80211])
    [ 1027.372641] [<bf1e21d0>] (__sta_info_flush [mac80211]) from [<bf21e714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [ 1027.373414] [<bf21e714>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1027.374186] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1027.375618] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1027.376096] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1027.376553] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1027.377010] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1027.377462] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1027.377728] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1027.377755] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1027.377768] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1027.377782] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1027.378030] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1027.397769] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1027.400384] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1027.401496] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1027.401517] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1027.401540] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1027.401558] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1027.401566] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1027.401574] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1027.401581] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1027.401588] ---[ end trace 0000000000000015 ]---
    [ 1027.758522] ------------[ cut here ]------------
    [ 1027.758536] WARNING: CPU: 0 PID: 1046 at net/mac80211/driver-ops.c:190 drv_conf_tx+0xc8/0x12c [mac80211]
    [ 1027.759871] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [ 1027.759878] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1027.759998] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1027.760012] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1027.760022] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1027.760544] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1027.760580] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1027.760608] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [ 1027.760624] [<c09a0a84>] (warn_slowpath_fmt) from [<bf1dd5a0>] (drv_conf_tx+0xc8/0x12c [mac80211])
    [ 1027.761102] [<bf1dd5a0>] (drv_conf_tx [mac80211]) from [<bf213278>] (ieee80211_set_wmm_default+0x188/0x35c [mac80211])
    [ 1027.761881] [<bf213278>] (ieee80211_set_wmm_default [mac80211]) from [<bf21e82c>] (ieee80211_set_disassoc+0x1bc/0x478 [mac80211])
    [ 1027.762653] [<bf21e82c>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1027.763417] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1027.764877] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1027.765357] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1027.765814] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1027.766272] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1027.766728] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1027.766992] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1027.767019] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1027.767033] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1027.767047] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1027.767295] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1027.768306] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1027.779848] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1027.781277] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1027.781299] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1027.781321] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1027.781339] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1027.781347] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1027.781355] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1027.781362] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1027.781370] ---[ end trace 0000000000000016 ]---
    [ 1028.138530] ------------[ cut here ]------------
    [ 1028.138543] WARNING: CPU: 0 PID: 1046 at net/mac80211/driver-ops.h:927 ieee80211_assign_vif_chanctx+0x310/0x38c [mac80211]
    [ 1028.139918] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [ 1028.139925] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1028.140044] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1028.140058] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1028.140068] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1028.140603] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1028.140638] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1028.140666] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [ 1028.140683] [<c09a0a84>] (warn_slowpath_fmt) from [<bf2198d0>] (ieee80211_assign_vif_chanctx+0x310/0x38c [mac80211])
    [ 1028.141164] [<bf2198d0>] (ieee80211_assign_vif_chanctx [mac80211]) from [<bf21a758>] (__ieee80211_vif_release_channel+0x48/0x144 [mac80211])
    [ 1028.141947] [<bf21a758>] (__ieee80211_vif_release_channel [mac80211]) from [<bf21b0c8>] (ieee80211_vif_release_channel+0x50/0x60 [mac80211])
    [ 1028.142712] [<bf21b0c8>] (ieee80211_vif_release_channel [mac80211]) from [<bf21e878>] (ieee80211_set_disassoc+0x208/0x478 [mac80211])
    [ 1028.143481] [<bf21e878>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1028.144245] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1028.145689] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1028.146165] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1028.146623] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1028.147079] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1028.147533] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1028.147797] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1028.147824] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1028.147839] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1028.147852] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1028.148100] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1028.178465] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1028.180953] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1028.182060] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1028.182081] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1028.182103] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1028.182120] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1028.182129] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1028.182137] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1028.182144] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1028.182152] ---[ end trace 0000000000000017 ]---
    [ 1028.538519] ------------[ cut here ]------------
    [ 1028.538532] WARNING: CPU: 0 PID: 1046 at net/mac80211/driver-ops.h:876 ieee80211_del_chanctx+0xfc/0x100 [mac80211]
    [ 1028.539877] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1028.539996] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1028.540009] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1028.540018] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1028.540545] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1028.540576] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1028.540604] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [ 1028.540622] [<c09a0a50>] (warn_slowpath_fmt) from [<bf218258>] (ieee80211_del_chanctx+0xfc/0x100 [mac80211])
    [ 1028.541101] [<bf218258>] (ieee80211_del_chanctx [mac80211]) from [<bf2182fc>] (ieee80211_free_chanctx+0xa0/0x10c [mac80211])
    [ 1028.541893] [<bf2182fc>] (ieee80211_free_chanctx [mac80211]) from [<bf21a810>] (__ieee80211_vif_release_channel+0x100/0x144 [mac80211])
    [ 1028.542654] [<bf21a810>] (__ieee80211_vif_release_channel [mac80211]) from [<bf21b0c8>] (ieee80211_vif_release_channel+0x50/0x60 [mac80211])
    [ 1028.543419] [<bf21b0c8>] (ieee80211_vif_release_channel [mac80211]) from [<bf21e878>] (ieee80211_set_disassoc+0x208/0x478 [mac80211])
    [ 1028.544185] [<bf21e878>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1028.544950] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1028.546412] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1028.546895] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1028.547351] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1028.547808] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1028.548261] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1028.573455] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1028.573521] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1028.573536] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1028.573550] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1028.574314] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1028.576205] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1028.577088] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1028.577521] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1028.577541] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1028.577562] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1028.577578] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1028.577587] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1028.577595] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1028.577603] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1028.577610] ---[ end trace 0000000000000018 ]---
    [ 1029.078526] wlan0: failed to remove key (1, ff:ff:ff:ff:ff:ff) from hardware (-5)
  • This project uses AM437x SDK download from here, using Linux platform.
    The SDK version is 08.02.00.24, and the kernel version is 5.10.100.
    WL1807 module can connect with AP, but it disconnected while doing throughput test(using iperf3).
    Or ping Google DNS server(8.8.8.8) for about  40min, and it disconnected too.
    We have replaced several WL1807 firmware on this website, and tried 8.9.0.0.90, 8.9.0.0.89, 8.9.0.0.88, 8.9.0.0.86 got same result.
    DUT is testing at room temperature.
    The kernel message is herekmsg.txt
    Would you like to help me to clear this problem?
    And I found a manual about Wilink8 https://www.ti.com/lit/pdf/swru561
    Should I follow the manual to patch my current BSP?
    Appreciate your help.
    attache dts file
    // SPDX-License-Identifier: GPL-2.0-only
     * Copyright (C) 2014 Texas Instruments Incorporated - https://www.ti.com/
    /* AM437x SK EVM */
    /dts-v1/;
    #include "am4372.dtsi"
    #include <dt-bindings/pinctrl/am43xx.h>
    #include <dt-bindings/pwm/pwm.h>
    #include <dt-bindings/gpio/gpio.h>
    #include <dt-bindings/input/input.h>
    #include <dt-bindings/interrupt-controller/irq.h>
    	model = "TI AM437x EMU200";
    	compatible = "ti,am437x-emu200","ti,am4372","ti,am43";
    	aliases {
    		// display0 = &lcd0;
    	chosen {
    		stdout-path = &uart0;
    	/* fixed 32k external oscillator clock */
    	clk_32k_rtc: clk_32k_rtc {
    		#clock-cells = <0>;
    		compatible = "fixed-clock";
    		clock-frequency = <32768>;
    /* haidar-add */
    	leds {
    		compatible = "gpio-leds";
    		emu_sysg {
            	label = "led_sysg";
            	gpios = <&gpio0 12 GPIO_ACTIVE_HIGH>;
            	linux,default-trigger = "timer";
            	default-state = "on";
            	max_brightness = <1>;
            	status = "okay";
            emu_sysr {
            	label = "led_sysr";
            	gpios = <&gpio0 15 GPIO_ACTIVE_HIGH>;
            	// linux,default-trigger = "heartbeat";
            	default-state = "off";
            	status = "okay";
            emu_user2g {
            	label = "led_user2g";
            	gpios = <&gpio0 13 GPIO_ACTIVE_HIGH>;
            	// linux,default-trigger = "usb-host";
            	status = "okay";
            emu_user1g {
            	label = "led_user1g";
            	gpios = <&gpio2 2 GPIO_ACTIVE_HIGH>;
            	status = "okay";
    		emu_user3g {
            	label = "led_user3g";
            	gpios = <&gpio1 29 GPIO_ACTIVE_HIGH>;
            	status = "okay";
    	wlan_en_reg: fixed-regulator-wlen {
    		 * WL_EN is not SDIO standard compliant. It is an out of band
    		 * signal and hard to be dealt with in a standard way by the
    		 * SDIO core driver.
    		 * So modelling the WL_EN line as a regulator was a natural
    		 * choice as the MMC core already deals with MMC supplies.
    		compatible = "regulator-fixed";
    		regulator-name = "wlan_en_regulator";
    		regulator-min-microvolt = <1800000>;
    		regulator-max-microvolt = <1800000>;
    		gpio = <&gpio4 29 GPIO_ACTIVE_HIGH>;
    		// startup-delay-us = <70000>;
    		enable-active-high;
    		// regulator-boot-on;
    		regulator-always-on;
    &am43xx_pinmux {
    	// haidar eeprom wp on A3 +{
    	eeprom_pins: eeprom_pins {
    		pinctrl-single,pins = <
    			AM4372_IOPAD(0x898, PIN_OUTPUT_PULLUP | MUX_MODE7)  /* gpmc_wen.gpio2_io4 */
    	// haidar eeprom wp on A3 +}
    	// UART5 on A4 design, 2020-07-20 +{
    	uart5_pins: uart5_pins{
    			AM4372_IOPAD(0x8c0, PIN_OUTPUT        | MUX_MODE4)  /* (A19) dss_data8.uart5_txd */
    			AM4372_IOPAD(0x8c4, PIN_INPUT_PULLUP  | MUX_MODE4)  /* (B19) dss_data9.uart5.rxd */
    	gpio1_pins_default: gpio1_pins_default {
    			AM4372_IOPAD(0x87c, PIN_OUTPUT | MUX_MODE7) /* (A8) gpmc_csn0.gpio1[29] */
    	gpio2_pins_default: gpio2_pins_default {
    			AM4372_IOPAD(0x890, PIN_INPUT | MUX_MODE7) /* (A9) gpmc_advn_ale.gpio2[2] */
    	gpio4_pins_default: gpio4_pins_default {
    			AM4372_IOPAD(0x9b0, PIN_OUTPUT | MUX_MODE7) /* (AE17) cam0_hd.gpio4[0] */
    			AM4372_IOPAD(0x9b4, PIN_OUTPUT_PULLUP | MUX_MODE7) /* (AD18) cam0_vd.gpio4[1] */
    			AM4372_IOPAD(0x9c0, PIN_OUTPUT_PULLUP | MUX_MODE7) /* (AC20) cam0_pclk.gpio4[4] */
    			AM4372_IOPAD(0xa18, PIN_OUTPUT_PULLUP | MUX_MODE7) /* (AE19) cam0_data4.gpio4[26] */
    	// leds_pins: leds_pins {
    	// 	pinctrl-single,pins = <
    	i2c0_pins: i2c0_pins {
