Unable to open, read or write to a file in httpserver code when device is in AP Mode.
Other Parts Discussed in Thread: CC3200SDK, CC3200-LAUNCHXL, UNIFLASH, CC3200
I have been referring to the httpserver code, wherein i have been able create my own webpage for setting the IP address, gateway etc.
I have used user-defined tokens and successfully received data in my code.
My problem is that i am unable to save this data in a file on the Serial Flash.
I want to save the data in a .txt file, but the command lRetVal = sl_FsOpen((unsigned char *)USER_FILE_NAME, FS_MODE_OPEN_CREATE(65536, \ _FS_FILE_OPEN_FLAG_COMMIT|_FS_FILE_PUBLIC_WRITE), ulToken, lFileHandle); does not execute completely, and does not return lRetVal.
I did refer to the file_operations code, and performed these open-write-read operations using sl_FsOpen, sl_FsWrite, sl_FsRead, sl_FsClose etc successfully.
But, i am unable to do the same in httpserver code when device is in AP mode.
Please shed some light on this.
P.S: #define USER_FILE_NAME "fs_demo.txt"
  • HI Abhishek,
    Please provide us following information:
    1. Device version
    2. Is it stuck in sl_FsOpen? If yes then please provide us the stack trace else tell us the error code you are getting.
    Aashish
  • Hi,You should be able to communicate with the file system during AP mode.
    Can you please clarify if you are getting stuck on file system API or does it return with some error code? if it is stuck, what is the call stack?
    In addition, are you able to communicate with the serial flash at all (not only in AP mode, e.g. run the file operations example code)?
    Last, please send me the version of the device and also the service pack version (you can do it by invoking sl_DevGet() with SL_DEVICE_GENERAL_VERSION option).
    Regards,Shlomi
  • Hello Aashish.
    Many thanks for replying.
    I am using the CC3200-LaunchXL Rev3.2, the CC3200SDK_1.0.0 and CC31xx_CC32xx_ServicePack_1.0.0.1.1.
    The execution is not struck anywhere, it returns to
    //Handle Async Events
       while(1)
    I am attaching the stack trace screens for code execution before execution, at execution and after execution of  sl_FsOpen (in descending order).
    Please reply.
  • Hello Shlomi.
    Thank you for replying.
    I am unable to communicate with the file system in AP mode only.
    The code doesn't get stuck anywhere, it doesn't completely execute the sl_FsOpen, sl_FsWrite etc functions, and goes to handle Async events. It does not return the value of IRetVal.
    In other cases, i am completely able to communicate with the Serial Flash.
    I have run the file_operations many times to confirm. Also, i have Flashed it using UniFlash as well.
    I have mentioned the device and software versions and uploaded screens of Stack Traces above.
    Please reply.
  • Hi Abhishek,
    Still we need some more information form you as it still not clear from stack trace. Can you please put a debug point at if(RetVal < 0) and let us know what value you are getting for RetVal. If it's not coming to this debug point then please do step-by-step debugging and let us know where exactly it stuck in sl_FsOpen.
    Also let us know device version that printed on chip (HZ or JR or something else).
    Aashish
  • Thank you once again.
    The version name printed on the device is XCC3200HZ.
    The execution never comes to if(RetVal<0), nor does it execute the else part.
    It just goes to handle Async events.
    I am uploading screens of single step debug.
    Please refer and reply.
  • Hi Shlomi,
    You said "Hi,You should be able to communicate with the file system during AP mode. "
    Can you please provide some example or code to show how this is done.
    Abhishek.
  • Hi Abhishek,
    You supposed to not to call any simplelink host api (in your case sl_FsOpen) from simplelink async event handler as it will try to lock a object that already locked by host callback caller function.
    Aashish
  • Hi,I can see the problem.
    You are calling to driver API (in this case file system API but it could be any other command) from async event context.
    This is not allowed as the async event grabs the global lock and then the calling API waits on the same global lock causing to a dead lock.
    You can for example implement a state machine and avoid calling these APIs from event context. You should call it from your main.
    Regards,Shlomi
  • Thank you for replying.
    I would like to explain to you my code.
    I have created a html page, which sends me the IP address, Gateway, Subnet Mask, and DNS while other page sends me the SSID name, Password and Profile Priority set in the browser.
    I want to store this data in a .txt file (while the CC3200 is still in AP mode).
    Then, i want to restart my device and come up in Station mode, apply the stored IP adddress etc and connect to the AP whose SSID name and Password is stored.
    I am finding it difficult to store the data received from the browser in .txt file.
  • Whenever i stop(halt) the execution, the execution always stops in static void HTTPServerTask(void *pvParameters) function....
    As you suggest, where should i call the sl_FsOpen function from ??
    Should i call it from
    while(1)
    //CALL sl_FsOpen from here ??
    or should i call it from
    void main()
    // Start OS Scheduler
    osi_start();
    while (1)
    Please reply.
  • Hi Abhishek,
    You can use queue for your requirement. You can post data to a queue from async handler and read it back in another task and write to a file. For queue example please refer freertos_demo.
    Aashish
  • Thank you so much.
    I will implement this and get back to you.
    Abhishek.
  • Hello Ashish.
    I implemented the what you suggested.
    I am uploading some screens that will help you understand my implementation step by step....
  • First: In the httpserver code, i created another task for creating a .txt file (task-2)
    Second: static void Update_IPConfig_file (void *pvParameters) called the function WriteFileToDevice(&ulToken, &lFileHandle)
    Third: long WriteFileToDevice(unsigned long *ulToken, long *lFileHandle) calls the function sl_FsOpen(.....)
  • Hi Abhishek,
    Is it working or you still facing some issue?
    Aashish
  • Fourth: sl_FsOpen called the function RetVal = _SlDrvCmdOp((_SlCmdCtrl_t *)&_SlFsOpenCmdCtrl, &Msg, &CmdExt);
    Fifth: _SlDrvCmdOp calls the function OSI_RET_OK_CHECK(sl_LockObjLock(&g_pCB->GlobalLockObj, SL_OS_WAIT_FOREVER));
    Sixth: osi_LockObjLock calls the function  if(pdTRUE == xSemaphoreTake( *pLockObj, ( TickType_t ) (Timeout/portTICK_PERIOD_MS) ))
  • Seventh: Execution goes to xQueueGenericReceive( QueueHandle_t xQueue, void * const pvBuffer, TickType_t xTicksToWait, const BaseType_t xJus
    Eight: Execution gets stuck in void
    vAssertCalled( const char *pcFile, unsigned long ulLine )
  • Hello Aashish.
    Thank you very much for replying.
    I have sent you 8 steps and screens with stack trace.
    I am still unable to open the file using sl_FsOpen...
    Please go through the screens and reply.
    Warm regards,
    Abhishek
  • Hi Abhishek,
    Is it possible to share code with us?
    Aashish
  • Yes.
    Uploading the files here...
    // Copyright (C) 2014 Texas Instruments Incorporated - http://www.ti.com/
    // Redistribution and use in source and binary forms, with or without
    // modification, are permitted provided that the following conditions
    // are met:
    // Redistributions of source code must retain the above copyright
    // notice, this list of conditions and the following disclaimer.
    // Redistributions in binary form must reproduce the above copyright
    // notice, this list of conditions and the following disclaimer in the
    // documentation and/or other materials provided with the
    // distribution.
    // Neither the name of Texas Instruments Incorporated nor the names of
    // its contributors may be used to endorse or promote products derived
    // from this software without specific prior written permission.
    // THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    // "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    // LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    // A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
    // OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    // SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    // LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    // DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
    // THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    // (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
    // OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    // Application Name - HTTP Server
    // Application Overview - This is a sample application demonstrating
    // interaction between HTTP Client(Browser) and
    // SimpleLink Device.The SimpleLink device runs an
    // HTTP Server and user can interact using web browser.
