Hi
We are using wl18xx (wifi + BT) module for our custom board,
In one of our custom board we are facing an issue, when the wlan0 tries to acquire IP we could see some interrupt messages on the console ,
While probing the interrupt line during these error occurs we were able to see some activity on the interrupt line of wl1835.
What might be the issue?
Note: We tested the same SD on another boards and seems working fine,
The output on the console is as follows...
root@arm:~# ifup wlan0
[ 617.726104] wlcore: ERROR SW watchdog interrupt received! starting recovery.
Internet Systems Consortium DHCP Client 4.2.4
Copyright 2004-2012 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Listening on LPF/wlan0/de:ad:be:ef:00:00
Sending on LPF/wlan0/de:ad:be:ef:00:00
Sending on Socket/fallback
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 3 (xid=0x38f56685)
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 6 (xid=0x38f56685)
[ 623.156494] wlcore: ERROR SW watchdog interrupt received! starting recovery.
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 8 (xid=0x38f56685)
DHCPREQUEST of 192.168.43.88 on wlan0 to 255.255.255.255 port 67 (xid=0x38f56685)
DHCPOFFER of 192.168.43.88 from 192.168.43.1
DHCPACK of 192.168.43.88 from 192.168.43.1
[ 637.760528] wlcore: ERROR SW watchdog interrupt received! starting recovery.
bound to 192.168.43.88 -- renewal in 20889 seconds.
[ 645.591827] wlcore: ERROR SW watchdog interrupt received! starting recovery.
[ 651.098632] wlcore: ERROR SW watchdog interrupt received! starting recovery.
[ 652.103820] wlcore: ERROR SW watchdog interrupt received! starting recovery.
[ 660.050109] wlcore: ERROR SW watchdog interrupt received! starting recovery.
root@arm:~# [ 662.343933] wlcore: ERROR SW watchdog interrupt received! starting recovery.
[ 663.335540] wlcore: ERROR SW watchdog interrupt received! starting recovery.
[ 664.289581] wlcore: ERROR SW watchdog interrupt received! starting recovery.
[ 667.346496] wlcore: ERROR SW watchdog interrupt received! starting recovery.
[ 668.385772] wlcore: ERROR SW watchdog interrupt received! starting recovery.
[ 672.265258] wlcore: ERROR SW watchdog interrupt received! starting recovery.
[ 674.017181] wlcore: ERROR SW watchdog interrupt received! starting recovery.
[ 680.339874] wlcore: ERROR SW watchdog interrupt received! starting recovery.
[ 729.203979] wlcore: ERROR SW watchdog interrupt received! starting recovery.
root@arm:~# ifconfig
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:2 errors:0 dropped:0 overruns:0 frame:0
TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:176 (176.0 B) TX bytes:176 (176.0 B)
wlan0 Link encap:Ethernet HWaddr de:ad:be:ef:00:00
inet addr:192.168.43.88 Bcast:192.168.43.255 Mask:255.255.255.0
inet6 addr: fe80::dcad:beff:feef:0/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:14 errors:0 dropped:0 overruns:0 frame:0
TX packets:62 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1580 (1.5 KB) TX bytes:9836 (9.8 KB)
root@arm:~# [ 785.120086] wlcore: ERROR SW watchdog interrupt received! starting recovery.
[ 803.302764] wlcore: ERROR SW watchdog interrupt received! starting recovery.
[ 808.721099] wlcore: ERROR SW watchdog interrupt received! starting recovery.
[ 913.179504] wlcore: ERROR SW watchdog interrupt received! starting recovery.
[ 964.059539] wlcore: ERROR SW watchdog interrupt received! starting recovery.
[ 980.961608] wlcore: ERROR SW watchdog interrupt received! starting recovery.
[ 988.687713] wlcore: ERROR SW watchdog interrupt received! starting recovery.
[ 999.316497] wlcore: ERROR SW watchdog interrupt received! starting recovery.
I'm also attching the dmesg alongwith.
