SETTING CC3200 TI BOARD FOR SENDING DATA
Other Parts Discussed in Thread: CC3200
I tried each example application present in sdk example.. I can't see the packets in wireshark..
Must I activate something in the board ?
There are some jumper that can create a problem for the transmission ?
  • Hi ,
    I am using CC3200 launch board xl.. I would like to send udp packets over "wifi-direct " from cc3200 to a smartphone.
    I can see the effective transmission in the Tera Term terminal and the connection with the server into the smartphone. I used iperf but with it I can't see the data packets.
    For this I am trying to use Wireshark as a sniffer but I can see only the procedure to establish the connection.
    Do you know if there is a particular encryption for CC3200 ??
    What Must I set in wire-shark for seeing the packets ??
  • Hi Luca,
    You don't need to put any jumper for that. Please make sure the PC (on which wireshark is running) and device are on same network.
    Aashish
  • Hi ,
    It is not my first post here.. I have a problem with the board because for me the board doesn't send packets..
    I have put the code in a previous post and another Ti employee
    answered that it was ok..
    I opened an iperf server but I can't see the data received.. Ok I don't see the exact data but I can see on iperf that I have received a packet. I can see only the connection between the smartphone and the board..
    For this I thought that the problem was the board ( maybe a jumper or something inside to the board...)
    Do you help me about this problem ?? I can put again the code in this post.. It seems easy but I can't see the packets..
    Maybe there is a mistake in the code ( even if the ti employee (Raghavendra Shenoy) said that is correct )..
  • Hi Luca,
    Please run the application and post following information:
    1. IP of P2P Group owner (device)
    2. IP of Device once its connected to P2P server or Screenshot of console
    3. Configured IP in code (sAddr.sin_addr.s_addr = sl_Htonl((_u320<IP>)
    4. Screenshot of iperf application showing when on console following message appears "packets successfully"
    Aashish
  • 1) 192.168.49.1
    2) 192.168.49.131
    3) sAddr.sin_addr.s_addr = sl_Htonl((_u32)0xc0a83101);
    4) I don't have that message.. I have only the message about the connection..
    local 192.168.49.1 port 5001 connected with I HAVE ONLY THIS..
    There aren't messages about the packets
    Luca
  • Hi Luca,
    What is value usPort "sAddr.sin_port = sl_Htons((unsigned short)usPort);" ? As per your code in thread e2e.ti.com/.../1465501 its 2000.
    Aashish
  • Hi ,
    I changed in 5001.
    the code is this :
    // simplelink includes
    #include "simplelink.h"
    //driverlib includes
    #include "utils.h"
    #include "hw_ints.h"
    #include "hw_types.h"
    #include "interrupt.h"
    #include "prcm.h"
    #include "rom.h"
    #include "rom_map.h"
    #include "pinmux.h"
    // common interface includes
    #include "common.h"
    #ifndef NOTERM
    #include "uart_if.h"
    #endif
    #include "gpio_if.h"
    #define APPLICATION_VERSION "1.1.1"
    #define P2P_REMOTE_DEVICE "remote-p2p-device"
    #define P2P_DEVICE_NAME "luca-rete"
    #define P2P_SECURITY_TYPE SL_SEC_TYPE_P2P_PBC
    #define P2P_SECURITY_KEY ""
    #define P2P_CONFIG_VALUE "1-0050F204-1"
    #define Delay(x) MAP_UtilsDelay(x * 8000)
    #define APP_NAME "UDP_P2P"
    #define LISENING_CHANNEL 11
    #define REGULATORY_CLASS 81
    #define OPERATING_CHANNEL 6
    #define g_ulPacketCount 1000
    #define PORT_NUM 5001 /* Port to be used by TCP server*/
    #define BUF_SIZE 1400
    #define P2P_ROLE_TYPE_NEGOTIATE
    /* Application specific status/error codes */
    typedef enum{
    // Choosing this number to avoid overlap w/ host-driver's error codes
    NETWORK_CONNECTION_FAILED = -0x7D0,
    P2P_CONFIG_FAILED = NETWORK_CONNECTION_FAILED - 1,
    P2P_MODE_START_FAILED = P2P_CONFIG_FAILED - 1,
    DEVICE_NOT_IN_STATION_MODE = P2P_MODE_START_FAILED - 1,
    CLIENT_DISCONNECTED = DEVICE_NOT_IN_STATION_MODE -1,
    STATUS_CODE_MAX = -0xBB8
    }e_AppStatusCodes;
    char g_cBsdBuf[BUF_SIZE];
    // GLOBAL VARIABLES -- Start
    unsigned long g_ulDeviceIp = 0;
    volatile unsigned long g_ulStatus = 0;
    unsigned long g_ulGatewayIP = 0;
    const char digits[] = "0123456789";
    char g_p2p_dev[MAXIMAL_SSID_LENGTH + 1];
    #if defined(ccs)
    extern void (* const g_pfnVectors[])(void);
    #endif
    #if defined(ewarm)
    extern uVectorEntry __vector_table;
    #endif
    // SimpleLink Asynchronous Event Handlers -- Start
    //! \brief The Function Handles WLAN Events
    //! \param[in] pWlanEvent pointer indicating Event type
    //! \return None
    void SimpleLinkWlanEventHandler(SlWlanEvent_t *pSlWlanEvent)
    switch(pSlWlanEvent->Event)
    case SL_WLAN_CONNECT_EVENT:
    SET_STATUS_BIT(g_ulStatus, STATUS_BIT_CONNECTION);
    CLR_STATUS_BIT(g_ulStatus, STATUS_BIT_CONNECTION_FAILED);