    // Application Details -
    // http://processors.wiki.ti.com/index.php/CC32xx_HTTP_Server
    // or
    // doc\examples\CC32xx_HTTP_Server.pdf
    //! \addtogroup httpserver
    // Standard includes
    #include <string.h>
    #include <stdlib.h>
    // Simplelink includes
    #include "simplelink.h"
    #include "netcfg.h"
    //driverlib includes
    #include "hw_ints.h"
    #include "hw_types.h"
    #include "hw_memmap.h"
    #include "interrupt.h"
    #include "utils.h"
    #include "pin.h"
    #include "uart.h"
    #include "rom.h"
    #include "rom_map.h"
    #include "prcm.h"
    //Free_rtos/ti-rtos includes
    #include "osi.h"
    // common interface includes
    #include "gpio_if.h"
    #include "uart_if.h"
    #include "common.h"
    #include "smartconfig.h"
    #include "pinmux.h"
    #define APPLICATION_NAME "HTTP Server"
    #define APPLICATION_VERSION "1.1.0"
    #define AP_SSID_LEN_MAX (33)
    #define ROLE_INVALID (-5)
    #define LED_STRING "LED"
    #define LED1_STRING "LED1_"
    #define LED2_STRING ",LED2_"
    #define LED_ON_STRING "ON"
    #define LED_OFF_STRING "OFF"
    #define OOB_TASK_PRIORITY (1)
    #define OSI_STACK_SIZE (2048)
    #define SH_GPIO_3 (3) /* P58 - Device Mode */
    #define AUTO_CONNECTION_TIMEOUT_COUNT (50) /* 5 Sec */
    #define SL_MAX_FILE_SIZE 64L*1024L /* 64KB file */
    #define BUF_SIZE 2048
    // Application specific status/error codes
    typedef enum{
    // Choosing -0x7D0 to avoid overlap w/ host-driver's error codes
    LAN_CONNECTION_FAILED = -0x7D0,
    INTERNET_CONNECTION_FAILED = LAN_CONNECTION_FAILED - 1,
    DEVICE_NOT_IN_STATION_MODE = INTERNET_CONNECTION_FAILED - 1,
    FILE_ALREADY_EXIST = -0x7D0,
    FILE_CLOSE_ERROR = FILE_ALREADY_EXIST - 1,
    FILE_NOT_MATCHED = FILE_CLOSE_ERROR - 1,
    FILE_OPEN_READ_FAILED = FILE_NOT_MATCHED - 1,
    FILE_OPEN_WRITE_FAILED = FILE_OPEN_READ_FAILED -1,
    FILE_READ_FAILED = FILE_OPEN_WRITE_FAILED - 1,
    FILE_WRITE_FAILED = FILE_READ_FAILED - 1,
    STATUS_CODE_MAX = -0xBB8
    }e_AppStatusCodes;
    // GLOBAL VARIABLES -- Start
    unsigned char ptrlen ;
    unsigned long g_ulStatus = 0;//SimpleLink Status
    unsigned long g_ulPingPacketsRecv = 0; //Number of Ping Packets received
    unsigned long g_ulGatewayIP = 0; //Network Gateway IP address
    unsigned char g_ucConnectionSSID[SSID_LEN_MAX+1]; //Connection SSID
    unsigned char g_ucConnectionBSSID[BSSID_LEN_MAX]; //Connection BSSID
    unsigned char POST_token[] = "__SL_P_ULD";
    unsigned char GET_token[] = "__SL_G_ULD";
    int g_iSimplelinkRole = ROLE_INVALID;
    signed int g_uiIpAddress = 0;
    unsigned char g_ucSSID[AP_SSID_LEN_MAX];
    unsigned char gaucCmpBuf[BUF_SIZE];
    const unsigned char gaucOldMacDonald[] = "Old MacDonald had a farm,E-I-E-I-O, \
    And on his farm he had a cow, \
    E-I-E-I-O, \
    With a moo-moo here, \
    And a moo-moo there, \
    Here a moo, there a moo, \
    Everywhere a moo-moo. \
    Old MacDonald had a farm, \
    E-I-E-I-O. \
    E-I-E-I-O, \
    And on his farm he had a pig, \
    E-I-E-I-O, \
    With an oink-oink here, \
    And an oink-oink there, \
    Here an oink, there an oink, \
    Everywhere an oink-oink. \
    E-I-E-I-O. \
    E-I-E-I-O, \
    And on his farm he had a duck, \
    E-I-E-I-O, \
    With a quack-quack here, \
    And a quack-quack there, \
    Here a quack, there a quack, \
    Everywhere a quack-quack. \
    E-I-E-I-O. \
    E-I-E-I-O, \
    And on his farm he had a horse, \
    E-I-E-I-O, \
    With a neigh-neigh here, \
    And a neigh-neigh there, \
    Here a neigh, there a neigh, \
    Everywhere a neigh-neigh. \
    E-I-E-I-O. \
    E-I-E-I-O, \
    And on his farm he had a donkey, \
    E-I-E-I-O, \
    With a hee-haw here, \
    And a hee-haw there, \
    Here a hee, there a hee, \
    Everywhere a hee-haw. \
    E-I-E-I-O. \
    E-I-E-I-O, \
    And on his farm he had some chickens, \
    E-I-E-I-O, \
    With a cluck-cluck here, \
    And a cluck-cluck there, \
    Here a cluck, there a cluck, \
    Everywhere a cluck-cluck. \
    E-I-E-I-O.";
    long lRetVal;
    unsigned char policyVal;
    long lFileHandle;
    unsigned long ulToken;
    #if defined(ccs)
    extern void (* const g_pfnVectors[])(void);
    #endif
    #if defined(ewarm)
    extern uVectorEntry __vector_table;
    #endif
    // GLOBAL VARIABLES -- End
    // Variable related to Connection status
    volatile unsigned short g_usMCNetworkUstate = 0;
    int g_uiSimplelinkRole = ROLE_INVALID;
    unsigned int g_uiDeviceModeConfig = ROLE_STA; //default is STA mode
    unsigned char g_ucConnectTimeout =0;
    #ifdef USE_FREERTOS
    // FreeRTOS User Hook Functions enabled in FreeRTOSConfig.h
    //! \brief Application defined hook (or callback) function - assert
    //! \param[in] pcFile - Pointer to the File Name
    //! \param[in] ulLine - Line Number
    //! \return none
    void
    //Handle Assert here
    while(1)
    //! \brief Application defined idle task hook
    //! \param none
    //! \return none
    void
    vApplicationIdleHook( void)
    //Handle Idle Hook for Profiling, Power Management etc
    //! \brief Application defined malloc failed hook
    //! \param none
    //! \return none
    void vApplicationMallocFailedHook()
    //Handle Memory Allocation Errors
    while(1)
    //! \brief Application defined stack overflow hook
    //! \param none
    //! \return none
    void vApplicationStackOverflowHook( OsiTaskHandle *pxTask,
    signed char *pcTaskName)
    //Handle FreeRTOS Stack Overflow
    while(1)
    #endif //USE_FREERTOS
    //! This funtion includes the following steps:
    //! -open a user file for writing
    //! -write "Old MacDonalds" child song 37 times to get just below a 64KB file
    //! -close the user file
    //! /param[out] ulToken : file token
    //! /param[out] lFileHandle : file handle
    //! /return 0:Success, -ve: failure
    long lRetVal = -1;
    int iLoopCnt = 0;
    // create a user file
    ulToken,
    lFileHandle);
    if(lRetVal < 0)
    // File may already be created
    lRetVal = sl_FsClose(*lFileHandle, 0, 0, 0);
    ASSERT_ON_ERROR(lRetVal);
    else
    // close the user file
    if (SL_RET_CODE_OK != lRetVal)
    ASSERT_ON_ERROR(FILE_CLOSE_ERROR);
    // open a user file for writing
    FS_MODE_OPEN_WRITE,
    ulToken,
    lFileHandle);
    if(lRetVal < 0)
    ASSERT_ON_ERROR(FILE_OPEN_WRITE_FAILED);
    // write "Old MacDonalds" child song as many times to get just below a 64KB file
    for (iLoopCnt = 0;
    iLoopCnt < (SL_MAX_FILE_SIZE / sizeof(gaucOldMacDonald));
    iLoopCnt++)
    lRetVal = sl_FsWrite(*lFileHandle,
    (unsigned int)(iLoopCnt * sizeof(gaucOldMacDonald)),
    (unsigned char *)gaucOldMacDonald, sizeof(gaucOldMacDonald));
    if (lRetVal < 0)
    ASSERT_ON_ERROR(FILE_WRITE_FAILED);
    return SUCCESS;
    //! -open the user file for reading
    //! -read the data and compare with the stored buffer
    //! /param[in] ulToken : file token
    //! /param[in] lFileHandle : file handle
    //! /return 0: success, -ve:failure
    long ReadFileFromDevice(unsigned long ulToken, long lFileHandle)
    long lRetVal = -1;
    int iLoopCnt = 0;
    // open a user file for reading
    FS_MODE_OPEN_READ,
    &ulToken,
    &lFileHandle);
    if(lRetVal < 0)
    lRetVal = sl_FsClose(lFileHandle, 0, 0, 0);
    ASSERT_ON_ERROR(FILE_OPEN_READ_FAILED);
    // read the data and compare with the stored buffer
    for (iLoopCnt = 0;
    iLoopCnt++)
    lRetVal = sl_FsRead(lFileHandle,
    gaucCmpBuf, sizeof(gaucOldMacDonald));
    if ((lRetVal < 0) || (lRetVal != sizeof(gaucOldMacDonald)))
    ASSERT_ON_ERROR(FILE_READ_FAILED);
    lRetVal = memcmp(gaucOldMacDonald,
    gaucCmpBuf,
    if (lRetVal != 0)
    ASSERT_ON_ERROR(FILE_NOT_MATCHED);
    return SUCCESS;
    // Updating IP Configuration file
    if(WriteFileToDevice(&ulToken, &lFileHandle) < 0)
    GPIO_IF_LedOn(MCU_RED_LED_GPIO);
    LOOP_FOREVER();
    if(ReadFileFromDevice(ulToken, lFileHandle) < 0)
    LOOP_FOREVER();
    // SimpleLink Asynchronous Event Handlers -- Start
    //! \brief The Function Handles WLAN Events
    //! \param[in] pWlanEvent - Pointer to WLAN Event Info
    //! \return None
    void SimpleLinkWlanEventHandler(SlWlanEvent_t *pWlanEvent)
    if(!pWlanEvent)
    return;
    switch(pWlanEvent->Event)
    case SL_WLAN_CONNECT_EVENT:
    SET_STATUS_BIT(g_ulStatus, STATUS_BIT_CONNECTION);
    // Information about the connected AP (like name, MAC etc) will be
    // available in 'slWlanConnectAsyncResponse_t'-Applications
    // can use it if required
    // slWlanConnectAsyncResponse_t *pEventData = NULL;
    // pEventData = &pWlanEvent->EventData.STAandP2PModeWlanConnected;
    // Copy new connection SSID and BSSID to global parameters
    memcpy(g_ucConnectionSSID,pWlanEvent->EventData.
