CC3351: failed with error -13 while reload kernel modules
Part Number: CC3351
Hi TI experts,
     When I unloaded and loaded kernel modules, it failed with error -13. Please check out the following kernel log.
     [10/10/2025 20:52:50.136] [ 167.880012] btti_cc33xx_bt_sdio: probe of mmc1:0001:1 failed with error -13
root@smm-m2d ~ # dmesg
[10/10/2025 20:51:26.010] [    0.000000] Booting Linux on physical CPU 0x0
[10/10/2025 20:51:26.010] [    0.000000] Linux version 5.10.72+g5fa027c4887b (oe-user@oe-host) (arm-poky-linux-musleabi-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 PREEMPT Tue Sep 30 12:11:48 UTC 2025
[10/10/2025 20:51:26.027] [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
[10/10/2025 20:51:26.037] [    0.000000] CPU: div instructions available: patching division code
[10/10/2025 20:51:26.044] [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[10/10/2025 20:51:26.055] [    0.000000] OF: fdt: Machine model: BSH SMM M2D
[10/10/2025 20:51:26.055] [    0.000000] Memory policy: Data cache writeback
[10/10/2025 20:51:26.063] [    0.000000] cma: Reserved 32 MiB at 0x9e000000
[10/10/2025 20:51:26.063] [    0.000000] Zone ranges:
[10/10/2025 20:51:26.069] [    0.000000]   Normal   [mem 0x0000000080000000-0x000000009fffffff]
[10/10/2025 20:51:26.070] [    0.000000] Movable zone start for each node
[10/10/2025 20:51:26.077] [    0.000000] Early memory node ranges
[10/10/2025 20:51:26.077] [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009fffffff]
[10/10/2025 20:51:26.087] [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fffffff]
[10/10/2025 20:51:26.093] [    0.000000] On node 0 totalpages: 131072
[10/10/2025 20:51:26.101] [    0.000000]   Normal zone: 1024 pages used for memmap
[10/10/2025 20:51:26.101] [    0.000000]   Normal zone: 0 pages reserved
[10/10/2025 20:51:26.104] [    0.000000]   Normal zone: 131072 pages, LIFO batch:31
[10/10/2025 20:51:26.109] [    0.000000] CPU: All CPU(s) started in SVC mode.
[10/10/2025 20:51:26.118] [    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[10/10/2025 20:51:26.120] [    0.000000] pcpu-alloc: [0] 0
[10/10/2025 20:51:26.120] [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 130048
[10/10/2025 20:51:26.137] [    0.000000] Kernel command line: console=ttymxc3,115200 ubi.mtd=ubi cmdlinepart.mtdparts=gpmi-nand:3m(boot),512k(envA),512k(envB),8m(fitA),8m(fitB),-(ubi) root=/dev/ram rootfstype=ramfs init=/init loglevel=4 panic=2 bsh.red_hw=1 bsh.prod-utils-mode=ifp bsh.dbus2_baud_rate=9600
[10/10/2025 20:51:26.154] [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[10/10/2025 20:51:26.159] [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[10/10/2025 20:51:26.171] [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[10/10/2025 20:51:26.176] [    0.000000] Memory: 475396K/524288K available (3072K kernel code, 522K rwdata, 948K rodata, 1024K init, 181K bss, 16124K reserved, 32768K cma-reserved)
[10/10/2025 20:51:26.202] [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[10/10/2025 20:51:26.202] [    0.000000] rcu: Preemptible hierarchical RCU implementation.
[10/10/2025 20:51:26.204] [    0.000000]        Trampoline variant of Tasks RCU enabled.
[10/10/2025 20:51:26.204] [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[10/10/2025 20:51:26.220] [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[10/10/2025 20:51:26.221] [    0.000000] Switching to timer-based delay loop, resolution 41ns
[10/10/2025 20:51:26.227] [    0.000020] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[10/10/2025 20:51:26.235] [    0.000058] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[10/10/2025 20:51:26.243] [    0.002124] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[10/10/2025 20:51:26.254] [    0.002159] pid_max: default: 32768 minimum: 301
[10/10/2025 20:51:26.260] [    0.002449] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[10/10/2025 20:51:26.270] [    0.002478] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[10/10/2025 20:51:26.271] [    0.003558] CPU: Testing write buffer coherency: ok
[10/10/2025 20:51:26.280] [    0.004909] Setting up static identity map for 0x80100000 - 0x80100060
[10/10/2025 20:51:26.288] [    0.005095] rcu: Hierarchical SRCU implementation.
[10/10/2025 20:51:26.288] [    0.005727] devtmpfs: initialized
[10/10/2025 20:51:26.294] [    0.017359] random: get_random_bytes called from net_ns_init+0x8c/0x258 with crng_init=0
[10/10/2025 20:51:26.302] [    0.017684] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[10/10/2025 20:51:26.311] [    0.018142] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[10/10/2025 20:51:26.320] [    0.018181] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[10/10/2025 20:51:26.328] [    0.021157] pinctrl core: initialized pinctrl subsystem
[10/10/2025 20:51:26.339] [    0.022454] NET: Registered protocol family 16
[10/10/2025 20:51:26.339] [    0.036249] DMA: preallocated 256 KiB pool for atomic coherent allocations
[10/10/2025 20:51:26.347] [    0.192242] vdd3p0: supplied by regulator-dummy
[10/10/2025 20:51:26.353] [    0.201428] cpu: supplied by regulator-dummy
[10/10/2025 20:51:26.353] [    0.210922] vddsoc: supplied by regulator-dummy
[10/10/2025 20:51:26.354] [    0.445541] failed to find ocotp node
[10/10/2025 20:51:26.361] [    0.445927] failed to find ocotp node
[10/10/2025 20:51:26.361] [    0.447285] imx6ul-pinctrl 20e0000.pinctrl: initialized IMX pinctrl driver
[10/10/2025 20:51:26.370] [    0.447772] imx6ul-pinctrl 2290000.iomuxc-snvs: no groups defined in /soc/bus@2200000/iomuxc-snvs@2290000
[10/10/2025 20:51:26.377] [    0.447809] imx6ul-pinctrl 2290000.iomuxc-snvs: initialized IMX pinctrl driver
[10/10/2025 20:51:26.387] [    0.479825] clocksource: Switched to clocksource mxc_timer1
[10/10/2025 20:51:26.397] [    0.482362] NET: Registered protocol family 2
[10/10/2025 20:51:26.397] [    0.482951] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[10/10/2025 20:51:26.412] [    0.484574] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[10/10/2025 20:51:26.412] [    0.484650] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[10/10/2025 20:51:26.420] [    0.484747] TCP bind hash table entries: 4096 (order: 2, 16384 bytes, linear)
[10/10/2025 20:51:26.428] [    0.484835] TCP: Hash tables configured (established 4096 bind 4096)
[10/10/2025 20:51:26.436] [    0.485024] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[10/10/2025 20:51:26.437] [    0.485074] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[10/10/2025 20:51:26.446] [    0.485377] NET: Registered protocol family 1
[10/10/2025 20:51:26.456] [    0.485838] Unpacking initramfs...
[10/10/2025 20:51:26.456] [    0.745922] Freeing initrd memory: 4556K
[10/10/2025 20:51:26.470] [    0.747959] Bus freq driver module loaded
[10/10/2025 20:51:26.470] [    0.748926] Initialise system trusted keyrings
[10/10/2025 20:51:26.470] [    0.749215] workingset: timestamp_bits=30 max_order=17 bucket_order=0
[10/10/2025 20:51:26.471] [    0.758067] Key type asymmetric registered
[10/10/2025 20:51:26.478] [    0.758092] Asymmetric key parser 'x509' registered
[10/10/2025 20:51:26.486] [    0.762882] mxs-dma 1804000.dma-apbh: initialized
[10/10/2025 20:51:26.487] [    0.766880] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 21, base_baud = 5000000) is a IMX
[10/10/2025 20:51:26.494] [    0.769500] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 47, base_baud = 5000000) is a IMX
[10/10/2025 20:51:26.504] [    0.771826] 21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 48, base_baud = 5000000) is a IMX
[10/10/2025 20:51:26.513] [    0.782133] printk: console [ttymxc3] enabled
[10/10/2025 20:51:26.522] [    0.816965] imx_rngc 2284000.rng: Freescale RNGB registered (HW revision 2.129)
[10/10/2025 20:51:26.528] [    0.819313] random: fast init done
[10/10/2025 20:51:26.528] [    0.823807] NET: Registered protocol family 45
[10/10/2025 20:51:26.536] [    0.825490] tty ttymxc0: Opened B/S/H DBus2 line discipline
[10/10/2025 20:51:26.537] [    0.825864] random: crng init done
[10/10/2025 20:51:26.537] [    0.830421] NET: Registered protocol family 17
[10/10/2025 20:51:26.544] [    0.830801] Loading compiled-in X.509 certificates
[10/10/2025 20:51:26.552] [    0.835015] Freeing unused kernel memory: 1024K
[10/10/2025 20:51:26.554] [    0.860103] Run /init as init process
[10/10/2025 20:51:26.563] [    0.860117]   with arguments:
[10/10/2025 20:51:26.563] [    0.860129]     /init
[10/10/2025 20:51:26.563] [    0.860138]   with environment:
[10/10/2025 20:51:26.572] [    0.860147]     HOME=/
[10/10/2025 20:51:26.572] [    0.860158]     TERM=linux
[10/10/2025 20:51:26.572] [    1.065285] Initial DBus2 baud rate was set to 9600
[10/10/2025 20:51:26.579] [    1.130244] nand: device found, Manufacturer ID: 0xc2, Chip ID: 0xdc
[10/10/2025 20:51:26.586] [    1.130270] nand: Macronix MX30LF4G18AC
[10/10/2025 20:51:26.587] [    1.130292] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[10/10/2025 20:51:26.594] [    1.131141] Bad block table found at page 262080, version 0x01
[10/10/2025 20:51:26.602] [    1.131292] Bad block table found at page 262016, version 0x01
[10/10/2025 20:51:26.604] [    1.131476] nand_read_bbt: bad block at 0x000008520000
[10/10/2025 20:51:26.611] [    1.139017] 6 cmdlinepart partitions found on MTD device gpmi-nand
[10/10/2025 20:51:26.619] [    1.139044] Creating 6 MTD partitions on "gpmi-nand":
[10/10/2025 20:51:26.621] [    1.139068] 0x000000000000-0x000000300000 : "boot"
[10/10/2025 20:51:26.629] [    1.158832] 0x000000300000-0x000000380000 : "envA"
[10/10/2025 20:51:26.638] [    1.171953] 0x000000380000-0x000000400000 : "envB"
[10/10/2025 20:51:26.638] [    1.183740] 0x000000400000-0x000000c00000 : "fitA"
[10/10/2025 20:51:26.638] [    1.193930] 0x000000c00000-0x000001400000 : "fitB"
[10/10/2025 20:51:26.644] [    1.204203] 0x000001400000-0x000020000000 : "ubi"
[10/10/2025 20:51:26.652] [    1.218009] gpmi-nand 1806000.nand-controller: driver registered.
[10/10/2025 20:51:26.654] [    1.230430] ubi0: attaching mtd5
[10/10/2025 20:51:26.660] [    2.188593] ubi0: scanning is finished
[10/10/2025 20:51:26.670] [    2.205153] ubi0: attached mtd5 (name "ubi", size 492 MiB)
[10/10/2025 20:51:26.670] [    2.205184] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[10/10/2025 20:51:26.677] [    2.205202] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[10/10/2025 20:51:26.688] [    2.205221] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[10/10/2025 20:51:26.688] [    2.205238] ubi0: good PEBs: 3931, bad PEBs: 5, corrupted PEBs: 0
[10/10/2025 20:51:26.696] [    2.205255] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[10/10/2025 20:51:26.704] [    2.205278] ubi0: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 1272438453
[10/10/2025 20:51:26.710] [    2.205296] ubi0: available PEBs: 0, total reserved PEBs: 3931, PEBs reserved for bad PEB handling: 75
[10/10/2025 20:51:26.720] [    2.209994] ubi0: background thread "ubi_bgt0d" started, PID 55
[10/10/2025 20:51:26.727] [    2.242472] UBIFS (ubi0:1): Mounting in unauthenticated mode
[10/10/2025 20:51:26.735] [    2.242806] UBIFS (ubi0:1): background thread "ubifs_bgt0_1" started, PID 57
[10/10/2025 20:51:26.737] [    2.258518] UBIFS (ubi0:1): recovery needed
[10/10/2025 20:51:26.747] [    2.298671] UBIFS (ubi0:1): recovery completed
[10/10/2025 20:51:26.754] [    2.298712] UBIFS (ubi0:1): UBIFS: mounted UBI device 0, volume 1, name "pvroot"
[10/10/2025 20:51:26.755] [    2.298739] UBIFS (ubi0:1): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[10/10/2025 20:51:26.769] [    2.298768] UBIFS (ubi0:1): FS size: 487714816 bytes (465 MiB, 3841 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
[10/10/2025 20:51:26.777] [    2.298786] UBIFS (ubi0:1): reserved for root: 0 bytes (0 KiB)
[10/10/2025 20:51:26.786] [    2.298815] UBIFS (ubi0:1): media format: w4/r0 (latest is w5/r0), UUID 3D77181C-AE2B-4271-A90F-616FA02D5BD5, small LPT model
[10/10/2025 20:51:26.794] [    2.355933] sdhci: Secure Digital Host Controller Interface driver
[10/10/2025 20:51:26.805] [    2.355955] sdhci: Copyright(c) Pierre Ossman
[10/10/2025 20:51:26.805] [    2.357683] sdhci-pltfm: SDHCI platform and OF driver helper
[10/10/2025 20:51:26.813] [    2.363405] sdhci-esdhc-imx 2194000.mmc: allocated mmc-pwrseq
[10/10/2025 20:51:26.819] [    2.449882] mmc1: SDHCI controller on 2194000.mmc [2194000.mmc] using ADMA
[10/10/2025 20:51:26.820] [    2.474473] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[10/10/2025 20:51:26.827] [    2.508556] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[10/10/2025 20:51:26.837] [    2.520924] sdhci-esdhc-imx 2194000.mmc: card claims to support voltages below defined range
[10/10/2025 20:51:26.844] [    2.584705] mmc1: new high speed SDIO card at address 0001
[10/10/2025 20:51:26.853] [    2.596524] Bluetooth: Core ver 2.22
[10/10/2025 20:51:26.854] [    2.596623] NET: Registered protocol family 31
[10/10/2025 20:51:26.863] [    2.596638] Bluetooth: HCI device and connection manager initialized
[10/10/2025 20:51:26.871] [    2.596673] Bluetooth: HCI socket layer initialized
[10/10/2025 20:51:26.878] [    2.596694] Bluetooth: L2CAP socket layer initialized
[10/10/2025 20:51:26.878] [    2.600901] Bluetooth: [bt sdio] BLE SDIO init module
[10/10/2025 20:51:26.878] [    2.820151] Bluetooth: [bt sdio] PROBE vendor=0x97, device=0x4077, class=255, fn=1 0xc48f1a00
[10/10/2025 20:51:26.887] [    2.830147] Bluetooth: [bt sdio hci] btti_hci_add_sdio_dev
[10/10/2025 20:51:26.894] [    2.830167] Bluetooth: [bt sdio hci] Starting work thread...
[10/10/2025 20:51:26.903] [    2.830407] Bluetooth: [bt sdio hci] work thread is started
[10/10/2025 20:51:26.904] [    2.830523] Bluetooth: [bt sdio] TI cc33xx BLE-over-SDIO driver is up and running!
[10/10/2025 20:51:26.911] [    2.830950] Bluetooth: [bt sdio hci] work thread is sleeping...
