wl18xx bluetooth
Hi, I am trying to make wl18xx bluetooth wok, but I am not able to turn on the bluetooth. The log is as follow.
--------- beginning of /dev/log/main
D/BluetoothManagerService(  324): enable():  mBluetooth =null mBinding = false
D/BluetoothManagerService(  324): Message: 1
D/BluetoothManagerService(  324): MESSAGE_ENABLE: mBluetooth = null
I/InputDispatcher(  324): Window 'Window{4106c4d0 u0 com.android.settings/com.android.settings.SubSettings}' spent 2156.8ms processing the las)
I/Choreographer(  549): Skipped 143 frames!  The application may be doing too much work on its main thread.
--------- beginning of /dev/log/system
I/ActivityManager(  324): Start proc com.android.bluetooth for service com.android.bluetooth/.btservice.AdapterService: pid=659 uid=1002 gids=}
D/dalvikvm(   82): GC_EXPLICIT freed 36K, 14% free 404K/468K, paused 0ms+1ms, total 9ms
D/dalvikvm(   82): GC_EXPLICIT freed <1K, 14% free 405K/468K, paused 0ms+1ms, total 6ms
D/dalvikvm(   82): GC_EXPLICIT freed <1K, 14% free 405K/468K, paused 1ms+0ms, total 7ms
D/dalvikvm(  659): Note: class Landroid/app/ActivityManagerNative; has 157 unimplemented (abstract) methods
D/AdapterServiceConfig(  659): Adding HeadsetService
D/AdapterServiceConfig(  659): Adding A2dpService
D/AdapterServiceConfig(  659): Adding HidService
D/AdapterServiceConfig(  659): Adding HealthService
D/AdapterServiceConfig(  659): Adding PanService
D/BluetoothAdapterService(  659): REFCOUNT: CREATED. INSTANCE_COUNT1
D/BluetoothManagerService(  324): Message: 20
D/BluetoothManagerService(  324): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@40f5c2a0:true
D/BluetoothAdapterState(  659): make
I/bluedroid(  659): init
I/bte_conf(  659): Attempt to load stack conf from /etc/bluetooth/bt_stack.conf
I/bluedroid(  659): get_profile_interface socket
D/BluetoothManagerService(  324): BluetoothServiceConnection: connected to AdapterService
D/BluetoothManagerService(  324): Message: 40
D/BluetoothManagerService(  324): MESSAGE_BLUETOOTH_SERVICE_CONNECTED
D/BluetoothManagerService(  324): Calling onBluetoothServiceUp callbacks
D/BluetoothManagerService(  324): Broadcasting onBluetoothServiceUp() to 5 receivers.
I/GKI_LINUX(  659): gki_task_entry: gki_task_entry task_id=1 [BTIF] starting
D/BluetoothAdapterService(  659): Broadcasting updateAdapterState() to 1 receivers.
D/BluetoothManagerService(  324): Message: 60
D/BluetoothManagerService(  324): MESSAGE_BLUETOOTH_STATE_CHANGE: prevState = 10, newState=11
D/BluetoothManagerService(  324): Bluetooth State Change Intent: 10 -> 11
D/BluetoothBondStateMachine(  659): make
D/BluetoothAdapterService(1089067384)(  659): getState(): mAdapterProperties: com.android.bluetooth.btservice.AdapterProperties@40e9f8d0
D/dalvikvm(  659): GC_CONCURRENT freed 149K, 22% free 635K/812K, paused 1ms+5ms, total 50ms
I/BluetoothBondStateMachine(  659): StableState(): Entering Off State
D/BluetoothHeadset(  324): Proxy object connected
D/BluetoothHeadset(  482): Proxy object connected
D/HeadsetService(  659): Received start request. Starting profile...
I/BluetoothHeadsetServiceJni(  659): classInitNative: succeeds
D/HeadsetStateMachine(  659): make
D/TelephonyManager(  659): No /proc/cmdline exception=java.io.FileNotFoundException: /proc/cmdline: open failed: EACCES (Permission denied)
D/TelephonyManager(  659): /proc/cmdline=
I/bluedroid(  659): get_profile_interface handsfree
E/bt-btif (  659): btif_enable_service: current services:0x40
D/A2dpService(  659): Received start request. Starting profile...
I/BluetoothA2dpServiceJni(  659): classInitNative: succeeds
D/A2dpStateMachine(  659): make
I/bluedroid(  659): get_profile_interface a2dp
I/GKI_LINUX(  659): gki_task_entry: gki_task_entry task_id=2 [A2DP-MEDIA] starting
E/bt-btif (  659): btif_enable_service: current services:0x40040
D/A2dpStateMachine(  659): Enter Disconnected: -2
I/BluetoothHidServiceJni(  659): classInitNative: succeeds
D/BluetoothInputDevice(  549): Proxy object connected
D/HidProfile(  549): Bluetooth service connected
D/HidService(  659): Received start request. Starting profile...
I/bluedroid(  659): get_profile_interface hidhost
E/bt-btif (  659): btif_enable_service: current services:0x140040
I/BluetoothHealthServiceJni(  659): classInitNative: succeeds
D/HealthService(  659): Received start request. Starting profile...