    STAandP2PModeWlanConnected.ssid_name,
    pWlanEvent->EventData.STAandP2PModeWlanConnected.ssid_len);
    memcpy(g_ucConnectionBSSID,
    pWlanEvent->EventData.STAandP2PModeWlanConnected.bssid,
    SL_BSSID_LENGTH);
    UART_PRINT("[WLAN EVENT] STA Connected to the AP: %s ,"
    "BSSID: %x:%x:%x:%x:%x:%x\n\r",
    g_ucConnectionSSID,g_ucConnectionBSSID[0],
    g_ucConnectionBSSID[1],g_ucConnectionBSSID[2],
    g_ucConnectionBSSID[3],g_ucConnectionBSSID[4],
    g_ucConnectionBSSID[5]);
    break;
    case SL_WLAN_DISCONNECT_EVENT:
    slWlanConnectAsyncResponse_t* pEventData = NULL;
    CLR_STATUS_BIT(g_ulStatus, STATUS_BIT_CONNECTION);
    CLR_STATUS_BIT(g_ulStatus, STATUS_BIT_IP_AQUIRED);
    pEventData = &pWlanEvent->EventData.STAandP2PModeDisconnected;
    // If the user has initiated 'Disconnect' request,
    //'reason_code' is SL_USER_INITIATED_DISCONNECTION
    if(SL_USER_INITIATED_DISCONNECTION == pEventData->reason_code)
    UART_PRINT("[WLAN EVENT]Device disconnected from the AP: %s,"
    "BSSID: %x:%x:%x:%x:%x:%x on application's request \n\r",
    else
    UART_PRINT("[WLAN ERROR]Device disconnected from the AP AP: %s,"
    "BSSID: %x:%x:%x:%x:%x:%x on an ERROR..!! \n\r",
    memset(g_ucConnectionSSID,0,sizeof(g_ucConnectionSSID));
    memset(g_ucConnectionBSSID,0,sizeof(g_ucConnectionBSSID));
    break;
    case SL_WLAN_STA_CONNECTED_EVENT:
    // when device is in AP mode and any client connects to device cc3xxx
    CLR_STATUS_BIT(g_ulStatus, STATUS_BIT_CONNECTION_FAILED);
    // Information about the connected client (like SSID, MAC etc) will
    // be available in 'slPeerInfoAsyncResponse_t' - Applications
    // slPeerInfoAsyncResponse_t *pEventData = NULL;
    // pEventData = &pSlWlanEvent->EventData.APModeStaConnected;
    break;
    case SL_WLAN_STA_DISCONNECTED_EVENT:
    // when client disconnects from device (AP)
    CLR_STATUS_BIT(g_ulStatus, STATUS_BIT_IP_LEASED);
    // pEventData = &pSlWlanEvent->EventData.APModestaDisconnected;
    break;
    case SL_WLAN_SMART_CONFIG_COMPLETE_EVENT:
    SET_STATUS_BIT(g_ulStatus, STATUS_BIT_SMARTCONFIG_START);
    // Information about the SmartConfig details (like Status, SSID,
    // Token etc) will be available in 'slSmartConfigStartAsyncResponse_t'
    // - Applications can use it if required
    // slSmartConfigStartAsyncResponse_t *pEventData = NULL;
    // pEventData = &pSlWlanEvent->EventData.smartConfigStartResponse;
    break;
    case SL_WLAN_SMART_CONFIG_STOP_EVENT:
    // SmartConfig operation finished
    CLR_STATUS_BIT(g_ulStatus, STATUS_BIT_SMARTCONFIG_START);
    // Information about the SmartConfig details (like Status, padding
    // etc) will be available in 'slSmartConfigStopAsyncResponse_t' -
    // Applications can use it if required
    // slSmartConfigStopAsyncResponse_t *pEventData = NULL;
    // pEventData = &pSlWlanEvent->EventData.smartConfigStopResponse;
    break;
    case SL_WLAN_P2P_DEV_FOUND_EVENT:
    SET_STATUS_BIT(g_ulStatus, STATUS_BIT_P2P_DEV_FOUND);
    // Information about P2P config details (like Peer device name, own
    // SSID etc) will be available in 'slPeerInfoAsyncResponse_t' -
    // pEventData = &pSlWlanEvent->EventData.P2PModeDevFound;
    break;
    case SL_WLAN_P2P_NEG_REQ_RECEIVED_EVENT:
    SET_STATUS_BIT(g_ulStatus, STATUS_BIT_P2P_REQ_RECEIVED);
    // Information about P2P Negotiation req details (like Peer device
    // name, own SSID etc) will be available in 'slPeerInfoAsyncResponse_t'
    // pEventData = &pSlWlanEvent->EventData.P2PModeNegReqReceived;
    break;
    case SL_WLAN_CONNECTION_FAILED_EVENT:
    // If device gets any connection failed event
    SET_STATUS_BIT(g_ulStatus, STATUS_BIT_CONNECTION_FAILED);
    break;
    default:
    UART_PRINT("[WLAN EVENT] Unexpected event [0x%x]\n\r",
    pWlanEvent->Event);
    break;
    //! \brief This function handles network events such as IP acquisition, IP
    //! leased, IP released etc.
