LAUNCHXL-CC3235S: network_terminal example Compilation Error: "Error: Exception occurred calling addInstance()"
Part Number: LAUNCHXL-CC3235S
Other Parts Discussed in Thread: CC3235S, SYSCONFIG
I'm trying to run the network_terminal sample on my LP-CC3235S, but when I compile the program, I get the errors below. I'm using CCS 12.3.0.00005, but have also tried on CCS 9.1.0 and could not get it to work either. I have tried both the FreeRTOS and TI-RTOS7 versions, as well as with both GCC and TI-Clang versions, and they all produce the same error. My sdk version is 7.10.00.13. How can I resolve this?
**** Build of configuration MCU+Image for project network_terminal_CC3235S_LAUNCHXL_freertos_ticlang ****
"C:\\ti\\ccs1230\\ccs\\utils\\bin\\gmake" -k -j 16 all -O
Building file: "../common.syscfg"
Invoking: SysConfig
"C:/ti/sysconfig_1_12_0/sysconfig_cli.bat" -s "C:/ti/simplelink_cc32xx_sdk_7_10_00_13/.metadata/product.json" --script "C:/Users/micha_o8lgp/workspace_v12/network_terminal_CC3235S_LAUNCHXL_freertos_ticlang/common.syscfg" -o "syscfg" --compiler ticlang
Running script...
subdir_rules.mk:16: recipe for target 'build-1009566543' failed
at Proxy.<anonymous> (C:\ti\sysconfig_1_12_0\dist\webpack:\src\pinmux\services\scripting\scriptingGuard.ts:34:10)
at scriptFunc (C:\Users\micha_o8lgp\workspace_v12\network_terminal_CC3235S_LAUNCHXL_freertos_ticlang\common.syscfg:61:28)
at cb (C:\ti\sysconfig_1_12_0\dist\webpack:\src\pinmux\services\scripting\runScript.ts:94:27)
at Object.withDeprecatedAccess (C:\ti\sysconfig_1_12_0\dist\webpack:\src\pinmux\services\deprecatedAccessGuard.ts:14:10)
at Object.runAsUserScript (C:\ti\sysconfig_1_12_0\dist\webpack:\src\pinmux\services\scripting\scriptingGuard.ts:49:3)
at iteratee (C:\ti\sysconfig_1_12_0\dist\webpack:\src\pinmux\services\scripting\runScript.ts:94:5)
at baseEach (C:\ti\sysconfig_1_12_0\dist\webpack:\node_modules\lodash\lodash.js:530:11)
at Function.each (C:\ti\sysconfig_1_12_0\dist\webpack:\node_modules\lodash\lodash.js:9409:52)
at iteratee (C:\ti\sysconfig_1_12_0\dist\webpack:\src\pinmux\services\scripting\runScript.ts:92:6)
at at (C:\ti\sysconfig_1_12_0\dist\webpack:\node_modules\lodash\lodash.js:530:11)
Caused by: Error: Configurable "mode" of "/ti/drivers/SPI": Validation failed: [
"keyword": "type",
"dataPath": "/options/0/name",
"schemaPath": "#/definitions/EnumerationOption<number>/properties/name/type",
"params": {
"type": "number"
"message": "should be number"
"keyword": "additionalProperties",
"dataPath": "/options/1",
"schemaPath": "#/definitions/EnumerationOption<string>/additionalProperties",
"params": {
"additionalProperty": "legacyNames"
"message": "should NOT have additional properties"
"keyword": "anyOf",
"dataPath": "",
"schemaPath": "#/anyOf",
"params": {},
"message": "should match some schema in anyOf"
at validateConfigurable (C:\ti\sysconfig_1_12_0\dist\webpack:\src\pinmux\services\objectManagers\configurable.ts:1255:10)
at Object.createMetaContentConfigurableMgr (C:\ti\sysconfig_1_12_0\dist\webpack:\src\pinmux\services\objectManagers\configurable.ts:1281:3)
at b.createMetaContentConfigurableMgr (C:\ti\sysconfig_1_12_0\dist\webpack:\src\pinmux\services\objectManagers\moduleInstance.ts:761:10)
at iteratee (C:\ti\sysconfig_1_12_0\dist\webpack:\src\pinmux\services\objectManagers\moduleInstance.ts:755:57)
at baseMap (C:\ti\sysconfig_1_12_0\dist\webpack:\node_modules\lodash\lodash.js:653:23)
at Function.map (C:\ti\sysconfig_1_12_0\dist\webpack:\node_modules\lodash\lodash.js:9621:51)
at b.addMetaContentConfigurableMgrs (C:\ti\sysconfig_1_12_0\dist\webpack:\src\pinmux\services\objectManagers\moduleInstance.ts:755:30)
at b.initMetaConfigurables (C:\ti\sysconfig_1_12_0\dist\webpack:\src\pinmux\services\objectManagers\moduleInstance.ts:799:8)
at Function.createInstanceImpl (C:\ti\sysconfig_1_12_0\dist\webpack:\src\pinmux\services\objectManagers\moduleInstance.ts:125:11)
at Function.createInstance (C:\ti\sysconfig_1_12_0\dist\webpack:\src\pinmux\services\objectManagers\moduleInstance.ts:997:28)
gmake: *** [build-1009566543] Error 1
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
