Other Parts Discussed in Thread: CC3235SF, CC3200
I’m using TI’s CC3235SF LaunchXL FreeRTOS MQTT example to connect over Wi-Fi to my own broker (HiveMQ), but MQTTClient_Connect() fails with errors –111, –456, –468, and –2006. What exact certificate format (PEM vs. DER, root vs. chain), TLS parameters, and example settings (including how to populate Mqtt_Client_secure_files and MQTTClient_ConnParams) are required to establish a successful secure connection to the MQTT so I can subscribe and publish messages?
below are changes and results obtained:
Code modified in the main example project:
#define WILL_TOPIC "devices/865031063735368/telemetry" #define WILL_MSG "Client start to test" #define WILL_QOS MQTT_QOS_2 #define WILL_RETAIN false /* Defining Broker IP address and port Number */ #define SERVER_ADDRESS "mqtt.mssve.ai" #define SECURED_PORT_NUMBER 8883 #define SUBSCRIPTION_TOPIC0 "devices/865031063735368/telemetry" /* Defining Publish Topic Values */ #define PUBLISH_TOPIC0 "devices/865031063735368/telemetry" #define PUBLISH_TOPIC0_DATA \ "This is the testing results" /* Defining Enrolled Topic Values. */ #define ENROLLED_TOPIC "devices/865031063735368/telemetry" char ClientId[13] = "Inno1234"; /* Client User Name and Password */ const char *ClientUsername = "test"; const char *ClientPassword = "1234"; /* Server User Name and Password */ const char *ServerUsername = "test"; const char *ServerPassword = "1234"; #ifdef SECURE_CLIENT char *Mqtt_Client_secure_files[CLIENT_NUM_SECURE_FILES] = {"isrgrootx1.der"}; MQTTClient_ConnParams Mqtt_ClientCtx = { MQTTCLIENT_NETCONN_SEC | MQTT_DEV_NETCONN_URL, SERVER_ADDRESS, //SERVER_ADDRESS, SECURED_PORT_NUMBER, // PORT_NUMBER SLNETSOCK_SEC_METHOD_SSLv3_TLSV1_2, SLNETSOCK_SEC_CIPHER_FULL_LIST, CLIENT_NUM_SECURE_FILES, Mqtt_Client_secure_files }; #ifdef SECURE_SERVER /* In order to use secured socket method, cipher, n_files and secure_files */ /* must be configured. certificates also must be programmed */ /* ("server-key.pem", "server-cert.pem") */ #define SERVER_NUM_SECURE_FILES 2 char *Mqtt_Server_secure_files[SERVER_NUM_SECURE_FILES] = { "isrgrootx1.pem", "isrgrootx1.der"}; MQTTServer_ConnParams Mqtt_Server = { SECURED_PORT_NUMBER, SLNETSOCK_SEC_METHOD_SSLv3_TLSV1_2, SLNETSOCK_SEC_CIPHER_FULL_LIST, SERVER_NUM_SECURE_FILES, Mqtt_Server_secure_files };
Output:
[NETAPP EVENT] IP acquired by the device
Device came up in Station mode
[WLAN EVENT] STA Connected to the AP: Innowave , BSSID: a6:a4:6b:a4:97:7c
Device has connected to Innowave
Device IP Address is 192.168.100.137
Create MQTT client successfully
Client thread created successfully
MQTT client set successfully
..........Connection to broker failed, Error code: -111
CC3200 Publishes the following message
Topic: devices/865031063735368/telemetry
Data: This is the testing results
On-board Client Disconnected
In order to reconnect local client, Reset board.
Aiman,