[10/10/2025 20:51:26.922] [    2.831006] Bluetooth: [bt sdio] PROBE vendor=0x97, device=0x4077, class=255, fn=2 0xc48f1c00
[10/10/2025 20:51:26.930] [    2.833998] cc33xx_sdio mmc1:0001:2: Using GPIO as IRQ
[10/10/2025 20:51:26.936] [    2.845995] wlcore: cc33xx_probe :: Start
[10/10/2025 20:51:26.937] [    2.846575] wlcore: Wireless Driver Version 1.7.0.239
[10/10/2025 20:51:26.937] [    2.846617] wlcore: WLAN CC33xx platform device probe done
[10/10/2025 20:51:26.944] [    2.847721] cc33xx_driver cc33xx.0.auto: Direct firmware load for ti-connectivity/cc33xx-nvs.bin failed with error -2
[10/10/2025 20:51:26.954] [    2.847753] wlcore: Could not get nvs file ti-connectivity/cc33xx-nvs.bin
[10/10/2025 20:51:26.969] [    2.848355] wlcore: Chip wakeup
[10/10/2025 20:51:26.969] [    3.010084] mxs-dcp 2280000.crypto: Not in Trusted or Secure State, Non-volatile Test Key in effect
[10/10/2025 20:51:26.978] [    3.028509] NET: Registered protocol family 38
[10/10/2025 20:51:26.987] [    3.030653] imx_usb 2184000.usb: No over current polarity defined
[10/10/2025 20:51:26.995] [    3.040936] imx_usb 2184000.usb: No over current polarity defined
[10/10/2025 20:51:26.995] [    3.045460] loop: module loaded
[10/10/2025 20:51:26.995] [    3.059908] ci_hdrc ci_hdrc.0: doesn't support host
[10/10/2025 20:51:27.003] [    3.079280] using random self ethernet address
[10/10/2025 20:51:27.004] [    3.079311] using random host ethernet address
[10/10/2025 20:51:27.011] [    3.100339] wlcore: Set BLKsize to 128
[10/10/2025 20:51:27.011] [    3.100696] wlcore: BOOT IRQs: 0x8
[10/10/2025 20:51:27.019] [    3.170857] wlcore: Reading control info
[10/10/2025 20:51:27.020] [    3.171184] wlcore: Processing message type 2, len 704
[10/10/2025 20:51:27.028] [    3.171241] wlcore: Response len 704, allocated buffer len 712
[10/10/2025 20:51:27.038] [    3.171258] wlcore: CMD# 35, len=712
[10/10/2025 20:51:27.038] [    3.171287] wlcore: CC33XX device info: PG version: 2, Metal version: 1, Boot ROM version: 1, M3 ROM version: 1, MAC address: 0x7402e120ec30, Device part number: 0
[10/10/2025 20:51:27.053] [    3.171301] wlcore: Downloading ti-connectivity/cc33xx_2nd_loader.bin to device
[10/10/2025 20:51:27.054] [    3.173564] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[10/10/2025 20:51:27.070] [    3.175148] wlcore: Reading control info
[10/10/2025 20:51:27.070] [    3.175471] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.070] [    3.176835] wlcore: Reading control info
[10/10/2025 20:51:27.077] [    3.177153] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.085] [    3.178188] wlcore: Reading control info
[10/10/2025 20:51:27.087] [    3.178529] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.097] [    3.179570] wlcore: Reading control info
[10/10/2025 20:51:27.097] [    3.179972] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.105] [    3.182086] usb0: HOST MAC aa:5c:dc:d2:32:3f
[10/10/2025 20:51:27.105] [    3.182881] usb0: MAC 56:a3:23:2d:cd:c0
[10/10/2025 20:51:27.110] [    3.189948] wlcore: Reading control info
[10/10/2025 20:51:27.110] [    3.190282] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.119] [    3.191326] wlcore: Reading control info
[10/10/2025 20:51:27.120] [    3.191642] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.127] [    3.192684] wlcore: Reading control info
[10/10/2025 20:51:27.136] [    3.192984] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.136] [    3.193964] wlcore: Reading control info
[10/10/2025 20:51:27.137] [    3.194255] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.144] [    3.195322] wlcore: Reading control info
[10/10/2025 20:51:27.154] [    3.195690] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.155] [    3.196726] wlcore: Reading control info
[10/10/2025 20:51:27.155] [    3.197024] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.163] [    3.198153] wlcore: Reading control info
[10/10/2025 20:51:27.169] [    3.198526] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.170] [    3.199591] wlcore: Reading control info
[10/10/2025 20:51:27.177] [    3.199950] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.177] [    3.201111] wlcore: Reading control info
[10/10/2025 20:51:27.185] [    3.201454] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.187] [    3.202532] wlcore: Reading control info
[10/10/2025 20:51:27.193] [    3.202867] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.202] [    3.203978] wlcore: Reading control info
[10/10/2025 20:51:27.202] [    3.204321] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.204] [    3.205406] wlcore: Reading control info
[10/10/2025 20:51:27.210] [    3.205715] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.221] [    3.206790] wlcore: Reading control info
[10/10/2025 20:51:27.221] [    3.207098] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.221] [    3.208129] wlcore: Reading control info
[10/10/2025 20:51:27.229] [    3.208495] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.235] [    3.209672] wlcore: Reading control info
[10/10/2025 20:51:27.237] [    3.209998] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.244] [    3.211029] wlcore: Reading control info
[10/10/2025 20:51:27.244] [    3.211358] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.252] [    3.212405] wlcore: Reading control info
[10/10/2025 20:51:27.254] [    3.212733] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.260] [    3.213816] wlcore: Reading control info
[10/10/2025 20:51:27.260] [    3.214128] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.268] [    3.215165] wlcore: Reading control info
[10/10/2025 20:51:27.270] [    3.215506] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.277] [    3.216597] wlcore: Reading control info
[10/10/2025 20:51:27.287] [    3.216932] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.287] [    3.218030] wlcore: Reading control info
[10/10/2025 20:51:27.287] [    3.218356] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.294] [    3.219412] wlcore: Reading control info
[10/10/2025 20:51:27.302] [    3.219749] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.304] [    3.220943] wlcore: Reading control info
[10/10/2025 20:51:27.304] [    3.221266] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.310] [    3.222306] wlcore: Reading control info
[10/10/2025 20:51:27.318] [    3.222625] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.320] [    3.223698] wlcore: Reading control info
[10/10/2025 20:51:27.326] [    3.224039] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.326] [    3.225173] wlcore: Reading control info
[10/10/2025 20:51:27.335] [    3.225505] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.337] [    3.226574] wlcore: Reading control info
[10/10/2025 20:51:27.343] [    3.226891] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.355] [    3.227939] wlcore: Reading control info
[10/10/2025 20:51:27.355] [    3.228264] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.355] [    3.229301] wlcore: Reading control info
[10/10/2025 20:51:27.362] [    3.229611] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.368] [    3.230633] wlcore: Reading control info
[10/10/2025 20:51:27.370] [    3.230943] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.370] [    3.232011] wlcore: Reading control info
[10/10/2025 20:51:27.377] [    3.232322] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.385] [    3.233353] wlcore: Reading control info
[10/10/2025 20:51:27.387] [    3.233708] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.393] [    3.234799] wlcore: Reading control info
[10/10/2025 20:51:27.393] [    3.235128] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.402] [    3.236190] wlcore: Reading control info
[10/10/2025 20:51:27.404] [    3.236523] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.410] [    3.237604] wlcore: Reading control info
[10/10/2025 20:51:27.421] [    3.237944] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.421] [    3.239051] wlcore: Reading control info
[10/10/2025 20:51:27.421] [    3.239385] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.429] [    3.240491] wlcore: Reading control info
[10/10/2025 20:51:27.435] [    3.240803] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.437] [    3.241849] wlcore: Reading control info
[10/10/2025 20:51:27.437] [    3.242201] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.443] [    3.243267] wlcore: Reading control info
[10/10/2025 20:51:27.451] [    3.243612] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.454] [    3.244673] wlcore: Reading control info
[10/10/2025 20:51:27.460] [    3.244998] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.460] [    3.246077] wlcore: Reading control info
[10/10/2025 20:51:27.468] [    3.246425] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.471] [    3.247487] wlcore: Reading control info
[10/10/2025 20:51:27.477] [    3.247849] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.488] [    3.248915] wlcore: Reading control info
[10/10/2025 20:51:27.488] [    3.249246] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.488] [    3.250326] wlcore: Reading control info
[10/10/2025 20:51:27.496] [    3.250677] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.502] [    3.251772] wlcore: Reading control info
[10/10/2025 20:51:27.502] [    3.252109] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.504] [    3.253167] wlcore: Reading control info
[10/10/2025 20:51:27.510] [    3.253499] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.518] [    3.254592] wlcore: Reading control info
[10/10/2025 20:51:27.520] [    3.254930] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.527] [    3.256037] wlcore: Reading control info
[10/10/2025 20:51:27.527] [    3.256376] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.534] [    3.257435] wlcore: Reading control info
[10/10/2025 20:51:27.537] [    3.257823] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.543] [    3.258901] wlcore: Reading control info
[10/10/2025 20:51:27.543] [    3.259210] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.554] [    3.260262] wlcore: Reading control info
[10/10/2025 20:51:27.554] [    3.260616] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.562] [    3.261771] wlcore: Reading control info
[10/10/2025 20:51:27.570] [    3.262094] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.570] [    3.263130] wlcore: Reading control info
[10/10/2025 20:51:27.570] [    3.263466] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.577] [    3.264563] wlcore: Reading control info
[10/10/2025 20:51:27.585] [    3.264882] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.587] [    3.265949] wlcore: Reading control info
[10/10/2025 20:51:27.587] [    3.266280] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.593] [    3.267432] wlcore: Reading control info
[10/10/2025 20:51:27.602] [    3.267786] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.604] [    3.268840] wlcore: Reading control info
[10/10/2025 20:51:27.610] [    3.269167] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.610] [    3.270240] wlcore: Reading control info
[10/10/2025 20:51:27.621] [    3.270575] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.621] [    3.271632] wlcore: Reading control info
[10/10/2025 20:51:27.629] [    3.271948] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.635] [    3.272991] wlcore: Reading control info
[10/10/2025 20:51:27.635] [    3.273305] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.637] [    3.274381] wlcore: Reading control info
[10/10/2025 20:51:27.644] [    3.274701] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.652] [    3.275770] wlcore: Reading control info
[10/10/2025 20:51:27.654] [    3.276102] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.654] [    3.277190] wlcore: Reading control info
[10/10/2025 20:51:27.660] [    3.277499] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.668] [    3.278515] wlcore: Reading control info
[10/10/2025 20:51:27.670] [    3.278845] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.677] [    3.279940] wlcore: Reading control info
[10/10/2025 20:51:27.677] [    3.280282] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.688] [    3.281384] wlcore: Reading control info
[10/10/2025 20:51:27.688] [    3.281705] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.696] [    3.282739] wlcore: Reading control info
[10/10/2025 20:51:27.702] [    3.283156] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.702] [    3.284235] wlcore: Reading control info
[10/10/2025 20:51:27.704] [    3.284557] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.710] [    3.285603] wlcore: Reading control info
[10/10/2025 20:51:27.718] [    3.285912] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.720] [    3.286971] wlcore: Reading control info
[10/10/2025 20:51:27.720] [    3.287277] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.726] [    3.288338] wlcore: Reading control info
[10/10/2025 20:51:27.735] [    3.288655] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.737] [    3.289733] wlcore: Reading control info
[10/10/2025 20:51:27.743] [    3.290069] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.743] [    3.291153] wlcore: Reading control info
[10/10/2025 20:51:27.756] [    3.291501] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.756] [    3.292654] wlcore: Reading control info
[10/10/2025 20:51:27.762] [    3.292982] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.769] [    3.294052] wlcore: Reading control info
[10/10/2025 20:51:27.769] [    3.294430] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.770] [    3.295528] wlcore: Reading control info
[10/10/2025 20:51:27.777] [    3.295857] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.785] [    3.296931] wlcore: Reading control info
[10/10/2025 20:51:27.785] [    3.297262] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.787] [    3.298341] wlcore: Reading control info
[10/10/2025 20:51:27.793] [    3.298666] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.802] [    3.299751] wlcore: Reading control info
[10/10/2025 20:51:27.804] [    3.300080] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.810] [    3.301165] wlcore: Reading control info
[10/10/2025 20:51:27.810] [    3.301486] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.821] [    3.302570] wlcore: Reading control info
[10/10/2025 20:51:27.822] [    3.302911] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.829] [    3.304004] wlcore: Reading control info
[10/10/2025 20:51:27.829] [    3.304346] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.835] [    3.305416] wlcore: Reading control info
[10/10/2025 20:51:27.837] [    3.305743] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.843] [    3.306791] wlcore: Reading control info
[10/10/2025 20:51:27.854] [    3.307107] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.854] [    3.308185] wlcore: Reading control info
[10/10/2025 20:51:27.854] [    3.308512] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.860] [    3.309583] wlcore: Reading control info
[10/10/2025 20:51:27.868] [    3.309944] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.870] [    3.311059] wlcore: Reading control info
[10/10/2025 20:51:27.870] [    3.311386] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.877] [    3.312451] wlcore: Reading control info
[10/10/2025 20:51:27.887] [    3.312776] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.889] [    3.313822] wlcore: Reading control info
[10/10/2025 20:51:27.895] [    3.314147] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.895] [    3.315214] wlcore: Reading control info
[10/10/2025 20:51:27.902] [    3.315542] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.904] [    3.316602] wlcore: Reading control info
[10/10/2025 20:51:27.910] [    3.316917] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.918] [    3.317951] wlcore: Reading control info
[10/10/2025 20:51:27.918] [    3.318265] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.920] [    3.319324] wlcore: Reading control info
[10/10/2025 20:51:27.926] [    3.319649] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.935] [    3.320704] wlcore: Reading control info
[10/10/2025 20:51:27.937] [    3.321010] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.937] [    3.321997] wlcore: Reading control info
[10/10/2025 20:51:27.943] [    3.322297] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.954] [    3.323270] wlcore: Reading control info
[10/10/2025 20:51:27.957] [    3.323567] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.963] [    3.324581] wlcore: Reading control info
[10/10/2025 20:51:27.963] [    3.324897] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.969] [    3.325928] wlcore: Reading control info
[10/10/2025 20:51:27.970] [    3.326244] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.977] [    3.327276] wlcore: Reading control info
[10/10/2025 20:51:27.985] [    3.327584] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.985] [    3.328605] wlcore: Reading control info
[10/10/2025 20:51:27.987] [    3.328916] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:27.993] [    3.330062] wlcore: Reading control info
[10/10/2025 20:51:28.002] [    3.330388] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.004] [    3.331423] wlcore: Reading control info
[10/10/2025 20:51:28.004] [    3.331746] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.010] [    3.332784] wlcore: Reading control info
[10/10/2025 20:51:28.021] [    3.333097] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.021] [    3.334166] wlcore: Reading control info
[10/10/2025 20:51:28.029] [    3.334489] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.029] [    3.335563] wlcore: Reading control info
[10/10/2025 20:51:28.035] [    3.335903] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.037] [    3.336947] wlcore: Reading control info
[10/10/2025 20:51:28.043] [    3.337267] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.054] [    3.337320] wlcore: Suspending IRQ while device reboots
[10/10/2025 20:51:28.054] [    3.599980] wlcore: Resuming IRQ
[10/10/2025 20:51:28.054] [    3.600272] wlcore: BOOT IRQs: 0x10
[10/10/2025 20:51:28.060] [    3.670505] wlcore: ti-connectivity/cc33xx_2nd_loader.bin loaded successfully
[10/10/2025 20:51:28.068] [    3.672003] wlcore: Reading control info
[10/10/2025 20:51:28.070] [    3.672333] wlcore: Processing message type 2, len 704
[10/10/2025 20:51:28.077] [    3.672394] wlcore: Response len 704, allocated buffer len 712
[10/10/2025 20:51:28.089] [    3.672410] wlcore: CMD# 35, len=712
[10/10/2025 20:51:28.089] [    3.672431] wlcore: Downloading ti-connectivity/cc33xx_fw.bin to device
[10/10/2025 20:51:28.096] [    3.680269] wlcore: Reading control info
[10/10/2025 20:51:28.096] [    3.680590] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.102] [    3.681865] wlcore: Reading control info
[10/10/2025 20:51:28.104] [    3.682202] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.110] [    3.683513] wlcore: Reading control info
[10/10/2025 20:51:28.110] [    3.683848] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.118] [    3.685129] wlcore: Reading control info
[10/10/2025 20:51:28.120] [    3.685465] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.126] [    3.687472] wlcore: Reading control info
[10/10/2025 20:51:28.135] [    3.687819] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.135] [    3.689183] wlcore: Reading control info
[10/10/2025 20:51:28.137] [    3.689521] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.143] [    3.690890] wlcore: Reading control info
[10/10/2025 20:51:28.154] [    3.691260] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.161] [    3.701500] wlcore: Reading control info
[10/10/2025 20:51:28.161] [    3.701833] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.162] [    3.703140] wlcore: Reading control info
[10/10/2025 20:51:28.169] [    3.703453] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.170] [    3.704778] wlcore: Reading control info
[10/10/2025 20:51:28.177] [    3.705130] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.177] [    3.706481] wlcore: Reading control info
[10/10/2025 20:51:28.185] [    3.706824] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.187] [    3.708206] wlcore: Reading control info
[10/10/2025 20:51:28.193] [    3.708530] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.202] [    3.709960] wlcore: Reading control info
[10/10/2025 20:51:28.202] [    3.710276] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.204] [    3.711585] wlcore: Reading control info
[10/10/2025 20:51:28.210] [    3.711918] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.221] [    3.712819] EXT4-fs (dm-0): recovery complete
[10/10/2025 20:51:28.221] [    3.712863] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
[10/10/2025 20:51:28.229] [    3.713305] wlcore: Reading control info
[10/10/2025 20:51:28.235] [    3.713618] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.237] [    3.714945] wlcore: Reading control info
[10/10/2025 20:51:28.237] [    3.715291] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.243] [    3.716629] wlcore: Reading control info
[10/10/2025 20:51:28.252] [    3.716956] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.254] [    3.718252] wlcore: Reading control info
[10/10/2025 20:51:28.254] [    3.718567] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.260] [    3.719908] wlcore: Reading control info
[10/10/2025 20:51:28.268] [    3.720236] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.270] [    3.721529] wlcore: Reading control info
[10/10/2025 20:51:28.277] [    3.721847] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.290] [    3.723117] wlcore: Reading control info
[10/10/2025 20:51:28.290] [    3.723446] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.290] [    3.724805] wlcore: Reading control info
[10/10/2025 20:51:28.296] [    3.725145] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.301] [    3.726518] wlcore: Reading control info
[10/10/2025 20:51:28.301] [    3.726842] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.304] [    3.728236] wlcore: Reading control info
[10/10/2025 20:51:28.310] [    3.728573] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.319] [    3.729946] wlcore: Reading control info
[10/10/2025 20:51:28.320] [    3.730281] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.326] [    3.732367] wlcore: Reading control info
[10/10/2025 20:51:28.326] [    3.732678] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.335] [    3.733924] wlcore: Reading control info
[10/10/2025 20:51:28.337] [    3.734221] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.344] [    3.735458] wlcore: Reading control info
[10/10/2025 20:51:28.344] [    3.735756] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.354] [    3.736988] wlcore: Reading control info
[10/10/2025 20:51:28.355] [    3.737280] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.363] [    3.738515] wlcore: Reading control info
[10/10/2025 20:51:28.368] [    3.738806] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.368] [    3.740128] wlcore: Reading control info
[10/10/2025 20:51:28.370] [    3.740441] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.377] [    3.741687] wlcore: Reading control info
[10/10/2025 20:51:28.385] [    3.741982] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.387] [    3.743216] wlcore: Reading control info
[10/10/2025 20:51:28.387] [    3.743514] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.393] [    3.744748] wlcore: Reading control info
[10/10/2025 20:51:28.402] [    3.745046] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.404] [    3.746280] wlcore: Reading control info
