CC3301: Wi-Fi driver on RV1106 platform
Part Number: CC3301
I have a few problem porting driver to the RV1106 platform, espacially using Luckfox SDK as reference.
First problem is that all other drivers that I have tested with this platform( AIC8800DC, RTL8189FTV) have drivers as files and can be build external from the kernel. (You can see it in sysdrv/drv_ko/wifi folder)
I have found driver only like a patch foc CC33xx. Write python script to extract files. Then comment all stuff connected with power managment (it was't work for me). This make me able to load driver. I'm able to scan Wi-Fi networks but it fails to connect to any Wi-Fi for some reason.
Could you kindly asist me to solve this error. We are thinking to walk away from Chinese radio.
dmesg of the connection attempt.
[  155.198572] wlcore: Reading control info
[  155.198645] wlcore: Processing message type 2, len 4
[  155.199622] wlcore: Reading control info
[  155.199695] wlcore: Processing message type 2, len 4
[  155.200671] wlcore: Reading control info
[  155.200742] wlcore: Processing message type 2, len 4
[  155.201720] wlcore: Reading control info
[  155.201794] wlcore: Processing message type 2, len 4
[  155.202772] wlcore: Reading control info
[  155.202845] wlcore: Processing message type 2, len 4
[  155.203822] wlcore: Reading control info
[  155.203896] wlcore: Processing message type 2, len 4
[  155.204872] wlcore: Reading control info
[  155.204947] wlcore: Processing message type 2, len 4
[  155.205923] wlcore: Reading control info
[  155.205996] wlcore: Processing message type 2, len 4
[  155.206972] wlcore: Reading control info
[  155.207048] wlcore: Processing message type 2, len 4
[  155.208026] wlcore: Reading control info
[  155.208100] wlcore: Processing message type 2, len 4
[  155.209093] wlcore: Reading control info
[  155.209181] wlcore: Processing message type 2, len 4
[  155.210156] wlcore: Reading control info
[  155.210232] wlcore: Processing message type 2, len 4
[  155.211221] wlcore: Reading control info
[  155.211294] wlcore: Processing message type 2, len 4
[  155.212326] wlcore: Reading control info
[  155.212409] wlcore: Processing message type 2, len 4
[  155.213402] wlcore: Reading control info
[  155.213476] wlcore: Processing message type 2, len 4
[  155.214458] wlcore: Reading control info
[  155.214541] wlcore: Processing message type 2, len 4
[  155.215531] wlcore: Reading control info
[  155.215603] wlcore: Processing message type 2, len 4
[  155.216580] wlcore: Reading control info
[  155.216652] wlcore: Processing message type 2, len 4
[  155.217626] wlcore: Reading control info
[  155.217699] wlcore: Processing message type 2, len 4
[  155.218669] wlcore: Reading control info
[  155.218743] wlcore: Processing message type 2, len 4
[  155.219718] wlcore: Reading control info
[  155.219792] wlcore: Processing message type 2, len 4
[  155.220765] wlcore: Reading control info
[  155.220839] wlcore: Processing message type 2, len 4
[  155.221810] wlcore: Reading control info
[  155.221885] wlcore: Processing message type 2, len 4
[  155.222864] wlcore: Reading control info
[  155.222937] wlcore: Processing message type 2, len 4
[  155.223914] wlcore: Reading control info
[  155.223987] wlcore: Processing message type 2, len 4
[  155.224961] wlcore: Reading control info
[  155.225035] wlcore: Processing message type 2, len 4
[  155.226009] wlcore: Reading control info
[  155.226084] wlcore: Processing message type 2, len 4
[  155.227077] wlcore: Reading control info
[  155.227155] wlcore: Processing message type 2, len 4
[  155.228144] wlcore: Reading control info
[  155.228220] wlcore: Processing message type 2, len 4
[  155.229277] wlcore: Reading control info
[  155.229356] wlcore: Processing message type 2, len 4
[  155.230382] wlcore: Reading control info
[  155.230518] wlcore: Processing message type 2, len 4
[  155.231528] wlcore: Reading control info
[  155.231624] wlcore: Processing message type 2, len 4
[  155.232635] wlcore: Reading control info
[  155.232747] wlcore: Processing message type 2, len 4
[  155.233753] wlcore: Reading control info
[  155.233831] wlcore: Processing message type 2, len 4
[  155.234832] wlcore: Reading control info
[  155.234913] wlcore: Processing message type 2, len 4
[  155.235911] wlcore: Reading control info
[  155.235990] wlcore: Processing message type 2, len 4
[  155.236993] wlcore: Reading control info
[  155.237075] wlcore: Processing message type 2, len 4
[  155.238101] wlcore: Reading control info
[  155.238208] wlcore: Processing message type 2, len 4
[  155.239454] wlcore: Reading control info
[  155.239651] wlcore: Processing message type 2, len 4
[  155.240657] wlcore: Reading control info
[  155.240734] wlcore: Processing message type 2, len 4
[  155.241721] wlcore: Reading control info
[  155.241791] wlcore: Processing message type 2, len 4
[  155.242773] wlcore: Reading control info
[  155.242847] wlcore: Processing message type 2, len 4
[  155.243826] wlcore: Reading control info
[  155.243901] wlcore: Processing message type 2, len 4
[  155.244879] wlcore: Reading control info
[  155.244956] wlcore: Processing message type 2, len 4
[  155.245933] wlcore: Reading control info
[  155.246004] wlcore: Processing message type 2, len 4
[  155.246981] wlcore: Reading control info
[  155.247056] wlcore: Processing message type 2, len 4
[  155.248035] wlcore: Reading control info
[  155.248127] wlcore: Processing message type 2, len 4
[  155.249119] wlcore: Reading control info
[  155.249195] wlcore: Processing message type 2, len 4
[  155.250385] wlcore: Reading control info
[  155.250465] wlcore: Processing message type 2, len 4
[  155.251438] wlcore: Reading control info
[  155.251511] wlcore: Processing message type 2, len 4
[  155.252488] wlcore: Reading control info
[  155.252561] wlcore: Processing message type 2, len 4
[  155.253534] wlcore: Reading control info
[  155.253606] wlcore: Processing message type 2, len 4
[  155.254582] wlcore: Reading control info
[  155.254654] wlcore: Processing message type 2, len 4
[  155.255626] wlcore: Reading control info
[  155.255698] wlcore: Processing message type 2, len 4
[  155.256671] wlcore: Reading control info
[  155.256742] wlcore: Processing message type 2, len 4
[  155.257716] wlcore: Reading control info
[  155.257787] wlcore: Processing message type 2, len 4
[  155.258758] wlcore: Reading control info
[  155.258829] wlcore: Processing message type 2, len 4
[  155.259804] wlcore: Reading control info
[  155.259875] wlcore: Processing message type 2, len 4
[  155.260849] wlcore: Reading control info
[  155.260923] wlcore: Processing message type 2, len 4
[  155.261897] wlcore: Reading control info
[  155.261968] wlcore: Processing message type 2, len 4
[  155.262937] wlcore: Reading control info
[  155.263011] wlcore: Processing message type 2, len 4
[  155.264054] wlcore: Reading control info
[  155.264132] wlcore: Processing message type 2, len 4
[  155.265098] wlcore: Reading control info
[  155.265196] wlcore: Processing message type 2, len 4
[  155.266228] wlcore: Reading control info
[  155.266313] wlcore: Processing message type 2, len 4
[  155.267296] wlcore: Reading control info
[  155.267372] wlcore: Processing message type 2, len 4
[  155.268341] wlcore: Reading control info
[  155.268425] wlcore: Processing message type 2, len 4
[  155.269457] wlcore: Reading control info
[  155.269533] wlcore: Processing message type 2, len 4
[  155.269552] wlcore: Suspending IRQ while device reboots
[  155.521118] wlcore: Resuming IRQ
[  155.521286] wlcore: Reading control info
[  155.521360] wlcore: Processing message type 2, len 4
[  155.527840] wlcore: BOOT IRQs: 0x20
[  155.533177] wlcore: ti-connectivity/cc33xx_fw.bin loaded successfully
[  155.533303] 10
[  155.533322] wlcore: Downloading INI Params and Configurations to FW, INI Bin File Payload Length: 1280
[  155.533852] wlcore: Reading control info
[  155.533920] wlcore: Processing message type 2, len 3
[  155.533938] wlcore: CMD# 37, len=1296
[  155.533943] wlcore: INI Params downloaded successfully
[  155.533947] 11
[  155.536422] wlcore: BOOT IRQs: 0x40
[  155.545169] 12
[  155.545187] wlcore: Chip is PG2, No static calibration needed
[  155.545191] 13
[  155.545201] wlcore: acx mem map
[  155.545206] wlcore: cmd interrogate
[  155.545466] wlcore: Reading control info
[  155.545533] wlcore: Processing message type 2, len 20
[  155.545550] wlcore: Response len 20, allocated buffer len 32
