Bluetooth can't search other devices with wilink 8.
Other Parts Discussed in Thread: TWL6032, TWL6030, WL1271
Hi everyone!
I'm porting bluetooth with android 4.2.2 based omap 4 platform.
I can turn  on/off bluetooth button on setting interface. but I can't search other devices.
I followed this link: http://processors.wiki.ti.com/index.php/TI-Android-ICS-PortingGuide#Driver_Configuration_2
<6>[    0.000000] Booting Linux on physical CPU 0
<6>[    0.000000] Initializing cgroup subsys cpu
<5>[    0.000000] Linux version 3.4.48 (hoavn@hibk-MS-7846) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #4 SMP PREEMPT Thu Apr 23 14:18:29 FNT 2015
<4>[    0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d
<4>[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
<4>[    0.000000] Machine: OMAP44XX Tablet board
<6>[    0.000000] Initialized persistent memory from a0000000-a01fffff
<6>[    0.000000] android_display: setting hdmi resolution to 1920*1080, bpp=4
<6>[    0.000000] android_display: tiler1d 56623104
<6>[    0.000000] android_display: setting fb0.vram to 16588800
<6>[    0.000000] android_display: setting fb1.vram to 16588800
<6>[    0.000000] android_display: setting vram to 33177600
<3>[    0.000000] Cannot detect omap type!
<6>[    0.000000] Reserving 33554432 bytes SDRAM for VRAM
<6>[    0.000000] cma: CMA: reserved 16 MiB at 95800000
<4>[    0.000000] Memory policy: ECC disabled, Data cache writealloc
<6>[    0.000000] OMAP4: Map 0x96e00000 to 0xfe600000 for dram barrier
<7>[    0.000000] On node 0 totalpages: 168192
<7>[    0.000000] free_area_init_node: node 0, pgdat c09ff240, node_mem_map c102e000
<7>[    0.000000]   Normal zone: 1024 pages used for memmap
<7>[    0.000000]   Normal zone: 0 pages reserved
<7>[    0.000000]   Normal zone: 92672 pages, LIFO batch:31
<7>[    0.000000]   HighMem zone: 1024 pages used for memmap
<7>[    0.000000]   HighMem zone: 73472 pages, LIFO batch:15
<6>[    0.000000] OMAP4460 ES1.1
<6>[    0.000000] PERCPU: Embedded 9 pages/cpu @c1835000 s13056 r8192 d15616 u36864
<7>[    0.000000] pcpu-alloc: s13056 r8192 d15616 u36864 alloc=9*4096
<7>[    0.000000] pcpu-alloc: [0] 0 [0] 1
<4>[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 166144
<5>[    0.000000] Kernel command line: console=ttyO2,115200n8 androidboot.console=ttyO2 omap_wdt.timer_margin=30 vmalloc=496M omapfb.fb_opt=-1,-1,-1,1,1280,720 omap-cpufreq.safe_suspend_freq=600000000 androidboot.serialno=0158B4200301800E androidboot.bootloader=U-Boot_1.1.4 omapdss.def_disp=hdmi
<6>[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
<6>[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>[    0.000000] Memory: 366MB 2MB 289MB = 657MB total
<5>[    0.000000] Memory: 633664k/633664k available, 414912k reserved, 295936K highmem
<5>[    0.000000] Virtual kernel memory layout:
<5>[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
<5>[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
<5>[    0.000000]     vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
<5>[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
<5>[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
<5>[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
<5>[    0.000000]       .text : 0xc0008000 - 0xc0903000   (9196 kB)
<5>[    0.000000]       .init : 0xc0903000 - 0xc095b300   ( 353 kB)
<5>[    0.000000]       .data : 0xc095c000 - 0xc0a01f90   ( 664 kB)
<5>[    0.000000]        .bss : 0xc0a01fb4 - 0xc0b7bad8   (1511 kB)
<6>[    0.000000] Preemptible hierarchical RCU implementation.
<6>[    0.000000] NR_IRQS:626
<6>[    0.000000] OMAP clockevent source: GPTIMER1 at 32768 Hz
<6>[    0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
<6>[    0.000213] Calibrating delay loop... 1392.74 BogoMIPS (lpj=5439488)
<6>[    0.070343] pid_max: default: 32768 minimum: 301
<6>[    0.070556] Security Framework initialized
<6>[    0.070648] Mount-cache hash table entries: 512
<6>[    0.071899] Initializing cgroup subsys debug
<6>[    0.071929] Initializing cgroup subsys cpuacct
<6>[    0.071960] Initializing cgroup subsys freezer
<6>[    0.071960] Initializing cgroup subsys net_cls
<6>[    0.072021] CPU: Testing write buffer coherency: ok
<6>[    0.072235] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
<6>[    0.072479] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
<6>[    0.072631] Setting up static identity map for 0x80697670 - 0x806976c8
<6>[    0.072662] L310 cache controller enabled
<6>[    0.072662] l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x7e470000, Cache size: 1048576 B
<6>[    0.073150] generating sar_ram layout...
<6>[    0.073364] sar ram layout created
<4>[    0.151000] CPU1: Booted secondary processor
<6>[    0.220947] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
<2>[    0.220977] CPU1: Unknown IPI message 0x1
<6>[    0.221008] Brought up 2 CPUs
<6>[    0.221008] SMP: Total of 2 processors activated (2792.83 BogoMIPS).