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.12.6-armv7-x11 (hari@hari-IOT-Laptop) (gcc version 4.8.3 20140401 (prerelease) (crosstool-NG linaro-1.13.1-4.8-2014.04 - Linaro GCC 4.8-2014.04) ) #6 SMP Mon Sep 15 18:18:37 IST 2014
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: Generic OMAP36xx (Flattened Device Tree), model: TI OMAP3 BeagleBoard xM
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 130816
[ 0.000000] free_area_init_node: node 0, pgdat c0bbf4c0, node_mem_map c0cb3000
[ 0.000000] Normal zone: 1024 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 130816 pages, LIFO batch:31
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] OMAP3630 ES1.2 (l2cache iva sgx neon isp 192mhz_clk )
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c10bf000 s13952 r8192 d14720 u36864
[ 0.000000] pcpu-alloc: s13952 r8192 d14720 u36864 alloc=9*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129792
[ 0.000000] Kernel command line: console=ttyO2,115200n8 mpurate=auto buddy=none camera=none vram=12M omapfb.mode=dvi:640x480MR-16@60 omapdss.def_disp=dvi root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait fixrtc
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] allocated 1048576 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Memory: 504632K/523264K available (7751K kernel code, 645K rwdata, 3156K rodata, 461K init, 948K bss, 18632K reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0aaf128 (10909 kB)
[ 0.000000] .init : 0xc0ab0000 - 0xc0b23680 ( 462 kB)
[ 0.000000] .data : 0xc0b24000 - 0xc0bc5500 ( 646 kB)
[ 0.000000] .bss : 0xc0bc5500 - 0xc0cb2704 ( 949 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/400/600 MHz
[ 0.000000] clock: dpll5: dpll5_clk omap3630
[ 0.000000] clock: dpll5: Applying SPRZ319E 2.1: 13000000, 443, 5, 8
[ 0.000000] OMAP clockevent source: timer1 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
[ 0.000000] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000305] Calibrating delay loop... 398.13 BogoMIPS (lpj=1990656)
[ 0.049957] pid_max: default: 32768 minimum: 301
[ 0.050109] Security Framework initialized
[ 0.050201] AppArmor: AppArmor initialized
[ 0.050415] Mount-cache hash table entries: 512
[ 0.056518] Initializing cgroup subsys memory
[ 0.056579] Initializing cgroup subsys devices
[ 0.056610] Initializing cgroup subsys freezer
[ 0.056610] Initializing cgroup subsys net_cls
[ 0.056610] Initializing cgroup subsys blkio
[ 0.056640] Initializing cgroup subsys perf_event
[ 0.056762] CPU: Testing write buffer coherency: ok
[ 0.057189] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.057250] Setting up static identity map for 0xc0756928 - 0xc0756980
[ 0.058410] Brought up 1 CPUs
[ 0.058441] SMP: Total of 1 processors activated.
[ 0.058441] CPU: All CPU(s) started in SVC mode.
[ 0.059356] devtmpfs: initialized
[ 0.063842] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.082641] omap_hwmod: mcbsp2: cannot be enabled for reset (3)
[ 0.118957] xor: measuring software checksum speed
[ 0.209564] arm4regs : 746.000 MB/sec
[ 0.309356] 8regs : 550.000 MB/sec
[ 0.409149] 32regs : 643.600 MB/sec
[ 0.508941] neon : 533.600 MB/sec
[ 0.508941] xor: using function: arm4regs (746.000 MB/sec)
[ 0.508972] pinctrl core: initialized pinctrl subsystem
[ 0.509490] regulator-dummy: no parameters
[ 0.509948] NET: Registered protocol family 16
[ 0.510833] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.511627] cpuidle: using governor ladder
[ 0.511657] cpuidle: using governor menu
[ 0.518218] Reprogramming SDRC clock to 400000000 Hz
[ 0.520568] gpiochip_add: registered GPIOs 0 to 31 on device: gpio
[ 0.521148] OMAP GPIO hardware version 2.5
[ 0.521606] gpiochip_add: registered GPIOs 32 to 63 on device: gpio
[ 0.522583] gpiochip_add: registered GPIOs 64 to 95 on device: gpio
[ 0.523620] gpiochip_add: registered GPIOs 96 to 127 on device: gpio
[ 0.524658] gpiochip_add: registered GPIOs 128 to 159 on device: gpio
[ 0.525726] gpiochip_add: registered GPIOs 160 to 191 on device: gpio
[ 0.529327] platform 49022000.mcbsp: alias fck already exists
[ 0.529754] platform 49024000.mcbsp: alias fck already exists
[ 0.533447] omap-gpmc 6e000000.gpmc: GPMC revision 5.0
[ 0.537109] No ATAGs?
[ 0.537139] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.538818] OMAP DMA hardware revision 5.0
[ 0.554870] bio: create slab <bio-0> at 0
[ 0.718536] raid6: int32x1 93 MB/s
[ 0.888549] raid6: int32x2 129 MB/s
[ 1.058197] raid6: int32x4 102 MB/s
[ 1.227447] raid6: int32x8 103 MB/s
[ 1.397094] raid6: neonx1 543 MB/s
[ 1.566802] raid6: neonx2 790 MB/s
[ 1.736541] raid6: neonx4 267 MB/s
[ 1.906066] raid6: neonx8 153 MB/s
[ 1.906066] raid6: using algorithm neonx2 (790 MB/s)
[ 1.906097] raid6: using intx1 recovery algorithm
[ 1.907501] edma-dma-engine edma-dma-engine.0: Can't allocate PaRAM dummy slot
[ 1.907531] edma-dma-engine: probe of edma-dma-engine.0 failed with error -5
[ 1.922821] omap-dma-engine 48056000.dma-controller: OMAP DMA engine driver
[ 1.923492] of_get_named_gpio_flags exited with status 16
[ 1.923706] vmmc3: 1800 mV
[ 1.923919] of_get_named_gpio_flags exited with status -517
[ 1.923950] platform hsusb2_power_reg.31: Driver reg-fixed-voltage requests probe deferral
[ 1.928039] SCSI subsystem initialized
[ 1.928619] libata version 3.00 loaded.