I/bluedroid(  659): get_profile_interface health
I/BluetoothPanServiceJni(  659): classInitNative(L105): succeeds
D/PanService(  659): Received sta[  112.324188] (hci_tty): inside hci_tty_open (cf3c9200, c3d53740)
D/BluetoothPanServiceJni(  659): initializeNative(L110): pan
I/bluedroid(  659): get_profile_interface pan
D/BluetoothAdapterService(  659): Profile still not running:com.android.bluetooth.hdp.HealthService
D/HeadsetPhoneState(  659): sendDeviceStateChanged. mService=0 mSignal=0 mRoam=0 mBatteryCharge=5
D/BluetoothAdapterService(  659): Profile still not running:com.android.bluetooth.pan.PanService
I/bluedroid(  659): enable
I/bt_hci_bdroid(  659): init
I/        (  659): vendor Init
D/BluetoothPan(  549): BluetoothPAN Proxy object connected
D/PanProfile(  549): Bluetooth service connected
I/GKI_LINUX(  659): gki_task_entry: gki_task_entry task_id=0 [BTU] starting
I/bt_hci_bdroid(  659): bt_hc_worker_thread started
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-89129639,-50000000) -- cpu overload ? #####
E/uim-sysfs(   78): uim: Inside st_uart_config
E/uim-sysfs(   78): uim:install set to 1
E/uim-sysfs(   78): uim: Inside set_baud_rate
E/uim-sysfs(   78): uim: set_baud_rate() done
E/uim-sysfs(   78): uim: Inside read_firmware_version
E/uim-sysfs(   78): uim: Inside read_hci_event
E/uim-sysfs(   78): uim: read_hci_event
D/BluetoothA2dp(  324): Proxy object connected
D/BluetoothManagerService(  324): Bluetooth Adapter name changed to AM335x EVM
D/BluetoothManagerService(  324): Stored Bluetooth name: AM335x EVM
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-88376465,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-79719240,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-70939943,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-62160646,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-53350831,-50000000) -- cpu overload ? #####
E/uim-sysfs(   78): uim:Failed to read init response (READ_LOCAL_VERSION_INFORMATION)
E/uim-sysfs(   78): uim: Setting speed to 3000000
E/uim-sysfs(   78): uim: Inside read_command_complete
E/uim-sysfs(   78): uim: Command complete started
E/uim-sysfs(   78): uim: Invalid response
E/uim-sysfs(   78): uim:cleanup
[  113.450408] (stk) :line disc installation timed out E/uim-sysfs(   78): uim: Inside st_uart_config
E/uim-sysfs(   78): uim: Un-Installed N_TI_WL Line displine
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-96195069,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-87324219,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-78453370,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-69613039,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-60711671,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-51840822,-50000000) -- cpu overload ? #####
[  115.570404] (stk) :line disc installation timed out E/uim-sysfs(   78): uim: Inside st_uart_config
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-94298096,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-85457764,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-76617432,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-67716065,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-58845215,-50000000) -- cpu overload ? #####
W/ThrottleService(  324): unable to find stats for iface rmnet0
W/SocketClient(   79): write error (Broken pipe)
[  117.690399] (stk) :line disc installation timed out E/uim-sysfs(   78): uim: Inside st_uart_config
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-94293213,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-86826172,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-78046875,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-69176025,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-60274659,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-51403809,-50000000) -- cpu overload ? #####
[  119.810394] (stk) :line disc installation timed out E/uim-sysfs(   78): uim: Inside st_uart_config
E/BluetoothAdapterState(  659): Error enabling Bluetooth
D/BluetoothManagerService(  324): MESSAGE_BLUETOOTH_STATE_CHANGE: prevState = 11, newState=10
D/BluetoothManagerService(  324): Broadcasting onBluetoothStateChange(false) to 7 receivers.
D/BluetoothHeadset(  324): onBluetoothStateChange: up=false
D/BluetoothPbap(  549): onBluetoothStateChange: up=false
D/BluetoothHeadset(  482): onBluetoothStateChange: up=false
D/BluetoothA2dp(  324): onBluetoothStateChange: up=false
D/BluetoothInputDevice(  549): onBluetoothStateChange: up=false
D/BluetoothManagerService(  324): Bluetooth State Change Intent: 11 -> 10
W/ContextImpl(  549): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1352 android.conte
D/DockEventReceiver(  549): finishStartingService: stopping service
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-95722657,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-86851807,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-77980958,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-69079590,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-60178223,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-51276856,-50000000) -- cpu overload ? #####
[  121.930419] (stk) :line disc installation timed out E/uim-sysfs(   78): uim: Inside st_uart_config
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-95656739,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-86816407,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-77945557,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-69044190,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-60142823,-50000000) -- cpu overload ? #####
E/GKI_LINUX(  659): ##### ERROR : timer_thread: tick delayed > 5 slots (-51271974,-50000000) -- cpu overload ? #####
[  124.050415] (stk) :line disc installation timed out E/uim-sysfs(   78): uim: Inside st_uart_config
[  125.050415] (hci_tty): st_register failed -22E/        (  659):  Can't open hci_tty
E/bt_userial(  659): userial_open: wrong numbers of open fd in vendor lib [-1]!
E/bt_userial(  659): userial_open: HCI UART expects only one open fd
I/        (  659): BTE_InitTraceLevels -- TRC_HCI
I/        (  659): BTE_InitTraceLevels -- TRC_L2CAP
I/        (  659): BTE_InitTraceLevels -- TRC_RFCOMM
I/        (  659): BTE_InitTraceLevels -- TRC_AVDT
I/        (  659): BTE_InitTraceLevels -- TRC_AVRC
I/        (  659): BTE_InitTraceLevels -- TRC_A2D
I/        (  659): BTE_InitTraceLevels -- TRC_BNEP
I/        (  659): BTE_InitTraceLevels -- TRC_BTM
I/        (  659): BTE_InitTraceLevels -- TRC_PAN
I/        (  659): BTE_InitTraceLevels -- TRC_SDP
I/        (  659): BTE_InitTraceLevels -- TRC_BTAPP
I/        (  659): BTE_InitTraceLevels -- TRC_BTIF