[10/10/2025 20:51:28.410] [    3.746575] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.410] [    3.747805] wlcore: Reading control info
[10/10/2025 20:51:28.421] [    3.748097] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.421] [    3.749330] wlcore: Reading control info
[10/10/2025 20:51:28.429] [    3.749623] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.435] [    3.750870] wlcore: Reading control info
[10/10/2025 20:51:28.435] [    3.751169] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.437] [    3.752407] wlcore: Reading control info
[10/10/2025 20:51:28.444] [    3.752704] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.454] [    3.753934] wlcore: Reading control info
[10/10/2025 20:51:28.454] [    3.754230] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.454] [    3.755461] wlcore: Reading control info
[10/10/2025 20:51:28.460] [    3.755752] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.468] [    3.756985] wlcore: Reading control info
[10/10/2025 20:51:28.470] [    3.757282] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.477] [    3.758509] wlcore: Reading control info
[10/10/2025 20:51:28.477] [    3.758802] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.489] [    3.760048] wlcore: Reading control info
[10/10/2025 20:51:28.489] [    3.760346] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.496] [    3.761589] wlcore: Reading control info
[10/10/2025 20:51:28.496] [    3.761886] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.502] [    3.763120] wlcore: Reading control info
[10/10/2025 20:51:28.504] [    3.763412] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.510] [    3.764640] wlcore: Reading control info
[10/10/2025 20:51:28.519] [    3.764932] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.520] [    3.766162] wlcore: Reading control info
[10/10/2025 20:51:28.520] [    3.766454] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.527] [    3.767687] wlcore: Reading control info
[10/10/2025 20:51:28.535] [    3.767976] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.537] [    3.769210] wlcore: Reading control info
[10/10/2025 20:51:28.537] [    3.769506] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.544] [    3.770763] wlcore: Reading control info
[10/10/2025 20:51:28.554] [    3.771075] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.554] [    3.772325] wlcore: Reading control info
[10/10/2025 20:51:28.562] [    3.772629] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.569] [    3.773873] wlcore: Reading control info
[10/10/2025 20:51:28.569] [    3.774172] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.570] [    3.775416] wlcore: Reading control info
[10/10/2025 20:51:28.577] [    3.775716] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.585] [    3.776963] wlcore: Reading control info
[10/10/2025 20:51:28.585] [    3.777258] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.587] [    3.778501] wlcore: Reading control info
[10/10/2025 20:51:28.593] [    3.778802] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.602] [    3.780070] wlcore: Reading control info
[10/10/2025 20:51:28.604] [    3.780373] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.610] [    3.781624] wlcore: Reading control info
[10/10/2025 20:51:28.610] [    3.781927] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.621] [    3.783174] wlcore: Reading control info
[10/10/2025 20:51:28.621] [    3.783473] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.629] [    3.784715] wlcore: Reading control info
[10/10/2025 20:51:28.629] [    3.785015] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.635] [    3.786258] wlcore: Reading control info
[10/10/2025 20:51:28.637] [    3.786558] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.643] [    3.787803] wlcore: Reading control info
[10/10/2025 20:51:28.652] [    3.788106] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.652] [    3.789348] wlcore: Reading control info
[10/10/2025 20:51:28.654] [    3.789650] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.660] [    3.790898] wlcore: Reading control info
[10/10/2025 20:51:28.668] [    3.791202] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.670] [    3.792451] wlcore: Reading control info
[10/10/2025 20:51:28.670] [    3.792752] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.677] [    3.793995] wlcore: Reading control info
[10/10/2025 20:51:28.687] [    3.794295] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.687] [    3.795541] wlcore: Reading control info
[10/10/2025 20:51:28.695] [    3.795841] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.695] [    3.797083] wlcore: Reading control info
[10/10/2025 20:51:28.702] [    3.797382] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.704] [    3.798630] wlcore: Reading control info
[10/10/2025 20:51:28.710] [    3.798930] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.718] [    3.800191] wlcore: Reading control info
[10/10/2025 20:51:28.718] [    3.800495] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.720] [    3.801740] wlcore: Reading control info
[10/10/2025 20:51:28.726] [    3.802042] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.737] [    3.803287] wlcore: Reading control info
[10/10/2025 20:51:28.737] [    3.803585] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.737] [    3.804831] wlcore: Reading control info
[10/10/2025 20:51:28.744] [    3.805133] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.754] [    3.806376] wlcore: Reading control info
[10/10/2025 20:51:28.754] [    3.806677] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.763] [    3.807918] wlcore: Reading control info
[10/10/2025 20:51:28.763] [    3.808221] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.769] [    3.809463] wlcore: Reading control info
[10/10/2025 20:51:28.770] [    3.809763] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.777] [    3.811048] wlcore: Reading control info
[10/10/2025 20:51:28.777] [    3.811350] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.785] [    3.812595] wlcore: Reading control info
[10/10/2025 20:51:28.787] [    3.812897] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.793] [    3.814139] wlcore: Reading control info
[10/10/2025 20:51:28.802] [    3.814439] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.804] [    3.815683] wlcore: Reading control info
[10/10/2025 20:51:28.804] [    3.815981] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.813] [    3.817218] wlcore: Reading control info
[10/10/2025 20:51:28.820] [    3.817517] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.820] [    3.818763] wlcore: Reading control info
[10/10/2025 20:51:28.820] [    3.819064] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.826] [    3.820321] wlcore: Reading control info
[10/10/2025 20:51:28.835] [    3.820619] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.837] [    3.821869] wlcore: Reading control info
[10/10/2025 20:51:28.843] [    3.822173] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.852] [    3.823421] wlcore: Reading control info
[10/10/2025 20:51:28.852] [    3.823721] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.854] [    3.824971] wlcore: Reading control info
[10/10/2025 20:51:28.860] [    3.825271] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.868] [    3.826515] wlcore: Reading control info
[10/10/2025 20:51:28.868] [    3.826813] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.879] [    3.828066] wlcore: Reading control info
[10/10/2025 20:51:28.879] [    3.828369] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.888] [    3.829613] wlcore: Reading control info
[10/10/2025 20:51:28.888] [    3.829927] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.894] [    3.831175] wlcore: Reading control info
[10/10/2025 20:51:28.894] [    3.831479] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.902] [    3.832722] wlcore: Reading control info
[10/10/2025 20:51:28.904] [    3.833025] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.910] [    3.834272] wlcore: Reading control info
[10/10/2025 20:51:28.910] [    3.834573] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.918] [    3.835820] wlcore: Reading control info
[10/10/2025 20:51:28.920] [    3.836122] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.926] [    3.837368] wlcore: Reading control info
[10/10/2025 20:51:28.935] [    3.837666] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.935] [    3.838911] wlcore: Reading control info
[10/10/2025 20:51:28.937] [    3.839210] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.947] [    3.840472] wlcore: Reading control info
[10/10/2025 20:51:28.953] [    3.840775] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.954] [    3.842021] wlcore: Reading control info
[10/10/2025 20:51:28.954] [    3.842321] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.960] [    3.843565] wlcore: Reading control info
[10/10/2025 20:51:28.968] [    3.843866] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.970] [    3.845111] wlcore: Reading control info
[10/10/2025 20:51:28.976] [    3.845411] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.976] [    3.846653] wlcore: Reading control info
[10/10/2025 20:51:28.985] [    3.846954] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:28.987] [    3.848187] wlcore: Reading control info
[10/10/2025 20:51:28.994] [    3.848486] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.002] [    3.849729] wlcore: Reading control info
[10/10/2025 20:51:29.002] [    3.850044] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.013] [    3.851295] wlcore: Reading control info
[10/10/2025 20:51:29.013] [    3.851593] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.027] [    3.852840] wlcore: Reading control info
[10/10/2025 20:51:29.027] [    3.853140] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.027] [    3.854388] wlcore: Reading control info
[10/10/2025 20:51:29.038] [    3.854688] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.038] [    3.855937] wlcore: Reading control info
[10/10/2025 20:51:29.038] [    3.856238] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.055] [    3.857484] wlcore: Reading control info
[10/10/2025 20:51:29.055] [    3.857786] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.055] [    3.859031] wlcore: Reading control info
[10/10/2025 20:51:29.056] [    3.859333] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.060] [    3.860594] wlcore: Reading control info
[10/10/2025 20:51:29.060] [    3.860895] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.068] [    3.862143] wlcore: Reading control info
[10/10/2025 20:51:29.071] [    3.862444] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.078] [    3.863693] wlcore: Reading control info
[10/10/2025 20:51:29.090] [    3.863993] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.090] [    3.865239] wlcore: Reading control info
[10/10/2025 20:51:29.090] [    3.865539] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.105] [    3.866779] wlcore: Reading control info
[10/10/2025 20:51:29.105] [    3.867075] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.110] [    3.868316] wlcore: Reading control info
[10/10/2025 20:51:29.110] [    3.868615] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.111] [    3.869874] wlcore: Reading control info
[10/10/2025 20:51:29.119] [    3.870180] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.121] [    3.871429] wlcore: Reading control info
[10/10/2025 20:51:29.128] [    3.871729] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.135] [    3.872972] wlcore: Reading control info
[10/10/2025 20:51:29.135] [    3.873271] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.137] [    3.874517] wlcore: Reading control info
[10/10/2025 20:51:29.144] [    3.874816] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.163] [    3.876058] wlcore: Reading control info
[10/10/2025 20:51:29.163] [    3.876357] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.163] [    3.877601] wlcore: Reading control info
[10/10/2025 20:51:29.175] [    3.877900] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.175] [    3.879146] wlcore: Reading control info
[10/10/2025 20:51:29.181] [    3.879447] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.181] [    3.880692] wlcore: Reading control info
[10/10/2025 20:51:29.181] [    3.880995] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.189] [    3.882243] wlcore: Reading control info
[10/10/2025 20:51:29.194] [    3.882545] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.194] [    3.883787] wlcore: Reading control info
[10/10/2025 20:51:29.194] [    3.884095] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.203] [    3.885337] wlcore: Reading control info
[10/10/2025 20:51:29.204] [    3.885638] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.227] [    3.886883] wlcore: Reading control info
[10/10/2025 20:51:29.227] [    3.887184] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.227] [    3.888427] wlcore: Reading control info
[10/10/2025 20:51:29.227] [    3.888726] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.227] [    3.889992] wlcore: Reading control info
[10/10/2025 20:51:29.236] [    3.890287] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.237] [    3.891526] wlcore: Reading control info
[10/10/2025 20:51:29.237] [    3.891823] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.244] [    3.893069] wlcore: Reading control info
[10/10/2025 20:51:29.252] [    3.893370] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.254] [    3.894614] wlcore: Reading control info
[10/10/2025 20:51:29.261] [    3.894913] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.261] [    3.896158] wlcore: Reading control info
[10/10/2025 20:51:29.269] [    3.896455] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.271] [    3.897693] wlcore: Reading control info
[10/10/2025 20:51:29.279] [    3.897995] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.298] [    3.899242] wlcore: Reading control info
[10/10/2025 20:51:29.298] [    3.899546] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.298] [    3.900789] wlcore: Reading control info
[10/10/2025 20:51:29.298] [    3.901096] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.311] [    3.902340] wlcore: Reading control info
[10/10/2025 20:51:29.311] [    3.902638] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.311] [    3.903882] wlcore: Reading control info
[10/10/2025 20:51:29.348] [    3.904182] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.348] [    3.905425] wlcore: Reading control info
[10/10/2025 20:51:29.348] [    3.905726] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.348] [    3.906970] wlcore: Reading control info
[10/10/2025 20:51:29.348] [    3.907270] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.348] [    3.908509] wlcore: Reading control info
[10/10/2025 20:51:29.348] [    3.908811] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.348] [    3.910076] wlcore: Reading control info
[10/10/2025 20:51:29.348] [    3.910377] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.386] [    3.911620] wlcore: Reading control info
[10/10/2025 20:51:29.386] [    3.911921] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.386] [    3.913164] wlcore: Reading control info
[10/10/2025 20:51:29.386] [    3.913467] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.386] [    3.914712] wlcore: Reading control info
[10/10/2025 20:51:29.386] [    3.915010] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.386] [    3.916256] wlcore: Reading control info
[10/10/2025 20:51:29.386] [    3.916555] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.387] [    3.917796] wlcore: Reading control info
[10/10/2025 20:51:29.387] [    3.918097] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.423] [    3.919345] wlcore: Reading control info
[10/10/2025 20:51:29.423] [    3.919645] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.423] [    3.920895] wlcore: Reading control info
[10/10/2025 20:51:29.423] [    3.921199] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.423] [    3.922444] wlcore: Reading control info
[10/10/2025 20:51:29.423] [    3.922747] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.423] [    3.923993] wlcore: Reading control info
[10/10/2025 20:51:29.426] [    3.924295] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.435] [    3.925538] wlcore: Reading control info
[10/10/2025 20:51:29.435] [    3.925839] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.437] [    3.927093] wlcore: Reading control info
[10/10/2025 20:51:29.444] [    3.927393] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.463] [    3.928643] wlcore: Reading control info
[10/10/2025 20:51:29.463] [    3.928942] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.463] [    3.930208] wlcore: Reading control info
[10/10/2025 20:51:29.463] [    3.930511] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.473] [    3.931761] wlcore: Reading control info
[10/10/2025 20:51:29.479] [    3.932065] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.479] [    3.933307] wlcore: Reading control info
[10/10/2025 20:51:29.479] [    3.933607] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.488] [    3.934847] wlcore: Reading control info
[10/10/2025 20:51:29.488] [    3.935150] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.495] [    3.936392] wlcore: Reading control info
[10/10/2025 20:51:29.505] [    3.936695] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.505] [    3.937940] wlcore: Reading control info
[10/10/2025 20:51:29.505] [    3.938240] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.529] [    3.939490] wlcore: Reading control info
[10/10/2025 20:51:29.529] [    3.939789] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.529] [    3.941105] wlcore: Reading control info
[10/10/2025 20:51:29.529] [    3.941413] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.529] [    3.942658] wlcore: Reading control info
[10/10/2025 20:51:29.539] [    3.942959] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.546] [    3.944205] wlcore: Reading control info
[10/10/2025 20:51:29.552] [    3.944509] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.552] [    3.945754] wlcore: Reading control info
[10/10/2025 20:51:29.557] [    3.946053] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.562] [    3.947294] wlcore: Reading control info
[10/10/2025 20:51:29.562] [    3.947592] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.569] [    3.948838] wlcore: Reading control info
[10/10/2025 20:51:29.569] [    3.949138] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.570] [    3.950400] wlcore: Reading control info
[10/10/2025 20:51:29.577] [    3.950706] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.587] [    3.951954] wlcore: Reading control info
[10/10/2025 20:51:29.587] [    3.952255] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.587] [    3.953500] wlcore: Reading control info
[10/10/2025 20:51:29.608] [    3.953799] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.608] [    3.955044] wlcore: Reading control info
[10/10/2025 20:51:29.608] [    3.955348] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.611] [    3.956594] wlcore: Reading control info
[10/10/2025 20:51:29.611] [    3.956899] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.620] [    3.958140] wlcore: Reading control info
[10/10/2025 20:51:29.621] [    3.958440] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.629] [    3.959682] wlcore: Reading control info
[10/10/2025 20:51:29.629] [    3.959998] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.637] [    3.961239] wlcore: Reading control info
[10/10/2025 20:51:29.637] [    3.961542] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.644] [    3.962788] wlcore: Reading control info
[10/10/2025 20:51:29.654] [    3.963088] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.654] [    3.964331] wlcore: Reading control info
[10/10/2025 20:51:29.654] [    3.964629] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.662] [    3.965869] wlcore: Reading control info
[10/10/2025 20:51:29.683] [    3.966169] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.683] [    3.967410] wlcore: Reading control info
[10/10/2025 20:51:29.683] [    3.967709] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.683] [    3.968956] wlcore: Reading control info
[10/10/2025 20:51:29.686] [    3.969255] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.687] [    3.970514] wlcore: Reading control info
[10/10/2025 20:51:29.694] [    3.970815] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.703] [    3.972061] wlcore: Reading control info
[10/10/2025 20:51:29.703] [    3.972362] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.704] [    3.973607] wlcore: Reading control info
[10/10/2025 20:51:29.710] [    3.973907] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.721] [    3.975154] wlcore: Reading control info
[10/10/2025 20:51:29.721] [    3.975457] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.721] [    3.976703] wlcore: Reading control info
[10/10/2025 20:51:29.728] [    3.977002] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.736] [    3.978244] wlcore: Reading control info
[10/10/2025 20:51:29.737] [    3.978542] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.743] [    3.979785] wlcore: Reading control info
[10/10/2025 20:51:29.743] [    3.980125] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.760] [    3.981375] wlcore: Reading control info
[10/10/2025 20:51:29.760] [    3.981672] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.763] [    3.982927] wlcore: Reading control info
[10/10/2025 20:51:29.763] [    3.983229] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.779] [    3.984475] wlcore: Reading control info
[10/10/2025 20:51:29.779] [    3.984777] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.779] [    3.986018] wlcore: Reading control info
[10/10/2025 20:51:29.797] [    3.986314] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.797] [    3.987564] wlcore: Reading control info
[10/10/2025 20:51:29.797] [    3.987867] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.797] [    3.989108] wlcore: Reading control info
[10/10/2025 20:51:29.798] [    3.989410] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.804] [    3.990667] wlcore: Reading control info
[10/10/2025 20:51:29.804] [    3.990975] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.810] [    3.992224] wlcore: Reading control info
[10/10/2025 20:51:29.819] [    3.992526] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.821] [    3.993771] wlcore: Reading control info
[10/10/2025 20:51:29.832] [    3.994074] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.832] [    3.995316] wlcore: Reading control info
[10/10/2025 20:51:29.839] [    3.995614] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.844] [    3.996859] wlcore: Reading control info
[10/10/2025 20:51:29.847] [    3.997161] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.854] [    3.998403] wlcore: Reading control info
[10/10/2025 20:51:29.854] [    3.998705] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.854] [    3.999965] wlcore: Reading control info
[10/10/2025 20:51:29.862] [    4.000267] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.870] [    4.001518] wlcore: Reading control info
[10/10/2025 20:51:29.870] [    4.001815] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.870] [    4.003062] wlcore: Reading control info
[10/10/2025 20:51:29.879] [    4.003365] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.904] [    4.004610] wlcore: Reading control info