    			AM4372_IOPAD(0x988, PIN_INPUT | SLEWCTRL_FAST | MUX_MODE0)  /* i2c0_sda.i2c0_sda */
    			AM4372_IOPAD(0x98c, PIN_INPUT | SLEWCTRL_FAST | MUX_MODE0)  /* i2c0_scl.i2c0_scl */
    	// i2c1_pins: i2c1_pins {
    	// 		AM4372_IOPAD(0x95c, PIN_INPUT | SLEWCTRL_FAST | MUX_MODE2)  /* spi0_cs0.i2c1_scl */
    	// 		AM4372_IOPAD(0x958, PIN_INPUT | SLEWCTRL_FAST | MUX_MODE2)  /* spi0_d1.i2c1_sda  */
    	mmc1_pins: pinmux_mmc1_pins {
    			AM4372_IOPAD(0x8f0, PIN_INPUT | MUX_MODE0) /* mmc0_dat3.mmc0_dat3 */
    			AM4372_IOPAD(0x8f4, PIN_INPUT | MUX_MODE0) /* mmc0_dat2.mmc0_dat2 */
    			AM4372_IOPAD(0x8f8, PIN_INPUT | MUX_MODE0) /* mmc0_dat1.mmc0_dat1 */
    			AM4372_IOPAD(0x8fc, PIN_INPUT | MUX_MODE0) /* mmc0_dat0.mmc0_dat0 */
    			AM4372_IOPAD(0x900, PIN_INPUT | MUX_MODE0) /* mmc0_clk.mmc0_clk */
    			AM4372_IOPAD(0x904, PIN_INPUT | MUX_MODE0) /* mmc0_cmd.mmc0_cmd */
    			AM4372_IOPAD(0x9AC, PIN_INPUT | MUX_MODE7) /* spi0_cs1.gpio0_6 */
    	mmc2_pins: pinmux_mmc2_pins {
    			AM4372_IOPAD(0x820, PIN_INPUT  | MUX_MODE2)	/* gpmc_ad8.mmc1_dat0 , B10 */
    			AM4372_IOPAD(0x824, PIN_INPUT  | MUX_MODE2)	/* gpmc_ad9.mmc1_dat1 , A10 */
    			AM4372_IOPAD(0x828, PIN_INPUT  | MUX_MODE2)	/* gpmc_ad10.mmc1_dat2, F11 */
    			AM4372_IOPAD(0x82C, PIN_INPUT  | MUX_MODE2)	/* gpmc_ad11.mmc1_dat3, D11 */
    			AM4372_IOPAD(0x830, PIN_INPUT  | MUX_MODE2)	/* gpmc_ad12.mmc1_dat4, E11 */
    			AM4372_IOPAD(0x834, PIN_INPUT  | MUX_MODE2)	/* gpmc_ad13.mmc1_dat5, C11 */
    			AM4372_IOPAD(0x838, PIN_INPUT  | MUX_MODE2)	/* gpmc_ad14.mmc1_dat6, B11 */
    			AM4372_IOPAD(0x83C, PIN_INPUT  | MUX_MODE2)	/* gpmc_ad15.mmc1_dat7, A11 */
    			AM4372_IOPAD(0x880, PIN_INPUT  | MUX_MODE2)	/* gpmc_csn1.mmc1_clk, B9 */
    			AM4372_IOPAD(0x884, PIN_INPUT  | MUX_MODE2)	/* gpmc_csn2.mmc1_cmd, F10 */
    			AM4372_IOPAD(0xA38, PIN_OUTPUT_PULLUP | MUX_MODE7) /* gpio5_8.gpio5_8 , RSTn*/
    			AM4372_IOPAD(0xA3C, PIN_INPUT | MUX_MODE7) /* gpio5_9.gpio5_9 , mmc1_DS , F24*/
    	mmc3_pins_default: pinmux_mmc3_pins_default {
    			AM4372_IOPAD(0x9f0, PIN_INPUT_PULLUP | MUX_MODE3) /* (AD21) cam1_data2.mmc2_clk */
    			AM4372_IOPAD(0x9f4, PIN_INPUT_PULLUP | MUX_MODE3) /* (AE22) cam1_data3.mmc2_cmd */
    			AM4372_IOPAD(0x9f8, PIN_INPUT_PULLUP | MUX_MODE3) /* (AD22) cam1_data4.mmc2_dat0 */
    			AM4372_IOPAD(0x9fc, PIN_INPUT_PULLUP | MUX_MODE3) /* (AE23) cam1_data5.mmc2_dat1 */
    			AM4372_IOPAD(0xa00, PIN_INPUT_PULLUP | MUX_MODE3) /* (AD23) cam1_data6.mmc2_dat2 */
    			AM4372_IOPAD(0xa04, PIN_INPUT_PULLUP | MUX_MODE3) /* (AE24) cam1_data7.mmc2_dat3 */
    			// AM4372_IOPAD(0xa20, PIN_INPUT | MUX_MODE7) /* (AE20) cam0_data6.gpio4[28] WL_IRQ*/
    	wlan_pins_default: pinmux_wlan_pins_default {
    			AM4372_IOPAD(0xa24, PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* (AD20) cam0_data7.gpio4[29] WL_EN*/
    			AM4372_IOPAD(0xa20, PIN_INPUT_PULLUP | MUX_MODE7) /* (AE20) cam0_data6.gpio4[28] WL_IRQ*/
    	clkout1_pin: pinmux_clkout1_pin {
    			0x270 (PIN_OUTPUT_PULLDOWN | MUX_MODE3)	/* XDMA_EVENT_INTR0/CLKOUT1 */
    	cpsw_default: cpsw_default {
    			/* Slave 1 */
    			AM4372_IOPAD(0x92c, PIN_OUTPUT | MUX_MODE2)	/* mii1_txclk.rmii1_tclk */
    			AM4372_IOPAD(0x914, PIN_OUTPUT | MUX_MODE2)	/* mii1_txen.rgmii1_tctl */
    			AM4372_IOPAD(0x928, PIN_OUTPUT | MUX_MODE2)	/* mii1_txd0.rgmii1_td0 */
    			AM4372_IOPAD(0x924, PIN_OUTPUT | MUX_MODE2)	/* mii1_txd1.rgmii1_td1 */
    			AM4372_IOPAD(0x920, PIN_OUTPUT | MUX_MODE2)	/* mii1_txd0.rgmii1_td2 */
    			AM4372_IOPAD(0x91c, PIN_OUTPUT | MUX_MODE2)	/* mii1_txd1.rgmii1_td3 */
    			AM4372_IOPAD(0x930, PIN_INPUT | MUX_MODE2)	/* mii1_rxclk.rmii1_rclk */
    			AM4372_IOPAD(0x918, PIN_INPUT | MUX_MODE2)	/* mii1_rxdv.rgmii1_rctl */
    			AM4372_IOPAD(0x940, PIN_INPUT | MUX_MODE2)	/* mii1_rxd0.rgmii1_rd0 */
    			AM4372_IOPAD(0x93c, PIN_INPUT | MUX_MODE2)	/* mii1_rxd1.rgmii1_rd1 */
    			AM4372_IOPAD(0x938, PIN_INPUT | MUX_MODE2)	/* mii1_rxd0.rgmii1_rd2 */
    			AM4372_IOPAD(0x934, PIN_INPUT | MUX_MODE2)	/* mii1_rxd1.rgmii1_rd3 */
    			/* Slave 2 */
    			AM4372_IOPAD(0x858, PIN_OUTPUT | MUX_MODE2)	/* gpmc_a6.rgmii2_tclk */
    			AM4372_IOPAD(0x840, PIN_OUTPUT | MUX_MODE2)	/* gpmc_a0.rgmii2_tctl */
    			AM4372_IOPAD(0x854, PIN_OUTPUT | MUX_MODE2)	/* gpmc_a5.rgmii2_td0 */
    			AM4372_IOPAD(0x850, PIN_OUTPUT | MUX_MODE2)	/* gpmc_a4.rgmii2_td1 */
    			AM4372_IOPAD(0x84c, PIN_OUTPUT | MUX_MODE2)	/* gpmc_a3.rgmii2_td2 */
    			AM4372_IOPAD(0x848, PIN_OUTPUT | MUX_MODE2)	/* gpmc_a2.rgmii2_td3 */
    			AM4372_IOPAD(0x85c, PIN_INPUT | MUX_MODE2)	/* gpmc_a7.rgmii2_rclk */
    			AM4372_IOPAD(0x844, PIN_INPUT | MUX_MODE2)	/* gpmc_a1.rgmii2_rtcl */
    			AM4372_IOPAD(0x86c, PIN_INPUT | MUX_MODE2)	/* gpmc_a11.rgmii2_rd0 */
    			AM4372_IOPAD(0x868, PIN_INPUT | MUX_MODE2)	/* gpmc_a10.rgmii2_rd1 */
    			AM4372_IOPAD(0x864, PIN_INPUT | MUX_MODE2)	/* gpmc_a9.rgmii2_rd2 */
    			AM4372_IOPAD(0x860, PIN_INPUT | MUX_MODE2)	/* gpmc_a8.rgmii2_rd3 */
    	cpsw_sleep: cpsw_sleep {
    			/* Slave 1 reset value */
    			AM4372_IOPAD(0x92c, PIN_INPUT_PULLDOWN | MUX_MODE7)
    			AM4372_IOPAD(0x914, PIN_INPUT_PULLDOWN | MUX_MODE7)
    			AM4372_IOPAD(0x928, PIN_INPUT_PULLDOWN | MUX_MODE7)
    			AM4372_IOPAD(0x924, PIN_INPUT_PULLDOWN | MUX_MODE7)
    			AM4372_IOPAD(0x920, PIN_INPUT_PULLDOWN | MUX_MODE7)
    			AM4372_IOPAD(0x91c, PIN_INPUT_PULLDOWN | MUX_MODE7)
    			AM4372_IOPAD(0x930, PIN_INPUT_PULLDOWN | MUX_MODE7)
    			AM4372_IOPAD(0x918, PIN_INPUT_PULLDOWN | MUX_MODE7)
    			AM4372_IOPAD(0x940, PIN_INPUT_PULLDOWN | MUX_MODE7)
    			AM4372_IOPAD(0x93c, PIN_INPUT_PULLDOWN | MUX_MODE7)
    			AM4372_IOPAD(0x938, PIN_INPUT_PULLDOWN | MUX_MODE7)
    			AM4372_IOPAD(0x934, PIN_INPUT_PULLDOWN | MUX_MODE7)
    			/* Slave 2 reset value */
    			AM4372_IOPAD(0x858, PIN_INPUT_PULLDOWN | MUX_MODE7)
    			AM4372_IOPAD(0x840, PIN_INPUT_PULLDOWN | MUX_MODE7)
    			AM4372_IOPAD(0x854, PIN_INPUT_PULLDOWN | MUX_MODE7)
    			AM4372_IOPAD(0x850, PIN_INPUT_PULLDOWN | MUX_MODE7)
    			AM4372_IOPAD(0x84c, PIN_INPUT_PULLDOWN | MUX_MODE7)
    			AM4372_IOPAD(0x848, PIN_INPUT_PULLDOWN | MUX_MODE7)
    			AM4372_IOPAD(0x85c, PIN_INPUT_PULLDOWN | MUX_MODE7)
    			AM4372_IOPAD(0x844, PIN_INPUT_PULLDOWN | MUX_MODE7)
    			AM4372_IOPAD(0x86c, PIN_INPUT_PULLDOWN | MUX_MODE7)
    			AM4372_IOPAD(0x868, PIN_INPUT_PULLDOWN | MUX_MODE7)
    			AM4372_IOPAD(0x864, PIN_INPUT_PULLDOWN | MUX_MODE7)
    			AM4372_IOPAD(0x860, PIN_INPUT_PULLDOWN | MUX_MODE7)
    	davinci_mdio_default: davinci_mdio_default {
    			/* MDIO */
    			AM4372_IOPAD(0x948, PIN_INPUT | SLEWCTRL_FAST | MUX_MODE0)	/* mdio_data.mdio_data */
    			AM4372_IOPAD(0x94c, PIN_OUTPUT | MUX_MODE0)			/* mdio_clk.mdio_clk */
    	davinci_mdio_sleep: davinci_mdio_sleep {
    			/* MDIO reset value */
    			AM4372_IOPAD(0x948, PIN_INPUT_PULLDOWN | MUX_MODE7)
    			AM4372_IOPAD(0x94c, PIN_INPUT_PULLDOWN | MUX_MODE7)
    	spi0_pins: spi0_pins {
    		/* ctrl */
    			AM4372_IOPAD(0x960, PIN_OUTPUT  | MUX_MODE0)   /* spi0_cs1.spi0_cs1 */
    			AM4372_IOPAD(0x950, PIN_INPUT   | MUX_MODE0)   /* spi0_sclk.spi0_sclk */
    			AM4372_IOPAD(0x954, PIN_INPUT   | MUX_MODE0)   /* spi0_d0.spi0_d0 */
    			AM4372_IOPAD(0x958, PIN_INPUT   | MUX_MODE0)   /* spi0_d1.spi0_d1 */
    	spi1_pins: spi1_pins {
    		/* ai */
    			AM4372_IOPAD(0x944, PIN_OUTPUT   | MUX_MODE2)     /* rmii1_ref_clk.spi1_cs0 */
    			AM4372_IOPAD(0x908, PIN_INPUT    | MUX_MODE2)     /* mii1_col.spi1_sclk */
    			AM4372_IOPAD(0x90c, PIN_INPUT    | MUX_MODE2)     /* mii1_crs.spi1_d0 */
    			AM4372_IOPAD(0x910, PIN_INPUT    | MUX_MODE2)     /* mii1_rx_er.spi1_d1 */
    	usb1_pins: usb1_pins {
    			// AM4372_IOPAD(0xac0, PIN_OUTPUT | MUX_MODE0) /* usb0_drvvbus.usb0_drvvbus */
    			AM4372_IOPAD(0xac0, PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* usb0_drvvbus.gpio0_io18 */
    	usb2_pins: usb2_pins {
    			AM4372_IOPAD(0xac4, PIN_OUTPUT | MUX_MODE0) /* usb0_drvvbus.usb0_drvvbus */
    			// AM4372_IOPAD(0xac4, PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* usb0_drvvbus.gpio3_io13 */
    	pmic_pins: pmic_pins {
    		AM4372_IOPAD(0x980, PIN_OUTPUT | MUX_MODE7) /* uart1_rxd.gpio0_io14 */
    &i2c0 {
    	status = "okay";
    	pinctrl-names = "default";
    	pinctrl-0 = <&i2c0_pins>;
    	clock-frequency = <100000>;
    	tps@24 {
    		compatible = "ti,tps65218";
    		reg = <0x24>;
    		// interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>;
    		// interrupt-controller;
    		// #interrupt-cells = <2>;
    		pinctrl-0 = <&pmic_pins>;
    		interrupt-parent = <&gpio0>;
    		interrupts = <14 IRQ_TYPE_LEVEL_HIGH>;
    		dcdc1: regulator-dcdc1 {
    			/* VDD_CORE limits min of OPP50 and max of OPP100 */
    			regulator-name = "vdd_core";
    			regulator-min-microvolt = <912000>;
    			regulator-max-microvolt = <1144000>;
    			regulator-boot-on;
    		dcdc2: regulator-dcdc2 {
    			/* VDD_MPU limits min of OPP50 and max of OPP_NITRO */
    			regulator-name = "vdd_mpu";
    			regulator-max-microvolt = <1378000>;
    			regulator-boot-on;
    		dcdc3: regulator-dcdc3 {
    			regulator-name = "vdds_ddr";
    			regulator-boot-on;
    			regulator-state-mem {
    				regulator-on-in-suspend;
    			regulator-state-disk {
    				regulator-off-in-suspend;
    		dcdc4: regulator-dcdc4 {
    			regulator-name = "v3_3d";
    			regulator-min-microvolt = <3300000>;
    			regulator-max-microvolt = <3300000>;
    			regulator-boot-on;
    		dcdc5: regulator-dcdc5 {
    			compatible = "ti,tps65218-dcdc5";
    			regulator-name = "v1_0bat";
    			regulator-min-microvolt = <1000000>;
    			regulator-max-microvolt = <1000000>;
    			regulator-boot-on;
    		dcdc6: regulator-dcdc6 {
    			compatible = "ti,tps65218-dcdc6";
    			regulator-name = "v1_8bat";
    			regulator-boot-on;
    		ldo1: regulator-ldo1 {
    			regulator-name = "v1_8d";
    			regulator-boot-on;
    	emu_eeprom: emu_at24@50 {
    		// compatible = "atmel,24c256";
    		// pagesize = <64>;
    		compatible = "adlink,emu-eeprom";
    		reg = <0x50>;
    		pagesize = <16>;
    		pinctrl-0 = <&eeprom_pins>;
    		wp_gpio = <&gpio2 4 GPIO_ACTIVE_HIGH>;
    &epwmss0 {
    	status = "okay";
    &uart5 {
    	pinctrl-0 = <&uart5_pins>;
    	status = "okay";
    &i2c1 {
    	status = "disabled";
    &ecap0 {
    &gpio0 {
    	status = "okay";
    &gpio1 {
    	pinctrl-0 = <&gpio1_pins_default>;
    	status = "okay";
    &gpio2 {
    	pinctrl-0 = <&gpio2_pins_default>;
    	status = "okay";
    &gpio3 {
    	status = "okay";
    &gpio4 {
    	status = "okay";
    	pinctrl-0 = <&gpio4_pins_default>;
    	// p29 {
    	// 	gpio-hog;
    	// 	gpios = <29 GPIO_ACTIVE_HIGH>;
    	// 	line-name = "wl_en";
    	// 	output-high;
    &gpio5 {
    	status = "okay";
    &mmc1 {
    	status = "okay";
    	pinctrl-0 = <&mmc1_pins>;
    	vmmc-supply = <&dcdc4>;
    	bus-width = <4>;
    	cd-gpios = <&gpio3 21 GPIO_ACTIVE_LOW>;
    &mmc2 {
    	status = "okay";
    	bus-width = <8>;
    	pinctrl-0 = <&mmc2_pins>;
    	//cap-mmc-dual-data-rate;
    	keep-power-in-suspend;
    	non-removable;
    	no-1-8-v;
    	cap-mmc-hw-reset;
    	broken-cd;
    	disable-wp;
    &mmc3 {
    	status = "okay";
    	 * these are on the crossbar and are outlined in the
    	 * xbar-event-map element
    	dmas = <&edma_xbar 30 0 1>,
    		<&edma_xbar 31 0 2>;
    	dma-names = "tx", "rx";
    	vmmc-supply = <&wlan_en_reg>;
    	bus-width = <4>;
    	pinctrl-0 = <&mmc3_pins_default>;
    	cap-power-off-card;
    	non-removable;
    	#address-cells = <1>;
    	#size-cells = <0>;
    	wlcore: wlcore@0 {
    		compatible = "ti,wl1807";
    		pinctrl-0 = <&wlan_pins_default>;
    		reg = <2>;
    		interrupt-parent = <&gpio4>;
    		interrupts = <28 IRQ_TYPE_LEVEL_LOW>;
    &usb2_phy1 {
    	status = "okay";
    &usb1 {
    	dr_mode = "host";
    	status = "okay";
    	pinctrl-0 = <&usb1_pins>;
    &usb2_phy2 {
    	status = "okay";
    &usb2 {
    	dr_mode = "host";
    	status = "okay";
    	pinctrl-0 = <&usb2_pins>;
    &qspi {
    /* lyc-add ,start */
    &spi0 {
    	status = "okay";
    	pinctrl-0 = <&spi0_pins>;
    	dmas = <&edma 16 0>, <&edma 17 0>;
    	dma-names = "tx0", "rx0";
    	ti,pindir-d0-out-d1-in;
    	//spi-max-frequency = <48000000>;
    	spi-max-frequency =   <24000000>;
    	ti,spi-num-cs = <4>;
    	mcm_ctrl: mcm_ctrl@1 {
    		compatible = "adlink,mcm-ctrl";
    		reg = <1>;
    &spi1 {
    	status = "okay";
    	pinctrl-0 = <&spi1_pins>;
    	dmas = <&edma 42 0>, <&edma 43 0>;
    	mcm_ai: mcm_ai@0 {
    		compatible = "adlink,mcm-ai";
    		reg = <0>;
    &mac_sw {
    	pinctrl-names = "default", "sleep";
    	pinctrl-0 = <&cpsw_default>;
    	pinctrl-1 = <&cpsw_sleep>;
    	status = "okay";
    	// reset-gpios = <&gpio1 28 GPIO_ACTIVE_LOW>,<&gpio4 10 GPIO_ACTIVE_LOW>;
    	// reset-delay-us = <10>;
    &davinci_mdio_sw {
    	pinctrl-0 = <&davinci_mdio_default>;
    	pinctrl-1 = <&davinci_mdio_sleep>;
    	status = "okay";
    	ethphy0: ethernet-phy@5 {
    		reset-gpios = <&gpio1 28 GPIO_ACTIVE_LOW>;
    		reg = <5>;
    	ethphy1: ethernet-phy@4 {
    		reset-gpios = <&gpio4 10 GPIO_ACTIVE_LOW>;
    		reg = <4>;
    &cpsw_port1 {
    	phy-handle = <&ethphy0>;
    	phy-mode = "rgmii-rxid";
    	ti,dual-emac-pvid = <1>;
    &cpsw_port2 {
    	phy-handle = <&ethphy1>;
    	ti,dual-emac-pvid = <2>;
    &elm {
    	status = "okay";
    &mcasp1 {
    &dss {
    &rtc {
    	clocks = <&clk_32k_rtc>, <&clk_32768_ck>;
    	clock-names = "ext-clk", "int-clk";
    	status = "okay";
    &wdt {
    	status = "okay";
    &cpu {
    	cpu0-supply = <&dcdc2>;
    &vpfe0 {
    &wkup_m3_ipc {
    	ti,scale-data-fw = "am43x-evm-scale-data.bin";
  • Hello Lee,
    In general you should not have to patch the BSP. However in this case, please remove the 'regulator-always-on' tag in your DTS, line 98 and test again. I believe this is the issue you are experiencing. The host is attempting to reset the device but the regulator-always-on means that the line will also stay on.