[ 1.928955] usbcore: registered new interface driver usbfs
[ 1.929046] usbcore: registered new interface driver hub
[ 1.929260] usbcore: registered new device driver usb
[ 1.929534] of_get_named_gpio_flags exited with status 39
[ 1.929656] hsusb2_phy.32 supply vcc not found, using dummy regulator
[ 1.933166] omap_i2c i2c.11: bus 0 rev4.4 at 2600 kHz
[ 1.933746] omap_i2c i2c.12: bus 1 rev4.4 at 100 kHz
[ 1.934234] omap_i2c i2c.13: bus 2 rev4.4 at 100 kHz
[ 1.934478] media: Linux media interface: v0.10
[ 1.934570] Linux video capture interface: v2.00
[ 1.934692] pps_core: LinuxPPS API ver. 1 registered
[ 1.934692] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.934722] PTP clock support registered
[ 1.934814] EDAC MC: Ver: 3.0.0
[ 1.935729] omap-iommu omap-iommu.0: mmu_isp registered
[ 1.936309] Advanced Linux Sound Architecture Driver Initialized.
[ 1.937316] Bluetooth: Core ver 2.16
[ 1.937408] NET: Registered protocol family 31
[ 1.937408] Bluetooth: HCI device and connection manager initialized
[ 1.937438] Bluetooth: HCI socket layer initialized
[ 1.937469] Bluetooth: L2CAP socket layer initialized
[ 1.937499] Bluetooth: SCO socket layer initialized
[ 1.937530] NetLabel: Initializing
[ 1.937530] NetLabel: domain hash size = 128
[ 1.937530] NetLabel: protocols = UNLABELED CIPSOv4
[ 1.937622] NetLabel: unlabeled traffic allowed by default
[ 1.938446] Switched to clocksource 32k_counter
[ 1.968200] AppArmor: AppArmor Filesystem Enabled
[ 1.982513] NET: Registered protocol family 2
[ 1.983489] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 1.983612] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 1.983703] TCP: Hash tables configured (established 4096 bind 4096)
[ 1.983764] TCP: reno registered
[ 1.983795] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 1.983825] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 1.984222] NET: Registered protocol family 1
[ 1.984771] RPC: Registered named UNIX socket transport module.
[ 1.984802] RPC: Registered udp transport module.
[ 1.984802] RPC: Registered tcp transport module.
[ 1.984832] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.987335] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available
[ 1.991180] audit: initializing netlink socket (disabled)
[ 1.991241] type=2000 audit(1.990:1): initialized
[ 2.334381] VFS: Disk quotas dquot_6.5.2
[ 2.334808] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 2.338226] NFS: Registering the id_resolver key type
[ 2.338317] Key type id_resolver registered
[ 2.338348] Key type id_legacy registered
[ 2.338409] jffs2: version 2.2. (NAND) \xffffffc2\xffffffa9\xffffffa9 2001-2006 Red Hat, Inc.
[ 2.339263] fuse init (API version 7.22)
[ 2.340576] bio: create slab <bio-1> at 1
[ 2.342041] Btrfs loaded
[ 2.342346] msgmni has been set to 985
[ 2.345458] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 2.345642] io scheduler noop registered
[ 2.345642] io scheduler deadline registered
[ 2.345825] io scheduler cfq registered (default)
[ 2.347778] pinctrl-single 48002030.pinmux: 284 pins at pa fa002030 size 568
[ 2.348144] pinctrl-single 480025a0.pinmux: 46 pins at pa fa0025a0 size 92
[ 2.348419] pinctrl-single 48002a00.pinmux: 46 pins at pa fa002a00 size 92
[ 2.351104] OMAP DSS rev 2.0
[ 2.354797] abb: 1012 <--> 1380 mV
[ 2.437438] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 2.439575] of_get_named_gpio_flags: can't parse gpios property of node '/ocp/serial@4806a000[0]'
[ 2.440002] serial.7: ttyO0 at MMIO 0x4806a000 (irq = 88, base_baud = 3000000) is a OMAP UART0
[ 2.440490] of_get_named_gpio_flags: can't parse gpios property of node '/ocp/serial@4806c000[0]'
[ 2.440765] serial.8: ttyO1 at MMIO 0x4806c000 (irq = 89, base_baud = 3000000) is a OMAP UART1
[ 2.441253] of_get_named_gpio_flags: can't parse gpios property of node '/ocp/serial@49020000[0]'
[ 2.441528] serial.9: ttyO2 at MMIO 0x49020000 (irq = 90, base_baud = 3000000) is a OMAP UART2
