CC3301: Cannot enable BLE on SDK 10.00.07.04
Part Number: CC3301
Other Parts Discussed in Thread: M2-CC3351
Hi all,
I want to porting BLE function to SDK 10.00.07.04 on AM62xx EVK platform ,then I refer to patches from M2-CC3351 SDK and document as below
https://dr-download.ti.com/software-development/driver-or-library/MD-UoRUAALCjn/1.0.0.7/cc33xx-linux-package-1.0.0.7-linux-x64-installer.run
software-dl.ti.com/.../How_To_Enable_M2CC3301_in_linux.html
but I cannot see BT interface when I enable BLE (echo 1 > /sys/kernel/debug/ieee80211/phy0/cc33xx/ble_enable), my detail logs and patches as below
dmesg logs
U-Boot 2024.04-ti-gfda88f8bcea3 (Jul 26 2024 - 11:00:12 +0000)
SoC:   AM62X SR1.0 HS-FS
Model: Texas Instruments AM625 SK
EEPROM not available at 0x50, trying to read at 0x51
Reading on-board EEPROM at 0x51 failed -121
DRAM:  2 GiB
Core:  81 devices, 31 uclasses, devicetree: separate
MMC:   mmc@fa10000: 0, mmc@fa00000: 1
Loading Environment from nowhere... OK
In:    serial
Out:   serial
Err:   serial
Net:   eth0: ethernet@8000000port@1
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
574 bytes read in 21 ms (26.4 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
20285952 bytes read in 228 ms (84.9 MiB/s)
61887 bytes read in 24 ms (2.5 MiB/s)
Working FDT set to 88000000
   Loading Device Tree to 000000008feed000, end 000000008fffffff ... OK
Working FDT set to 8feed000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 6.6.32-ti-01287-g6de6e418c80e-dirty (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240716) #1 SMP PREEMPT Fri Jul 26 14:32:20 UTC 2024
[    0.000000] KASLR disabled due to lack of seed
[    0.000000] Machine model: Texas Instruments AM625 SK
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created CMA memory pool at 0x00000000f7600000, size 128 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000f7600000..0x00000000ff5fffff (131072 KiB) map reusable linux,cma
[    0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000
[    0.000000] OF: reserved mem: 0x000000009c700000..0x000000009c7fffff (1024 KiB) map non-reusable ramoops@9c700000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB
[    0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009c800000..0x000000009cafffff (3072 KiB) nomap non-reusable ipc-memories@9c800000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009cb00000..0x000000009cbfffff (1024 KiB) nomap non-reusable m4f-dma-memory@9cb00000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB
[    0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009cc00000..0x000000009d9fffff (14336 KiB) nomap non-reusable m4f-memory@9cc00000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009da00000..0x000000009dafffff (1024 KiB) nomap non-reusable r5f-dma-memory@9da00000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009db00000..0x000000009e6fffff (12288 KiB) nomap non-reusable r5f-memory@9db00000
[    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
[    0.000000] OF: reserved mem: 0x00000000ff700000..0x00000000ffffffff (9216 KiB) nomap non-reusable framebuffer@ff700000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000008007ffff]
[    0.000000]   node   0: [mem 0x0000000080080000-0x000000009c7fffff]
[    0.000000]   node   0: [mem 0x000000009c800000-0x000000009e6fffff]
[    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x000000009fffffff]
[    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000ff6fffff]
[    0.000000]   node   0: [mem 0x00000000ff700000-0x00000000ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.4
[    0.000000] percpu: Embedded 20 pages/cpu s42920 r8192 d30808 u81920
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nt
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x00000000f0f00000-0x00000000f4f00000] (64MB)
[    0.000000] Memory: 1771852K/2097152K available (11968K kernel code, 1250K rwdata, 4036K rodata, 2432K init, 502K bss, 194228K reserved, 131072K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80c00000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000080440000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080450000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008653] Console: colour dummy device 80x25
[    0.013276] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023961] pid_max: default: 32768 minimum: 301
[    0.028790] LSM: initializing lsm=capability,integrity
[    0.034189] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.041785] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.052158] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.059515] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.067494] rcu: Hierarchical SRCU implementation.
[    0.072401] rcu:     Max phase no-delay instances is 1000.
[    0.078082] Platform MSI: msi-controller@1820000 domain created
[    0.084475] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.093960] EFI services will not be available.
[    0.098955] smp: Bringing up secondary CPUs ...
[    0.104406] Detected VIPT I-cache on CPU1
[    0.104519] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[    0.104537] GICv3: CPU1: using allocated LPI pending table @0x0000000080460000
[    0.104612] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.105509] Detected VIPT I-cache on CPU2
[    0.105583] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[    0.105598] GICv3: CPU2: using allocated LPI pending table @0x0000000080470000
[    0.105639] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.106392] Detected VIPT I-cache on CPU3
[    0.106452] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[    0.106468] GICv3: CPU3: using allocated LPI pending table @0x0000000080480000
[    0.106503] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.106599] smp: Brought up 1 node, 4 CPUs
[    0.186357] SMP: Total of 4 processors activated.
[    0.191172] CPU features: detected: 32-bit EL0 Support
[    0.196452] CPU features: detected: CRC32 instructions
[    0.201787] CPU: All CPU(s) started at EL2
[    0.205986] alternatives: applying system-wide alternatives
[    0.214041] devtmpfs: initialized
[    0.227763] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.237787] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.250312] pinctrl core: initialized pinctrl subsystem
[    0.256425] DMI not present or invalid.
[    0.261187] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.268417] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.275841] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.283932] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.292146] audit: initializing netlink subsys (disabled)
[    0.297976] audit: type=2000 audit(0.184:1): state=initialized audit_enabled=0 res=1
[    0.298507] thermal_sys: Registered thermal governor 'step_wise'
[    0.305911] thermal_sys: Registered thermal governor 'power_allocator'
[    0.312124] cpuidle: using governor menu
[    0.323016] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.330069] ASID allocator initialised with 65536 entries
[    0.349160] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    0.359025] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@f0000/pinctrl@a40000/cpsw-cpts
[    0.370513] platform connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    0.382735] Modules: 27680 pages in range for non-PLT usage
[    0.382749] Modules: 519200 pages in range for PLT usage
[    0.389503] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.401909] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.408319] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.415259] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.421667] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.428607] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.435018] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.441957] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.450111] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
[    0.459801] iommu: Default domain type: Translated
[    0.464749] iommu: DMA domain TLB invalidation policy: strict mode
[    0.471435] SCSI subsystem initialized
[    0.475667] usbcore: registered new interface driver usbfs
[    0.481318] usbcore: registered new interface driver hub
[    0.486790] usbcore: registered new device driver usb
[    0.492584] pps_core: LinuxPPS API ver. 1 registered
[    0.497665] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.507018] PTP clock support registered
[    0.511236] EDAC MC: Ver: 3.0.0
[    0.515133] scmi_core: SCMI protocol bus registered
[    0.520524] FPGA manager framework
[    0.524112] Advanced Linux Sound Architecture Driver Initialized.
[    0.531502] vgaarb: loaded
[    0.534764] clocksource: Switched to clocksource arch_sys_counter
[    0.541337] VFS: Disk quotas dquot_6.6.0
[    0.545390] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.559842] NET: Registered PF_INET protocol family
[    0.565172] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.574441] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    0.583281] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.591225] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.599448] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.607557] TCP: Hash tables configured (established 16384 bind 16384)
[    0.614528] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.621469] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.629080] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.635526] RPC: Registered named UNIX socket transport module.
[    0.641626] RPC: Registered udp transport module.
[    0.646436] RPC: Registered tcp transport module.
[    0.651245] RPC: Registered tcp-with-tls transport module.
[    0.656870] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.663462] NET: Registered PF_XDP protocol family
[    0.668385] PCI: CLS 0 bytes, default 64
[    0.674219] Initialise system trusted keyrings
[    0.679099] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[    0.686104] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.692468] NFS: Registering the id_resolver key type
[    0.697682] Key type id_resolver registered
[    0.701963] Key type id_legacy registered
[    0.706081] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.712937] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.754378] Key type asymmetric registered
[    0.758574] Asymmetric key parser 'x509' registered
[    0.763643] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.771215] io scheduler mq-deadline registered
[    0.775851] io scheduler kyber registered
[    0.779993] io scheduler bfq registered
[    0.787827] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[    0.794457] pinctrl-single f4000.pinctrl: 171 pins, size 684
[    0.802248] pinctrl-single a40000.pinctrl: 512 pins, size 2048
[    0.815852] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
[    0.835192] loop: module loaded
[    0.839963] megasas: 07.725.01.00-rc1
[    0.849284] VFIO - User Level meta-driver version: 0.3
[    0.855982] usbcore: registered new interface driver usb-storage
[    0.862872] i2c_dev: i2c /dev entries driver
[    0.869386] sdhci: Secure Digital Host Controller Interface driver
[    0.875740] sdhci: Copyright(c) Pierre Ossman
[    0.880474] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.887256] ledtrig-cpu: registered to indicate activity on CPUs
[    0.893773] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.901178] usbcore: registered new interface driver usbhid
[    0.906886] usbhid: USB HID core driver
[    0.911260] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
[    0.919735] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.928877] optee: probing for conduit method.
[    0.933465] optee: revision 4.2 (12d7c4ee)
[    0.933861] optee: dynamic shared memory is enabled
[    0.944005] random: crng init done
[    0.947626] optee: initialized driver
[    0.953541] NET: Registered PF_PACKET protocol family
[    0.958901] Key type dns_resolver registered
[    0.972228] registered taskstats version 1
[    0.976887] Loading compiled-in X.509 certificates
[    0.999576] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
[    1.056266] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=81, clk=20, ret=-19
[    1.090227] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[    1.097617] platform connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    1.107613] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    1.117373] i2c 1-003b: Fixed dependency cycle(s) with /connector-hdmi
[    1.124117] i2c 1-003b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
[    1.132117] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[    1.139398] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
[    1.145468] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[    1.154789] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[    1.164876] simple-framebuffer ff700000.framebuffer: framebuffer at 0xff700000, 0x8ca000 bytes
[    1.173718] simple-framebuffer ff700000.framebuffer: format=a8r8g8b8, mode=1920x1200x32, linelength=7680
[    1.199323] Console: switching to colour frame buffer device 240x75
[    1.220273] simple-framebuffer ff700000.framebuffer: fb0: simplefb registered!
[    1.229121] ti-udma 485c0100.dma-controller: Number of rings: 82
[    1.238423] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[    1.250046] ti-udma 485c0000.dma-controller: Number of rings: 150
[    1.261880] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[    1.272913] printk: console [ttyS2] disabled
[    1.277862] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 239, base_baud = 3000000) is a 8250
[    1.286792] printk: console [ttyS2] enabled
[    1.295247] printk: bootconsole [ns16550a0] disabled
[    1.307875] omap8250 2810000.serial: failed to get alias
[    1.317151] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[    1.322314] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
[    1.329276] Creating 7 MTD partitions on "fc40000.spi.0":
[    1.334674] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    1.341710] 0x000000080000-0x000000280000 : "ospi.tispl"
[    1.348313] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    1.354966] 0x000000680000-0x0000006c0000 : "ospi.env"
[    1.361391] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
[    1.368391] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[    1.375175] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[    1.388712] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[    1.434775] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.447149] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[    1.455257] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
[    1.463387] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
[    1.476395] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
[    1.482669] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[    1.489795] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[    1.496412] pps pps0: new PPS source ptp0
[    1.500747] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
[    1.516723] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[    1.528187] platform 31000000.usb: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector
[    1.544181] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.549764] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    1.557640] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
[    1.563645] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008000000010
[    1.573100] xhci-hcd xhci-hcd.0.auto: irq 255, io mem 0x31100000
[    1.580084] hub 1-0:1.0: USB hub found
[    1.583888] hub 1-0:1.0: 1 port detected
[    1.589913] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1200000 KHz, changing to: 1250000 KHz
[    1.603194] mmc0: CQHCI version 5.10
[    1.610846] pca953x 1-0022: supply vcc not found, using dummy regulator
[    1.617633] pca953x 1-0022: using AI
[    1.643343] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[    1.652591] debugfs: Directory 'pd:186' with parent 'pm_genpd' already present!
[    1.654457] mmc1: CQHCI version 5.10
[    1.661056] clk: Disabling unused clocks
[    1.664546] mmc2: CQHCI version 5.10
[    1.670893] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=81, clk=20, ret=-19
[    1.686569] ALSA device list:
[    1.689638]   No soundcards found.