    //! \param[in] pNetAppEvent - Pointer to NetApp Event Info
    //! \return None
    void SimpleLinkNetAppEventHandler(SlNetAppEvent_t *pNetAppEvent)
    if(!pNetAppEvent)
    return;
    switch(pNetAppEvent->Event)
    case SL_NETAPP_IPV4_IPACQUIRED_EVENT:
    SlIpV4AcquiredAsync_t *pEventData = NULL;
    SET_STATUS_BIT(g_ulStatus, STATUS_BIT_IP_AQUIRED);
    //Ip Acquired Event Data
    pEventData = &pNetAppEvent->EventData.ipAcquiredV4;
    g_uiIpAddress = pEventData->ip;
    //Gateway IP address
    g_ulGatewayIP = pEventData->gateway;
    /*UART_PRINT("[NETAPP EVENT] IP Acquired: IP=%d.%d.%d.%d , "
    "Gateway=%d.%d.%d.%d\n\r",
    SL_IPV4_BYTE(pNetAppEvent->EventData.ipAcquiredV4.ip,3),
    SL_IPV4_BYTE(pNetAppEvent->EventData.ipAcquiredV4.ip,2),
    SL_IPV4_BYTE(pNetAppEvent->EventData.ipAcquiredV4.ip,1),
    SL_IPV4_BYTE(pNetAppEvent->EventData.ipAcquiredV4.ip,0),
    SL_IPV4_BYTE(pNetAppEvent->EventData.ipAcquiredV4.gateway,3),
    SL_IPV4_BYTE(pNetAppEvent->EventData.ipAcquiredV4.gateway,2),
    SL_IPV4_BYTE(pNetAppEvent->EventData.ipAcquiredV4.gateway,1),
    SL_IPV4_BYTE(pNetAppEvent->EventData.ipAcquiredV4.gateway,0));
    break;
    case SL_NETAPP_IP_LEASED_EVENT:
    SET_STATUS_BIT(g_ulStatus, STATUS_BIT_IP_LEASED);
    // Information about the IP-Leased details(like IP-Leased,lease-time,
    // mac etc) will be available in 'SlIpLeasedAsync_t' - Applications
    // SlIpLeasedAsync_t *pEventData = NULL;
    // pEventData = &pNetAppEvent->EventData.ipLeased;
    break;
    case SL_NETAPP_IP_RELEASED_EVENT:
    // Information about the IP-Released details (like IP-address, mac
    // etc) will be available in 'SlIpReleasedAsync_t' - Applications
    // SlIpReleasedAsync_t *pEventData = NULL;
    // pEventData = &pNetAppEvent->EventData.ipReleased;
    break;
    default:
    UART_PRINT("[NETAPP EVENT] Unexpected event [0x%x] \n\r",
    pNetAppEvent->Event);
    break;
    //! This function handles socket events indication
    //! \param[in] pSock - Pointer to Socket Event Info
    //! \return None
    void SimpleLinkSockEventHandler(SlSockEvent_t *pSock)
    // This application doesn't work w/ socket - Events are not expected
    //! This function gets triggered when HTTP Server receives Application
    //! defined GET and POST HTTP Tokens.
    //! \param pHttpServerEvent Pointer indicating http server event
    //! \param pHttpServerResponse Pointer indicating http server response
    //! \return None
    void SimpleLinkHttpServerCallback(SlHttpServerEvent_t *pSlHttpServerEvent,
    SlHttpServerResponse_t *pSlHttpServerResponse)
    unsigned char strLenVal = 0;
    if(!pSlHttpServerEvent || !pSlHttpServerResponse)
    return;
    switch (pSlHttpServerEvent->Event)
    case SL_NETAPP_HTTPGETTOKENVALUE_EVENT:
    unsigned char status, *ptr;
    ptr = pSlHttpServerResponse->ResponseData.token_value.data;
    pSlHttpServerResponse->ResponseData.token_value.len = 0;
    if(memcmp(pSlHttpServerEvent->EventData.httpTokenName.data, GET_token,
    strlen((const char *)GET_token)) == 0)
    status = GPIO_IF_LedStatus(MCU_RED_LED_GPIO);
    strLenVal = strlen(LED1_STRING);
    memcpy(ptr, LED1_STRING, strLenVal);
    ptr += strLenVal;
    pSlHttpServerResponse->ResponseData.token_value.len += strLenVal;
    if(status & 0x01)
    strLenVal = strlen(LED_ON_STRING);
    memcpy(ptr, LED_ON_STRING, strLenVal);
    ptr += strLenVal;
    else
    strLenVal = strlen(LED_OFF_STRING);
    memcpy(ptr, LED_OFF_STRING, strLenVal);
    ptr += strLenVal;
    status = GPIO_IF_LedStatus(MCU_GREEN_LED_GPIO);
    strLenVal = strlen(LED2_STRING);
    memcpy(ptr, LED2_STRING, strLenVal);
    ptr += strLenVal;
    if(status & 0x01)
    ptr += strLenVal;
    else
    ptr += strLenVal;
    *ptr = '\0';
    break;
    case SL_NETAPP_HTTPPOSTTOKENVALUE_EVENT:
    unsigned char led;
    unsigned char *ptr = pSlHttpServerEvent->EventData.httpPostData.token_name.data;
    if(memcmp(ptr, POST_token, strlen((const char *)POST_token)) == 0)
    ptr = pSlHttpServerEvent->EventData.httpPostData.token_value.data;
    strLenVal = strlen(LED_STRING);
    if(memcmp(ptr, LED_STRING, strLenVal) != 0)
    break;
    ptr += strLenVal;
    led = *ptr;
    ptr += strLenVal;
    if(led == '1')
    if(memcmp(ptr, LED_ON_STRING, strLenVal) == 0)
    else
    GPIO_IF_LedOff(MCU_RED_LED_GPIO);
    else if(led == '2')
    GPIO_IF_LedOn(MCU_GREEN_LED_GPIO);
    else
    GPIO_IF_LedOff(MCU_GREEN_LED_GPIO);
    break;
    default:
    break;
    //! \brief This function initializes the application variables
    //! \param None
    //! \return None
    static void InitializeAppVariables()
    g_ulStatus = 0;
    g_uiIpAddress = 0;
    //! \brief This function puts the device in its default state. It:
    //! - Set the mode to STATION
    //! - Configures connection policy to Auto and AutoSmartConfig
    //! - Deletes all the stored profiles
    //! - Enables DHCP
    //! - Disables Scan policy
    //! - Sets Tx power to maximum
    //! - Sets power policy to normal
    //! - Unregister mDNS services
    //! - Remove all filters
    //! \param none
    //! \return On success, zero is returned. On error, negative is returned
    static long ConfigureSimpleLinkToDefaultState()
    SlVersionFull ver = {0};
    _WlanRxFilterOperationCommandBuff_t RxFilterIdMask = {0};
    unsigned char ucVal = 1;
    unsigned char ucConfigOpt = 0;
    unsigned char ucConfigLen = 0;
    unsigned char ucPower = 0;
    long lRetVal = -1;
    long lMode = -1;
    lMode = sl_Start(0, 0, 0);
    ASSERT_ON_ERROR(lMode);
    // If the device is not in station-mode, try configuring it in station-mode
    if (ROLE_STA != lMode)
    if (ROLE_AP == lMode)
    // If the device is in AP mode, we need to wait for this event
    // before doing anything
    while(!IS_IP_ACQUIRED(g_ulStatus))
    #ifndef SL_PLATFORM_MULTI_THREADED
    _SlNonOsMainLoopTask();
    #endif
    // Switch to STA role and restart
    lRetVal = sl_WlanSetMode(ROLE_STA);
    lRetVal = sl_Stop(0xFF);
    lRetVal = sl_Start(0, 0, 0);
    // Check if the device is in station again
    if (ROLE_STA != lRetVal)
    // We don't want to proceed if the device is not coming up in STA-mode
    return DEVICE_NOT_IN_STATION_MODE;
    //abhishek
    _u8 len = sizeof(SlNetCfgIpV4Args_t);
    _u8 dhcpIsOn = 0;
    SlNetCfgIpV4Args_t ipV4 = {0};
    sl_NetCfgGet(SL_IPV4_STA_P2P_CL_GET_INFO,&dhcpIsOn,&len,(_u8 *)&ipV4);
    UART_PRINT("DHCP is %s IP %d.%d.%d.%d MASK %d.%d.%d.%d GW %d.%d.%d.%d DNS %d.%d.%d.%d\n",
    (dhcpIsOn > 0) ? "ON" : "OFF",
    SL_IPV4_BYTE(ipV4.ipV4,3),SL_IPV4_BYTE(ipV4.ipV4,2),SL_IPV4_BYTE(ipV4.ipV4,1),SL_IPV4_BYTE(ipV4.ipV4,0),
    SL_IPV4_BYTE(ipV4.ipV4Mask,3),SL_IPV4_BYTE(ipV4.ipV4Mask,2),SL_IPV4_BYTE(ipV4.ipV4Mask,1),SL_IPV4_BYTE(ipV4.ipV4Mask,0),
    SL_IPV4_BYTE(ipV4.ipV4Gateway,3),SL_IPV4_BYTE(ipV4.ipV4Gateway,2),SL_IPV4_BYTE(ipV4.ipV4Gateway,1),SL_IPV4_BYTE(ipV4.ipV4Gateway,0),
    SL_IPV4_BYTE(ipV4.ipV4DnsServer,3),SL_IPV4_BYTE(ipV4.ipV4DnsServer,2),SL_IPV4_BYTE(ipV4.ipV4DnsServer,1),SL_IPV4_BYTE(ipV4.ipV4DnsServer,0));
    sl_NetCfgGet(SL_IPV4_AP_P2P_GO_GET_INFO,&dhcpIsOn,&len,(_u8 *)&ipV4);
    UART_PRINT("IP %d.%d.%d.%d MASK %d.%d.%d.%d GW %d.%d.%d.%d DNS %d.%d.%d.%d\n",
    //abhishek
    //Update_IPConfig_file();
    // Get the device's version-information
    ucConfigOpt = SL_DEVICE_GENERAL_VERSION;
    ucConfigLen = sizeof(ver);
    lRetVal = sl_DevGet(SL_DEVICE_GENERAL_CONFIGURATION, &ucConfigOpt,
    &ucConfigLen, (unsigned char *)(&ver));
    UART_PRINT("Host Driver Version: %s\n\r",SL_DRIVER_VERSION);