    // Information about the connected AP (like name, MAC etc) will be
    // available in 'slWlanConnectAsyncResponse_t' - Applications
    // can use it if required
    // slWlanConnectAsyncResponse_t *pEventData = NULL;
    // pEventData = &pSlWlanEvent->EventData.STAandP2PModeWlanConnected;
    break;
    case SL_WLAN_DISCONNECT_EVENT:
    slWlanConnectAsyncResponse_t* pEventData = NULL;
    CLR_STATUS_BIT(g_ulStatus, STATUS_BIT_CONNECTION);
    CLR_STATUS_BIT(g_ulStatus, STATUS_BIT_IP_AQUIRED);
    pEventData = &pSlWlanEvent->EventData.STAandP2PModeDisconnected;
    // If the user has initiated 'Disconnect' request, 'reason_code'
    // is SL_USER_INITIATED_DISCONNECTION
    if(SL_USER_INITIATED_DISCONNECTION == pEventData->reason_code)
    UART_PRINT("Device disconnected from the Peer Device on "
    "application's request \n\r");
    else
    UART_PRINT("Device disconnected from the Peer device on an ERROR..!! \n\r");
    break;
    case SL_WLAN_STA_CONNECTED_EVENT:
    // when device is in AP mode and any client connects to device cc3xxx
    // Information about the connected client (like SSID, MAC etc) will
    // be available in 'slPeerInfoAsyncResponse_t' - Applications
    // slPeerInfoAsyncResponse_t *pEventData = NULL;
    // pEventData = &pSlWlanEvent->EventData.APModeStaConnected;
    break;
    case SL_WLAN_STA_DISCONNECTED_EVENT:
    // when client disconnects from device (AP)
    CLR_STATUS_BIT(g_ulStatus, STATUS_BIT_IP_LEASED);
    // pEventData = &pSlWlanEvent->EventData.APModestaDisconnected;
    break;
    case SL_WLAN_P2P_DEV_FOUND_EVENT:
    SET_STATUS_BIT(g_ulStatus, STATUS_BIT_P2P_DEV_FOUND);
    // Information about P2P config details (like Peer device name, own
    // SSID etc) will be available in 'slPeerInfoAsyncResponse_t' -
    // Applications can use it if required
    // pEventData = &pSlWlanEvent->EventData.P2PModeDevFound;
    break;
    case SL_WLAN_P2P_NEG_REQ_RECEIVED_EVENT:
    SET_STATUS_BIT(g_ulStatus, STATUS_BIT_P2P_REQ_RECEIVED);
    memset(g_p2p_dev, '\0', MAXIMAL_SSID_LENGTH + 1);
    memcpy(g_p2p_dev,pSlWlanEvent->EventData.P2PModeNegReqReceived.go_peer_device_name,
    pSlWlanEvent->EventData.P2PModeNegReqReceived.go_peer_device_name_len);
    // Information about P2P Negotiation req details (like Peer device
    // name, own SSID etc) will be available in
    // 'slPeerInfoAsyncResponse_t' - Applications can use it if required
    // pEventData = &pSlWlanEvent->EventData.P2PModeNegReqReceived;
    break;
    case SL_WLAN_CONNECTION_FAILED_EVENT:
    // If device gets any connection failed event
    SET_STATUS_BIT(g_ulStatus, STATUS_BIT_CONNECTION_FAILED);
    break;
    default:
    UART_PRINT("[WLAN EVENT] Unexpected event \n\r");
    break;
    //! This function gets triggered when HTTP Server receives Application
    //! defined GET and POST HTTP Tokens.
    //! \param pHttpServerEvent Pointer indicating http server event
    //! \param pHttpServerResponse Pointer indicating http server response
    //! \return None
    void SimpleLinkHttpServerCallback(SlHttpServerEvent_t *pSlHttpServerEvent,
    SlHttpServerResponse_t *pSlHttpServerResponse)
    /* Unused in this example */
    //! This function gets triggered when device acquires IP
    //! status to be set. When Device is in DHCP mode recommended to use this.
    //! \param pNetAppEvent Pointer indicating device acquired IP
    //! \return None
    void SimpleLinkNetAppEventHandler(SlNetAppEvent_t *pNetAppEvent)
    switch(pNetAppEvent->Event)
    case SL_NETAPP_IPV4_IPACQUIRED_EVENT:
    case SL_NETAPP_IPV6_IPACQUIRED_EVENT:
    SlIpV4AcquiredAsync_t *pEventData = NULL;
    SET_STATUS_BIT(g_ulStatus, STATUS_BIT_IP_AQUIRED);
    // Information about the IPv4 & IPv6 details (like IP, gateway,dns
    // etc) will be available in 'SlIpV4AcquiredAsync_t / SlIpV6AcquiredAsync_t' - Applications
    // For IPv4:
    // SlIpV4AcquiredAsync_t *pEventData = NULL;
    // pEventData = &pNetAppEvent->EventData.ipAcquiredV4;
    // For IPv6:
    // SlIpV6AcquiredAsync_t *pEventData = NULL;
    // pEventData = &pNetAppEvent->EventData.ipAcquiredV6;
    //Ip Acquired Event Data
    g_ulDeviceIp = pNetAppEvent->EventData.ipAcquiredV4.ip;
    //Gateway IP address
    g_ulGatewayIP = pEventData->gateway;
    UART_PRINT("[NETAPP EVENT] IP Acquired: IP=%d.%d.%d.%d , "
    "Gateway=%d.%d.%d.%d\n\r",
    SL_IPV4_BYTE(g_ulDeviceIp,3),
    SL_IPV4_BYTE(g_ulDeviceIp,2),
    SL_IPV4_BYTE(g_ulDeviceIp,1),
    SL_IPV4_BYTE(g_ulDeviceIp,0),
    SL_IPV4_BYTE(g_ulGatewayIP,3),
    SL_IPV4_BYTE(g_ulGatewayIP,2),
    SL_IPV4_BYTE(g_ulGatewayIP,1),
    SL_IPV4_BYTE(g_ulGatewayIP,0));
    break;
    case SL_NETAPP_IP_LEASED_EVENT:
    SET_STATUS_BIT(g_ulStatus, STATUS_BIT_IP_LEASED);
    // Information about the IP-Leased details (like IP-Leased,
    // lease-time, mac etc) will be available in 'SlIpLeasedAsync_t' -
    // SlIpLeasedAsync_t *pEventData = NULL;
    // pEventData = &pNetAppEvent->EventData.ipLeased;
    break;
    default:
    UART_PRINT("[NETAPP EVENT] Unexpected event \n\r");
    break;
    //! \brief This function handles socket events indication
    //! \param[in] pSock is the event passed to the handler
    //! \return None
    void SimpleLinkSockEventHandler(SlSockEvent_t *pSock)
    // This application doesn't work w/ socket - Hence not handling these events
    //UART_PRINT(" [SOCK EVENT] Unexpected event \n\r");
    //! \brief This function initializes the application variables
    //! \param[in] None
    //! \return 0 on success, negative error-code on error
    static void InitializeAppVariables()
    g_ulStatus = 0;
    g_ulDeviceIp = 0;
    //! \brief This function puts the device in its default state. It:
    //! - Set the mode to STATION
    //! - Configures connection policy to Auto and AutoSmartConfig
    //! - Deletes all the stored profiles
    //! - Enables DHCP
    //! - Disables Scan policy
    //! - Sets Tx power to maximum
    //! - Sets power policy to normal
    //! - Unregister mDNS services
    //! - Remove all filters
    //! \param none
    //! \return On success, zero is returned. On error, negative is returned
    static long ConfigureSimpleLinkToDefaultState()
    SlVersionFull ver = {0};
    _WlanRxFilterOperationCommandBuff_t RxFilterIdMask = {0};
    unsigned char ucVal = 1;
    unsigned char ucConfigOpt = 0;
    unsigned char ucConfigLen = 0;
    unsigned char ucPower = 0;
    long lRetVal = -1;
    long lMode = -1;
    lMode = sl_Start(0, 0, 0);
    ASSERT_ON_ERROR(lMode);
    // If the device is not in station-mode, try configuring it in station-mode
    if (ROLE_STA != lMode)
    if (ROLE_AP == lMode)
    // If the device is in AP mode, we need to wait for this event
    // before doing anything
    while(!IS_IP_ACQUIRED(g_ulStatus))
    #ifndef SL_PLATFORM_MULTI_THREADED
    _SlNonOsMainLoopTask();
    #endif
    // Switch to STA role and restart
    lRetVal = sl_WlanSetMode(ROLE_STA);
    ASSERT_ON_ERROR(lRetVal);
    lRetVal = sl_Stop(0xFF);
    lRetVal = sl_Start(0, 0, 0);
    // Check if the device is in station again
    if (ROLE_STA != lRetVal)
    // We don't want to proceed if the device is not coming up in STA-mode
    return DEVICE_NOT_IN_STATION_MODE;
    // Get the device's version-information
    ucConfigOpt = SL_DEVICE_GENERAL_VERSION;
    ucConfigLen = sizeof(ver);
    lRetVal = sl_DevGet(SL_DEVICE_GENERAL_CONFIGURATION, &ucConfigOpt,
    &ucConfigLen, (unsigned char *)(&ver));
    UART_PRINT("Host Driver Version: %s\n\r",SL_DRIVER_VERSION);
    UART_PRINT("Build Version %d.%d.%d.%d.31.%d.%d.%d.%d.%d.%d.%d.%d\n\r",
    ver.NwpVersion[0],ver.NwpVersion[1],ver.NwpVersion[2],ver.NwpVersion[3],
    ver.ChipFwAndPhyVersion.FwVersion[0],ver.ChipFwAndPhyVersion.FwVersion[1],
    ver.ChipFwAndPhyVersion.FwVersion[2],ver.ChipFwAndPhyVersion.FwVersion[3],
    ver.ChipFwAndPhyVersion.PhyVersion[0],ver.ChipFwAndPhyVersion.PhyVersion[1],
    ver.ChipFwAndPhyVersion.PhyVersion[2],ver.ChipFwAndPhyVersion.PhyVersion[3]);
    // Set connection policy to Auto + SmartConfig
    // (Device's default connection policy)
    lRetVal = sl_WlanPolicySet(SL_POLICY_CONNECTION,
    SL_CONNECTION_POLICY(1, 0, 0, 0, 1), NULL, 0);
    // Remove all profiles
    lRetVal = sl_WlanProfileDel(0xFF);
    // Device in station-mode. Disconnect previous connection if any
    // The function returns 0 if 'Disconnected done', negative number if already
    // disconnected Wait for 'disconnection' event if 0 is returned, Ignore
    // other return-codes
    lRetVal = sl_WlanDisconnect();
    if(0 == lRetVal)
    // Wait
    while(IS_CONNECTED(g_ulStatus))
    #endif
    // Enable DHCP client
    lRetVal = sl_NetCfgSet(SL_IPV4_STA_P2P_CL_DHCP_ENABLE,1,1,&ucVal);
    // Disable scan
    ucConfigOpt = SL_SCAN_POLICY(0);
    lRetVal = sl_WlanPolicySet(SL_POLICY_SCAN , ucConfigOpt, NULL, 0);
    // Set Tx power level for station mode
    // Number between 0-15, as dB offset from max power - 0 will set max power
    ucPower = 0;
    lRetVal = sl_WlanSet(SL_WLAN_CFG_GENERAL_PARAM_ID,
    WLAN_GENERAL_PARAM_OPT_STA_TX_POWER, 1, (unsigned char *)&ucPower);
    // Set PM policy to normal
    lRetVal = sl_WlanPolicySet(SL_POLICY_PM , SL_NORMAL_POLICY, NULL, 0);
    // Unregister mDNS services
    lRetVal = sl_NetAppMDNSUnRegisterService(0, 0);
    // Remove all 64 filters (8*8)
    memset(RxFilterIdMask.FilterIdMask, 0xFF, 8);
    lRetVal = sl_WlanRxFilterSet(SL_REMOVE_RX_FILTER, (_u8 *)&RxFilterIdMask,
    sizeof(_WlanRxFilterOperationCommandBuff_t));
    lRetVal = sl_Stop(SL_STOP_TIMEOUT);
    InitializeAppVariables();
    return lRetVal; // Success
    //! \brief Connecting to a WLAN Access point
    //! This function connects to the required AP (SSID_NAME) with Security
    //! parameters specified in the form of macros at the top of this file
    //! \param[in] None
    //! \return None
    //! \warning If the WLAN connection fails or we don't acquire an IP
    //! address, It will be stuck in this function forever.