[    1.705388] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[    1.710913] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
[    1.720714] Waiting for root device PARTUUID=076c4a2a-02...
[    1.725489] sdhci-am654 fa20000.mmc: card claims to support voltages below defined range
[    1.738316] mmc0: Command Queue Engine enabled
[    1.742809] mmc0: new HS200 MMC card at address 0001
[    1.746561] mmc2: new high speed SDIO card at address 0001
[    1.748698] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[    1.762148]  mmcblk0: p1
[    1.765451] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB
[    1.768557] mmc1: new ultra high speed SDR104 SDXC card at address aaaa
[    1.771743] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB
[    1.777783] mmcblk1: mmc1:aaaa SB64G 59.5 GiB
[    1.783096] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (239:0)
[    1.791564]  mmcblk1: p1 p2
[    1.995244] EXT4-fs (mmcblk1p2): mounted filesystem 5385bda0-7bd8-4ade-9453-e9d3a8dcbc87 r/w with ordered data mode. Quota mode: none.
[    2.007579] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    2.016491] devtmpfs: mounted
[    2.021341] Freeing unused kernel memory: 2432K
[    2.025981] Run /sbin/init as init process
[    2.238193] systemd[1]: System time before build time, advancing clock.
[    2.290739] NET: Registered PF_INET6 protocol family
[    2.297156] Segment Routing with IPv6
[    2.300898] In-situ OAM (IOAM) with IPv6
[    2.343203] systemd[1]: systemd 255.4^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPT)
[    2.375096] systemd[1]: Detected architecture arm64.
Welcome to Arago 2023.10!
[    2.407407] systemd[1]: Hostname set to <am62xx-evm>.
[    2.667759] systemd[1]: Configuration file /usr/lib/systemd/system/ti-apps-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    2.705568] systemd[1]: Configuration file /usr/lib/systemd/system/seva-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    2.789722] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the settin.
[    2.906710] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting.
[    2.992376] systemd[1]: Queued start job for default target Graphical Interface.
[    3.033811] systemd[1]: Created slice Slice /system/getty.
[  OK  ] Created slice Slice /system/getty.
[    3.057907] systemd[1]: Created slice Slice /system/modprobe.
[  OK  ] Created slice Slice /system/modprobe.
[    3.081791] systemd[1]: Created slice Slice /system/serial-getty.
[  OK  ] Created slice Slice /system/serial-getty.
[    3.104859] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    3.127417] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[    3.151237] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[    3.175014] systemd[1]: Expecting device /dev/ttyS2...
[    3.191088] systemd[1]: Reached target Path Units.
[  OK  ] Reached target Path Units.
[    3.206946] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    3.226922] systemd[1]: Reached target Slice Units.
[  OK  ] Reached target Slice Units.
[    3.242960] systemd[1]: Reached target Swaps.
[  OK  ] Reached target Swaps.
[    3.300189] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    3.327201] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    3.356738] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[    3.379565] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    3.404405] systemd[1]: Listening on Journal Audit Socket.
[  OK  ] Listening on Journal Audit Socket.
[    3.427835] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    3.451800] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    3.471982] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    3.500316] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    3.523765] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    3.547800] systemd[1]: Listening on User Database Manager Socket.
[  OK  ] Listening on User Database Manager Socket.
[    3.611337] systemd[1]: Mounting Huge Pages File System...
[    3.632515] systemd[1]: Mounting POSIX Message Queue File System...
[    3.661225] systemd[1]: Mounting Kernel Debug File System...
[    3.687652] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[    3.709267] systemd[1]: Mounting Temporary Directory /tmp...
[    3.738974] systemd[1]: Starting Create List of Static Device Nodes...
[    3.769705] systemd[1]: Starting Load Kernel Module configfs...
[    3.826264] systemd[1]: Starting Load Kernel Module drm...
[    3.857783] systemd[1]: Starting Load Kernel Module fuse...
[    3.897115] systemd[1]: Starting Start psplash boot splash screen...
[    3.912207] fuse: init (API version 7.39)
[    3.929011] systemd[1]: Starting RPC Bind...
[    3.947754] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[    3.960209] systemd[1]: Starting Journal Service...
[    3.991710] systemd[1]: Starting Load Kernel Modules...
[    4.020125] systemd[1]: Starting Generate network units from Kernel command line...
[    4.061161] systemd[1]: Starting Remount Root and Kernel File Systems...
[    4.076928] cryptodev: loading out-of-tree module taints kernel.
[    4.080340] systemd-journald[129]: Collecting audit messages is enabled.
[    4.098540] cryptodev: driver 1.13 loaded.
[    4.107642] systemd[1]: Starting Coldplug All udev Devices...
[    4.135435] systemd[1]: Started Start psplash boot splash screen.
[  OK  ] Started Start psplash boot splash screen.
[    4.166336] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    4.180240] EXT4-fs (mmcblk1p2): re-mounted 5385bda0-7bd8-4ade-9453-e9d3a8dcbc87 r/w. Quota mode: none.
[    4.193972] systemd[1]: Mounted Huge Pages File System.
[  OK  ] Mounted Huge Pages File System.
[    4.216136] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted Temporary Directory /tmp.
[  OK  ] Finished Create List of Static Device Nodes.
[  OK  ] Finished Load Kernel Module configfs.
[  OK  ] Finished Load Kernel Module drm.
[  OK  ] Finished Load Kernel Module fuse.
[  OK  ] Finished Load Kernel Modules.
[  OK  ] Finished Generate network units from Kernel command line.
[  OK  ] Finished Remount Root and Kernel File Systems.
         Mounting FUSE Control File System...
         Mounting Kernel Configuration File System...
[  OK  ] Started Start psplash-systemd progress communication helper.
         Starting Flush Journal to Persistent Storage...
         Starting Apply Kernel Variables...
         Starting Create Static Device Nodes in /dev gracefully...
[  OK  ] Mounted FUSE Control File System.
[    4.634535] systemd-journald[129]: Received client request to flush runtime journal.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Finished Flush Journal to Persistent Storage.
[  OK  ] Finished Apply Kernel Variables.
[  OK  ] Finished Create Static Device Nodes in /dev gracefully.
         Starting Create Static Device Nodes in /dev...
[  OK  ] Finished Create Static Device Nodes in /dev.
[  OK  ] Reached target Preparation for Local File Systems.
         Mounting /var/volatile...
[    4.940264] audit: type=1334 audit(1709054766.700:2): prog-id=6 op=LOAD
[    4.947157] audit: type=1334 audit(1709054766.708:3): prog-id=7 op=LOAD
         Starting Rule-based Manager for Device Events and Files...
[  OK  ] Finished Coldplug All udev Devices.
[  OK  ] Mounted /var/volatile.
         Starting Load/Save OS Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Finished Load/Save OS Random Seed.
[  OK  ] Finished Create Volatile Files and Directories.
[    5.206653] audit: type=1334 audit(1709054766.964:4): prog-id=8 op=LOAD
         Starting Network Name Resolution...
[    5.256566] audit: type=1334 audit(1709054767.012:5): prog-id=9 op=LOAD
         Starting Network Time Synchronization...
         Starting Record System Boot/Shutdown in UTMP...
[  OK  ] Started Rule-based Manager for Device Events and Files.
[    5.351996] audit: type=1334 audit(1709054767.112:6): prog-id=10 op=LOAD
[    5.359030] audit: type=1334 audit(1709054767.120:7): prog-id=11 op=LOAD
[    5.366132] audit: type=1334 audit(1709054767.124:8): prog-id=12 op=LOAD
         Starting User Database Manager...
[  OK  ] Finished Record System Boot/Shutdown in UTMP.
[  OK  ] Started User Database Manager.
[  OK  ] Found device /dev/ttyS2.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Time Set.
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Host and Network Name Lookups.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timer Units.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
         Starting Docker Socket for the API...
[  OK  ] Listening on dropbear.socket.
[  OK  ] Listening on PC/SC Smart Card Daemon Activation Socket.
         Starting Weston socket...
[    6.619668] audit: type=1334 audit(1733832313.827:9): prog-id=13 op=LOAD
         Starting D-Bus System Message Bus...
         Starting Reboot and dump vmcore via kexec...
[  OK  ] Listening on Docker Socket for the API.
[  OK  ] Listening on Weston socket.
[  OK  ] Finished Reboot and dump vmcore via kexec.
[  OK  ] Started D-Bus System Message Bus.
[    6.855159] dbus-broker-lau[434]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[  OK  ] Reached target Socket Units.
[  OK  ] Reached target Basic System.
[  OK  ] Started Job spooling tools.
[    7.001665] at24 0-0051: supply vcc not found, using dummy regulator
         Starting Avahi mDNS/DNS-SD Stack...
[    7.044934] at24 0-0051: 65536 byte 24c512 EEPROM, writable, 1 bytes/write
[  OK  ] Started Periodic Command Scheduler.
[    7.058522] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[    7.067150] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[    7.080348] tps6598x 0-003f: Unable to find the interrupt, switching to polling
         Starting Print notice about GPLv3 packages[    7.090122] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[    7.102846] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[    7.105455] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[    7.105488] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[    7.120281] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[    7.145909] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[    7.170400] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@9cb00000
         Starting IPv6 Packet Filtering Framework...
[    7.197140] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
         Starting IPv4 Packet Filtering Framework...
[  OK  ] Started irqbalance daemon.
         Starting Telephony service...
[    7.266906] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
         Starting PulseAudio Sound System...
         Starting Expand the rootfs partiti�…to full size of the boot device....
[  OK  ] Started Seva Launcher Service.
[  OK  ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
[    7.361183] audit: type=1334 audit(1733832314.567:10): prog-id=14 op=LOAD
[    7.371149] audit: type=1334 audit(1733832314.579:11): prog-id=15 op=LOAD
[    7.378736] audit: type=1334 audit(1733832314.583:12): prog-id=16 op=LOAD
[    7.380027] remoteproc remoteproc0: 5000000.m4fss is available
         Starting User Login Management...
[    7.427012] remoteproc remoteproc0: powering up 5000000.m4fss
[    7.437895] remoteproc remoteproc0: Booting fw image am62-mcu-m4f0_0-fw, size 55016
         Starting Telnet Server...
[    7.475731] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[    7.492513] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[    7.514354] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
[    7.520175] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:13 UTC (13)
[    7.529905] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node m4f-dma-memory@9cb00000
[    7.533769] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[    7.547636] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[    7.568981] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[    7.577562] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[    7.581350] systemd-journald[129]: Time jumped backwards, rotating.
[    7.608711] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[    7.619034] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[    7.624020] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[    7.631318] platform 78000000.r5f: configured R5F for IPC-only mode
[    7.647675] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9da00000
[    7.663918] virtio_rpmsg_bus virtio0: rpmsg host is online
[    7.665113] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[    7.677610] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[    7.678923] rproc-virtio rproc-virtio.1.auto: registered virtio0 (type 7)
[    7.686425] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[    7.692402] remoteproc remoteproc0: remote processor 5000000.m4fss is now up
[    7.699087] remoteproc remoteproc1: 78000000.r5f is available
[    7.699205] remoteproc remoteproc1: attaching to 78000000.r5f
[    7.701465] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[  OK  ] Started ti-apps-launcher service.
[    7.738610] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[    7.747508] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[    7.752935] platform 78000000.r5f: R5F core initialized in IPC-only mode
[    7.765954] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node r5f-dma-memory@9da00000
[    7.770605] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[    7.781698] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
[    7.783566] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[    7.791356] virtio_rpmsg_bus virtio1: rpmsg host is online
[  OK  ] Finished IPv6 Packet Filtering Fram[    7.808053] rproc-virtio rproc-virtio.3.auto: registered virtio1 (type 7)
ework.
[    7.818543] remoteproc remoteproc1: remote processor 78000000.r5f is now attached
[    7.824471] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
[  OK  ] Finished IPv4 Packet Filtering Framework.
[  OK  ] Finished Telnet Server.
[    7.890469] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[    7.904025] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[    7.931374] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[    7.942855] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[  OK  ] Started Telephony service.
[  OK  ] Reached target Preparation for Network.
[  OK  ] Reached target Hardware [    8.001196] audit: type=1334 audit(13.976:13): prog-id=17 op=LOAD
activated USB gadget.
         Starting Network Configuration...