[10/10/2025 20:51:29.904] [    4.004910] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.904] [    4.006151] wlcore: Reading control info
[10/10/2025 20:51:29.904] [    4.006450] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.904] [    4.007695] wlcore: Reading control info
[10/10/2025 20:51:29.904] [    4.007996] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.912] [    4.009242] wlcore: Reading control info
[10/10/2025 20:51:29.912] [    4.009542] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.921] [    4.010792] wlcore: Reading control info
[10/10/2025 20:51:29.921] [    4.011101] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.927] [    4.012349] wlcore: Reading control info
[10/10/2025 20:51:29.937] [    4.012650] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.937] [    4.013892] wlcore: Reading control info
[10/10/2025 20:51:29.937] [    4.014193] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.945] [    4.015440] wlcore: Reading control info
[10/10/2025 20:51:29.952] [    4.015740] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.954] [    4.016983] wlcore: Reading control info
[10/10/2025 20:51:29.954] [    4.017282] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.961] [    4.018525] wlcore: Reading control info
[10/10/2025 20:51:29.970] [    4.018823] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.982] [    4.020076] wlcore: Reading control info
[10/10/2025 20:51:29.982] [    4.020376] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.987] [    4.021612] wlcore: Reading control info
[10/10/2025 20:51:29.987] [    4.021908] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:29.987] [    4.023144] wlcore: Reading control info
[10/10/2025 20:51:29.995] [    4.023442] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.003] [    4.024675] wlcore: Reading control info
[10/10/2025 20:51:30.003] [    4.024969] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.004] [    4.026202] wlcore: Reading control info
[10/10/2025 20:51:30.012] [    4.026497] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.021] [    4.027731] wlcore: Reading control info
[10/10/2025 20:51:30.021] [    4.028024] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.027] [    4.029262] wlcore: Reading control info
[10/10/2025 20:51:30.027] [    4.029560] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.047] [    4.030810] wlcore: Reading control info
[10/10/2025 20:51:30.047] [    4.031115] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.047] [    4.032360] wlcore: Reading control info
[10/10/2025 20:51:30.047] [    4.032664] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.049] [    4.033914] wlcore: Reading control info
[10/10/2025 20:51:30.054] [    4.034215] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.063] [    4.035456] wlcore: Reading control info
[10/10/2025 20:51:30.068] [    4.035752] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.068] [    4.036997] wlcore: Reading control info
[10/10/2025 20:51:30.070] [    4.037297] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.077] [    4.038540] wlcore: Reading control info
[10/10/2025 20:51:30.085] [    4.038840] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.087] [    4.040106] wlcore: Reading control info
[10/10/2025 20:51:30.087] [    4.040411] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.094] [    4.041659] wlcore: Reading control info
[10/10/2025 20:51:30.102] [    4.041964] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.111] [    4.043203] wlcore: Reading control info
[10/10/2025 20:51:30.113] [    4.043503] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.113] [    4.044752] wlcore: Reading control info
[10/10/2025 20:51:30.122] [    4.045053] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.122] [    4.046298] wlcore: Reading control info
[10/10/2025 20:51:30.127] [    4.046596] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.135] [    4.047837] wlcore: Reading control info
[10/10/2025 20:51:30.135] [    4.048141] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.137] [    4.049390] wlcore: Reading control info
[10/10/2025 20:51:30.143] [    4.049692] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.154] [    4.050940] wlcore: Reading control info
[10/10/2025 20:51:30.154] [    4.051238] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.154] [    4.052481] wlcore: Reading control info
[10/10/2025 20:51:30.160] [    4.052779] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.169] [    4.054020] wlcore: Reading control info
[10/10/2025 20:51:30.171] [    4.054322] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.179] [    4.055565] wlcore: Reading control info
[10/10/2025 20:51:30.179] [    4.055865] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.186] [    4.057113] wlcore: Reading control info
[10/10/2025 20:51:30.187] [    4.057413] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.194] [    4.058656] wlcore: Reading control info
[10/10/2025 20:51:30.194] [    4.058955] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.202] [    4.060212] wlcore: Reading control info
[10/10/2025 20:51:30.204] [    4.060513] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.210] [    4.061760] wlcore: Reading control info
[10/10/2025 20:51:30.218] [    4.062061] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.220] [    4.063307] wlcore: Reading control info
[10/10/2025 20:51:30.220] [    4.063604] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.226] [    4.064853] wlcore: Reading control info
[10/10/2025 20:51:30.235] [    4.065154] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.237] [    4.066397] wlcore: Reading control info
[10/10/2025 20:51:30.237] [    4.066697] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.246] [    4.067948] wlcore: Reading control info
[10/10/2025 20:51:30.254] [    4.068248] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.254] [    4.069490] wlcore: Reading control info
[10/10/2025 20:51:30.260] [    4.069792] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.269] [    4.071078] wlcore: Reading control info
[10/10/2025 20:51:30.269] [    4.071379] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.270] [    4.072624] wlcore: Reading control info
[10/10/2025 20:51:30.277] [    4.072922] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.285] [    4.074166] wlcore: Reading control info
[10/10/2025 20:51:30.285] [    4.074465] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.287] [    4.075710] wlcore: Reading control info
[10/10/2025 20:51:30.293] [    4.076011] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.302] [    4.077257] wlcore: Reading control info
[10/10/2025 20:51:30.304] [    4.077557] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.312] [    4.078800] wlcore: Reading control info
[10/10/2025 20:51:30.312] [    4.079102] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.320] [    4.080362] wlcore: Reading control info
[10/10/2025 20:51:30.321] [    4.080665] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.327] [    4.081918] wlcore: Reading control info
[10/10/2025 20:51:30.327] [    4.082216] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.335] [    4.083460] wlcore: Reading control info
[10/10/2025 20:51:30.337] [    4.083760] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.343] [    4.085002] wlcore: Reading control info
[10/10/2025 20:51:30.352] [    4.085304] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.352] [    4.086547] wlcore: Reading control info
[10/10/2025 20:51:30.354] [    4.086846] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.360] [    4.088092] wlcore: Reading control info
[10/10/2025 20:51:30.369] [    4.088394] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.371] [    4.089640] wlcore: Reading control info
[10/10/2025 20:51:30.371] [    4.089956] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.380] [    4.091203] wlcore: Reading control info
[10/10/2025 20:51:30.387] [    4.091505] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.387] [    4.092749] wlcore: Reading control info
[10/10/2025 20:51:30.393] [    4.093051] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.393] [    4.094293] wlcore: Reading control info
[10/10/2025 20:51:30.402] [    4.094593] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.404] [    4.095836] wlcore: Reading control info
[10/10/2025 20:51:30.410] [    4.096135] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.418] [    4.097385] wlcore: Reading control info
[10/10/2025 20:51:30.418] [    4.097683] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.420] [    4.098930] wlcore: Reading control info
[10/10/2025 20:51:30.426] [    4.099232] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.437] [    4.100491] wlcore: Reading control info
[10/10/2025 20:51:30.437] [    4.100791] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.437] [    4.102033] wlcore: Reading control info
[10/10/2025 20:51:30.446] [    4.102333] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.454] [    4.103578] wlcore: Reading control info
[10/10/2025 20:51:30.454] [    4.103879] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.460] [    4.105118] wlcore: Reading control info
[10/10/2025 20:51:30.460] [    4.105418] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.468] [    4.106663] wlcore: Reading control info
[10/10/2025 20:51:30.470] [    4.106962] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.476] [    4.108209] wlcore: Reading control info
[10/10/2025 20:51:30.476] [    4.108507] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.485] [    4.109760] wlcore: Reading control info
[10/10/2025 20:51:30.487] [    4.110070] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.493] [    4.111319] wlcore: Reading control info
[10/10/2025 20:51:30.502] [    4.111620] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.504] [    4.112864] wlcore: Reading control info
[10/10/2025 20:51:30.504] [    4.113165] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.511] [    4.114414] wlcore: Reading control info
[10/10/2025 20:51:30.521] [    4.114710] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.521] [    4.115953] wlcore: Reading control info
[10/10/2025 20:51:30.521] [    4.116253] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.527] [    4.117495] wlcore: Reading control info
[10/10/2025 20:51:30.535] [    4.117792] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.537] [    4.119036] wlcore: Reading control info
[10/10/2025 20:51:30.543] [    4.119334] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.552] [    4.120587] wlcore: Reading control info
[10/10/2025 20:51:30.552] [    4.120890] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.554] [    4.122137] wlcore: Reading control info
[10/10/2025 20:51:30.560] [    4.122437] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.568] [    4.123690] wlcore: Reading control info
[10/10/2025 20:51:30.568] [    4.123990] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.577] [    4.125234] wlcore: Reading control info
[10/10/2025 20:51:30.579] [    4.125531] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.587] [    4.126777] wlcore: Reading control info
[10/10/2025 20:51:30.587] [    4.127074] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.594] [    4.128321] wlcore: Reading control info
[10/10/2025 20:51:30.594] [    4.128623] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.601] [    4.129878] wlcore: Reading control info
[10/10/2025 20:51:30.604] [    4.130177] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.610] [    4.131424] wlcore: Reading control info
[10/10/2025 20:51:30.610] [    4.131724] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.618] [    4.132974] wlcore: Reading control info
[10/10/2025 20:51:30.620] [    4.133277] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.626] [    4.134521] wlcore: Reading control info
[10/10/2025 20:51:30.635] [    4.134825] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.635] [    4.136069] wlcore: Reading control info
[10/10/2025 20:51:30.638] [    4.136370] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.645] [    4.137615] wlcore: Reading control info
[10/10/2025 20:51:30.654] [    4.137915] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.654] [    4.139162] wlcore: Reading control info
[10/10/2025 20:51:30.654] [    4.139464] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.660] [    4.140705] wlcore: Reading control info
[10/10/2025 20:51:30.668] [    4.141004] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.670] [    4.142248] wlcore: Reading control info
[10/10/2025 20:51:30.677] [    4.142548] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.677] [    4.143792] wlcore: Reading control info
[10/10/2025 20:51:30.685] [    4.144094] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.687] [    4.145343] wlcore: Reading control info
[10/10/2025 20:51:30.693] [    4.145643] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.702] [    4.146889] wlcore: Reading control info
[10/10/2025 20:51:30.702] [    4.147189] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.704] [    4.148439] wlcore: Reading control info
[10/10/2025 20:51:30.712] [    4.148737] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.720] [    4.149992] wlcore: Reading control info
[10/10/2025 20:51:30.720] [    4.150290] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.720] [    4.151535] wlcore: Reading control info
[10/10/2025 20:51:30.727] [    4.151840] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.735] [    4.153082] wlcore: Reading control info
[10/10/2025 20:51:30.737] [    4.153381] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.743] [    4.154626] wlcore: Reading control info
[10/10/2025 20:51:30.743] [    4.154926] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.752] [    4.156172] wlcore: Reading control info
[10/10/2025 20:51:30.754] [    4.156474] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.760] [    4.157721] wlcore: Reading control info
[10/10/2025 20:51:30.760] [    4.158021] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.768] [    4.159268] wlcore: Reading control info
[10/10/2025 20:51:30.771] [    4.159571] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.779] [    4.160818] wlcore: Reading control info
[10/10/2025 20:51:30.787] [    4.161121] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.787] [    4.162372] wlcore: Reading control info
[10/10/2025 20:51:30.787] [    4.162672] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.793] [    4.163915] wlcore: Reading control info
[10/10/2025 20:51:30.802] [    4.164219] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.804] [    4.165459] wlcore: Reading control info
[10/10/2025 20:51:30.804] [    4.165760] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.810] [    4.167005] wlcore: Reading control info
[10/10/2025 20:51:30.818] [    4.167303] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.820] [    4.168549] wlcore: Reading control info
[10/10/2025 20:51:30.827] [    4.168849] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.835] [    4.170105] wlcore: Reading control info
[10/10/2025 20:51:30.835] [    4.170406] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.837] [    4.171656] wlcore: Reading control info
[10/10/2025 20:51:30.846] [    4.171956] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.854] [    4.173197] wlcore: Reading control info
[10/10/2025 20:51:30.854] [    4.173501] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.854] [    4.174750] wlcore: Reading control info
[10/10/2025 20:51:30.860] [    4.175052] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.869] [    4.176293] wlcore: Reading control info
[10/10/2025 20:51:30.870] [    4.176592] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.877] [    4.177837] wlcore: Reading control info
[10/10/2025 20:51:30.877] [    4.178133] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.885] [    4.179381] wlcore: Reading control info
[10/10/2025 20:51:30.887] [    4.179683] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.893] [    4.180932] wlcore: Reading control info
[10/10/2025 20:51:30.893] [    4.181235] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.902] [    4.182481] wlcore: Reading control info
[10/10/2025 20:51:30.904] [    4.182782] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.914] [    4.184027] wlcore: Reading control info
[10/10/2025 20:51:30.920] [    4.184323] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.920] [    4.185569] wlcore: Reading control info
[10/10/2025 20:51:30.920] [    4.185869] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.927] [    4.187114] wlcore: Reading control info
[10/10/2025 20:51:30.935] [    4.187415] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.937] [    4.188663] wlcore: Reading control info
[10/10/2025 20:51:30.937] [    4.188963] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.943] [    4.190225] wlcore: Reading control info
[10/10/2025 20:51:30.952] [    4.190527] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.954] [    4.191774] wlcore: Reading control info
[10/10/2025 20:51:30.960] [    4.192074] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.960] [    4.193314] wlcore: Reading control info
[10/10/2025 20:51:30.969] [    4.193613] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.971] [    4.194862] wlcore: Reading control info
[10/10/2025 20:51:30.979] [    4.195162] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.987] [    4.196404] wlcore: Reading control info
[10/10/2025 20:51:30.987] [    4.196704] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:30.987] [    4.197952] wlcore: Reading control info
[10/10/2025 20:51:30.993] [    4.198251] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.004] [    4.199495] wlcore: Reading control info
[10/10/2025 20:51:31.004] [    4.199797] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.004] [    4.201088] wlcore: Reading control info
[10/10/2025 20:51:31.010] [    4.201387] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.018] [    4.202631] wlcore: Reading control info
[10/10/2025 20:51:31.020] [    4.202934] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.027] [    4.204179] wlcore: Reading control info
[10/10/2025 20:51:31.027] [    4.204481] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.035] [    4.205725] wlcore: Reading control info
[10/10/2025 20:51:31.037] [    4.206028] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.046] [    4.207279] wlcore: Reading control info
[10/10/2025 20:51:31.046] [    4.207576] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.054] [    4.208831] wlcore: Reading control info
[10/10/2025 20:51:31.054] [    4.209131] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.060] [    4.210389] wlcore: Reading control info
[10/10/2025 20:51:31.068] [    4.210688] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.070] [    4.211933] wlcore: Reading control info
[10/10/2025 20:51:31.070] [    4.212234] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.076] [    4.213476] wlcore: Reading control info
[10/10/2025 20:51:31.085] [    4.213773] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.087] [    4.215013] wlcore: Reading control info
[10/10/2025 20:51:31.087] [    4.215315] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.093] [    4.216566] wlcore: Reading control info
[10/10/2025 20:51:31.102] [    4.216865] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.104] [    4.218108] wlcore: Reading control info
[10/10/2025 20:51:31.112] [    4.218409] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.120] [    4.219653] wlcore: Reading control info
[10/10/2025 20:51:31.120] [    4.219970] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.120] [    4.221213] wlcore: Reading control info
[10/10/2025 20:51:31.127] [    4.221511] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.135] [    4.222761] wlcore: Reading control info
[10/10/2025 20:51:31.135] [    4.223062] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.137] [    4.224306] wlcore: Reading control info
[10/10/2025 20:51:31.143] [    4.224604] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.151] [    4.225851] wlcore: Reading control info
[10/10/2025 20:51:31.154] [    4.226154] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.160] [    4.227400] wlcore: Reading control info
[10/10/2025 20:51:31.160] [    4.227700] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.169] [    4.228946] wlcore: Reading control info
[10/10/2025 20:51:31.171] [    4.229248] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.177] [    4.230506] wlcore: Reading control info
[10/10/2025 20:51:31.177] [    4.230806] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.186] [    4.232052] wlcore: Reading control info
[10/10/2025 20:51:31.188] [    4.232353] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.194] [    4.233600] wlcore: Reading control info
[10/10/2025 20:51:31.201] [    4.233900] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.201] [    4.235142] wlcore: Reading control info
[10/10/2025 20:51:31.204] [    4.235442] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.210] [    4.236688] wlcore: Reading control info
[10/10/2025 20:51:31.218] [    4.236988] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.220] [    4.238234] wlcore: Reading control info
[10/10/2025 20:51:31.220] [    4.238534] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.226] [    4.239780] wlcore: Reading control info
[10/10/2025 20:51:31.235] [    4.240168] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.237] [    4.241448] wlcore: Reading control info
[10/10/2025 20:51:31.244] [    4.241751] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.244] [    4.242997] wlcore: Reading control info
[10/10/2025 20:51:31.254] [    4.243302] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.254] [    4.244550] wlcore: Reading control info
[10/10/2025 20:51:31.260] [    4.244848] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.268] [    4.246093] wlcore: Reading control info
[10/10/2025 20:51:31.268] [    4.246394] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.270] [    4.247633] wlcore: Reading control info
[10/10/2025 20:51:31.276] [    4.247928] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.287] [    4.249170] wlcore: Reading control info
[10/10/2025 20:51:31.287] [    4.249470] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.287] [    4.250727] wlcore: Reading control info
[10/10/2025 20:51:31.293] [    4.251033] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.302] [    4.252277] wlcore: Reading control info
[10/10/2025 20:51:31.304] [    4.252578] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.312] [    4.253824] wlcore: Reading control info
[10/10/2025 20:51:31.312] [    4.254129] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.320] [    4.255373] wlcore: Reading control info
[10/10/2025 20:51:31.321] [    4.255672] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.327] [    4.256917] wlcore: Reading control info
[10/10/2025 20:51:31.327] [    4.257217] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.335] [    4.258465] wlcore: Reading control info
[10/10/2025 20:51:31.337] [    4.258764] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.343] [    4.260025] wlcore: Reading control info
[10/10/2025 20:51:31.352] [    4.260328] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.354] [    4.261572] wlcore: Reading control info
[10/10/2025 20:51:31.354] [    4.261875] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.360] [    4.263119] wlcore: Reading control info
[10/10/2025 20:51:31.369] [    4.263417] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.371] [    4.264662] wlcore: Reading control info