    static long WlanConnect()
    SlSecParams_t secParams = {0};
    long lRetVal = 0;
    secParams.Key = (signed char *)P2P_SECURITY_KEY;
    secParams.KeyLen = strlen(P2P_SECURITY_KEY);
    secParams.Type = P2P_SECURITY_TYPE;
    lRetVal = sl_WlanConnect((signed char *)P2P_REMOTE_DEVICE,
    strlen((const char *)P2P_REMOTE_DEVICE), 0,
    &secParams, 0);
    // Wait till Device acquired an IP in P2P mode
    while(! IS_P2P_REQ_RCVD(g_ulStatus))
    // Connect with the device requesting the connection
    lRetVal = sl_WlanConnect((signed char *)g_p2p_dev,
    strlen((const char *)g_p2p_dev),
    0, &secParams, 0);
    #ifdef P2P_ROLE_TYPE_NEGOTIATE
    while(! IS_IP_ACQUIRED(g_ulStatus))
    #else
    while(! IS_IP_LEASED(g_ulStatus))
    #endif
    if(IS_CONNECT_FAILED(g_ulStatus))
    // Error, connection is failed
    ASSERT_ON_ERROR(NETWORK_CONNECTION_FAILED);
    return SUCCESS;
    //! \brief Display the IP Adderess of device
    //! \param[in] none
    //! \return none
    static signed long DisplayIP()
    unsigned long mask, dns, gateway;
    long lRetVal = -1;
    unsigned char len, dhcpIsOn;
    if(g_ulDeviceIp == 0)
    /* Device is in GO mode, Get the IP of Device */
    len = sizeof(SlNetCfgIpV4Args_t);
    dhcpIsOn = 0;
    SlNetCfgIpV4Args_t ipV4 = {0};
    // Get the IP address of device
    lRetVal = sl_NetCfgGet(SL_IPV4_AP_P2P_GO_GET_INFO,&dhcpIsOn,
    &len,(unsigned char *)&ipV4);
    #else
    lRetVal = sl_NetCfgGet(SL_IPV4_STA_P2P_CL_GET_INFO,&dhcpIsOn,
    #endif
    g_ulDeviceIp=ipV4.ipV4;
    mask=ipV4.ipV4Mask;
    gateway=ipV4.ipV4Gateway;
    dns=ipV4.ipV4DnsServer;
    UNUSED(mask);
    UNUSED(gateway);
    UNUSED(dns);
    UART_PRINT("CC3200 Device IP : IP=%d.%d.%d.%d \n\r",
    SL_IPV4_BYTE(g_ulDeviceIp,3), SL_IPV4_BYTE(g_ulDeviceIp,2),
    SL_IPV4_BYTE(g_ulDeviceIp,1), SL_IPV4_BYTE(g_ulDeviceIp,0));
    return 0;
    //! \brief Opening a server side socket and receiving data
    //! This function opens a TCP socket in Listen mode and waits for an incoming
    //! TCP connection. If a socket connection is established then the function
    //! will try to read 1000 TCP packets from the connected client.
    //! \param[in] port number on which the server will be listening on
    //! \return 0 on success, -1 on Error.
    //! \note This function will wait for an incoming connection till one
    //! is established
    int BsdUdpClient(unsigned short usPort)
    int iCounter;
    short sTestBufLen;
    SlSockAddrIn_t sAddr;
    int iAddrSize;
    int iSockID;
    int iStatus;
    long lLoopCount = 0;
    // filling the buffer
    for (iCounter=0 ; iCounter<BUF_SIZE ; iCounter++)
    g_cBsdBuf[iCounter] = (char)(iCounter % 10);
    sTestBufLen= BUF_SIZE;
    //filling the UDP server socket address
    sAddr.sin_family = SL_AF_INET;
    iAddrSize = sizeof(SlSockAddrIn_t);
    // creating a UDP socket
    iSockID = sl_Socket(SL_AF_INET,SL_SOCK_DGRAM, 0);
    if( iSockID < 0 )
    // error
    // ASSERT_ON_ERROR(SOCKET_CREATE_ERROR);
    // for a UDP connection connect is not required
    // sending 1000 packets to the UDP server
    while (lLoopCount < g_ulPacketCount)
    // sending packet
    iStatus = sl_SendTo(iSockID, g_cBsdBuf, sTestBufLen, 0,
    (SlSockAddr_t *)&sAddr, iAddrSize);
    if( iStatus <= 0 )
    // error
    sl_Close(iSockID);
    //ASSERT_ON_ERROR(SEND_ERROR);
    lLoopCount++;
    UART_PRINT("Sent %u packets successfully\n\r",g_ulPacketCount);
    //closing the socket after sending 1000 packets
    sl_Close(iSockID);
    return SUCCESS;
    //! Board Initialization & Configuration
    //! \param None
    //! \return None
    static void
    BoardInit(void)
    /* In case of TI-RTOS vector table is initialize by OS itself */
    #ifndef USE_TIRTOS
    // Set vector table base
    #if defined(ccs)
    MAP_IntVTableBaseSet((unsigned long)&g_pfnVectors[0]);
    #endif
    #if defined(ewarm)
    MAP_IntVTableBaseSet((unsigned long)&__vector_table);
    #endif
    #endif
    // Enable Processor
    MAP_IntMasterEnable();
    MAP_IntEnable(FAULT_SYSTICK);
    PRCMCC3200MCUInit();
    //! Check the device mode and switch to P2P mode
    //! restart the NWP to activate P2P mode
    //! \param None
    //! \return status code - Success:0, Failure:-ve
    long StartDeviceInP2P()
    long lRetVal = -1;
    // Reset CC3200 Network State Machine
    // Following function configure the device to default state by cleaning
    // the persistent settings stored in NVMEM (viz. connection profiles &
    // policies, power policy etc)
    // Applications may choose to skip this step if the developer is sure
    // that the device is in its default state at start of application
    // Note that all profiles and persistent settings that were done on the
    // device will be lost
    lRetVal = ConfigureSimpleLinkToDefaultState();
    if(lRetVal < 0)
    if (DEVICE_NOT_IN_STATION_MODE == lRetVal)
    UART_PRINT("Failed to configure the device in its default state \n\r");
    LOOP_FOREVER();
    UART_PRINT("Device is configured in default state \n\r");
    // Assumption is that the device is configured in station mode already
    // and it is in its default state
    lRetVal = sl_Start(NULL,NULL,NULL);
    if(lRetVal != ROLE_P2P)
    lRetVal = sl_WlanSetMode(ROLE_P2P);
    // reset the Status bits
    CLR_STATUS_BIT_ALL(g_ulStatus);
    if(lRetVal < 0 || lRetVal != ROLE_P2P)
    ASSERT_ON_ERROR(P2P_MODE_START_FAILED);
    else
    UART_PRINT("Started SimpleLink Device: P2P Mode\n\r");
    return SUCCESS;
    return SUCCESS;
    //! Set all P2P Configuration to device
    //! \param None
    long P2PConfiguration()
    unsigned char ucP2PParam[4];
    long lRetVal = -1;
    // Set any p2p option (SL_CONNECTION_POLICY(0,0,0,any_p2p,0)) to connect to
    // first available p2p device
    lRetVal = sl_WlanPolicySet(SL_POLICY_CONNECTION,SL_CONNECTION_POLICY(1,0,0,0,0),NULL,0);
    // Set the negotiation role (SL_P2P_ROLE_NEGOTIATE).