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[    8.097742] sii902x 1-003b: supply iovcc not found, using dummy regulator
[    8.107124] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
[    8.124057] i2c i2c-1: Added multiplexed i2c bus 3
[    8.132640] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[    8.146274] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[    8.157726] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
[    8.170342] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
[    8.178692] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
[    8.201886] Bluetooth: Core ver 2.22
[    8.205769] NET: Registered PF_BLUETOOTH protocol family
[    8.211280] Bluetooth: HCI device and connection manager initialized
[    8.217758] Bluetooth: HCI socket layer initialized
[    8.222774] Bluetooth: L2CAP socket layer initialized
[    8.227958] Bluetooth: SCO socket layer initialized
[  OK  ] Finished Expand the rootfs partition to full size of the boot device..
[    8.310111] PVR_K:  189: Device: fd00000.gpu
[    8.323043] PVR_K:  189: Read BVNC 33.15.11.3 from HW device registers
[    8.330497] PVR_K:  189: RGX Device registered with BVNC 33.15.11.3
[    8.343710] [drm] Initialized pvr 24.1.6554834 20170530 for fd00000.gpu on minor 1
[  OK  ] Started User Login Management.
[    8.431647] cc33xx_sdio mmc2:0001:2: Using GPIO as IRQ
[    8.527203] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    8.565608] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    8.572713] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[  OK  ] Started PulseAudio Sound System.
[    8.729064] remoteproc remoteproc2: 30074000.pru is available
[    8.736534] remoteproc remoteproc3: 30078000.pru is available
         Starting Virtual Console Setup...
[  OK  ] Started Network Configuration.
[  OK  ] Reached target Network.
         Starting Enable and configure wl18xx bluetooth stack...
         Starting containerd container runtime...
[  OK  ] Started Netperf Benchmark Server.
[    8.887177] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
         Starting Simple Network Management Protocol (SNMP) Daemon....
         Starting Permit User Sessions...
[    8.917896] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[    8.975371] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL)
[    8.988593] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
[  OK  ] Finished Enable and configure wl18xx bluetooth stack.
[  OK  ] Finished Permit User Sessions.
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
         Starting Weston, a Wayland compositor, as a system service...
[  OK  ] Finished Virtual Console Setup.
[    9.331525] cc33xx_driver cc33xx.5.auto: Direct firmware load for ti-connectivity/cc33xx-nvs.bin failed with error -2
[  OK  ] Created slice Slice /system/systemd-fsck.
         Expecting device /dev/mmcblk0p1...
         Starting Save/Restore Sound Card State...
[  OK  ] Found device /dev/mmcblk0p1.
[  OK  ] Finished Save/Restore Sound Card State.
[  OK  ] Reached target Sound Card.
         Starting File System Check on /dev/mmcblk0p1...
[  OK  ] Created slice User Slice of UID 1000.
         Starting User Runtime Directory /run/user/1000...
[  OK  ] Finished User Runtime Directory /run/user/1000.
         Starting User Manager for UID 1000...
[  OK  ] Finished Synchronize System and HW clocks.
[  OK  ] Finished File System Check on /dev/mmcblk0p1.
         Mounting /run/media/rootfs-mmcblk0p1...
[   10.138738] audit: type=1006 audit(16.112:14): pid=623 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
[   10.151029] audit: type=1300 audit(16.112:14): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffeef6bab8 a2=4 a3=1 items=0 ppid=1 pid=623 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgi)
[   10.177458] audit: type=1327 audit(16.112:14): proctitle="(systemd)"
         Expecting device /dev/mmcblk1p1...
[   10.231060] EXT4-fs (mmcblk0p1): mounted filesystem 356b1c79-78f9-45f7-893a-781d6d3d644d r/w with ordered data mode. Quota mode: none.
[  OK  ] Mounted /run/media/rootfs-mmcblk0p1.
[  OK  ] Found device /dev/mmcblk1p1.
         Starting File System Check on /dev/mmcblk1p1...
[  OK  ] Finished File System Check on /dev/mmcblk1p1.
         Mounting /run/media/boot-mmcblk1p1...
[  OK  ] Started Simple Network Management Protocol (SNMP) Daemon..
[  OK  ] Mounted /run/media/boot-mmcblk1p1.
[  OK  ] Started User Manager for UID 1000.
[  OK  ] Started Session c1 of User weston.
[   11.285651] audit: type=1006 audit(17.260:15): pid=565 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1
[   11.297885] audit: type=1300 audit(17.260:15): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffe4309d38 a2=4 a3=1 items=0 ppid=1 pid=565 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgi)
         Starting Load/Save RF Kill Switch Status...
[  OK  ] Started Load/Save RF Kill Switch Status.
[   11.700575] PVR_K:  565: RGX Firmware image 'rgx.fw.33.15.11.3' loaded
[   11.715040] PVR_K:  565: Shader binary image 'rgx.sh.33.15.11.3' loaded
[  OK  ] Started containerd container runtime.
[FAILED] Failed to start Weston, a Wayland compositor, as a system service.
See 'systemctl status weston.service' for details.
[   12.011698] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[  OK  ] Started Session c2 of User weston   12.147795] kauditd_printk_skb: 1 callbacks suppressed
0m.
[   12.147814] audit: type=1006 audit(18.124:16): pid=698 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=3 res=1
[   12.166928] audit: type=1300 audit(18.124:16): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffdb471af8 a2=4 a3=1 items=0 ppid=1 pid=698 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgi)
[   12.192814] audit: type=1327 audit(18.124:16): proctitle="(weston)"
[  OK  ] Started Session c3 of User weston   12.480358] audit: type=1006 audit(18.456:17): pid=702 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=4 res=1
0m.
[   12.493838] audit: type=1300 audit(18.456:17): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffd5479878 a2=4 a3=1 items=0 ppid=1 pid=702 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgi)
[   12.519732] audit: type=1327 audit(18.456:17): proctitle="(weston)"
[  OK  ] Started Session c4 of User weston   12.796684] audit: type=1006 audit(18.772:18): pid=706 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=5 res=1
0m.
[   12.811189] audit: type=1300 audit(18.772:18): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffdaa14b08 a2=4 a3=1 items=0 ppid=1 pid=706 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgi)
[   12.837392] audit: type=1327 audit(18.772:18): proctitle="(weston)"
[  OK  ] Started Session c5 of User weston.
[   13.163847] audit: type=1006 audit(19.140:19): pid=767 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=6 res=1
NOTICE: This file system contains the following GPL-3.0 packages:
        adwaita-icon-theme-symbolic
        autoconf
        bash-dev
        bash
        bc
        binutils
        cifs-utils
        coreutils-stdbuf
        coreutils
        cpio
        cpp-symlinks
        cpp
        dosfstools
        elfutils
        findutils
        g++-symlinks
        g++
        gawk
        gcc-symlinks
        gcc
        gdb
        gdbserver
        gettext
        glmark2
        gnu-config
        grub-common
        grub-editenv
        grub-efi
        gzip
        hidapi
        kbd-dev
        kbd-keymaps-pine
        less
        libasm1
        libatomic-dev
        libatomic1
        libbfd
        libdebuginfod1
        libdw1
        libelf1
        libgcc-s-dev
        libgcc1
        libgdbm-compat4
        libgdbm-dev
        libgdbm6
        libgettextlib
        libgettextsrc
        libgmp10
        libidn2-0
        libmpc3
        libmpfr6
        libopcodes
        libqt5charts-examples
        libqt5charts-plugins
        libqt5charts-qmlplugins
        libqt5charts5
        libqt5serialport-examples
        libqt5serialport-plugins
        libqt5serialport-qmlplugins
        libqt5serialport5
        libqt5svg-examples
        libqt5svg-plugins
        libqt5svg-qmlplugins
        libqt5svg5
        libqt5virtualkeyboard-plugins
        libqt5virtualkeyboard-qmlplugins
        libqt5virtualkeyboard5
        libreadline-dev
        libreadline8
        libstdc++-dev
        libstdc++6
        libunistring5
        m4
        make
        nettle
        parted
        piglit
        qt3d-plugins
        qt3d-qmlplugins
        qt3d
        qtbase-examples
        qtbase-plugins
        qtbase-qmlplugins
        qtbase
        qtconnectivity-plugins
        qtconnectivity-qmlplugins
        qtconnectivity
        qtdeclarative-plugins
        qtdeclarative-qmlplugins
        qtdeclarative-tools
        qtdeclarative
        qtgraphicaleffects-qmlplugins
        qtlocation-examples
        qtlocation-plugins
        qtlocation-qmlplugins
        qtlocation
        qtmultimedia-examples
        qtmultimedia-plugins
        qtmultimedia-qmlplugins
        qtmultimedia
        qtquick3d-plugins
        qtquick3d-qmlplugins
        qtquick3d
        qtquics-qmlplugins.control
        qtquics2-plugins.control
        qtquics2-qmlplugins.control
        qtquics2.control
        qtscript-examples
        qtscript-plugins
        qtscript-qmlplugins
        qtscript
        qtwayland-examples
        qtwayland-plugins
        qtwayland-qmlplugins
        qtwayland
        tar
        which
If you do not wish to distribute GPL-3.0 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
[  OK  ] Finished Print notice about GPLv3 packages.
[  OK  ] Reached target Multi-User System.
[  OK  ] Reached target Graphical Interface.
         Starting Record Runlevel Change in UTMP...