[  155.545557] wlcore: CMD# 28, len=16
[  155.545562] wlcore: Skipping cc33xx_hw_init
[  155.545569] wlcore: 11a is supported
[  155.545576] wlcore: Wireless driver version 1.7.0.233
[  155.545587] wlcore: acx get FW versions
[  155.545590] wlcore: cmd interrogate
[  155.545865] wlcore: Reading control info
[  155.545933] wlcore: Processing message type 2, len 28
[  155.545947] wlcore: Response len 28, allocated buffer len 36
[  155.545953] wlcore: CMD# 28, len=36
[  155.545959] wlcore: Wireless firmware version 1.7.0.312
[  155.545971] wlcore: Wireless PHY version 1.2.0.45.6.0.37.69
[  155.545983] wlcore: MAC address derived from EFUSE
[  155.545990] wlcore: Base MAC address: 10:ca:bf:d5:8f:22
[  155.546966] wlcore: Reading control info
[  155.547151] wlcore: Processing message type 2, len 3
[  155.547174] wlcore: CMD# 38, len=20
[  155.548355] wlcore: loaded
[  155.548374] wlcore: wlcore_nvs_cb Complete
[  176.598437] wlcore: mac80211 start
[  176.598456] wlcore: mac80211 add interface type 2 mac 10:ca:bf:d5:8f:22
[  176.598467] wlcore: allocating hw queue base: 0
[  176.598476] wlcore: cmd roles enabled: bitmap before: 0, ret=0
[  176.598484] wlcore: cmd role enable, role type 0, addr = 10:ca:bf:d5:8f:22
[  176.599008] wlcore: Reading control info
[  176.599083] wlcore: Processing message type 2, len 5
[  176.599827] wlcore: CMD# 17, len=20
[  176.599835] wlcore: complete role_id = 0
[  176.599843] wlcore: acx sleep auth 2
[  176.599852] wlcore: cmd configure (9), TSFL 1419131
[  176.600417] wlcore: Reading control info
[  176.600626] wlcore: Processing message type 2, len 4
[  176.600651] wlcore: CMD# 27, len=20
[  176.600659] wlcore: acx group address tbl
[  176.600666] wlcore: cmd configure (7), TSFL 14196b2
[  176.601002] wlcore: Reading control info
[  176.601071] wlcore: Processing message type 2, len 4
[  176.601086] wlcore: CMD# 27, len=140
[  176.601092] wlcore: acx beacon filter table
[  176.601124] wlcore: cmd configure (18), TSFL 14198f9
[  176.601923] wlcore: Reading control info
[  176.602001] wlcore: Processing message type 2, len 4
[  176.602019] wlcore: CMD# 27, len=120
[  176.602028] wlcore: acx beacon filter opt enable=0
[  176.602036] wlcore: cmd configure (17), TSFL 1419c96
[  176.602635] wlcore: Reading control info
[  176.602712] wlcore: Processing message type 2, len 4
[  176.602728] wlcore: CMD# 27, len=20
[  176.602735] wlcore: acx slot
[  176.602743] wlcore: cmd configure (5), TSFL 1419f5d
[  176.603626] wlcore: Reading control info
[  176.603711] wlcore: Processing message type 2, len 4
[  176.603733] wlcore: CMD# 27, len=20
[  176.603746] wlcore: tx param cfg 0 cw_ming 15 cw_max 63 aifs 3 txop 0
[  176.603753] wlcore: tx param cfg ps_scheme 0 is_mu_edca 0 mu_edca_aifs 0 mu_edca_ecw_min_max 0 mu_edca_timer 0
[  176.603761] wlcore: cmd configure (1), TSFL 141a341
[  176.604422] wlcore: Reading control info
[  176.604621] wlcore: Processing message type 2, len 4
[  176.604970] wlcore: CMD# 27, len=32
[  176.604984] wlcore: tx param cfg 1 cw_ming 15 cw_max 63 aifs 7 txop 0
[  176.604991] wlcore: tx param cfg ps_scheme 0 is_mu_edca 0 mu_edca_aifs 0 mu_edca_ecw_min_max 0 mu_edca_timer 0
[  176.604998] wlcore: cmd configure (1), TSFL 141a658
[  176.605650] wlcore: Reading control info
[  176.605724] wlcore: Processing message type 2, len 4
[  176.605743] wlcore: CMD# 27, len=32
[  176.605753] wlcore: tx param cfg 2 cw_ming 15 cw_max 63 aifs 1 txop 3008
[  176.605759] wlcore: tx param cfg ps_scheme 0 is_mu_edca 0 mu_edca_aifs 0 mu_edca_ecw_min_max 0 mu_edca_timer 0
[  176.605767] wlcore: cmd configure (1), TSFL 141ab23
[  176.606406] wlcore: Reading control info
[  176.606599] wlcore: Processing message type 2, len 4
[  176.606946] wlcore: CMD# 27, len=32
[  176.606959] wlcore: tx param cfg 3 cw_ming 15 cw_max 63 aifs 1 txop 1504
[  176.606965] wlcore: tx param cfg ps_scheme 0 is_mu_edca 0 mu_edca_aifs 0 mu_edca_ecw_min_max 0 mu_edca_timer 0
[  176.606973] wlcore: cmd configure (1), TSFL 141ae17
[  176.607634] wlcore: Reading control info
[  176.607714] wlcore: Processing message type 2, len 4
[  176.607995] wlcore: CMD# 27, len=32
[  176.608012] wlcore: mac80211 bss info role 0 changed 0xe
[  176.608019] wlcore: acx slot
[  176.608026] wlcore: cmd configure (5), TSFL 141b2e2
[  176.608697] wlcore: Reading control info
[  176.608774] wlcore: Processing message type 2, len 4
[  176.608790] wlcore: CMD# 27, len=20
[  176.608797] wlcore: acx_set_preamble
[  176.608804] wlcore: cmd configure (6), TSFL 141b70e
[  176.609294] wlcore: Reading control info
[  176.609380] wlcore: Processing message type 2, len 4
[  176.609833] wlcore: CMD# 27, len=20
[  176.609842] wlcore: acx_set_ctsprotect
[  176.609850] wlcore: cmd configure (0), TSFL 141b95f
[  176.610367] wlcore: Reading control info
[  176.610449] wlcore: Processing message type 2, len 4
[  176.610474] wlcore: CMD# 27, len=20
[  176.610492] wlcore: mac80211 conf tx 0
[  176.610500] wlcore: tx param cfg 3 cw_ming 15 cw_max 1023 aifs 2 txop 0
[  176.610506] wlcore: tx param cfg ps_scheme 0 is_mu_edca 0 mu_edca_aifs 0 mu_edca_ecw_min_max 0 mu_edca_timer 0
[  176.610513] wlcore: cmd configure (1), TSFL 141bd90
[  176.611172] wlcore: Reading control info
[  176.611253] wlcore: Processing message type 2, len 4
[  176.611277] wlcore: CMD# 27, len=32
[  176.611285] wlcore: mac80211 conf tx 1
[  176.611294] wlcore: tx param cfg 2 cw_ming 15 cw_max 1023 aifs 2 txop 0
[  176.611301] wlcore: tx param cfg ps_scheme 0 is_mu_edca 0 mu_edca_aifs 0 mu_edca_ecw_min_max 0 mu_edca_timer 0
[  176.611308] wlcore: cmd configure (1), TSFL 141c0b5
[  176.611937] wlcore: Reading control info
[  176.612050] wlcore: Processing message type 2, len 4
[  176.612071] wlcore: CMD# 27, len=32
[  176.612078] wlcore: mac80211 conf tx 2
[  176.612087] wlcore: tx param cfg 0 cw_ming 15 cw_max 1023 aifs 2 txop 0
[  176.612093] wlcore: tx param cfg ps_scheme 0 is_mu_edca 0 mu_edca_aifs 0 mu_edca_ecw_min_max 0 mu_edca_timer 0
[  176.612122] wlcore: cmd configure (1), TSFL 141c3b3
[  176.612762] wlcore: Reading control info
[  176.612847] wlcore: Processing message type 2, len 4
[  176.612877] wlcore: CMD# 27, len=32
[  176.612885] wlcore: mac80211 conf tx 3
[  176.612894] wlcore: tx param cfg 1 cw_ming 15 cw_max 1023 aifs 2 txop 0
[  176.612900] wlcore: tx param cfg ps_scheme 0 is_mu_edca 0 mu_edca_aifs 0 mu_edca_ecw_min_max 0 mu_edca_timer 0
[  176.612906] wlcore: cmd configure (1), TSFL 141c6ee
[  176.613538] wlcore: Reading control info
[  176.613622] wlcore: Processing message type 2, len 4
[  176.613651] wlcore: CMD# 27, len=32
[  176.613662] wlcore: mac80211 bss info role 0 changed 0x2000
[  176.613677] wlcore: mac80211 config psm off power 0 idle changed 0xffffff9f
[  176.613842] wlcore: mac80211 config psm off power 0 idle changed 0x10
[  176.613876] wlcore: mac80211 configure filter, FIF_ALLMULTI = 0
[  176.613882] wlcore: acx group address tbl
[  176.613889] wlcore: cmd configure (7), TSFL 141c9f4
[  176.614309] wlcore: Reading control info
[  176.614406] wlcore: Processing message type 2, len 4
[  176.614433] wlcore: CMD# 27, len=140
[  176.643834] wlcore: mac80211 configure filter, FIF_ALLMULTI = 0
[  176.643847] wlcore: acx group address tbl
[  176.643856] wlcore: cmd configure (7), TSFL 141ccf8
[  176.644464] wlcore: Reading control info
[  176.644684] wlcore: Processing message type 2, len 4
[  176.644708] wlcore: CMD# 27, len=140
[  176.650469] wlcore: mac80211 configure filter, FIF_ALLMULTI = 0
[  176.650481] wlcore: acx group address tbl
[  176.650488] wlcore: cmd configure (7), TSFL 14242c6
[  176.650931] wlcore: Reading control info
[  176.651972] wlcore: Processing message type 2, len 4
[  176.652004] wlcore: CMD# 27, len=140
  • Hi Dmitrii,
    Looks like you are pretty far along. However, I don't see any errors. I see from the github page this is using kernel 5.10, is this the same kernel version you are using? Did you apply the 5.10 backport patch as well?
  • Could you also share the errors you are getting when you issue scan command?
  • Yes, it's 5.10 kernel. I have apply this  patch, but only for driver files. I don't wont touch kernel because one image should works with a few radios. So I didn't touch /net/mac80211/mlme.c. May be you have driver like a folder or git just to unzip or git clone and compile it? It looks like I can miss something while extracting files from the patch. Example  what I'm looking for and how I keep drivers in folders away from the kernel.
