hi, all
I found a serious problem on the module(CC3100+MSP430F5529), the following is my context description
we are developing a customized android tablet, android verison is 4.0.4, the SOC is samsung s5pv210, all drivers work fine under android platform, surfing on internet and pinging local PC by wifi module are both very good. I have install wifi starter(http://www.ti.com/tool/wifistarter) on our android tablet. I also burning ti official program into CC3100+MSP430F5529, the program info is as following:
it is based on ti official SDK project C:\ti\CC3100SDK_1.0.0\cc3100-sdk\platform\msp430f5529lp\example_project_ccs\getting_started_with_wlan_station (I using default installation path,CC3100SDK-1.0.0-windows-installer.exe,CC31xx_CC32xx_ServicePack-1.0.0.1.2-windows-installer.exe,CC3100_OTA_Update-1.0.0-windows-installer.exe,Code Composer Studio 6.0.1 ), the line 527 in main.c under the project path(my path is D:\CCS6_WS\workspace_v6_0-wlan-station\getting_started_with_wlan_station)
retVal = sl_WlanConnect((_i8 *)SSID_NAME, pal_Strlen(SSID_NAME), 0, &secParams, 0);
is changed to the following contents:
CLI_Write(" Starting smartconfig process \n\r");
/* Clear all profiles */
/* This is of course not a must, it is used in this example to make sure
* we will connect to the new profile added by SmartConfig
sl_WlanProfileDel(WLAN_DEL_ALL_PROFILES);
/* set AUTO policy */
sl_WlanPolicySet(SL_POLICY_CONNECTION,SL_CONNECTION_POLICY(1,0,0,0,0),NULL,0);
/* Start SmartConfig
* This example uses the unsecured SmartConfig method
retVal = sl_WlanSmartConfigStart(1, /* groupIdBitmask */
1, /* cipher */
0, /* publicKeyLen */
0, /* group1KeyLen */
0, /* group2KeyLen */
(const unsigned char *)"", /* publicKey */
(const unsigned char *)"", /* group1Key */
(const unsigned char *)""); /* group2Key */
if (retVal) {
CLI_Write("Failed to connect AP \r\n");
return -1;
no any other modifications are done in relevant source code;
the question is
when I run wifi starter on our customized android tablet, wifi starter can not found the device(CC3100+MSP430F5529), the following is the device print info:
Getting started with station application - Version 1.1.0
Device is configured in default state
Device started as STATION
then I run wifi starter on my cell phone or other android tablet on-sale to find devcie(CC3100+MSP430F5529), the device is normally found, the following is device console print info:
[WLAN EVENT] Unexpected event
Connection established w/ AP and IP is acquired
Pinging...!
Device successfully connected to the LAN and internet
In addition, I found that when I restore source code modification I describle above, only make a SSID name and passkey modification in C:\ti\CC3100SDK_1.0.0\cc3100-sdk\examples\common\sl_common.h, the wifi starter on our customized android tablet can found the device(CC3100+MSP430F5529), namely, after the credentials is verified, the device can communicate with wifi starter.
any suggestions and ideas are welcome