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project am62xx-evm ttyS2
Arago 2023.10 am62xx-evm ttyS2
am62xx-evm login: root
[   17.581732] kauditd_printk_skb: 6 callbacks suppressed
[   17.581756] audit: type=1006 audit(23.556:24): pid=1087 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=7 res=1
[   17.599963] audit: type=1300 audit(23.556:24): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffd87f7038 a2=1 a3=1 items=0 ppid=1 pid=1087 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=)
[   17.626890] audit: type=1327 audit(23.556:24): proctitle="(systemd)"
[   17.634011] audit: type=1334 audit(23.592:25): prog-id=21 op=LOAD
[   17.641295] audit: type=1300 audit(23.592:25): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffd32abc58 a2=90 a3=0 items=0 ppid=1 pid=1087 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgi)
[   17.667251] audit: type=1327 audit(23.592:25): proctitle="(systemd)"
[   17.674544] audit: type=1334 audit(23.600:26): prog-id=21 op=UNLOAD
[   17.681764] audit: type=1300 audit(23.600:26): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffff892c8c60 items=0 ppid=1 pid=1087 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=)
[   17.706954] audit: type=1327 audit(23.600:26): proctitle="(systemd)"
[   17.713497] audit: type=1334 audit(23.600:27): prog-id=22 op=LOAD
root@am62xx-evm:~# ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet6 fe80::1e63:49ff:fe22:4ed8  prefixlen 64  scopeid 0x20<link>
        ether 1c:63:49:22:4e:d8  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 17  bytes 2720 (2.6 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
eth1: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 66:d7:27:b4:88:48  txqueuelen 1000  (Ethernet)
        TX packets 0  bytes 0 (0.0 B)
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 92  bytes 7634 (7.4 KiB)
        TX packets 92  bytes 7634 (7.4 KiB)
wlan0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether a4:34:f1:b2:e8:d0  txqueuelen 1000  (Ethernet)
root@am62xx-evm:~# cat /sys/kernel/debug/ieee80211/phy0/cc33xx/ble_enable
0
root@am62xx-evm:~# echo 1 > /sys/kernel/debug/ieee80211/phy0/cc33xx/ble_enable
1
root@am62xx-evm:~# hciconfig -a
root@am62xx-evm:~#
CTRL-A Z for help | 115200 8N1 | NOR | Minicom 2.7.1 | VT102 | Offline | ttyUSB0
system configs
From af3f6f374d3b02d222685e42dc14eafc7d4907fd Mon Sep 17 00:00:00 2001
Date: Tue, 10 Dec 2024 02:58:53 +0000
Subject: [PATCH] new ti system config
Signed-off-by: Mike <mike_yang@pegatroncorp.com>
 arch/arm64/configs/defconfig | 27 +++++++++++++++++++++++++--
 1 file changed, 25 insertions(+), 2 deletions(-)
diff --git a/arch/arm64/configs/defconfig b/arch/arm64/configs/defconfig
index f8047c965270..252cf2eac572 100644
--- a/arch/arm64/configs/defconfig
+++ b/arch/arm64/configs/defconfig
@@ -451,10 +451,12 @@ CONFIG_MWIFIEX_SDIO=m
 CONFIG_MWIFIEX_PCIE=m
 CONFIG_MT7921E=m
 CONFIG_RSI_91X=m
-CONFIG_WL18XX=m
+CONFIG_WL18XX=n
 CONFIG_CC33XX=m
 CONFIG_CC33XX_SDIO=m
-CONFIG_WLCORE_SDIO=m
+CONFIG_CC33XX_SPI=m
+CONFIG_WLCORE=n
+CONFIG_WLCORE_SDIO=n
 CONFIG_WWAN=m
 CONFIG_MHI_WWAN_CTRL=m
 CONFIG_MHI_WWAN_MBIM=m
@@ -1646,3 +1648,24 @@ CONFIG_CORESIGHT_STM=m
 CONFIG_CORESIGHT_CPU_DEBUG=m
 CONFIG_CORESIGHT_CTI=m
 CONFIG_MEMTEST=y
+CONFIG_BT_TI_UART=m
+CONFIG_TUN=m
+CONFIG_USB_ACM=m
+CONFIG_6LOWPAN=m
+CONFIG_6LOWPAN_GHC_EXT_HDR_HOP=m
+CONFIG_6LOWPAN_GHC_UDP=m
+CONFIG_6LOWPAN_GHC_ICMPV6=m
+CONFIG_6LOWPAN_GHC_EXT_HDR_DEST=m
+CONFIG_6LOWPAN_GHC_EXT_HDR_FRAG=m
+CONFIG_6LOWPAN_GHC_EXT_HDR_ROUTE=m
+CONFIG_IEEE802154=m
+CONFIG_IEEE802154_6LOWPAN=m
+CONFIG_MAC802154=m
+CONFIG_IP_MROUTE=y
+CONFIG_IP_MROUTE_MULTIPLE_TABLES=y
+CONFIG_IP_MULTICAST=y
+CONFIG_IPV6_MROUTE=y
+CONFIG_IPV6_MROUTE_MULTIPLE_TABLES=y
+CONFIG_BT_DEBUGFS=y
+CONFIG_BT_TI=n
+CONFIG_BT_TI_SDIO=n
\ No newline at end of file
2.34.1
Device tree
From c1713dd141a819cc7c04e9891699222b26921d5c Mon Sep 17 00:00:00 2001
Date: Tue, 10 Dec 2024 03:21:04 +0000
Subject: [PATCH] new ti dts setting
 arch/arm64/boot/dts/ti/k3-am625-sk.dts        | 94 +++++++++++++++++++
 .../arm64/boot/dts/ti/k3-am62x-sk-common.dtsi | 14 +--
 2 files changed, 101 insertions(+), 7 deletions(-)
diff --git a/arch/arm64/boot/dts/ti/k3-am625-sk.dts b/arch/arm64/boot/dts/ti/k3-am625-sk.dts
index f353db3664ac..b8580fa4b2f8 100644
--- a/arch/arm64/boot/dts/ti/k3-am625-sk.dts
+++ b/arch/arm64/boot/dts/ti/k3-am625-sk.dts
@@ -103,9 +103,66 @@ vcc_1v8: regulator-5 {
 		regulator-always-on;
 		regulator-boot-on;
+	wlan_lten: regulator-6 {
+		compatible = "regulator-fixed";
+		regulator-name = "wlan_lten";
+		regulator-min-microvolt = <3300000>;
+		regulator-max-microvolt = <3300000>;
+		vin-supply = <&vdd_mmc1>;
+		gpios = <&exp1 11 GPIO_ACTIVE_HIGH>;
+		enable-active-high;
+	wlan_en: regulator-7 {
+		regulator-name = "wlan_en";
+		regulator-min-microvolt = <1800000>;
+		regulator-max-microvolt = <1800000>;
+		vin-supply = <&wlan_lten>;
+		gpios = <&main_gpio0 71 GPIO_ACTIVE_HIGH>;
+		pinctrl-names = "default";
+		pinctrl-0 = <&wlan_en_pins_default>;
+	uart_buf_en: regulator-9 {
+		regulator-name = "uart_buf_en";
+		gpios = <&exp1 10 GPIO_ACTIVE_LOW>;
+		regulator-always-on;
 &main_pmx0 {
+	wlan_en_pins_default: wlan-en-pins-default {
+			pinctrl-single,pins = <
+					AM62X_IOPAD(0x124, PIN_OUTPUT, 7) /* (A23) MMC2_SDCD.GPIO0_71 */
+	main_mmc2_pins_default: main-mmc2-pins-default {
+			AM62X_IOPAD(0x120, PIN_INPUT, 0) /* (C24) MMC2_CMD */
+			AM62X_IOPAD(0x118, PIN_INPUT, 0) /* (D25) MMC2_CLK */
+			AM62X_IOPAD(0x114, PIN_INPUT, 0) /* (B24) MMC2_DAT0 */
+			AM62X_IOPAD(0x110, PIN_INPUT, 0) /* (C25) MMC2_DAT1 */
+			AM62X_IOPAD(0x10c, PIN_INPUT, 0) /* (E23) MMC2_DAT2 */
+			AM62X_IOPAD(0x108, PIN_INPUT, 0) /* (D24) MMC2_DAT3 */
+			AM62X_IOPAD(0x11c, PIN_INPUT, 0) /* (#N/A) MMC2_CLKB */
+	main_wlirq_pins_default: main-wlirq-pins-default {
+			AM62X_IOPAD(0x128, PIN_INPUT, 7) /* (B23) MMC2_SDWP.GPIO0_72 */
 	main_rgmii2_pins_default: main-rgmii2-default-pins {
 		bootph-all;
@@ -200,6 +257,43 @@ &sdhci1 {
 	vqmmc-supply = <&vdd_sd_dv>;
+&sdhci2 {
+	status = "okay";
+    bootph-all;
+	vmmc-supply = <&wlan_en>;
+	pinctrl-0 = <&main_mmc2_pins_default>;
+	bus-width = <4>;
+	non-removable;
+	ti,fails-without-test-cd;
+	cap-power-off-card;
+	keep-power-in-suspend;
+	ti,driver-strength-ohm = <50>;
+	#address-cells = <1>;
+	#size-cells = <0>;
+	wlcore: wlcore@2 {
+		compatible = "ti,cc3301";
+		reg = <2>;
+		pinctrl-0 = <&main_wlirq_pins_default>;
+		interrupt-parent = <&main_gpio0>;
+		interrupts = <72 IRQ_TYPE_EDGE_FALLING>;
+&main_uart1 {
+	status = "okay";
+	pinctrl-0 = <&main_uart1_pins_default>;
+	bluetooth {
+		compatible = "ti,cc33xx-bt";
+		cc33xx-supply = <&wlan_en>;
+		max-speed = <115200>;
 &cpsw3g {
 	pinctrl-0 = <&main_rgmii1_pins_default
diff --git a/arch/arm64/boot/dts/ti/k3-am62x-sk-common.dtsi b/arch/arm64/boot/dts/ti/k3-am62x-sk-common.dtsi
index 57fbcd6892fc..58672f876025 100644
--- a/arch/arm64/boot/dts/ti/k3-am62x-sk-common.dtsi
+++ b/arch/arm64/boot/dts/ti/k3-am62x-sk-common.dtsi
@@ -372,13 +372,13 @@ &main_uart0 {
 	interrupt-names = "irq", "wakeup";
-&main_uart1 {
-	/* Main UART1 is used by TIFS firmware */
-	bootph-pre-ram;
-	status = "reserved";
-	pinctrl-names = "default";
-	pinctrl-0 = <&main_uart1_pins_default>;
+// &main_uart1 {
+// 	/* Main UART1 is used by TIFS firmware */
+// 	bootph-pre-ram;
+// 	status = "reserved";
+// 	pinctrl-names = "default";
+// 	pinctrl-0 = <&main_uart1_pins_default>;
 &main_i2c0 {
 	status = "okay";
2.34.1
Wi-Fi driver patch
From 455db02028f162f08ef66c4b3eca99657e31fdc0 Mon Sep 17 00:00:00 2001
Date: Sun, 27 Oct 2024 00:01:44 -0500
Subject: [PATCH] drivers: cc33xx: update to 1.0.0.7
 drivers/net/wireless/ti/cc33xx/acx.c      |  93 ----
 drivers/net/wireless/ti/cc33xx/acx.h      |  20 -
 drivers/net/wireless/ti/cc33xx/boot.c     |   8 +
 drivers/net/wireless/ti/cc33xx/cc33xx_i.h |   3 +-
 drivers/net/wireless/ti/cc33xx/cmd.c      | 100 +++-
 drivers/net/wireless/ti/cc33xx/cmd.h      |  10 +-
 drivers/net/wireless/ti/cc33xx/conf.h     | 641 ++--------------------
 drivers/net/wireless/ti/cc33xx/io.c       |   5 -
 drivers/net/wireless/ti/cc33xx/main.c     |  55 +-
 drivers/net/wireless/ti/cc33xx/ps.c       |   2 -
 drivers/net/wireless/ti/cc33xx/rx.c       |   3 +
 drivers/net/wireless/ti/cc33xx/rx.h       |   6 +-
 12 files changed, 184 insertions(+), 762 deletions(-)
diff --git a/drivers/net/wireless/ti/cc33xx/acx.c b/drivers/net/wireless/ti/cc33xx/acx.c
index 34a6f9cee245..1e628a23d08e 100644
--- a/drivers/net/wireless/ti/cc33xx/acx.c
+++ b/drivers/net/wireless/ti/cc33xx/acx.c
@@ -5,30 +5,6 @@
 #include "acx.h"
-int cc33xx_acx_clear_statistics(struct cc33xx *cc)
-	struct acx_header *acx;
-	int ret = 0;
-	cc33xx_debug(DEBUG_ACX, "acx clear statistics");
-	acx = kzalloc(sizeof(*acx), GFP_KERNEL);
-	if (!acx) {
-		ret = -ENOMEM;
-		goto out;
-	ret = cc33xx_cmd_configure(cc, ACX_CLEAR_STATISTICS, acx, sizeof(*acx));
-	if (ret < 0) {
-		cc33xx_warning("failed to clear firmware statistics: %d", ret);
-		goto out;
-out:
-	kfree(acx);
-	return ret;
 int cc33xx_acx_wake_up_conditions(struct cc33xx *cc, struct cc33xx_vif *wlvif,
 				  u8 wake_up_event, u8 listen_interval)
@@ -431,23 +407,6 @@ int cc33xx_acx_cts_protect(struct cc33xx *cc, struct cc33xx_vif *wlvif,
 	return ret;
-int cc33xx_acx_statistics(struct cc33xx *cc, void *stats)
-	int ret;
-	cc33xx_debug(DEBUG_ACX, "acx statistics");
-	ret = cc33xx_cmd_interrogate(cc, ACX_STATISTICS, stats,
-				     sizeof(struct acx_header),
-				     sizeof(struct cc33xx_acx_statistics));
-	if (ret < 0) {
-		cc33xx_warning("acx statistics failed: %d", ret);
-		return -ENOMEM;
-	return 0;
 int cc33xx_update_ap_rates(struct cc33xx *cc, u8 role_id,
 			   u32 basic_rates_set, u32 supported_rates)
@@ -666,58 +625,6 @@ int cc33xx_acx_set_ba_receiver_session(struct cc33xx *cc, u8 tid_index, u16 ssn,
 	return ret;
-int cc33xx_acx_tsf_info(struct cc33xx *cc,
-			struct cc33xx_vif *wlvif, u64 *mactime)
-	struct cc33xx_acx_fw_tsf_information *tsf_info;
-	int ret = 0;
-	tsf_info = kzalloc(sizeof(*tsf_info), GFP_KERNEL);
-	if (!tsf_info) {
-		ret = -ENOMEM;
-		goto out;
-	tsf_info->role_id = wlvif->role_id;
-	*mactime = le32_to_cpu(tsf_info->current_tsf_low) |
-		((u64)le32_to_cpu(tsf_info->current_tsf_high) << 32);
-out:
-	kfree(tsf_info);
-	return ret;