    // CC3200 will negotiate with remote device GO/client mode.
    // Other valid options are:
    // - SL_P2P_ROLE_GROUP_OWNER
    // - SL_P2P_ROLE_CLIENT
    lRetVal = sl_WlanPolicySet(SL_POLICY_P2P, SL_P2P_POLICY(SL_P2P_ROLE_CLIENT,
    SL_P2P_NEG_INITIATOR_ACTIVE),NULL,0);
    // Set P2P Device name
    lRetVal = sl_NetAppSet(SL_NET_APP_DEVICE_CONFIG_ID, \
    NETAPP_SET_GET_DEV_CONF_OPT_DEVICE_URN,
    strlen(P2P_DEVICE_NAME), (unsigned char *)P2P_DEVICE_NAME);
    // Set P2P device type
    lRetVal = sl_WlanSet(SL_WLAN_CFG_P2P_PARAM_ID, WLAN_P2P_OPT_DEV_TYPE,
    strlen(P2P_CONFIG_VALUE), (unsigned char*)P2P_CONFIG_VALUE);
    // setting P2P channel parameters
    ucP2PParam[0] = LISENING_CHANNEL;
    ucP2PParam[1] = REGULATORY_CLASS;
    ucP2PParam[2] = OPERATING_CHANNEL;
    ucP2PParam[3] = REGULATORY_CLASS;
    // Set P2P Device listen and open channel valid channels are 1/6/11
    lRetVal = sl_WlanSet(SL_WLAN_CFG_P2P_PARAM_ID, WLAN_P2P_OPT_CHANNEL_N_REGS,
    sizeof(ucP2PParam), ucP2PParam);
    // Restart as P2P device
    ASSERT_ON_ERROR(P2P_CONFIG_FAILED);
    else
    UART_PRINT("Connect to %s \n\r",P2P_DEVICE_NAME);
    return SUCCESS;
    //! Application startup display on UART
    //! \param none
    //! \return none
    static void
    DisplayBanner(char * AppName)
    UART_PRINT("\n\n\n\r");
    UART_PRINT("\t\t *************************************************\n\r");
    UART_PRINT("\t\t\t CC3200 %s Application \n\r", AppName);
    int main()
    long lRetVal = -1;
    // Initialize Board configurations
    BoardInit();
    // Pinmuxing for GPIO, UART
    PinMuxConfig();
    // configure LEDs
    GPIO_IF_LedConfigure(LED1|LED2|LED3);
    // off all LEDs
    GPIO_IF_LedOff(MCU_ALL_LED_IND);
    #ifndef NOTERM
    // Configuring UART
    InitTerm();
    #endif
    // Display the Application Banner
    DisplayBanner(APP_NAME);
    UART_PRINT("Scan Wi-FI direct device in your handheld device\n\r");
    // Initializing the CC3200 device
    lRetVal = StartDeviceInP2P();
    if(lRetVal < 0)
    UART_PRINT("Start Device in P2P mode failed \n\r");
    LOOP_FOREVER();
    lRetVal = P2PConfiguration();
    if(lRetVal < 0)
    UART_PRINT("Setting P2P configuration failed\n\r");
    LOOP_FOREVER();
    /* Connect to configure P2P device */
    lRetVal = WlanConnect();
    if(lRetVal == 0)
    GPIO_IF_LedOn(MCU_IP_ALLOC_IND);
    else
    UART_PRINT("Reset the device and try again\n\r");
    LOOP_FOREVER();
    if(DisplayIP() < 0)
    UART_PRINT("Get IP address failed \n\r");
    LOOP_FOREVER();
    UART_PRINT("Send UDP PACKETS");
    /*After calling this function, you can start sending data to CC3200 IP
    * address on PORT_NUM */
    if(!(IS_CONNECT_FAILED(g_ulStatus)))
    lRetVal = BsdUdpClient(PORT_NUM);
    if(lRetVal >= 0)
    UART_PRINT("SENT UDP packets successfully \n\r");
    else if(lRetVal == CLIENT_DISCONNECTED)
    UART_PRINT("P2P Client disconnected \n\r");
    else
    UART_PRINT("TCP packets receive failed \n\r");
    if(lRetVal >=0)
    UART_PRINT("Test passed, exiting application... \n\r");
    else
    UART_PRINT("Test failed, exiting application... \n\r");
    if(lRetVal >= 0)
    else
    if(lRetVal >=0)
    else
    // revert Device into STA mode and power off Network Processor
    //lRetVal = sl_WlanSetMode(ROLE_STA);
    //ERR_PRINT(lRetVal);
    //LOOP_FOREVER();
    //lRetVal = sl_Stop(SL_STOP_TIMEOUT);
    //GPIO_IF_LedOff(MCU_IP_ALLOC_IND);
    //while(1)
    //_SlNonOsMainLoopTask();
  • Hi ,
    have you found the mistake ?
  • Hi Luca,
    What command you issuing on iperf? It should be iperf -s -i 1 -t 10000 -u
    Aashish
  • Hi ,
    I used without i but i don't think it changes a lot.. I can't write the small i in iperf with my phone..
    I put -s -u -p 5001 ..
    I don't know the problem.. It is two weeks that I try to solve it..
    Maybe I should use the board as a group_owner ? but what does it change ?
    Best Regards
                Luca
  • Hi Luca,
    -i 1 option needed. Disable auto-cap in your mobile or type i the space it will converted to I, use backspace it will re-convert to i. If possible install iperf on PC/laptop.
    Aashish
  • Hi ,
    with your written that you advised I can't see the connection and the packets..
    I put
    -s -i 1 -t 10000 -u
    and after
    -s -i 1 -t 10000 -u -p 5001
    but in both case I see operation aborted even if the connection is ok .
    I would like to use in a pc with iperf but I need wifi-direct not wifi-traditional..
    I think that I am doing a stupid mistake in the code.. If the connection is ok , I can see in iperf that the server is ok ( with this written -s -u -p 5001 ) why Can't I see the packets on iperf ????
    It is very strange...
  • Hi Luca,
    Try with attached main.c. It is working on my setup.