  • Hello Sabeeh
    appreciate your reply.
    I have rolled back the patch and emove the 'regulator-always-on' tag in the  DTS, and the test result still fails.
    Please help us solve this issue, thank you.
  • Could you probe the WL_EN pin with an oscilloscope and issue the following command:
    echo 1 > /sys/kernel/debug/ieee80211/phy0/wlcore/start_recovery
    Does the command run successfully? Do you see the WL_EN line toggle from high to low and back to high?
  • We have tried the command and wifi device got lost.
    The voltage of WL_EN pin will check next morning.
    The log that excute the command is shown below.
    [  465.511631] wlcore: using inverted interrupt logic: 8
    [  465.612501] wlcore: PHY firmware version: Rev 8.2.0.0.245
    [  465.733620] wlcore: firmware booted (Rev 8.9.0.0.86)
    [  473.930962] wlan0: authenticate with f8:32:e4:a9:c5:24
    [  473.946760] wlan0: send auth to f8:32:e4:a9:c5:24 (try 1/3)
    [  473.968819] wlan0: authenticated
    [  473.980047] wlan0: associate with f8:32:e4:a9:c5:24 (try 1/3)
    [  473.988118] wlan0: RX AssocResp from f8:32:e4:a9:c5:24 (capab=0x1411 status=0 aid=2)
    [  474.025067] wlan0: associated
    [  474.134489] cryptd: max_cpu_qlen set to 1000
    [  474.282110] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
    [  474.284238] wlcore: Association completed.
    [  627.913072] ------------[ cut here ]------------
    [  627.913090] WARNING: CPU: 0 PID: 896 at drivers/net/wireless/ti/wlcore/main.c:803 wl12xx_queue_recovery_work+0x68/0x6c [wlcore]
    [  627.913505] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm irq_pruss_intc pru_rproc icss_iep dwc3 roles udc_core cfg80211 pm33xx omap_des omap_aes_driver omap_sham libdes pruss omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [  627.913624] CPU: 0 PID: 896 Comm: bash Tainted: G           O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [  627.913636] Hardware name: Generic AM43 (Flattened Device Tree)
    [  627.913650] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [  627.913681] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [  627.913710] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [  627.913727] [<c09a0a50>] (warn_slowpath_fmt) from [<bf25c7d0>] (wl12xx_queue_recovery_work+0x68/0x6c [wlcore])
    [  627.913902] [<bf25c7d0>] (wl12xx_queue_recovery_work [wlcore]) from [<bf26c720>] (start_recovery_write+0x20/0x30 [wlcore])
    [  627.914130] [<bf26c720>] (start_recovery_write [wlcore]) from [<c03fe2bc>] (full_proxy_write+0x54/0x70)
    [  627.914259] [<c03fe2bc>] (full_proxy_write) from [<c0243c88>] (vfs_write+0xcc/0x468)
    [  627.914284] [<c0243c88>] (vfs_write) from [<c0244178>] (ksys_write+0x64/0xec)
    [  627.914299] [<c0244178>] (ksys_write) from [<c0100060>] (ret_fast_syscall+0x0/0x5c)
    [  627.914316] Exception stack(0xc1c17fa8 to 0xc1c17ff0)
    [  627.914326] 7fa0:                   00000002 00570780 00000001 00570780 00000002 00000000
    [  627.914336] 7fc0: 00000002 00570780 b6f32500 00000004 b6ec7780 00000000 0053e948 00000000
    [  627.914342] 7fe0: 00000004 bea01968 b6e5f4cf b6de57e6
    [  627.914349] ---[ end trace 0000000000000002 ]---
    [  628.155831] wlcore: Hardware recovery in progress. FW ver: Rev 8.9.0.0.86
    [  628.157650] wlcore: pc: 0x0, hint_sts: 0x00000020 count: 1
    [  628.168685] wlcore: down
    [  628.168748] wlcore: down
    [  628.175959] ieee80211 phy0: Hardware restart was requested
    [  628.561833] wlcore: using inverted interrupt logic: 8
    [  630.013640] ------------[ cut here ]------------
    [  630.013657] WARNING: CPU: 0 PID: 1038 at drivers/net/wireless/ti/wlcore/sdio.c:123 wl12xx_sdio_raw_write+0x140/0x15c [wlcore_sdio]
    [  630.013706] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm irq_pruss_intc pru_rproc icss_iep dwc3 roles udc_core cfg80211 pm33xx omap_des omap_aes_driver omap_sham libdes pruss omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [  630.013825] CPU: 0 PID: 1038 Comm: kworker/0:0 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [  630.013838] Hardware name: Generic AM43 (Flattened Device Tree)
    [  630.013847] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [  630.015199] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [  630.015234] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [  630.015263] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [  630.015279] [<c09a0a50>] (warn_slowpath_fmt) from [<bf057234>] (wl12xx_sdio_raw_write+0x140/0x15c [wlcore_sdio])
    [  630.015314] [<bf057234>] (wl12xx_sdio_raw_write [wlcore_sdio]) from [<bf269f28>] (wlcore_boot_upload_firmware+0x174/0x4a4 [wlcore])
    [  630.015734] [<bf269f28>] (wlcore_boot_upload_firmware [wlcore]) from [<bf289fcc>] (wl18xx_boot+0x910/0xd6c [wl18xx])
    [  630.016073] [<bf289fcc>] (wl18xx_boot [wl18xx]) from [<bf25bde8>] (wl1271_op_add_interface+0x6d4/0x9c8 [wlcore])
    [  630.016271] [<bf25bde8>] (wl1271_op_add_interface [wlcore]) from [<bf198f10>] (drv_add_interface+0x2c/0x7c [mac80211])
    [  630.017301] [<bf198f10>] (drv_add_interface [mac80211]) from [<bf1cfcc0>] (ieee80211_reconfig+0x2e8/0xf00 [mac80211])
    [  630.018121] [<bf1cfcc0>] (ieee80211_reconfig [mac80211]) from [<bf195408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [  630.043177] [<bf195408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [  630.044677] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [  630.044711] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [  630.044734] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [  630.044752] Exception stack(0xc118bfb0 to 0xc118bff8)
    [  630.044760] bfa0:                                     00000000 00000000 00000000 00000000
    [  630.044769] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [  630.044776] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [  630.044784] ---[ end trace 0000000000000003 ]---
    [  630.278579] wl1271_sdio mmc2:0001:2: sdio write failed (-110)
    [  631.749479] wl1271_sdio mmc2:0001:2: wl12xx_sdio_power_on: failed to get_sync(-16)
    [  631.788635] wl1271_sdio mmc2:0001:2: wl12xx_sdio_power_on: failed to get_sync(-22)
    [  631.788662] wlcore: ERROR firmware boot failed despite 3 retries
    [  631.788674] ------------[ cut here ]------------
    [  631.788677] WARNING: CPU: 0 PID: 1038 at net/mac80211/util.c:2385 ieee80211_reconfig+0xc38/0xf00 [mac80211]
    [  631.790058] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm irq_pruss_intc pru_rproc icss_iep dwc3 roles udc_core cfg80211 pm33xx omap_des omap_aes_driver omap_sham libdes pruss omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [  631.790177] CPU: 0 PID: 1038 Comm: kworker/0:0 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [  631.790191] Hardware name: Generic AM43 (Flattened Device Tree)
    [  631.790201] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [  631.790722] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [  631.790756] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [  631.790784] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [  631.790800] [<c09a0a50>] (warn_slowpath_fmt) from [<bf1d0610>] (ieee80211_reconfig+0xc38/0xf00 [mac80211])
    [  631.791272] [<bf1d0610>] (ieee80211_reconfig [mac80211]) from [<bf195408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [  631.792055] [<bf195408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [  631.792483] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [  631.792502] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [  631.792525] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [  631.792541] Exception stack(0xc118bfb0 to 0xc118bff8)
    [  631.792549] bfa0:                                     00000000 00000000 00000000 00000000
    [  631.792558] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [  631.792565] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [  631.792572] ---[ end trace 0000000000000004 ]---
    [  632.058571] ------------[ cut here ]------------
    [  632.058584] WARNING: CPU: 0 PID: 1038 at net/mac80211/driver-ops.c:97 drv_remove_interface+0x88/0x8c [mac80211]
    [  632.059955] p2p-dev-wlan0: Failed check-sdata-in-driver check, flags: 0x0
    [  632.059962] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm irq_pruss_intc pru_rproc icss_iep dwc3 roles udc_core cfg80211 pm33xx omap_des omap_aes_driver omap_sham libdes pruss omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [  632.060083] CPU: 0 PID: 1038 Comm: kworker/0:0 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [  632.060096] Hardware name: Generic AM43 (Flattened Device Tree)
    [  632.060106] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [  632.060644] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [  632.060678] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [  632.060707] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [  632.060724] [<c09a0a84>] (warn_slowpath_fmt) from [<bf199074>] (drv_remove_interface+0x88/0x8c [mac80211])
    [  632.061196] [<bf199074>] (drv_remove_interface [mac80211]) from [<bf1ad890>] (ieee80211_do_stop+0x5d0/0x8a8 [mac80211])
    [  632.061985] [<bf1ad890>] (ieee80211_do_stop [mac80211]) from [<bf0c8fb8>] (cfg80211_stop_p2p_device+0x58/0x150 [cfg80211])
    [  632.063450] [<bf0c8fb8>] (cfg80211_stop_p2p_device [cfg80211]) from [<bf0c9224>] (cfg80211_shutdown_all_interfaces+0x98/0xe0 [cfg80211])
    [  632.063933] [<bf0c9224>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf1cfa84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [  632.064873] [<bf1cfa84>] (ieee80211_reconfig [mac80211]) from [<bf195408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [  632.065673] [<bf195408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [  632.066109] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [  632.066128] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [  632.066150] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [  632.066167] Exception stack(0xc118bfb0 to 0xc118bff8)
    [  632.066176] bfa0:                                     00000000 00000000 00000000 00000000
    [  632.066185] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [  632.066192] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [  632.066199] ---[ end trace 0000000000000005 ]---
    [  632.418646] wlan0: deauthenticating from f8:32:e4:a9:c5:24 by local choice (Reason: 3=DEAUTH_LEAVING)
    [  632.418683] ------------[ cut here ]------------
    [  632.418688] WARNING: CPU: 0 PID: 1038 at net/mac80211/driver-ops.h:172 ieee80211_bss_info_change_notify+0xf4/0x178 [mac80211]
    [  632.420095] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [  632.420101] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm irq_pruss_intc pru_rproc icss_iep dwc3 roles udc_core cfg80211 pm33xx omap_des omap_aes_driver omap_sham libdes pruss omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [  632.420220] CPU: 0 PID: 1038 Comm: kworker/0:0 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [  632.420234] Hardware name: Generic AM43 (Flattened Device Tree)
    [  632.420243] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [  632.420774] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [  632.420805] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [  632.420834] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [  632.420850] [<c09a0a84>] (warn_slowpath_fmt) from [<bf1972c0>] (ieee80211_bss_info_change_notify+0xf4/0x178 [mac80211])
    [  632.421319] [<bf1972c0>] (ieee80211_bss_info_change_notify [mac80211]) from [<bf1da6e0>] (ieee80211_set_disassoc+0x70/0x478 [mac80211])
    [  632.422106] [<bf1da6e0>] (ieee80211_set_disassoc [mac80211]) from [<bf1df34c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [  632.422877] [<bf1df34c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0f68c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [  632.424320] [<bf0f68c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0f6a88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [  632.424804] [<bf0f6a88>] (cfg80211_mlme_down [cfg80211]) from [<bf0fa974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [  632.425262] [<bf0fa974>] (cfg80211_disconnect [cfg80211]) from [<bf0c97c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [  632.425717] [<bf0c97c8>] (cfg80211_leave [cfg80211]) from [<bf0c9ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [  632.426171] [<bf0c9ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [  632.426438] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [  632.426465] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [  632.426479] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [  632.426493] [<c081eca0>] (dev_close.part.0) from [<bf0c9200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [  632.426741] [<bf0c9200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf1cfa84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [  632.427746] [<bf1cfa84>] (ieee80211_reconfig [mac80211]) from [<bf195408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [  632.449640] [<bf195408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [  632.451074] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [  632.451095] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [  632.451119] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [  632.451136] Exception stack(0xc118bfb0 to 0xc118bff8)
    [  632.451144] bfa0:                                     00000000 00000000 00000000 00000000
    [  632.451153] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [  632.451160] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [  632.451167] ---[ end trace 0000000000000006 ]---
    [  632.838597] ------------[ cut here ]------------
    [  632.838611] WARNING: CPU: 0 PID: 1038 at net/mac80211/driver-ops.h:633 __ieee80211_flush_queues+0x144/0x148 [mac80211]
    [  632.839998] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [  632.840005] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm irq_pruss_intc pru_rproc icss_iep dwc3 roles udc_core cfg80211 pm33xx omap_des omap_aes_driver omap_sham libdes pruss omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [  632.840123] CPU: 0 PID: 1038 Comm: kworker/0:0 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [  632.840137] Hardware name: Generic AM43 (Flattened Device Tree)
    [  632.840146] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [  632.840686] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [  632.840719] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [  632.840747] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [  632.840764] [<c09a0a84>] (warn_slowpath_fmt) from [<bf1ceb60>] (__ieee80211_flush_queues+0x144/0x148 [mac80211])
    [  632.841235] [<bf1ceb60>] (__ieee80211_flush_queues [mac80211]) from [<bf1da8e8>] (ieee80211_set_disassoc+0x278/0x478 [mac80211])
    [  632.842022] [<bf1da8e8>] (ieee80211_set_disassoc [mac80211]) from [<bf1df34c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [  632.842790] [<bf1df34c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0f68c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [  632.844251] [<bf0f68c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0f6a88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [  632.844733] [<bf0f6a88>] (cfg80211_mlme_down [cfg80211]) from [<bf0fa974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [  632.845188] [<bf0fa974>] (cfg80211_disconnect [cfg80211]) from [<bf0c97c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [  632.845643] [<bf0c97c8>] (cfg80211_leave [cfg80211]) from [<bf0c9ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [  632.846097] [<bf0c9ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [  632.846365] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [  632.846391] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [  632.846406] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [  632.846420] [<c081eca0>] (dev_close.part.0) from [<bf0c9200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [  632.846668] [<bf0c9200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf1cfa84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [  632.847695] [<bf1cfa84>] (ieee80211_reconfig [mac80211]) from [<bf195408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [  632.848508] [<bf195408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [  632.868801] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [  632.868861] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [  632.868884] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [  632.868902] Exception stack(0xc118bfb0 to 0xc118bff8)
    [  632.868910] bfa0:                                     00000000 00000000 00000000 00000000
    [  632.868918] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [  632.868925] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [  632.868932] ---[ end trace 0000000000000007 ]---
    [  633.228628] ------------[ cut here ]------------
    [  633.228642] WARNING: CPU: 0 PID: 1038 at net/mac80211/driver-ops.c:335 drv_ampdu_action+0x90/0xa4 [mac80211]
    [  633.230002] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [  633.230008] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm irq_pruss_intc pru_rproc icss_iep dwc3 roles udc_core cfg80211 pm33xx omap_des omap_aes_driver omap_sham libdes pruss omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [  633.230128] CPU: 0 PID: 1038 Comm: kworker/0:0 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [  633.230141] Hardware name: Generic AM43 (Flattened Device Tree)
    [  633.230150] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [  633.230686] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [  633.230718] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [  633.230746] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [  633.230762] [<c09a0a84>] (warn_slowpath_fmt) from [<bf199a4c>] (drv_ampdu_action+0x90/0xa4 [mac80211])
    [  633.231235] [<bf199a4c>] (drv_ampdu_action [mac80211]) from [<bf1a6e04>] (___ieee80211_stop_rx_ba_session+0xbc/0x18c [mac80211])
    [  633.232026] [<bf1a6e04>] (___ieee80211_stop_rx_ba_session [mac80211]) from [<bf1a4e20>] (ieee80211_sta_tear_down_BA_sessions+0x50/0x11c [mac80211])
    [  633.232795] [<bf1a4e20>] (ieee80211_sta_tear_down_BA_sessions [mac80211]) from [<bf19b084>] (__sta_info_destroy_part1+0x38/0x20c [mac80211])
    [  633.233561] [<bf19b084>] (__sta_info_destroy_part1 [mac80211]) from [<bf19e174>] (__sta_info_flush+0xe0/0x1bc [mac80211])
    [  633.234327] [<bf19e174>] (__sta_info_flush [mac80211]) from [<bf1da714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [  633.235096] [<bf1da714>] (ieee80211_set_disassoc [mac80211]) from [<bf1df34c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [  633.235861] [<bf1df34c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0f68c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [  633.237303] [<bf0f68c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0f6a88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [  633.237780] [<bf0f6a88>] (cfg80211_mlme_down [cfg80211]) from [<bf0fa974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [  633.238239] [<bf0fa974>] (cfg80211_disconnect [cfg80211]) from [<bf0c97c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [  633.259515] [<bf0c97c8>] (cfg80211_leave [cfg80211]) from [<bf0c9ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [  633.260493] [<bf0c9ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [  633.260775] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [  633.260804] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [  633.260818] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [  633.260832] [<c081eca0>] (dev_close.part.0) from [<bf0c9200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [  633.261089] [<bf0c9200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf1cfa84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [  633.262960] [<bf1cfa84>] (ieee80211_reconfig [mac80211]) from [<bf195408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [  633.263846] [<bf195408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [  633.264276] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [  633.264295] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [  633.264316] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [  633.264333] Exception stack(0xc118bfb0 to 0xc118bff8)
    [  633.264342] bfa0:                                     00000000 00000000 00000000 00000000
    [  633.264350] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [  633.264357] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [  633.264365] ---[ end trace 0000000000000008 ]---
    [  633.748565] wlan0: HW problem - can not stop rx aggregation for f8:32:e4:a9:c5:24 tid 0
    [  633.748615] ------------[ cut here ]------------
    [  633.748619] WARNING: CPU: 0 PID: 1038 at net/mac80211/driver-ops.h:514 __sta_info_destroy_part1+0x1b0/0x20c [mac80211]
