CC3301: Channel-specific scanning feature in R7 version
Part Number: CC3301
In the current R7 wifi driver, wifi scan uses the below API which performs a full spectrum scan:
ret = ctrlCmdFw_WLSendCommand(WLAN_SCAN, &cmd, sizeof(wlan_scan_cmd_t), &complete, sizeof(wlan_scan_complete_t));
This approach has several limitations:
Performance: Full spectrum scanning is time-consuming and resource-intensive
Reliability: The AP we expected is not found in scan results sometimes
We want TI to provide an enhanced API to improve scanning stability and performance:
Channel-specific scanning: only scan specific channels and eliminate unnecessary scanning of all channels
Ssid-specific scanning: only scan specified AP with ssid.
Mac-specific scanning: only scan specified AP with Mac address.
  • for the connection api, we also have the same requirement.
    wifi connecting api have below parameter:
    typedef struct
    cmd_header_t hdr;
    signed char pName[33]; //ssid up to 32 chars + null termination
    int NameLen;
    unsigned char pMacAddr[6];
    char SecType;
    char pPass[64]; //passphrase can be 8-63 characters long + Null termination
    char PassLen;
    char padding[3];
    }wlan_connect_cmd_t;
    This api has a limitation: before it start a connection, it will perform a scan operation to find the AP's channel.
    we want add a parameter for channel (which we can provide), if the fw knows the AP's channel, it can either skip scan operation or speed up scan operation during the connection process.
  • Our overall goal is to connect as quickly and reliably as possible. CC3301 seems to first do scanning with a wildcard SSID, on all channels. Then, after it hears the requested SSID it connects. This is not optimal since we already know the channel. In this example, the connection could have been at least ~1s faster by immediately doing the ProbeReq with the correct SSID on the correct channel.
    16:35:16.846] WiFi: MAC address: xx:xx:xx:xx:xx:xx
    16:35:16.849] WiFi: Requested country_code: DE, using EU instead.
    16:35:16.850] WiFi: Updated ssid in context:xx-xxxxxx, country code:EU
    16:35:16.850] WiFi: WIFI config saved
    16:35:16.868] WiFi: Connecting...
    16:35:16.871] WiFi: Updating wifi status: CONNECTING  error: 0 isp_error: ISP_ERR_OK(0) rssi: 16777215
    16:35:16.890] WiFi: ISP Wifi transitioning from state DISCONNECTED to CONNECTING
    16:35:16.894] WiFi: Pending action: CONNECT
    16:35:16.895] WiFi: Updating wifi status: CONNECTING  error: 0 isp_error: ISP_ERR_OK(0) rssi: 16777215
    16:35:16.895] WiFi: Initializing network stack...
    16:35:16.895] WiFi: Starting network...
    16:35:16.902] CC33xx wifi driver version: R_7
    16:35:16.906] select scio 2
    16:35:17.135] scio_init2: pre_init failed, got to reset init
    16:35:17.139] sdio_change_clk: set sdio clock 25000000
    16:35:17.139] sdio_set_buswidth_4bit: card_bus_width_switch to 4bit
    16:35:17.140] sdio function num=2, wifi_run_flag=0, err = 0
    16:35:17.140] sdio_wifi_init sdio2 ret=0
    16:35:17.141] Hardware init DONE!
    16:35:17.141] Starting FW download.....
    16:35:17.396] Download RAM-BTL
    16:35:17.400] Download FW
    16:35:17.448] cc33xx_rev: 1.7.6.310
    16:35:18.709] Download IniParams
    16:35:18.714] FW Download complete
    16:35:18.714] wifi init done
    16:35:18.722] Wlan_Start: set mac xx:xx:xx:xx:xx:xx
    16:35:18.726] Chosen domain is EU
    16:35:18.727] Wlan_RoleUp ROLE_STA!
    16:35:18.743] WiFi: [wl0] NETIF_LINK_STATUS_UP
    16:35:18.747] WiFi: [wl0] NETIF_LINK_STATUS_DOWN
    16:35:18.747] WiFi: [wl0] Link is down as part of re-/activation
    16:35:18.755] [WLAN EVENT] Device disconnected from the AP, ReasonCode: 200
    16:35:19.409] scan 10 find ssid xx-xxxxxx (len 9)
    16:35:19.421] security type: WPA2_PLUS
    16:35:19.422] connect to xx-xxxxxx, sectype: 11
    16:35:29.415] connect timeout
    16:35:29.425] connect to xx-xxxxxx, sectype: 11
    16:35:39.416] connect timeout
    16:35:39.427] connect to xx-xxxxxx, sectype: 11
    16:35:40.159] connect SSID: xx-xxxxxx
    16:35:40.170] BSSID: xx:xx:xx:xx:xx:xx
    16:35:40.171] WiFi: [wl0] NETIF_LINK_STATUS_ON
    16:35:40.172] WiFi: [wl0] Setting manual IP config (ip=192.168.x.xx, netmask=255.255.255.0, gateway=192.168.x.x, dns=192.168.x.x)
    16:35:40.172] WiFi: [wl0] NETIF_LINK_STATUS_UP
    16:35:40.176] WIFI Connected!
    16:35:40.177] WiFi: Connected
    In the logs above, the connection is 23.308 sec. Even if scanning all channels, this takes a very long time. Does the CC3301 continue scanning the whole time?
  • We are looking into the feasibility of these requests and will update you on it