    // Copyright (C) 2014 Texas Instruments Incorporated - http://www.ti.com/
    //  Redistribution and use in source and binary forms, with or without
    //  modification, are permitted provided that the following conditions
    //  are met:
    //    Redistributions of source code must retain the above copyright
    //    notice, this list of conditions and the following disclaimer.
    //    Redistributions in binary form must reproduce the above copyright
    //    notice, this list of conditions and the following disclaimer in the
    //    documentation and/or other materials provided with the
    //    distribution.
    //    Neither the name of Texas Instruments Incorporated nor the names of
    //    its contributors may be used to endorse or promote products derived
    //    from this software without specific prior written permission.
    //  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    //  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    //  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    //  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
    //  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    //  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    //  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    //  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
    //  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    //  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
    //  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    // Application Name     - P2P
    // Application Overview - This sample example demostrates how CC3200 connects
    //                          to a P2P device. The application starts a TCP server
    //                          on port 5001 and waits for P2P device to connect and
    //                          send data on it.
    // Application Details  -
    // http://processors.wiki.ti.com/index.php/CC32xx_P2P_Application
    // or
    // docs\examples\CC32xx_P2P_Application.pdf
    //! \addtogroup p2p
    #include "utils.h"
    #include "prcm.h"
    #include "rom.h"
    #include "pinmux.h"
    #include "common.h"
    #ifndef NOTERM
    #endif
    #define P2P_DEVICE_NAME     "cc3200-p2p-device"
    #define APP_NAME            "P2P Demo"
    #define TCP_PACKET_COUNT    1000
    typedef enum{
    }e_AppStatusCodes;
    union
        char BsdBuf[BUF_SIZE];
        unsigned long demobuf[BUF_SIZE/4];
    } uBuf;
    #if defined(ccs)
    #endif
    #if defined(ewarm)
    #endif
    //! \return None
            break;
                else
            break;
            break;
            break;
            break;
            break;
            break;
            default:
            break;
    //! \return None
    //! \return None
                // For IPv4:
                // For IPv6:
            break;
            break;
            default:
            break;
    //!    \return         None
    //!    \param[in]  None
        g_ulStatus = 0;
        g_ulDeviceIp = 0;
    //!           - Enables DHCP
    //! \param   none
        long lRetVal = -1;
        long lMode = -1;
    #endif
        if(0 == lRetVal)
            // Wait
    #endif
        // Disable scan
        ucPower = 0;
    //!   \param[in]              None
    //!   \return                 None
        long lRetVal = 0;
                                &secParams, 0);
                               0, &secParams, 0);
    #else
    #endif
        return SUCCESS;
    //! \param[in]      none
    //! \return         none
        long lRetVal = -1;
            dhcpIsOn = 0;
    #else
    #endif
            mask=ipV4.ipV4Mask;
        UNUSED(mask);
        UNUSED(gateway);
        UNUSED(dns);
        return 0;
    //!                 is established
    static int BsdTcpServer(unsigned short Port)
        SlSockAddrIn_t  Addr;
        SlSockAddrIn_t  LocalAddr;
        int             idx;
        int             AddrSize;
        int             SockID;
        int             Status;
        int             newSockID;
        long            LoopCount = 0;
        long            nonBlocking = 1;
        for (idx=0 ; idx<BUF_SIZE ; idx++)
            uBuf.BsdBuf[idx] = (char)(idx % 10);
        LocalAddr.sin_family = SL_AF_INET;
        LocalAddr.sin_port = sl_Htons((unsigned short)Port);
        LocalAddr.sin_addr.s_addr = 0;
        SockID = sl_Socket(SL_AF_INET,SL_SOCK_STREAM, 0);
        ASSERT_ON_ERROR(SockID);
        Status = sl_Bind(SockID, (SlSockAddr_t *)&LocalAddr, AddrSize);
        if( Status < 0 )
            /* error */
            sl_Close(SockID);
            ASSERT_ON_ERROR(Status);
        Status = sl_Listen(SockID, 0);
        if( Status < 0 )
            sl_Close(SockID);
        Status = sl_SetSockOpt(SockID, SL_SOL_SOCKET, SL_SO_NONBLOCKING,
                               &nonBlocking, sizeof(nonBlocking));
        newSockID = SL_EAGAIN;
        while( newSockID < 0 &&  IS_IP_ACQUIRED(g_ulStatus))
            newSockID = sl_Accept(SockID, ( struct SlSockAddr_t *)&Addr,
                                  (SlSocklen_t*)&AddrSize);
            if( newSockID == SL_EAGAIN )
                /* Wait for 1 ms */
                Delay(1);
            else if( newSockID < 0 )
                sl_Close(SockID);
                ASSERT_ON_ERROR(newSockID);
        if(! IS_IP_ACQUIRED(g_ulStatus))
            return CLIENT_DISCONNECTED;
        // run 'iperf -c <device IP> -i 1 -t 10000'  command on PC/Smartphone
        while (LoopCount < TCP_PACKET_COUNT)
            Status = sl_Recv(newSockID, uBuf.BsdBuf, BUF_SIZE, 0);
            if( Status <= 0 )
                /* error */
                ASSERT_ON_ERROR(sl_Close(newSockID));
                ASSERT_ON_ERROR(sl_Close(SockID));
            LoopCount++;
        GPIO_IF_LedOn(MCU_EXECUTE_SUCCESS_IND);
        return SUCCESS;
    //! \param  None
    //! \return None
    static void
    BoardInit(void)
    #ifndef USE_TIRTOS
    #if defined(ccs)
    #endif
    #if defined(ewarm)
    #endif
    #endif
        // Enable Processor
    //! \param  None
        long lRetVal = -1;
        if(lRetVal < 0)
            LOOP_FOREVER();
            else
                return SUCCESS;
        return SUCCESS;
    //! \param  None
        long lRetVal = -1;
        lRetVal = sl_WlanPolicySet(SL_POLICY_P2P, SL_P2P_POLICY(SL_P2P_ROLE_NEGOTIATE,
        else
        return SUCCESS;
    //! \param  none
    //! \return none
    static void
    int BsdUdpServer(unsigned short usPort)
        SlSockAddrIn_t  sLocalAddr;