    [  633.749931] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [  633.749938] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm irq_pruss_intc pru_rproc icss_iep dwc3 roles udc_core cfg80211 pm33xx omap_des omap_aes_driver omap_sham libdes pruss omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [  633.750059] CPU: 0 PID: 1038 Comm: kworker/0:0 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [  633.750072] Hardware name: Generic AM43 (Flattened Device Tree)
    [  633.750081] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [  633.750624] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [  633.750658] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [  633.750687] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [  633.750703] [<c09a0a84>] (warn_slowpath_fmt) from [<bf19b1fc>] (__sta_info_destroy_part1+0x1b0/0x20c [mac80211])
    [  633.751179] [<bf19b1fc>] (__sta_info_destroy_part1 [mac80211]) from [<bf19e174>] (__sta_info_flush+0xe0/0x1bc [mac80211])
    [  633.751960] [<bf19e174>] (__sta_info_flush [mac80211]) from [<bf1da714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [  633.752733] [<bf1da714>] (ieee80211_set_disassoc [mac80211]) from [<bf1df34c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [  633.753500] [<bf1df34c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0f68c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [  633.755418] [<bf0f68c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0f6a88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [  633.756115] [<bf0f6a88>] (cfg80211_mlme_down [cfg80211]) from [<bf0fa974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [  633.756575] [<bf0fa974>] (cfg80211_disconnect [cfg80211]) from [<bf0c97c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [  633.757035] [<bf0c97c8>] (cfg80211_leave [cfg80211]) from [<bf0c9ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [  633.757490] [<bf0c9ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [  633.757757] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [  633.757785] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [  633.757799] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [  633.757813] [<c081eca0>] (dev_close.part.0) from [<bf0c9200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [  633.758061] [<bf0c9200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf1cfa84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [  633.778412] [<bf1cfa84>] (ieee80211_reconfig [mac80211]) from [<bf195408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [  633.781013] [<bf195408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [  633.782122] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [  633.782143] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [  633.782165] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [  633.782183] Exception stack(0xc118bfb0 to 0xc118bff8)
    [  633.782191] bfa0:                                     00000000 00000000 00000000 00000000
    [  633.782199] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [  633.782206] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [  633.782213] ---[ end trace 0000000000000009 ]---
    [  634.168560] ------------[ cut here ]------------
    [  634.168575] WARNING: CPU: 0 PID: 1038 at net/mac80211/driver-ops.c:118 drv_sta_state+0x26c/0x2cc [mac80211]
    [  634.169968] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [  634.169974] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm irq_pruss_intc pru_rproc icss_iep dwc3 roles udc_core cfg80211 pm33xx omap_des omap_aes_driver omap_sham libdes pruss omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [  634.170094] CPU: 0 PID: 1038 Comm: kworker/0:0 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [  634.170108] Hardware name: Generic AM43 (Flattened Device Tree)
    [  634.170118] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [  634.170646] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [  634.170680] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [  634.170709] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [  634.170725] [<c09a0a84>] (warn_slowpath_fmt) from [<bf1992e4>] (drv_sta_state+0x26c/0x2cc [mac80211])
    [  634.171194] [<bf1992e4>] (drv_sta_state [mac80211]) from [<bf19c5a8>] (sta_info_move_state+0x1d0/0x2c4 [mac80211])
    [  634.171978] [<bf19c5a8>] (sta_info_move_state [mac80211]) from [<bf19de80>] (__sta_info_destroy_part2+0x19c/0x1d8 [mac80211])
    [  634.172746] [<bf19de80>] (__sta_info_destroy_part2 [mac80211]) from [<bf19e1d0>] (__sta_info_flush+0x13c/0x1bc [mac80211])
    [  634.173513] [<bf19e1d0>] (__sta_info_flush [mac80211]) from [<bf1da714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [  634.174282] [<bf1da714>] (ieee80211_set_disassoc [mac80211]) from [<bf1df34c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [  634.175049] [<bf1df34c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0f68c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [  634.176494] [<bf0f68c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0f6a88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [  634.176973] [<bf0f6a88>] (cfg80211_mlme_down [cfg80211]) from [<bf0fa974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [  634.177428] [<bf0fa974>] (cfg80211_disconnect [cfg80211]) from [<bf0c97c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [  634.177884] [<bf0c97c8>] (cfg80211_leave [cfg80211]) from [<bf0c9ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [  634.178338] [<bf0c9ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [  634.189919] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [  634.189989] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [  634.190005] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [  634.190020] [<c081eca0>] (dev_close.part.0) from [<bf0c9200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [  634.190741] [<bf0c9200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf1cfa84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [  634.192598] [<bf1cfa84>] (ieee80211_reconfig [mac80211]) from [<bf195408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [  634.193491] [<bf195408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [  634.193925] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [  634.193945] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [  634.193967] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [  634.193984] Exception stack(0xc118bfb0 to 0xc118bff8)
    [  634.193992] bfa0:                                     00000000 00000000 00000000 00000000
    [  634.194001] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [  634.194008] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [  634.194015] ---[ end trace 000000000000000a ]---
    [  634.668578] ------------[ cut here ]------------
    [  634.668592] WARNING: CPU: 0 PID: 1038 at net/mac80211/sta_info.c:1069 __sta_info_destroy_part2+0x1d4/0x1d8 [mac80211]
    [  634.670019] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm irq_pruss_intc pru_rproc icss_iep dwc3 roles udc_core cfg80211 pm33xx omap_des omap_aes_driver omap_sham libdes pruss omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [  634.670141] CPU: 0 PID: 1038 Comm: kworker/0:0 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [  634.670155] Hardware name: Generic AM43 (Flattened Device Tree)
    [  634.670165] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [  634.670700] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [  634.670733] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [  634.670762] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [  634.670779] [<c09a0a50>] (warn_slowpath_fmt) from [<bf19deb8>] (__sta_info_destroy_part2+0x1d4/0x1d8 [mac80211])
    [  634.671258] [<bf19deb8>] (__sta_info_destroy_part2 [mac80211]) from [<bf19e1d0>] (__sta_info_flush+0x13c/0x1bc [mac80211])
    [  634.672049] [<bf19e1d0>] (__sta_info_flush [mac80211]) from [<bf1da714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [  634.672823] [<bf1da714>] (ieee80211_set_disassoc [mac80211]) from [<bf1df34c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [  634.673589] [<bf1df34c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0f68c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [  634.675020] [<bf0f68c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0f6a88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [  634.675510] [<bf0f6a88>] (cfg80211_mlme_down [cfg80211]) from [<bf0fa974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [  634.675970] [<bf0fa974>] (cfg80211_disconnect [cfg80211]) from [<bf0c97c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [  634.676428] [<bf0c97c8>] (cfg80211_leave [cfg80211]) from [<bf0c9ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [  634.676882] [<bf0c9ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [  634.677148] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [  634.677175] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [  634.677189] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [  634.677203] [<c081eca0>] (dev_close.part.0) from [<bf0c9200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [  634.677450] [<bf0c9200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf1cfa84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [  634.678459] [<bf1cfa84>] (ieee80211_reconfig [mac80211]) from [<bf195408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [  634.699921] [<bf195408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [  634.701351] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [  634.701375] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [  634.701398] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [  634.701416] Exception stack(0xc118bfb0 to 0xc118bff8)
    [  634.701424] bfa0:                                     00000000 00000000 00000000 00000000
    [  634.701432] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [  634.701440] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [  634.701447] ---[ end trace 000000000000000b ]---
    [  635.208555] ------------[ cut here ]------------
    [  635.208569] WARNING: CPU: 0 PID: 1038 at net/mac80211/driver-ops.h:248 ieee80211_key_replace+0x750/0x798 [mac80211]
    [  635.209916] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [  635.209923] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm irq_pruss_intc pru_rproc icss_iep dwc3 roles udc_core cfg80211 pm33xx omap_des omap_aes_driver omap_sham libdes pruss omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [  635.210045] CPU: 0 PID: 1038 Comm: kworker/0:0 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [  635.210059] Hardware name: Generic AM43 (Flattened Device Tree)
    [  635.210068] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [  635.210601] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [  635.210635] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [  635.210664] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [  635.210680] [<c09a0a84>] (warn_slowpath_fmt) from [<bf1cac20>] (ieee80211_key_replace+0x750/0x798 [mac80211])
    [  635.211159] [<bf1cac20>] (ieee80211_key_replace [mac80211]) from [<bf1cba4c>] (ieee80211_free_sta_keys+0xa4/0xd8 [mac80211])
    [  635.211946] [<bf1cba4c>] (ieee80211_free_sta_keys [mac80211]) from [<bf19dd10>] (__sta_info_destroy_part2+0x2c/0x1d8 [mac80211])
    [  635.212717] [<bf19dd10>] (__sta_info_destroy_part2 [mac80211]) from [<bf19e1d0>] (__sta_info_flush+0x13c/0x1bc [mac80211])
    [  635.213485] [<bf19e1d0>] (__sta_info_flush [mac80211]) from [<bf1da714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [  635.214255] [<bf1da714>] (ieee80211_set_disassoc [mac80211]) from [<bf1df34c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [  635.215023] [<bf1df34c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0f68c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [  635.216464] [<bf0f68c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0f6a88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [  635.216949] [<bf0f6a88>] (cfg80211_mlme_down [cfg80211]) from [<bf0fa974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [  635.217406] [<bf0fa974>] (cfg80211_disconnect [cfg80211]) from [<bf0c97c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [  635.217862] [<bf0c97c8>] (cfg80211_leave [cfg80211]) from [<bf0c9ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [  635.218315] [<bf0c9ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [  635.229948] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [  635.230018] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [  635.230033] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [  635.230049] [<c081eca0>] (dev_close.part.0) from [<bf0c9200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [  635.230799] [<bf0c9200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf1cfa84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [  635.232608] [<bf1cfa84>] (ieee80211_reconfig [mac80211]) from [<bf195408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [  635.233496] [<bf195408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [  635.233927] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [  635.233947] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [  635.233969] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [  635.233986] Exception stack(0xc118bfb0 to 0xc118bff8)
    [  635.233995] bfa0:                                     00000000 00000000 00000000 00000000
    [  635.234004] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [  635.234011] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [  635.234018] ---[ end trace 000000000000000c ]---
    [  635.708571] wlan0: failed to remove key (0, f8:32:e4:a9:c5:24) from hardware (-5)
    [  635.708779] ------------[ cut here ]------------
    [  635.708785] WARNING: CPU: 0 PID: 1038 at net/mac80211/sta_info.c:1086 __sta_info_destroy_part2+0x138/0x1d8 [mac80211]
    [  635.710153] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm irq_pruss_intc pru_rproc icss_iep dwc3 roles udc_core cfg80211 pm33xx omap_des omap_aes_driver omap_sham libdes pruss omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [  635.710277] CPU: 0 PID: 1038 Comm: kworker/0:0 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [  635.710292] Hardware name: Generic AM43 (Flattened Device Tree)
    [  635.710301] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [  635.710829] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [  635.710861] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [  635.710892] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [  635.710908] [<c09a0a50>] (warn_slowpath_fmt) from [<bf19de1c>] (__sta_info_destroy_part2+0x138/0x1d8 [mac80211])
    [  635.711375] [<bf19de1c>] (__sta_info_destroy_part2 [mac80211]) from [<bf19e1d0>] (__sta_info_flush+0x13c/0x1bc [mac80211])
    [  635.712156] [<bf19e1d0>] (__sta_info_flush [mac80211]) from [<bf1da714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [  635.712929] [<bf1da714>] (ieee80211_set_disassoc [mac80211]) from [<bf1df34c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [  635.713696] [<bf1df34c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0f68c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [  635.715161] [<bf0f68c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0f6a88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [  635.715635] [<bf0f6a88>] (cfg80211_mlme_down [cfg80211]) from [<bf0fa974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [  635.716092] [<bf0fa974>] (cfg80211_disconnect [cfg80211]) from [<bf0c97c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [  635.716550] [<bf0c97c8>] (cfg80211_leave [cfg80211]) from [<bf0c9ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [  635.717002] [<bf0c9ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [  635.717267] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [  635.717295] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [  635.717309] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [  635.717322] [<c081eca0>] (dev_close.part.0) from [<bf0c9200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [  635.717570] [<bf0c9200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf1cfa84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [  635.734238] [<bf1cfa84>] (ieee80211_reconfig [mac80211]) from [<bf195408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [  635.736087] [<bf195408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [  635.736554] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [  635.736573] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [  635.736595] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [  635.736613] Exception stack(0xc118bfb0 to 0xc118bff8)
    [  635.736622] bfa0:                                     00000000 00000000 00000000 00000000
    [  635.736631] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [  635.736638] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [  635.736646] ---[ end trace 000000000000000d ]---
    [  636.088592] ------------[ cut here ]------------
    [  636.088606] WARNING: CPU: 0 PID: 1038 at net/mac80211/sta_info.c:1094 __sta_info_destroy_part2+0x190/0x1d8 [mac80211]
    [  636.089972] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm irq_pruss_intc pru_rproc icss_iep dwc3 roles udc_core cfg80211 pm33xx omap_des omap_aes_driver omap_sham libdes pruss omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [  636.090092] CPU: 0 PID: 1038 Comm: kworker/0:0 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [  636.090106] Hardware name: Generic AM43 (Flattened Device Tree)
    [  636.090116] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [  636.090649] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [  636.090682] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [  636.090711] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [  636.090728] [<c09a0a50>] (warn_slowpath_fmt) from [<bf19de74>] (__sta_info_destroy_part2+0x190/0x1d8 [mac80211])
    [  636.091207] [<bf19de74>] (__sta_info_destroy_part2 [mac80211]) from [<bf19e1d0>] (__sta_info_flush+0x13c/0x1bc [mac80211])
    [  636.091998] [<bf19e1d0>] (__sta_info_flush [mac80211]) from [<bf1da714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [  636.092770] [<bf1da714>] (ieee80211_set_disassoc [mac80211]) from [<bf1df34c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [  636.093536] [<bf1df34c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0f68c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [  636.094937] [<bf0f68c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0f6a88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [  636.095415] [<bf0f6a88>] (cfg80211_mlme_down [cfg80211]) from [<bf0fa974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [  636.095870] [<bf0fa974>] (cfg80211_disconnect [cfg80211]) from [<bf0c97c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [  636.096328] [<bf0c97c8>] (cfg80211_leave [cfg80211]) from [<bf0c9ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [  636.096780] [<bf0c9ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [  636.097047] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [  636.097074] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [  636.097088] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [  636.097101] [<c081eca0>] (dev_close.part.0) from [<bf0c9200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [  636.097353] [<bf0c9200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf1cfa84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [  636.098365] [<bf1cfa84>] (ieee80211_reconfig [mac80211]) from [<bf195408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [  636.119536] [<bf195408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [  636.120929] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [  636.120951] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [  636.120975] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [  636.120992] Exception stack(0xc118bfb0 to 0xc118bff8)
    [  636.121000] bfa0:                                     00000000 00000000 00000000 00000000
    [  636.121009] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [  636.121016] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [  636.121024] ---[ end trace 000000000000000e ]---
    [  636.478577] ------------[ cut here ]------------
    [  636.478590] WARNING: CPU: 0 PID: 1038 at net/mac80211/driver-ops.h:561 sta_set_sinfo+0xb54/0xba0 [mac80211]
    [  636.479908] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [  636.479914] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm irq_pruss_intc pru_rproc icss_iep dwc3 roles udc_core cfg80211 pm33xx omap_des omap_aes_driver omap_sham libdes pruss omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [  636.480034] CPU: 0 PID: 1038 Comm: kworker/0:0 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [  636.480047] Hardware name: Generic AM43 (Flattened Device Tree)