[10/10/2025 20:51:31.371] [    4.264964] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.379] [    4.266210] wlcore: Reading control info
[10/10/2025 20:51:31.387] [    4.266516] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.387] [    4.267758] wlcore: Reading control info
[10/10/2025 20:51:31.394] [    4.268059] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.401] [    4.269301] wlcore: Reading control info
[10/10/2025 20:51:31.401] [    4.269602] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.404] [    4.270848] wlcore: Reading control info
[10/10/2025 20:51:31.410] [    4.271148] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.418] [    4.272391] wlcore: Reading control info
[10/10/2025 20:51:31.418] [    4.272690] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.420] [    4.273932] wlcore: Reading control info
[10/10/2025 20:51:31.427] [    4.274231] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.435] [    4.275476] wlcore: Reading control info
[10/10/2025 20:51:31.437] [    4.275778] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.445] [    4.277028] wlcore: Reading control info
[10/10/2025 20:51:31.445] [    4.277332] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.453] [    4.278581] wlcore: Reading control info
[10/10/2025 20:51:31.454] [    4.278889] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.460] [    4.280148] wlcore: Reading control info
[10/10/2025 20:51:31.460] [    4.280451] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.469] [    4.281695] wlcore: Reading control info
[10/10/2025 20:51:31.470] [    4.281993] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.477] [    4.283235] wlcore: Reading control info
[10/10/2025 20:51:31.485] [    4.283537] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.485] [    4.284779] wlcore: Reading control info
[10/10/2025 20:51:31.487] [    4.285076] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.493] [    4.286326] wlcore: Reading control info
[10/10/2025 20:51:31.502] [    4.286622] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.505] [    4.287870] wlcore: Reading control info
[10/10/2025 20:51:31.505] [    4.288169] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.513] [    4.289406] wlcore: Reading control info
[10/10/2025 20:51:31.522] [    4.289707] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.527] [    4.290956] wlcore: Reading control info
[10/10/2025 20:51:31.527] [    4.291263] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.527] [    4.292509] wlcore: Reading control info
[10/10/2025 20:51:31.535] [    4.292817] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.537] [    4.294061] wlcore: Reading control info
[10/10/2025 20:51:31.544] [    4.294361] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.551] [    4.295604] wlcore: Reading control info
[10/10/2025 20:51:31.551] [    4.295903] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.554] [    4.297143] wlcore: Reading control info
[10/10/2025 20:51:31.560] [    4.297445] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.572] [    4.298691] wlcore: Reading control info
[10/10/2025 20:51:31.572] [    4.298991] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.572] [    4.300246] wlcore: Reading control info
[10/10/2025 20:51:31.582] [    4.300541] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.587] [    4.301777] wlcore: Reading control info
[10/10/2025 20:51:31.587] [    4.302071] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.593] [    4.303300] wlcore: Reading control info
[10/10/2025 20:51:31.593] [    4.303593] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.602] [    4.304826] wlcore: Reading control info
[10/10/2025 20:51:31.604] [    4.305122] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.610] [    4.306352] wlcore: Reading control info
[10/10/2025 20:51:31.610] [    4.306648] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.619] [    4.307885] wlcore: Reading control info
[10/10/2025 20:51:31.620] [    4.308180] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.627] [    4.309419] wlcore: Reading control info
[10/10/2025 20:51:31.636] [    4.309711] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.638] [    4.310969] wlcore: Reading control info
[10/10/2025 20:51:31.638] [    4.311272] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.645] [    4.312522] wlcore: Reading control info
[10/10/2025 20:51:31.654] [    4.312824] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.654] [    4.314070] wlcore: Reading control info
[10/10/2025 20:51:31.654] [    4.314375] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.660] [    4.315618] wlcore: Reading control info
[10/10/2025 20:51:31.669] [    4.315916] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.670] [    4.317159] wlcore: Reading control info
[10/10/2025 20:51:31.677] [    4.317464] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.685] [    4.318706] wlcore: Reading control info
[10/10/2025 20:51:31.685] [    4.319004] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.687] [    4.320261] wlcore: Reading control info
[10/10/2025 20:51:31.693] [    4.320565] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.702] [    4.321815] wlcore: Reading control info
[10/10/2025 20:51:31.702] [    4.322117] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.704] [    4.323360] wlcore: Reading control info
[10/10/2025 20:51:31.712] [    4.323663] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.720] [    4.324908] wlcore: Reading control info
[10/10/2025 20:51:31.721] [    4.325210] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.727] [    4.326459] wlcore: Reading control info
[10/10/2025 20:51:31.727] [    4.326761] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.735] [    4.328007] wlcore: Reading control info
[10/10/2025 20:51:31.737] [    4.328311] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.744] [    4.329553] wlcore: Reading control info
[10/10/2025 20:51:31.744] [    4.329870] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.752] [    4.331118] wlcore: Reading control info
[10/10/2025 20:51:31.754] [    4.331420] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.760] [    4.332666] wlcore: Reading control info
[10/10/2025 20:51:31.769] [    4.332967] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.769] [    4.334209] wlcore: Reading control info
[10/10/2025 20:51:31.771] [    4.334510] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.779] [    4.335762] wlcore: Reading control info
[10/10/2025 20:51:31.787] [    4.336062] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.787] [    4.337308] wlcore: Reading control info
[10/10/2025 20:51:31.787] [    4.337612] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.794] [    4.338853] wlcore: Reading control info
[10/10/2025 20:51:31.801] [    4.339156] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.804] [    4.340412] wlcore: Reading control info
[10/10/2025 20:51:31.810] [    4.340713] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.810] [    4.341957] wlcore: Reading control info
[10/10/2025 20:51:31.818] [    4.342255] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.820] [    4.343498] wlcore: Reading control info
[10/10/2025 20:51:31.826] [    4.343798] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.835] [    4.345046] wlcore: Reading control info
[10/10/2025 20:51:31.835] [    4.345346] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.838] [    4.346592] wlcore: Reading control info
[10/10/2025 20:51:31.846] [    4.346891] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.854] [    4.348130] wlcore: Reading control info
[10/10/2025 20:51:31.854] [    4.348428] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.854] [    4.349673] wlcore: Reading control info
[10/10/2025 20:51:31.860] [    4.349992] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.868] [    4.351233] wlcore: Reading control info
[10/10/2025 20:51:31.870] [    4.351533] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.877] [    4.352779] wlcore: Reading control info
[10/10/2025 20:51:31.877] [    4.353080] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.885] [    4.354327] wlcore: Reading control info
[10/10/2025 20:51:31.887] [    4.354629] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.893] [    4.355873] wlcore: Reading control info
[10/10/2025 20:51:31.893] [    4.356174] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.902] [    4.357418] wlcore: Reading control info
[10/10/2025 20:51:31.904] [    4.357721] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.912] [    4.358968] wlcore: Reading control info
[10/10/2025 20:51:31.921] [    4.359272] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.921] [    4.360531] wlcore: Reading control info
[10/10/2025 20:51:31.921] [    4.360831] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.927] [    4.362080] wlcore: Reading control info
[10/10/2025 20:51:31.935] [    4.362382] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.937] [    4.363631] wlcore: Reading control info
[10/10/2025 20:51:31.937] [    4.363935] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.943] [    4.365183] wlcore: Reading control info
[10/10/2025 20:51:31.952] [    4.365479] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.954] [    4.366725] wlcore: Reading control info
[10/10/2025 20:51:31.960] [    4.367028] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.969] [    4.368280] wlcore: Reading control info
[10/10/2025 20:51:31.969] [    4.368583] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.971] [    4.369843] wlcore: Reading control info
[10/10/2025 20:51:31.979] [    4.370147] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.987] [    4.371395] wlcore: Reading control info
[10/10/2025 20:51:31.987] [    4.371696] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:31.987] [    4.372940] wlcore: Reading control info
[10/10/2025 20:51:31.993] [    4.373240] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.002] [    4.374483] wlcore: Reading control info
[10/10/2025 20:51:32.004] [    4.374781] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.010] [    4.376025] wlcore: Reading control info
[10/10/2025 20:51:32.010] [    4.376323] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.018] [    4.377570] wlcore: Reading control info
[10/10/2025 20:51:32.020] [    4.377874] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.026] [    4.379124] wlcore: Reading control info
[10/10/2025 20:51:32.026] [    4.379423] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.035] [    4.380679] wlcore: Reading control info
[10/10/2025 20:51:32.038] [    4.380980] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.046] [    4.382224] wlcore: Reading control info
[10/10/2025 20:51:32.053] [    4.382524] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.053] [    4.383767] wlcore: Reading control info
[10/10/2025 20:51:32.054] [    4.384073] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.060] [    4.385319] wlcore: Reading control info
[10/10/2025 20:51:32.069] [    4.385621] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.070] [    4.386864] wlcore: Reading control info
[10/10/2025 20:51:32.070] [    4.387165] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.077] [    4.388410] wlcore: Reading control info
[10/10/2025 20:51:32.085] [    4.388710] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.087] [    4.389975] wlcore: Reading control info
[10/10/2025 20:51:32.093] [    4.390274] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.093] [    4.391526] wlcore: Reading control info
[10/10/2025 20:51:32.102] [    4.391829] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.104] [    4.393067] wlcore: Reading control info
[10/10/2025 20:51:32.112] [    4.393365] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.120] [    4.394611] wlcore: Reading control info
[10/10/2025 20:51:32.120] [    4.394908] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.121] [    4.396149] wlcore: Reading control info
[10/10/2025 20:51:32.127] [    4.396451] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.137] [    4.397698] wlcore: Reading control info
[10/10/2025 20:51:32.137] [    4.397995] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.137] [    4.399238] wlcore: Reading control info
[10/10/2025 20:51:32.143] [    4.399538] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.152] [    4.400789] wlcore: Reading control info
[10/10/2025 20:51:32.154] [    4.401091] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.160] [    4.402334] wlcore: Reading control info
[10/10/2025 20:51:32.160] [    4.402633] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.169] [    4.403884] wlcore: Reading control info
[10/10/2025 20:51:32.171] [    4.404187] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.179] [    4.405433] wlcore: Reading control info
[10/10/2025 20:51:32.179] [    4.405732] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.187] [    4.406974] wlcore: Reading control info
[10/10/2025 20:51:32.187] [    4.407273] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.194] [    4.408520] wlcore: Reading control info
[10/10/2025 20:51:32.202] [    4.408821] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.204] [    4.410082] wlcore: Reading control info
[10/10/2025 20:51:32.204] [    4.410387] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.210] [    4.411632] wlcore: Reading control info
[10/10/2025 20:51:32.218] [    4.411935] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.220] [    4.413178] wlcore: Reading control info
[10/10/2025 20:51:32.220] [    4.413482] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.227] [    4.414730] wlcore: Reading control info
[10/10/2025 20:51:32.235] [    4.415032] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.238] [    4.416283] wlcore: Reading control info
[10/10/2025 20:51:32.245] [    4.416583] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.253] [    4.417826] wlcore: Reading control info
[10/10/2025 20:51:32.253] [    4.418128] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.254] [    4.419378] wlcore: Reading control info
[10/10/2025 20:51:32.260] [    4.419686] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.269] [    4.420923] wlcore: Reading control info
[10/10/2025 20:51:32.269] [    4.421219] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.270] [    4.422453] wlcore: Reading control info
[10/10/2025 20:51:32.277] [    4.422749] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.285] [    4.423979] wlcore: Reading control info
[10/10/2025 20:51:32.287] [    4.424274] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.293] [    4.425503] wlcore: Reading control info
[10/10/2025 20:51:32.293] [    4.425795] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.302] [    4.427032] wlcore: Reading control info
[10/10/2025 20:51:32.311] [    4.427327] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.313] [    4.428564] wlcore: Reading control info
[10/10/2025 20:51:32.313] [    4.428859] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.322] [    4.430126] wlcore: Reading control info
[10/10/2025 20:51:32.322] [    4.430463] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.327] [    4.431879] wlcore: Reading control info
[10/10/2025 20:51:32.335] [    4.432184] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.335] [    4.433427] wlcore: Reading control info
[10/10/2025 20:51:32.337] [    4.433732] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.343] [    4.434972] wlcore: Reading control info
[10/10/2025 20:51:32.352] [    4.435273] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.354] [    4.436511] wlcore: Reading control info
[10/10/2025 20:51:32.354] [    4.436807] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.360] [    4.438045] wlcore: Reading control info
[10/10/2025 20:51:32.369] [    4.438341] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.371] [    4.439573] wlcore: Reading control info
[10/10/2025 20:51:32.379] [    4.439902] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.379] [    4.441164] wlcore: Reading control info
[10/10/2025 20:51:32.387] [    4.441464] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.388] [    4.442704] wlcore: Reading control info
[10/10/2025 20:51:32.394] [    4.443002] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.402] [    4.444238] wlcore: Reading control info
[10/10/2025 20:51:32.402] [    4.444531] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.404] [    4.445762] wlcore: Reading control info
[10/10/2025 20:51:32.410] [    4.446054] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.420] [    4.447285] wlcore: Reading control info
[10/10/2025 20:51:32.420] [    4.447586] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.420] [    4.448820] wlcore: Reading control info
[10/10/2025 20:51:32.426] [    4.449114] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.435] [    4.450357] wlcore: Reading control info
[10/10/2025 20:51:32.437] [    4.450653] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.445] [    4.451885] wlcore: Reading control info
[10/10/2025 20:51:32.445] [    4.452179] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.453] [    4.453411] wlcore: Reading control info
[10/10/2025 20:51:32.454] [    4.453704] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.460] [    4.454935] wlcore: Reading control info
[10/10/2025 20:51:32.460] [    4.455227] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.469] [    4.456462] wlcore: Reading control info
[10/10/2025 20:51:32.470] [    4.456759] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.477] [    4.457995] wlcore: Reading control info
[10/10/2025 20:51:32.485] [    4.458290] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.487] [    4.459518] wlcore: Reading control info
[10/10/2025 20:51:32.487] [    4.459875] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.493] [    4.461266] wlcore: Reading control info
[10/10/2025 20:51:32.502] [    4.461568] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.504] [    4.462811] wlcore: Reading control info
[10/10/2025 20:51:32.504] [    4.463105] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.512] [    4.464341] wlcore: Reading control info
[10/10/2025 20:51:32.520] [    4.464636] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.521] [    4.465867] wlcore: Reading control info
[10/10/2025 20:51:32.527] [    4.466158] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.535] [    4.467390] wlcore: Reading control info
[10/10/2025 20:51:32.535] [    4.467683] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.537] [    4.468913] wlcore: Reading control info
[10/10/2025 20:51:32.543] [    4.469208] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.552] [    4.470451] wlcore: Reading control info
[10/10/2025 20:51:32.552] [    4.470751] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.554] [    4.471985] wlcore: Reading control info
[10/10/2025 20:51:32.560] [    4.472280] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.569] [    4.473519] wlcore: Reading control info
[10/10/2025 20:51:32.571] [    4.473813] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.579] [    4.475041] wlcore: Reading control info
[10/10/2025 20:51:32.579] [    4.475335] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.586] [    4.476567] wlcore: Reading control info
[10/10/2025 20:51:32.587] [    4.476863] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.594] [    4.478096] wlcore: Reading control info
[10/10/2025 20:51:32.594] [    4.478388] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.602] [    4.479616] wlcore: Reading control info
[10/10/2025 20:51:32.604] [    4.479918] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.610] [    4.481157] wlcore: Reading control info
[10/10/2025 20:51:32.618] [    4.481450] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.618] [    4.482683] wlcore: Reading control info
[10/10/2025 20:51:32.620] [    4.482975] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.627] [    4.484207] wlcore: Reading control info
[10/10/2025 20:51:32.635] [    4.484499] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.637] [    4.485729] wlcore: Reading control info
[10/10/2025 20:51:32.637] [    4.486024] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.647] [    4.487253] wlcore: Reading control info
[10/10/2025 20:51:32.654] [    4.487546] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.654] [    4.488775] wlcore: Reading control info
[10/10/2025 20:51:32.660] [    4.489071] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.660] [    4.490343] wlcore: Reading control info
[10/10/2025 20:51:32.669] [    4.490649] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.670] [    4.491895] wlcore: Reading control info
[10/10/2025 20:51:32.677] [    4.492192] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.685] [    4.493429] wlcore: Reading control info
[10/10/2025 20:51:32.685] [    4.493722] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.687] [    4.494954] wlcore: Reading control info
[10/10/2025 20:51:32.693] [    4.495247] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.704] [    4.496476] wlcore: Reading control info
[10/10/2025 20:51:32.704] [    4.496773] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.704] [    4.498007] wlcore: Reading control info
[10/10/2025 20:51:32.712] [    4.498305] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.720] [    4.499541] wlcore: Reading control info
[10/10/2025 20:51:32.721] [    4.499888] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.727] [    4.501149] wlcore: Reading control info
[10/10/2025 20:51:32.727] [    4.501444] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.735] [    4.502690] wlcore: Reading control info
[10/10/2025 20:51:32.737] [    4.502987] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.743] [    4.504222] wlcore: Reading control info
[10/10/2025 20:51:32.743] [    4.504517] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.752] [    4.505752] wlcore: Reading control info
[10/10/2025 20:51:32.754] [    4.506047] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.760] [    4.507282] wlcore: Reading control info
[10/10/2025 20:51:32.769] [    4.507580] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.770] [    4.508810] wlcore: Reading control info
[10/10/2025 20:51:32.770] [    4.509100] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.778] [    4.510343] wlcore: Reading control info
[10/10/2025 20:51:32.787] [    4.510641] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.787] [    4.511874] wlcore: Reading control info
[10/10/2025 20:51:32.787] [    4.512170] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.794] [    4.513399] wlcore: Reading control info
[10/10/2025 20:51:32.802] [    4.513695] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.804] [    4.514921] wlcore: Reading control info
[10/10/2025 20:51:32.810] [    4.515212] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.818] [    4.516453] wlcore: Reading control info
[10/10/2025 20:51:32.818] [    4.516750] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.820] [    4.517977] wlcore: Reading control info
[10/10/2025 20:51:32.826] [    4.518272] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.835] [    4.519499] wlcore: Reading control info
[10/10/2025 20:51:32.835] [    4.519794] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.838] [    4.521106] wlcore: Reading control info
[10/10/2025 20:51:32.846] [    4.521411] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.854] [    4.522655] wlcore: Reading control info
