tcp server
sorry ,i have many questions,can anyone give the sample code for below function?
1.cc3000 as a tcp server.
2.cc3000 as a tcp client.
2.cc3000 as a udp server
now i can send data use Wifi_send_data(),but others i don't know how to do?
anyone help?
  • oh,good.
    i have implemented some function of the tcp server,i can connect the device ,but when connected it,the device stuck on function hci_event_handler,what should i do next.
    and this is my code:
    		ulSocket=socket(AF_INET,SOCK_STREAM,IPPROTO_TCP);
    		if(ulSocket == -1)
    			printf("socket error !");
    			continue;
    		serverSock.sa_family=AF_INET;
    		serverSock.sa_data[0]=(port&0xff00)>>8;
    		serverSock.sa_data[1]=(port&0xff);
    		memset(&serverSock.sa_data[2],0,4);
    		if (bind(ulSocket,&serverSock,sizeof(serverSock))==-1)
    			printf("bind error !");
    			continue;
    		if (listen(ulSocket,5)==-1)
    			printf("listen error");
    			continue;
    		while(1)
    			printf("wait\r\n");
    			clientDescript=accept(ulSocket,(sockaddr*)&romoteAddr,&addrLen);
    			if (clientDescript<0)
    				printf("accept error !");
    				continue;
    			printf("get one\r\n");
    			while(1)
    				recv(ulSocket,receiveData,255,0);
    				if (receiveData[0]==1)
    					printf("get");
  • Hi Augus,
    Where does it exactly get stuck?
    I see that you are using listening socket's descriptor 'ulSocket' while doing a receive. Please use the 'clientDescript' in recv and it should work.
    Thanks & Regards,
    Raghavendra
  • thanks
    you correct