<4>[    0.229705] omap_hwmod: aess: _wait_target_disable failed
<4>[    0.232482] omap_hwmod: dss_dispc: cannot be enabled (3)
<4>[    0.235198] omap_hwmod: dss_dsi1: cannot be enabled (3)
<4>[    0.237915] omap_hwmod: dss_dsi2: cannot be enabled (3)
<4>[    0.240631] omap_hwmod: dss_hdmi: cannot be enabled (3)
<4>[    0.243316] omap_hwmod: dss_rfbi: cannot be enabled (3)
<4>[    0.246032] omap_hwmod: dss_venc: cannot be enabled (3)
<4>[    0.249877] omap_hwmod: mcpdm: cannot be enabled (3)
<3>[    0.251708] omap_device: cannot add global notifier for dev PM QoS
<6>[    0.252288] dummy:
<6>[    0.253356] NET: Registered protocol family 16
<6>[    0.270294] DMA: preallocated 256 KiB pool for atomic coherent allocations
<6>[    0.270660] GPMC revision 6.0
<6>[    0.272399] gpiochip_add: registered GPIOs 0 to 31 on device: gpio
<6>[    0.272460] OMAP GPIO hardware version 0.1
<6>[    0.272613] gpiochip_add: registered GPIOs 32 to 63 on device: gpio
<6>[    0.272827] gpiochip_add: registered GPIOs 64 to 95 on device: gpio
<6>[    0.273040] gpiochip_add: registered GPIOs 96 to 127 on device: gpio
<6>[    0.273223] gpiochip_add: registered GPIOs 128 to 159 on device: gpio
<6>[    0.273437] gpiochip_add: registered GPIOs 160 to 191 on device: gpio
<6>[    0.274658] omap_mux_init: Add partition: #1: core, flags: 2
<6>[    0.275634] omap_mux_init: Add partition: #2: wkup, flags: 2
<6>[    0.282226] dmm dmm: initialized all PAT entries
<3>[    0.283843] omap_mux_get_by_name: Could not find signal csi22_dx2.csi22_dx2
<3>[    0.283874] omap_mux_get_by_name: Could not find signal csi22_dy2.csi22_dy2
<6>[    0.284271] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
<6>[    0.284301] hw-breakpoint: maximum watchpoint size is 4 bytes.
<4>[    0.287994]  omap-mcbsp.1: alias pad_fck already exists
<4>[    0.288177]  omap-mcbsp.2: alias pad_fck already exists
<4>[    0.288330]  omap-mcbsp.3: alias pad_fck already exists
<4>[    0.288482]  omap-mcbsp.4: alias pad_fck already exists
<6>[    0.288940] gcxxx_int failed. gcx hardware is not present
<6>[    0.289093] OMAP DMA hardware revision 0.0
<6>[    0.289642] emif emif.1: emif_probe: device configured with addr = e0984000 and IRQ142
<6>[    0.289916] emif emif.2: emif_probe: device configured with addr = e0986000 and IRQ143
<6>[    0.291259] SmartReflex Recalibration delay = 86400000ms
<6>[    0.291290] SmartReflex Class 1.5 initialized
<6>[    0.291687] Reprogramming LPDDR2 timings to 800000000 Hz
<6>[    0.300903] bio: create slab <bio-0> at 0
<6>[    0.301544] VBAT: 3750 mV
<6>[    0.301788] vwl1271: 1800 mV
<5>[    0.302734] SCSI subsystem initialized
<6>[    0.303039] usbcore: registered new interface driver usbfs
<6>[    0.303161] usbcore: registered new interface driver hub
<6>[    0.303283] usbcore: registered new device driver usb
<6>[    0.304229] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 400 kHz
<6>[    0.305236] twl_core: detected twl6032 rev.2 eepromrev.56
<6>[    0.306488] twl 1-0048: PIH (irq 39) chaining IRQs 416..436
<6>[    0.307525] LDOUSB: 3300 mV normal standby
<6>[    1.025604] PC detected
<3>[    1.025665] musb-omap2430 musb-omap2430: musb core is not yet ready
<6>[    1.025970] twl6030_usb twl6030_usb: Initialized TWL6030 USB module
<6>[    1.026916] VANA: 2100 mV normal standby
<6>[    1.027648] CLK32KAUDIO:
<6>[    1.028564] SYSEN:
<6>[    1.029541] REGEN1:
<6>[    1.030242] CLK32KG:
<6>[    1.030548] V2V1: 2100 mV normal
<6>[    1.030578] V2V1: supplied by SYSEN
<6>[    1.031341] LDO5: 1200 <--> 3000 mV at 3000 mV normal standby
<6>[    1.032287] LDO1: 1800 <--> 2500 mV at 1900 mV normal standby
<6>[    1.033203] LDO7: 1200 <--> 2900 mV at 1800 mV normal standby
<6>[    1.034362] LDO6: 1800 mV normal standby
<6>[    1.034576] LDO6: supplied by V2V1
<6>[    1.035888] LDOLN: 1800 mV normal standby
<6>[    1.036102] LDOLN: supplied by V2V1
<6>[    1.037048] LDO2: 1000 <--> 3000 mV at 2800 mV normal standby
<6>[    1.037994] LDO4: 1200 <--> 2800 mV at 1800 mV normal standby
<6>[    1.038940] LDO3: 1000 <--> 3000 mV at 1200 mV normal standby
<6>[    1.040191] SMPS4: 1800 mV normal standby
<6>[    1.040954] omap_i2c omap_i2c.2: bus 2 rev2.4.0 at 400 kHz
<6>[    1.041381] omap_i2c omap_i2c.3: bus 3 rev2.4.0 at 400 kHz
<6>[    1.041656] omap_i2c omap_i2c.4: bus 4 rev2.4.0 at 400 kHz
<6>[    1.041900] Linux video capture interface: v2.00
<4>[    1.041961] sr_init: No PMIC hook to init smartreflex
<6>[    1.042541] omap-iommu omap-iommu.0: dsp registered
<6>[    1.042633] omap-iommu omap-iommu.1: ipu registered
<6>[    1.042877] Advanced Linux Sound Architecture Driver Version 1.0.25.
<6>[    1.043518] Bluetooth: Core ver 2.16
<6>[    1.043579] NET: Registered protocol family 31
<6>[    1.043579] Bluetooth: HCI device and connection manager initialized
<6>[    1.043609] Bluetooth: HCI socket layer initialized
<6>[    1.043609] Bluetooth: L2CAP socket layer initialized
<6>[    1.043640] Bluetooth: SCO socket layer initialized
<6>[    1.045288] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized
<6>[    1.045776] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized
<6>[    1.046234] smartreflex smartreflex.2: omap_sr_probe: SmartReflex driver initialized
<6>[    1.046264] Power Management for TI OMAP4XX/OMAP5XXX devices.