    UART_PRINT("Build Version %d.%d.%d.%d.31.%d.%d.%d.%d.%d.%d.%d.%d\n\r",
    ver.NwpVersion[0],ver.NwpVersion[1],ver.NwpVersion[2],ver.NwpVersion[3],
    ver.ChipFwAndPhyVersion.FwVersion[0],ver.ChipFwAndPhyVersion.FwVersion[1],
    ver.ChipFwAndPhyVersion.FwVersion[2],ver.ChipFwAndPhyVersion.FwVersion[3],
    ver.ChipFwAndPhyVersion.PhyVersion[0],ver.ChipFwAndPhyVersion.PhyVersion[1],
    ver.ChipFwAndPhyVersion.PhyVersion[2],ver.ChipFwAndPhyVersion.PhyVersion[3]);
    // Set connection policy to Auto + SmartConfig
    // (Device's default connection policy)
    lRetVal = sl_WlanPolicySet(SL_POLICY_CONNECTION,
    SL_CONNECTION_POLICY(1, 0, 0, 0, 1), NULL, 0);
    // Remove all profiles
    lRetVal = sl_WlanProfileDel(0xFF);
    // Device in station-mode. Disconnect previous connection if any
    // The function returns 0 if 'Disconnected done', negative number if already
    // disconnected Wait for 'disconnection' event if 0 is returned, Ignore
    // other return-codes
    lRetVal = sl_WlanDisconnect();
    if(0 == lRetVal)
    // Wait
    while(IS_CONNECTED(g_ulStatus))
    #endif
    // Enable DHCP client
    lRetVal = sl_NetCfgSet(SL_IPV4_STA_P2P_CL_DHCP_ENABLE,1,1,&ucVal);
    // Disable scan
    ucConfigOpt = SL_SCAN_POLICY(0);
    lRetVal = sl_WlanPolicySet(SL_POLICY_SCAN , ucConfigOpt, NULL, 0);
    // Set Tx power level for station mode
    // Number between 0-15, as dB offset from max power - 0 will set max power
    ucPower = 0;
    lRetVal = sl_WlanSet(SL_WLAN_CFG_GENERAL_PARAM_ID,
    WLAN_GENERAL_PARAM_OPT_STA_TX_POWER, 1, (unsigned char *)&ucPower);
    // Set PM policy to normal
    lRetVal = sl_WlanPolicySet(SL_POLICY_PM , SL_NORMAL_POLICY, NULL, 0);
    // Unregister mDNS services
    lRetVal = sl_NetAppMDNSUnRegisterService(0, 0);
    // Remove all 64 filters (8*8)
    memset(RxFilterIdMask.FilterIdMask, 0xFF, 8);
    lRetVal = sl_WlanRxFilterSet(SL_REMOVE_RX_FILTER, (_u8 *)&RxFilterIdMask,
    sizeof(_WlanRxFilterOperationCommandBuff_t));
    lRetVal = sl_Stop(SL_STOP_TIMEOUT);
    InitializeAppVariables();
    return lRetVal; // Success
    //! \brief Connects to the Network in AP or STA Mode - If ForceAP Jumper is
    //! Placed, Force it to AP mode
    //! \return 0 on success else error code
    long ConnectToNetwork()
    char ucAPSSID[32];
    unsigned short len, config_opt;
    long lRetVal = -1;
    // staring simplelink
    g_uiSimplelinkRole = sl_Start(NULL,NULL,NULL);
    // Device is not in STA mode and Force AP Jumper is not Connected
    //- Switch to STA mode
    if(g_uiSimplelinkRole != ROLE_STA && g_uiDeviceModeConfig == ROLE_STA )
    //Switch to STA Mode
    //Device is not in AP mode and Force AP Jumper is Connected -
    //Switch to AP mode
    if(g_uiSimplelinkRole != ROLE_AP && g_uiDeviceModeConfig == ROLE_AP )
    //Switch to AP Mode
    lRetVal = sl_WlanSetMode(ROLE_AP);
    //No Mode Change Required
    if(g_uiSimplelinkRole == ROLE_AP)
    //waiting for the AP to acquire IP address from Internal DHCP Server
    //Stop Internal HTTP Server
    lRetVal = sl_NetAppStop(SL_NET_APP_HTTP_SERVER_ID);
    ASSERT_ON_ERROR( lRetVal);
    //Start Internal HTTP Server
    lRetVal = sl_NetAppStart(SL_NET_APP_HTTP_SERVER_ID);
    char iCount=0;
    //Read the AP SSID
    memset(ucAPSSID,'\0',AP_SSID_LEN_MAX);
    len = AP_SSID_LEN_MAX;
    config_opt = WLAN_AP_OPT_SSID;
    lRetVal = sl_WlanGet(SL_WLAN_CFG_AP_ID, &config_opt , &len,
    (unsigned char*) ucAPSSID);
    Report("\n\rDevice is in AP Mode, Please Connect to AP [%s] and"
    "type [mysimplelink.net] in the browser \n\r",ucAPSSID);
    //Blink LED 3 times to Indicate AP Mode
    for(iCount=0;iCount<3;iCount++)
    //Turn RED LED On
    osi_Sleep(400);
    //Turn RED LED Off
    osi_Sleep(400);
    else
    //waiting for the device to Auto Connect
    while ( (!IS_IP_ACQUIRED(g_ulStatus))&&
    g_ucConnectTimeout < AUTO_CONNECTION_TIMEOUT_COUNT)
    //Turn RED LED On
    osi_Sleep(50);
    //Turn RED LED Off
    osi_Sleep(50);
    g_ucConnectTimeout++;
    //Couldn't connect Using Auto Profile
    if(g_ucConnectTimeout == AUTO_CONNECTION_TIMEOUT_COUNT)
    //Blink Red LED to Indicate Connection Error
    CLR_STATUS_BIT_ALL(g_ulStatus);
    Report("Use Smart Config Application to configure the device.\n\r");
    //Connect Using Smart Config
    lRetVal = SmartConfigConnect();
    //Waiting for the device to Auto Connect
    MAP_UtilsDelay(500);
    //Turn RED LED Off
    UART_PRINT("\n\rDevice is in STA Mode, Connect to the AP[%s] and type"
    "IP address [%d.%d.%d.%d] in the browser \n\r",g_ucConnectionSSID,
    SL_IPV4_BYTE(g_uiIpAddress,3),SL_IPV4_BYTE(g_uiIpAddress,2),
    SL_IPV4_BYTE(g_uiIpAddress,1),SL_IPV4_BYTE(g_uiIpAddress,0));
    return SUCCESS;
    //! \brief Read Force AP GPIO and Configure Mode - 1(Access Point Mode)
    //! - 0 (Station Mode)
    //! \return None
    static void ReadDeviceConfiguration()
    unsigned int uiGPIOPort;
    unsigned char pucGPIOPin;
    unsigned char ucPinValue;
    //Read GPIO
    GPIO_IF_GetPortNPin(SH_GPIO_3,&uiGPIOPort,&pucGPIOPin);
    ucPinValue = GPIO_IF_Get(SH_GPIO_3,uiGPIOPort,pucGPIOPin);
    //If Connected to VCC, Mode is AP
    if(ucPinValue == 1)
    //AP Mode
    g_uiDeviceModeConfig = ROLE_AP;
    else
    //STA Mode
    //! \brief Handles HTTP Server Task
    //! \param[in] pvParameters is the data passed to the Task
    //! \return None
    long lRetVal = -1;
    // Following function configure the device to default state by cleaning
    // the persistent settings stored in NVMEM (viz. connection profiles &
    // policies, power policy etc)
    // Applications may choose to skip this step if the developer is sure
    // that the device is in its default state at start of applicaton
    // Note that all profiles and persistent settings that were done on the
    // device will be lost
    lRetVal = ConfigureSimpleLinkToDefaultState();
    if(lRetVal < 0)
    if (DEVICE_NOT_IN_STATION_MODE == lRetVal)
    UART_PRINT("Failed to configure the device in its default state\n\r");
    LOOP_FOREVER();
    UART_PRINT("Device is configured in default state \n\r");
    memset(g_ucSSID,'\0',AP_SSID_LEN_MAX);
    //Read Device Mode Configuration
    ReadDeviceConfiguration();
    //Connect to Network
    lRetVal = ConnectToNetwork();
    if(lRetVal < 0)
    ERR_PRINT(lRetVal);
    LOOP_FOREVER();
    if(lRetVal < 0)
    ERR_PRINT(lRetVal);
    LOOP_FOREVER();
    while(1)
    //! Application startup display on UART
    //! \param none
    //! \return none
    static void
    DisplayBanner(char * AppName)
    Report("\n\n\n\r");
    Report("\t\t *************************************************\n\r");
    Report("\t\t CC3200 %s Application \n\r", AppName);
    Report("\n\n\n\r");
    //! Board Initialization & Configuration
    //! \param None
    //! \return None
    static void
    BoardInit(void)
    /* In case of TI-RTOS vector table is initialize by OS itself */
    #ifndef USE_TIRTOS
    // Set vector table base
    #if defined(ccs)
    MAP_IntVTableBaseSet((unsigned long)&g_pfnVectors[0]);
    #endif
    #if defined(ewarm)
    MAP_IntVTableBaseSet((unsigned long)&__vector_table);
    #endif
    #endif
    // Enable Processor
    MAP_IntMasterEnable();
    MAP_IntEnable(FAULT_SYSTICK);
    PRCMCC3200MCUInit();
    // MAIN FUNCTION
    void main()
    long lRetVal = -1;
    //Board Initialization
    BoardInit();
    //Pin Configuration
    PinMuxConfig();
    //Change Pin 58 Configuration from Default to Pull Down
    MAP_PinConfigSet(PIN_58,PIN_STRENGTH_2MA|PIN_STRENGTH_4MA,PIN_TYPE_STD_PD);