[ 3.387176] console [ttyO2] enabled
[ 3.391387] of_get_named_gpio_flags: can't parse gpios property of node '/ocp/serial@49042000[0]'
[ 3.391723] serial.10: ttyO3 at MMIO 0x49042000 (irq = 96, base_baud = 3000000) is a OMAP UART3
[ 3.402099] [drm] Initialized drm 1.1.0 20060810
[ 3.413543] twl 0-0048: PIH (irq 23) chaining IRQs 338..346
[ 3.419586] twl 0-0048: power (irq 343) chaining IRQs 346..353
[ 3.428009] VDD1: 600 <--> 1450 mV at 1200 mV
[ 3.434020] VDAC: 1800 mV
[ 3.438110] VPLL2: 1800 mV
[ 3.442199] VMMC1: 1850 <--> 3150 mV at 3150 mV
[ 3.448150] VMMC2: 1850 <--> 3150 mV at 2600 mV
[ 3.453979] VUSB1V5: 1500 mV
[ 3.457733] VUSB1V8: 1800 mV
[ 3.461517] VUSB3V1: 3100 mV
[ 3.465423] VSIM: 1800 <--> 3000 mV at 1800 mV
[ 3.471221] twl4030_gpio gpio.46: gpio (irq 338) chaining IRQs 354..371
[ 3.478485] gpiochip_find_base: found new base at 492
[ 3.478637] gpiochip_add: registered GPIOs 492 to 511 on device: twl4030
[ 3.481170] twl4030_usb twl4030-usb.47: Initialized TWL4030 USB module
[ 3.493133] Missing elm_id property, fall back to Software BCH
[ 3.502288] enabling NAND BCH ecc with 8-bit correction
[ 3.507934] Trying ONFI probe in 16 bits mode, aborting !
[ 3.513671] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xbc (Micron NAND 512MiB 1,8V 16-bit), 512MiB, page size: 2048, OOB size: 64
[ 3.526367] 6 ofpart partitions found on MTD device omap2-nand.0
[ 3.532714] Creating 6 MTD partitions on "omap2-nand.0":
[ 3.538299] 0x000000000000-0x000000080000 : "mlO"
[ 3.545074] 0x000000080000-0x000000260000 : "u-boot"
[ 3.553131] 0x000000260000-0x000000280000 : "uboot-env"
[ 3.559936] 0x000000280000-0x0000002a0000 : "dtbs"
[ 3.566192] 0x0000002a0000-0x0000006a0000 : "uimage"
[ 3.575805] 0x0000006a0000-0x00001a6a0000 : "filesystem"
[ 3.927947] omap-dma-engine 48056000.dma-controller: allocating channel for 36
[ 3.935638] omap-dma-engine 48056000.dma-controller: allocating channel for 35
[ 3.947052] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.954010] ehci-platform: EHCI generic platform driver
[ 3.959838] ehci-omap: OMAP-EHCI Host Controller driver
[ 3.978637] ehci-omap 48064800.ehci: EHCI Host Controller
[ 3.984649] ehci-omap 48064800.ehci: new USB bus registered, assigned bus number 1
[ 3.992828] ehci-omap 48064800.ehci: irq 93, io mem 0x48064800
[ 4.018554] ehci-omap 48064800.ehci: USB 2.0 started, EHCI 1.00
[ 4.025146] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.032318] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.039947] usb usb1: Product: EHCI Host Controller
[ 4.045074] usb usb1: Manufacturer: Linux 3.12.6-armv7-x11 ehci_hcd
[ 4.051666] usb usb1: SerialNumber: 48064800.ehci
[ 4.057464] hub 1-0:1.0: USB hub found
[ 4.061523] hub 1-0:1.0: 3 ports detected
[ 4.066467] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.073394] ohci-omap3 48064400.ohci: OMAP3 OHCI Host Controller
[ 4.080139] ohci-omap3 48064400.ohci: new USB bus registered, assigned bus number 2
[ 4.088226] ohci-omap3 48064400.ohci: irq 92, io mem 0x48064400
[ 4.168975] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 4.176086] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.183715] usb usb2: Product: OMAP3 OHCI Host Controller
[ 4.189422] usb usb2: Manufacturer: Linux 3.12.6-armv7-x11 ohci_hcd
[ 4.196014] usb usb2: SerialNumber: 48064400.ohci
[ 4.202667] hub 2-0:1.0: USB hub found
[ 4.206665] hub 2-0:1.0: 3 ports detected
[ 4.211883] usbcore: registered new interface driver usb-storage
[ 4.218383] usbcore: registered new interface driver usbserial
[ 4.224670] usbcore: registered new interface driver option
[ 4.230621] usbserial: USB Serial support registered for GSM modem (1-port)
[ 4.243041] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 4.243072] musb-hdrc: MHDRC RTL version 1.800
[ 4.243072] musb-hdrc: setup fifo_mode 4
[ 4.243103] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 4.243225] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver
[ 4.249725] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus number 3
[ 4.258270] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.265472] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.273101] usb usb3: Product: MUSB HDRC host driver
[ 4.278320] usb usb3: Manufacturer: Linux 3.12.6-armv7-x11 musb-hcd
[ 4.284912] usb usb3: SerialNumber: musb-hdrc.0.auto
[ 4.290985] hub 3-0:1.0: USB hub found
[ 4.295013] hub 3-0:1.0: 1 port detected
[ 4.300567] mousedev: PS/2 mouse device common for all mice
[ 4.307739] i2c /dev entries driver
[ 4.314361] omap_wdt: OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 4.323364] sdhci: Secure Digital Host Controller Interface driver
[ 4.329956] sdhci: Copyright(c) Pierre Ossman
[ 4.334838] of_get_named_gpio_flags: can't parse gpios property of node '/ocp/mmc@4809c000[0]'
[ 4.334869] of_get_named_gpio_flags: can't parse gpios property of node '/ocp/mmc@4809c000[0]'
[ 4.335296] omap-dma-engine 48056000.dma-controller: allocating channel for 62
[ 4.343017] omap-dma-engine 48056000.dma-controller: allocating channel for 61
[ 4.354309] omap_hsmmc mmc.18: pins are not configured from the driver
[ 4.399230] of_get_named_gpio_flags: can't parse gpios property of node '/ocp/mmc@480b4000[0]'
[ 4.399261] of_get_named_gpio_flags: can't parse gpios property of node '/ocp/mmc@480b4000[0]'
[ 4.399444] omap-dma-engine 48056000.dma-controller: allocating channel for 48
[ 4.407104] omap-dma-engine 48056000.dma-controller: allocating channel for 47
[ 4.515991] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 4.524963] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.532226] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.538269] mmc0: new high speed SDHC card at address 1234
[ 4.544952] usbcore: registered new interface driver usbhid
[ 4.550872] usbhid: USB HID core driver
[ 4.555938] mmcblk0: mmc0:1234 SA08G 7.28 GiB
[ 4.561859] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 4.568939] [drm] No driver support for vblank timestamp query.
[ 4.575134] [drm] Initialized imx-drm 1.0.0 20120507 on minor 0
[ 4.584381] mmcblk0: p1 p2
[ 4.593353] of_get_named_gpio_flags: can't parse gpios property of node '/sound[0]'
[ 4.593872] of_get_named_gpio_flags: can't parse gpios property of node '/ocp/i2c@48070000/twl@48/audio/codec[0]'
[ 4.599639] mmc1: card claims to support voltages below the defined range. These will be ignored.
[ 4.620208] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 4.627288] mmc1: new high speed SDIO card at address 0001
[ 4.661529] omap-twl4030 sound.29: twl4030-hifi <-> 49022000.mcbsp mapping ok
[ 4.673522] oprofile: using arm/armv7
[ 4.677551] nf_conntrack version 0.5.0 (7884 buckets, 31536 max)
[ 4.685180] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.690887] TCP: cubic registered
[ 4.695007] NET: Registered protocol family 10
[ 4.700744] mip6: Mobile IPv6
[ 4.703887] NET: Registered protocol family 17
[ 4.708740] Bridge firewalling registered
[ 4.713287] Bluetooth: RFCOMM TTY layer initialized
[ 4.718444] Bluetooth: RFCOMM socket layer initialized
[ 4.723907] Bluetooth: RFCOMM ver 1.11
[ 4.727844] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 4.733459] Bluetooth: BNEP filters: protocol multicast
[ 4.739013] Bluetooth: BNEP socket layer initialized
[ 4.744201] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.750457] Bluetooth: HIDP socket layer initialized
[ 4.755828] Key type dns_resolver registered
[ 4.760345] mpls_gso: MPLS GSO support
[ 4.767303] ThumbEE CPU extension supported.
[ 4.771972] Registering SWP/SWPB emulation handler
[ 4.777069] SmartReflex Class3 initialized
[ 4.782257] registered taskstats version 1
[ 4.786651] AppArmor: AppArmor sha1 policy hashing enabled
[ 4.793029] VPLL2: disabling
[ 4.796752] VDAC: disabling
[ 4.801391] omapdrm omapdrm.0: DMM not available, disable DMM support
[ 4.808807] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 4.815856] [drm] No driver support for vblank timestamp query.