<6>[    1.046661] omap_opp_set_min_rate: Missing opp info for hwmod hsi
<6>[    1.046661] Forcing clock hsi_fck to minimum rate 96000000
<6>[    1.046722] omap_opp_set_min_rate: Missing opp info for hwmod dsp_c0
<6>[    1.046722] Forcing clock virt_dpll_dsp_ck to minimum rate 232750000
<6>[    1.047393] Switching to clocksource 32k_counter
<6>[    1.067504] NET: Registered protocol family 2
<6>[    1.067810] IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
<6>[    1.068481] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
<6>[    1.069610] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
<6>[    1.070831] TCP: Hash tables configured (established 65536 bind 65536)
<6>[    1.070861] TCP: reno registered
<6>[    1.070922] UDP hash table entries: 256 (order: 1, 8192 bytes)
<6>[    1.070953] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
<6>[    1.071289] NET: Registered protocol family 1
<6>[    1.071716] RPC: Registered named UNIX socket transport module.
<6>[    1.071746] RPC: Registered udp transport module.
<6>[    1.071746] RPC: Registered tcp transport module.
<6>[    1.071746] RPC: Registered tcp NFSv4.1 backchannel transport module.
<4>[    1.071899] usbhs_omap usbhs_omap: ehci_logic_fck failed:-2
<6>[    1.072937] Trying to unpack rootfs image as initramfs...
<6>[    1.088775] Freeing initrd memory: 180K
<4>[    1.089111] NetWinder Floating Point Emulator V0.97 (double precision)
<4>[    1.089996]  omap-rproc.1: alias fck already exists
<6>[    1.090667] persistent_ram: error in header, 6
<6>[    1.090698] persistent_ram: found existing buffer, size 38355, start 38355
<6>[    1.094543] sr_classp5_calib_work: smartreflex_core: Calibration complete: Voltage Nominal=1127000 Calib=1000180 Dyn=1050180 OPP_margin=13000 total_margin=25320
<6>[    1.094604] sr_classp5_calib_work: smartreflex_mpu: Calibration complete: Voltage Nominal=1203000 Calib=1012840 Dyn=1062840 OPP_margin=0 total_margin=0
<6>[    1.094726] sr_classp5_calib_work: smartreflex_iva: Calibration complete: Voltage Nominal=950000 Calib=848260 Dyn=898260 OPP_margin=13000 total_margin=25320
<6>[    1.232971] console [ram-1] enabled
<4>[    1.391143] highmem bounce pool size: 64 pages
<6>[    1.392608] fuse init (API version 7.18)
<6>[    1.392974] msgmni has been set to 691
<6>[    1.394989] io scheduler noop registered
<6>[    1.395080] io scheduler deadline registered
<6>[    1.395324] io scheduler cfq registered (default)
<6>[    1.396667] OMAP DSS rev 4.0
<3>[    1.418334] d2l 2-000f: D2L i2c initialized
<6>[    1.418823] dsscomp: initializing.
<7>[    1.418945] misc dsscomp: display0=hdmi_panel
<6>[    1.418975] misc dsscomp: found 1 displays and 4 overlays, WB overlay 1
<6>[    1.420135] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 105) is a OMAP UART1
<6>[    1.420715] omap_uart.2: ttyO2 at MMIO 0x48020000 (irq = 106) is a OMAP UART2
<6>[    2.564117] console [ttyO2] enabled
<6>[    2.568542] omap_uart.3: ttyO3 at MMIO 0x4806e000 (irq = 102) is a OMAP UART3
<6>[    2.577026] [drm] Initialized drm 1.1.0 20060810
<6>[    2.582366] omap_ion_probe: adding heap secure_input of type 2 with ba300000@5a00000
<6>[    2.591003] omap_ion_probe: adding heap tiler of type 4 with b4300000@6000000
<6>[    2.598937] omap_ion_probe: adding heap nonsecure_tiler of type 4 with a0200000@2000000
<6>[    2.607727] omap_ion_probe: adding heap system of type 0 with 0@0
<6>[    2.614532] omap_ion_probe: adding heap tiler_reservation of type 5 with 0@0
<6>[    2.631317] brd: module loaded
<6>[    2.639404] loop: module loaded
<6>[    2.643035] (stk) :sysfs entries created
<6>[    2.647430] (stk) : debugfs entries created
<6>[    2.652130] (hci_tty): inside hci_tty_init
<6>[    2.657135] (hci_tty): allocated 252, 0
<6>[    2.661376] AK8975 compass driver: init
<3>[    2.666290] cdc_tcxo_driver 1-006c: failed to initialize registers (-121)
<4>[    2.673767] cdc_tcxo_driver: probe of 1-006c failed with error -121
<3>[    2.685638] tps6130x 1-0033: tps6130x_probe: Failed to access device
<4>[    2.693084] tps6130x: probe of 1-0033 failed with error -121
<6>[    2.701477] NFC Driver for TI WiLink
<6>[    2.705474] (nfcdrv) nfc_drv_probe: allocated major 250, minor 0
<3>[    2.713287] mtdoops: mtd device (mtddev=name/number) must be supplied
<6>[    2.721435] omap2_mcspi omap2_mcspi.1: master is unqueued, this is deprecated
<6>[    2.729766] omap2_mcspi omap2_mcspi.2: master is unqueued, this is deprecated
<6>[    2.738067] omap2_mcspi omap2_mcspi.3: master is unqueued, this is deprecated
<6>[    2.746276] omap2_mcspi omap2_mcspi.4: master is unqueued, this is deprecated
<6>[    2.754547] tun: Universal TUN/TAP device driver, 1.6
<6>[    2.760131] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
<6>[    2.767730] usbcore: registered new interface driver asix
<6>[    2.773773] usbcore: registered new interface driver cdc_ether
<6>[    2.780364] usbcore: registered new interface driver smsc95xx
<6>[    2.786773] usbcore: registered new interface driver net1080
<6>[    2.793151] usbcore: registered new interface driver cdc_subset
<6>[    2.799743] usbcore: registered new interface driver zaurus
<6>[    2.806060] usbcore: registered new interface driver cdc_ncm
<6>[    2.812744] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
<7>[    2.820007] ehci_hcd: block sizes: qh 64 qtd 96 itd 160 sitd 96
<7>[    2.820220] ehci-omap ehci-omap.0: failed to get ehci port0 regulator
<7>[    3.820892] ehci-omap ehci-omap.0: phy reset operation timed out
<3>[    3.826263] ehci: omap_ehci_ulpi_write: Error