    // Initialize GREEN and ORANGE LED
    GPIO_IF_LedConfigure(LED1|LED2|LED3);
    //Turn Off the LEDs
    GPIO_IF_LedOff(MCU_ALL_LED_IND);
    //UART Initialization
    MAP_PRCMPeripheralReset(PRCM_UARTA0);
    MAP_UARTConfigSetExpClk(CONSOLE,MAP_PRCMPeripheralClockGet(CONSOLE_PERIPH),
    UART_BAUD_RATE,(UART_CONFIG_WLEN_8 |
    UART_CONFIG_STOP_ONE | UART_CONFIG_PAR_NONE));
    //Display Application Banner on UART Terminal
    DisplayBanner(APPLICATION_NAME);
    // Simplelinkspawntask
    lRetVal = VStartSimpleLinkSpawnTask(SPAWN_TASK_PRIORITY);
    if(lRetVal < 0)
    UART_PRINT("Unable to start simpelink spawn task\n\r");
    LOOP_FOREVER();
    // Create HTTP Server Task
    lRetVal = osi_TaskCreate(HTTPServerTask, (signed char*)"HTTPServerTask",
    OSI_STACK_SIZE, NULL, OOB_TASK_PRIORITY, NULL );
    if(lRetVal < 0)
    UART_PRINT("Unable to create task\n\r");
    LOOP_FOREVER();
    // Create Filesystem Task
    lRetVal = osi_TaskCreate(Update_IPConfig_file, (signed char*)"Update_IPConfig_file",
    if(lRetVal < 0)
    LOOP_FOREVER();
    osi_start();
    while (1)
  • Hello Aashish,
    I am very thankful to you for replying.
    I have created the task of updating file in main(), and used the long WriteFileToDevice(unsigned long *ulToken, long *lFileHandle) and ReadFileFromDevice(unsigned long ulToken, long lFileHandle) functions and their parameters from file_operations code...
    Awaiting you reply.
    Abhishek.
  • Hi Abhishek,
    Update_IPConfig_file is getting schedule before the n/w processor started/initialized and trying to access file system. That causing to break the flow. Please create file or performed file operation after the n/w processor started (After the final sl_start() call).
    Aashish
  • Hi Aashish,
    Sending you the complete application code here.....
    Please refer to the bold part in the code...
    //  are met:
    //    distribution.
    // or
    #include <string.h>
    #include <stdlib.h>
    #include "netcfg.h"
    #include "utils.h"
    #include "pin.h"
    #include "uart.h"
    #include "rom.h"
    #include "prcm.h"
    // Driverlib includes
    #include "hw_common_reg.h"
    #include "osi.h"
    #include "FreeRTOS.h"
    #include "task.h"
    #include "queue.h"
    #include "semphr.h"
    #include "portmacro.h"
    #include "common.h"
    #include "pinmux.h"
    #define FILE_TASK_PRIORITY              (2)
    #define SL_MAX_FILE_SIZE        1024L*1024L       /* 64KB file */
    #define USER_FILE_NAME1          "www/IP_Config.txt"
    #define USER_FILE_NAME2          "www/safe/SSID_Config.txt"
    typedef enum{
    }e_AppStatusCodes;
    SlNetCfgIpV4Args_t Machine_IP_Config;
    ProfileConfig Profile_Config;
    ServerIPConfig Server_IP_Config;
    // The queue used to send strings to the task2.
    QueueHandle_t xPrintQueue;
    char Temp_IP_String[16];
    unsigned char Temp_SSID_String[32];
    unsigned char Temp_Priority_String[10];
    unsigned char bytes[4];
    int iCount = 0;
    unsigned char priority_status;
    void SET_STATIC_IPADDRESS(void);
    unsigned long IP_Parsing(char* Temp_IP_String1);
    static void Update_IPConfig_file(void *pvParameters);
    unsigned char IP_Config_Set = 0;
    unsigned char Profile_Config_Set = 0;
    unsigned char POST_token_DHCP[] = "__SL_P_UDH";
    unsigned char GET_token_DHCP[]  = "__SL_G_UDH";
    unsigned char POST_token_IPaddress[] = "__SL_P_UIP";
    unsigned char GET_token_IPaddress[]  = "__SL_G_UIP";
    unsigned char POST_token_SubnetMask[] = "__SL_P_USM";
    unsigned char GET_token_SubnetMask[]  = "__SL_G_USM";
    unsigned char POST_token_DefaultGateway[] = "__SL_P_UDG";
    unsigned char GET_token_DefaultGateway[]  = "__SL_G_UDG";
    unsigned char POST_token_DNSserver[] = "__SL_P_UDS";
    unsigned char GET_token_DNSserver[]  = "__SL_G_UDS";
    unsigned char POST_token_ServerIP[] = "__SL_P_USI";
    unsigned char GET_token_ServerIP[]  = "__SL_G_USI";
    unsigned char POST_token_PortNumber[] = "__SL_P_UPN";
    unsigned char GET_token_PortNumber[]  = "__SL_G_UPN";
    unsigned char POST_token_SSID[] = "__SL_P_USN";
    unsigned char GET_token_SSID[]  = "__SL_G_USN";
    unsigned char POST_token_SecurityType[] = "__SL_P_UST";
    unsigned char GET_token_SecurityType[]  = "__SL_G_UST";
    unsigned char POST_token_SecurityKey[] = "__SL_P_USK";
    unsigned char GET_token_SecurityKey[]  = "__SL_G_USK";
    unsigned char POST_token_ProfilePriority[] = "__SL_P_UPP";
    unsigned char GET_token_ProfilePriority[]  = "__SL_G_UPP";
    E-I-E-I-O, \
    E-I-E-I-O. \
    E-I-E-I-O, \
    E-I-E-I-O, \
    E-I-E-I-O. \
    E-I-E-I-O, \
    E-I-E-I-O, \
    E-I-E-I-O. \
    E-I-E-I-O, \
    E-I-E-I-O, \
    E-I-E-I-O. \
    E-I-E-I-O, \
    E-I-E-I-O, \
    E-I-E-I-O. \
    E-I-E-I-O, \
    E-I-E-I-O, \
    E-I-E-I-O.";
    long lRetVal;
    long lFileHandle;
    #if defined(ccs)
    #endif
    #if defined(ewarm)
    #endif
    #ifdef USE_FREERTOS
    //! \return none
    void
        while(1)
    //! \param  none
    //! \return none
    void
    //! \param  none
    //! \return none
        while(1)
    //! \param  none
    //! \return none
        while(1)
        long lRetVal = -1;
        int iLoopCnt = 0;
                            ulToken,
                            lFileHandle);
        if(lRetVal < 0)
        else
                            FS_MODE_OPEN_WRITE,
                            ulToken,
                            lFileHandle);
        if(lRetVal < 0)
        for (iLoopCnt = 0;
                iLoopCnt++)
            if (lRetVal < 0)
        return SUCCESS;
        long lRetVal = -1;
        int iLoopCnt = 0;
                            FS_MODE_OPEN_READ,
                            &ulToken,
                            &lFileHandle);
        if(lRetVal < 0)
        for (iLoopCnt = 0;
                iLoopCnt++)
                             gaucCmpBuf,
            if (lRetVal != 0)
        return SUCCESS;
    //                 SETTING THE STATIC IP ADDRESS
      Machine_IP_Config.ipV4          = (_u32)SL_IPV4_VAL(192,168,100,5);            // _u32 IP address
      Machine_IP_Config.ipV4Mask      = (_u32)SL_IPV4_VAL(255,255,255,0);         // _u32 Subnet mask for this STA/P2P
      Machine_IP_Config.ipV4Gateway   = (_u32)SL_IPV4_VAL(192,168,100,50);              // _u32 Default gateway address
      Machine_IP_Config.ipV4DnsServer = (_u32)SL_IPV4_VAL(192,168,100,23);            // _u32 DNS server address
    //                 IP Address Parsing (AtoI)
      long Address;
                iCount = 0;
                char* buff = malloc(ptrlen+1);
                buff = strtok(Temp_IP_String1,".");
                while (buff != NULL)
                  //if you want to print its value
                  //printf("%s\n",buff);
                  //and also if you want to save each byte
                  bytes[iCount] = (unsigned char)atoi(buff);
                  buff = strtok(NULL,".");
                  iCount++;
                free(buff);
                Address = (_u32)SL_IPV4_VAL(bytes[0], bytes[1], bytes[2], bytes[3]);
                return Address;
           /*char*           DeviceFileName = "MyFile.txt";
           unsigned long   MaxSize = 63 * 1024; //62.5K is max file size
           long            DeviceFileHandle = -1;
           long            lRetVal;        //negative retval is an error
           unsigned long   Offset = 0;
           unsigned char   InputBuffer[100];
           // Create a file and write data. The file in this example is secured, without signature and with a fail safe commit