-int cc33xx_acx_config_ps(struct cc33xx *cc, struct cc33xx_vif *wlvif)
-	struct cc33xx_acx_config_ps *config_ps;
-	int ret;
-	cc33xx_debug(DEBUG_ACX, "acx config ps");
-	config_ps = kzalloc(sizeof(*config_ps), GFP_KERNEL);
-	if (!config_ps) {
-		ret = -ENOMEM;
-		goto out;
-	config_ps->exit_retries = cc->conf.host_conf.conn.psm_exit_retries;
-	config_ps->enter_retries = cc->conf.host_conf.conn.psm_entry_retries;
-	config_ps->null_data_rate = cpu_to_le32(wlvif->basic_rate);
-	ret = cc33xx_cmd_configure(cc, ACX_CONFIG_PS, config_ps,
-				   sizeof(*config_ps));
-	if (ret < 0) {
-		cc33xx_warning("acx config ps failed: %d", ret);
-		goto out;
-out:
-	kfree(config_ps);
-	return ret;
 int cc33xx_acx_average_rssi(struct cc33xx *cc,
 			    struct cc33xx_vif *wlvif, s8 *avg_rssi)
diff --git a/drivers/net/wireless/ti/cc33xx/acx.h b/drivers/net/wireless/ti/cc33xx/acx.h
index f250758c3da5..b3cb675bed1f 100644
--- a/drivers/net/wireless/ti/cc33xx/acx.h
+++ b/drivers/net/wireless/ti/cc33xx/acx.h
@@ -398,15 +398,6 @@ struct cc33xx_acx_fw_tsf_information {
 	u8 padding2[3];
 } __packed;
-struct cc33xx_acx_config_ps {
-	struct acx_header header;
-	u8 exit_retries;
-	u8 enter_retries;
-	u8 padding[2];
-	__le32 null_data_rate;
-} __packed;
 #define ACX_RATE_MGMT_ALL_PARAMS 0xff
 struct acx_default_rx_filter {
@@ -527,12 +518,6 @@ enum interrogate_opt {
 	MAX_IE = 0xFFFF /*force enumeration to 16bits*/
-enum {
-	ACX_STATISTICS = LAST_CFG_VALUE,
-	ACX_CONFIG_PS,
-	ACX_CLEAR_STATISTICS		 = 0x0054,
 struct cc33xx_acx_error_stats {
 	__le32 error_frame_non_ctrl;
 	__le32 error_frame_ctrl;
@@ -799,7 +784,6 @@ int cc33xx_acx_set_preamble(struct cc33xx *cc, struct cc33xx_vif *wlvif,
 			    enum acx_preamble_type preamble);
 			   enum acx_ctsprotect_type ctsprotect);
-int cc33xx_acx_statistics(struct cc33xx *cc, void *stats);
 int cc33xx_tx_param_cfg(struct cc33xx *cc, struct cc33xx_vif *wlvif, u8 ac,
 			u8 cw_min, u16 cw_max, u8 aifsn, u16 txop, bool acm,
 			u8 ps_scheme, u8 is_mu_edca, u8 mu_edca_aifs,
@@ -813,9 +797,6 @@ int cc33xx_acx_set_ht_information(struct cc33xx *cc, struct cc33xx_vif *wlvif,
 				  u16 he_oper_nss_set);
 				       bool enable, u8 peer_hlid, u8 win_size);
-			struct cc33xx_vif *wlvif, u64 *mactime);
-int cc33xx_acx_config_ps(struct cc33xx *cc, struct cc33xx_vif *wlvif);
 int cc33xx_acx_get_tx_rate(struct cc33xx *cc, struct cc33xx_vif *wlvif,
 			   struct station_info *sinfo);
@@ -824,7 +805,6 @@ int cc33xx_acx_default_rx_filter_enable(struct cc33xx *cc, bool enable,
 					enum rx_filter_action action);
 int cc33xx_acx_set_rx_filter(struct cc33xx *cc, u8 index, bool enable,
 			     struct cc33xx_rx_filter *filter);
-int cc33xx_acx_clear_statistics(struct cc33xx *cc);
 int cc33xx_acx_set_peer_cap(struct cc33xx *cc,
 			    struct ieee80211_sta_ht_cap *ht_cap,
 			    struct ieee80211_sta_he_cap *he_cap,
diff --git a/drivers/net/wireless/ti/cc33xx/boot.c b/drivers/net/wireless/ti/cc33xx/boot.c
index f734659f989c..f53b4ea9e7d0 100644
--- a/drivers/net/wireless/ti/cc33xx/boot.c
+++ b/drivers/net/wireless/ti/cc33xx/boot.c
@@ -130,6 +130,14 @@ static int wait_for_boot_irq(struct cc33xx *cc, u32 boot_irq_mask,
 	fw_download = cc->fw_download;
+	 * Hosts can miss boot-done signal after powerup or internal reset.
+	 * Work around this by explicitly triggering IRQ handler which will
+	 * check current device status after a safe delay.
+	msleep(10);
+	cc33xx_irq(cc);
 	ret = wait_for_completion_interruptible_timeout(&fw_download->wait_on_irq,
 							msecs_to_jiffies(timeout));
diff --git a/drivers/net/wireless/ti/cc33xx/cc33xx_i.h b/drivers/net/wireless/ti/cc33xx/cc33xx_i.h
index 9437f78b364f..be627f20668f 100644
--- a/drivers/net/wireless/ti/cc33xx/cc33xx_i.h
+++ b/drivers/net/wireless/ti/cc33xx/cc33xx_i.h
@@ -136,7 +136,6 @@ enum cc33xx_vif_flags {
 	WLVIF_FLAG_STA_AUTHORIZED,
 	WLVIF_FLAG_IBSS_JOINED,
 	WLVIF_FLAG_AP_STARTED,
-	WLVIF_FLAG_IN_PS,
 	WLVIF_FLAG_STA_STATE_SENT,
 	WLVIF_FLAG_PSPOLL_FAILURE,
 	WLVIF_FLAG_CS_PROGRESS,
@@ -398,6 +397,8 @@ struct cc33xx_vif {
 	u8 persistent[];
+void cc33xx_irq(void *cookie);
 static inline struct cc33xx_vif *cc33xx_vif_to_data(struct ieee80211_vif *vif)
 	WARN_ON(!vif);
diff --git a/drivers/net/wireless/ti/cc33xx/cmd.c b/drivers/net/wireless/ti/cc33xx/cmd.c
index 9654b3fe1810..7b41861bfaca 100644
--- a/drivers/net/wireless/ti/cc33xx/cmd.c
+++ b/drivers/net/wireless/ti/cc33xx/cmd.c
@@ -8,7 +8,7 @@
 #include "io.h"
 #include "tx.h"
-#define CC33XX_REBOOT_TIMEOUT_MSEC		100
+#define CC33XX_REBOOT_TIMEOUT_MSEC		250
 static void init_cmd_header(struct cc33xx_cmd_header *header,
 			    size_t cmd_len, u16 id)
@@ -327,6 +327,87 @@ int cc33xx_set_link(struct cc33xx *cc, struct cc33xx_vif *wlvif, u8 link)
 	return 0;
+static u8 cc33xx_check_is_dfs_channel(struct cc33xx *cc,
+						enum nl80211_band rate_band, u8 channel)
+	struct ieee80211_supported_band *band;
+	u8 is_dfs = 0;
+	if (rate_band != NL80211_BAND_5GHZ) {
+		return is_dfs;
+	band = cc->hw->wiphy->bands[NL80211_BAND_5GHZ];
+	for (int i = 0; i < band->n_channels; i++) {
+		if (band->channels[i].hw_value == channel) {
+			is_dfs = !!(band->channels[i].flags & IEEE80211_CHAN_RADAR);
+			break;
+	return is_dfs;
+static u8 cc33xx_get_sub_channel_type(u8 band, u8 channel, u8 band_width)
+	if (band == NL80211_BAND_5GHZ) {
+		switch (channel) {
+		case 36:
+		case 52:
+		case 100:
+		case 116:
+		case 132:
+		case 149:
+		case 165:
+			return 0;
+		case 40:
+		case 56:
+		case 104:
+		case 120:
+		case 136:
+		case 153:
+		case 169:
+			return 1;
+		case 44:
+		case 60:
+		case 108:
+		case 124:
+		case 140:
+		case 157:
+		case 173:
+			return 2;
+		case 48:
+		case 64:
+		case 112:
+		case 128:
+		case 144:
+		case 161:
+		case 177:
+			return 3;
+		default:
+			return 0xff;
+	if (band == NL80211_BAND_2GHZ) {
+		case 9:
+		case 5:
+			return 0;
+		case 1:
+			return 0;
+		case 13:
+			return 1;
+		default:
+			return 0;
+	return 0xff;
 void cc33xx_clear_link(struct cc33xx *cc, struct cc33xx_vif *wlvif, u8 *hlid)
 	unsigned long flags;
@@ -615,6 +696,7 @@ int cc33xx_cmd_role_start_sta(struct cc33xx *cc, struct cc33xx_vif *wlvif)
 	cmd->role_id = wlvif->role_id;
 	cmd->role_type = CC33XX_ROLE_STA;
 	cmd->channel = wlvif->channel;
+	cmd->is_dfs_channel = cc33xx_check_is_dfs_channel(cc, wlvif->band, cmd->channel);
 	if (wlvif->band == NL80211_BAND_5GHZ) {
 		cmd->band = CC33XX_BAND_5GHZ;
 		cmd->sta.basic_rate_set = cpu_to_le32(wlvif->basic_rate_set
@@ -635,9 +717,8 @@ int cc33xx_cmd_role_start_sta(struct cc33xx *cc, struct cc33xx_vif *wlvif)
 	if (wlvif->p2p)
 		supported_rates &= ~CONF_TX_CCK_RATES;
-	cmd->sta.local_rates = cpu_to_le32(supported_rates);
-	cmd->channel_type = cc33xx_get_native_channel_type(wlvif->channel_type);
+	cmd->sta.local_rates = cpu_to_le32(supported_rates);
+	cmd->channel_type = cc33xx_get_sub_channel_type(cmd->band, cmd->channel, 0);
 	/* We don't have the correct remote rates in this stage.  The
 	 * rates will be reconfigured later, after association, if the
@@ -747,6 +828,7 @@ int cc33xx_cmd_role_start_ap(struct cc33xx *cc, struct cc33xx_vif *wlvif)
 	cmd->ap.wmm = wlvif->wmm_enabled;
 	supported_rates = CONF_TX_ENABLED_RATES | CONF_TX_MCS_RATES;
 	if (wlvif->p2p)
@@ -1443,12 +1525,12 @@ static int cc33xx_get_reg_conf_ch_idx(enum nl80211_band band, u16 ch)
 		case 52 ... 64:
 			/* channels 52,56..64 are mapped to 29..32 */
 			return 29 + (ch - 52) / 4;
-		case 100 ... 140:
-			/* channels 100,104..140 are mapped to 33..43 */
+		case 100 ... 144:
+			/* channels 100,104..144 are mapped to 33..44 */
 			return 33 + (ch - 100) / 4;
-		case 149 ... 165:
-			/* channels 149,153..165 are mapped to 44..48 */
-			return 44 + (ch - 149) / 4;
+		case 149 ... 169:
+			/* channels 149,153..169 are mapped to 45..50 */
+			return 45 + (ch - 149) / 4;
 		default:
 			break;
diff --git a/drivers/net/wireless/ti/cc33xx/cmd.h b/drivers/net/wireless/ti/cc33xx/cmd.h
index f6e4877cf7b4..e819a92a2122 100644
--- a/drivers/net/wireless/ti/cc33xx/cmd.h
+++ b/drivers/net/wireless/ti/cc33xx/cmd.h
@@ -137,12 +137,12 @@ enum cc33xx_cmd {
 	CMD_DOWNLOAD_INI_PARAMS = 37,
 	CMD_SET_BD_ADDR = 38,
 	CMD_BLE_COMMANDS = 39,
+	CMD_SET_PS_MODE = 40,
 	CMD_LAST_SUPPORTED_COMMAND,
 	/* The following commands are legacy and are not yet supported */
-	CMD_SET_PS_MODE,
 	CMD_DFS_CHANNEL_CONFIG,
 	CMD_CONFIG_FWLOGGER,
 	CMD_START_FWLOGGER,
@@ -258,7 +258,7 @@ struct cc33xx_cmd_role_start {
 	u8 role_type;
 	u8 band;
 	u8 channel;
+	u8 is_dfs_channel;
 	u8 channel_type;
 	union {
@@ -316,7 +316,7 @@ struct cc33xx_cmd_role_start {
 			u8 padding_1[42];
 		} __packed ap;
-	u8 padding;
+	u8 padding[4];
 } __packed;
 struct cc33xx_cmd_complete_role_start {
@@ -640,8 +640,8 @@ struct cmd_channel_switch {
 	u8 channel_type;
 	u8 band;
-	u8 padding[2];
+	u8 padding;
 } __packed;
 struct cmd_set_bd_addr {
diff --git a/drivers/net/wireless/ti/cc33xx/conf.h b/drivers/net/wireless/ti/cc33xx/conf.h
index d3881aadeade..f3f7701f8a1c 100644
--- a/drivers/net/wireless/ti/cc33xx/conf.h
+++ b/drivers/net/wireless/ti/cc33xx/conf.h
@@ -13,10 +13,12 @@ struct cc33xx_conf_header {
 } __packed;
 #define CC33XX_CONF_MAGIC	0x10e100ca
-#define CC33XX_CONF_VERSION	0x01070069
+#define CC33XX_CONF_VERSION	0x010700bc
 #define CC33XX_CONF_MASK	0x0000ffff
 #define CC33X_CONF_SIZE	(sizeof(struct cc33xx_conf_file))
+#define CONF_HW_RXTX_RATE_UNSUPPORTED 0xff
 enum {
 	CONF_HW_BIT_RATE_1MBPS   = BIT(1),
 	CONF_HW_BIT_RATE_2MBPS   = BIT(2),
@@ -82,11 +84,25 @@ enum {
 	CONF_PREAMBLE_TYPE_INVALID	= 0xFF
-#define CONF_HW_RXTX_RATE_UNSUPPORTED 0xff
+enum {
+	CONF_PS_SCHEME_LEGACY = 0,
+	CONF_PS_SCHEME_UPSD_TRIGGER = 1,
+	CONF_PS_SCHEME_LEGACY_PSPOLL = 2,
+	CONF_PS_SCHEME_SAPSD = 3,
-enum conf_rx_queue_type {
-	CONF_RX_QUEUE_TYPE_LOW_PRIORITY,  /* All except the high priority */
-	CONF_RX_QUEUE_TYPE_HIGH_PRIORITY, /* Management and voice packets */
+enum {
+	CONF_TX_AC_BE = 0,
+	CONF_TX_AC_BK = 1,
+	CONF_TX_AC_VI = 2,
+	CONF_TX_AC_VO = 3,
+	CONF_TX_AC_CTS2SELF = 4,
+	CONF_TX_AC_ANY_TID = 0xff
+enum {
+	CONF_BCN_FILT_MODE_DISABLED = 0,
+	CONF_BCN_FILT_MODE_ENABLED = 1
 struct cc33xx_clk_cfg {
@@ -97,204 +113,8 @@ struct cc33xx_clk_cfg {
 	u8 swallow;
-struct conf_rx_settings {
-	/* The maximum amount of time, in TU, before the
-	 * firmware discards the MSDU.