<7>[    3.830932] ehci-omap ehci-omap.0: reset hcs_params 0x1313 dbg=0 cc=1 pcc=3 ordered ports=3
<7>[    3.831237] ehci-omap ehci-omap.0: reset hcc_params 20016 thresh 1 uframes 256/512/1024 park LPM
<7>[    3.831268] ehci-omap ehci-omap.0: reset command 0080b02  park=3 ithresh=8 period=1024 Reset HALT
<6>[    3.831298] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
<7>[    3.837738] drivers/usb/core/inode.c: creating file 'devices'
<7>[    3.837768] drivers/usb/core/inode.c: creating file '001'
<6>[    3.837921] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
<7>[    3.847564] ehci-omap ehci-omap.0: park 0
<7>[    3.847595] ehci-omap ehci-omap.0: support lpm
<6>[    3.847625] ehci-omap ehci-omap.0: irq 109, io mem 0x4a064c00
<7>[    3.854064] ehci-omap ehci-omap.0: init command 0010005 (park)=0 ithresh=1 period=512 RUN
<6>[    3.867797] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
<7>[    3.874267] usb usb1: default language 0x0409
<7>[    3.874298] usb usb1: udev 1, busnum 1, minor = 0
<6>[    3.874328] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
<6>[    3.881805] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[    3.889831] usb usb1: Product: OMAP-EHCI Host Controller
<6>[    3.895690] usb usb1: Manufacturer: Linux 3.4.48 ehci_hcd
<6>[    3.901702] usb usb1: SerialNumber: ehci-omap.0
<7>[    3.907073] usb usb1: usb_probe_device
<7>[    3.907104] usb usb1: configuration #1 chosen from 1 choice
<7>[    3.907135] usb usb1: adding 1-0:1.0 (config #1, interface 0)
<7>[    3.907287] hub 1-0:1.0: usb_probe_interface
<7>[    3.907287] hub 1-0:1.0: usb_probe_interface - got id
<6>[    3.907318] hub 1-0:1.0: USB hub found
<6>[    3.911468] hub 1-0:1.0: 3 ports detected
<7>[    3.916015] hub 1-0:1.0: standalone hub
<7>[    3.916046] hub 1-0:1.0: individual port power switching
<7>[    3.916046] hub 1-0:1.0: individual port over-current protection
<7>[    3.916076] hub 1-0:1.0: power on to power good time: 20ms
<7>[    3.916107] hub 1-0:1.0: local power source is good
<7>[    3.916107] hub 1-0:1.0: enabling power on all ports
<7>[    3.916351] drivers/usb/core/inode.c: creating file '001'
<7>[    3.916503] ehci-omap ehci-omap.0: ...powerup ports...
<6>[    3.946197] usbcore: registered new interface driver cdc_wdm
<6>[    3.952423] Initializing USB Mass Storage driver...
<6>[    3.958007] usbcore: registered new interface driver usb-storage
<6>[    3.964660] USB Mass Storage support registered.
<6>[    3.969940] usbcore: registered new interface driver libusual
<6>[    3.976348] usbcore: registered new interface driver usbtest
<6>[    3.982666] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
<7>[    4.016265] hub 1-0:1.0: state 7 ports 3 chg 0000 evt 0000
<7>[    4.190002] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
<7>[    4.190032] musb-hdrc: MHDRC RTL version 2.0
<7>[    4.190063] musb-hdrc: setup fifo_mode 4
<7>[    4.190063] musb-hdrc: 28/31 max ep, 16384/16384 memory
<6>[    4.190429] musb-hdrc musb-hdrc: USB OTG mode controller at e0b16000 using DMA, IRQ 124
<6>[    4.199829] file system registered
<6>[    4.205078]  gadget: Mass Storage Function, version: 2009/09/11
<6>[    4.211700]  gadget: Number of LUNs=1
<6>[    4.215759]  lun0: LUN: removable file: (no medium)
<6>[    4.221496]  gadget: android_usb ready
<6>[    4.426147] musb-hdrc musb-hdrc: MUSB HDRC host driver
<7>[    4.431854] drivers/usb/core/inode.c: creating file '002'
<6>[    4.432037] musb-hdrc musb-hdrc: new USB bus registered, assigned bus number 2
<7>[    4.440063] musb-hdrc musb-hdrc: supports USB remote wakeup
<7>[    4.440124] usb usb2: default language 0x0409
<7>[    4.440155] usb usb2: udev 1, busnum 2, minor = 128
<6>[    4.440185] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
<6>[    4.447662] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[    4.455657] usb usb2: Product: MUSB HDRC host driver
<6>[    4.461212] usb usb2: Manufacturer: Linux 3.4.48 musb-hcd
<6>[    4.467163] usb usb2: SerialNumber: musb-hdrc
<7>[    4.472351] usb usb2: usb_probe_device
<7>[    4.472381] usb usb2: configuration #1 chosen from 1 choice
<7>[    4.472412] usb usb2: adding 2-0:1.0 (config #1, interface 0)
<7>[    4.472564] hub 2-0:1.0: usb_probe_interface
<7>[    4.472595] hub 2-0:1.0: usb_probe_interface - got id
<6>[    4.472595] hub 2-0:1.0: USB hub found
<6>[    4.476837] hub 2-0:1.0: 1 port detected
<7>[    4.481231] hub 2-0:1.0: standalone hub
<7>[    4.481231] hub 2-0:1.0: individual port power switching
<7>[    4.481262] hub 2-0:1.0: no over-current protection
<7>[    4.481262] hub 2-0:1.0: Single TT
<7>[    4.481292] hub 2-0:1.0: TT requires at most 8 FS bit times (666 ns)
<7>[    4.481292] hub 2-0:1.0: power on to power good time: 10ms
<7>[    4.481323] hub 2-0:1.0: 200mA bus power budget for each child
<7>[    4.481323] hub 2-0:1.0: local power source is good
<7>[    4.481353] hub 2-0:1.0: enabling power on all ports
<7>[    4.481597] drivers/usb/core/inode.c: creating file '001'
<6>[    4.516479] mousedev: PS/2 mouse device common for all mice
<6>[    4.524322] twl6030_pwrbutton_probe: Enter
<6>[    4.529205] input: twl6030_pwrbutton as /devices/platform/omap_i2c.1/i2c-1/1-0049/twl6030_pwrbutton/input/input0
<7>[    4.578765] hub 2-0:1.0: state 7 ports 1 chg 0000 evt 0000
<6>[    4.581420] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
<6>[    4.588256] i2c /dev entries driver
<6>[    4.592864] usbcore: registered new interface driver uvcvideo
<6>[    4.599212] USB Video Class driver (1.1.1)
<6>[    4.604003] Driver for 1-wire Dallas network protocol.