           lRetVal = sl_FsOpen((unsigned char *)DeviceFileName,
                                            FS_MODE_OPEN_CREATE(MaxSize , _FS_FILE_OPEN_FLAG_NO_SIGNATURE_TEST | _FS_FILE_OPEN_FLAG_COMMIT ),
                                            NULL, &DeviceFileHandle);
               if(lRetVal < 0)
        else
            LOOP_FOREVER();
             LOOP_FOREVER();
    //! \return None
        if(!pWlanEvent)
            return;
                       SL_BSSID_LENGTH);
            break;
                else
            break;
            break;
            break;
            break;
            break;
            break;
            break;
            break;
            default:
                           pWlanEvent->Event);
            break;
    //! \return None
        if(!pNetAppEvent)
            return;
            break;
            break;
            break;
            default:
            break;
    //! \return None
    //! \return None
            return;
                ptr += strLenVal;
                if(status & 0x01)
                  ptr += strLenVal;
                else
                  ptr += strLenVal;
                ptr += strLenVal;
                if(status & 0x01)
                  ptr += strLenVal;
                else
                  ptr += strLenVal;
                *ptr = '\0';
            break;
              unsigned char led;
                  break;
                ptr += strLenVal;
                led = *ptr;
                ptr += strLenVal;
                if(led == '1')
                  else
                else if(led == '2')
                  else
              if(memcmp(ptr, POST_token_DHCP, strlen((const char *)POST_token_DHCP)) == 0)
              else if(memcmp(ptr, POST_token_IPaddress, strlen((const char *)POST_token_IPaddress)) == 0)
                ptrlen =0;
                memset(bytes,0,4);
                memset(Temp_IP_String,0,16);
                while(ptrlen <= (pSlHttpServerEvent->EventData.httpPostData.token_value.len))
                  Temp_IP_String[ptrlen] = *ptr;
                  ptr++;
                  ptrlen++;
                Machine_IP_Config.ipV4 = IP_Parsing(Temp_IP_String);
              else if(memcmp(ptr, POST_token_SubnetMask, strlen((const char *)POST_token_SubnetMask)) == 0)
                ptrlen =0;
                memset(bytes,0,4);
                  ptr++;
                  ptrlen++;
                Machine_IP_Config.ipV4Mask = IP_Parsing(Temp_IP_String);
              else if(memcmp(ptr, POST_token_DefaultGateway, strlen((const char *)POST_token_DefaultGateway)) == 0)
                ptrlen =0;
                memset(bytes,0,4);
                  ptr++;
                  ptrlen++;
                Machine_IP_Config.ipV4Gateway = IP_Parsing(Temp_IP_String);
              else if(memcmp(ptr, POST_token_DNSserver, strlen((const char *)POST_token_DNSserver)) == 0)
                ptrlen =0;
                memset(bytes,0,4);
                  ptr++;
                  ptrlen++;
                Machine_IP_Config.ipV4DnsServer = IP_Parsing(Temp_IP_String);         // _u32 DNS server address
              else if(memcmp(ptr, POST_token_ServerIP, strlen((const char *)POST_token_ServerIP)) == 0)
                ptrlen =0;
                memset(bytes,0,4);
                  ptr++;
                  ptrlen++;
                Server_IP_Config.ServerIP = IP_Parsing(Temp_IP_String);         // _u32 DNS server address
              else if(memcmp(ptr, POST_token_PortNumber, strlen((const char *)POST_token_PortNumber)) == 0)
              ptrlen =0;
              while(ptrlen < (pSlHttpServerEvent->EventData.httpPostData.token_value.len))
               ptr++;
               ptrlen++;
              Server_IP_Config.Server_Port = atoi(Temp_IP_String);
    This is where my complete data is received. I want to store the Machine_IP_Config and Server_IP_Config structures onto a .txt file. So i call Update_IPConfig_file function here. According to you, from exactly where should i call this function ??
              //Update_IPConfig_file();       //Updating the IP config file
              else if(memcmp(ptr, POST_token_SSID, strlen((const char *)POST_token_SSID)) == 0)
              ptrlen =0;
              memset(Temp_SSID_String,0,32);
               Temp_SSID_String[ptrlen] = *ptr;
               ptr++;
               ptrlen++;
              for(iCount = 0; iCount < (pSlHttpServerEvent->EventData.httpPostData.token_value.len); iCount++)
              Profile_Config.SSID[iCount] = Temp_SSID_String[iCount];
              else if(memcmp(ptr, POST_token_SecurityType, strlen((const char *)POST_token_SecurityType)) == 0)
              priority_status = (*ptr - 0x30);
      switch(priority_status)
              case 0:
                Profile_Config.Security_Type = SL_SEC_TYPE_OPEN;
                break;
              case 1:
                Profile_Config.Security_Type = SL_SEC_TYPE_WEP;
                break;
              case 2:
                Profile_Config.Security_Type = SL_SEC_TYPE_WPA;
                break;
              case 3:
                Profile_Config.Security_Type = SL_SEC_TYPE_WPA_WPA2;
                break;
          default:
          break;
              else if(memcmp(ptr, POST_token_SecurityKey, strlen((const char *)POST_token_SecurityKey)) == 0)
              ptrlen =0;
               ptr++;
               ptrlen++;
              Profile_Config.Security_Key[iCount] = Temp_SSID_String[iCount];
              else if(memcmp(ptr, POST_token_ProfilePriority, strlen((const char *)POST_token_ProfilePriority)) == 0)
              Profile_Config.Priority = priority_status;
              break;
            default:
              break;
    //! \param    None
    //! \return None
        g_ulStatus = 0;
        g_uiIpAddress = 0;
    //!           - Enables DHCP
    //! \param   none
        long lRetVal = -1;
        long lMode = -1;
    #endif
        if(0 == lRetVal)
            // Wait
    #endif
        // Disable scan
        ucPower = 0;
        char ucAPSSID[32];
        long lRetVal = -1;
        //Switch to AP mode
             //Switch to AP Mode
           char iCount=0;
           //Read the AP SSID
               //Turn RED LED On
               osi_Sleep(400);
               //Turn RED LED Off
               osi_Sleep(400);
        else
                //Turn RED LED On
                osi_Sleep(50);
                //Turn RED LED Off
                osi_Sleep(50);
        //Turn RED LED Off
        return SUCCESS;
    //! \return                        None
            //Read GPIO
        if(ucPinValue == 1)
                //AP Mode
        else
                //STA Mode
    //! \return                        None
        long lRetVal = -1;
        if(lRetVal < 0)
            LOOP_FOREVER();
        if(lRetVal < 0)
            ERR_PRINT(lRetVal);
            LOOP_FOREVER();
        if(lRetVal < 0)
            ERR_PRINT(lRetVal);
            LOOP_FOREVER();
        while(1)
    //! \param  none
    //! \return none
    static void
        Report("\n\n\n\r");
        Report("\n\n\n\r");
    //! \param  None
    //! \return None
    static void
    BoardInit(void)
    #ifndef USE_TIRTOS
    #if defined(ccs)
    #endif
    #if defined(ewarm)
    #endif
    #endif
        // Enable Processor
    //                            MAIN FUNCTION
    int main(void)
        long lRetVal = -1;
        BoardInit();
        //Pin Configuration
        PinMuxConfig();
        //Turn Off the LEDs
        // Creating a queue for 10 elements.