    [  636.480057] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [  636.480589] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [  636.480621] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [  636.480650] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [  636.480667] [<c09a0a84>] (warn_slowpath_fmt) from [<bf19dc98>] (sta_set_sinfo+0xb54/0xba0 [mac80211])
    [  636.481139] [<bf19dc98>] (sta_set_sinfo [mac80211]) from [<bf19dd98>] (__sta_info_destroy_part2+0xb4/0x1d8 [mac80211])
    [  636.481920] [<bf19dd98>] (__sta_info_destroy_part2 [mac80211]) from [<bf19e1d0>] (__sta_info_flush+0x13c/0x1bc [mac80211])
    [  636.482689] [<bf19e1d0>] (__sta_info_flush [mac80211]) from [<bf1da714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [  636.483457] [<bf1da714>] (ieee80211_set_disassoc [mac80211]) from [<bf1df34c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [  636.484223] [<bf1df34c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0f68c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [  636.485678] [<bf0f68c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0f6a88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [  636.486155] [<bf0f6a88>] (cfg80211_mlme_down [cfg80211]) from [<bf0fa974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [  636.486613] [<bf0fa974>] (cfg80211_disconnect [cfg80211]) from [<bf0c97c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [  636.487069] [<bf0c97c8>] (cfg80211_leave [cfg80211]) from [<bf0c9ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [  636.487521] [<bf0c9ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [  636.487791] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [  636.487817] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [  636.487831] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [  636.487845] [<c081eca0>] (dev_close.part.0) from [<bf0c9200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [  636.488098] [<bf0c9200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf1cfa84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [  636.510015] [<bf1cfa84>] (ieee80211_reconfig [mac80211]) from [<bf195408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [  636.511828] [<bf195408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [  636.512288] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [  636.512309] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [  636.512331] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [  636.512348] Exception stack(0xc118bfb0 to 0xc118bff8)
    [  636.512356] bfa0:                                     00000000 00000000 00000000 00000000
    [  636.512365] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [  636.512372] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [  636.512379] ---[ end trace 000000000000000f ]---
    [  636.868819] ------------[ cut here ]------------
    [  636.868833] WARNING: CPU: 0 PID: 1038 at net/mac80211/sta_info.c:272 sta_info_free+0x70/0x118 [mac80211]
    [  636.870219] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm irq_pruss_intc pru_rproc icss_iep dwc3 roles udc_core cfg80211 pm33xx omap_des omap_aes_driver omap_sham libdes pruss omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [  636.870339] CPU: 0 PID: 1038 Comm: kworker/0:0 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [  636.870354] Hardware name: Generic AM43 (Flattened Device Tree)
    [  636.870364] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [  636.870892] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [  636.870924] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [  636.870953] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [  636.870970] [<c09a0a50>] (warn_slowpath_fmt) from [<bf19c70c>] (sta_info_free+0x70/0x118 [mac80211])
    [  636.871444] [<bf19c70c>] (sta_info_free [mac80211]) from [<bf19e1d0>] (__sta_info_flush+0x13c/0x1bc [mac80211])
    [  636.872229] [<bf19e1d0>] (__sta_info_flush [mac80211]) from [<bf1da714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [  636.872997] [<bf1da714>] (ieee80211_set_disassoc [mac80211]) from [<bf1df34c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [  636.873763] [<bf1df34c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0f68c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [  636.875199] [<bf0f68c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0f6a88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [  636.875681] [<bf0f6a88>] (cfg80211_mlme_down [cfg80211]) from [<bf0fa974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [  636.876134] [<bf0fa974>] (cfg80211_disconnect [cfg80211]) from [<bf0c97c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [  636.876592] [<bf0c97c8>] (cfg80211_leave [cfg80211]) from [<bf0c9ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [  636.877042] [<bf0c9ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [  636.877308] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [  636.877335] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [  636.877350] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [  636.877364] [<c081eca0>] (dev_close.part.0) from [<bf0c9200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [  636.877611] [<bf0c9200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf1cfa84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [  636.899082] [<bf1cfa84>] (ieee80211_reconfig [mac80211]) from [<bf195408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [  636.900907] [<bf195408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [  636.901374] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [  636.901396] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [  636.901418] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [  636.901436] Exception stack(0xc118bfb0 to 0xc118bff8)
    [  636.901444] bfa0:                                     00000000 00000000 00000000 00000000
    [  636.901452] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [  636.901460] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [  636.901467] ---[ end trace 0000000000000010 ]---
    [  637.258577] ------------[ cut here ]------------
    [  637.258590] WARNING: CPU: 0 PID: 1038 at net/mac80211/sta_info.c:275 sta_info_free+0xb4/0x118 [mac80211]
    [  637.259967] sta_info_move_state() returned -5
    [  637.259971] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm irq_pruss_intc pru_rproc icss_iep dwc3 roles udc_core cfg80211 pm33xx omap_des omap_aes_driver omap_sham libdes pruss omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [  637.260090] CPU: 0 PID: 1038 Comm: kworker/0:0 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [  637.260102] Hardware name: Generic AM43 (Flattened Device Tree)
    [  637.260111] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [  637.260635] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [  637.260668] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [  637.260698] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [  637.260715] [<c09a0a84>] (warn_slowpath_fmt) from [<bf19c750>] (sta_info_free+0xb4/0x118 [mac80211])
    [  637.261185] [<bf19c750>] (sta_info_free [mac80211]) from [<bf19e1d0>] (__sta_info_flush+0x13c/0x1bc [mac80211])
    [  637.261966] [<bf19e1d0>] (__sta_info_flush [mac80211]) from [<bf1da714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [  637.262736] [<bf1da714>] (ieee80211_set_disassoc [mac80211]) from [<bf1df34c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [  637.263505] [<bf1df34c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0f68c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [  637.264918] [<bf0f68c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0f6a88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [  637.265402] [<bf0f6a88>] (cfg80211_mlme_down [cfg80211]) from [<bf0fa974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [  637.265859] [<bf0fa974>] (cfg80211_disconnect [cfg80211]) from [<bf0c97c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [  637.266314] [<bf0c97c8>] (cfg80211_leave [cfg80211]) from [<bf0c9ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [  637.266765] [<bf0c9ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [  637.267028] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [  637.267055] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [  637.267069] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [  637.267083] [<c081eca0>] (dev_close.part.0) from [<bf0c9200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [  637.267332] [<bf0c9200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf1cfa84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [  637.268344] [<bf1cfa84>] (ieee80211_reconfig [mac80211]) from [<bf195408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [  637.289573] [<bf195408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [  637.291005] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [  637.291027] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [  637.291048] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [  637.291066] Exception stack(0xc118bfb0 to 0xc118bff8)
    [  637.291074] bfa0:                                     00000000 00000000 00000000 00000000
    [  637.291083] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [  637.291090] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [  637.291097] ---[ end trace 0000000000000011 ]---
    [  637.648620] ------------[ cut here ]------------
    [  637.648634] WARNING: CPU: 0 PID: 1038 at net/mac80211/driver-ops.c:190 drv_conf_tx+0xc8/0x12c [mac80211]
    [  637.650044] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [  637.650050] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm irq_pruss_intc pru_rproc icss_iep dwc3 roles udc_core cfg80211 pm33xx omap_des omap_aes_driver omap_sham libdes pruss omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [  637.650171] CPU: 0 PID: 1038 Comm: kworker/0:0 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [  637.650183] Hardware name: Generic AM43 (Flattened Device Tree)
    [  637.650193] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [  637.650732] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [  637.650766] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [  637.650793] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [  637.650809] [<c09a0a84>] (warn_slowpath_fmt) from [<bf1995a0>] (drv_conf_tx+0xc8/0x12c [mac80211])
    [  637.651280] [<bf1995a0>] (drv_conf_tx [mac80211]) from [<bf1cf278>] (ieee80211_set_wmm_default+0x188/0x35c [mac80211])
    [  637.652073] [<bf1cf278>] (ieee80211_set_wmm_default [mac80211]) from [<bf1da82c>] (ieee80211_set_disassoc+0x1bc/0x478 [mac80211])
    [  637.652847] [<bf1da82c>] (ieee80211_set_disassoc [mac80211]) from [<bf1df34c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [  637.653613] [<bf1df34c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0f68c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [  637.655066] [<bf0f68c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0f6a88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [  637.655544] [<bf0f6a88>] (cfg80211_mlme_down [cfg80211]) from [<bf0fa974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [  637.656002] [<bf0fa974>] (cfg80211_disconnect [cfg80211]) from [<bf0c97c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [  637.656457] [<bf0c97c8>] (cfg80211_leave [cfg80211]) from [<bf0c9ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [  637.656910] [<bf0c9ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [  637.657177] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [  637.657203] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [  637.657217] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [  637.657231] [<c081eca0>] (dev_close.part.0) from [<bf0c9200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [  637.657482] [<bf0c9200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf1cfa84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [  637.658467] [<bf1cfa84>] (ieee80211_reconfig [mac80211]) from [<bf195408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [  637.679553] [<bf195408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [  637.680964] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [  637.680985] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [  637.681008] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [  637.681026] Exception stack(0xc118bfb0 to 0xc118bff8)
    [  637.681034] bfa0:                                     00000000 00000000 00000000 00000000
    [  637.681042] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [  637.681050] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [  637.681057] ---[ end trace 0000000000000012 ]---
    [  638.038580] ------------[ cut here ]------------
    [  638.038593] WARNING: CPU: 0 PID: 1038 at net/mac80211/driver-ops.h:927 ieee80211_assign_vif_chanctx+0x310/0x38c [mac80211]
    [  638.039937] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [  638.039945] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm irq_pruss_intc pru_rproc icss_iep dwc3 roles udc_core cfg80211 pm33xx omap_des omap_aes_driver omap_sham libdes pruss omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [  638.040063] CPU: 0 PID: 1038 Comm: kworker/0:0 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [  638.040077] Hardware name: Generic AM43 (Flattened Device Tree)
    [  638.040087] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [  638.040622] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [  638.040655] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [  638.040684] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [  638.040700] [<c09a0a84>] (warn_slowpath_fmt) from [<bf1d58d0>] (ieee80211_assign_vif_chanctx+0x310/0x38c [mac80211])
    [  638.041171] [<bf1d58d0>] (ieee80211_assign_vif_chanctx [mac80211]) from [<bf1d6758>] (__ieee80211_vif_release_channel+0x48/0x144 [mac80211])
    [  638.041952] [<bf1d6758>] (__ieee80211_vif_release_channel [mac80211]) from [<bf1d70c8>] (ieee80211_vif_release_channel+0x50/0x60 [mac80211])
    [  638.042717] [<bf1d70c8>] (ieee80211_vif_release_channel [mac80211]) from [<bf1da878>] (ieee80211_set_disassoc+0x208/0x478 [mac80211])
    [  638.043485] [<bf1da878>] (ieee80211_set_disassoc [mac80211]) from [<bf1df34c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [  638.044250] [<bf1df34c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0f68c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [  638.045693] [<bf0f68c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0f6a88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [  638.046174] [<bf0f6a88>] (cfg80211_mlme_down [cfg80211]) from [<bf0fa974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [  638.046627] [<bf0fa974>] (cfg80211_disconnect [cfg80211]) from [<bf0c97c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [  638.047081] [<bf0c97c8>] (cfg80211_leave [cfg80211]) from [<bf0c9ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [  638.047534] [<bf0c9ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [  638.047800] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [  638.047828] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [  638.047842] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [  638.047856] [<c081eca0>] (dev_close.part.0) from [<bf0c9200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [  638.048102] [<bf0c9200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf1cfa84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [  638.071766] [<bf1cfa84>] (ieee80211_reconfig [mac80211]) from [<bf195408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [  638.073571] [<bf195408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [  638.074038] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [  638.074057] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [  638.074080] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [  638.074097] Exception stack(0xc118bfb0 to 0xc118bff8)
    [  638.074106] bfa0:                                     00000000 00000000 00000000 00000000
    [  638.074115] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [  638.074122] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [  638.074129] ---[ end trace 0000000000000013 ]---
    [  638.428581] ------------[ cut here ]------------
    [  638.428594] WARNING: CPU: 0 PID: 1038 at net/mac80211/driver-ops.h:876 ieee80211_del_chanctx+0xfc/0x100 [mac80211]
    [  638.429855] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm irq_pruss_intc pru_rproc icss_iep dwc3 roles udc_core cfg80211 pm33xx omap_des omap_aes_driver omap_sham libdes pruss omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [  638.429975] CPU: 0 PID: 1038 Comm: kworker/0:0 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [  638.429988] Hardware name: Generic AM43 (Flattened Device Tree)
    [  638.429998] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [  638.430526] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [  638.430557] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [  638.430586] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [  638.430602] [<c09a0a50>] (warn_slowpath_fmt) from [<bf1d4258>] (ieee80211_del_chanctx+0xfc/0x100 [mac80211])
    [  638.431079] [<bf1d4258>] (ieee80211_del_chanctx [mac80211]) from [<bf1d42fc>] (ieee80211_free_chanctx+0xa0/0x10c [mac80211])
    [  638.431861] [<bf1d42fc>] (ieee80211_free_chanctx [mac80211]) from [<bf1d6810>] (__ieee80211_vif_release_channel+0x100/0x144 [mac80211])
    [  638.432633] [<bf1d6810>] (__ieee80211_vif_release_channel [mac80211]) from [<bf1d70c8>] (ieee80211_vif_release_channel+0x50/0x60 [mac80211])
    [  638.433400] [<bf1d70c8>] (ieee80211_vif_release_channel [mac80211]) from [<bf1da878>] (ieee80211_set_disassoc+0x208/0x478 [mac80211])
    [  638.434165] [<bf1da878>] (ieee80211_set_disassoc [mac80211]) from [<bf1df34c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [  638.434934] [<bf1df34c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0f68c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [  638.436378] [<bf0f68c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0f6a88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [  638.436863] [<bf0f6a88>] (cfg80211_mlme_down [cfg80211]) from [<bf0fa974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [  638.437319] [<bf0fa974>] (cfg80211_disconnect [cfg80211]) from [<bf0c97c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [  638.437775] [<bf0c97c8>] (cfg80211_leave [cfg80211]) from [<bf0c9ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [  638.438225] [<bf0c9ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [  638.438495] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [  638.438522] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [  638.459543] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [  638.459591] [<c081eca0>] (dev_close.part.0) from [<bf0c9200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [  638.460329] [<bf0c9200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf1cfa84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [  638.462201] [<bf1cfa84>] (ieee80211_reconfig [mac80211]) from [<bf195408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [  638.463073] [<bf195408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [  638.463508] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [  638.463528] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [  638.463550] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [  638.463568] Exception stack(0xc118bfb0 to 0xc118bff8)
    [  638.463576] bfa0:                                     00000000 00000000 00000000 00000000
    [  638.463584] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [  638.463591] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [  638.463598] ---[ end trace 0000000000000014 ]---
    And we capture normal and abnormal waveform.
    Nornal: test command "iperf3 -c 192.168.0.28 -t 72000 -i 1 -P 10 "
    SDIO clock is 48MHz
    Abnormal:
    1. wifi1.8v, 2. WL_EN, 3.WL_CLK_1V8, 4.WL_IRQ
  • Hi Lee,
    I think we are on the right track. Executing this command should successfully restart the WL18xx chip. I would investigate the WL_EN line while executing this command.
  • Hi Khan
    I update the module and this command is success restart the WL1807.
    waveform "execute command success", success log
    but executing this command still fail ,"iperf3 -c 192.168.0.28 -t 72000 -i 1 -P 10 "
    fail waveform
    I check the kernel message, the iperf3 test and start_recovery run the same procedure, but I got two different waveform.
    what causes this difference?
  • Hi Lee,
    start_recovery is a command that simulates a software restart. If you look at kernel logs you can see that the restart fails.
    Could you please post the command line logs of when you see this?