<3>[    4.610107] bq2415x_charger 1-006a: i2c_write failed to transfer all messages
<3>[    4.618041] bq2415x_charger 1-006a: chip not present at address 6a
<4>[    4.624847] bq2415x_charger: probe of 1-006a failed with error -22
<6>[    4.644897] twl6030_bci twl6030_bci: Battery Voltage at Bootup is 3786 mV
<3>[    4.659515] report_temperature_delayed_work_fn: Fail to set temp
<6>[    4.667602] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 30 sec
<6>[    4.676696] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
<6>[    4.686218] Bluetooth: Virtual HCI driver ver 1.3
<6>[    4.691833] Bluetooth: HCI UART driver ver 2.2
<6>[    4.696807] Bluetooth: HCI H4 protocol initialized
<6>[    4.702209] Bluetooth: HCI BCSP protocol initialized
<6>[    4.707794] Bluetooth: HCILL protocol initialized
<6>[    4.713134] Bluetooth: HCIATH3K protocol initialized
<6>[    4.718780] usbcore: registered new interface driver bcm203x
<6>[    4.725280] usbcore: registered new interface driver bpa10x
<6>[    4.731719] usbcore: registered new interface driver bfusb
<6>[    4.737976] usbcore: registered new interface driver btusb
<6>[    4.744110] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
<6>[    4.750427] Bluetooth: Bluetooth Driver for TI WiLink - Version 1.0
<6>[    4.757995] (stc): st_register(4)
<6>[    4.761718] (stc):  chnl_id list empty :4
<6>[    4.766174] (stk) : st_kim_start
<6>[    4.770416] cpuidle: using governor ladder
<6>[    4.775512] cpuidle: using governor menu
<6>[    4.793762] omap4430_sdp_display_probe:Enter
<7>[    4.798645] Registered led device: lcd-backlight
<6>[    4.799102] omap4430_sdp_display_probe:Exit
<6>[    4.804229] usbcore: registered new interface driver usbhid
<6>[    4.810485] usbhid: USB HID core driver
<6>[    4.815307] ashmem: initialized
<6>[    4.818817] logger: created 256K log 'log_main'
<6>[    4.823913] logger: created 256K log 'log_events'
<6>[    4.829223] logger: created 256K log 'log_radio'
<6>[    4.834411] logger: created 256K log 'log_system'
<6>[    4.839874] omap_governor_init: domain cpu slope 348 const -9301
<3>[    4.846557] thermal_get_slope:Getting slope is not supported for domain gpu
<3>[    4.854248] thermal_get_offset:Getting offset is not supported for domain gpu
<6>[    4.862152] omap_governor_init: domain gpu slope -22 const -22
<6>[    4.868988] rproc remoteproc0: ipu_c0 is available
<6>[    4.874359] rproc remoteproc0: Note: remoteproc is still under development and considered experimental.
<6>[    4.884674] rproc remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
<6>[    4.896545] (stk) :ldisc_install = 1
<6>[    4.900665] OMAP HSI: HSI driver version 0.4.4
<6>[    4.906188] usbcore: registered new interface driver snd-usb-audio
<6>[    4.916839] aess aess: ABE Firmware version 9560
<4>[    4.934356] twl6040-codec twl6040-codec: couldn't get VDDHF regulator -517
<6>[    4.938110] sr_classp5_calib_work: smartreflex_mpu: Calibration complete: Voltage Nominal=1380000 Calib=1266040 Dyn=1316040 OPP_margin=0 total_margin=0
<6>[    4.972106] mmc0: new high speed MMC card at address 0001
<6>[    4.978424] mmcblk0: mmc0:0001 004G90 3.68 GiB
<6>[    4.983642] mmcblk0boot0: mmc0:0001 004G90 partition 1 2.00 MiB
<6>[    4.990386] mmcblk0boot1: mmc0:0001 004G90 partition 2 2.00 MiB
<4>[    4.999420] Alternate GPT is invalid, using primary GPT.
<6>[    5.005493]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10
<6>[    5.016662] asoc: snd-soc-dummy-dai <-> MultiMedia1 mapping ok
<6>[    5.024139]  mmcblk0boot1: unknown partition table
<6>[    5.030334] asoc: snd-soc-dummy-dai <-> MultiMedia2 mapping ok
<6>[    5.036804]  mmcblk0boot0: unknown partition table
<6>[    5.056243] asoc: snd-soc-dummy-dai <-> Voice mapping ok
<6>[    5.072113] asoc: snd-soc-dummy-dai <-> Tones mapping ok
<6>[    5.087677] asoc: snd-soc-dummy-dai <-> Vibra mapping ok
<6>[    5.102264] asoc: snd-soc-dummy-dai <-> MODEM mapping ok
<6>[    5.117950] asoc: snd-soc-dummy-dai <-> MultiMedia1 LP mapping ok
<6>[    5.133483] asoc: snd-soc-dummy-dai <-> omap-mcbsp.2 mapping ok
<6>[    5.151214] asoc: twl6040-legacy <-> mcpdm-legacy mapping ok
<6>[    5.164276] asoc: dit-hifi <-> mcasp-legacy mapping ok
<6>[    5.171325] asoc: dmic-hifi <-> omap-dmic mapping ok
<6>[    5.177246] asoc: twl6040-dl1 <-> mcpdm-dl1 mapping ok
<6>[    5.183380] asoc: twl6040-ul <-> mcpdm-ul1 mapping ok
<6>[    5.189178] asoc: twl6040-dl2 <-> mcpdm-dl2 mapping ok
<6>[    5.195007] asoc: twl6040-vib <-> mcpdm-vib mapping ok
<6>[    5.200866] asoc: snd-soc-dummy-dai <-> omap-mcbsp.1 mapping ok
<6>[    5.207550] asoc: snd-soc-dummy-dai <-> omap-mcbsp.1 mapping ok
<6>[    5.214355] asoc: snd-soc-dummy-dai <-> omap-mcbsp.2 mapping ok
<6>[    5.224090] asoc: snd-soc-dummy-dai <-> omap-mcbsp.2 mapping ok
<6>[    5.230865] asoc: snd-soc-dummy-dai <-> omap-mcbsp.2 mapping ok
<4>[    5.237396] mmc2: card claims to support voltages below the defined range. These will be ignored.
