bluetooth tiwi5 chip
root@at91sam9260ek:/home# hcitool scan
Scanning ...
        78:9E:D0:2B:45:CB       GT-S6012
root@at91sam9260ek:/home# l2ping 78:9E:D0:2B:45:CB
Can't connect: Host is down
root@at91sam9260ek:/home# rfcomm connect /dev/rfcomm0
regards,
karthik
    Did you try different options of l2ping.
  • root@at91sam9260ek:/home# bluetoothd -n -d 5
    bluetoothd[1163]: Bluetooth daemon 4.35
    bluetoothd[1163]: Enabling debug information
    bluetoothd[1163]: parsing main.conf
    bluetoothd[1163]: discovto=0
    bluetoothd[1163]: pairto=0
    bluetoothd[1163]: pageto=8192
    bluetoothd[1163]: name=%h-%d
    bluetoothd[1163]: class="0x000100"
    bluetoothd[1163]: inqmode=0
    bluetoothd[1163]: Key file does not have key 'DeviceID'
    bluetoothd[1163]: Starting SDP server
    bluetoothd[1163]: Loading plugins /usr/lib/bluetooth/plugins
    bluetoothd[1163]: input.conf: Key file does not have key 'IdleTimeout'
    bluetoothd[1163]: register_interface: path /org/bluez/1163/any
    bluetoothd[1163]: Registered interface org.bluez.Service on path /org/bluez/1163
    /any
    bluetoothd[1163]: /etc/bluetooth/network.conf: Key file does not have key 'Disab
    le'
    leSecurity'
    bluetoothd[1163]: /etc/bluetooth/network.conf: Key file does not have key 'Inter
    face'
    face'
    face'
    bluetoothd[1163]: Config options: InterfacePrefix=bnep%d, PANU_Script=(null), GN
    _Script=(null), NAP_Script=(null), GN_Interface=pan0, NAP_Interface=pan1, Securi
    ty=true
    bluetoothd[1163]: Can't create GN bridge
    bluetoothd[1163]: Unix socket created: 13
    bluetoothd[1163]: audio.conf: Key file does not have group 'Headset'
    bluetoothd[1163]: HCI dev 0 registered
    bluetoothd[1163]: child 1166 forked
    bluetoothd[1163]: Entering main loop
    bluetoothd[1163]: child 1166 exited
    bluetoothd[1163]: HCI dev 0 up
    bluetoothd[1163]: Starting security manager 0
    bluetoothd[1163]: register_interface: path /org/bluez/1163/hci0
    /hci0
    bluetoothd[1163]: network_server_probe: path /org/bluez/1163/hci0
    bluetoothd[1163]: Adding record with handle 0x10000
    bluetoothd[1163]: Record pattern UUID 0000000f-0000-1000-8000-00805f9
    bluetoothd[1163]: Record pattern UUID 00000100-0000-1000-8000-00805f9
    bluetoothd[1163]: Record pattern UUID 00001002-0000-1000-8000-00805f9
    bluetoothd[1163]: Record pattern UUID 00001115-0000-1000-8000-00805f9
    bluetoothd[1163]: register_server_record: got record id 0x10000
    bluetoothd[1163]: Registered interface org.bluez.NetworkPeer on path /org/bluez/
    1163/hci0
    bluetoothd[1163]: Adding record with handle 0x10001
    bluetoothd[1163]: Record pattern UUID 00001117-0000-1000-8000-00805f9
    bluetoothd[1163]: register_server_record: got record id 0x10001
    bluetoothd[1163]: Registered interface org.bluez.NetworkHub on path /org/bluez/1
    163/hci0
    bluetoothd[1163]: Adding record with handle 0x10002
    bluetoothd[1163]: Record pattern UUID 00001116-0000-1000-8000-00805f9
    bluetoothd[1163]: register_server_record: got record id 0x10002
    bluetoothd[1163]: Registered interface org.bluez.NetworkRouter on path /org/blue
    z/1163/hci0
    bluetoothd[1163]: a2dp_server_probe: path /org/bluez/1163/hci0
    bluetoothd[1163]: audio.conf: Key file does not have key 'SBCSinks'
    bluetoothd[1163]: audio.conf: Key file does not have key 'MPEG12Sinks'
    bluetoothd[1163]: SEP 0x40352010 registered: type:0 codec:0 seid:1
    bluetoothd[1163]: Adding record with handle 0x10003
    bluetoothd[1163]: Record pattern UUID 00000019-0000-1000-8000-00805f9
    bluetoothd[1163]: Record pattern UUID 0000110a-0000-1000-8000-00805f9
    bluetoothd[1163]: Record pattern UUID 0000110d-0000-1000-8000-00805f9
    bluetoothd[1163]: avrcp_server_probe: path /org/bluez/1163/hci0
    bluetoothd[1163]: Adding record with handle 0x10004
    bluetoothd[1163]: Record pattern UUID 00000017-0000-1000-8000-00805f9
    bluetoothd[1163]: Record pattern UUID 0000110c-0000-1000-8000-00805f9
    bluetoothd[1163]: Record pattern UUID 0000110e-0000-1000-8000-00805f9
    bluetoothd[1163]: Adding record with handle 0x10005
    bluetoothd[1163]: proxy_probe: path /org/bluez/1163/hci0
    bluetoothd[1163]: Registered interface org.bluez.SerialProxyManager on path /org
    /bluez/1163/hci0
    bluetoothd[1163]: Changing service classes to 0x0a0100
    bluetoothd[1163]: Adapter /org/bluez/1163/hci0 has been enabled
    bluetoothd[1163]: Failed to access HAL
  • Hi Karthik,
    This looks to be unrelated to the TI Chip. Looks to me that the remote device is not responding...
    Anyways, please send a snoop log ("hcidump -x -w <filename>") to confirm.
    Gigi Joseph.