        int             iCounter;
        int             iAddrSize;
        int             iSockID;
        int             iStatus;
        short           sTestBufLen;
        	uBuf.BsdBuf[iCounter] = (char)(iCounter % 10);
        sTestBufLen  = BUF_SIZE;
        sLocalAddr.sin_family = SL_AF_INET;
        sLocalAddr.sin_port = sl_Htons((unsigned short)usPort);
        sLocalAddr.sin_addr.s_addr = 0;
        if( iSockID < 0 )
            // error
            ASSERT_ON_ERROR(-1);
        // binding the UDP socket to the UDP server address
        iStatus = sl_Bind(iSockID, (SlSockAddr_t *)&sLocalAddr, iAddrSize);
        if( iStatus < 0 )
            // error
            sl_Close(iSockID);
        // no listen or accept is required as UDP is connectionless protocol
        /// waits for 1000 packets from a UDP client
        while (1)
            iStatus = sl_RecvFrom(iSockID, uBuf.BsdBuf, sTestBufLen, 0,
                         ( SlSockAddr_t *)&sAddr, (SlSocklen_t*)&iAddrSize );
        if( iStatus < 0 )
            // error
            sl_Close(iSockID);
        for (iCounter=0 ; iCounter<iStatus ; iCounter++)
        	UART_PRINT("%c", uBuf.BsdBuf[iCounter]);
        UART_PRINT("\n\r");
        lLoopCount++;
        UART_PRINT("Recieved %u packets successfully\n\r",lLoopCount);
        //closing the socket after receiving 1000 packets
        sl_Close(iSockID);
        return SUCCESS;
        int             iCounter;
        short           sTestBufLen;
        int             iAddrSize;
        int             iSockID;
        int             iStatus;
        sAddr.sin_port = sl_Htons((unsigned short)5001);
        sAddr.sin_addr.s_addr = sl_Htonl((unsigned int)0xC0A83101);
        GPIO_IF_LedOn(MCU_RED_LED_GPIO);
        GPIO_IF_LedOff(MCU_RED_LED_GPIO);
        if( iSockID < 0 )
            // error
        while (1)
            // sending packet
            iStatus = sl_SendTo(iSockID, uBuf.BsdBuf, sTestBufLen, 0,
            if( iStatus <= 0 )
                // error
                sl_Close(iSockID);
            lLoopCount++;
        UART_PRINT("Sent %u packets successfully\n\r",lLoopCount);
        sl_Close(iSockID);
        return SUCCESS;
    int main()
        long lRetVal = -1;
        BoardInit();
        PinMuxConfig();
        // configure LEDs
        // off all LEDs
    #ifndef NOTERM
        // Configuring UART
        InitTerm();
    #endif
        if(lRetVal < 0)
            LOOP_FOREVER();
        if(lRetVal < 0)
            LOOP_FOREVER();
        if(lRetVal == 0)
        else
            LOOP_FOREVER();
        if(DisplayIP() < 0)
            LOOP_FOREVER();
        UART_PRINT("Send TCP packets from your handheld device to CC3200's IP\n\r");
        	//lRetVal = BsdUdpServer(PORT_NUM);
        	//lRetVal = BsdTcpServer(PORT_NUM);
            if(lRetVal >= 0)
                UART_PRINT("Received TCP packets successfully \n\r");
            else
        if(lRetVal >=0)
        else
        if(lRetVal < 0)
             ERR_PRINT(lRetVal);
             LOOP_FOREVER();
        while(1)
    Aashish
  • Hi Luca,
    Also can you try with other UDP application on your android device.
    Aashish
  •  Hi ,
    now iperf it seems ok.. I don't know if it is ok..
    In your code you have changed only the loop ( while (1) infinite loop ).. It was only that the problem ?? it seems strange because if I want to send a smaller number of packets I need that loop..
    For you , iperf photo is ok ?
    I tried with wireshark and aircap but I can't see the udp packets.. I set the airpcap usb ( i have only two usb airpcap) in the channel 6 and 11.. I can see only the probe request and the probe response..
    Can you know if the board send the packets in an other channel ?
    Or maybe the board uses an encryption of the data and wireshark can't enter inside the 802.11 packets.. But in this case I should see the 802.11 packets in wire shark..right ??
  • Hi Luca,
    It's verified your phone receiving UDP packets.
    Using while(1) as connecting to P2P device and opening iperf on my phone taking time. So CC3200 transmitted all 1000 packets before iperf open on my phone. That's the reason I am using while loop. You can send small number of packets, there is no issue,
    Yes, it's perfect.
    Board sending the packets as it verified by iperf screenshot. Data can be on channel 1 or 6 or 11, depend upon negotiation between mobile and device.
    Yes data is encrypted. As WiFi Direct uses in-built WPA2 AES256 encryption for all data transfer. Please refer WiFi Direct specification.
    Aashish
  • hi ,
    yes but my network is without the password..
    the encryption is between the 802.11 packets and udp packets inside ??
    thanks for your help
  • Hi ,
    I looked at your main code.. It is equal than to my code but with one only difference : while(1) ..
    It I put "while ( loop_count < UDP_PACKET_COUNT) " the board doesn't send packet..
    In your code there isn't a count for the number of packets ma I stay always inside the while(1)..
    I want something with a correct number of packets..
    it is correct what I said ?
  • Hi Luca,
    No. Board sending packets but you cant see in iperf because by the time iperf open, board already sent the packets. 1000 packets take only few milliseconds to transmit in UDP.
    Aashish
  • Hi ,
    so the code is the same.. I had to put an higher value for the UDP_PACKET_COUNT for seeing on iperf.. The different is only this..
    Do you have any idea for wireshark ?
    Is there a mode for seeing the udp packets ? or you know another sniffer where I can see packets?
    Luca
  • Hi Luca,
    Yes. Alternatively put the breakpoint before while loop (pause the execution), open the iperf and resume the code.
    As we mentioned packets are encrypted so you can't  see. We are using omnipeak and by packets size(udp data len + 82) we determining it's UDP packet, but actual content we can't see.
    Aashish
  • Hi ,
    could you see again the photo about iperf that I sent yesterday ?
    It doesn't seem ok because I see 0.00 Bytes .
    I send nothing ??
    Luca
  • Hi Luca,
    Do you mean on this post: e2e.ti.com/.../1472533. I can see packets are received (950 datagram received etc.)
    Aashish
  • Hi ,
    sorry it is ok..
    I can't use a sniffer so.. I can create an app for seeing the packets on the smartphone.. Do you think that it can be a solution ?
    Best Regards
    Luca
  • Hi Luca,
    Yes you can do that only thing you need to take care of sync between device and your application.