        xPrintQueue =xQueueCreate( 10, sizeof( unsigned portLONG ) );
        if( xPrintQueue == 0 )
          // Queue was not created and must not be used.
          return 0;
        if(lRetVal < 0)
            LOOP_FOREVER();
        if(lRetVal < 0)
            LOOP_FOREVER();
                             OSI_STACK_SIZE, NULL, FILE_TASK_PRIORITY, NULL );
        if(lRetVal < 0)
            LOOP_FOREVER();
        osi_start();
        while (1)
  • Hi Abhishek,
    Please find attached file for your reference. In SimpleLinkHttpServerCallback() I am writing dummy data to queue and in HTTPServerTask() reading from queue and writing to a file.
    //  are met:
    //    distribution.
    // or
    #include <string.h>
    #include <stdlib.h>
    #include "netcfg.h"
    #include "utils.h"
    #include "pin.h"
    #include "uart.h"
    #include "rom.h"
    #include "prcm.h"
    #include "task.h"
    #include "queue.h"
    #include "semphr.h"
    #include "osi.h"
    #include "common.h"
    #include "pinmux.h"
    typedef enum{
    }e_AppStatusCodes;
    // The queue used to send strings to the task1.
    #if defined(ccs)
    #endif
    #if defined(ewarm)
    #endif
    #ifdef USE_FREERTOS
    //! \return none
    void
        while(1)
    //! \param  none
    //! \return none
    void
    //! \param  none
    //! \return none
        while(1)
    //! \param  none
    //! \return none
        while(1)
    //! \return None
        if(!pWlanEvent)
            return;
                       SL_BSSID_LENGTH);
            break;
                else
            break;
            break;
            break;
            break;
            break;
            break;
            break;
            break;
            default:
                           pWlanEvent->Event);
            break;
    //! \return None
        if(!pNetAppEvent)
            return;
            break;
            break;
    		break;
            default:
            break;
    //! \return None
    //! \return None
        static unsigned int dummy = 0;
            return;
        xQueueSend( xPrintQueue, &dummy, portMAX_DELAY ); //Send data to queue for writing to a file. here writing dummy
        dummy++;
                ptr += strLenVal;
                if(status & 0x01)
                  ptr += strLenVal;
                else
                  ptr += strLenVal;
                ptr += strLenVal;
                if(status & 0x01)
                  ptr += strLenVal;
                else
                  ptr += strLenVal;
                *ptr = '\0';
            break;
              unsigned char led;
                  break;
                ptr += strLenVal;
                led = *ptr;
                ptr += strLenVal;
                if(led == '1')
                  else
                else if(led == '2')
                  else
              break;
            default:
              break;
    //! \param    None
    //! \return None
        g_ulStatus = 0;
        g_uiIpAddress = 0;
    //!           - Enables DHCP
    //! \param   none
        long lRetVal = -1;
        long lMode = -1;
    #endif
        if(0 == lRetVal)
            // Wait
    #endif
        // Disable scan
        ucPower = 0;
        char ucAPSSID[32];
        long lRetVal = -1;
        //Switch to AP mode
             //Switch to AP Mode
           char iCount=0;
           //Read the AP SSID
               //Turn RED LED On
               osi_Sleep(400);
               //Turn RED LED Off
               osi_Sleep(400);
        else
    			//Turn RED LED On
    			osi_Sleep(50);
    			//Turn RED LED Off
    			osi_Sleep(50);
        //Turn RED LED Off
        return SUCCESS;
    //! \return                        None
            //Read GPIO
        if(ucPinValue == 1)
                //AP Mode
        else
                //STA Mode
    //! \return                        None
        long lRetVal = -1;
        unsigned int readDummy = 0;
        unsigned int offset1 = 0;
        static unsigned int offset = 0;
        long lFileHandle;
        if(lRetVal < 0)
            LOOP_FOREVER();
        if(lRetVal < 0)
            ERR_PRINT(lRetVal);
            LOOP_FOREVER();
        if(lRetVal < 0)
            ERR_PRINT(lRetVal);
            LOOP_FOREVER();
        while(1)
            xQueueReceive( xPrintQueue, &dummy, portMAX_DELAY ); // Read data from queue and write to file
            lRetVal = sl_FsOpen((unsigned char *)"demo.txt",
                            NULL,
                            &lFileHandle);
            if(lRetVal < 0)
                LOOP_FOREVER();
            else
                    LOOP_FOREVER();
                                FS_MODE_OPEN_WRITE,
                                NULL,
                                &lFileHandle);
            if(lRetVal < 0)
                LOOP_FOREVER();
            lRetVal = sl_FsWrite(lFileHandle, offset, (unsigned char *)&dummy, sizeof(dummy));
            if (lRetVal < 0)
                LOOP_FOREVER();
            offset += sizeof(dummy);
              LOOP_FOREVER();
                            FS_MODE_OPEN_READ,
                            NULL,
                            &lFileHandle);
            if(lRetVal < 0)
                LOOP_FOREVER();
            offset1 = 0;
            UART_PRINT("----\n\r");
            while(1)
              lRetVal = sl_FsRead(lFileHandle, offset1, (unsigned char *)&readDummy, sizeof(readDummy));
              if(lRetVal <= 0)
                break;
              UART_PRINT("%d", readDummy);
              offset1 += sizeof(readDummy);
            UART_PRINT("\n\r----");
                LOOP_FOREVER();
    //! \param  none
    //! \return none
    static void
        Report("\n\n\n\r");
        Report("\n\n\n\r");
    //! \param  None
    //! \return None
    static void
    BoardInit(void)
    #ifndef USE_TIRTOS
    #if defined(ccs)
    #endif
    #if defined(ewarm)
    #endif
    #endif
        // Enable Processor
    //                            MAIN FUNCTION
    void main()
        long lRetVal = -1;
        BoardInit();
        //Pin Configuration
        PinMuxConfig();
        //Turn Off the LEDs
          LOOP_FOREVER();
        if(lRetVal < 0)
            LOOP_FOREVER();
        if(lRetVal < 0)
            LOOP_FOREVER();
        osi_start();
        while (1)
    Aashish
  • Thank you so much Aashish.
    I will implement in my code and get back to you.
  • I implemented the code.
    Everything works fine for now.
    Thank you very much Aashish for you support.
    Really appreciated.
  • Hello Aashish.
    Thank you for your support.
    The first write looks correct, but on the next write, the data read from the file looks like -1-1-1-1-2....
    Actually i want to delete the previous file and create a new file on every new write.
    I implemented this,
    ....//Handle Async Events
       while(1)
         xQueueReceive( xPrintQueue, &Dummy_Machine_Config, portMAX_DELAY ); // Read data from queue and write to file
         lRetVal = sl_FsDel("demo.txt",0);                    //Deleting the previous file
                           NULL,
                           &lFileHandle);
           if(lRetVal < 0)
               LOOP_FOREVER();
           else
                   LOOP_FOREVER();
    But this doesn't work.
    How do i delete the previous file and write new data to new file every-time ??
    Please help !!
  • Thank you very much Aashish for your help and co-operation.
    I implemented everything successfully.
    Abhishek.
  • Abhishek, in that case one solution is to create global variables in your code to store these variables you get from the HTML pages. The async HTTP handler would only store the inputs from the webpage to those variables, nothing else.
    Then your event-loop in main() can check if they are present/set. When they are, it can begin writing them to the .txt and doing the reset you want.
  • Hello Nemanja,
    Thank for replying.
    I didn't get what you are suggesting.
    Can you please send me a sample code to make things more clear.
    Abhishek.