    Why have you added -P 10? If you were to remove this is it successful?
    I would also suggest lowering the SDIO clock to 10 MHz or less for more reliable communication.
    Could I please understand your setup in more detail? What is your testing environment, what AP are you connected to, etc?
  • Also,
    are you using debian or the processor SDK on the AM437x?
  • Hi Khan
    the kernel log when executing start_recovery
    [ 2511.767465] ------------[ cut here ]------------
    [ 2511.767483] WARNING: CPU: 0 PID: 733 at drivers/net/wireless/ti/wlcore/main.c:803 wl12xx_queue_recovery_work+0x68/0x6c [wlcore]
    [ 2511.767913] Modules linked in: cbc aes_arm_bs crypto_simd cryptd cdc_acm wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd usbcore sha256_generic libsha256 sha256_arm pru_rproc icss_iep irq_pruss_intc dwc3 cfg80211 roles udc_core usb_common pm33xx omap_des omap_aes_driver omap_sham pruss libdes omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc ip_tables x_tables
    [ 2511.768032] CPU: 0 PID: 733 Comm: bash Not tainted 5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 2511.768044] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 2511.768058] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 2511.768088] [<c010a064>] (show_stack) from [<c09b4964>] (__warn+0xd4/0xec)
    [ 2511.768120] [<c09b4964>] (__warn) from [<c09b49e0>] (warn_slowpath_fmt+0x64/0xc8)
    [ 2511.768136] [<c09b49e0>] (warn_slowpath_fmt) from [<bf1927d0>] (wl12xx_queue_recovery_work+0x68/0x6c [wlcore])
    [ 2511.768324] [<bf1927d0>] (wl12xx_queue_recovery_work [wlcore]) from [<bf1a2720>] (start_recovery_write+0x20/0x30 [wlcore])
    [ 2511.768554] [<bf1a2720>] (start_recovery_write [wlcore]) from [<c0410fc8>] (full_proxy_write+0x54/0x70)
    [ 2511.768681] [<c0410fc8>] (full_proxy_write) from [<c0243c88>] (vfs_write+0xcc/0x468)
    [ 2511.768706] [<c0243c88>] (vfs_write) from [<c0244178>] (ksys_write+0x64/0xec)
    [ 2511.768721] [<c0244178>] (ksys_write) from [<c0100060>] (ret_fast_syscall+0x0/0x5c)
    [ 2511.768736] Exception stack(0xc1c53fa8 to 0xc1c53ff0)
    [ 2511.768746] 3fa0:                   00000002 005a2a58 00000001 005a2a58 00000002 00000000
    [ 2511.768755] 3fc0: 00000002 005a2a58 b6f60500 00000004 b6ef5780 00000000 0056e948 00000000
    [ 2511.768761] 3fe0: 00000004 bedaa948 b6e8d4cf b6e137e6
    [ 2511.768767] ---[ end trace 0000000000000002 ]---
    [ 2512.013751] wlcore: Hardware recovery in progress. FW ver: Rev 8.9.0.0.90
    [ 2512.015582] wlcore: pc: 0x0, hint_sts: 0x00000020 count: 1
    [ 2512.018623] wlcore: down
    [ 2512.018693] wlcore: down
    [ 2512.028436] ieee80211 phy0: Hardware restart was requested
    [ 2512.450044] wlcore: using inverted interrupt logic: 8
    [ 2512.550202] wlcore: PHY firmware version: Rev 8.2.0.0.246
    [ 2512.675859] wlcore: firmware booted (Rev 8.9.0.0.90)
    [ 2512.753687] wlcore: Association completed.
    The following kernel log when wifi module loses after executing "iperf3 -c 192.168.0.28 -t 72000 -i 1 -P 10" 10~30 mins later.
    Seems  SDIO read fail (wl1271_sdio mmc2:0001:2: sdio read failed (-110))
    [  212.183257] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
    [  212.186473] wlcore: Association completed.
    [ 1009.758487] mmc2: Timeout waiting for hardware interrupt.
    [ 1009.758505] mmc2: sdhci: ============ SDHCI REGISTER DUMP ===========
    [ 1009.758511] mmc2: sdhci: Sys addr:  0x00000000 | Version:  0x00003101
    [ 1009.758519] mmc2: sdhci: Blk size:  0x00000100 | Blk cnt:  0x00000001
    [ 1009.758524] mmc2: sdhci: Argument:  0x20c22900 | Trn mode: 0x00000013
    [ 1009.758530] mmc2: sdhci: Present:   0x01f70a06 | Host ctl: 0x00000002
    [ 1009.758536] mmc2: sdhci: Power:     0x0000000f | Blk gap:  0x00000000
    [ 1009.758541] mmc2: sdhci: Wake-up:   0x00000000 | Clock:    0x00000087
    [ 1009.758546] mmc2: sdhci: Timeout:   0x0000000d | Int stat: 0x00000000
    [ 1009.758550] mmc2: sdhci: Int enab:  0x027f000b | Sig enab: 0x027f000b
    [ 1009.758556] mmc2: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [ 1009.758561] mmc2: sdhci: Caps:      0x05e10080 | Caps_1:   0x00000000
    [ 1009.758567] mmc2: sdhci: Cmd:       0x0000353a | Max curr: 0x00000000
    [ 1009.758572] mmc2: sdhci: Resp[0]:   0x00001000 | Resp[1]:  0x00000000
    [ 1009.758577] mmc2: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
    [ 1009.758581] mmc2: sdhci: Host ctl2: 0x00000000
    [ 1009.758585] mmc2: sdhci: ============================================
    [ 1009.758879] ------------[ cut here ]------------
    [ 1009.758888] WARNING: CPU: 0 PID: 666 at drivers/net/wireless/ti/wlcore/sdio.c:78 wl12xx_sdio_raw_read+0x104/0x160 [wlcore_sdio]
    [ 1009.758931] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1009.759051] CPU: 0 PID: 666 Comm: irq/93-wl18xx Tainted: G           O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1009.759063] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1009.759077] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1009.759109] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1009.759138] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [ 1009.759153] [<c09a0a50>] (warn_slowpath_fmt) from [<bf057354>] (wl12xx_sdio_raw_read+0x104/0x160 [wlcore_sdio])
    [ 1009.759182] [<bf057354>] (wl12xx_sdio_raw_read [wlcore_sdio]) from [<bf284428>] (wlcore_rx+0x1d0/0x760 [wlcore])
    [ 1009.759597] [<bf284428>] (wlcore_rx [wlcore]) from [<bf278868>] (wlcore_irq_locked+0x478/0x714 [wlcore])
    [ 1009.759827] [<bf278868>] (wlcore_irq_locked [wlcore]) from [<bf27af14>] (wlcore_irq+0xd8/0x1a8 [wlcore])
    [ 1009.760040] [<bf27af14>] (wlcore_irq [wlcore]) from [<c016b67c>] (irq_thread_fn+0x1c/0x78)
    [ 1009.760177] [<c016b67c>] (irq_thread_fn) from [<c016b8f4>] (irq_thread+0x108/0x260)
    [ 1009.760197] [<c016b8f4>] (irq_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1009.760220] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1009.760237] Exception stack(0xc28abfb0 to 0xc28abff8)
    [ 1009.760245] bfa0:                                     00000000 00000000 00000000 00000000
    [ 1009.760254] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1009.760261] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1009.760267] ---[ end trace 0000000000000002 ]---
    [ 1010.118558] wl1271_sdio mmc2:0001:2: sdio read failed (-110)
    [ 1010.118586] ------------[ cut here ]------------
    [ 1010.118590] WARNING: CPU: 0 PID: 666 at drivers/net/wireless/ti/wlcore/main.c:803 wl12xx_queue_recovery_work+0x68/0x6c [wlcore]
    [ 1010.118988] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1010.119107] CPU: 0 PID: 666 Comm: irq/93-wl18xx Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1010.119119] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1010.119133] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1010.119166] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1010.119194] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [ 1010.119210] [<c09a0a50>] (warn_slowpath_fmt) from [<bf27a7d0>] (wl12xx_queue_recovery_work+0x68/0x6c [wlcore])
    [ 1010.119374] [<bf27a7d0>] (wl12xx_queue_recovery_work [wlcore]) from [<bf27afc8>] (wlcore_irq+0x18c/0x1a8 [wlcore])
    [ 1010.119596] [<bf27afc8>] (wlcore_irq [wlcore]) from [<c016b67c>] (irq_thread_fn+0x1c/0x78)
    [ 1010.119735] [<c016b67c>] (irq_thread_fn) from [<c016b8f4>] (irq_thread+0x108/0x260)
    [ 1010.119753] [<c016b8f4>] (irq_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1010.119776] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1010.119792] Exception stack(0xc28abfb0 to 0xc28abff8)
    [ 1010.119801] bfa0:                                     00000000 00000000 00000000 00000000
    [ 1010.119809] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1010.119816] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1010.119822] ---[ end trace 0000000000000003 ]---
    [ 1010.200662] ------------[ cut here ]------------
    [ 1010.200676] WARNING: CPU: 0 PID: 1046 at drivers/net/wireless/ti/wlcore/main.c:803 wl12xx_queue_recovery_work+0x68/0x6c [wlcore]
    [ 1010.201094] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1010.201215] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1010.201228] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1010.201237] Workqueue: pm pm_runtime_work
    [ 1010.201274] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1010.201301] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1010.201329] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [ 1010.201345] [<c09a0a50>] (warn_slowpath_fmt) from [<bf27a7d0>] (wl12xx_queue_recovery_work+0x68/0x6c [wlcore])
    [ 1010.201515] [<bf27a7d0>] (wl12xx_queue_recovery_work [wlcore]) from [<bf27ae28>] (wlcore_runtime_suspend+0x144/0x158 [wlcore])
    [ 1010.201738] [<bf27ae28>] (wlcore_runtime_suspend [wlcore]) from [<c064d698>] (__rpm_callback+0xf8/0x160)
    [ 1010.201864] [<c064d698>] (__rpm_callback) from [<c064d754>] (rpm_callback+0x54/0x80)
    [ 1010.201879] [<c064d754>] (rpm_callback) from [<c064e360>] (rpm_suspend+0xe8/0x4c8)
    [ 1010.201894] [<c064e360>] (rpm_suspend) from [<c064eb14>] (pm_runtime_work+0xac/0xb8)
    [ 1010.201909] [<c064eb14>] (pm_runtime_work) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1010.201940] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1010.201958] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1010.201980] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1010.201996] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1010.202004] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1010.202012] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1010.202019] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1010.202025] ---[ end trace 0000000000000004 ]---
    [ 1012.121433] sched: RT throttling activated
    [ 1012.358553] wlcore: WARNING Enable for recovery failed
    [ 1012.358576] wlcore: Hardware recovery in progress. FW ver: Rev 8.9.0.0.86
    [ 1012.358594] wlcore: down
    [ 1012.358654] wlcore: down
    [ 1012.361028] ieee80211 phy0: Hardware restart was requested
    [ 1012.701664] wlcore: using inverted interrupt logic: 8
    [ 1014.153555] ------------[ cut here ]------------
    [ 1014.153570] WARNING: CPU: 0 PID: 1046 at drivers/net/wireless/ti/wlcore/sdio.c:123 wl12xx_sdio_raw_write+0x140/0x15c [wlcore_sdio]
    [ 1014.153617] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1014.153738] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1014.153750] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1014.153759] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1014.155118] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1014.155154] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1014.155184] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [ 1014.155201] [<c09a0a50>] (warn_slowpath_fmt) from [<bf057234>] (wl12xx_sdio_raw_write+0x140/0x15c [wlcore_sdio])
    [ 1014.155234] [<bf057234>] (wl12xx_sdio_raw_write [wlcore_sdio]) from [<bf287f28>] (wlcore_boot_upload_firmware+0x174/0x4a4 [wlcore])
    [ 1014.155628] [<bf287f28>] (wlcore_boot_upload_firmware [wlcore]) from [<bf175fcc>] (wl18xx_boot+0x910/0xd6c [wl18xx])
    [ 1014.155968] [<bf175fcc>] (wl18xx_boot [wl18xx]) from [<bf279de8>] (wl1271_op_add_interface+0x6d4/0x9c8 [wlcore])
    [ 1014.156170] [<bf279de8>] (wl1271_op_add_interface [wlcore]) from [<bf1dcf10>] (drv_add_interface+0x2c/0x7c [mac80211])
    [ 1014.157228] [<bf1dcf10>] (drv_add_interface [mac80211]) from [<bf213cc0>] (ieee80211_reconfig+0x2e8/0xf00 [mac80211])
    [ 1014.158049] [<bf213cc0>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1014.184634] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1014.186102] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1014.186124] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1014.186148] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1014.186166] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1014.186175] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1014.186183] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1014.186190] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1014.186197] ---[ end trace 0000000000000005 ]---
    [ 1014.418543] wl1271_sdio mmc2:0001:2: sdio write failed (-110)
    [ 1015.899210] mmc2: tried to HW reset card, got error -16
    [ 1017.500010] ------------[ cut here ]------------
    [ 1017.500027] WARNING: CPU: 0 PID: 1046 at drivers/net/wireless/ti/wlcore/sdio.c:123 wl12xx_sdio_raw_write+0x140/0x15c [wlcore_sdio]
    [ 1017.500078] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1017.500199] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1017.500212] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1017.500221] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1017.501578] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1017.501612] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1017.501642] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [ 1017.501658] [<c09a0a50>] (warn_slowpath_fmt) from [<bf057234>] (wl12xx_sdio_raw_write+0x140/0x15c [wlcore_sdio])
    [ 1017.501693] [<bf057234>] (wl12xx_sdio_raw_write [wlcore_sdio]) from [<bf280d5c>] (wlcore_set_partition+0xd4/0x510 [wlcore])
    [ 1017.502104] [<bf280d5c>] (wlcore_set_partition [wlcore]) from [<bf2753a8>] (wl12xx_set_power_on+0x7c/0x168 [wlcore])
    [ 1017.502328] [<bf2753a8>] (wl12xx_set_power_on [wlcore]) from [<bf279518>] (wl12xx_chip_wakeup+0x28/0x224 [wlcore])
    [ 1017.502543] [<bf279518>] (wl12xx_chip_wakeup [wlcore]) from [<bf279dd0>] (wl1271_op_add_interface+0x6bc/0x9c8 [wlcore])
    [ 1017.502756] [<bf279dd0>] (wl1271_op_add_interface [wlcore]) from [<bf1dcf10>] (drv_add_interface+0x2c/0x7c [mac80211])
    [ 1017.503683] [<bf1dcf10>] (drv_add_interface [mac80211]) from [<bf213cc0>] (ieee80211_reconfig+0x2e8/0xf00 [mac80211])
    [ 1017.504488] [<bf213cc0>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1017.505259] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1017.505684] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1017.505703] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1017.505725] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1017.505742] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1017.505750] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1017.505759] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1017.505766] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1017.505772] ---[ end trace 0000000000000006 ]---
    [ 1017.858519] wl1271_sdio mmc2:0001:2: sdio write failed (-16)
    [ 1019.320165] mmc2: tried to HW reset card, got error -16
    [ 1020.929444] ------------[ cut here ]------------
    [ 1020.929461] WARNING: CPU: 0 PID: 1046 at drivers/net/wireless/ti/wlcore/sdio.c:123 wl12xx_sdio_raw_write+0x140/0x15c [wlcore_sdio]
    [ 1020.929515] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1020.929638] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1020.929650] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1020.929660] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1020.931042] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1020.931076] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1020.931105] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [ 1020.931122] [<c09a0a50>] (warn_slowpath_fmt) from [<bf057234>] (wl12xx_sdio_raw_write+0x140/0x15c [wlcore_sdio])
    [ 1020.931156] [<bf057234>] (wl12xx_sdio_raw_write [wlcore_sdio]) from [<bf280d5c>] (wlcore_set_partition+0xd4/0x510 [wlcore])
    [ 1020.931580] [<bf280d5c>] (wlcore_set_partition [wlcore]) from [<bf2753a8>] (wl12xx_set_power_on+0x7c/0x168 [wlcore])
    [ 1020.931804] [<bf2753a8>] (wl12xx_set_power_on [wlcore]) from [<bf279518>] (wl12xx_chip_wakeup+0x28/0x224 [wlcore])
    [ 1020.932016] [<bf279518>] (wl12xx_chip_wakeup [wlcore]) from [<bf279dd0>] (wl1271_op_add_interface+0x6bc/0x9c8 [wlcore])
    [ 1020.932227] [<bf279dd0>] (wl1271_op_add_interface [wlcore]) from [<bf1dcf10>] (drv_add_interface+0x2c/0x7c [mac80211])
    [ 1020.933153] [<bf1dcf10>] (drv_add_interface [mac80211]) from [<bf213cc0>] (ieee80211_reconfig+0x2e8/0xf00 [mac80211])
    [ 1020.933969] [<bf213cc0>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1020.934741] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1020.935167] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1020.935186] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1020.935209] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1020.935225] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1020.935234] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1020.935242] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1020.935249] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1020.935255] ---[ end trace 0000000000000007 ]---
    [ 1021.288515] wl1271_sdio mmc2:0001:2: sdio write failed (-16)
    [ 1021.987085] wlcore: ERROR firmware boot failed despite 3 retries
    [ 1021.987109] ------------[ cut here ]------------
    [ 1021.987113] WARNING: CPU: 0 PID: 1046 at net/mac80211/util.c:2385 ieee80211_reconfig+0xc38/0xf00 [mac80211]
    [ 1021.988469] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1022.001651] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1022.001666] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1022.001675] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1022.002950] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1022.002985] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1022.003016] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [ 1022.003033] [<c09a0a50>] (warn_slowpath_fmt) from [<bf214610>] (ieee80211_reconfig+0xc38/0xf00 [mac80211])
    [ 1022.003562] [<bf214610>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1022.004354] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1022.004782] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1022.004803] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1022.004825] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1022.004842] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1022.004850] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1022.004858] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1022.004866] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1022.004872] ---[ end trace 0000000000000008 ]---
    [ 1022.268508] ------------[ cut here ]------------
    [ 1022.268522] WARNING: CPU: 0 PID: 1046 at net/mac80211/driver-ops.c:97 drv_remove_interface+0x88/0x8c [mac80211]
    [ 1022.269951] p2p-dev-wlan0: Failed check-sdata-in-driver check, flags: 0x0
    [ 1022.269959] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1022.270077] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1022.270091] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1022.270101] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1022.270642] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1022.270675] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1022.270704] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [ 1022.270721] [<c09a0a84>] (warn_slowpath_fmt) from [<bf1dd074>] (drv_remove_interface+0x88/0x8c [mac80211])
    [ 1022.271201] [<bf1dd074>] (drv_remove_interface [mac80211]) from [<bf1f1890>] (ieee80211_do_stop+0x5d0/0x8a8 [mac80211])
    [ 1022.271992] [<bf1f1890>] (ieee80211_do_stop [mac80211]) from [<bf0bffb8>] (cfg80211_stop_p2p_device+0x58/0x150 [cfg80211])
    [ 1022.273431] [<bf0bffb8>] (cfg80211_stop_p2p_device [cfg80211]) from [<bf0c0224>] (cfg80211_shutdown_all_interfaces+0x98/0xe0 [cfg80211])
    [ 1022.273920] [<bf0c0224>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1022.274845] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1022.275647] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1022.276075] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1022.276095] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1022.276118] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1022.276133] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1022.276141] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1022.276150] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1022.276157] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1022.276163] ---[ end trace 0000000000000009 ]---
    [ 1022.628567] wlan0: deauthenticating from 54:b8:0a:13:1e:66 by local choice (Reason: 3=DEAUTH_LEAVING)
    [ 1022.628605] ------------[ cut here ]------------
    [ 1022.628609] WARNING: CPU: 0 PID: 1046 at net/mac80211/driver-ops.h:172 ieee80211_bss_info_change_notify+0xf4/0x178 [mac80211]
    [ 1022.630021] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [ 1022.630027] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1022.630147] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1022.630160] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1022.630170] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1022.630692] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1022.630724] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1022.630752] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [ 1022.630770] [<c09a0a84>] (warn_slowpath_fmt) from [<bf1db2c0>] (ieee80211_bss_info_change_notify+0xf4/0x178 [mac80211])
    [ 1022.631239] [<bf1db2c0>] (ieee80211_bss_info_change_notify [mac80211]) from [<bf21e6e0>] (ieee80211_set_disassoc+0x70/0x478 [mac80211])