[ 4.822235] omapdrm omapdrm.0: No connectors reported connected with modes
[ 4.829589] [drm] Cannot find any crtc or sizes - going 1024x768
[ 4.859924] Console: switching to colour frame buffer device 128x48
[ 4.882995] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
[ 4.889343] omapdrm omapdrm.0: registered panic notifier
[ 4.895019] [drm] Initialized omapdrm 1.0.0 20110917 on minor 1
[ 4.901458] Error: Driver 'tfp410' is already registered, aborting...
[ 4.909667] of_get_named_gpio_flags exited with status 510
[ 4.910614] hsusb2_vbus: 3300 mV
[ 4.914703] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 4.921478] sr_init: No PMIC hook to init smartreflex
[ 4.927062] sr_init: platform driver register failed for SR
[ 4.933044] imx-drm imx-drm: No connectors reported connected with modes
[ 4.940246] [drm] Cannot find any crtc or sizes - going 1024x768
[ 4.949768] imx-drm imx-drm: fb1: frame buffer device
[ 4.955688] ALSA device list:
[ 4.958923] #0: omap3beagle
[ 4.968383] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 4.976257] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 12.277954] EXT4-fs (mmcblk0p2): recovery complete
[ 13.079833] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 13.088592] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 13.097961] devtmpfs: mounted
[ 13.102233] Freeing unused kernel memory: 460K (c0ab0000 - c0b23000)
[ 13.793548] init: plymouth-upstart-bridge main process (69) terminated with status 1
[ 13.816986] init: plymouth-upstart-bridge main process ended, respawning
[ 13.954345] init: plymouth-upstart-bridge main process (79) terminated with status 1
[ 13.962921] init: plymouth-upstart-bridge main process ended, respawning
[ 13.978302] init: ureadahead main process (72) terminated with status 5
[ 14.070800] init: plymouth-upstart-bridge main process (84) terminated with status 1
[ 14.079406] init: plymouth-upstart-bridge main process ended, respawning
[ 14.560333] init: mounted-proc main process (96) terminated with status 1
[ 16.454223] systemd-udevd[195]: starting version 204
[ 17.160217] of_get_named_gpio_flags exited with status 4
[ 17.160766] input: gpio_keys.30 as /devices/gpio_keys.30/input/input0
[ 17.270935] (stk) :sysfs entries created
[ 18.399963] hub 1-0:1.0: USB hub found
[ 18.400451] hub 1-0:1.0: 3 ports detected
[ 18.450378] hub 2-0:1.0: USB hub found
[ 18.450653] hub 2-0:1.0: 3 ports detected
[ 18.471588] hub 3-0:1.0: USB hub found
[ 18.471984] hub 3-0:1.0: 1 port detected
[ 18.764190] twl_rtc rtc.35: Power up reset detected.
[ 18.771453] twl_rtc rtc.35: Enabling TWL-RTC
[ 18.773986] twl_rtc rtc.35: rtc core: registered rtc.35 as rtc0
[ 18.909942] compat-drivers backport release: ol_r8.a8.04_32
[ 18.909942] Backport based on wl18xx.git ol_r8.a8.10
[ 18.909973] compat.git: wl18xx.git
[ 20.328643] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-ro
[ 22.820922] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 26.311614] cfg80211: Calling CRDA to update world regulatory domain
[ 26.596069] wlcore: wl18xx driver version: ol_r8.a8.04_32
[ 26.850463] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[ 26.867645] wlcore: loaded
[ 26.867706] wlcore: driver version: ol_r8.a8.04_32
[ 26.867736] wlcore: compilation time: Sun Sep 14 16:58:31 2014
[ 28.850677] wlcore: PHY firmware version: Rev 8.2.0.0.195
[ 28.955017] wlcore: firmware booted (Rev 8.8.0.0.13)