    Aashish
  • it is not enough having a server running in the same port where I want to connect the client ( TI board ) ?
    What do you mean with sync ? Can you explain better ?
  • Hi Luca,
    mean put the breakpoint before while loop (pause the execution), run your android application and resume the code at device side.
    Aashish
  • Hi ,
    ok , I will try..
    I could use the same strategy for evaluating the traffic ?
    Why you can see with omnipeak and not with wireshark ?
    udp data len + 82 , why this + 82 ?? What does it mean ?
    Best Regards
    Luca
  • Hi Luca,
    Can't comments on this.
    82 bytes are different type of header (udp header, ipv4/6 header, ethernet header etc.)
    Aashish
  • Hi ,
    why you can't comment ??
    because you don't believe that I don't see the packets on wireshark ? or because you don't want to say that one program is better than another ?
  • Hi Luca,
    Because I don't have any reason why wireshark not showing encrypted packets. Unfortunately I am not wireshark or omnipeak or any other sniffer expert so can't comment on these.
    Aashish
  • I can send only udp packets ??
    If I want to change ??
    The code seems ok but I can't see the TCP packets on iperf...
    int BsdTcpClient(unsigned short usPort)
    int iCounter;
    short sTestBufLen;
    int iAddrSize;
    int iSockID;
    int iStatus;
    //filling the TCP server socket address
    sAddr.sin_addr.s_addr = sl_Htonl((unsigned int)g_ulDestinationIp);
    // creating a TCP socket
    iSockID = sl_Socket(SL_AF_INET,SL_SOCK_STREAM, 0);
    if( iSockID < 0 )
    // connecting to TCP server
    iStatus = sl_Connect(iSockID, ( SlSockAddr_t *)&sAddr, iAddrSize);
    if( iStatus < 0 )
    // error
    sl_Close(iSockID);
    ASSERT_ON_ERROR(CONNECT_ERROR);
    // sending multiple packets to the TCP server
    // sending packet
    iStatus = sl_Send(iSockID, g_cBsdBuf, sTestBufLen, 0 );
    if( iStatus < 0 )
    // error
    sl_Close(iSockID);
    lLoopCount++;
    Report("Sent %u packets successfully\n\r",g_ulPacketCount);
    iStatus = sl_Close(iSockID);
    ASSERT_ON_ERROR(iStatus);
    return SUCCESS;
  • Hi Luca,
    Please make sure configure server IP (value of g_ulDestinationIp) is correct. Can you please post iperf screenshot.
    Aashish
  • Hi ,
    The ip address is the same in both cases ( udp and tcp).. 192.168.49.1
    On iperf I wrote -s -i 1 -t 10000
    but i can see only the connection..
  • Have you tried with your board ??
    You can see something on iperf if you use TCP packets ??
    REgards
        Luca
  • Hi Luca,
    We are able to see TCP packets on iperf. Please post iperf screenshot here.
    Aashish
  • Hi ,
    With the same my code ?
    It is not possible.. It is not useful that I show the iperf screenshot.. I can see only the connection between the smartphone and the board..
    The code is ok for udp but not for tcp
  • Hi Luca,
    Yes we tried same TCP client code that you posted on previous post with following changes:
    g_ulDestinationIp = 0xC0A83101 (our tcp server ip)
    g_ulPacketCount = 1000 (sending 1000 packets)
    Aashish
  • Hi ,
    the set on iperf is : -s -i 1 -t 10000 ? or it is different ??
  • HI Luca,
    Yes, we used same option "-s -i 1 -t 10000" on iperf .
    Aashish
  • Hi ,
    it is not possible..
    mmm i will try again but for me you aren't saying the truth.
    Luca
  • Hi Luca,
    For your reference screenshots attached.
    Aashish
  • I have this problem :
    Can't find a source file at "D:/GIT/a0132167_sdk_1.1.0/source-1p1-rahul/simplelink/source/nonos.c"
    Locate the file or edit the source lookup path to include its location.
    Maybe this is the mistake.. How can add the source file ??
    What is the source file ? the main file ?
    Best Regards
               Luca
  • Hi Luca,
    You can do either of one.
    No. CCS use this file to map executing code to source code for debugging.
    Aashish
  • Hi ,
    Hi ,
    I filled the buffer in the same mode that it was on the example ( with count and the mod operator ).. I have an application for receiving udp packets and saving data with get method in a text file..
    Look at the photo..
    In each file I have .txt14291000039161 for example where 142910000 is the same for each file..
    Do you know how can read this data for understanding what there is inside ?
    For example what the first part is ( 142910000 )??
    and 39161 ?
    I had seen in another post that you know a lot about the buffer and how I can fill it..
    How can read this type of data ? Must i do a conversion or something ?
  • Hi Luca,
    Android side store data in some file and open in hex-editor.
    Aashish
  • Hi ,
    I am trying to understand how I can modify the data inside the buffer.
    I have the possibility to change the buffer size and for example I put 1024
    #define BUF_SIZE 1024
    What does it mean 1024 ? The dimension of the buffer is 1 kb ?
    How many packets i have ?
    I am trying do understand how I can fill the buffer.. but before I wuold like to understand : one complete buffer is one packet ?
    Best Regards
    LUca
  • Hi Luca,
    Yes, 1024 bytes in buffer.
    Generally a UDP packets contain 1400 bytes or less.
    you can put something like that
    char ch = 'a';
        if(ch > 'z')
            ch = 'a';
       g_cBsdBuf[iCounter] =  ch;
       ch++;
    it will fill buffer from a-z
    or you can use memcpy, strcpy, sprintf to fill any data.
    Aashish
  • Hi ,
    Thanks for your right answers..
    I would like to ask another question..
    1) In my smartphone I have seen that I loose a lot of packets..
    Maybe the problem is the frequency of sending..
    Can I set/change the frequency of sending packets in Ti board ?
    2)In my last question I asked how I can fill the buffer and now I understand where I can search information.. but if I want to modify something in the TCP header ( udp is not useful because I don't a lot of thing) , I can access across the code ?
    Because now we spoke only about the data but If I want to access to other parts of the tcp packets how can i do ?
    It is possible to insert timestamp or different type of packets from the code ( for example monitoring packets ) ??
    Sorry for the number of the question but I think there isn't a guide for this part..
    Thanks a lot
    Best Regards
    Luca Rossini
  • i have also same problem. the locate file is not opening any thing and next one is how can i edit source lookup path? where it is available?
