wlan scan ssid
Other Parts Discussed in Thread: CC3200
Now i want to scan ssid of the enviroment using cc3200.I have see the demo of scan_policy .
First my cc3200 works in ap mode which have created a udp socket,and i use pc connect the 3200.
Then i send a command to it,after the 3200 recives the command ,it begin to scan the ssid of other ap.
After it get the list of ssid, it turn to the AP mode and send these ssids  to the pc.
Now i have one problem, it takes too long to scan the list.What should i do to reduce the time .
Follow is my code:
                        sl_Close(iSockID);    //close the udp socket
                        sl_WlanSetMode(ROLE_STA);
                        sl_Stop(10);  //
                        sl_Start(NULL,NULL,NULL);
                        ucpolicyOpt = SL_CONNECTION_POLICY(0, 0, 0, 0,0);
                        lRetVal = sl_WlanPolicySet(SL_POLICY_CONNECTION , ucpolicyOpt, NULL, 0);
                        if(lRetVal != 0)
                            UART_PRINT("Unable to clear the Connection Policy\r\n");
                        ucpolicyOpt = SL_SCAN_POLICY(1);
                        // set scan cycle to 1 seconds
                        policyVal.uiPolicyLen = 1;   //the least is 900 ms?
                        // set scan policy - this starts the scan
                        lRetVal = sl_WlanPolicySet(SL_POLICY_SCAN , ucpolicyOpt,
                                                   (unsigned char*)(policyVal.ucPolicy), sizeof(policyVal));
                        if(lRetVal!=0)
                            UART_PRINT("Unable to set the Scan Policy\r\n");
                            //return lRetVal;
                        usr_Report("start scan");
                        MAP_UtilsDelay(1000000);//wait to read list
                        sl_WlanGetNetworkList(0, (unsigned char)20,
        &netEntries[0]);
                        usr_Report("get list");
                        for(j=0;j<20-1;j++)
                            for(i=0;i<20-1-j;i++)
                                if(netEntries[i].rssi>netEntries[i+1].rssi)//数组元素大小按升序排列
                                    data_temp1=netEntries[i];
                                    netEntries[i]=netEntries[i+1];
                                    netEntries[i+1]=data_temp1;
                        sl_WlanSetMode(ROLE_AP);
                        sl_Stop(10);  //
                        for(j=0;j<32;j++)
                            para[j]=init_flash_temp[init_flash_ap_sta+j];
                        sl_WlanSet(SL_WLAN_CFG_AP_ID, WLAN_AP_OPT_SSID, strlen((const char *)para), (unsigned char *)para);
                            val = SL_SEC_TYPE_OPEN;
                            sl_WlanSet(SL_WLAN_CFG_AP_ID, WLAN_AP_OPT_SECURITY_TYPE, 1, (unsigned char *)&val);
                        iSockID = sl_Socket(SL_AF_INET,SL_SOCK_DGRAM, 0);
                        if( iSockID < 0 )
                            usr_Report("Creat search UDP SOCKET err\r\n");
                            goto start;
                        // binding the UDP socket to the UDP server address
                        iStatus = sl_Bind(iSockID, (SlSockAddr_t *)&sLocalAddr, iAddrSize);
                        if( iStatus < 0 )
                            usr_Report("Creat search UDP SOCKET bind err\r\n");
                            goto start;
                        iStatus = sl_SetSockOpt(iSockID, SL_SOL_SOCKET, SL_SO_NONBLOCKING,
                                                            &lNonBlocking, sizeof(lNonBlocking));
                        if( iStatus < 0 )
                            usr_Report("Creat search UDP SOCKET set opt err\r\n");
                            goto start;
                        for(i=20;i>0;i--)
                            usr_Report("%s\r\n",netEntries[i-1].ssid);
                            usr_Report("%d\r\n",netEntries[i-1].rssi);
                        g_cBsdBuf[0]=0xff;
                        g_cBsdBuf[1]=0xff;//length
                        g_cBsdBuf[2]=0xff;
                        g_cBsdBuf[3]=0x81;//return cmd
                        g_cBsdBuf[4]=0x00;//num of ap
                        i=5;
                        for(j=20;j>0;j--)//ap ssid
                            if(netEntries[j-1].ssid_len==0)
                                continue;
                            else
                                for(k=0;k<netEntries[j-1].ssid_len;k++)
                                    g_cBsdBuf[i++]=netEntries[j-1].ssid[k];
                                g_cBsdBuf[i++]=0x00;//end of ssid
                                if((netEntries[j-1].rssi+95)*2<0)
                                    g_cBsdBuf[i++]=0;//ssid rssi
                                else if((netEntries[j-1].rssi+95)*2>100)
                                    g_cBsdBuf[i++]=100;//ssid rssi
                                else
                                    g_cBsdBuf[i++]=(netEntries[j-1].rssi+95)*2;
                                g_cBsdBuf[i++]=0x0d;//end ssid rssi
                                g_cBsdBuf[i++]=0x0a;//end ssid rssi
                                g_cBsdBuf[4]++;
                        g_cBsdBuf[1]=(i-3)<<8;//length
                        g_cBsdBuf[2]=i-3;
                        data_sum=0;
                        for(j=1;j<i;j++)
                            data_sum+=g_cBsdBuf[j];
                        g_cBsdBuf[i++]=data_sum;//sum check
                        sl_SendTo(iSockID, g_cBsdBuf, i, 0,( SlSockAddr_t *)&sAddr, (SlSocklen_t)iAddrSize);