[ 28.999664] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 30.679748] init: avahi-cups-reload main process (491) terminated with status 1
[ 46.839874] udc musb-hdrc.0.auto: registering UDC driver [g_ether]
[ 46.881134] using random self ethernet address
[ 46.881164] using random host ethernet address
[ 46.882293] usb0: HOST MAC ba:26:f8:f4:e9:a8
[ 46.882415] usb0: MAC 6a:05:17:64:ad:39
[ 46.882476] using random self ethernet address
[ 46.882507] using random host ethernet address
[ 46.882537] g_ether gadget: adding config #2 'RNDIS'/bf1f03a8
[ 46.882537] rndis_register: configNr = 0
[ 46.882568] g_ether gadget: adding 'rndis'/df5830c0 to config 'RNDIS'/bf1f03a8
[ 46.882598] rndis_set_param_medium: 0 0
[ 46.882629] g_ether gadget: RNDIS: dual speed IN/ep1in OUT/ep1out NOTIFY/ep2in
[ 46.882629] g_ether gadget: cfg 2/bf1f03a8 speeds: high full
[ 46.882659] g_ether gadget: interface 0 = rndis/df5830c0
[ 46.882659] g_ether gadget: interface 1 = rndis/df5830c0
[ 46.882690] g_ether gadget: adding config #1 'CDC Ethernet (ECM)'/bf1f02fc
[ 46.882720] g_ether gadget: adding 'cdc_ethernet'/df583180 to config 'CDC Ethernet (ECM)'/bf1f02fc
[ 46.882751] g_ether gadget: CDC Ethernet: dual speed IN/ep1in OUT/ep1out NOTIFY/ep2in
[ 46.882781] g_ether gadget: cfg 1/bf1f02fc speeds: high full
[ 46.882781] g_ether gadget: interface 0 = cdc_ethernet/df583180
[ 46.882812] g_ether gadget: interface 1 = cdc_ethernet/df583180
[ 46.882812] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
[ 46.882843] g_ether gadget: g_ether ready
[ 47.084564] hdev de3ee000
[ 47.094726] HCI device registered (hdev de3ee000)
[ 47.104766] hci0 de3ee000
[ 17.271026] (stk) : debugfs entries created
[ 47.104797] (stc): chnl_id list empty :4 (stk) : st_kim_start
[ 47.244781] (stk) :ldisc_install = 1(stc): st_tty_open
[ 47.334869] (stk) :line discipline installed(stk) :TIInit_11.8.32.bts
[ 47.341156] (stk) :change remote baud rate command in firmware(stk) :skipping the wait event of change remote baud
[ 47.851226] (stk) :sleep command in scrinit: plymouth-upstart-bridge main process ended, respawning
[ 48.685180] (stk) :sleep command in scr
[ 50.352935] (stc): add_channel_to_table: id 4
[ 50.352966] (stc): add_channel_to_table: id 2
[ 50.352966] (stc): add_channel_to_table: id 3
[ 50.356384] hci0: type 1 len 4
[ 50.357025] hci0: type 1 len 4
[ 50.357666] hci0: type 1 len 4
[ 50.358276] hci0: type 1 len 4
[ 50.358764] hci0: type 1 len 4
[ 50.359161] hci0: type 1 len 4
[ 50.359771] hci0: type 1 len 4
[ 50.362609] hci0: type 1 len 4
[ 50.363189] hci0: type 1 len 5
[ 50.363769] hci0: type 1 len 6
[ 50.364135] hci0: type 1 len 4
[ 50.364501] hci0: type 1 len 4
[ 50.364837] hci0: type 1 len 4
[ 50.365203] hci0: type 1 len 4
[ 50.365722] hci0: type 1 len 4
[ 50.366088] hci0: type 1 len 4
[ 50.366546] hci0: type 1 len 4
[ 50.367004] hci0: type 1 len 12
[ 50.367462] hci0: type 1 len 12
[ 50.368103] hci0: type 1 len 4
[ 50.369079] hci0: type 1 len 245
[ 50.372009] hci0: type 1 len 5
[ 50.372589] hci0: type 1 len 4
[ 50.373138] hci0: type 1 len 5
[ 50.373809] hci0: type 1 len 11
[ 50.374389] hci0: type 1 len 6
[ 50.374694] hci0: type 1 len 36
[ 50.457366] hci0: type 1 len 5
[ 50.457763] hci0: type 1 len 6
[ 50.458099] hci0: type 1 len 5
[ 50.458618] hci0: type 1 len 7
[ 50.459045] hci0: type 1 len 252
[ 50.461883] hci0: type 1 len 245
[ 71.018005] wlcore: ERROR SW watchdog interrupt received! starting recovery.
