Hello TI Support,
I'm using the CC3235S Wi-Fi MCU in Access Point (AP) mode with the SimpleLink SDK. In my image.syscfg
file, I have enabled 5 GHz support via:
Radio Settings > 5 GHz Radio Settings > Support 5G = Enable
However, when I analyze the antenna output using a spectrum analyzer, I do not observe any activity in the 5 GHz spectrum—only 2.4 GHz activity is visible.
Could you please clarify the following:
Does the CC3235S support AP mode operation on the 5 GHz band?
If so, are there additional configuration steps required beyond enabling "Support 5G" in SysConfig?
Is there a way to explicitly select a 5 GHz channel for AP mode?
Thank you for your assistance.
Mason Dill