  • [root@luckfox ko]# iw wlan0 scan
    BSS 1e:3c:d4:05:14:78(on wlan0)
            last seen: 2195.864s [boottime]
            TSF: 11393709130109 usec (131d, 20:55:09)
            freq: 2437
            beacon interval: 100 TUs
            capability: ESS Privacy ShortPreamble ShortSlotTime RadioMeasure (0x1431)
            signal: -59.00 dBm
            last seen: 648 ms ago
            Information elements from Probe Response frame:
            SSID: Personal-0AF
            Supported rates: 1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0
            DS Parameter set: channel 6
            Country: AR     Environment: bogus
                    Channels [1 - 13] @ 30 dBm
            TPC report: TX power: 21 dBm
            RM enabled capabilities:
                    Capabilities: 0x03 0x02 0x00 0x00 0x00
                            Link Measurement
                            Neighbor Report
                            Channel Load
                    Nonoperating Channel Max Measurement Duration: 0
                    Measurement Pilot Capability: 0
            ERP: NonERP_Present Use_Protection
            RSN:     * Version: 1
                     * Group cipher: CCMP
                     * Pairwise ciphers: CCMP
                     * Authentication suites: PSK
                     * Capabilities: 16-PTKSA-RC 1-GTKSA-RC (0x000c)
            WMM:     * Parameter version 1
                     * BE: CW 15-1023, AIFSN 3
                     * BK: CW 15-1023, AIFSN 7
                     * VI: CW 7-15, AIFSN 2, TXOP 3008 usec
                     * VO: CW 3-7, AIFSN 2, TXOP 1504 usec
            Extended supported rates: 24.0 36.0 48.0 54.0
            BSS Load:
                     * station count: 3
                     * channel utilisation: 87/255
                     * available admission capacity: 31250 [*32us]
            HT capabilities:
                    Capabilities: 0x41ed
                            RX LDPC
                            HT20
                            SM Power Save disabled
                            RX HT20 SGI
                            RX HT40 SGI
                            TX STBC
                            RX STBC 1-stream
                            Max AMSDU length: 3839 bytes
                            No DSSS/CCK HT40
                            40 MHz Intolerant
                    Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
                    Minimum RX AMPDU time spacing: No restriction (0x00)
                    HT TX/RX MCS rate indexes supported: 0-15
            HT operation:
                     * primary channel: 6
                     * secondary channel offset: no secondary
                     * STA channel width: 20 MHz
                     * RIFS: 0
                     * HT protection: nonmember
                     * non-GF present: 1
                     * OBSS non-GF present: 1
                     * dual beacon: 0
                     * dual CTS protection: 0
                     * STBC beacon: 0
                     * L-SIG TXOP Prot: 0
                     * PCO active: 0
                     * PCO phase: 0
            Extended capabilities:
                     * BSS Transition
                     * Operating Mode Notification
                     * Max Number Of MSDUs In A-MSDU is unlimited
            VHT capabilities:
                    VHT Capabilities (0x03197992):
                            Max MPDU length: 11454
                            Supported Channel Width: neither 160 nor 80+80
                            RX LDPC
                            TX STBC
                            SU Beamformer
                            SU Beamformee
                            MU Beamformer
                            MU Beamformee
                    VHT RX MCS set:
                            1 streams: MCS 0-9
                            2 streams: MCS 0-9
                            3 streams: not supported
                            4 streams: not supported
                            5 streams: not supported
                            6 streams: not supported
                            7 streams: not supported
                            8 streams: not supported
                    VHT RX highest supported: 216 Mbps
                    VHT TX MCS set:
                            1 streams: MCS 0-9
                            2 streams: MCS 0-9
                    VHT TX highest supported: 216 Mbps
                    VHT extended NSS: supported
            VHT operation:
                     * channel width: 0 (20 or 40 MHz)
                     * center freq segment 1: 0
                     * center freq segment 2: 0
                     * VHT basic MCS set: 0xfffa
            HE capabilities:
                    HE MAC Capabilities (0x08011e085800):
                            +HTC HE Supported
                            Trigger Frame MAC Padding Duration: 2
                            BSR
                            OM Control
                            OFDMA RA
                            Maximum A-MPDU Length Exponent: 3
                            UL 2x996-Tone RU
                            OM Control UL MU Data Disable RX
                    HE PHY Capabilities: (0x002f4ec96fc927de018f00):
                            Punctured Preamble RX: 15
                            LDPC Coding in Payload
                            NDP with 4x HE-LTF and 3.2us GI
                            STBC Tx <= 80MHz
                            STBC Rx <= 80MHz
                            Full Bandwidth UL MU-MIMO
                            DCM Max Constellation: 1
                            DCM Max Constellation Rx: 1
                            Rx HE MU PPDU from Non-AP STA
                            SU Beamformer
                            SU Beamformee
                            MU Beamformer
                            Beamformee STS <= 80Mhz: 3
                            Beamformee STS > 80Mhz: 3
                            Sounding Dimensions <= 80Mhz: 1
                            Sounding Dimensions > 80Mhz: 1
                            Ng = 16 SU Feedback
                            Ng = 16 MU Feedback
                            Codebook Size SU Feedback
                            Codebook Size MU Feedback
                            Triggered SU Beamforming Feedback
                            Partial Bandwidth Extended Range
                            Power Boost Factor ar
                            HE SU PPDU & HE PPDU 4x HE-LTF 0.8us GI
                            Max NC: 3
                            STBC Tx > 80MHz
                            STBC Rx > 80MHz
                            HE ER SU PPDU 4x HE-LTF 0.8us GI
                            Longer Than 16HE SIG-B OFDM Symbols
                            Non-Triggered CQI Feedback
                            TX 1024-QAM
                            RX 1024-QAM
            WPS:     * Version: 1.0
                     * Wi-Fi Protected Setup State: 2 (Configured)
                     * Response Type: 3 (AP)
                     * UUID: 13814000-1dd2-11b2-90d6-1c3cd4051472
                     * Manufacturer: huaweitec
                     * Model: WAP
                     * Model Number: 123
                     * Serial Number: 12345
                     * Primary Device Type: 6-0050f204-1
                     * Device name: huawei_ONT
                     * Config methods: PBC
                     * Version2: 2.0
    Scan give me more, but I cut it. All the same,
    dmesg, 110 sec - it's after ifip wlan0 - command. 2195 - ip wlan0 scan.
    [  110.385442] wlcore: mac80211 start
    [  110.385462] wlcore: mac80211 add interface type 2 mac 10:ca:bf:d5:8f:2e
    [  110.385474] wlcore: allocating hw queue base: 0
    [  110.385482] wlcore: cmd roles enabled: bitmap before: 0, ret=0
    [  110.385490] wlcore: cmd role enable, role type 0, addr = 10:ca:bf:d5:8f:2e
    [  110.386008] wlcore: Reading control info
    [  110.386749] wlcore: Processing message type 2, len 5
    [  110.386780] wlcore: CMD# 17, len=20
    [  110.386786] wlcore: complete role_id = 0
    [  110.386793] wlcore: acx sleep auth 2
    [  110.386802] wlcore: cmd configure (9), TSFL 2c57986
    [  110.387584] wlcore: Reading control info
    [  110.387663] wlcore: Processing message type 2, len 4
    [  110.387686] wlcore: CMD# 27, len=20
    [  110.387693] wlcore: acx group address tbl
    [  110.387698] wlcore: cmd configure (7), TSFL 2c57fb3
    [  110.388074] wlcore: Reading control info
    [  110.388407] wlcore: Processing message type 2, len 4
    [  110.388616] wlcore: CMD# 27, len=140
    [  110.388624] wlcore: acx beacon filter table
    [  110.388634] wlcore: cmd configure (18), TSFL 2c58197
    [  110.389071] wlcore: Reading control info
    [  110.389377] wlcore: Processing message type 2, len 4
    [  110.389561] wlcore: CMD# 27, len=120
    [  110.389571] wlcore: acx beacon filter opt enable=0
    [  110.389579] wlcore: cmd configure (17), TSFL 2c5857e
    [  110.389898] wlcore: Reading control info