    [ 1022.632029] [<bf21e6e0>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1022.632798] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1022.634254] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1022.634732] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1022.635190] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1022.635646] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1022.636099] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1022.636367] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1022.636395] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1022.636409] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1022.636424] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1022.636676] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1022.637675] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1022.659572] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1022.661023] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1022.661046] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1022.661068] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1022.661085] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1022.661094] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1022.661102] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1022.661109] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1022.661116] ---[ end trace 000000000000000a ]---
    [ 1023.048504] ------------[ cut here ]------------
    [ 1023.048518] WARNING: CPU: 0 PID: 1046 at net/mac80211/driver-ops.h:633 __ieee80211_flush_queues+0x144/0x148 [mac80211]
    [ 1023.049860] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [ 1023.049867] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1023.049988] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1023.050001] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1023.050011] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1023.050543] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1023.050577] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1023.050606] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [ 1023.050622] [<c09a0a84>] (warn_slowpath_fmt) from [<bf212b60>] (__ieee80211_flush_queues+0x144/0x148 [mac80211])
    [ 1023.051099] [<bf212b60>] (__ieee80211_flush_queues [mac80211]) from [<bf21e8e8>] (ieee80211_set_disassoc+0x278/0x478 [mac80211])
    [ 1023.051891] [<bf21e8e8>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1023.052657] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1023.054113] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1023.054593] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1023.055049] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1023.055507] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1023.055959] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1023.056226] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1023.056252] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1023.056266] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1023.056280] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1023.056528] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1023.057526] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1023.058340] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1023.078565] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1023.078620] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1023.078642] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1023.078660] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1023.078668] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1023.078677] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1023.078684] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1023.078691] ---[ end trace 000000000000000b ]---
    [ 1023.438568] ------------[ cut here ]------------
    [ 1023.438584] WARNING: CPU: 0 PID: 1046 at net/mac80211/driver-ops.c:335 drv_ampdu_action+0x90/0xa4 [mac80211]
    [ 1023.439985] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [ 1023.439991] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1023.440110] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1023.440125] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1023.440134] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1023.440662] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1023.440695] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1023.440725] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [ 1023.440741] [<c09a0a84>] (warn_slowpath_fmt) from [<bf1dda4c>] (drv_ampdu_action+0x90/0xa4 [mac80211])
    [ 1023.441222] [<bf1dda4c>] (drv_ampdu_action [mac80211]) from [<bf1eae04>] (___ieee80211_stop_rx_ba_session+0xbc/0x18c [mac80211])
    [ 1023.442009] [<bf1eae04>] (___ieee80211_stop_rx_ba_session [mac80211]) from [<bf1e8e20>] (ieee80211_sta_tear_down_BA_sessions+0x50/0x11c [mac80211])
    [ 1023.442773] [<bf1e8e20>] (ieee80211_sta_tear_down_BA_sessions [mac80211]) from [<bf1df084>] (__sta_info_destroy_part1+0x38/0x20c [mac80211])
    [ 1023.443529] [<bf1df084>] (__sta_info_destroy_part1 [mac80211]) from [<bf1e2174>] (__sta_info_flush+0xe0/0x1bc [mac80211])
    [ 1023.444291] [<bf1e2174>] (__sta_info_flush [mac80211]) from [<bf21e714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [ 1023.445061] [<bf21e714>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1023.445826] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1023.447293] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1023.447775] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1023.448230] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1023.469438] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1023.470406] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1023.470688] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1023.470716] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1023.470729] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1023.470743] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1023.470997] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1023.472862] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1023.473756] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1023.474186] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1023.474207] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1023.474227] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1023.474243] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1023.474253] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1023.474261] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1023.474269] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1023.474276] ---[ end trace 000000000000000c ]---
    [ 1023.948529] wlan0: HW problem - can not stop rx aggregation for 54:b8:0a:13:1e:66 tid 0
    [ 1023.948584] ------------[ cut here ]------------
    [ 1023.948589] WARNING: CPU: 0 PID: 1046 at net/mac80211/driver-ops.h:514 __sta_info_destroy_part1+0x1b0/0x20c [mac80211]
    [ 1023.949958] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [ 1023.949965] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1023.950085] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1023.950100] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1023.950109] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1023.950638] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1023.950669] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1023.950698] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [ 1023.950715] [<c09a0a84>] (warn_slowpath_fmt) from [<bf1df1fc>] (__sta_info_destroy_part1+0x1b0/0x20c [mac80211])
    [ 1023.951191] [<bf1df1fc>] (__sta_info_destroy_part1 [mac80211]) from [<bf1e2174>] (__sta_info_flush+0xe0/0x1bc [mac80211])
    [ 1023.951973] [<bf1e2174>] (__sta_info_flush [mac80211]) from [<bf21e714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [ 1023.952750] [<bf21e714>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1023.953515] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1023.954958] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1023.955439] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1023.955899] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1023.956357] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1023.956810] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1023.957076] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1023.957103] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1023.957116] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1023.957130] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1023.957381] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1023.958378] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1023.978832] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1023.980295] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1023.980315] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1023.980339] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1023.980357] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1023.980366] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1023.980375] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1023.980382] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1023.980389] ---[ end trace 000000000000000d ]---
    [ 1024.368504] ------------[ cut here ]------------
    [ 1024.368517] WARNING: CPU: 0 PID: 1046 at net/mac80211/driver-ops.c:118 drv_sta_state+0x26c/0x2cc [mac80211]
    [ 1024.369886] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [ 1024.369892] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1024.370013] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1024.370027] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1024.370036] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1024.370565] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1024.370599] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1024.370629] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [ 1024.370645] [<c09a0a84>] (warn_slowpath_fmt) from [<bf1dd2e4>] (drv_sta_state+0x26c/0x2cc [mac80211])
    [ 1024.371118] [<bf1dd2e4>] (drv_sta_state [mac80211]) from [<bf1e05a8>] (sta_info_move_state+0x1d0/0x2c4 [mac80211])
    [ 1024.371900] [<bf1e05a8>] (sta_info_move_state [mac80211]) from [<bf1e1e80>] (__sta_info_destroy_part2+0x19c/0x1d8 [mac80211])
    [ 1024.372665] [<bf1e1e80>] (__sta_info_destroy_part2 [mac80211]) from [<bf1e21d0>] (__sta_info_flush+0x13c/0x1bc [mac80211])
    [ 1024.373434] [<bf1e21d0>] (__sta_info_flush [mac80211]) from [<bf21e714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [ 1024.374200] [<bf21e714>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1024.374966] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1024.376433] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1024.376914] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1024.377371] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1024.377827] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1024.378281] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1024.399451] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1024.399521] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1024.399536] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1024.399551] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1024.400308] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1024.402220] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1024.403102] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1024.403533] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1024.403552] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1024.403573] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1024.403590] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1024.403598] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1024.403607] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1024.403614] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1024.403622] ---[ end trace 000000000000000e ]---
    [ 1024.758506] ------------[ cut here ]------------
    [ 1024.758518] WARNING: CPU: 0 PID: 1046 at net/mac80211/sta_info.c:1069 __sta_info_destroy_part2+0x1d4/0x1d8 [mac80211]
    [ 1024.759875] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1024.759996] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1024.760010] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1024.760020] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1024.760544] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1024.760579] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1024.760608] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [ 1024.760625] [<c09a0a50>] (warn_slowpath_fmt) from [<bf1e1eb8>] (__sta_info_destroy_part2+0x1d4/0x1d8 [mac80211])
    [ 1024.761100] [<bf1e1eb8>] (__sta_info_destroy_part2 [mac80211]) from [<bf1e21d0>] (__sta_info_flush+0x13c/0x1bc [mac80211])
    [ 1024.761887] [<bf1e21d0>] (__sta_info_flush [mac80211]) from [<bf21e714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [ 1024.762658] [<bf21e714>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1024.763424] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1024.764860] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1024.765345] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1024.765800] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1024.766256] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1024.766711] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1024.766979] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1024.767006] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1024.767021] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1024.767035] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1024.767285] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1024.768287] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1024.789925] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1024.791346] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1024.791367] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1024.791390] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1024.791408] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1024.791417] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1024.791426] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1024.791432] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1024.791440] ---[ end trace 000000000000000f ]---
    [ 1025.178553] ------------[ cut here ]------------
    [ 1025.178567] WARNING: CPU: 0 PID: 1046 at net/mac80211/driver-ops.h:248 ieee80211_key_replace+0x750/0x798 [mac80211]
    [ 1025.179959] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [ 1025.179967] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1025.180088] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1025.180102] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1025.180112] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1025.180648] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1025.180683] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1025.180711] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [ 1025.180728] [<c09a0a84>] (warn_slowpath_fmt) from [<bf20ec20>] (ieee80211_key_replace+0x750/0x798 [mac80211])
    [ 1025.181202] [<bf20ec20>] (ieee80211_key_replace [mac80211]) from [<bf20fa4c>] (ieee80211_free_sta_keys+0xa4/0xd8 [mac80211])
    [ 1025.181985] [<bf20fa4c>] (ieee80211_free_sta_keys [mac80211]) from [<bf1e1d10>] (__sta_info_destroy_part2+0x2c/0x1d8 [mac80211])
    [ 1025.182758] [<bf1e1d10>] (__sta_info_destroy_part2 [mac80211]) from [<bf1e21d0>] (__sta_info_flush+0x13c/0x1bc [mac80211])
    [ 1025.183522] [<bf1e21d0>] (__sta_info_flush [mac80211]) from [<bf21e714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [ 1025.184289] [<bf21e714>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1025.185058] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1025.186513] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1025.186994] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1025.187452] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1025.187913] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1025.188367] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1025.208517] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1025.208578] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1025.208593] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1025.208607] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1025.209331] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1025.211443] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1025.212690] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1025.213142] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1025.213162] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1025.213184] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1025.213202] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1025.213210] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1025.213218] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1025.213225] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1025.213233] ---[ end trace 0000000000000010 ]---
    [ 1025.688519] wlan0: failed to remove key (0, 54:b8:0a:13:1e:66) from hardware (-5)
    [ 1025.688731] ------------[ cut here ]------------
    [ 1025.688737] WARNING: CPU: 0 PID: 1046 at net/mac80211/sta_info.c:1086 __sta_info_destroy_part2+0x138/0x1d8 [mac80211]
    [ 1025.690090] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1025.690211] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1025.690224] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1025.690233] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1025.690770] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1025.690804] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1025.690834] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [ 1025.690849] [<c09a0a50>] (warn_slowpath_fmt) from [<bf1e1e1c>] (__sta_info_destroy_part2+0x138/0x1d8 [mac80211])
    [ 1025.691324] [<bf1e1e1c>] (__sta_info_destroy_part2 [mac80211]) from [<bf1e21d0>] (__sta_info_flush+0x13c/0x1bc [mac80211])
    [ 1025.692115] [<bf1e21d0>] (__sta_info_flush [mac80211]) from [<bf21e714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [ 1025.692886] [<bf21e714>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1025.693657] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1025.695116] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1025.695591] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1025.696044] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1025.696500] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1025.696956] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1025.697221] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1025.697247] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1025.697261] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1025.697274] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1025.697525] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1025.718668] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1025.720520] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1025.720978] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1025.720998] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1025.721021] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1025.721039] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1025.721049] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1025.721057] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1025.721065] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1025.721072] ---[ end trace 0000000000000011 ]---
    [ 1026.078518] ------------[ cut here ]------------
    [ 1026.078530] WARNING: CPU: 0 PID: 1046 at net/mac80211/sta_info.c:1094 __sta_info_destroy_part2+0x190/0x1d8 [mac80211]
    [ 1026.079897] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1026.080020] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1026.080033] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1026.080044] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1026.080566] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1026.080599] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1026.080628] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [ 1026.080644] [<c09a0a50>] (warn_slowpath_fmt) from [<bf1e1e74>] (__sta_info_destroy_part2+0x190/0x1d8 [mac80211])
    [ 1026.081129] [<bf1e1e74>] (__sta_info_destroy_part2 [mac80211]) from [<bf1e21d0>] (__sta_info_flush+0x13c/0x1bc [mac80211])
    [ 1026.081910] [<bf1e21d0>] (__sta_info_flush [mac80211]) from [<bf21e714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [ 1026.082680] [<bf21e714>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1026.083448] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1026.084879] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1026.085365] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1026.085823] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1026.086279] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1026.086732] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1026.086999] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1026.087026] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1026.087040] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1026.087055] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1026.087306] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1026.088312] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1026.109890] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1026.111327] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1026.111349] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1026.111371] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1026.111389] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1026.111398] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1026.111406] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1026.111413] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1026.111420] ---[ end trace 0000000000000012 ]---
