Hi,all
I am using a combination of iMX53 + WL1271 chip. Android version is 2.3.4,the wifi module is ok,but the bluetooth module have a problem,
when I press the bluetooth turn on button,bluetooth does not work and print log as below: anyone can help me? TKS!
D/BluetoothService( 2136): Bluetooth state 10 -> 11
V/BluetoothEventRedirector( 2416): Received android.bluetooth.adapter.action.STATE_CHANGED
I/bluedroid( 2136): Starting hciattach daemon
E/UIM: ( 2095): uim: Inside st_sig_handler
E/UIM: ( 2095): uim: signal received, opening /dev/ttymxc2
E/UIM: ( 2095): uim: Inside set_baud_rate
D/UIM: ( 2095): uim: set_baud_rate() done
E/UIM: ( 2095): uim: Setting speed to 921600
E/UIM: ( 2095): uim: Inside read_command_complete
E/UIM: ( 2095): uim: Command complete started
E/UIM: ( 2095): uim: Inside read_hci_event
E/UIM: ( 2095): uim: read_hci_event
E/UIM: ( 2095): uim: Invalid response
(stk):line disc installation timed out