    [  110.389966] wlcore: Processing message type 2, len 4
    [  110.389982] wlcore: CMD# 27, len=20
    [  110.389988] wlcore: acx slot
    [  110.389994] wlcore: cmd configure (5), TSFL 2c588b7
    [  110.390770] wlcore: Reading control info
    [  110.390846] wlcore: Processing message type 2, len 4
    [  110.390867] wlcore: CMD# 27, len=20
    [  110.390877] wlcore: tx param cfg 0 cw_ming 15 cw_max 63 aifs 3 txop 0
    [  110.390885] wlcore: tx param cfg ps_scheme 0 is_mu_edca 0 mu_edca_aifs 0 mu_edca_ecw_min_max 0 mu_edca_timer 0
    [  110.390891] wlcore: cmd configure (1), TSFL 2c58c23
    [  110.391647] wlcore: Reading control info
    [  110.391724] wlcore: Processing message type 2, len 4
    [  110.391742] wlcore: CMD# 27, len=32
    [  110.391754] wlcore: tx param cfg 1 cw_ming 15 cw_max 63 aifs 7 txop 0
    [  110.391760] wlcore: tx param cfg ps_scheme 0 is_mu_edca 0 mu_edca_aifs 0 mu_edca_ecw_min_max 0 mu_edca_timer 0
    [  110.391767] wlcore: cmd configure (1), TSFL 2c58f91
    [  110.392384] wlcore: Reading control info
    [  110.392609] wlcore: Processing message type 2, len 4
    [  110.392915] wlcore: CMD# 27, len=32
    [  110.392928] wlcore: tx param cfg 2 cw_ming 15 cw_max 63 aifs 1 txop 3008
    [  110.392936] wlcore: tx param cfg ps_scheme 0 is_mu_edca 0 mu_edca_aifs 0 mu_edca_ecw_min_max 0 mu_edca_timer 0
    [  110.392943] wlcore: cmd configure (1), TSFL 2c5926e
    [  110.393611] wlcore: Reading control info
    [  110.393685] wlcore: Processing message type 2, len 4
    [  110.393704] wlcore: CMD# 27, len=32
    [  110.393714] wlcore: tx param cfg 3 cw_ming 15 cw_max 63 aifs 1 txop 1504
    [  110.393720] wlcore: tx param cfg ps_scheme 0 is_mu_edca 0 mu_edca_aifs 0 mu_edca_ecw_min_max 0 mu_edca_timer 0
    [  110.393727] wlcore: cmd configure (1), TSFL 2c5973b
    [  110.394363] wlcore: Reading control info
    [  110.394546] wlcore: Processing message type 2, len 4
    [  110.394880] wlcore: CMD# 27, len=32
    [  110.394896] wlcore: mac80211 bss info role 0 changed 0xe
    [  110.394903] wlcore: acx slot
    [  110.394911] wlcore: cmd configure (5), TSFL 2c59a2b
    [  110.395423] wlcore: Reading control info
    [  110.395505] wlcore: Processing message type 2, len 4
    [  110.395920] wlcore: CMD# 27, len=20
    [  110.395929] wlcore: acx_set_preamble
    [  110.395935] wlcore: cmd configure (6), TSFL 2c59e4f
    [  110.396479] wlcore: Reading control info
    [  110.396555] wlcore: Processing message type 2, len 4
    [  110.396574] wlcore: CMD# 27, len=20
    [  110.396580] wlcore: acx_set_ctsprotect
    [  110.396586] wlcore: cmd configure (0), TSFL 2c5a271
    [  110.397072] wlcore: Reading control info
    [  110.397145] wlcore: Processing message type 2, len 4
    [  110.397409] wlcore: CMD# 27, len=20
    [  110.397428] wlcore: mac80211 conf tx 0
    [  110.397438] wlcore: tx param cfg 3 cw_ming 15 cw_max 1023 aifs 2 txop 0
    [  110.397444] wlcore: tx param cfg ps_scheme 0 is_mu_edca 0 mu_edca_aifs 0 mu_edca_ecw_min_max 0 mu_edca_timer 0
    [  110.397451] wlcore: cmd configure (1), TSFL 2c5a4bf
    [  110.398109] wlcore: Reading control info
    [  110.398186] wlcore: Processing message type 2, len 4
    [  110.398260] wlcore: CMD# 27, len=32
    [  110.398269] wlcore: mac80211 conf tx 1
    [  110.398277] wlcore: tx param cfg 2 cw_ming 15 cw_max 1023 aifs 2 txop 0
    [  110.398284] wlcore: tx param cfg ps_scheme 0 is_mu_edca 0 mu_edca_aifs 0 mu_edca_ecw_min_max 0 mu_edca_timer 0
    [  110.398291] wlcore: cmd configure (1), TSFL 2c5a8cc
    [  110.398923] wlcore: Reading control info
    [  110.399039] wlcore: Processing message type 2, len 4
    [  110.399082] wlcore: CMD# 27, len=32
    [  110.399089] wlcore: mac80211 conf tx 2
    [  110.399096] wlcore: tx param cfg 0 cw_ming 15 cw_max 1023 aifs 2 txop 0
    [  110.399103] wlcore: tx param cfg ps_scheme 0 is_mu_edca 0 mu_edca_aifs 0 mu_edca_ecw_min_max 0 mu_edca_timer 0
    [  110.399109] wlcore: cmd configure (1), TSFL 2c5abfd
    [  110.399735] wlcore: Reading control info
    [  110.399820] wlcore: Processing message type 2, len 4
    [  110.399844] wlcore: CMD# 27, len=32
    [  110.399853] wlcore: mac80211 conf tx 3
    [  110.399861] wlcore: tx param cfg 1 cw_ming 15 cw_max 1023 aifs 2 txop 0
    [  110.399867] wlcore: tx param cfg ps_scheme 0 is_mu_edca 0 mu_edca_aifs 0 mu_edca_ecw_min_max 0 mu_edca_timer 0
    [  110.399873] wlcore: cmd configure (1), TSFL 2c5af28
    [  110.400504] wlcore: Reading control info
    [  110.400583] wlcore: Processing message type 2, len 4
    [  110.400606] wlcore: CMD# 27, len=32
    [  110.400616] wlcore: mac80211 bss info role 0 changed 0x2000
    [  110.400631] wlcore: mac80211 config psm off power 0 idle changed 0xffffff9f
    [  110.400799] wlcore: mac80211 config psm off power 0 idle changed 0x10
    [  110.400832] wlcore: mac80211 configure filter, FIF_ALLMULTI = 0
    [  110.400838] wlcore: acx group address tbl
    [  110.400846] wlcore: cmd configure (7), TSFL 2c5b229
    [  110.401267] wlcore: Reading control info
    [  110.401374] wlcore: Processing message type 2, len 4
    [  110.401398] wlcore: CMD# 27, len=140
    [  110.431955] wlcore: mac80211 configure filter, FIF_ALLMULTI = 0
    [  110.431967] wlcore: acx group address tbl
    [  110.431975] wlcore: cmd configure (7), TSFL 2c5b525
    [  110.432618] wlcore: Reading control info
    [  110.432714] wlcore: Processing message type 2, len 4
    [  110.432736] wlcore: CMD# 27, len=140
    [  110.438476] wlcore: mac80211 configure filter, FIF_ALLMULTI = 0
    [  110.438487] wlcore: acx group address tbl
    [  110.438494] wlcore: cmd configure (7), TSFL 2c62fa1
    [  110.438942] wlcore: Reading control info
    [  110.439573] wlcore: Processing message type 2, len 4
    [  110.439603] wlcore: CMD# 27, len=140
    [ 2195.830774] wlcore: mac80211 hw scan
    [ 2195.830799] wlcore: n_pactive_ch = 1
    [ 2195.830812] wlcore: freq 2472, ch. 13, flags 0x112, power 20, min/max_dwell 25/60, NO-IR
    [ 2195.830818] wlcore: n_pactive_ch = 2
    [ 2195.830826] wlcore: freq 2467, ch. 12, flags 0x112, power 20, min/max_dwell 25/60, NO-IR
    [ 2195.830833] wlcore: freq 2437, ch. 6, flags 0x180, power 20, min/max_dwell 25/60
    [ 2195.830840] wlcore: freq 2412, ch. 1, flags 0x1a0, power 20, min/max_dwell 25/60
    [ 2195.830847] wlcore: freq 2462, ch. 11, flags 0x190, power 20, min/max_dwell 25/60
    [ 2195.830854] wlcore: freq 2422, ch. 3, flags 0x1a0, power 20, min/max_dwell 25/60
    [ 2195.830861] wlcore: freq 2432, ch. 5, flags 0x180, power 20, min/max_dwell 25/60
    [ 2195.830867] wlcore: freq 2442, ch. 7, flags 0x180, power 20, min/max_dwell 25/60
    [ 2195.830874] wlcore: freq 2452, ch. 9, flags 0x180, power 20, min/max_dwell 25/60
    [ 2195.830881] wlcore: freq 2417, ch. 2, flags 0x1a0, power 20, min/max_dwell 25/60
    [ 2195.830887] wlcore: freq 2427, ch. 4, flags 0x1a0, power 20, min/max_dwell 25/60
    [ 2195.830894] wlcore: freq 2447, ch. 8, flags 0x180, power 20, min/max_dwell 25/60
    [ 2195.830902] wlcore: freq 2457, ch. 10, flags 0x190, power 20, min/max_dwell 25/60
    [ 2195.830910] wlcore: 2.4GHz: active 11 passive 2
    [ 2195.830914] wlcore: 5GHz: active 0 passive 0
    [ 2195.830918] wlcore: DFS: 0
    [ 2195.830924] wlcore: build probe request scan_type 2
    [ 2195.844584] wlcore: Reading control info
    [ 2195.844660] wlcore: Processing message type 2, len 4
    [ 2195.844679] wlcore: CMD# 26, len=528
    [ 2195.846904] wlcore: Reading control info
    [ 2195.846977] wlcore: Processing message type 2, len 4
    [ 2195.846997] wlcore: CMD# 24, len=316
    [ 2196.508536] wlcore: Reading control info
    [ 2196.508615] wlcore: Processing message type 1, len 624
    [ 2196.508634] wlcore: MBOX vector: 0x100
    [ 2196.508641] wlcore: scan results: 17
    [ 2196.508659] wlcore: Scanning complete
    It just don't wont to connect to any network and give me no errors. I put the same wpasupplicant.conf that ones work fine for the AIC8800DC radio.
  • post the wpasupplicant.conf contents and the supplicant debug log
  • wpa_supplicant v2.10
    random: Trying to read entropy from /dev/random
    Successfully initialized wpa_supplicant
    Initializing interface 'wlan0' conf '/etc/wpa_supplicant.conf' driver 'default' ctrl_interface 'N/A' bridge 'N/A'
    Configuration file '/etc/wpa_supplicant.conf' -> '/etc/wpa_supplicant.conf'
    Reading configuration file '/etc/wpa_supplicant.conf'
    ctrl_interface='/var/run/wpa_supplicant'
    ap_scan=1
    Line: 4 - start of a new network block
    ssid - hexdump_ascii(len=7):
         4f 70 65 6e 57 72 74                              OpenWrt
    PSK (ASCII passphrase) - hexdump_ascii(len=9): [REMOVED]
    PSK (from passphrase) - hexdump(len=32): [REMOVED]
    Priority group 0
       id=0 ssid='OpenWrt'
    nl80211: Supported cipher 00-0f-ac:4
    nl80211: Supported cipher 00-0f-ac:6
    nl80211: Supported cipher 00-0f-ac:2
    nl80211: Supported cipher 00-0f-ac:8
    nl80211: Supported cipher 00-0f-ac:9
    nl80211: Supported cipher 00-0f-ac:11