[10/10/2025 20:51:32.854] [    4.522960] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.860] [    4.524209] wlcore: Reading control info
[10/10/2025 20:51:32.860] [    4.524509] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.869] [    4.525753] wlcore: Reading control info
[10/10/2025 20:51:32.870] [    4.526055] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.877] [    4.527301] wlcore: Reading control info
[10/10/2025 20:51:32.877] [    4.527602] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.885] [    4.528851] wlcore: Reading control info
[10/10/2025 20:51:32.887] [    4.529152] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.893] [    4.530413] wlcore: Reading control info
[10/10/2025 20:51:32.902] [    4.530711] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.902] [    4.531948] wlcore: Reading control info
[10/10/2025 20:51:32.904] [    4.532243] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.912] [    4.533480] wlcore: Reading control info
[10/10/2025 20:51:32.920] [    4.533776] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.920] [    4.535004] wlcore: Reading control info
[10/10/2025 20:51:32.920] [    4.535297] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.927] [    4.536531] wlcore: Reading control info
[10/10/2025 20:51:32.935] [    4.536828] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.937] [    4.538066] wlcore: Reading control info
[10/10/2025 20:51:32.943] [    4.538361] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.943] [    4.539598] wlcore: Reading control info
[10/10/2025 20:51:32.952] [    4.539902] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.954] [    4.541167] wlcore: Reading control info
[10/10/2025 20:51:32.960] [    4.541473] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.969] [    4.542715] wlcore: Reading control info
[10/10/2025 20:51:32.969] [    4.543015] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.971] [    4.544265] wlcore: Reading control info
[10/10/2025 20:51:32.979] [    4.544567] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.987] [    4.545811] wlcore: Reading control info
[10/10/2025 20:51:32.987] [    4.546111] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:32.987] [    4.547355] wlcore: Reading control info
[10/10/2025 20:51:32.995] [    4.547657] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.002] [    4.548898] wlcore: Reading control info
[10/10/2025 20:51:33.004] [    4.549198] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.010] [    4.550458] wlcore: Reading control info
[10/10/2025 20:51:33.010] [    4.550762] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.018] [    4.552007] wlcore: Reading control info
[10/10/2025 20:51:33.020] [    4.552312] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.026] [    4.553561] wlcore: Reading control info
[10/10/2025 20:51:33.026] [    4.553861] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.035] [    4.555106] wlcore: Reading control info
[10/10/2025 20:51:33.038] [    4.555411] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.046] [    4.556657] wlcore: Reading control info
[10/10/2025 20:51:33.054] [    4.556959] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.054] [    4.558203] wlcore: Reading control info
[10/10/2025 20:51:33.054] [    4.558505] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.060] [    4.559753] wlcore: Reading control info
[10/10/2025 20:51:33.069] [    4.560059] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.070] [    4.561304] wlcore: Reading control info
[10/10/2025 20:51:33.070] [    4.561606] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.076] [    4.562853] wlcore: Reading control info
[10/10/2025 20:51:33.085] [    4.563155] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.087] [    4.564404] wlcore: Reading control info
[10/10/2025 20:51:33.093] [    4.564704] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.101] [    4.565951] wlcore: Reading control info
[10/10/2025 20:51:33.101] [    4.566254] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.104] [    4.567498] wlcore: Reading control info
[10/10/2025 20:51:33.112] [    4.567797] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.120] [    4.569043] wlcore: Reading control info
[10/10/2025 20:51:33.120] [    4.569344] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.120] [    4.570601] wlcore: Reading control info
[10/10/2025 20:51:33.127] [    4.570906] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.135] [    4.572152] wlcore: Reading control info
[10/10/2025 20:51:33.137] [    4.572456] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.143] [    4.573700] wlcore: Reading control info
[10/10/2025 20:51:33.143] [    4.574000] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.152] [    4.575249] wlcore: Reading control info
[10/10/2025 20:51:33.154] [    4.575550] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.160] [    4.576793] wlcore: Reading control info
[10/10/2025 20:51:33.160] [    4.577091] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.168] [    4.578330] wlcore: Reading control info
[10/10/2025 20:51:33.171] [    4.578632] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.179] [    4.579892] wlcore: Reading control info
[10/10/2025 20:51:33.188] [    4.580194] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.188] [    4.581439] wlcore: Reading control info
[10/10/2025 20:51:33.188] [    4.581738] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.194] [    4.582981] wlcore: Reading control info
[10/10/2025 20:51:33.202] [    4.583280] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.204] [    4.584525] wlcore: Reading control info
[10/10/2025 20:51:33.204] [    4.584824] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.210] [    4.586069] wlcore: Reading control info
[10/10/2025 20:51:33.218] [    4.586374] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.220] [    4.587624] wlcore: Reading control info
[10/10/2025 20:51:33.227] [    4.587922] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.227] [    4.589167] wlcore: Reading control info
[10/10/2025 20:51:33.235] [    4.589468] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.237] [    4.590717] wlcore: Reading control info
[10/10/2025 20:51:33.246] [    4.591018] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.254] [    4.592268] wlcore: Reading control info
[10/10/2025 20:51:33.254] [    4.592569] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.254] [    4.593816] wlcore: Reading control info
[10/10/2025 20:51:33.260] [    4.594117] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.270] [    4.595366] wlcore: Reading control info
[10/10/2025 20:51:33.270] [    4.595666] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.270] [    4.596910] wlcore: Reading control info
[10/10/2025 20:51:33.276] [    4.597210] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.285] [    4.598454] wlcore: Reading control info
[10/10/2025 20:51:33.287] [    4.598755] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.293] [    4.600015] wlcore: Reading control info
[10/10/2025 20:51:33.293] [    4.600315] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.302] [    4.601563] wlcore: Reading control info
[10/10/2025 20:51:33.304] [    4.601864] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.312] [    4.603110] wlcore: Reading control info
[10/10/2025 20:51:33.312] [    4.603410] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.320] [    4.604651] wlcore: Reading control info
[10/10/2025 20:51:33.320] [    4.604950] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.327] [    4.606196] wlcore: Reading control info
[10/10/2025 20:51:33.335] [    4.606495] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.337] [    4.607736] wlcore: Reading control info
[10/10/2025 20:51:33.337] [    4.608037] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.343] [    4.609282] wlcore: Reading control info
[10/10/2025 20:51:33.351] [    4.609583] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.354] [    4.610833] wlcore: Reading control info
[10/10/2025 20:51:33.354] [    4.611133] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.360] [    4.612422] wlcore: Reading control info
[10/10/2025 20:51:33.369] [    4.612721] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.371] [    4.613966] wlcore: Reading control info
[10/10/2025 20:51:33.379] [    4.614266] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.387] [    4.615510] wlcore: Reading control info
[10/10/2025 20:51:33.387] [    4.615812] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.387] [    4.617059] wlcore: Reading control info
[10/10/2025 20:51:33.394] [    4.617359] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.402] [    4.618606] wlcore: Reading control info
[10/10/2025 20:51:33.402] [    4.618907] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.404] [    4.620156] wlcore: Reading control info
[10/10/2025 20:51:33.410] [    4.620458] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.419] [    4.621703] wlcore: Reading control info
[10/10/2025 20:51:33.420] [    4.622005] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.426] [    4.623250] wlcore: Reading control info
[10/10/2025 20:51:33.426] [    4.623552] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.435] [    4.624795] wlcore: Reading control info
[10/10/2025 20:51:33.437] [    4.625097] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.445] [    4.626341] wlcore: Reading control info
[10/10/2025 20:51:33.445] [    4.626644] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.454] [    4.627888] wlcore: Reading control info
[10/10/2025 20:51:33.454] [    4.628187] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.460] [    4.629431] wlcore: Reading control info
[10/10/2025 20:51:33.469] [    4.629728] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.469] [    4.630982] wlcore: Reading control info
[10/10/2025 20:51:33.470] [    4.631285] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.476] [    4.632529] wlcore: Reading control info
[10/10/2025 20:51:33.485] [    4.632833] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.487] [    4.634084] wlcore: Reading control info
[10/10/2025 20:51:33.487] [    4.634384] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.493] [    4.635620] wlcore: Reading control info
[10/10/2025 20:51:33.502] [    4.635919] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.504] [    4.637311] wlcore: Reading control info
[10/10/2025 20:51:33.512] [    4.637612] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.512] [    4.638889] wlcore: Reading control info
[10/10/2025 20:51:33.520] [    4.639187] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.521] [    4.640475] wlcore: Reading control info
[10/10/2025 20:51:33.527] [    4.640776] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.535] [    4.642048] wlcore: Reading control info
[10/10/2025 20:51:33.535] [    4.642346] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.537] [    4.643625] wlcore: Reading control info
[10/10/2025 20:51:33.543] [    4.643923] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.554] [    4.645196] wlcore: Reading control info
[10/10/2025 20:51:33.554] [    4.645496] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.554] [    4.646766] wlcore: Reading control info
[10/10/2025 20:51:33.560] [    4.647064] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.569] [    4.648333] wlcore: Reading control info
[10/10/2025 20:51:33.571] [    4.648631] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.579] [    4.649903] wlcore: Reading control info
[10/10/2025 20:51:33.579] [    4.650211] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.587] [    4.651482] wlcore: Reading control info
[10/10/2025 20:51:33.587] [    4.651785] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.593] [    4.653057] wlcore: Reading control info
[10/10/2025 20:51:33.593] [    4.653358] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.602] [    4.654634] wlcore: Reading control info
[10/10/2025 20:51:33.604] [    4.654936] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.610] [    4.656208] wlcore: Reading control info
[10/10/2025 20:51:33.618] [    4.656510] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.620] [    4.657791] wlcore: Reading control info
[10/10/2025 20:51:33.620] [    4.658094] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.626] [    4.659364] wlcore: Reading control info
[10/10/2025 20:51:33.635] [    4.659667] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.637] [    4.661006] wlcore: Reading control info
[10/10/2025 20:51:33.637] [    4.661307] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.645] [    4.662603] wlcore: Reading control info
[10/10/2025 20:51:33.653] [    4.662905] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.654] [    4.664200] wlcore: Reading control info
[10/10/2025 20:51:33.660] [    4.664500] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.668] [    4.665792] wlcore: Reading control info
[10/10/2025 20:51:33.668] [    4.666092] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.670] [    4.667387] wlcore: Reading control info
[10/10/2025 20:51:33.677] [    4.667685] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.685] [    4.668982] wlcore: Reading control info
[10/10/2025 20:51:33.685] [    4.669283] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.687] [    4.670595] wlcore: Reading control info
[10/10/2025 20:51:33.693] [    4.670898] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.702] [    4.672192] wlcore: Reading control info
[10/10/2025 20:51:33.704] [    4.672494] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.712] [    4.673789] wlcore: Reading control info
[10/10/2025 20:51:33.712] [    4.674091] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.720] [    4.675385] wlcore: Reading control info
[10/10/2025 20:51:33.720] [    4.675688] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.727] [    4.676986] wlcore: Reading control info
[10/10/2025 20:51:33.727] [    4.677284] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.735] [    4.678580] wlcore: Reading control info
[10/10/2025 20:51:33.737] [    4.678879] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.743] [    4.680191] wlcore: Reading control info
[10/10/2025 20:51:33.752] [    4.680492] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.752] [    4.681797] wlcore: Reading control info
[10/10/2025 20:51:33.754] [    4.682102] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.760] [    4.683413] wlcore: Reading control info
[10/10/2025 20:51:33.769] [    4.683712] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.771] [    4.685021] wlcore: Reading control info
[10/10/2025 20:51:33.771] [    4.685318] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.780] [    4.686637] wlcore: Reading control info
[10/10/2025 20:51:33.787] [    4.686938] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.787] [    4.688249] wlcore: Reading control info
[10/10/2025 20:51:33.793] [    4.688550] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.793] [    4.689896] wlcore: Reading control info
[10/10/2025 20:51:33.802] [    4.690203] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.804] [    4.691521] wlcore: Reading control info
[10/10/2025 20:51:33.810] [    4.691822] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.818] [    4.693973] wlcore: Reading control info
[10/10/2025 20:51:33.818] [    4.694276] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.820] [    4.695539] wlcore: Reading control info
[10/10/2025 20:51:33.827] [    4.695842] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.837] [    4.697103] wlcore: Reading control info
[10/10/2025 20:51:33.837] [    4.697401] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.837] [    4.698667] wlcore: Reading control info
[10/10/2025 20:51:33.846] [    4.698967] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.853] [    4.700244] wlcore: Reading control info
[10/10/2025 20:51:33.854] [    4.700545] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.860] [    4.701814] wlcore: Reading control info
[10/10/2025 20:51:33.860] [    4.702117] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.868] [    4.703383] wlcore: Reading control info
[10/10/2025 20:51:33.870] [    4.703685] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.877] [    4.704941] wlcore: Reading control info
[10/10/2025 20:51:33.877] [    4.705241] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.885] [    4.706505] wlcore: Reading control info
[10/10/2025 20:51:33.887] [    4.706806] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.893] [    4.708069] wlcore: Reading control info
[10/10/2025 20:51:33.902] [    4.708368] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.904] [    4.709633] wlcore: Reading control info
[10/10/2025 20:51:33.904] [    4.709951] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.912] [    4.711212] wlcore: Reading control info
[10/10/2025 20:51:33.920] [    4.711514] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.920] [    4.712771] wlcore: Reading control info
[10/10/2025 20:51:33.920] [    4.713074] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.927] [    4.714331] wlcore: Reading control info
[10/10/2025 20:51:33.935] [    4.714633] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.937] [    4.715894] wlcore: Reading control info
[10/10/2025 20:51:33.944] [    4.716201] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.951] [    4.717464] wlcore: Reading control info
[10/10/2025 20:51:33.951] [    4.717764] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.954] [    4.719022] wlcore: Reading control info
[10/10/2025 20:51:33.960] [    4.719320] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.969] [    4.720590] wlcore: Reading control info
[10/10/2025 20:51:33.969] [    4.720887] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.970] [    4.722140] wlcore: Reading control info
[10/10/2025 20:51:33.979] [    4.722430] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.987] [    4.723683] wlcore: Reading control info
[10/10/2025 20:51:33.988] [    4.723979] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:33.993] [    4.725231] wlcore: Reading control info
[10/10/2025 20:51:33.993] [    4.725526] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.002] [    4.726775] wlcore: Reading control info
[10/10/2025 20:51:34.004] [    4.727070] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.010] [    4.728319] wlcore: Reading control info
[10/10/2025 20:51:34.010] [    4.728612] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.018] [    4.729872] wlcore: Reading control info
[10/10/2025 20:51:34.020] [    4.730193] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.027] [    4.731474] wlcore: Reading control info
[10/10/2025 20:51:34.035] [    4.731779] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.035] [    4.733046] wlcore: Reading control info
[10/10/2025 20:51:34.037] [    4.733347] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.046] [    4.734606] wlcore: Reading control info
[10/10/2025 20:51:34.053] [    4.734905] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.054] [    4.736165] wlcore: Reading control info
[10/10/2025 20:51:34.054] [    4.736466] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.060] [    4.737731] wlcore: Reading control info
[10/10/2025 20:51:34.068] [    4.738032] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.070] [    4.739295] wlcore: Reading control info
[10/10/2025 20:51:34.076] [    4.739594] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.076] [    4.740858] wlcore: Reading control info
[10/10/2025 20:51:34.085] [    4.741159] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.087] [    4.742428] wlcore: Reading control info
[10/10/2025 20:51:34.093] [    4.742732] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.102] [    4.743995] wlcore: Reading control info
[10/10/2025 20:51:34.102] [    4.744294] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.104] [    4.745554] wlcore: Reading control info
[10/10/2025 20:51:34.113] [    4.745853] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.121] [    4.747117] wlcore: Reading control info
[10/10/2025 20:51:34.121] [    4.747416] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.121] [    4.748678] wlcore: Reading control info
[10/10/2025 20:51:34.127] [    4.748975] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.135] [    4.750249] wlcore: Reading control info
[10/10/2025 20:51:34.137] [    4.750551] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.143] [    4.751812] wlcore: Reading control info
[10/10/2025 20:51:34.143] [    4.752110] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.152] [    4.753367] wlcore: Reading control info
[10/10/2025 20:51:34.154] [    4.753669] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.160] [    4.754929] wlcore: Reading control info
[10/10/2025 20:51:34.160] [    4.755230] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.169] [    4.756493] wlcore: Reading control info
[10/10/2025 20:51:34.170] [    4.756799] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.179] [    4.758059] wlcore: Reading control info
[10/10/2025 20:51:34.186] [    4.758361] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.188] [    4.759623] wlcore: Reading control info
[10/10/2025 20:51:34.188] [    4.759938] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.194] [    4.761202] wlcore: Reading control info
[10/10/2025 20:51:34.202] [    4.761503] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.204] [    4.762768] wlcore: Reading control info
[10/10/2025 20:51:34.204] [    4.763071] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.210] [    4.764329] wlcore: Reading control info
[10/10/2025 20:51:34.218] [    4.764625] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.220] [    4.765892] wlcore: Reading control info
[10/10/2025 20:51:34.227] [    4.766192] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.235] [    4.767454] wlcore: Reading control info
[10/10/2025 20:51:34.235] [    4.767753] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.237] [    4.769018] wlcore: Reading control info
[10/10/2025 20:51:34.245] [    4.769323] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.254] [    4.770599] wlcore: Reading control info
[10/10/2025 20:51:34.254] [    4.770903] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.254] [    4.772156] wlcore: Reading control info
[10/10/2025 20:51:34.260] [    4.772458] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.269] [    4.773728] wlcore: Reading control info
[10/10/2025 20:51:34.270] [    4.774027] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.277] [    4.775294] wlcore: Reading control info
[10/10/2025 20:51:34.277] [    4.775595] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.285] [    4.776860] wlcore: Reading control info
[10/10/2025 20:51:34.287] [    4.777156] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.293] [    4.778414] wlcore: Reading control info
[10/10/2025 20:51:34.293] [    4.778715] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.302] [    4.779995] wlcore: Reading control info
[10/10/2025 20:51:34.304] [    4.780295] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.312] [    4.781554] wlcore: Reading control info
[10/10/2025 20:51:34.320] [    4.781856] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.320] [    4.783117] wlcore: Reading control info
[10/10/2025 20:51:34.321] [    4.783415] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.327] [    4.784676] wlcore: Reading control info
[10/10/2025 20:51:34.335] [    4.784976] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.337] [    4.786237] wlcore: Reading control info
