Will 802.11n give a better/farther range coverage compare to 802.11b/g when use a single antenna on the module that function as a client?
Assume the AP will support 802.11b/g/n.
Hi Brandon,
Working with 802.11n single antenna will not give a higher range than 802.11g.
However it will give a higher throughput since the packet rates are higher and in addition BA (Ack per Block and not per frame – packet aggregation) contributes to higher over all link throughputs.
802.11n has a higher range only when using MIMO (Several Antennas)
Eyal