    nl80211: Supported cipher 00-0f-ac:12
    nl80211: Using driver-based off-channel TX
    nl80211: Driver-advertised extended capabilities (default) - hexdump(len=8): 04 00 40 00 00 00 00 40
    nl80211: Driver-advertised extended capabilities mask (default) - hexdump(len=8): 04 00 40 00 00 00 00 40
    nl80211: Driver-advertised extended capabilities for interface type STATION
    nl80211: Extended capabilities - hexdump(len=10): 04 00 40 00 00 00 00 40 00 20
    nl80211: Extended capabilities mask - hexdump(len=10): 04 00 40 00 00 00 00 40 00 20
    nl80211: Use separate P2P group interface (driver advertised support)
    nl80211: Enable multi-channel concurrent (driver advertised support)
    nl80211: use P2P_DEVICE support
    nl80211: key_mgmt=0x1ff0f enc=0x76c auth=0x7 flags=0x40005107303fae0 rrm_flags=0x10 probe_resp_offloads=0x0 max_stations=0 max_remain_on_chan=30000 max_scan_ssids=1
    nl80211: interface wlan0 in phy phy0
    nl80211: Set mode ifindex 3 iftype 2 (STATION)
    nl80211: Subscribe to mgmt frames with non-AP handle 0x60ab00
    nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x60ab00 match=0104 multicast=0
    nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x60ab00 match=040a multicast=0
    nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x60ab00 match=040b multicast=0
    nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x60ab00 match=040c multicast=0
    nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x60ab00 match=040d multicast=0
    nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x60ab00 match=090a multicast=0
    nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x60ab00 match=090b multicast=0
    nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x60ab00 match=090c multicast=0
    nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x60ab00 match=090d multicast=0
    nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x60ab00 match=0409506f9a1a multicast=0
    nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x60ab00 match=0801 multicast=0
    nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x60ab00 match=06 multicast=0
    nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x60ab00 match=0a07 multicast=0
    nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x60ab00 match=0a11 multicast=0
    nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x60ab00 match=0a1a multicast=0
    nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x60ab00 match=1101 multicast=0
    nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x60ab00 match=1102 multicast=0
    nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x60ab00 match=0505 multicast=0
    nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x60ab00 match=0500 multicast=0
    nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x60ab00 match=1301 multicast=0
    nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x60ab00 match=1305 multicast=0
    nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x60ab00 match=7e506f9a1a multicast=0
    rfkill: initial event: idx=2 type=1 op=0 soft=0 hard=0
    netlink: Operstate: ifindex=3 linkmode=1 (userspace-control), operstate=5 (IF_OPER_DORMANT)
    Add interface wlan0 to a new radio phy0
    nl80211: Regulatory information - country=00
    nl80211: 2402-2472 @ 40 MHz 20 mBm
    nl80211: 2457-2482 @ 20 MHz 20 mBm (no IR)
    nl80211: 2474-2494 @ 20 MHz 20 mBm (no OFDM) (no IR)
    nl80211: 5170-5250 @ 80 MHz 20 mBm (no IR)
    nl80211: 5250-5330 @ 80 MHz 20 mBm (DFS) (no IR)
    nl80211: 5490-5730 @ 160 MHz 20 mBm (DFS) (no IR)
    nl80211: 5735-5835 @ 80 MHz 20 mBm (no IR)
    nl80211: 57240-63720 @ 2160 MHz 0 mBm
    nl80211: Added 802.11b mode based on 802.11g information
    nl80211: Mode IEEE 802.11g: 2437 2412 2462 2422 2432 2442 2452 2472[NO_IR] 2417 2427 2447 2457 2467[NO_IR]
    nl80211: Mode IEEE 802.11b: 2437 2412 2462 2422 2432 2442 2452 2472[NO_IR] 2417 2427 2447 2457 2467[NO_IR]
    wlan0: Own MAC address: 10:ca:bf:d5:8f:2e
    wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=0 set_tx=0 seq_len=0 key_len=0 key_flag=0x10
    nl80211: DEL_KEY
       broadcast key
    wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0 key_flag=0x10
    nl80211: DEL_KEY
       broadcast key
    wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=2 set_tx=0 seq_len=0 key_len=0 key_flag=0x10
    nl80211: DEL_KEY
       broadcast key
    wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=3 set_tx=0 seq_len=0 key_len=0 key_flag=0x10
    nl80211: DEL_KEY
       broadcast key
    wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=4 set_tx=0 seq_len=0 key_len=0 key_flag=0x10
    nl80211: DEL_KEY
       broadcast key
    wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=5 set_tx=0 seq_len=0 key_len=0 key_flag=0x10
    nl80211: DEL_KEY
       broadcast key
    wlan0: RSN: flushing PMKID list in the driver
    nl80211: Flush PMKIDs
    TDLS: TDLS operation not supported by driver
    TDLS: Driver uses internal link setup
    TDLS: Driver does not support TDLS channel switching
    wlan0: WPS: UUID based on MAC address: edfd77e7-6c06-5ec1-b30e-bf51052ce04e
    EAPOL: SUPP_PAE entering state DISCONNECTED
    EAPOL: Supplicant port status: Unauthorized
    nl80211: Skip set_supp_port(unauthorized) while not associated
    EAPOL: KEY_RX entering state NO_KEY_RECEIVE
    EAPOL: SUPP_BE entering state INITIALIZE
    EAP: EAP entering state DISABLED
    wlan0: Added interface wlan0
    wlan0: State: DISCONNECTED -> DISCONNECTED
    nl80211: Set wlan0 operstate 0->0 (DORMANT)
    netlink: Operstate: ifindex=3 linkmode=-1 (no change), operstate=5 (IF_OPER_DORMANT)
    random: Got 20/20 bytes from /dev/random
    RTM_NEWLINK: ifi_index=3 ifname=wlan0 operstate=2 linkmode=1 ifi_family=0 ifi_flags=0x1003 ([UP])
    wlan0: Starting delayed sched scan
    wlan0: Use normal scan instead of sched_scan for initial scans (normal_scans=0)
    wlan0: Setting scan request: 0.000000 sec
    wlan0: State: DISCONNECTED -> SCANNING
    wlan0: Starting AP scan for wildcard SSID
    wlan0: Add radio work 'scan'@0x6210f0
    wlan0: First radio work item in the queue - schedule start immediately
    wlan0: Starting radio work 'scan'@0x6210f0 after 0.000073 second wait
    wlan0: nl80211: scan request
    nl80211: Scan SSID
    nl80211: Scan extra IEs - hexdump(len=13): 7f 0b 04 00 40 00 01 00 40 40 00 20 20
    Scan requested (ret=0) - scan timeout 10 seconds
    nl80211: Event message available
    nl80211: Drv Event 33 (NL80211_CMD_TRIGGER_SCAN) received for wlan0
    wlan0: nl80211: Scan trigger
    wlan0: Event SCAN_STARTED (47) received
    wlan0: Own scan request started a scan in 0.000798 seconds
    nl80211: Drv Event 34 (NL80211_CMD_NEW_SCAN_RESULTS) received for wlan0
    wlan0: nl80211: New scan results available
    nl80211: Scan probed for SSID ''
    nl80211: Scan included frequencies: 2437 2412 2462 2422 2432 2442 2452 2472 2417 2427 2447 2457 2467
    wlan0: Event SCAN_RESULTS (3) received
    wlan0: Scan completed in 0.657707 seconds
    nl80211: Received scan results (12 BSSes)
    wlan0: BSS: Start scan result update 1
    wlan0: BSS: Add new id 0 BSSID d8:ec:5e:7e:a9:33 SSID 'OpenWrt' freq 2437
    wlan0: BSS: Add new id 1 BSSID 1e:3c:d4:05:14:78 SSID 'Personal-0AF' freq 2412
    wlan0: BSS: Add new id 2 BSSID 56:f6:e2:64:f0:6c SSID 'Personal-230' freq 2462
    wlan0: BSS: Add new id 3 BSSID 60:83:e7:61:96:53 SSID 'TP-Link_9653' freq 2452
    wlan0: BSS: Add new id 4 BSSID 62:83:e7:11:96:53 SSID '' freq 2452
    wlan0: BSS: Add new id 5 BSSID d8:d7:75:78:e1:36 SSID 'Crisanta - 2.4GHz' freq 2412
    wlan0: BSS: Add new id 6 BSSID 56:f6:e2:64:f0:6d SSID 'Personal-230-2.4GHz' freq 2462
    wlan0: BSS: Add new id 7 BSSID a8:6a:bb:d9:5d:52 SSID 'Telecentro-5d4d' freq 2442
    wlan0: BSS: Add new id 8 BSSID 84:93:b2:5a:19:1e SSID 'IPLAN-GAUNA-2.4Ghz' freq 2432
    wlan0: BSS: Add new id 9 BSSID b0:92:4a:a4:74:d4 SSID 'Telecentro-74d3' freq 2447
    wlan0: BSS: Add new id 10 BSSID 1e:3c:d4:05:14:7b SSID 'Personal Wifi Zone' freq 2412
    wlan0: BSS: Add new id 11 BSSID 56:f6:e2:64:f0:6f SSID 'Personal Wifi Zone' freq 2462
    BSS: last_scan_res_used=12/32
    wlan0: New scan results available (own=1 ext=0)
    WPS: AP 1e:3c:d4:05:14:78 type 0 added
    WPS: AP 56:f6:e2:64:f0:6c type 0 added
    WPS: AP d8:d7:75:78:e1:36 type 0 added
    WPS: AP 84:93:b2:5a:19:1e type 0 added
    WPS: AP[0] 1e:3c:d4:05:14:78 type=0 tries=0 last_attempt=-1 sec ago bssid_ignore=0
    WPS: AP[1] 56:f6:e2:64:f0:6c type=0 tries=0 last_attempt=-1 sec ago bssid_ignore=0
    WPS: AP[2] d8:d7:75:78:e1:36 type=0 tries=0 last_attempt=-1 sec ago bssid_ignore=0
    WPS: AP[3] 84:93:b2:5a:19:1e type=0 tries=0 last_attempt=-1 sec ago bssid_ignore=0
    wlan0: Radio work 'scan'@0x6210f0 done in 0.680632 seconds
    wlan0: radio_work_free('scan'@0x6210f0): num_active_works --> 0
    wlan0: Selecting BSS from priority group 0
    wlan0: 0: d8:ec:5e:7e:a9:33 ssid='OpenWrt' wpa_ie_len=0 rsn_ie_len=20 caps=0x431 level=-42 freq=2437
    wlan0:    selected based on RSN IE
