CC3220S: Programming Error with SLI image.
Part Number: CC3220S
Hi!
Background:
We are using the CC3220S on a custom board. I have created an image file (.sli file) that uses custom keys and custom OTP files. I have been able to successfully program the this .sli file on other boards with no problems.
Current situation
On one of the boards, the Electrical team decided to replace just the MCU ( not the MCU and flash). After replacing the MCU alone, they tried to reprogram the device using the same .sli file; however, they were not able to do so successfully. The team faced the following error :
Question:
There is little information on the error code for 2632, can you help me figure out what this means?
Would replacing just the MCU work? Would the EE team need to replace both the MCU and the flash to prevent any secure boot errors?
Thanks for your help!
Vasav