-	 * Range: 0 - 0xFFFFFFFF
-	u32 rx_msdu_life_time;
-	/* Packet detection threshold in the PHY.
-	 * FIXME: details unknown.
-	u32 packet_detection_threshold;
-	/* The longest time the STA will wait to receive traffic from the AP
-	 * after a PS-poll has been transmitted.
-	 * Range: 0 - 200000
-	u16 ps_poll_timeout;
-	 * after a frame has been sent from an UPSD enabled queue.
-	u16 upsd_timeout;
-	/* The number of octets in an MPDU, below which an RTS/CTS
-	 * handshake is not performed.
-	 * Range: 0 - 4096
-	u16 rts_threshold;
-	/* The RX Clear Channel Assessment threshold in the PHY
-	 * (the energy threshold).
-	 * Range: ENABLE_ENERGY_D  == 0x140A
-	 *        DISABLE_ENERGY_D == 0xFFEF
-	u16 rx_cca_threshold;
-	/* Occupied Rx mem-blocks number which requires interrupting the host
-	 * (0 = no buffering, 0xffff = disabled).
-	 * Range: uint16_t
-	u16 irq_blk_threshold;
-	/* Rx packets number which requires interrupting the host
-	 * (0 = no buffering).
-	 * Range: uint16_t
-	u16 irq_pkt_threshold;
-	/* Max time in msec the FW may delay RX-Complete interrupt.
-	 * Range: 1 - 100
-	u16 irq_timeout;
-	/* The RX queue type.
-	 * Range: RX_QUEUE_TYPE_RX_LOW_PRIORITY, RX_QUEUE_TYPE_RX_HIGH_PRIORITY,
-	u8 queue_type;
-} __packed;
-#define CONF_TX_MAX_RATE_CLASSES       10
-#define CONF_TX_RATE_MASK_UNSPECIFIED  0
-#define CONF_TX_RATE_MASK_BASIC        (CONF_HW_BIT_RATE_1MBPS | \
-					CONF_HW_BIT_RATE_2MBPS)
-#define CONF_TX_RATE_RETRY_LIMIT       10
-/* basic rates for p2p operations (probe req/resp, etc.) */
-#define CONF_TX_RATE_MASK_BASIC_P2P    CONF_HW_BIT_RATE_6MBPS
-/* Rates supported for data packets when operating as STA/AP. Note the absence
- * of the 22Mbps rate. There is a FW limitation on 12 rates so we must drop
- * one. The rate dropped is not mandatory under any operating mode.
-#define CONF_TX_ENABLED_RATES       (CONF_HW_BIT_RATE_1MBPS |    \
-	CONF_HW_BIT_RATE_2MBPS | CONF_HW_BIT_RATE_5_5MBPS |      \
-	CONF_HW_BIT_RATE_6MBPS | CONF_HW_BIT_RATE_9MBPS |        \
-	CONF_HW_BIT_RATE_11MBPS | CONF_HW_BIT_RATE_12MBPS |      \
-	CONF_HW_BIT_RATE_18MBPS | CONF_HW_BIT_RATE_24MBPS |      \
-	CONF_HW_BIT_RATE_36MBPS | CONF_HW_BIT_RATE_48MBPS |      \
-	CONF_HW_BIT_RATE_54MBPS)
-#define CONF_TX_CCK_RATES  (CONF_HW_BIT_RATE_1MBPS |		\
-	CONF_HW_BIT_RATE_11MBPS)
-#define CONF_TX_OFDM_RATES (CONF_HW_BIT_RATE_6MBPS |             \
-	CONF_HW_BIT_RATE_12MBPS | CONF_HW_BIT_RATE_24MBPS |      \
-#define CONF_TX_MCS_RATES (CONF_HW_BIT_RATE_MCS_0 |              \
-	CONF_HW_BIT_RATE_MCS_1 | CONF_HW_BIT_RATE_MCS_2 |        \
-	CONF_HW_BIT_RATE_MCS_3 | CONF_HW_BIT_RATE_MCS_4 |        \
-	CONF_HW_BIT_RATE_MCS_5 | CONF_HW_BIT_RATE_MCS_6 |        \
-	CONF_HW_BIT_RATE_MCS_7)
-/* Default rates for management traffic when operating in AP mode. This
- * should be configured according to the basic rate set of the AP
-#define CONF_TX_AP_DEFAULT_MGMT_RATES  (CONF_HW_BIT_RATE_1MBPS | \
-	CONF_HW_BIT_RATE_2MBPS | CONF_HW_BIT_RATE_5_5MBPS)
-/* default rates for working as IBSS (11b and OFDM) */
-#define CONF_TX_IBSS_DEFAULT_RATES  (CONF_HW_BIT_RATE_1MBPS |       \
-		CONF_HW_BIT_RATE_11MBPS | CONF_TX_OFDM_RATES)
-struct conf_tx_rate_class {
-	/* The rates enabled for this rate class.
-	 * Range: CONF_HW_BIT_RATE_* bit mask
-	u32 enabled_rates;
-	/* The dot11 short retry limit used for TX retries.
-	 * Range: uint8_t
-	u8 short_retry_limit;
-	/* The dot11 long retry limit used for TX retries.
-	 * Range: uint8_t
-	u8 long_retry_limit;
-	/* Flags controlling the attributes of TX transmission.
-	 * Range: bit 0: Truncate - when set, FW attempts to send a frame stop
-	 *               when the total valid per-rate attempts have
-	 *               been exhausted; otherwise transmissions
-	 *               will continue at the lowest available rate
-	 *               until the appropriate one of the
-	 *               short_retry_limit, long_retry_limit,
-	 *               dot11_max_transmit_msdu_life_time, or
-	 *               max_tx_life_time, is exhausted.
-	 *            1: Preamble Override - indicates if the preamble type
-	 *               should be used in TX.
-	 *            2: Preamble Type - the type of the preamble to be used by
-	 *               the policy (0 - long preamble, 1 - short preamble.
-	u8 aflags;
-} __packed;
 #define CONF_TX_MAX_AC_COUNT 4
-/* Slot number setting to start transmission at PIFS interval */
-#define CONF_TX_AIFS_PIFS 1
-/* Slot number setting to start transmission at DIFS interval normal
- * DCF access
-#define CONF_TX_AIFS_DIFS 2
-enum conf_tx_ac {
-	CONF_TX_AC_BE = 0,         /* best effort / legacy */
-	CONF_TX_AC_BK = 1,         /* background */
-	CONF_TX_AC_VI = 2,         /* video */
-	CONF_TX_AC_VO = 3,         /* voice */
-	CONF_TX_AC_CTS2SELF = 4,   /* fictitious AC, follows AC_VO */
-	CONF_TX_AC_ANY_TID = 0xff
-struct conf_sig_weights {
-	/* RSSI from beacons average weight.
-	 * Range: uint8_t
-	u8 rssi_bcn_avg_weight;
-	/* RSSI from data average weight.
-	 * Range: uint8_t
-	u8 rssi_pkt_avg_weight;
-	/* SNR from beacons average weight.
-	 * Range: uint8_t
-	u8 snr_bcn_avg_weight;
-	/* SNR from data average weight.
-	 * Range: uint8_t
-	u8 snr_pkt_avg_weight;
-} __packed;
 struct conf_tx_ac_category {
 	/* The AC class identifier.
@@ -355,51 +175,44 @@ struct conf_tx_ac_category {
 	u8 mu_edca_timer;
 } __packed;
-#define CONF_TX_MAX_TID_COUNT 8
+struct conf_tx_tid {
+	u8 channel_type;
+	u8 ps_scheme;
+} __packed;
-/* Allow TX BA on all TIDs but 6,7. These are currently reserved in the FW */
-#define CONF_TX_BA_ENABLED_TID_BITMAP 0x3F
+#define CONF_TX_RATE_MASK_BASIC     (CONF_HW_BIT_RATE_1MBPS | CONF_HW_BIT_RATE_2MBPS)
-enum {
-	CONF_CHANNEL_TYPE_DCF = 0,   /* DC/LEGACY*/
-	CONF_CHANNEL_TYPE_EDCF = 1,  /* EDCA*/
-	CONF_CHANNEL_TYPE_HCCA = 2,  /* HCCA*/
+#define CONF_TX_ENABLED_RATES       (CONF_HW_BIT_RATE_1MBPS |    \
+	CONF_HW_BIT_RATE_2MBPS | CONF_HW_BIT_RATE_5_5MBPS |      \
+	CONF_HW_BIT_RATE_6MBPS | CONF_HW_BIT_RATE_9MBPS |        \
+	CONF_HW_BIT_RATE_11MBPS | CONF_HW_BIT_RATE_12MBPS |      \
+	CONF_HW_BIT_RATE_18MBPS | CONF_HW_BIT_RATE_24MBPS |      \
+	CONF_HW_BIT_RATE_36MBPS | CONF_HW_BIT_RATE_48MBPS |      \
+	CONF_HW_BIT_RATE_54MBPS)
-enum {
-	CONF_PS_SCHEME_LEGACY = 0,
-	CONF_PS_SCHEME_UPSD_TRIGGER = 1,
-	CONF_PS_SCHEME_LEGACY_PSPOLL = 2,
-	CONF_PS_SCHEME_SAPSD = 3,
+#define CONF_TX_MCS_RATES (CONF_HW_BIT_RATE_MCS_0 |              \
+	CONF_HW_BIT_RATE_MCS_1 | CONF_HW_BIT_RATE_MCS_2 |        \
+	CONF_HW_BIT_RATE_MCS_3 | CONF_HW_BIT_RATE_MCS_4 |        \
+	CONF_HW_BIT_RATE_MCS_5 | CONF_HW_BIT_RATE_MCS_6 |        \
+	CONF_HW_BIT_RATE_MCS_7)
-enum {
-	CONF_ACK_POLICY_LEGACY = 0,
-	CONF_ACK_POLICY_NO_ACK = 1,
-	CONF_ACK_POLICY_BLOCK = 2,
+#define CONF_TX_IBSS_DEFAULT_RATES  (CONF_HW_BIT_RATE_1MBPS |       \
+		CONF_HW_BIT_RATE_11MBPS | CONF_TX_OFDM_RATES)
-struct conf_tx_tid {
-	u8 queue_id;
-	u8 channel_type;
-	u8 tsid;
-	u8 ps_scheme;
-	u8 ack_policy;
-	u32 apsd_conf[2];
-} __packed;
+#define CONF_TX_CCK_RATES  (CONF_HW_BIT_RATE_1MBPS |		\
+	CONF_HW_BIT_RATE_11MBPS)
-struct conf_tx_settings {
-	/* The TX ED value for TELEC Enable/Disable.