    wlan0:    selected BSS d8:ec:5e:7e:a9:33 ssid='OpenWrt'
    wlan0: Considering connect request: reassociate: 0  selected: d8:ec:5e:7e:a9:33  bssid: 00:00:00:00:00:00  pending: 00:00:00:00:00:00  wpa_state: SCANNING  ssid=0x60bb50  current_ssid=(nil)
    wlan0: Request association with d8:ec:5e:7e:a9:33
    SAE-PK: Not a valid password (length)
    TDLS: TDLS is allowed in the target BSS
    TDLS: TDLS channel switch allowed in the target BSS
    wlan0: No ongoing scan/p2p-scan found to abort
    wlan0: Add radio work 'sme-connect'@0x6210f0
    wlan0: Starting radio work 'sme-connect'@0x6210f0 after 0.000103 second wait
    wlan0: WPA: clearing own WPA/RSN IE
    wlan0: RSN: clearing own RSNXE
    wlan0: Automatic auth_alg selection: 0x1
    RSN: PMKSA cache search - network_ctx=(nil) try_opportunistic=0 akmp=0x0
    RSN: Search for BSSID d8:ec:5e:7e:a9:33
    RSN: No PMKSA cache entry found
    wlan0: RSN: using IEEE 802.11i/D9.0
    wlan0: WPA: Selected cipher suites: group 16 pairwise 16 key_mgmt 2 proto 2
    wlan0: WPA: Selected mgmt group cipher 32
    wlan0: WPA: clearing AP WPA IE
    WPA: set AP RSN IE - hexdump(len=22): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 0c 00
    wlan0: WPA: clearing AP RSNXE
    wlan0: WPA: AP group 0x10 network profile group 0x18; available group 0x10
    wlan0: WPA: using GTK CCMP
    wlan0: WPA: AP pairwise 0x10 network profile pairwise 0x18; available pairwise 0x10
    wlan0: WPA: using PTK CCMP
    wlan0: WPA: AP key_mgmt 0x2 network profile key_mgmt 0x3; available key_mgmt 0x2
    wlan0: WPA: using KEY_MGMT WPA-PSK
    wlan0: WPA: AP mgmt_group_cipher 0x20 network profile mgmt_group_cipher 0x0; available mgmt_group_cipher 0x0
    wlan0: WPA: not using MGMT group cipher
    WPA: Set own WPA IE default - hexdump(len=22): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 00 00
    RSN: Set own RSNXE default - hexdump(len=0):
    PSK (set in config) - hexdump(len=32): [REMOVED]
    WPA: Set PMK based on external data - hexdump(len=32): [REMOVED]
    RRM: Determining whether RRM can be used - device support: 0x10
    RRM: No RRM in network
    Added supported operating classes IE - hexdump(len=4): 3b 02 51 51
    EAPOL: External notification - EAP success=0
    EAPOL: External notification - EAP fail=0
    EAPOL: External notification - portControl=Auto
    wlan0: Cancelling scan request
    wlan0: SME: Trying to authenticate with d8:ec:5e:7e:a9:33 (SSID='OpenWrt' freq=2437 MHz)
    EAPOL: External notification - portValid=0
    wlan0: State: SCANNING -> AUTHENTICATING
    Not configuring frame filtering - BSS 00:00:00:00:00:00 is not a Hotspot 2.0 network
    nl80211: Authenticate (ifindex=3)
      * bssid=d8:ec:5e:7e:a9:33
      * freq=2437
      * SSID=OpenWrt
      * IEs - hexdump(len=0): [NULL]
      * Auth Type 0
    nl80211: Authentication request send successfully
    nl80211: Drv Event 19 (NL80211_CMD_NEW_STATION) received for wlan0
    nl80211: New station d8:ec:5e:7e:a9:33
    nl80211: Drv Event 37 (NL80211_CMD_AUTHENTICATE) received for wlan0
    nl80211: MLME event 37 (NL80211_CMD_AUTHENTICATE) on wlan0(10:ca:bf:d5:8f:2e) A1=10:ca:bf:d5:8f:2e A2=d8:ec:5e:7e:a9:33
    nl80211: MLME event frame - hexdump(len=30): b0 00 3c 00 10 ca bf d5 8f 2e d8 ec 5e 7e a9 33 d8 ec 5e 7e a9 33 60 bf 00 00 02 00 00 00
    nl80211: Authenticate event
    wlan0: Event AUTH (10) received
    wlan0: SME: Authentication response: peer=d8:ec:5e:7e:a9:33 auth_type=0 auth_transaction=2 status_code=0
    SME: Authentication response IEs - hexdump(len=0): [NULL]
    SME: Association Request IEs - hexdump(len=39): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 00 00 7f 0b 04 00 40 00 01 00 40 40 00 20 20 3b 02 51 51
    wlan0: Trying to associate with d8:ec:5e:7e:a9:33 (SSID='OpenWrt' freq=2437 MHz)
    wlan0: State: AUTHENTICATING -> ASSOCIATING
    WPA: set own WPA/RSN IE - hexdump(len=22): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 00 00
    nl80211: Associate (ifindex=3)
      * freq=2437
      * SSID=OpenWrt
      * IEs - hexdump(len=39): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 00 00 7f 0b 04 00 40 00 01 00 40 40 00 20 20 3b 02 51 51
      * WPA Versions 0x2
      * pairwise=0xfac04
      * group=0xfac04
      * akm=0xfac02
    nl80211: Association request send successfully
    nl80211: BSS Event 129 (NL80211_CMD_CONTROL_PORT_FRAME) received for wlan0
    wlan0: Event EAPOL_RX (23) received
    wlan0: RX EAPOL from d8:ec:5e:7e:a9:33
    RX EAPOL - hexdump(len=99): 02 03 00 5f 02 00 8a 00 10 00 00 00 00 00 00 00 01 2f c1 49 a2 50 75 55 67 e2 8e 34 ad 8c b9 9e 4e 08 af dd 37 45 16 1b 7b fc 7c df 82 78 8e 9f b4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    wlan0: Not associated - Delay processing of received EAPOL frame (state=ASSOCIATING bssid=00:00:00:00:00:00)
    RTM_NEWLINK: ifi_index=3 ifname=wlan0 operstate=5 linkmode=1 ifi_family=0 ifi_flags=0x11003 ([UP][LOWER_UP])
    nl80211: Drv Event 38 (NL80211_CMD_ASSOCIATE) received for wlan0
    nl80211: MLME event 38 (NL80211_CMD_ASSOCIATE) on wlan0(10:ca:bf:d5:8f:2e) A1=10:ca:bf:d5:8f:2e A2=d8:ec:5e:7e:a9:33
    nl80211: MLME event frame - hexdump(len=210): 10 00 3c 00 10 ca bf d5 8f 2e d8 ec 5e 7e a9 33 d8 ec 5e 7e a9 33 00 00 31 04 00 00 02 c0 01 08 8c 12 98 24 b0 48 60 6c 2d 1a ef 11 03 ff ff ff ff 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 3d 16 06 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ff 1d 23 0d 00 18 9a 40 10 02 60 4c 88 7f c3 83 9c 01 0c 00 aa ff aa ff 1b 1c c7 71 1c c7 71 ff 07 24 f4 3f 00 28 fc ff ff 02 27 03 ff 0e 26 00 08 a9 ff 2f a9 ff 45 75 ff 65 75 ff 7f 0a 04 00 00 00 01 00 01 40 00 40 6e 12 00 00 02 10 01 01 ff ff 12 16 18 26 28 28 2c 2e 30 38 dd 18 00 50 f2 02 01 01 81 00 03 a4 00 00 27 a4 00 00 42 43 5e 00 62 32 2f 00
    nl80211: Associate event
    nl80211: Associated on 2437 MHz
    nl80211: Associated with d8:ec:5e:7e:a9:33
    nl80211: Set drv->ssid based on scan res info to 'OpenWrt'
    wlan0: Event ASSOC (0) received
    wlan0: Association info event
    req_ies - hexdump(len=119): 00 07 4f 70 65 6e 57 72 74 01 08 0c 12 18 24 30 48 60 6c 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 00 00 2d 1a 2c 08 1c ff 00 00 00 00 00 00 00 00 00 48 00 01 00 00 00 00 00 00 00 00 00 00 7f 0b 04 00 40 00 01 00 40 40 00 20 20 ff 16 23 03 78 ae 82 d0 80 00 50 02 18 0d c0 3f 04 13 b2 00 fc ff fc ff 3b 02 51 51 dd 07 00 50 f2 02 00 01 00
    resp_ies - hexdump(len=180): 01 08 8c 12 98 24 b0 48 60 6c 2d 1a ef 11 03 ff ff ff ff 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 3d 16 06 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ff 1d 23 0d 00 18 9a 40 10 02 60 4c 88 7f c3 83 9c 01 0c 00 aa ff aa ff 1b 1c c7 71 1c c7 71 ff 07 24 f4 3f 00 28 fc ff ff 02 27 03 ff 0e 26 00 08 a9 ff 2f a9 ff 45 75 ff 65 75 ff 7f 0a 04 00 00 00 01 00 01 40 00 40 6e 12 00 00 02 10 01 01 ff ff 12 16 18 26 28 28 2c 2e 30 38 dd 18 00 50 f2 02 01 01 81 00 03 a4 00 00 27 a4 00 00 42 43 5e 00 62 32 2f 00
    IEEE 802.11 element parsing ignored unknown element extension (ext_id=39 elen=1)
    IEEE 802.11 element parsing ignored unknown element extension (ext_id=38 elen=13)
    Interworking: QoS Map Set - hexdump(len=18): 00 00 02 10 01 01 ff ff 12 16 18 26 28 28 2c 2e 30 38
    nl80211: Setting QoS Map - hexdump(len=18): 00 00 02 10 01 01 ff ff 12 16 18 26 28 28 2c 2e 30 38
    wlan0: freq=2437 MHz
    wlan0: State: ASSOCIATING -> ASSOCIATED
    wlan0: Associated to a new BSS: BSSID=d8:ec:5e:7e:a9:33
    wlan0: Associated with d8:ec:5e:7e:a9:33
    wlan0: WPA: Association event - clear replay counter
    wlan0: WPA: Clear old PTK
    TDLS: Remove peers on association
    EAPOL: External notification - portEnabled=0
    EAPOL: External notification - portEnabled=1
    EAPOL: SUPP_PAE entering state CONNECTING
    EAPOL: SUPP_BE entering state IDLE
    wlan0: Setting authentication timeout: 10 sec 0 usec
    wlan0: Process pending EAPOL frame that was received just before association notification
    wlan0: IEEE 802.1X RX: version=2 type=3 length=95
    WPA: RX EAPOL-Key - hexdump(len=99): 02 03 00 5f 02 00 8a 00 10 00 00 00 00 00 00 00 01 2f c1 49 a2 50 75 55 67 e2 8e 34 ad 8c b9 9e 4e 08 af dd 37 45 16 1b 7b fc 7c df 82 78 8e 9f b4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    wlan0:   EAPOL-Key type=2
    wlan0:   key_info 0x8a (ver=2 keyidx=0 rsvd=0 Pairwise Ack)
    wlan0:   key_length=16 key_data_length=0
      replay_counter - hexdump(len=8): 00 00 00 00 00 00 00 01
      key_nonce - hexdump(len=32): 2f c1 49 a2 50 75 55 67 e2 8e 34 ad 8c b9 9e 4e 08 af dd 37 45 16 1b 7b fc 7c df 82 78 8e 9f b4
      key_iv - hexdump(len=16): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
      key_rsc - hexdump(len=8): 00 00 00 00 00 00 00 00
      key_id (reserved) - hexdump(len=8): 00 00 00 00 00 00 00 00
      key_mic - hexdump(len=16): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    wlan0: State: ASSOCIATED -> 4WAY_HANDSHAKE
    wlan0: WPA: RX message 1 of 4-Way Handshake from d8:ec:5e:7e:a9:33 (ver=2)
    RSN: msg 1/4 key data - hexdump(len=0):
    Get randomness: len=32 entropy=11