[10/10/2025 20:51:34.337] [    4.786536] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.343] [    4.787794] wlcore: Reading control info
[10/10/2025 20:51:34.352] [    4.788095] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.354] [    4.789362] wlcore: Reading control info
[10/10/2025 20:51:34.360] [    4.789663] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.360] [    4.790929] wlcore: Reading control info
[10/10/2025 20:51:34.369] [    4.791235] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.371] [    4.792500] wlcore: Reading control info
[10/10/2025 20:51:34.379] [    4.792799] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.387] [    4.794063] wlcore: Reading control info
[10/10/2025 20:51:34.387] [    4.794363] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.387] [    4.795630] wlcore: Reading control info
[10/10/2025 20:51:34.394] [    4.795930] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.404] [    4.797195] wlcore: Reading control info
[10/10/2025 20:51:34.404] [    4.797495] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.404] [    4.798762] wlcore: Reading control info
[10/10/2025 20:51:34.410] [    4.799064] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.418] [    4.800340] wlcore: Reading control info
[10/10/2025 20:51:34.420] [    4.800643] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.427] [    4.801908] wlcore: Reading control info
[10/10/2025 20:51:34.427] [    4.802213] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.435] [    4.803476] wlcore: Reading control info
[10/10/2025 20:51:34.437] [    4.803773] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.446] [    4.805034] wlcore: Reading control info
[10/10/2025 20:51:34.446] [    4.805336] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.453] [    4.806598] wlcore: Reading control info
[10/10/2025 20:51:34.454] [    4.806898] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.460] [    4.808158] wlcore: Reading control info
[10/10/2025 20:51:34.469] [    4.808457] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.470] [    4.809719] wlcore: Reading control info
[10/10/2025 20:51:34.470] [    4.810032] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.476] [    4.811296] wlcore: Reading control info
[10/10/2025 20:51:34.485] [    4.811597] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.487] [    4.812860] wlcore: Reading control info
[10/10/2025 20:51:34.487] [    4.813161] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.493] [    4.814416] wlcore: Reading control info
[10/10/2025 20:51:34.502] [    4.814716] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.504] [    4.815977] wlcore: Reading control info
[10/10/2025 20:51:34.512] [    4.816280] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.520] [    4.817545] wlcore: Reading control info
[10/10/2025 20:51:34.520] [    4.817846] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.520] [    4.819110] wlcore: Reading control info
[10/10/2025 20:51:34.527] [    4.819407] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.535] [    4.820686] wlcore: Reading control info
[10/10/2025 20:51:34.535] [    4.820986] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.537] [    4.822249] wlcore: Reading control info
[10/10/2025 20:51:34.543] [    4.822550] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.552] [    4.823807] wlcore: Reading control info
[10/10/2025 20:51:34.554] [    4.824109] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.560] [    4.825371] wlcore: Reading control info
[10/10/2025 20:51:34.560] [    4.825668] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.568] [    4.826926] wlcore: Reading control info
[10/10/2025 20:51:34.571] [    4.827226] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.578] [    4.828495] wlcore: Reading control info
[10/10/2025 20:51:34.578] [    4.828796] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.587] [    4.830074] wlcore: Reading control info
[10/10/2025 20:51:34.587] [    4.830381] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.593] [    4.831690] wlcore: Reading control info
[10/10/2025 20:51:34.602] [    4.831991] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.602] [    4.833287] wlcore: Reading control info
[10/10/2025 20:51:34.604] [    4.833587] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.610] [    4.834898] wlcore: Reading control info
[10/10/2025 20:51:34.618] [    4.835198] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.620] [    4.836519] wlcore: Reading control info
[10/10/2025 20:51:34.620] [    4.836821] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.627] [    4.838112] wlcore: Reading control info
[10/10/2025 20:51:34.635] [    4.838415] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.637] [    4.839710] wlcore: Reading control info
[10/10/2025 20:51:34.645] [    4.840023] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.645] [    4.841319] wlcore: Reading control info
[10/10/2025 20:51:34.654] [    4.841616] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.654] [    4.842901] wlcore: Reading control info
[10/10/2025 20:51:34.660] [    4.843201] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.669] [    4.844493] wlcore: Reading control info
[10/10/2025 20:51:34.669] [    4.844793] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.670] [    4.846268] wlcore: Reading control info
[10/10/2025 20:51:34.677] [    4.846571] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.687] [    4.848052] wlcore: Reading control info
[10/10/2025 20:51:34.687] [    4.848358] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.687] [    4.849673] wlcore: Reading control info
[10/10/2025 20:51:34.693] [    4.849990] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.702] [    4.851275] wlcore: Reading control info
[10/10/2025 20:51:34.704] [    4.851574] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.712] [    4.852863] wlcore: Reading control info
[10/10/2025 20:51:34.712] [    4.853163] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.720] [    4.854451] wlcore: Reading control info
[10/10/2025 20:51:34.721] [    4.854756] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.727] [    4.856039] wlcore: Reading control info
[10/10/2025 20:51:34.727] [    4.856337] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.735] [    4.857629] wlcore: Reading control info
[10/10/2025 20:51:34.737] [    4.857927] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.743] [    4.859217] wlcore: Reading control info
[10/10/2025 20:51:34.752] [    4.859517] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.754] [    4.860804] wlcore: Reading control info
[10/10/2025 20:51:34.754] [    4.861104] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.760] [    4.862393] wlcore: Reading control info
[10/10/2025 20:51:34.769] [    4.862693] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.771] [    4.863978] wlcore: Reading control info
[10/10/2025 20:51:34.771] [    4.864281] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.779] [    4.865572] wlcore: Reading control info
[10/10/2025 20:51:34.787] [    4.865871] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.787] [    4.867188] wlcore: Reading control info
[10/10/2025 20:51:34.794] [    4.867488] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.802] [    4.868782] wlcore: Reading control info
[10/10/2025 20:51:34.802] [    4.869083] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.804] [    4.870419] wlcore: Reading control info
[10/10/2025 20:51:34.810] [    4.870723] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.818] [    4.872014] wlcore: Reading control info
[10/10/2025 20:51:34.818] [    4.872314] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.820] [    4.873608] wlcore: Reading control info
[10/10/2025 20:51:34.827] [    4.873905] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.835] [    4.875200] wlcore: Reading control info
[10/10/2025 20:51:34.837] [    4.875499] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.846] [    4.876793] wlcore: Reading control info
[10/10/2025 20:51:34.846] [    4.877095] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.853] [    4.878388] wlcore: Reading control info
[10/10/2025 20:51:34.854] [    4.878688] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.860] [    4.879988] wlcore: Reading control info
[10/10/2025 20:51:34.860] [    4.880288] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.869] [    4.881580] wlcore: Reading control info
[10/10/2025 20:51:34.870] [    4.881877] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.877] [    4.883168] wlcore: Reading control info
[10/10/2025 20:51:34.885] [    4.883471] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.885] [    4.884765] wlcore: Reading control info
[10/10/2025 20:51:34.887] [    4.885063] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.893] [    4.886943] wlcore: Reading control info
[10/10/2025 20:51:34.902] [    4.887241] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.904] [    4.888500] wlcore: Reading control info
[10/10/2025 20:51:34.904] [    4.888799] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.914] [    4.890069] wlcore: Reading control info
[10/10/2025 20:51:34.920] [    4.890372] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.920] [    4.891630] wlcore: Reading control info
[10/10/2025 20:51:34.927] [    4.891928] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.927] [    4.893179] wlcore: Reading control info
[10/10/2025 20:51:34.935] [    4.893480] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.937] [    4.894735] wlcore: Reading control info
[10/10/2025 20:51:34.943] [    4.895034] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.952] [    4.896290] wlcore: Reading control info
[10/10/2025 20:51:34.952] [    4.896590] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.954] [    4.897842] wlcore: Reading control info
[10/10/2025 20:51:34.960] [    4.898140] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.971] [    4.899394] wlcore: Reading control info
[10/10/2025 20:51:34.971] [    4.899692] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.971] [    4.900947] wlcore: Reading control info
[10/10/2025 20:51:34.978] [    4.901249] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.987] [    4.902505] wlcore: Reading control info
[10/10/2025 20:51:34.987] [    4.902804] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:34.994] [    4.904056] wlcore: Reading control info
[10/10/2025 20:51:34.994] [    4.904358] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.002] [    4.905618] wlcore: Reading control info
[10/10/2025 20:51:35.004] [    4.905916] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.010] [    4.907168] wlcore: Reading control info
[10/10/2025 20:51:35.010] [    4.907468] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.017] [    4.908720] wlcore: Reading control info
[10/10/2025 20:51:35.020] [    4.909020] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.026] [    4.910286] wlcore: Reading control info
[10/10/2025 20:51:35.035] [    4.910590] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.038] [    4.911841] wlcore: Reading control info
[10/10/2025 20:51:35.038] [    4.912143] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.046] [    4.913394] wlcore: Reading control info
[10/10/2025 20:51:35.053] [    4.913695] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.054] [    4.914949] wlcore: Reading control info
[10/10/2025 20:51:35.054] [    4.915247] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.060] [    4.916503] wlcore: Reading control info
[10/10/2025 20:51:35.069] [    4.916802] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.070] [    4.918055] wlcore: Reading control info
[10/10/2025 20:51:35.077] [    4.918354] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.085] [    4.919607] wlcore: Reading control info
[10/10/2025 20:51:35.085] [    4.919921] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.087] [    4.921173] wlcore: Reading control info
[10/10/2025 20:51:35.093] [    4.921475] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.102] [    4.922727] wlcore: Reading control info
[10/10/2025 20:51:35.102] [    4.923027] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.104] [    4.924285] wlcore: Reading control info
[10/10/2025 20:51:35.112] [    4.924586] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.120] [    4.925838] wlcore: Reading control info
[10/10/2025 20:51:35.120] [    4.926134] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.127] [    4.927389] wlcore: Reading control info
[10/10/2025 20:51:35.127] [    4.927688] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.135] [    4.928942] wlcore: Reading control info
[10/10/2025 20:51:35.137] [    4.929244] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.143] [    4.930509] wlcore: Reading control info
[10/10/2025 20:51:35.143] [    4.930809] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.152] [    4.932071] wlcore: Reading control info
[10/10/2025 20:51:35.154] [    4.932376] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.160] [    4.933634] wlcore: Reading control info
[10/10/2025 20:51:35.169] [    4.933933] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.169] [    4.935188] wlcore: Reading control info
[10/10/2025 20:51:35.171] [    4.935491] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.179] [    4.936750] wlcore: Reading control info
[10/10/2025 20:51:35.186] [    4.937052] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.187] [    4.938306] wlcore: Reading control info
[10/10/2025 20:51:35.187] [    4.938609] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.193] [    4.939876] wlcore: Reading control info
[10/10/2025 20:51:35.202] [    4.940177] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.204] [    4.941431] wlcore: Reading control info
[10/10/2025 20:51:35.210] [    4.941731] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.210] [    4.942987] wlcore: Reading control info
[10/10/2025 20:51:35.218] [    4.943287] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.220] [    4.944540] wlcore: Reading control info
[10/10/2025 20:51:35.226] [    4.944842] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.235] [    4.946092] wlcore: Reading control info
[10/10/2025 20:51:35.235] [    4.946394] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.238] [    4.947647] wlcore: Reading control info
[10/10/2025 20:51:35.246] [    4.947947] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.254] [    4.949195] wlcore: Reading control info
[10/10/2025 20:51:35.254] [    4.949493] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.254] [    4.950749] wlcore: Reading control info
[10/10/2025 20:51:35.260] [    4.951054] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.269] [    4.952305] wlcore: Reading control info
[10/10/2025 20:51:35.270] [    4.952604] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.276] [    4.953854] wlcore: Reading control info
[10/10/2025 20:51:35.276] [    4.954154] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.285] [    4.955403] wlcore: Reading control info
[10/10/2025 20:51:35.287] [    4.955705] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.293] [    4.956959] wlcore: Reading control info
[10/10/2025 20:51:35.293] [    4.957259] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.302] [    4.958518] wlcore: Reading control info
[10/10/2025 20:51:35.304] [    4.958817] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.312] [    4.960083] wlcore: Reading control info
[10/10/2025 20:51:35.321] [    4.960384] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.321] [    4.961637] wlcore: Reading control info
[10/10/2025 20:51:35.321] [    4.961937] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.327] [    4.963189] wlcore: Reading control info
[10/10/2025 20:51:35.335] [    4.963488] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.337] [    4.964739] wlcore: Reading control info
[10/10/2025 20:51:35.337] [    4.965041] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.343] [    4.966297] wlcore: Reading control info
[10/10/2025 20:51:35.352] [    4.966597] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.354] [    4.967853] wlcore: Reading control info
[10/10/2025 20:51:35.360] [    4.968153] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.369] [    4.969402] wlcore: Reading control info
[10/10/2025 20:51:35.369] [    4.969703] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.371] [    4.970957] wlcore: Reading control info
[10/10/2025 20:51:35.379] [    4.971261] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.387] [    4.972518] wlcore: Reading control info
[10/10/2025 20:51:35.387] [    4.972822] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.387] [    4.974081] wlcore: Reading control info
[10/10/2025 20:51:35.394] [    4.974380] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.402] [    4.975642] wlcore: Reading control info
[10/10/2025 20:51:35.404] [    4.975943] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.410] [    4.977203] wlcore: Reading control info
[10/10/2025 20:51:35.410] [    4.977505] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.418] [    4.978762] wlcore: Reading control info
[10/10/2025 20:51:35.420] [    4.979062] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.427] [    4.980332] wlcore: Reading control info
[10/10/2025 20:51:35.427] [    4.980631] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.435] [    4.981886] wlcore: Reading control info
[10/10/2025 20:51:35.437] [    4.982188] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.446] [    4.983442] wlcore: Reading control info
[10/10/2025 20:51:35.454] [    4.983743] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.454] [    4.984993] wlcore: Reading control info
[10/10/2025 20:51:35.454] [    4.985294] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.460] [    4.986546] wlcore: Reading control info
[10/10/2025 20:51:35.469] [    4.986843] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.470] [    4.988096] wlcore: Reading control info
[10/10/2025 20:51:35.470] [    4.988394] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.477] [    4.989647] wlcore: Reading control info
[10/10/2025 20:51:35.485] [    4.989966] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.487] [    4.991223] wlcore: Reading control info
[10/10/2025 20:51:35.493] [    4.991527] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.493] [    4.992785] wlcore: Reading control info
[10/10/2025 20:51:35.502] [    4.993083] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.504] [    4.994340] wlcore: Reading control info
[10/10/2025 20:51:35.512] [    4.994641] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.520] [    4.995985] wlcore: Reading control info
[10/10/2025 20:51:35.520] [    4.996286] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.521] [    4.997536] wlcore: Reading control info
[10/10/2025 20:51:35.527] [    4.997835] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.537] [    4.999146] wlcore: Reading control info
[10/10/2025 20:51:35.537] [    4.999447] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.537] [    5.000706] wlcore: Reading control info
[10/10/2025 20:51:35.543] [    5.001008] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.551] [    5.002262] wlcore: Reading control info
[10/10/2025 20:51:35.554] [    5.002565] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.560] [    5.002608] wlcore: Suspending IRQ while device reboots
[10/10/2025 20:51:35.569] [    5.269847] wlcore: Resuming IRQ
[10/10/2025 20:51:35.569] [    5.270047] wlcore: Reading control info
[10/10/2025 20:51:35.571] [    5.270356] wlcore: Processing message type 2, len 4
[10/10/2025 20:51:35.580] [    5.295689] wlcore: BOOT IRQs: 0x20
[10/10/2025 20:51:35.580] [    5.340008] wlcore: ti-connectivity/cc33xx_fw.bin loaded successfully
[10/10/2025 20:51:35.587] [    5.340298] wlcore: Downloading INI Params and Configurations to FW, INI Bin File Payload Length: 1282
[10/10/2025 20:51:35.593] [    5.341263] wlcore: Reading control info
[10/10/2025 20:51:35.602] [    5.341570] wlcore: Processing message type 2, len 3
[10/10/2025 20:51:35.604] [    5.341615] wlcore: CMD# 37, len=1300
[10/10/2025 20:51:35.604] [    5.341628] wlcore: INI Params downloaded successfully
[10/10/2025 20:51:35.610] [    5.343805] wlcore: BOOT IRQs: 0x40
[10/10/2025 20:51:35.618] [    5.410012] wlcore: Chip is PG2, No static calibration needed
[10/10/2025 20:51:35.620] [    5.410030] wlcore: acx mem map
[10/10/2025 20:51:35.627] [    5.410040] wlcore: cmd interrogate
[10/10/2025 20:51:35.627] [    5.410535] wlcore: Reading control info
[10/10/2025 20:51:35.636] [    5.410837] wlcore: Processing message type 2, len 20
[10/10/2025 20:51:35.637] [    5.410879] wlcore: Response len 20, allocated buffer len 32
[10/10/2025 20:51:35.646] [    5.410894] wlcore: CMD# 28, len=16
[10/10/2025 20:51:35.646] [    5.410906] wlcore: Skipping cc33xx_hw_init
[10/10/2025 20:51:35.654] [    5.410918] wlcore: 11a is supported
[10/10/2025 20:51:35.654] [    5.410940] wlcore: Wireless driver version 1.7.0.239
[10/10/2025 20:51:35.661] [    5.410952] wlcore: acx get FW versions
[10/10/2025 20:51:35.661] [    5.410960] wlcore: cmd interrogate
[10/10/2025 20:51:35.668] [    5.411453] wlcore: Reading control info
[10/10/2025 20:51:35.670] [    5.411755] wlcore: Processing message type 2, len 28
[10/10/2025 20:51:35.677] [    5.411796] wlcore: Response len 28, allocated buffer len 36
[10/10/2025 20:51:35.685] [    5.411811] wlcore: CMD# 28, len=36
[10/10/2025 20:51:35.685] [    5.411828] wlcore: Wireless firmware version 1.7.0.323
[10/10/2025 20:51:35.687] [    5.411848] wlcore: Wireless PHY version 1.2.0.47.6.13.37.69
[10/10/2025 20:51:35.693] [    5.411869] wlcore: Wifi6 disable efuse:0, ini:1
[10/10/2025 20:51:35.702] [    5.411884] wlcore: MAC address derived from EFUSE
[10/10/2025 20:51:35.704] [    5.411900] wlcore: Base MAC address: 74:02:e1:20:ec:30
[10/10/2025 20:51:35.712] [    5.412400] wlcore: Reading control info
[10/10/2025 20:51:35.720] [    5.412703] wlcore: Processing message type 2, len 3
[10/10/2025 20:51:35.720] [    5.412750] wlcore: CMD# 38, len=20
[10/10/2025 20:51:35.721] [    5.414927] wlcore: loaded
[10/10/2025 20:51:35.727] [    5.414947] wlcore: wlcore_nvs_cb Complete
[10/10/2025 20:51:35.752] root@smm-m2d ~ #
[10/10/2025 20:51:37.207] root@smm-m2d ~ # echo 8 > /proc/sys/kernel/printk
[10/10/2025 20:51:42.884] root@smm-m2d ~ # modprobe -r cc33xx
[10/10/2025 20:51:50.014] [  107.760197] wlcore: Turning off
[10/10/2025 20:51:52.869] root@smm-m2d ~ # modprobe -r cc33xx_sdio
[10/10/2025 20:52:06.886] root@smm-m2d ~ # modprobe -r btti_sdio
[10/10/2025 20:52:18.404] [  136.148445] Bluetooth: [bt sdio] BLE SDIO exit module
[10/10/2025 20:52:18.404] [  136.153773] Bluetooth: [bt sdio if] sdio remove
[10/10/2025 20:52:18.429] [  136.158326] Bluetooth: [bt sdio] disable interrupt
[10/10/2025 20:52:18.429] [  136.163382] Bluetooth: [bt sdio hci] remove sdio dev
[10/10/2025 20:52:18.430] [  136.168385] Bluetooth: [bt sdio hci] work_thread: break from main thread
[10/10/2025 20:52:18.430] [  136.175205] Bluetooth: [bt sdio] btti_sdio_unregister_dev
[10/10/2025 20:52:18.525] [  136.269863] NET: Unregistered protocol family 31
[10/10/2025 20:52:21.546] [  139.290232] Bus freq set to 24000000 start...
[10/10/2025 20:52:21.551] [  139.296470] Bus freq set to 24000000 done!
[10/10/2025 20:52:27.175] root@smm-m2d ~ # modprobe -r btti
[10/10/2025 20:52:28.152] root@smm-m2d ~ # [  146.334200]
[10/10/2025 20:52:28.590] [  146.334200] Bus freq set to 400000000 start...
[10/10/2025 20:52:28.616] [  146.341156] Bus freq set to 400000000 done!