<6>[    5.247314] asoc: dmic-hifi <-> omap-dmic-abe-dai-0 mapping ok
<6>[    5.253967] asoc: dmic-hifi <-> omap-dmic-abe-dai-1 mapping ok
<6>[    5.260559] asoc: dmic-hifi <-> omap-dmic-abe-dai-2 mapping ok
<6>[    5.267181] asoc: snd-soc-dummy-dai <-> omap-abe-vxrec-dai mapping ok
<6>[    5.274444] asoc: snd-soc-dummy-dai <-> omap-abe-echo-dai mapping ok
<6>[    5.282226] input: tablet Headset Jack as /devices/platform/omap-abe-twl6040/sound/card0/input1
<6>[    5.295043] asoc: omap-hdmi-hifi <-> omap-hdmi-audio-dai mapping ok
<6>[    5.302795] oprofile: using arm/armv7-ca9
<6>[    5.307342] GACT probability NOT on
<6>[    5.311248] Mirror/redirect action on
<6>[    5.315307] u32 classifier
<6>[    5.318328]     Actions configured
<6>[    5.322174] Netfilter messages via NETLINK v0.30.
<6>[    5.327392] nf_conntrack version 0.5.0 (10159 buckets, 40636 max)
<6>[    5.334442] ctnetlink v0.93: registering with nfnetlink.
<6>[    5.340332] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
<6>[    5.348022] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
<4>[    5.355133] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
<6>[    5.361389] xt_time: kernel timezone is -0000
<6>[    5.366485] ip_tables: (C) 2000-2006 Netfilter Core Team
<6>[    5.372985] mmc2: new high speed SDIO card at address 0001
<6>[    5.379150] arp_tables: (C) 2002 David S. Miller
<6>[    5.384277] TCP: cubic registered
<6>[    5.387969] Initializing XFRM netlink socket
<6>[    5.394134] NET: Registered protocol family 10
<6>[    5.399749] Mobile IPv6
<6>[    5.402526] ip6_tables: (C) 2000-2006 Netfilter Core Team
<6>[    5.408599] IPv6 over IPv4 tunneling driver
<6>[    5.414215] NET: Registered protocol family 17
<6>[    5.419128] NET: Registered protocol family 15
<5>[    5.424072] Bridge firewalling registered
<6>[    5.428680] Bluetooth: RFCOMM TTY layer initialized
<6>[    5.434051] Bluetooth: RFCOMM socket layer initialized
<6>[    5.439727] Bluetooth: RFCOMM ver 1.11
<6>[    5.443878] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
<6>[    5.449707] Bluetooth: BNEP filters: protocol multicast
<6>[    5.455474] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
<6>[    5.462036] NET: Registered protocol family 35
<6>[    5.467254] NET: Registered protocol family 37
<6>[    5.472137] NET: Registered protocol family 40
<4>[    5.477203] safe_suspend_freq_set: suspend will take place at frequency 700000000
<6>[    5.485504] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
<6>[    5.494079] ThumbEE CPU extension supported.
<5>[    5.498779] Registering SWP/SWPB emulation handler
<6>[    5.511383] clock: disabling unused clocks to save power
<3>[    5.517944] HDCP: hdcp_3des_cb: hdcp_keys not loaded = 0
<3>[    5.517944]
<3>[    5.538513] omapdss error: timeout reading edid
<3>[    5.899108] (stk) :ldisc installation timeout
<6>[    5.903717] (stk) :ldisc_install = 0
<7>[    6.016326] hub 1-0:1.0: hub_suspend
<7>[    6.016754] usb usb1: bus auto-suspend, wakeup 1
<7>[    6.016754] ehci-omap ehci-omap.0: ehci_omap_bus_suspend
<7>[    6.016784] ehci-omap ehci-omap.0: suspend root hub
<6>[    6.069946] cannot apply mgr(tv) on inactive device
<6>[    6.075561] cannot aply mgr(lcd)--invalid device
<4>[    6.080993] omapfb omapfb: failed to apply dispc config
<6>[    6.086944] cannot apply mgr(tv) on inactive device
<4>[    6.092376] omapfb omapfb: failed to apply dispc config
<6>[    6.098144] cannot aply mgr(lcd2)--invalid device
<4>[    6.103332] omapfb omapfb: failed to apply dispc config
<6>[    6.110351] LDO5: disabling
<6>[    6.114959] twl_rtc twl_rtc: setting system clock to 2000-01-01 00:29:15 UTC (946686555)
<6>[    6.123931] ALSA device list:
<6>[    6.127227]   #0: tablet
<6>[    6.130004]   #1: OMAPHDMI
<6>[    6.133361] Freeing init memory: 352K
<3>[    6.140594] init: /init.omap44xxtabletboard.rc: 190: ignored duplicate definition of service 'uim'
<4>[    6.150970] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
<3>[    6.231536] init: could not open /dev/keychord
<6>[    6.327239] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
<6>[    6.336791] sr_classp5_calib_work: smartreflex_core: Calibration complete: Voltage Nominal=962000 Calib=898900 Dyn=948900 OPP_margin=38000 total_margin=50640
<6>[    6.354034] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null)
<6>[    6.366882] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<6>[    6.414764] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/omap/omap_hsmmc.1/by-name/cache
<6>[    6.583984] rproc remoteproc0: skipping power up until last virtio device ipu_c0
<6>[    6.592773] virtio_rpmsg_bus virtio0: rpmsg host is online
<6>[    6.598968] rproc remoteproc0: registered virtio0 (type 7)
<6>[    6.605438] rproc remoteproc0: powering up ipu_c0
<6>[    6.642486] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=panic
<6>[    6.657104] rproc remoteproc0: Booting fw image ducati-m3-core0.xem3, size 6806939
<6>[    6.677490] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<6>[    6.727233] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/omap/omap_hsmmc.1/by-name/userdata
<6>[    6.751556] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=panic
<3>[    6.786712] init: cannot find '/system/bin/shm_service', disabling 'shm_service'
<3>[    6.795135] HDCP: failed to load keys
<3>[    6.795135]
<3>[    6.809020] init: cannot find '/system/bin/rild', disabling 'ril-daemon'
<3>[    6.825744] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
<3>[    6.839508] init: cannot find '/system/bin/supl20clientd', disabling 'supl20clientd'
<3>[    6.852630] init: cannot find '/system/bin/arxd', disabling 'arxd'
<7>[    6.867187] hub 2-0:1.0: hub_suspend
<7>[    6.867187] usb usb2: bus auto-suspend, wakeup 1
<3>[    6.906860] (stk) : timed out waiting for ldisc to be un-installed
<6>[    6.920410] Compat-wireless backport release: ol_r8.a5.08
<6>[    6.936889] Backport based on wl18xx.git ol_r8.a5.13
<6>[    6.945983] compat.git: wl18xx.git
<6>[    6.950256] omap-iommu omap-iommu.1: ipu: version 2.1
<6>[    6.960601] rproc remoteproc0: remote processor ipu_c0 is now up
<6>[    6.968597] virtio_rpmsg_bus virtio1: rpmsg host is online
<6>[    6.974517] rproc remoteproc0: registered virtio1 (type 7)
<6>[    6.983489] omap-rproc omap-rproc.1: received echo reply from ipu_c0
<6>[    6.990661] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x32
<6>[    7.001068] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x33
<6>[    7.010040] virtio_rpmsg_bus virtio0: creating channel rpmsg-omx0 addr 0x3c
<6>[    7.019348] rpmsg_omx rpmsg-omx0: new OMX connection srv channel: 1024 -> 60!