    WPA: Renewed SNonce - hexdump(len=32): 6e 05 59 7e e4 b9 50 98 54 09 9c 57 31 a5 8a e8 0e f0 11 ce 86 68 a0 6a e6 cb 70 95 1e 1a e3 62
    WPA: PTK derivation using PRF(SHA1)
    WPA: PTK derivation - A1=10:ca:bf:d5:8f:2e A2=d8:ec:5e:7e:a9:33
    WPA: Nonce1 - hexdump(len=32): 6e 05 59 7e e4 b9 50 98 54 09 9c 57 31 a5 8a e8 0e f0 11 ce 86 68 a0 6a e6 cb 70 95 1e 1a e3 62
    WPA: Nonce2 - hexdump(len=32): 2f c1 49 a2 50 75 55 67 e2 8e 34 ad 8c b9 9e 4e 08 af dd 37 45 16 1b 7b fc 7c df 82 78 8e 9f b4
    WPA: PMK - hexdump(len=32): [REMOVED]
    WPA: PTK - hexdump(len=48): [REMOVED]
    WPA: KCK - hexdump(len=16): [REMOVED]
    WPA: KEK - hexdump(len=16): [REMOVED]
    WPA: TK - hexdump(len=16): [REMOVED]
    WPA: WPA IE for msg 2/4 - hexdump(len=22): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 00 00
    WPA: Replay Counter - hexdump(len=8): 00 00 00 00 00 00 00 01
    wlan0: WPA: Sending EAPOL-Key 2/4
    WPA: Send EAPOL-Key frame to d8:ec:5e:7e:a9:33 ver=2 mic_len=16 key_mgmt=0x2
    WPA: EAPOL-Key MIC using HMAC-SHA1
    WPA: Derived Key MIC - hexdump(len=16): 52 55 d4 8f cc 9b 3e 0c bc 30 78 b5 a5 48 0a b7
    WPA: TX EAPOL-Key - hexdump(len=121): 01 03 00 75 02 01 0a 00 00 00 00 00 00 00 00 00 01 6e 05 59 7e e4 b9 50 98 54 09 9c 57 31 a5 8a e8 0e f0 11 ce 86 68 a0 6a e6 cb 70 95 1e 1a e3 62 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 52 55 d4 8f cc 9b 3e 0c bc 30 78 b5 a5 48 0a b7 00 16 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 00 00
    nl80211: Send over control port dest=d8:ec:5e:7e:a9:33 proto=0x888e len=121 no_encrypt=1
    nl80211: tx_control_port cookie=0x7
    WMM AC: AC mandatory: AC_BE=0 AC_BK=0 AC_VI=0 AC_VO=0
    WMM AC: U-APSD queues=0x0
    WMM AC: Valid WMM association, WMM AC is enabled
    wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
    nl80211: Drv Event 46 (NL80211_CMD_CONNECT) received for wlan0
    nl80211: Ignore connect event (cmd=46) when using userspace SME
    nl80211: Drv Event 139 (NL80211_CMD_CONTROL_PORT_FRAME_TX_STATUS) received for wlan0
    nl80211: Control port TX status (ack=1), cookie=7
    wlan0: Event EAPOL_TX_STATUS (37) received
    wlan0: Unknown event 37
    RX EAPOL - hexdump(len=155): 02 03 00 97 02 13 ca 00 10 00 00 00 00 00 00 00 02 2f c1 49 a2 50 75 55 67 e2 8e 34 ad 8c b9 9e 4e 08 af dd 37 45 16 1b 7b fc 7c df 82 78 8e 9f b4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 e1 9b 71 83 b9 88 85 d6 4f 2b d2 14 6b 08 2a a6 00 38 95 2e e4 3f a9 8c 50 2e 7c ea 73 6b 51 ac a7 3e 67 a0 a1 82 0d 1b fe a5 29 21 a5 d7 44 8d 35 37 33 bf 51 16 86 c9 73 98 0c 91 66 ca 57 ea 7e e8 9f 18 16 19 0f 23 6e 02
    wlan0: IEEE 802.1X RX: version=2 type=3 length=151
    WPA: RX EAPOL-Key - hexdump(len=155): 02 03 00 97 02 13 ca 00 10 00 00 00 00 00 00 00 02 2f c1 49 a2 50 75 55 67 e2 8e 34 ad 8c b9 9e 4e 08 af dd 37 45 16 1b 7b fc 7c df 82 78 8e 9f b4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 e1 9b 71 83 b9 88 85 d6 4f 2b d2 14 6b 08 2a a6 00 38 95 2e e4 3f a9 8c 50 2e 7c ea 73 6b 51 ac a7 3e 67 a0 a1 82 0d 1b fe a5 29 21 a5 d7 44 8d 35 37 33 bf 51 16 86 c9 73 98 0c 91 66 ca 57 ea 7e e8 9f 18 16 19 0f 23 6e 02
    wlan0:   key_info 0x13ca (ver=2 keyidx=0 rsvd=0 Pairwise Install Ack MIC Secure Encr)
    wlan0:   key_length=16 key_data_length=56
      replay_counter - hexdump(len=8): 00 00 00 00 00 00 00 02
      key_mic - hexdump(len=16): e1 9b 71 83 b9 88 85 d6 4f 2b d2 14 6b 08 2a a6
    RSN: encrypted key data - hexdump(len=56): 95 2e e4 3f a9 8c 50 2e 7c ea 73 6b 51 ac a7 3e 67 a0 a1 82 0d 1b fe a5 29 21 a5 d7 44 8d 35 37 33 bf 51 16 86 c9 73 98 0c 91 66 ca 57 ea 7e e8 9f 18 16 19 0f 23 6e 02
    WPA: Decrypt Key Data using AES-UNWRAP (KEK length 16)
    WPA: decrypted EAPOL-Key key data - hexdump(len=48): [REMOVED]
    wlan0: State: 4WAY_HANDSHAKE -> 4WAY_HANDSHAKE
    wlan0: WPA: RX message 3 of 4-Way Handshake from d8:ec:5e:7e:a9:33 (ver=2)
    WPA: IE KeyData - hexdump(len=48): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 0c 00 dd 16 00 0f ac 01 02 00 d4 22 ab 57 5f a5 e9 10 66 0c 48 d2 1b d8 2a 21 dd 00
    WPA: RSN IE in EAPOL-Key - hexdump(len=22): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 0c 00
    WPA: GTK in EAPOL-Key - hexdump(len=24): [REMOVED]
    wlan0: WPA: Sending EAPOL-Key 4/4
    WPA: Derived Key MIC - hexdump(len=16): 09 6d 0f b9 94 a3 7d 4d b1 55 81 cf e7 86 b3 06
    WPA: TX EAPOL-Key - hexdump(len=99): 01 03 00 5f 02 03 0a 00 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 09 6d 0f b9 94 a3 7d 4d b1 55 81 cf e7 86 b3 06 00 00
    nl80211: Send over control port dest=d8:ec:5e:7e:a9:33 proto=0x888e len=99 no_encrypt=1
    nl80211: tx_control_port cookie=0x8
    wlan0: WPA: Installing PTK to the driver
    wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=3 addr=0x60b7e4 key_idx=0 set_tx=1 seq_len=6 key_len=16 key_flag=0x2c
    nl80211: NEW_KEY
    nl80211: KEY_DATA - hexdump(len=16): [REMOVED]
    nl80211: KEY_SEQ - hexdump(len=6): 00 00 00 00 00 00
       addr=d8:ec:5e:7e:a9:33
       pairwise key
    nl80211: kernel reports: key addition failed
    nl80211: set_key failed; err=-2 No such file or directory
    wlan0: WPA: Failed to set PTK to the driver (alg=3 keylen=16 bssid=d8:ec:5e:7e:a9:33 idx=0 key_flag=0xc)
    wlan0: Request to deauthenticate - bssid=d8:ec:5e:7e:a9:33 pending_bssid=00:00:00:00:00:00 reason=1 (UNSPECIFIED) state=4WAY_HANDSHAKE
    TDLS: Tear down peers
    wpa_driver_nl80211_deauthenticate(addr=d8:ec:5e:7e:a9:33 reason_code=1)
    wlan0: Event DEAUTH (11) received
    wlan0: Deauthentication notification
    wlan0:  * reason 1 (UNSPECIFIED) locally_generated=1
    Deauthentication frame IE(s) - hexdump(len=0): [NULL]
    wlan0: CTRL-EVENT-DISCONNECTED bssid=d8:ec:5e:7e:a9:33 reason=1 locally_generated=1
    wlan0: WPA: 4-Way Handshake failed - pre-shared key may be incorrect
    wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="OpenWrt" auth_failures=1 duration=10 reason=WRONG_KEY
    wlan0: Auto connect enabled: try to reconnect (wps=0/0 wpa_state=7)
    wlan0: Setting scan request: 0.100000 sec
    wlan0: Radio work 'sme-connect'@0x6210f0 done in 0.224952 seconds
    wlan0: radio_work_free('sme-connect'@0x6210f0): num_active_works --> 0
    Added BSSID d8:ec:5e:7e:a9:33 into ignore list, ignoring for 10 seconds
    wlan0: Consecutive connection failures: 1 --> request scan in 100 ms
    wlan0: Ignore new scan request for 0.100000 sec since an earlier request is scheduled to trigger sooner
    TDLS: Remove peers on disassociation
    wlan0: WPA: Clear old PMK and PTK
    wlan0: Disconnect event - remove keys
    nl80211: DEL_KEY
       broadcast key
    wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=0x6099c0 key_idx=0 set_tx=0 seq_len=0 key_len=0 key_flag=0x20
    nl80211: DEL_KEY
       pairwise key
    nl80211: Data frame filter flags=0x0
    nl80211: Failed to open /proc/sys/net/ipv6/conf/wlan0/drop_unicast_in_l2_multicast: No such file or directory
    nl80211: Failed to open /proc/sys/net/ipv6/conf/wlan0/drop_unsolicited_na: No such file or directory
    wlan0: State: 4WAY_HANDSHAKE -> DISCONNECTED
    WMM AC: WMM AC is disabled
    QM: Clear all active DSCP policies
    wlan0: CTRL-EVENT-DSCP-POLICY clear_all
    wlan0: Ignore new scan request for 5.000000 sec since an earlier request is scheduled to trigger sooner
    nl80211: Control port TX status (ack=1), cookie=8
    nl80211: Drv Event 20 (NL80211_CMD_DEL_STATION) received for wlan0
    nl80211: Delete station d8:ec:5e:7e:a9:33
    nl80211: Drv Event 39 (NL80211_CMD_DEAUTHENTICATE) received for wlan0
    nl80211: MLME event 39 (NL80211_CMD_DEAUTHENTICATE) on wlan0(10:ca:bf:d5:8f:2e) A1=d8:ec:5e:7e:a9:33 A2=10:ca:bf:d5:8f:2e
    nl80211: MLME event frame - hexdump(len=26): c0 00 00 00 d8 ec 5e 7e a9 33 10 ca bf d5 8f 2e d8 ec 5e 7e a9 33 00 00 01 00
    nl80211: Deauthenticate event
    nl80211: Ignore deauth event triggered due to own deauth request
    nl80211: Drv Event 48 (NL80211_CMD_DISCONNECT) received for wlan0
    nl80211: Ignore disconnect event when using userspace SME
    nl80211: Drv Event 36 (NL80211_CMD_REG_CHANGE) received for wlan0
    nl80211: Regulatory domain change
     * initiator=0
     * type=1
    wlan0: Event CHANNEL_LIST_CHANGED (27) received
    wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
    wlan0: Updating hw mode
    wlan0: Add radio work 'scan'@0x620a10
    wlan0: Starting radio work 'scan'@0x620a10 after 0.000078 second wait
    nl80211: Scan SSID
    Scan requested (ret=0) - scan timeout 30 seconds
    wlan0: Own scan request started a scan in 0.000331 seconds
    wlan0: Scan completed in 0.653223 seconds
    wlan0: BSS: Start scan result update 2
    wlan0: Radio work 'scan'@0x620a10 done in 0.673421 seconds
    wlan0: radio_work_free('scan'@0x620a10): num_active_works --> 0
    wlan0: Postpone network selection by 9 seconds since all networks are disabled
    EAPOL: startWhen --> 0
    EAPOL: disable timer tick
    wlan0: Try to associate due to network getting re-enabled
    Fast associate: Old scan results