[10/10/2025 20:52:32.266] [  150.010227] Bus freq set to 24000000 start...
[10/10/2025 20:52:32.289] [  150.016452] Bus freq set to 24000000 done!
[10/10/2025 20:52:43.028] root@smm-m2d ~ # modprobe btti
[10/10/2025 20:52:44.777] [  162.522331] Bluetooth: Core ver 2.22
[10/10/2025 20:52:44.800] [  162.528652] NET: Registered protocol family 31
[10/10/2025 20:52:44.800] [  162.534621] Bluetooth: HCI device and connection manager initialized
[10/10/2025 20:52:44.802] [  162.542637] Bluetooth: HCI socket layer initialized
[10/10/2025 20:52:44.803] [  162.548095] Bluetooth: L2CAP socket layer initialized
[10/10/2025 20:52:47.791] root@smm-m2d ~ # modprobe btti_sdio
[10/10/2025 20:52:49.904] [  167.647518] Bluetooth: [bt sdio] BLE SDIO init module
[10/10/2025 20:52:49.929] [  167.662958]
[10/10/2025 20:52:49.929] [  167.662958] Bus freq set to 400000000 start...
[10/10/2025 20:52:49.930] [  167.669297] Bus freq set to 400000000 done!
[10/10/2025 20:52:50.136] [  167.880012] btti_cc33xx_bt_sdio: probe of mmc1:0001:1 failed with error -13
[10/10/2025 20:52:50.356] [  168.100111] Bluetooth: [bt sdio] PROBE vendor=0x97, device=0x4077, class=255, fn=2 0xc48f1c00
    Additionally, if I unload the kernel modules sdhci_esdhc_imx and pwrseq_simple, and load them again before load btti_sdio, it works normally.
[10/10/2025 21:26:24.537] root@smm-m2d ~ # modprobe -r sdhci_esdhc_imx
[10/10/2025 21:26:33.286] [ 2191.050183] Bus freq set to 24000000 start...
[10/10/2025 21:26:33.310] [ 2191.056423] Bus freq set to 24000000 done!
[10/10/2025 21:26:33.489] [ 2191.253613] Bus freq set to 400000000 start...
[10/10/2025 21:26:33.501] [ 2191.260683] Bus freq set to 400000000 done!
[10/10/2025 21:26:33.501] [ 2191.265636] mmc1: card 0001 removed
[10/10/2025 21:26:43.873] [ 2201.637423] Bus freq set to 400000000 start...
[10/10/2025 21:26:43.900] [ 2201.644578] Bus freq set to 400000000 done!
root@smm-m2d ~ # modprobe -r pwrseq_simple
[10/10/2025 21:26:47.526] [ 2205.290226] Bus freq set to 24000000 start...
[10/10/2025 21:26:47.530] [ 2205.296483] Bus freq set to 24000000 done!
[10/10/2025 21:26:48.489]
[10/10/2025 21:26:48.906] root@smm-m2d ~ #
[10/10/2025 21:26:49.493]
[10/10/2025 21:26:49.524] root@smm-m2d ~ # lsmod
[10/10/2025 21:26:50.359]     Not tainted
[10/10/2025 21:26:50.372] Module                  Size  Used by
[10/10/2025 21:26:50.391] essiv                  16384  1 - Live 0xbf26c000
[10/10/2025 21:26:50.393] authenc                16384  1 essiv, Live 0xbf258000
[10/10/2025 21:26:50.404] dm_crypt               36864  1 - Live 0xbf3c5000
[10/10/2025 21:26:50.412] dm_mod                 98304  3 dm_crypt, Live 0xbf39f000
[10/10/2025 21:26:50.420] ext4                  393216  1 - Live 0xbf327000
[10/10/2025 21:26:50.430] mbcache                16384  1 ext4, Live 0xbf2d7000
[10/10/2025 21:26:50.443] jbd2                   73728  1 ext4, Live 0xbf30a000
[10/10/2025 21:26:50.452] crc32c_generic         16384  2 - Live 0xbf301000
[10/10/2025 21:26:50.461] loop                   28672  2 - Live 0xbf2f3000
[10/10/2025 21:26:50.471] algif_hash             16384  0 - Live 0xbf2ea000
[10/10/2025 21:26:50.479] phy_mxs_usb            20480  1 - Live 0xbf1be000
[10/10/2025 21:26:50.487] algif_skcipher         16384  0 - Live 0xbf2dc000
[10/10/2025 21:26:50.502] af_alg                 20480  2 algif_hash,algif_skcipher, Live 0xbf2d1000
[10/10/2025 21:26:50.510] hmac                   16384  0 - Live 0xbf2c8000
[10/10/2025 21:26:50.519] ofb                    16384  0 - Live 0xbf2bf000
[10/10/2025 21:26:50.527] crypto_user            16384  0 - Live 0xbf2ba000
[10/10/2025 21:26:50.538] cbc                    16384  1 - Live 0xbf2b5000
[10/10/2025 21:26:50.546] ci_hdrc_imx            16384  0 - Live 0xbf2ab000
[10/10/2025 21:26:50.560] ci_hdrc                40960  1 ci_hdrc_imx, Live 0xbf2a0000
[10/10/2025 21:26:50.564] aes_generic            36864  2 - Live 0xbf296000
[10/10/2025 21:26:50.576] ulpi                   16384  1 ci_hdrc, Live 0xbf291000
[10/10/2025 21:26:50.584] roles                  16384  1 ci_hdrc, Live 0xbf287000
[10/10/2025 21:26:50.594] mxs_dcp                20480  1 - Live 0xbf27c000
[10/10/2025 21:26:50.603] usbmisc_imx            20480  1 ci_hdrc_imx, Live 0xbf271000
[10/10/2025 21:26:50.614] usb_f_ncm              20480  2 - Live 0xbf266000
[10/10/2025 21:26:50.622] u_ether                20480  1 usb_f_ncm, Live 0xbf260000
[10/10/2025 21:26:50.635] libcomposite           45056  10 usb_f_ncm, Live 0xbf24c000
[10/10/2025 21:26:50.644] nls_base               16384  1 libcomposite, Live 0xbf1d3000
[10/10/2025 21:26:50.654] configfs               32768  3 usb_f_ncm,libcomposite, Live 0xbf1c4000
[10/10/2025 21:26:50.669] udc_core               20480  4 ci_hdrc,usb_f_ncm,u_ether,libcomposite, Live 0xbf154000
[10/10/2025 21:26:50.685] usb_common             16384  3 ci_hdrc,libcomposite,udc_core, Live 0xbf14f000
[10/10/2025 21:26:50.696] libaes                 16384  1 aes_generic, Live 0xbf106000
[10/10/2025 21:26:50.704] sha256_generic         16384  1 - Live 0xbf06a000
[10/10/2025 21:26:50.713] libsha256              20480  1 sha256_generic, Live 0xbf0d1000
[10/10/2025 21:26:50.721] ubifs                 237568  1 - Live 0xbf06f000
[10/10/2025 21:26:50.731] ubi                    98304  2 ubifs, Live 0xbf04d000
[10/10/2025 21:26:50.744] crc16                  16384  2 ext4,ubifs, Live 0xbf039000
[10/10/2025 21:26:50.752] cmdlinepart            16384  0 - Live 0xbf00e000
[10/10/2025 21:26:50.761] gpmi_nand              28672  1 - Live 0xbf040000
[10/10/2025 21:26:50.772] nand                   77824  1 gpmi_nand, Live 0xbf025000
[10/10/2025 21:26:50.779] nand_ecc               16384  1 nand, Live 0xbf01e000
[10/10/2025 21:26:50.787] nandcore               16384  1 nand, Live 0xbf016000
[10/10/2025 21:26:50.802] mtd                    53248  10 ubi,cmdlinepart,gpmi_nand,nand, Live 0xbf000000
[10/10/2025 21:26:50.940] root@smm-m2d ~ #
[10/10/2025 21:26:55.619] root@smm-m2d ~ # modprobe pwrseq_simple
[10/10/2025 21:27:14.085] root@smm-m2d ~ # modprobe sdhci_esdhc_imx
[10/10/2025 21:27:16.834] [ 2234.598261] sdhci: Secure Digital Host Controller Interface driver
[10/10/2025 21:27:16.866] [ 2234.630306] sdhci: Copyright(c) Pierre Ossman
[10/10/2025 21:27:16.971] [ 2234.734463] sdhci-pltfm: SDHCI platform and OF driver helper
[10/10/2025 21:27:17.238] [ 2235.002692]
[10/10/2025 21:27:17.238] [ 2235.002692] Bus freq set to 400000000 start...
[10/10/2025 21:27:17.259] [ 2235.009276] Bus freq set to 400000000 done!
[10/10/2025 21:27:17.259] [ 2235.015764] sdhci-esdhc-imx 2194000.mmc: allocated mmc-pwrseq
[10/10/2025 21:27:17.334] [ 2235.099874] mmc1: SDHCI controller on 2194000.mmc [2194000.mmc] using ADMA
[10/10/2025 21:27:17.350] root@smm-m2d ~ # [ 2235.170721] sdhci-esdhc-imx 2194000.mmc: card claims to support voltages below defined range
[10/10/2025 21:27:17.480] [ 2235.245070] mmc1: new high speed SDIO card at address 0001
[10/10/2025 21:27:28.531] [ 2246.297332] Bluetooth: Core ver 2.22
[10/10/2025 21:27:28.545] [ 2246.309963] NET: Registered protocol family 31
[10/10/2025 21:27:28.545] [ 2246.314433] Bluetooth: HCI device and connection manager initialized
[10/10/2025 21:27:28.556] [ 2246.321361] Bluetooth: HCI socket layer initialized
[10/10/2025 21:27:28.556] [ 2246.326269] Bluetooth: L2CAP socket layer initialized
[10/10/2025 21:27:31.036] [ 2248.799751] Bluetooth: [bt sdio] BLE SDIO init module
[10/10/2025 21:27:31.059] [ 2248.822757]
[10/10/2025 21:27:31.059] [ 2248.822757] Bus freq set to 400000000 start...
[10/10/2025 21:27:31.068] [ 2248.829090] Bus freq set to 400000000 done!
[10/10/2025 21:27:31.275] [ 2249.040107] Bluetooth: [bt sdio] PROBE vendor=0x97, device=0x4077, class=255, fn=1 0xc48f1400
[10/10/2025 21:27:31.304] [ 2249.050179] Bluetooth: [bt sdio hci] btti_hci_add_sdio_dev
[10/10/2025 21:27:31.304] [ 2249.055690] Bluetooth: [bt sdio hci] Starting work thread...
[10/10/2025 21:27:31.305] [ 2249.061631] Bluetooth: [bt sdio hci] work thread is started
[10/10/2025 21:27:31.305] [ 2249.067339] Bluetooth: [bt sdio] TI cc33xx BLE-over-SDIO driver is up and running!
[10/10/2025 21:27:31.313] [ 2249.074975] Bluetooth: [bt sdio hci] work thread is sleeping...
[10/10/2025 21:27:31.320] [ 2249.081412] Bluetooth: [bt sdio] PROBE vendor=0x97, device=0x4077, class=255, fn=2 0xc40e4c00
[10/10/2025 21:27:31.328] root@smm-m2d ~ #
     In our previous projects with AIC and broadcom wifi chip, we don't need to unload the kernel modules sdhci_esdhc_imx and pwrseq_simple.
     Could you please check whether the process of sdio device unregister for TI's drivers is normal?
  • Hello TI experts,
    I'm from the same team as Mr. Zhang Xianglong.
    This issue seems to us that the mmc devices are not released properly after the Wi-Fi / Bluetooth modules are unloaded. Could you please help us analyze the root cause and advise on a solution?
  • Hi Xianglong,
    The MMC driver has its own bind as well. Have you tried to unbind the MMC driver?
    For example, on my device I have to issue the following:
    CC33XX_MMC_DEVICE="481d8000.mmc"
    echo  "$CC33XX_MMC_DEVICE" > /sys/bus/platform/drivers/sdhci-omap/unbind
    sleep 1
    echo  "$CC33XX_MMC_DEVICE" > /sys/bus/platform/drivers/sdhci-omap/bind
  • Hi Sabeeh,
    Thank you for the quick response.
    As we said this morning, due to the limitation from our framework, we don't have such a change to invoke a piece of shell script to unbind the mmc device. Instead, we find a way to bind and unbind from the TI driver. Below I attached how we changed the code from __init and __exit functions. But, further more, we think this shouldn't be how the kernel driver works. If the driver is handling the functions something like device_register and device_release properly, the kernel mechanism should bind and unbind the mmc devices automatically. So please TI team make a deep check, and fix the bug as soon as possible.
    Thank you so much!
    static int __init sdio_cc33xx_init(void)
        struct device *dev;
        // Automatically bind MMC controller device
        dev = bus_find_device_by_name(&platform_bus_type, NULL, "2194000.mmc");
        if (dev) {
            dev_dbg(dev, "Binding MMC device 2194000.mmc");
            device_attach(dev);  // Equivalent to echo > bind
            put_device(dev);     // Release reference
        } else {
            dev_dbg(dev, "MMC device 2194000.mmc not found");
    	return sdio_register_driver(&cc33xx_sdio_driver);
    static void __exit sdio_cc33xx_exit(void)
        struct device *dev;
    	sdio_unregister_driver(&cc33xx_sdio_driver);
        // Automatically unbind MMC controller device
        if (dev) {
            dev_dbg(dev, "Unbinding MMC device 2194000.mmc");
            device_release_driver(dev);  // Equivalent to echo > unbind
        } else {
    module_init(sdio_cc33xx_init);
    module_exit(sdio_cc33xx_exit);
    module_param(dump, bool, 0600);
    MODULE_PARM_DESC(dump, "Enable sdio read/write dumps.");
    After investigating, I do not believe this is a bug. I believe the bind process actually occurs in the MMC driver, not the cc33xx side. I've also observed many other drivers that also do not have such functionality and only call 'sdio_register_device'. So I don't really see that this is a bug from our side.
    It would be interesting if you can try to unload/load the MMC/sdhci module (if compiled as module) you are using and see if that also creates the unbind/bind behavior.
    If not, then it is also acceptable that you can implement this code into your custom kernel version.
  • Hi, After some investigating, I find if change power management runtime, this issue could be fixed,
    like this way , Then btti_sdio could be reload without "error -13"
    Even in this way, it is not unbind, but could be reload and work.
    Thank you for providing this. Can you please help to explain how you found this solution?
      , Do you approve this fix as well?
  • Hi, I'm a developer from  's team,
    And This's one I checked with cc33xx_sdio, It without this logic, and I checked code in btti_sdio, There do not have other way to enable pm again,
    I guess some counter or "enable/disable logic" in pm make btti_sdio reload abnormal,
    Could you check with your team  ? Thanks
    I will also do some deeper check in here.
    After some check, if only disable this two lines, hci work abnormal,
    But if change btti-sdio as this way, hci work normally.
    Please have a check, Thanks!
    @@ -24459,8 +24459,8 @@ index 000000000000..4f8fda6209b9
     +	 * runtime PM for this func such as the case host->caps &
     +	 * MMC_CAP_POWER_OFF_CARD.
    -+	if (pm_runtime_enabled(&sdiodev->func->dev))
    -+		pm_runtime_disable(&sdiodev->func->dev);
    ++	//if (pm_runtime_enabled(&sdiodev->func->dev))
    ++		//pm_runtime_disable(&sdiodev->func->dev);
     +	/* As explaination in drivers/mmc/core/sdio_bus.c tells us:
     +	 * Unbound SDIO functions are always suspended.
    @@ -24471,7 +24471,7 @@ index 000000000000..4f8fda6209b9
     +	 * So, put a pm_runtime_put_noidle here !
    -+	pm_runtime_put_noidle(&sdiodev->func->dev);
    ++	pm_runtime_get_noresume(&sdiodev->func->dev);
     +	BT_DBG("[bt sdio] PROBE sdio_claim_irq");
     +	sdio_claim_host(func);
    @@ -24519,7 +24519,7 @@ index 000000000000..4f8fda6209b9
     +		btti_sdio_unregister_dev(func);
     +	/* Be consistent the state in btti_sdio_if_probe */
    -+	pm_runtime_get_noresume(&func->dev);
    ++	pm_runtime_put_noidle(&func->dev);
  • Hi  ,
    Yes, I'd like to approve the fix from  . But before that, I need your expert validation to confirm the change was implemented correctly, since your team is the owner of the driver. Please let me know once you've had a chance to review and validate it.
  • Hi Xing Su,
    Understood. I am currently testing these changes and will work report back if I find any issues.
  • Hi Chao,
    I have reproduced the original error. When removing the module and using 'modprobe btti_sdio' I had probe failed error with -13.
    After incorporating your changes, this result was not resolved for me. I am still able to create the -13 error. Can you show me the commands you used specifically to load and unload the modules successfully? Can you also add in the command on how you are re-issuing the ble_enable command from sysfs?
  • Hi,  :
    Load
    modprobe -a pwrseq_simple sha256_generic sdhci_esdhc_imx ecdh-generic cfg80211 mac80211 btti_sdio cc33xx_sdio cc33xx
    unload
    modprobe -r btti_sdio btti cc33xx_sdio cc33xx
  • for "ble_enable", I add a patch to auto enable it in cc33xx's nvs_cb.
    --- drivers/net/wireless/ti/cc33xx/main.c
    +++ drivers/net/wireless/ti/cc33xx/main.c
    @@ -6015,7 +6015,8 @@
     out:
     	release_firmware(fw);
     	complete_all(&wl->nvs_loading_complete);
    -	cc33xx_debug(DEBUG_CC33xx, "wlcore_nvs_cb Complete");
    +	cc33xx_debug(DEBUG_CC33xx, "wlcore_nvs_cb Complete");
    +	cc33xx_ble_enable(wl, 1);
     int wlcore_probe(struct cc33xx *wl, struct platform_device *pdev)
  • Hi Yan,
    I'm not opposed to adding this call so that ble is enabled automatically. However, I would suggest moving the function up higher. This is so that if the firmware download fails, you are not running the ble_enable command. See here:
    diff --git a/drivers/net/wireless/ti/cc33xx/main.c b/drivers/net/wireless/ti/cc33xx/main.c
    index d595e9422688..35cf8be6b56f 100644
    --- a/drivers/net/wireless/ti/cc33xx/main.c
    +++ b/drivers/net/wireless/ti/cc33xx/main.c
    @@ -6006,6 +6006,9 @@ static void wlcore_nvs_cb(const struct firmware *fw, void *context)
    wl->initialized = true;
    cc33xx_notice("loaded");
    goto out;
    out_unreg:
