TI8148 + wl1271 hostapd complaining about lack of nl80211 support
Other Parts Discussed in Thread: WL1271
I’m trying to get hostapd to behave and run on my TI8148 + wl1271 system. I recompiled hostapd with nl80211 support, by adding:
CONFIG_LIBNL20=y
CONFIG_DRIVER_NL80211=y
to the .config for hostapd. Then I try to run hostapd on my target:
root@bullfrog-060005:/lib/firmware$ hostapd /media/sda1/hostapd.conf
Configuration file: /media/sda1/hostapd.conf
Line 2: invalid/unknown driver 'nl80211'
Here’s my conf file, for reference:
interface=wlan0
driver=nl80211
ssid=BATTLETOAD
channel=1
hw_mode=g
preamble=1
dtim_period=2
beacon_int=100
logger_syslog=-1
logger_syslog_level=2
logger_stdout=-1
logger_stdout_level=2
dump_file=/tmp/hostapd.dump
ctrl_interface=/var/run/hostapd
ctrl_interface_group=0
supported_rates=60 90 120 180 240 360 480 540
basic_rates=60 90 120 180 240
ssid=MAC_AP
max_num_sta=5
macaddr_acl=0
auth_algs=3
ieee80211d=0
uapsd_advertisement_enabled=1
wep_rekey_period=0
own_ip_addr=127.0.0.1
wpa_group_rekey=0
wpa_strict_rekey=0
wpa_gmk_rekey=0
wpa_ptk_rekey=0
#ap_table_max_size=255
#ap_table_expiration_time=60
eap_server=1
#disassoc_low_ack=1
ap_max_inactivity=4294967295
Any tips on why hostapd is being such a butt?
  • Hi David,
    To use CONFIG_DRIVER_NL80211=y in hostap / wpa_supplicant, you need to enable CONFIG_NL80211_TESTMODE=y in the kernel config.
    Can you please cross check, whether it is present or not?
    If not, you need to recompile the kernel by enabling CONFIG_NL80211_TESTMODE. Then build and use hostap as you tried previously.
    Pandu.
  • Pandu,
    Thank-you for your post. That did indeed get me a little further. Now when I try to load hostapd, I get the following:
    [22570.150000] Powering off wl12xxPowering on wl12xx
    [22570.680000] ADDRCONF(NETDEV_UP): wlan0: link is not ready
    nl80211: Failed to set interface wlan0 into AP mode
    nl80211 driver initialization failed.
    rmdir[ctrl_interface]: No such file or directory
    ELOOP: remaining socket: sock=4 eloop_data=0x5c718 user_data=0x5e2e8 handler=0x2a294
    ELOOP: remaining socket: sock=6 eloop_data=0x5fbd0 user_data=(nil) handler=0x31a68
    Any ideas what might be happening now? Regardless, thank-you for helping me get a little further.
  • Hi David,
    Can you confirm whether you are able to use it station mode?
    If so, then it should straight forward to use in AP mode also.
    Can you share the output of "ifconfig -a" and "ifconfig wlan0 up"?
    Pandu.