<6>[    7.039672] (stk) :ldisc_install = 1
<6>[    7.046478] virtio_rpmsg_bus virtio1: creating channel rpmsg-omx1 addr 0x3c
<6>[    7.058807] rpmsg_omx rpmsg-omx1: new OMX connection srv channel: 1024 -> 60!
<6>[    7.066864] virtio_rpmsg_bus virtio1: creating channel omaprpc addr 0x3b
<6>[    7.094451] (stc): st_tty_open
<6>[    7.097839] (stk) :line discipline installed
<6>[    7.104248] (stk) :TIInit_11.8.32.bts
<6>[    7.112060] PVR: PVRCore_Init
<6>[    7.116821] PVR: LinuxMMInit: Maximum page pool size: 10800
<6>[    7.123199] PVR: PVRSRVDriverProbe(pDevice=d68e8c00)
<6>[    7.130096] PVR: SGX register base: 0x56000000
<6>[    7.134979] PVR: SGX register size: 65535
<6>[    7.141571] PVR: SGX IRQ: 53
<6>[    7.150787] PVR: EnableSystemClocks: Enabling System Clocks
<6>[    7.175231] PVR: PVRCore_Init: major device 245
<6>[    7.196197] sr_classp5_calib_work: smartreflex_core: Calibration complete: Voltage Nominal=1250000 Calib=1076140 Dyn=1126140 OPP_margin=13000 total_margin=25320
<6>[    7.243103] cfg80211: Calling CRDA to update world regulatory domain
<6>[    7.305786] cfg80211: World regulatory domain updated:
<6>[    7.311431] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
<6>[    7.321380] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
<6>[    7.329956] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
<6>[    7.338439] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
<6>[    7.348052] cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
<6>[    7.356597] cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
<6>[    7.433258] PVR: Installing MISR with cookie bf047274
<6>[    7.448913] PVR: Installing device LISR SGX ISR on IRQ 53 with cookie d52a8bc0
<6>[    7.457427] PVR: SysFinalise: Version string: SGX revision = 1.2.0
<6>[    7.470764] omaplfbOMAPLFBInit: Blitsville gc2d not present, blits disabled
<4>[    7.478393] omaplfb: OMAPLFBInitFBDev: Device 2: invalid framebuffer size
<7>[    7.485870] omaplfb: OMAPLFBInitFBVRAM: Device 1: Using 2 VRAM framebuffers
<7>[    7.485900] omaplfb: OMAPLFBInitFBVRAM: Device 0: Using 2 VRAM framebuffers
<6>[    7.609619] EXT4-fs (mmcblk0p8): re-mounted. Opts: (null)
<6>[    7.795776] virtio_rpmsg_bus virtio1: creating channel rpmsg-resmgr addr 0x66
<6>[    7.866485] EXT4-fs (mmcblk0p8): re-mounted. Opts: (null)
<6>[    8.048278] wlcore: wl12xx driver version:
<6>[    8.091766] wlcore: wl18xx driver version:
<3>[    8.142272] android_usb: already disabled
<3>[    8.146942] android_usb: already disabled
<3>[    8.152160] android_usb: already disabled
<6>[    8.164916] adb_open
<6>[    8.167327] mtp_bind_config
<6>[    8.170379] adb_bind_config
<6>[    8.202789] (stc): add_channel_to_table: id 4
<6>[    8.207519] (stc): st_register(2)
<6>[    8.211090] (stc): add_channel_to_table: id 2
<6>[    8.234954] (stc): st_register(3)
<6>[    8.238555] (stc): add_channel_to_table: id 3
<6>[    8.333435] virtio_rpmsg_bus virtio1: destroying channel rpmsg-resmgr addr 0x66
<6>[    8.481964] android_work: sent uevent USB_STATE=CONNECTED
<6>[    8.488647]  gadget: high-speed config #1: android
<6>[    8.494140] android_work: sent uevent USB_STATE=CONFIGURED
<6>[   10.266265] (stc): remove_channel_from_table: id 3
<6>[   10.271514] (stc): remove_channel_from_table: id 2
<6>[   10.277008] (stc): remove_channel_from_table: id 4
<6>[   10.283020] (stc):  all chnl_ids unregistered
<6>[   10.288208] (stk) :ldisc_install = 0
<6>[   10.292114] (stc): st_tty_close
<6>[   22.256072] warning: `zygote' uses 32-bit capabilities (legacy support in use)
<6>[   23.641296] sr_classp5_calib_work: smartreflex_mpu: Calibration complete: Voltage Nominal=1317000 Calib=1177420 Dyn=1227420 OPP_margin=0 total_margin=0
<6>[   30.625366] request_suspend_state: wakeup (3->0) at 30617004401 (2000-01-01 00:29:40.005828861 UTC)
<6>[   32.030700] acc_open
<6>[   32.033325] acc_release
<4>[   32.155578] Vibra left overcurrent detected
<7>[   36.915191] usb usb1: usb auto-resume
<7>[   36.915191] ehci-omap ehci-omap.0: ehci_omap_bus_resume
<7>[   36.915252] ehci-omap ehci-omap.0: resume root hub
<7>[   36.961578] hub 1-0:1.0: hub_resume
<7>[   36.961639] hub 1-0:1.0: state 7 ports 3 chg 0000 evt 0000