    wlan0: Starting radio work 'scan'@0x620a10 after 0.000083 second wait
    nl80211: Scan SSID
    wlan0: Own scan request started a scan in 0.000333 seconds
    wlan0: Scan completed in 0.565034 seconds
    nl80211: Received scan results (13 BSSes)
    wlan0: BSS: Start scan result update 3
    wlan0: BSS: Add new id 12 BSSID 46:05:3f:9b:f3:f6 SSID 'TeleCentro Wifi' freq 2447
    BSS: last_scan_res_used=13/32
    wlan0: Radio work 'scan'@0x620a10 done in 0.585801 seconds
    wlan0: CTRL-EVENT-SSID-REENABLED id=0 ssid="OpenWrt"
    wlan0: Re-association to the same ESS
    wlan0: Add radio work 'sme-connect'@0x620a10
    wlan0: Starting radio work 'sme-connect'@0x620a10 after 0.000105 second wait
      * freq=2437
      * SSID=OpenWrt
      * Auth Type 0
    nl80211: MLME event frame - hexdump(len=30): b0 00 3c 00 10 ca bf d5 8f 2e d8 ec 5e 7e a9 33 d8 ec 5e 7e a9 33 20 c0 00 00 02 00 00 00
      * freq=2437
      * SSID=OpenWrt
      * WPA Versions 0x2
      * pairwise=0xfac04
      * group=0xfac04
      * akm=0xfac02
    RX EAPOL - hexdump(len=99): 02 03 00 5f 02 00 8a 00 10 00 00 00 00 00 00 00 01 e8 52 d7 ce e3 9c 45 58 06 1a 7c d4 92 07 c5 0f 17 ce 54 9b ba b0 ac 37 07 d8 eb f6 0b 7b 38 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    EAPOL: enable timer tick
    WPA: RX EAPOL-Key - hexdump(len=99): 02 03 00 5f 02 00 8a 00 10 00 00 00 00 00 00 00 01 e8 52 d7 ce e3 9c 45 58 06 1a 7c d4 92 07 c5 0f 17 ce 54 9b ba b0 ac 37 07 d8 eb f6 0b 7b 38 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
      key_nonce - hexdump(len=32): e8 52 d7 ce e3 9c 45 58 06 1a 7c d4 92 07 c5 0f 17 ce 54 9b ba b0 ac 37 07 d8 eb f6 0b 7b 38 09
    Get randomness: len=32 entropy=21
    WPA: Renewed SNonce - hexdump(len=32): b4 c6 a7 91 27 ed 6d b3 13 58 63 57 ec fe 2f 96 04 62 1d db 48 56 7f ef 9d 06 c0 c0 cc b2 36 4d
    WPA: Nonce1 - hexdump(len=32): b4 c6 a7 91 27 ed 6d b3 13 58 63 57 ec fe 2f 96 04 62 1d db 48 56 7f ef 9d 06 c0 c0 cc b2 36 4d
    WPA: Nonce2 - hexdump(len=32): e8 52 d7 ce e3 9c 45 58 06 1a 7c d4 92 07 c5 0f 17 ce 54 9b ba b0 ac 37 07 d8 eb f6 0b 7b 38 09
    WPA: Derived Key MIC - hexdump(len=16): 85 6a ac fe 6c 97 e3 d3 b0 a4 8a d4 2d 14 8a 3d
    WPA: TX EAPOL-Key - hexdump(len=121): 01 03 00 75 02 01 0a 00 00 00 00 00 00 00 00 00 01 b4 c6 a7 91 27 ed 6d b3 13 58 63 57 ec fe 2f 96 04 62 1d db 48 56 7f ef 9d 06 c0 c0 cc b2 36 4d 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 85 6a ac fe 6c 97 e3 d3 b0 a4 8a d4 2d 14 8a 3d 00 16 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 00 00
    nl80211: tx_control_port cookie=0x9
    nl80211: Control port TX status (ack=1), cookie=9
    RX EAPOL - hexdump(len=155): 02 03 00 97 02 13 ca 00 10 00 00 00 00 00 00 00 02 e8 52 d7 ce e3 9c 45 58 06 1a 7c d4 92 07 c5 0f 17 ce 54 9b ba b0 ac 37 07 d8 eb f6 0b 7b 38 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 fe 71 2d db 43 35 cd a5 8a 17 2c ac bd c2 25 63 00 38 f1 2f 2a e9 31 b1 08 b9 b0 3c a5 13 ae 80 83 ce f3 03 c5 1e 6f 0f 39 39 9f 24 36 63 26 b9 40 a1 5c ca 1b a3 b7 c1 d0 aa 86 3d 9f 6c 21 3b f8 9d f7 0f b3 de b9 01 53 d0
    WPA: RX EAPOL-Key - hexdump(len=155): 02 03 00 97 02 13 ca 00 10 00 00 00 00 00 00 00 02 e8 52 d7 ce e3 9c 45 58 06 1a 7c d4 92 07 c5 0f 17 ce 54 9b ba b0 ac 37 07 d8 eb f6 0b 7b 38 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 fe 71 2d db 43 35 cd a5 8a 17 2c ac bd c2 25 63 00 38 f1 2f 2a e9 31 b1 08 b9 b0 3c a5 13 ae 80 83 ce f3 03 c5 1e 6f 0f 39 39 9f 24 36 63 26 b9 40 a1 5c ca 1b a3 b7 c1 d0 aa 86 3d 9f 6c 21 3b f8 9d f7 0f b3 de b9 01 53 d0
      key_mic - hexdump(len=16): fe 71 2d db 43 35 cd a5 8a 17 2c ac bd c2 25 63
    RSN: encrypted key data - hexdump(len=56): f1 2f 2a e9 31 b1 08 b9 b0 3c a5 13 ae 80 83 ce f3 03 c5 1e 6f 0f 39 39 9f 24 36 63 26 b9 40 a1 5c ca 1b a3 b7 c1 d0 aa 86 3d 9f 6c 21 3b f8 9d f7 0f b3 de b9 01 53 d0
    WPA: Derived Key MIC - hexdump(len=16): bc 9b 7b c2 ea de a0 10 66 b2 67 a1 de 62 3f f3
    WPA: TX EAPOL-Key - hexdump(len=99): 01 03 00 5f 02 03 0a 00 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 bc 9b 7b c2 ea de a0 10 66 b2 67 a1 de 62 3f f3 00 00
    nl80211: tx_control_port cookie=0xa
    nl80211: NEW_KEY
       pairwise key
    wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="OpenWrt" auth_failures=2 duration=35 reason=WRONG_KEY
    wlan0: Radio work 'sme-connect'@0x620a10 done in 0.181485 seconds
    wlan0: radio_work_free('sme-connect'@0x620a10): num_active_works --> 0
    BSSID d8:ec:5e:7e:a9:33 ignore list count incremented to 2, ignoring for 10 seconds
    wlan0: Consecutive connection failures: 2 --> request scan in 500 ms
    wlan0: Ignore new scan request for 0.500000 sec since an earlier request is scheduled to trigger sooner
    nl80211: DEL_KEY
       broadcast key
    nl80211: DEL_KEY
       pairwise key
    nl80211: Control port TX status (ack=1), cookie=10
     * initiator=0
     * type=1
    wlan0: Starting radio work 'scan'@0x620a10 after 0.000076 second wait
    nl80211: Scan SSID
    wlan0: Own scan request started a scan in 0.000833 seconds
    wlan0: Scan completed in 0.550595 seconds
    nl80211: Received scan results (14 BSSes)
    wlan0: BSS: Start scan result update 4
    wlan0: BSS: Add new id 13 BSSID 4a:83:c7:87:e8:c8 SSID 'TeleCentro Wifi' freq 2412
    BSS: last_scan_res_used=14/32
    wlan0: Radio work 'scan'@0x620a10 done in 0.572015 seconds
    wlan0: Postpone network selection by 34 seconds since all networks are disabled
    wlan0: Removing interface wlan0
    nl80211: Getting wowlan status
    nl80211: Getting wowlan status failed
    wlan0: Request to deauthenticate - bssid=00:00:00:00:00:00 pending_bssid=00:00:00:00:00:00 reason=3 (DEAUTH_LEAVING) state=SCANNING
    wlan0: State: SCANNING -> DISCONNECTED
    Removed BSSID d8:ec:5e:7e:a9:33 from ignore list (clear)
    wlan0: BSS: Remove id 0 BSSID d8:ec:5e:7e:a9:33 SSID 'OpenWrt' due to wpa_bss_flush
    wlan0: BSS: Remove id 2 BSSID 56:f6:e2:64:f0:6c SSID 'Personal-230' due to wpa_bss_flush
    wlan0: BSS: Remove id 6 BSSID 56:f6:e2:64:f0:6d SSID 'Personal-230-2.4GHz' due to wpa_bss_flush
    wlan0: BSS: Remove id 1 BSSID 1e:3c:d4:05:14:78 SSID 'Personal-0AF' due to wpa_bss_flush
    wlan0: BSS: Remove id 4 BSSID 62:83:e7:11:96:53 SSID '' due to wpa_bss_flush
    wlan0: BSS: Remove id 3 BSSID 60:83:e7:61:96:53 SSID 'TP-Link_9653' due to wpa_bss_flush
    wlan0: BSS: Remove id 5 BSSID d8:d7:75:78:e1:36 SSID 'Crisanta - 2.4GHz' due to wpa_bss_flush
    wlan0: BSS: Remove id 7 BSSID a8:6a:bb:d9:5d:52 SSID 'Telecentro-5d4d' due to wpa_bss_flush
    wlan0: BSS: Remove id 8 BSSID 84:93:b2:5a:19:1e SSID 'IPLAN-GAUNA-2.4Ghz' due to wpa_bss_flush
    wlan0: BSS: Remove id 9 BSSID b0:92:4a:a4:74:d4 SSID 'Telecentro-74d3' due to wpa_bss_flush
    wlan0: BSS: Remove id 11 BSSID 56:f6:e2:64:f0:6f SSID 'Personal Wifi Zone' due to wpa_bss_flush
    wlan0: BSS: Remove id 10 BSSID 1e:3c:d4:05:14:7b SSID 'Personal Wifi Zone' due to wpa_bss_flush
    wlan0: BSS: Remove id 13 BSSID 4a:83:c7:87:e8:c8 SSID 'TeleCentro Wifi' due to wpa_bss_flush
    wlan0: BSS: Remove id 12 BSSID 46:05:3f:9b:f3:f6 SSID 'TeleCentro Wifi' due to wpa_bss_flush
    wlan0: Cancelling delayed sched scan
    wlan0: Cancelling authentication timeout
    Off-channel: Clear pending Action frame TX (pending_action_tx=(nil)
    HS20: Delete all stored icons
    Off-channel: Action frame sequence done notification: pending_action_tx=(nil) drv_offchan_tx=1 action_tx_wait_time=0 off_channel_freq=0 roc_waiting_drv_freq=0
    Remove interface wlan0 from radio phy0
    Remove radio phy0
    nl80211: deinit ifname=wlan0 disabled_11b_rates=0
    nl80211: Remove monitor interface: refcount=0
    netlink: Operstate: ifindex=3 linkmode=0 (kernel-control), operstate=6 (IF_OPER_UP)
    nl80211: Unsubscribe mgmt frames handle 0x88e82389 (mode change)
    wlan0: CTRL-EVENT-TERMINATING
    ctrl_interface=/var/run/wpa_supplicant
    ap_scan=1
    network={
      ssid="OpenWrt"
      psk="987654321"
  • It's failing on the supplicant call to write the key to the radio.
    How is the AP configured? What encryption/AKM?
    Do you have mixed mode enabled in the cc33xx conf file?
  • I didn't modify any cc33xx related files.
    AP config is
    Mode: Master | SSID: OpenWrt
    BSSID: D8:EC:5E:7E:A9:33
    Encryption: WPA2 PSK (CCMP)
    Channel: 6 (2.437 GHz)
    Tx-Power: 29 dBm
    Signal: -33 dBm | Noise: -84 dBm
    Bitrate: 258.0 Mbit/s | Country: US
    With all other Wi-Fi devices it works well (ESP32, AIC8800DC, RTL8189FTV)
  • Some of those patches you skipped are related to decryption. I don't think they would be involved on this particular step, but you should consider applying all of them at least for testing purposes. Selectively removing patches puts you in an unknown/untested configuration.
    Get it working with all patches applied, then if you want to make changes you have a baseline to work from.
  • Can you kindly provide driver like a set of files, not patch on patch?
    Are you looking to compile out of tree? I can provide you the files but can't guarantee they will compile cleanly with  out of tree kernel 5.10.
