E_stackOverflow: ISR stack overflow during runtime
I've been searching around for a solution of my particular problem.  Other problems were with different boards and/or setups.  I've seen to edit Program.stack inside the config file, but where is it?
Below is a detailed look of the call stack.  If it helps, my program consists of running an ADC, connecting to my access point, and starting the http server.  I haven't gotten the opportunity to execute enough code to debug besides my ADC readings.  Also, I have doubled OSI_STACK_SIZE = 4096 from the examples, which did not help.
I need your expert advice on how to solve this problem.
  • Moderator,
    My problem was in fact the one listed above : need to increase stack size inside the config - which is inside the ti_rtos_config project that is imported from the "Getting Started" guide.
    Edit: Feel free to remove this post if you must.
    Thanks.