-	 * Range: 0, 1
-	u8 tx_energy_detection;
+#define CONF_TX_OFDM_RATES (CONF_HW_BIT_RATE_6MBPS |             \
+	CONF_HW_BIT_RATE_12MBPS | CONF_HW_BIT_RATE_24MBPS |      \
-	/* Configuration for rate classes for TX (currently only one
-	 * rate class supported). Used in non-AP mode.
-	struct conf_tx_rate_class sta_rc_conf;
+#define CONF_BCN_IE_OUI_LEN 3
+#define CONF_BCN_IE_VER_LEN 2
+struct conf_tx_settings {
 	/* Configuration for access categories for TX rate control.
 	u8 ac_conf_count;
@@ -416,11 +229,6 @@ struct conf_tx_settings {
 	u8 max_tx_retries;
-	/* AP-mode - after this number of seconds a connected station is
-	 * considered inactive.
-	u16 ap_aging_period;
 	/* Configuration for TID parameters.
 	u8 tid_conf_count;
@@ -434,25 +242,12 @@ struct conf_tx_settings {
 	struct conf_tx_tid tid_conf6;
 	struct conf_tx_tid tid_conf7;
-	/* The TX fragmentation threshold.
-	 * Range: uint16_t
-	u16 frag_threshold;
 	/* Max time in msec the FW may delay frame TX-Complete interrupt.
 	 * Range: uint16_t
 	u16 tx_compl_timeout;
-	/* Completed TX packet count which requires to issue the TX-Complete
-	 * interrupt.
-	 * Range: uint16_t
-	u16 tx_compl_threshold;
 	/* The rate used for control messages and scanning on the 2.4GHz band
@@ -465,43 +260,12 @@ struct conf_tx_settings {
 	u32 basic_rate_5;
-	/* TX retry limits for templates
-	u8 tmpl_short_retry_limit;
-	u8 tmpl_long_retry_limit;
 	/* Time in ms for Tx watchdog timer to expire */
 	u32 tx_watchdog_timeout;
-	/* when a slow link has this much packets pending, it becomes a low
-	 * priority link, scheduling-wise
-	u8 slow_link_thold;
-	/* when a fast link has this much packets pending, it becomes a low
-	u8 fast_link_thold;
 } __packed;
-enum {
-	CONF_WAKE_UP_EVENT_BEACON    = 0x00, /* Wake on every Beacon */
-	CONF_WAKE_UP_EVENT_DTIM      = 0x01, /* Wake on every DTIM */
-	CONF_WAKE_UP_EVENT_N_DTIM    = 0x02, /* Wake every Nth DTIM */
-	CONF_WAKE_UP_EVENT_LIMIT     = CONF_WAKE_UP_EVENT_N_DTIM,
-	/* Not supported: */
-	CONF_WAKE_UP_EVENT_N_BEACONS = 0x03, /* Wake every Nth beacon */
-	CONF_WAKE_UP_EVENT_BITS_MASK = 0x0F
 #define CONF_MAX_BCN_FILT_IE_COUNT 32
-#define CONF_BCN_RULE_PASS_ON_CHANGE         BIT(0)
-#define CONF_BCN_RULE_PASS_ON_APPEARANCE     BIT(1)
-#define CONF_BCN_IE_OUI_LEN    3
-#define CONF_BCN_IE_VER_LEN    2
 struct conf_bcn_filt_rule {
 	/* IE number to which to associate a rule.
@@ -528,16 +292,6 @@ struct conf_bcn_filt_rule {
 	u8 version[2];
 } __packed;
-enum conf_bcn_filt_mode {
-	CONF_BCN_FILT_MODE_DISABLED = 0,
-	CONF_BCN_FILT_MODE_ENABLED = 1
-enum conf_bet_mode {
-	CONF_BET_MODE_DISABLE = 0,
-	CONF_BET_MODE_ENABLE = 1,
 struct conf_conn_settings {
 	/* Enable or disable the beacon filtering.
@@ -598,88 +352,11 @@ struct conf_conn_settings {
 	u32 bss_lose_timeout;
-	/* Beacon receive timeout.
-	 * Range: uint32_t
-	u32 beacon_rx_timeout;
-	/* Broadcast receive timeout.
-	 * Range: uint32_t
-	u32 broadcast_timeout;
-	/* Enable/disable reception of broadcast packets in power save mode
-	 * Range: 1 - enable, 0 - disable
-	u8 rx_broadcast_in_ps;
-	/* Consecutive PS Poll failures before sending event to driver
-	 * Range: uint8_t
-	u8 ps_poll_threshold;
-	/* Configuration of signal average weights.
-	struct conf_sig_weights sig_weights;
-	/* Specifies if beacon early termination procedure is enabled or
-	 * disabled.
-	 * Range: CONF_BET_MODE_*
-	u8 bet_enable;
-	/* Specifies the maximum number of consecutive beacons that may be
-	 * early terminated. After this number is reached at least one full
-	 * beacon must be correctly received in FW before beacon ET
-	 * resumes.
-	 * Range 0 - 255
-	u8 bet_max_consecutive;
-	/* Specifies the maximum number of times to try PSM entry if it fails
-	 * (if sending the appropriate null-func message fails.)
-	 * Range 0 - 255
-	u8 psm_entry_retries;
-	/* Specifies the maximum number of times to try PSM exit if it fails
-	 * Range 0 - 255
-	u8 psm_exit_retries;
-	/* Specifies the maximum number of times to try transmit the PSM entry
-	 * null-func frame for each PSM entry attempt
-	 * Range 0 - 255
-	u8 psm_entry_nullfunc_retries;
 	/* Specifies the dynamic PS timeout in ms that will be used
 	 * by the FW when in AUTO_PS mode
 	u16 dynamic_ps_timeout;
-	/* Specifies whether dynamic PS should be disabled and PSM forced.
-	 * This is required for certain WiFi certification tests.
-	u8 forced_ps;
-	/* Specifies the interval of the connection keep-alive null-func
-	 * frame in ms.
-	 * Range: 1000 - 3600000
-	u32 keep_alive_interval;
 	/* Maximum listen interval supported by the driver in units of beacons.
 	 * Range: uint16_t
@@ -696,65 +373,6 @@ struct conf_conn_settings {
 	u8 suspend_rx_ba_activity;
 } __packed;
-struct conf_itrim_settings {
-	/* enable dco itrim */
-	u8 enable;
-	/* moderation timeout in microsecs from the last TX */
-	u32 timeout;
-} __packed;
-enum conf_fast_wakeup {
-	CONF_FAST_WAKEUP_ENABLE,
-	CONF_FAST_WAKEUP_DISABLE,
-struct conf_pm_config_settings {
-	/* Host clock settling time
-	 * Range: 0 - 30000 us
-	u32 host_clk_settling_time;
-	/* Host fast wakeup support
-	 * Range: enum conf_fast_wakeup
-	u8 host_fast_wakeup_support;
-} __packed;
-struct conf_roam_trigger_settings {
-	/* The minimum interval between two trigger events.
-	 * Range: 0 - 60000 ms
-	u16 trigger_pacing;
-	/* The weight for rssi/beacon average calculation
-	 * Range: 0 - 255
-	u8 avg_weight_rssi_beacon;
-	/* The weight for rssi/data frame average calculation
-	 * Range: 0 - 255
-	u8 avg_weight_rssi_data;
-	/* The weight for snr/beacon average calculation
-	 * Range: 0 - 255
-	u8 avg_weight_snr_beacon;
-	/* The weight for snr/data frame average calculation
-	 * Range: 0 - 255
-	u8 avg_weight_snr_data;
-} __packed;
 struct conf_scan_settings {
 	/* The minimum time to wait on each channel for active scans
 	 * This value will be used whenever there's a connected interface.
@@ -858,78 +476,11 @@ struct conf_sched_scan_settings {
 struct conf_ht_setting {
 	u8 rx_ba_win_size;
-	u8 tx_ba_win_size;
-	u16 inactivity_timeout;
-	/* bitmap of enabled TIDs for TX BA sessions */
-	u8 tx_ba_tid_bitmap;
 	/* DEFAULT / WIDE / SISO20 */
 	u8 mode;
 } __packed;
-struct conf_memory_settings {
-	/* Number of stations supported in IBSS mode */
-	u8 num_stations;
-	/* Number of ssid profiles used in IBSS mode */
-	u8 ssid_profiles;
-	/* Number of memory buffers allocated to rx pool */
-	u8 rx_block_num;
-	/* Minimum number of blocks allocated to tx pool */
-	u8 tx_min_block_num;
-	/* Disable/Enable dynamic memory */
-	u8 dynamic_memory;
-	/* Minimum required free tx memory blocks in order to assure optimum
-	 * performance
-	 * Range: 0-120
-	u8 min_req_tx_blocks;
-	/* Minimum required free rx memory blocks in order to assure optimum
-	 * performance
-	 * Range: 0-120
-	u8 min_req_rx_blocks;
-	/* Minimum number of mem blocks (free+used) guaranteed for TX
-	 * Range: 0-120
-	u8 tx_min;
-} __packed;
-struct conf_rx_streaming_settings {
-	/* RX Streaming duration (in msec) from last tx/rx
-	 * Range: uint32_t
-	u32 duration;
-	/* Bitmap of tids to be polled during RX streaming.
-	 * (Note: it doesn't look like it really matters)
-	 * Range: 0x1-0xff
-	u8 queues;
-	/* RX Streaming interval.