[ 71.025604] ------------[ cut here ]------------
[ 71.025878] WARNING: CPU: 0 PID: 406 at /home/hari/work/clickdrive/testing-release/test2/utility/compat-wireless/drivers/net/wireless/ti/wlcore/main.c:802 wl12xx_queue_recovery_work+0x2c/0x64 [wlcore]()
[ 71.025909] Modules linked in: btwilink usb_f_ecm g_ether usb_f_rndis u_rndis u_ether libcomposite wl18xx(O) wlcore(O) mac80211(O) cfg80211(O) wlcore_sdio(O) compat(O) rtc_twl st_drv uio_pdrv_genirq uio gpio_keys
[ 71.026092] CPU: 0 PID: 406 Comm: irq/224-wl18xx Tainted: G O 3.12.6-armv7-x11 #6
[ 71.026184] [<c0014060>] (unwind_backtrace+0x0/0xdc) from [<c0010f08>] (show_stack+0x10/0x14)
[ 71.026245] [<c0010f08>] (show_stack+0x10/0x14) from [<c074d344>] (dump_stack+0x70/0x8c)
[ 71.026306] [<c074d344>] (dump_stack+0x70/0x8c) from [<c003cb64>] (warn_slowpath_common+0x64/0x88)
[ 71.026367] [<c003cb64>] (warn_slowpath_common+0x64/0x88) from [<c003cc18>] (warn_slowpath_null+0x18/0x20)
[ 71.026519] [<c003cc18>] (warn_slowpath_null+0x18/0x20) from [<bf178204>] (wl12xx_queue_recovery_work+0x2c/0x64 [wlcore])
[ 71.026794] [<bf178204>] (wl12xx_queue_recovery_work+0x2c/0x64 [wlcore]) from [<bf178514>] (wlcore_irq+0xdc/0x154 [wlcore])
[ 71.026947] [<bf178514>] (wlcore_irq+0xdc/0x154 [wlcore]) from [<c007d29c>] (irq_thread_fn+0x1c/0x34)
[ 71.027008] [<c007d29c>] (irq_thread_fn+0x1c/0x34) from [<c007d540>] (irq_thread+0xf4/0x16c)
[ 71.027038] [<c007d540>] (irq_thread+0xf4/0x16c) from [<c0059d20>] (kthread+0xa0/0xac)
[ 71.027099] [<c0059d20>] (kthread+0xa0/0xac) from [<c000d998>] (ret_from_fork+0x14/0x3c)
[ 71.027130] ---[ end trace d8a11efff8fdaf1f ]---
[ 71.028045] wlcore: Reading FW panic log
[ 71.031768] wlcore: Hardware recovery in progress. FW ver: Rev 8.8.0.0.13
[ 71.032958] wlcore: pc: 0x114be6, hint_sts: 0x00000000 count: 1
[ 71.033905] wlcore: down
[ 71.035522] ieee80211 phy0: Hardware restart was requested
[ 71.496612] wlcore: PHY firmware version: Rev 8.2.0.0.195
[ 71.591308] wlcore: firmware booted (Rev 8.8.0.0.13)
[ 82.026214] wlcore: ERROR SW watchdog interrupt received! starting recovery.
[ 82.033813] ------------[ cut here ]------------
[ 82.034057] WARNING: CPU: 0 PID: 406 at /home/hari/work/clickdrive/testing-release/test2/utility/compat-wireless/drivers/net/wireless/ti/wlcore/main.c:802 wl12xx_queue_recovery_work+0x2c/0x64 [wlcore]()
[ 82.034088] Modules linked in: btwilink usb_f_ecm g_ether usb_f_rndis u_rndis u_ether libcomposite wl18xx(O) wlcore(O) mac80211(O) cfg80211(O) wlcore_sdio(O) compat(O) rtc_twl st_drv uio_pdrv_genirq uio gpio_keys
[ 82.034271] CPU: 0 PID: 406 Comm: irq/224-wl18xx Tainted: G W O 3.12.6-armv7-x11 #6
[ 82.034362] [<c0014060>] (unwind_backtrace+0x0/0xdc) from [<c0010f08>] (show_stack+0x10/0x14)
[ 82.034454] [<c0010f08>] (show_stack+0x10/0x14) from [<c074d344>] (dump_stack+0x70/0x8c)
[ 82.034515] [<c074d344>] (dump_stack+0x70/0x8c) from [<c003cb64>] (warn_slowpath_common+0x64/0x88)
[ 82.034545] [<c003cb64>] (warn_slowpath_common+0x64/0x88) from [<c003cc18>] (warn_slowpath_null+0x18/0x20)
[ 82.034729] [<c003cc18>] (warn_slowpath_null+0x18/0x20) from [<bf178204>] (wl12xx_queue_recovery_work+0x2c/0x64 [wlcore])
[ 82.034973] [<bf178204>] (wl12xx_queue_recovery_work+0x2c/0x64 [wlcore]) from [<bf178514>] (wlcore_irq+0xdc/0x154 [wlcore])
[ 82.035125] [<bf178514>] (wlcore_irq+0xdc/0x154 [wlcore]) from [<c007d29c>] (irq_thread_fn+0x1c/0x34)
[ 82.035186] [<c007d29c>] (irq_thread_fn+0x1c/0x34) from [<c007d540>] (irq_thread+0xf4/0x16c)
[ 82.035247] [<c007d540>] (irq_thread+0xf4/0x16c) from [<c0059d20>] (kthread+0xa0/0xac)
[ 82.035278] [<c0059d20>] (kthread+0xa0/0xac) from [<c000d998>] (ret_from_fork+0x14/0x3c)
[ 82.035308] ---[ end trace d8a11efff8fdaf20 ]---
[ 82.037689] wlcore: Reading FW panic log
[ 82.041442] wlcore: Hardware recovery in progress. FW ver: Rev 8.8.0.0.13
[ 82.043487] wlcore: pc: 0x11afc, hint_sts: 0x00000000 count: 2
[ 82.044433] wlcore: down
[ 82.045715] ieee80211 phy0: Hardware restart was requested
[ 82.511962] wlcore: PHY firmware version: Rev 8.2.0.0.195
[ 82.609436] wlcore: firmware booted (Rev 8.8.0.0.13)
