CC3235SF: secure socket problem
Part Number: CC3235SF
Hi  TI engineer
       Now SDK ver is 6.10.00.05,use secure  socket api  connect  serure server.The TCP connected  but not SSL handshake.
       This is my  secure socket code
	ssl_fd = sl_Socket(AF_INET,SOCK_STREAM,0);
		if(ssl_fd<0)
			goto tcp_error;
		SlSockSecureMethod_t method;
		_i16 status;
		method.SecureMethod = SL_SO_SEC_METHOD_SSLv3_TLSV1_2;
		status = sl_SetSockOpt(ssl_fd,SL_SOL_SOCKET,SL_SO_SECMETHOD,&method,sizeof(SlSockSecureMethod_t));
		SYS_LOGW(SSL_TAG,"sl_SetSockOpt SSL status=%d",status);
		SlSockSecureMask_t mask;
		mask.SecureMask = 0xFFFFF;
		status = sl_SetSockOpt(ssl_fd,SL_SOL_SOCKET,SL_SO_SECURE_MASK,&mask,sizeof(SlSockSecureMask_t));
		SYS_LOGW(SSL_TAG,"sl_SetSockOpt SSL mask=%d",status);
		status = sl_SetSockOpt(ssl_fd,SL_SOL_SOCKET,SL_SO_SECURE_FILES_CA_FILE_NAME,"ssl_ca",strlen("ssl_ca"));
		_u32 dummyVal;
		status = sl_SetSockOpt(ssl_fd,SL_SOL_SOCKET, SL_SO_SECURE_DISABLE_CERTIFICATE_STORE,&dummyVal,sizeof(dummyVal));
		ret = sl_Connect(ssl_fd,(struct sockaddr *)&dest, sizeof(dest));
		if(ret!=0)
			SYS_LOGE(SSL_TAG,"connect false,ret is %d,errno is %d\n",ret,errno);
			sl_Close(ssl_fd);
			sleep(1);
			goto create_socket;
		SYS_LOGI(SSL_TAG,"tcp client connect success\n");
		while(1)
	        ret = sl_Recv( ssl_fd, ssl_recv_buf, MAX_SSL_MSG ,0);
	        if( ret < 0 )
	            SYS_LOGE(SSL_TAG,"failed\n  ! mbedtls_ssl_read returned %d,errno=%d\r\n", ret ,errno);
	            break;
	        if( ret == 0 )
	            SYS_LOGE(SSL_TAG,"server discon" );
	            break;
			if(ssl_param.ssl_recv_deal)
	        	ssl_param.ssl_recv_deal(ssl_recv_buf,ret);
	sl_Close(ssl_fd);
  • Hi Lemon,
    Yes, this is expected. Because you have created pure TCP not a secured socket. For TLS sockets you need to create socket with secured flag (SL_SEC_SOCKET), e.g.:
    sl_Socket(SL_AF_INET, SL_SOCK_STREAM, SL_SEC_SOCKET);
    Jan
  • Thanks reply!
            This is a bad error to me. Now test successed.Does it support not verifying certificates?
    If you don't want to verify certificates, you can continue at connection when SL_ERROR_BSD_ESECSNOVERIFY is returned from sl_Connect() API.
    Jan
  • Hi
       I test connect AWS  ,need vertify server and client.  The certs is ok and  other device can connected AWS . But now connect false ,sl_Connect return -688.
    		_i16 status;
    		if(ssl_param.mode>=SSL_MODE_CHECK_SERVER)
    			SYS_LOGW(SSL_TAG,"sl_SetSockOpt SSL SL_SO_SECURE_FILES_CA_FILE_NAME=%d",status);
    		if(ssl_param.mode==SSL_MODE_CHECK_CLIENT)
    			status = sl_SetSockOpt(ssl_fd,SL_SOL_SOCKET,SL_SO_SECURE_FILES_CERTIFICATE_FILE_NAME,"ssl_client_cert",strlen("ssl_client_cert"));
    			SYS_LOGW(SSL_TAG,"sl_SetSockOpt SSL SL_SO_SECURE_FILES_CERTIFICATE_FILE_NAME=%d",status);
    			status = sl_SetSockOpt(ssl_fd,SL_SOL_SOCKET,SL_SO_SECURE_FILES_PRIVATE_KEY_FILE_NAME,"ssl_client_key",strlen("ssl_client_key"));
    			SYS_LOGW(SSL_TAG,"sl_SetSockOpt SSL SL_SO_SECURE_FILES_PRIVATE_KEY_FILE_NAME=%d",status);
    		_u32 dummyVal;
    		if(ret!=0)
    			if(ssl_param.mode == SSL_MODE_NOCHECK_SERVER && ret==SL_ERROR_BSD_ESECSNOVERIFY )
    				SYS_LOGE(SSL_TAG,"ssl connected but no vertify server");
    			else
    				sl_Close(ssl_fd);
    				sleep(1);
    				goto create_socket;
    What configuration is needed?
    For such authentication you need to set and upload certificate, private key and CA file. Usage of self-signed certificates with AWS may to be problematic.
    For more details about AWS connectivity issues please search for "SL_ERROR_BSD_ESEC_ASN_NO_SIGNER_E AWS" or "-688 AWS" at e2e forum. You will find multiple threads related to this topic.
    Jan