-	 * (Note:this value is also used as the rx streaming timeout)
-	 * Range: 0 (disabled), 10 - 100
-	u8 interval;
-	/* enable rx streaming also when there is no coex activity
-	u8 always;
-} __packed;
 struct conf_fwlog {
 	/* Continuous or on-demand */
 	u8 mode;
@@ -953,53 +504,6 @@ struct conf_fwlog {
 	u8 threshold;
 } __packed;
-#define ACX_RATE_MGMT_NUM_OF_RATES 13
-struct conf_rate_policy_settings {
-	u16 rate_retry_score;
-	u16 per_add;
-	u16 per_th1;
-	u16 per_th2;
-	u16 max_per;
-	u8 inverse_curiosity_factor;
-	u8 tx_fail_low_th;
-	u8 tx_fail_high_th;
-	u8 per_alpha_shift;
-	u8 per_add_shift;
-	u8 per_beta1_shift;
-	u8 per_beta2_shift;
-	u8 rate_check_up;
-	u8 rate_check_down;
-	u8 rate_retry_policy[13];
-} __packed;
-struct conf_hangover_settings {
-	u32 recover_time;
-	u8 hangover_period;
-	u8 dynamic_mode;
-	u8 early_termination_mode;
-	u8 max_period;
-	u8 min_period;
-	u8 increase_delta;
-	u8 decrease_delta;
-	u8 quiet_time;
-	u8 increase_time;
-	u8 window_size;
-} __packed;
-enum {
-	CLOCK_CONFIG_16_2_M	= 1,
-	CLOCK_CONFIG_16_368_M,
-	CLOCK_CONFIG_16_8_M,
-	CLOCK_CONFIG_19_2_M,
-	CLOCK_CONFIG_26_M,
-	CLOCK_CONFIG_32_736_M,
-	CLOCK_CONFIG_33_6_M,
-	CLOCK_CONFIG_38_468_M,
-	CLOCK_CONFIG_52_M,
-	NUM_CLOCK_CONFIGS,
 enum cc33xx_ht_mode {
 	/* Default - use MIMO, fallback to SISO20 */
 	HT_MODE_DEFAULT = 0,
@@ -1011,37 +515,6 @@ enum cc33xx_ht_mode {
 	HT_MODE_SISO20 = 2,
-struct conf_ap_sleep_settings {
-	/* Duty Cycle (20-80% of staying Awake) for IDLE AP
-	 * (0: disable)
-	u8 idle_duty_cycle;
-	/* Duty Cycle (20-80% of staying Awake) for Connected AP
-	 * (0: disable)
-	u8 connected_duty_cycle;
-	/* Maximum stations that are allowed to be connected to AP
-	 *  (255: no limit)
-	u8 max_stations_thresh;
-	/* Timeout till enabling the Sleep Mechanism after data stops
-	 * [unit: 100 msec]
-	u8 idle_conn_thresh;
-} __packed;
-#define CHANNELS_COUNT 39 /* 14 2.4GHz channels, 25 5GHz channels*/
-#define PER_CHANNEL_REG_RULE_BYTES 13
-#define REG_RULES_COUNT (CHANNELS_COUNT * PER_CHANNEL_REG_RULE_BYTES) /* 507 */
-/* TX Power limitation for a channel, used for reg domain */
-struct conf_channel_power_limit {
-	u32 reg_lim_0;
-	u32 reg_lim_1;
-	u32 reg_lim_2;
-	u8  reg_lim_3;
-} __packed;
 struct conf_coex_configuration {
 	/* Work without Coex HW
@@ -1178,7 +651,7 @@ struct cc33xx_core_conf {
 	u8 wake_up_event;
 	u8 suspend_listen_interval;
 	u8 suspend_wake_up_event;
-	u8 per_channel_power_limit[507];
+	u8 per_channel_power_limit[520];
 	u32 internal_slowclk_wakeup_earlier;
 	u32 internal_slowclk_open_window_longer;
 	u32 external_slowclk_wakeup_earlier;
@@ -1195,6 +668,7 @@ struct cc33xx_core_conf {
 } __packed;
 struct cc33xx_mac_conf {
+	u8 ps_mode;
 	u8 ps_scheme;
 	u8 he_enable;
 	u8 ap_max_num_stations;
@@ -1217,21 +691,12 @@ struct cc33xx_phy_conf {
 } __packed;
 struct cc33xx_host_conf {
-	struct conf_rx_settings rx;
 	struct conf_tx_settings tx;
 	struct conf_conn_settings conn;
-	struct conf_itrim_settings itrim;
-	struct conf_pm_config_settings pm_config;
-	struct conf_roam_trigger_settings roam_trigger;
 	struct conf_scan_settings scan;
 	struct conf_sched_scan_settings sched_scan;
 	struct conf_ht_setting ht;
-	struct conf_memory_settings mem;
-	struct conf_rx_streaming_settings rx_streaming;
 	struct conf_fwlog fwlog;
-	struct conf_rate_policy_settings rate;
-	struct conf_hangover_settings hangover;
-	struct conf_ap_sleep_settings ap_sleep;
 } __packed;
diff --git a/drivers/net/wireless/ti/cc33xx/io.c b/drivers/net/wireless/ti/cc33xx/io.c
index c8759b63ac2d..e0f5dd2cb78a 100644
--- a/drivers/net/wireless/ti/cc33xx/io.c
+++ b/drivers/net/wireless/ti/cc33xx/io.c
@@ -26,14 +26,9 @@ void cc33xx_disable_interrupts_nosync(struct cc33xx *cc)
 	cc->if_ops->disable_irq(cc->dev);
-void cc33xx_irq(void *cookie);
 void cc33xx_enable_interrupts(struct cc33xx *cc)
 	cc->if_ops->enable_irq(cc->dev);
-	cc33xx_debug(DEBUG_CC33xx, "IBI_WA: Read core status");
-	cc33xx_irq(cc);
-	cc33xx_debug(DEBUG_CC33xx, "IBI_WA: Core status processed");
 void cc33xx_io_reset(struct cc33xx *cc)
diff --git a/drivers/net/wireless/ti/cc33xx/main.c b/drivers/net/wireless/ti/cc33xx/main.c
index 4c271221a14b..52554e0adb1f 100644
--- a/drivers/net/wireless/ti/cc33xx/main.c
+++ b/drivers/net/wireless/ti/cc33xx/main.c
@@ -302,7 +302,8 @@ static struct ieee80211_sband_iftype_data iftype_data_2ghz[] = {{
 			IEEE80211_HE_PHY_CAP9_NON_TRIGGERED_CQI_FEEDBACK |
 			IEEE80211_HE_PHY_CAP9_RX_FULL_BW_SU_USING_MU_WITH_COMP_SIGB |
 			IEEE80211_HE_PHY_CAP9_RX_FULL_BW_SU_USING_MU_WITH_NON_COMP_SIGB |
-			IEEE80211_HE_PHY_CAP9_NOMINAL_PKT_PADDING_16US,
+			(IEEE80211_HE_PHY_CAP9_NOMINAL_PKT_PADDING_16US <<
+				IEEE80211_HE_PHY_CAP9_NOMINAL_PKT_PADDING_POS),
 		/* Set default Tx/Rx HE MCS NSS Support field.
 		 * Indicate support for up to 2 spatial streams and all
@@ -382,6 +383,7 @@ static struct ieee80211_channel cc33xx_channels_5ghz[] = {
 	{ .hw_value = 132, .center_freq = 5660, .max_power = CC33XX_MAX_TXPWR },
 	{ .hw_value = 136, .center_freq = 5680, .max_power = CC33XX_MAX_TXPWR },
 	{ .hw_value = 140, .center_freq = 5700, .max_power = CC33XX_MAX_TXPWR },
+	{ .hw_value = 144, .center_freq = 5720, .max_power = CC33XX_MAX_TXPWR },
 	{ .hw_value = 149, .center_freq = 5745, .max_power = CC33XX_MAX_TXPWR },
 	{ .hw_value = 153, .center_freq = 5765, .max_power = CC33XX_MAX_TXPWR },
 	{ .hw_value = 157, .center_freq = 5785, .max_power = CC33XX_MAX_TXPWR },
@@ -449,7 +451,8 @@ static struct ieee80211_sband_iftype_data iftype_data_5ghz[] = {{
@@ -2335,11 +2338,6 @@ static int cc33xx_op_add_interface(struct ieee80211_hw *hw,
 					     &wlvif->dev_role_id);
 		if (ret < 0)
 			goto out;
-		/* needed mainly for configuring rate policies */
-		ret = cc33xx_acx_config_ps(cc, wlvif);
-		if (ret < 0)
-			goto out;
 	list_add(&wlvif->list, &cc->wlvif_list);
@@ -3052,6 +3050,7 @@ static int cc33xx_set_key(struct cc33xx *cc, enum set_key_cmd cmd,
 	case WLAN_CIPHER_SUITE_TKIP:
 		key_type = KEY_TKIP;
 		key_conf->hw_key_idx = key_conf->keyidx;
+		key_conf->flags |= IEEE80211_KEY_FLAG_PUT_IV_SPACE;
 		break;
 	case WLAN_CIPHER_SUITE_CCMP:
 		key_type = KEY_AES;
@@ -3819,35 +3818,20 @@ static void cc33xx_bss_info_changed_sta(struct cc33xx *cc,
 	if (changed & BSS_CHANGED_PS) {
-		if (vif->cfg.ps &&
-		    test_bit(WLVIF_FLAG_STA_ASSOCIATED, &wlvif->flags) &&
-		    !test_bit(WLVIF_FLAG_IN_PS, &wlvif->flags)) {
-			int ps_mode;
-			char *ps_mode_str;
-			if (cc->conf.host_conf.conn.forced_ps) {
-				ps_mode = STATION_POWER_SAVE_MODE;
-				ps_mode_str = "forced";
-			} else {
-				ps_mode = STATION_AUTO_PS_MODE;
-				ps_mode_str = "auto";
-			cc33xx_debug(DEBUG_PSM, "%s ps enabled", ps_mode_str);
+		ret = 0;
-			ret = cc33xx_ps_set_mode(cc, wlvif, ps_mode);
-			if (ret < 0)
-				cc33xx_warning("enter %s ps failed %d",
-					       ps_mode_str, ret);
-		} else if (!vif->cfg.ps && test_bit(WLVIF_FLAG_IN_PS,
-						     &wlvif->flags)) {
-			cc33xx_debug(DEBUG_PSM, "auto ps disabled");
-						 STATION_ACTIVE_MODE);
-			if (ret < 0)
-				cc33xx_warning("exit auto ps failed %d", ret);
+		if (cc->conf.mac.ps_mode == STATION_AUTO_PS_MODE) {
+			if ((vif->cfg.ps) && test_bit(WLVIF_FLAG_STA_ASSOCIATED, &wlvif->flags)) {
+				ret = cc33xx_ps_set_mode(cc, wlvif, STATION_AUTO_PS_MODE);
+			} else if (!vif->cfg.ps) {
+				ret = cc33xx_ps_set_mode(cc, wlvif, STATION_ACTIVE_MODE);
+		} else {
+			ret = cc33xx_ps_set_mode(cc, wlvif, cc->conf.mac.ps_mode);
+		if (ret < 0)
+			cc33xx_warning("exit auto ps failed %d", ret);
 	/* Handle new association with HT. Do this after join. */
@@ -4197,7 +4181,6 @@ static int cc33xx_op_conf_tx(struct ieee80211_hw *hw,
 static u64 cc33xx_op_get_tsf(struct ieee80211_hw *hw, struct ieee80211_vif *vif)
 	struct cc33xx *cc = hw->priv;
-	struct cc33xx_vif *wlvif = cc33xx_vif_to_data(vif);
 	u64 mactime = ULLONG_MAX;
 	cc33xx_debug(DEBUG_MAC80211, "mac80211 get tsf");
@@ -4207,8 +4190,6 @@ static u64 cc33xx_op_get_tsf(struct ieee80211_hw *hw, struct ieee80211_vif *vif)
 	if (unlikely(cc->state != CC33XX_STATE_ON))
 		goto out;
-	cc33xx_acx_tsf_info(cc, wlvif, &mactime);
 out:
 	mutex_unlock(&cc->mutex);
diff --git a/drivers/net/wireless/ti/cc33xx/ps.c b/drivers/net/wireless/ti/cc33xx/ps.c
index e708ef8d5f46..1386a3f9f344 100644
--- a/drivers/net/wireless/ti/cc33xx/ps.c
+++ b/drivers/net/wireless/ti/cc33xx/ps.c
@@ -23,7 +23,6 @@ int cc33xx_ps_set_mode(struct cc33xx *cc, struct cc33xx_vif *wlvif,
 		if (ret < 0)
 			return ret;
-		set_bit(WLVIF_FLAG_IN_PS, &wlvif->flags);
 		break;
 	case STATION_ACTIVE_MODE:
@@ -33,7 +32,6 @@ int cc33xx_ps_set_mode(struct cc33xx *cc, struct cc33xx_vif *wlvif,
 		if (ret < 0)
 			return ret;
-		clear_bit(WLVIF_FLAG_IN_PS, &wlvif->flags);
 		break;
 	default:
diff --git a/drivers/net/wireless/ti/cc33xx/rx.c b/drivers/net/wireless/ti/cc33xx/rx.c
index e6467e1e223e..3493238de8e2 100644
--- a/drivers/net/wireless/ti/cc33xx/rx.c
+++ b/drivers/net/wireless/ti/cc33xx/rx.c
@@ -67,6 +67,9 @@ static void cc33xx_rx_status(struct cc33xx *cc,
 			cc33xx_warning("Michael MIC error. Desc: 0x%x",
 				       desc_err_code);
+		if (desc->status & CC33XX_RX_DESC_NEW_KEY)
+			status->flag |= RX_FLAG_PN_VALIDATED;
 	if (beacon || probe_rsp)
diff --git a/drivers/net/wireless/ti/cc33xx/rx.h b/drivers/net/wireless/ti/cc33xx/rx.h
index 46ff6867749f..523a35288d15 100644
--- a/drivers/net/wireless/ti/cc33xx/rx.h
+++ b/drivers/net/wireless/ti/cc33xx/rx.h
@@ -25,13 +25,15 @@
  * Bits 0-2 - error code
  * Bits 3-5 - process_id tag (AP mode FW)
- * Bits 6-7 - reserved
+ * Bits 6   - new key
+ * Bits 7   - reserved
 enum {
 	CC33XX_RX_DESC_SUCCESS		= 0x00,
 	CC33XX_RX_DESC_DECRYPT_FAIL	= 0x01,
 	CC33XX_RX_DESC_MIC_FAIL		= 0x02,
-	CC33XX_RX_DESC_STATUS_MASK	= 0x07
+	CC33XX_RX_DESC_STATUS_MASK	= 0x07,
+	CC33XX_RX_DESC_NEW_KEY		= 0x40
 /* Account for the padding inserted by the FW in case of RX_ALIGNMENT
2.34.1
BT driver patch
0001-bluetooth-add-cc33xx-ble-driver-and-debugfs.patch.txt
I'm not sure miss some detail in my patches, Could anyone know where the problem is?
Thanks!!
Mike