    [ 1026.468504] ------------[ cut here ]------------
    [ 1026.468517] WARNING: CPU: 0 PID: 1046 at net/mac80211/driver-ops.h:561 sta_set_sinfo+0xb54/0xba0 [mac80211]
    [ 1026.469929] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [ 1026.469936] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1026.470054] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1026.470067] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1026.470076] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1026.470619] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1026.470652] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1026.470682] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [ 1026.470697] [<c09a0a84>] (warn_slowpath_fmt) from [<bf1e1c98>] (sta_set_sinfo+0xb54/0xba0 [mac80211])
    [ 1026.471170] [<bf1e1c98>] (sta_set_sinfo [mac80211]) from [<bf1e1d98>] (__sta_info_destroy_part2+0xb4/0x1d8 [mac80211])
    [ 1026.471957] [<bf1e1d98>] (__sta_info_destroy_part2 [mac80211]) from [<bf1e21d0>] (__sta_info_flush+0x13c/0x1bc [mac80211])
    [ 1026.472726] [<bf1e21d0>] (__sta_info_flush [mac80211]) from [<bf21e714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [ 1026.473496] [<bf21e714>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1026.474261] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1026.475728] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1026.476214] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1026.476671] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1026.477125] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1026.477578] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1026.477845] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1026.477872] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1026.477886] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1026.477900] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1026.478147] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1026.499933] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1026.501763] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1026.502229] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1026.502249] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1026.502272] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1026.502289] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1026.502297] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1026.502305] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1026.502313] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1026.502320] ---[ end trace 0000000000000013 ]---
    [ 1026.858751] ------------[ cut here ]------------
    [ 1026.858765] WARNING: CPU: 0 PID: 1046 at net/mac80211/sta_info.c:272 sta_info_free+0x70/0x118 [mac80211]
    [ 1026.860183] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1026.860304] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1026.860318] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1026.860328] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1026.860860] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1026.860894] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1026.860922] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [ 1026.860938] [<c09a0a50>] (warn_slowpath_fmt) from [<bf1e070c>] (sta_info_free+0x70/0x118 [mac80211])
    [ 1026.861422] [<bf1e070c>] (sta_info_free [mac80211]) from [<bf1e21d0>] (__sta_info_flush+0x13c/0x1bc [mac80211])
    [ 1026.862209] [<bf1e21d0>] (__sta_info_flush [mac80211]) from [<bf21e714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [ 1026.862983] [<bf21e714>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1026.863750] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1026.865194] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1026.865672] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1026.866127] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1026.866585] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1026.867037] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1026.867303] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1026.867330] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1026.867345] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1026.867360] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1026.867609] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1026.889013] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1026.890819] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1026.891281] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1026.891301] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1026.891324] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1026.891341] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1026.891350] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1026.891359] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1026.891366] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1026.891373] ---[ end trace 0000000000000014 ]---
    [ 1027.368504] ------------[ cut here ]------------
    [ 1027.368517] WARNING: CPU: 0 PID: 1046 at net/mac80211/sta_info.c:275 sta_info_free+0xb4/0x118 [mac80211]
    [ 1027.370323] sta_info_move_state() returned -5
    [ 1027.370335] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1027.370454] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1027.370466] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1027.370475] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1027.371289] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1027.371323] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1027.371352] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [ 1027.371367] [<c09a0a84>] (warn_slowpath_fmt) from [<bf1e0750>] (sta_info_free+0xb4/0x118 [mac80211])
    [ 1027.371854] [<bf1e0750>] (sta_info_free [mac80211]) from [<bf1e21d0>] (__sta_info_flush+0x13c/0x1bc [mac80211])
    [ 1027.372641] [<bf1e21d0>] (__sta_info_flush [mac80211]) from [<bf21e714>] (ieee80211_set_disassoc+0xa4/0x478 [mac80211])
    [ 1027.373414] [<bf21e714>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1027.374186] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1027.375618] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1027.376096] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1027.376553] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1027.377010] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1027.377462] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1027.377728] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1027.377755] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1027.377768] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1027.377782] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1027.378030] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1027.397769] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1027.400384] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1027.401496] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1027.401517] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1027.401540] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1027.401558] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1027.401566] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1027.401574] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1027.401581] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1027.401588] ---[ end trace 0000000000000015 ]---
    [ 1027.758522] ------------[ cut here ]------------
    [ 1027.758536] WARNING: CPU: 0 PID: 1046 at net/mac80211/driver-ops.c:190 drv_conf_tx+0xc8/0x12c [mac80211]
    [ 1027.759871] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [ 1027.759878] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1027.759998] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1027.760012] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1027.760022] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1027.760544] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1027.760580] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1027.760608] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [ 1027.760624] [<c09a0a84>] (warn_slowpath_fmt) from [<bf1dd5a0>] (drv_conf_tx+0xc8/0x12c [mac80211])
    [ 1027.761102] [<bf1dd5a0>] (drv_conf_tx [mac80211]) from [<bf213278>] (ieee80211_set_wmm_default+0x188/0x35c [mac80211])
    [ 1027.761881] [<bf213278>] (ieee80211_set_wmm_default [mac80211]) from [<bf21e82c>] (ieee80211_set_disassoc+0x1bc/0x478 [mac80211])
    [ 1027.762653] [<bf21e82c>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1027.763417] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1027.764877] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1027.765357] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1027.765814] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1027.766272] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1027.766728] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1027.766992] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1027.767019] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1027.767033] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1027.767047] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1027.767295] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1027.768306] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1027.779848] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1027.781277] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1027.781299] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1027.781321] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1027.781339] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1027.781347] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1027.781355] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1027.781362] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1027.781370] ---[ end trace 0000000000000016 ]---
    [ 1028.138530] ------------[ cut here ]------------
    [ 1028.138543] WARNING: CPU: 0 PID: 1046 at net/mac80211/driver-ops.h:927 ieee80211_assign_vif_chanctx+0x310/0x38c [mac80211]
    [ 1028.139918] wlan0: Failed check-sdata-in-driver check, flags: 0x4
    [ 1028.139925] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1028.140044] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1028.140058] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1028.140068] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1028.140603] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1028.140638] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1028.140666] [<c09a09d4>] (__warn) from [<c09a0a84>] (warn_slowpath_fmt+0x98/0xc8)
    [ 1028.140683] [<c09a0a84>] (warn_slowpath_fmt) from [<bf2198d0>] (ieee80211_assign_vif_chanctx+0x310/0x38c [mac80211])
    [ 1028.141164] [<bf2198d0>] (ieee80211_assign_vif_chanctx [mac80211]) from [<bf21a758>] (__ieee80211_vif_release_channel+0x48/0x144 [mac80211])
    [ 1028.141947] [<bf21a758>] (__ieee80211_vif_release_channel [mac80211]) from [<bf21b0c8>] (ieee80211_vif_release_channel+0x50/0x60 [mac80211])
    [ 1028.142712] [<bf21b0c8>] (ieee80211_vif_release_channel [mac80211]) from [<bf21e878>] (ieee80211_set_disassoc+0x208/0x478 [mac80211])
    [ 1028.143481] [<bf21e878>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1028.144245] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1028.145689] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1028.146165] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1028.146623] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1028.147079] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1028.147533] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1028.147797] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1028.147824] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1028.147839] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1028.147852] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1028.148100] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1028.178465] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1028.180953] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1028.182060] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1028.182081] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1028.182103] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1028.182120] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1028.182129] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1028.182137] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1028.182144] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1028.182152] ---[ end trace 0000000000000017 ]---
    [ 1028.538519] ------------[ cut here ]------------
    [ 1028.538532] WARNING: CPU: 0 PID: 1046 at net/mac80211/driver-ops.h:876 ieee80211_del_chanctx+0xfc/0x100 [mac80211]
    [ 1028.539877] Modules linked in: cbc aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 xhci_plat_hcd xhci_hcd sha256_generic libsha256 sha256_arm pru_rproc irq_pruss_intc icss_iep dwc3 roles udc_core cfg80211 pm33xx pruss omap_des omap_aes_driver libdes omap_sham omap_crypto crypto_engine ti_emif_sram phy_omap_usb2 dwc3_omap wkup_m3_ipc wlcore_sdio wkup_m3_rproc xr_usb_serial_common(O) usbcore usb_common ip_tables x_tables
    [ 1028.539996] CPU: 0 PID: 1046 Comm: kworker/0:2 Tainted: G        W  O      5.10.100-rt62-EMU200.rel-1v0.0.0-g204ec708dc #1
    [ 1028.540009] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 1028.540018] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1028.540545] [<c010d6a4>] (unwind_backtrace) from [<c010a064>] (show_stack+0x10/0x14)
    [ 1028.540576] [<c010a064>] (show_stack) from [<c09a09d4>] (__warn+0xd4/0xec)
    [ 1028.540604] [<c09a09d4>] (__warn) from [<c09a0a50>] (warn_slowpath_fmt+0x64/0xc8)
    [ 1028.540622] [<c09a0a50>] (warn_slowpath_fmt) from [<bf218258>] (ieee80211_del_chanctx+0xfc/0x100 [mac80211])
    [ 1028.541101] [<bf218258>] (ieee80211_del_chanctx [mac80211]) from [<bf2182fc>] (ieee80211_free_chanctx+0xa0/0x10c [mac80211])
    [ 1028.541893] [<bf2182fc>] (ieee80211_free_chanctx [mac80211]) from [<bf21a810>] (__ieee80211_vif_release_channel+0x100/0x144 [mac80211])
    [ 1028.542654] [<bf21a810>] (__ieee80211_vif_release_channel [mac80211]) from [<bf21b0c8>] (ieee80211_vif_release_channel+0x50/0x60 [mac80211])
    [ 1028.543419] [<bf21b0c8>] (ieee80211_vif_release_channel [mac80211]) from [<bf21e878>] (ieee80211_set_disassoc+0x208/0x478 [mac80211])
    [ 1028.544185] [<bf21e878>] (ieee80211_set_disassoc [mac80211]) from [<bf22334c>] (ieee80211_mgd_deauth+0x144/0x270 [mac80211])
    [ 1028.544950] [<bf22334c>] (ieee80211_mgd_deauth [mac80211]) from [<bf0ed8c4>] (cfg80211_mlme_deauth+0x8c/0x100 [cfg80211])
    [ 1028.546412] [<bf0ed8c4>] (cfg80211_mlme_deauth [cfg80211]) from [<bf0eda88>] (cfg80211_mlme_down+0x64/0x88 [cfg80211])
    [ 1028.546895] [<bf0eda88>] (cfg80211_mlme_down [cfg80211]) from [<bf0f1974>] (cfg80211_disconnect+0xe8/0xf4 [cfg80211])
    [ 1028.547351] [<bf0f1974>] (cfg80211_disconnect [cfg80211]) from [<bf0c07c8>] (cfg80211_leave+0x24/0x30 [cfg80211])
    [ 1028.547808] [<bf0c07c8>] (cfg80211_leave [cfg80211]) from [<bf0c0ba8>] (cfg80211_netdev_notifier_call+0x24c/0x4b0 [cfg80211])
    [ 1028.548261] [<bf0c0ba8>] (cfg80211_netdev_notifier_call [cfg80211]) from [<c0147ffc>] (raw_notifier_call_chain+0x34/0x64)
    [ 1028.573455] [<c0147ffc>] (raw_notifier_call_chain) from [<c081e8a4>] (__dev_close_many+0x54/0x12c)
    [ 1028.573521] [<c081e8a4>] (__dev_close_many) from [<c081e9fc>] (dev_close_many+0x80/0x118)
    [ 1028.573536] [<c081e9fc>] (dev_close_many) from [<c081eca0>] (dev_close.part.0+0x44/0x74)
    [ 1028.573550] [<c081eca0>] (dev_close.part.0) from [<bf0c0200>] (cfg80211_shutdown_all_interfaces+0x74/0xe0 [cfg80211])
    [ 1028.574314] [<bf0c0200>] (cfg80211_shutdown_all_interfaces [cfg80211]) from [<bf213a84>] (ieee80211_reconfig+0xac/0xf00 [mac80211])
    [ 1028.576205] [<bf213a84>] (ieee80211_reconfig [mac80211]) from [<bf1d9408>] (ieee80211_restart_work+0xb4/0xec [mac80211])
    [ 1028.577088] [<bf1d9408>] (ieee80211_restart_work [mac80211]) from [<c013fd9c>] (process_one_work+0x1c4/0x45c)
    [ 1028.577521] [<c013fd9c>] (process_one_work) from [<c014008c>] (worker_thread+0x58/0x5fc)
    [ 1028.577541] [<c014008c>] (worker_thread) from [<c0145ca4>] (kthread+0x168/0x1bc)
    [ 1028.577562] [<c0145ca4>] (kthread) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [ 1028.577578] Exception stack(0xc1c17fb0 to 0xc1c17ff8)
    [ 1028.577587] 7fa0:                                     00000000 00000000 00000000 00000000
    [ 1028.577595] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1028.577603] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 1028.577610] ---[ end trace 0000000000000018 ]---
    [ 1029.078526] wlan0: failed to remove key (1, ff:ff:ff:ff:ff:ff) from hardware (-5)
    start_recovery is a command that simulates a software restart. If you look at kernel logs you can see that the restart fails.
    Can I run "start_recovery" command while wifi device lost?
    Why have you added -P 10? If you were to remove this is it successful?
    I have tried to remove -P 10, but It still fails.
    The next step will try to decrease clock frequency of SDIO. Will affect WiFi throughout, If setting 10M or lower to SDIO clock.
    The project's environment is listed below. If you need more information, please tell me.
    SDK version:is 08.02.00.24, and the kernel version is 5.10.100 with Debian 11 on AM437x.
    SDIO clock is 48MHz
    The test is run at room temperature in a wireless signal isolation room.
    And DUT connects to Netgear router with 2.4G. The specific P/N will add later.
  • Hey Lee,
    Thanks for this, it helps. Regarding the SDIO speed decrease, I understand it would decrease throughput, but it is a debug step for now. I am trying to understand if the issue is in hardware or software.
    I also just now noticed you are using RT linux, correct? We do not support RT linux and this could likely be the reason for these issues.
  • Hello Khan
    If it works at lower SDIO clock, it's meaning the issue is in HW side, right?
    This is meaning the WL1807 behavior will unpredictable on RT Linux. But It is OK on Linux(not RT)?
    Is any possible that modify some driver code make WL1807 usable on RT-Linux
    Would you like to show me some documents that can describe the differ between RT-Linux and Linux.
    I will post the test result of lower the SDIO clock tomorrow.
    Appreciate your help.
    Thank you.
  • If it works at lower SDIO clock, it's meaning the issue is in HW side, right?
    Correct, that is my thinking but it is difficult to understand as this might be a result of using rt-linux also. Slowing down the communication might result in a more reliable communication in general.
    Yes, we have not experienced this issue on non-RT Linux. I would encourage you to try Linux and see if this resolves your issue. There is a processor SDK for this am437. https://www.ti.com/tool/download/PROCESSOR-SDK-LINUX-AM437X
    Unfortunately I am not aware of a patch to the driver that would resolve this issue.
  • Hi
    Pin 42 is WLAN-logger. We have “WLAN gLogger” tool from RTTT, and it needs to have one parser file (different FW version need specific parser file). Could you tell me how to get this parser file.
  • , customer (Jackie) want to ask if they need to capture FW log for you to analyze the problem. If yes, do they need to have one specific FW bin file from you ?
    Thank you
    The parser should be the FW itself.
  • Hello Khan
    As your suggestions, I do some testing.
    1. My attempts to reset the WL1807 device when it is lost have failed. The waveform in the following pictures shows the unsuccessful reset attempts.
    It has retried three times, but it still failed.
    CH1:WL_EN; CH2:WL_clock CH3:WL_CMD CH4:WL_IRQ
    2. I run iperf3 on AM4378 EVB with RT-Linux and WL1837 EVB board
      The WL1837 device was lost after running the iperf3 application for 5 hours. Additionally, attempts to wake up the WL1837 device have failed.
    3. I decrease the clock of SDIO from 48MHz to 24MHz
       It has run iperf3 over 24 hours.
    4. WL_CLOCK and WL_CMD SR
    5. There is a level shift between AM4372 and WL1807, as shown in the schematic below.
    Why can't I reset WL1807/1837, when it is lost on the interface?
    Does the level shift affect the SDIO bus?
  • Hi Lee,
    How are you resetting the WL18x? There is a command to do this in linux:
    • echo 1 > /sys/kernel/debug/ieee80211/phy0/wlcore/start_recovery
    The level shift translates the 3v3 SDIO bus from the AM437 to the wl18xx's 1v8.
    Again, please do not use RT LInux, we do not supported this so behavior is unknown.