<7>[   36.961669] hub 1-0:1.0: hub_suspend
<7>[   36.961700] usb usb1: bus auto-suspend, wakeup 1
<7>[   36.961700] ehci-omap ehci-omap.0: ehci_omap_bus_suspend
<7>[   36.961700] ehci-omap ehci-omap.0: suspend root hub
<7>[   36.962554] usb usb2: usb auto-resume
<7>[   36.984985] hub 2-0:1.0: hub_resume
<7>[   36.985046] hub 2-0:1.0: state 7 ports 1 chg 0000 evt 0000
<7>[   36.985107] hub 2-0:1.0: hub_suspend
<7>[   36.985107] usb usb2: bus auto-suspend, wakeup 1
<6>[   41.981781] (stc): st_register(12)
<6>[   41.985626] (stc):  chnl_id list empty :12
<6>[   41.990112] (stk) : st_kim_start
<6>[   42.125640] (stk) :ldisc_install = 1
<6>[   42.180450] (stc): st_tty_open
<6>[   42.184356] (stk) :line discipline installed
<6>[   42.189178] (stk) :TIInit_11.8.32.bts
<6>[   43.157684] (stc): add_channel_to_table: id 12
<6>[   43.189575] mtp_open
<6>[   43.626556] (stc): remove_channel_from_table: id 12
<6>[   43.631835] (stc):  all chnl_ids unregistered
<6>[   43.637878] (stk) :ldisc_install = 0
<6>[   43.642211] (stc): st_tty_close
<6>[   46.985229] sr_classp5_calib_work: smartreflex_mpu: Calibration complete: Voltage Nominal=1025000 Calib=835600 Dyn=885600 OPP_margin=10000 total_margin=12660
<6>[   52.297637] (hci_tty): inside hci_tty_open (d52981f8, d11d9300)
<6>[   52.304199] (stc): st_register(4)
<6>[   52.307922] (stc):  chnl_id list empty :4
<6>[   52.312347] (stk) : st_kim_start
<6>[   52.422515] (stk) :ldisc_install = 1
<6>[   52.478881] (stc): st_tty_open
<6>[   52.483001] (stk) :line discipline installed
<6>[   52.488159] (stk) :TIInit_11.8.32.bts
<3>[   52.792755] init: sys_prop: permission denied uid:1003  name:service.bootanim.exit
<6>[   53.278350] (stc): add_channel_to_table: id 4
<6>[   53.283142] (stc): st_register(2)
<6>[   53.286834] (stc): add_channel_to_table: id 2
<6>[   53.291595] (stc): st_register(3)
<6>[   53.295227] (stc): add_channel_to_table: id 3
<3>[   53.818786] init: Boot Animation exit
<6>[   55.898315] (hci_tty): inside hci_tty_release (d52981f8, d11d9300)
<6>[   55.914642] (stc): remove_channel_from_table: id 4
<6>[   55.919982] (stc): remove_channel_from_table: id 2
<6>[   55.930328] (stc): remove_channel_from_table: id 3
<6>[   55.945953] (stc):  all chnl_ids unregistered
<6>[   55.950714] (stk) :ldisc_install = 0
<6>[   55.954620] (stc): st_tty_close
<6>[  116.973449] request_suspend_state: sleep (0->3) at 116965057568 (2000-01-01 00:31:06.353882028 UTC)
<6>[  116.984466] DSSCOMP: dsscomp_early_suspend
<6>[  116.989074] DSSCOMP: blanked screen
<6>[  274.085388] request_suspend_state: wakeup (3->0) at 274077026374 (2000-01-01 00:33:43.465850834 UTC)
<6>[  274.095581] DSSCOMP: dsscomp_late_resume
<4>[  279.332000] Vibra left overcurrent detected
<4>[  279.564758] Vibra left overcurrent detected
<4>[  279.844421] Vibra left overcurrent detected
<4>[  280.006744] Vibra left overcurrent detected
<4>[  280.483520] Vibra left overcurrent detected
<4>[  280.684387] Vibra left overcurrent detected
<4>[  292.033325] Vibra left overcurrent detected
<6>[  337.049591] wlcore: wl18xx HW: RDL 2, 1857 MIMO, PG 2.0 (ROM 0)
<4>[  337.076385] cfg80211: wext will not work because kernel was compiled with CONFIG_WIRELESS_EXT=n. Tools using wext interface, like iwconfig will not work.
<6>[  337.093841] wlcore: loaded
<6>[  337.099121] wlcore: driver version:
<6>[  337.105285] wlcore: timestamp: Fri Mar 20 09:30:07 2015
<6>[  337.731323] wlcore: PHY firmware version: Rev 8.2.0.0.163
<6>[  337.819335] wlcore: firmware booted (Rev 8.5.0.0.53)
<6>[  337.843383] ADDRCONF(NETDEV_UP): wlan0: link is not ready
<6>[  337.968109] ADDRCONF(NETDEV_UP): p2p0: link is not ready
<6>[  342.227722] (hci_tty): inside hci_tty_open (d52981f8, d43e4300)
<6>[  342.234283] (stc): st_register(4)
<6>[  342.238067] (stc):  chnl_id list empty :4
<6>[  342.243164] (stk) : st_kim_start
<6>[  342.359985] (stk) :ldisc_install = 1
<6>[  342.415161] (stc): st_tty_open
<6>[  342.418914] (stk) :line discipline installed
<6>[  342.423889] (stk) :TIInit_11.8.32.bts
<4>[  342.600189] ------------[ cut here ]------------
<4>[  342.605682] WARNING: at /home/hoavn/WORK/jorjin_bsp/mydroid/hardware/ti/wlan/mac80211/compat_wl18xx/drivers/net/wireless/ti/wlcore/sdio.c:106 wl12xx_sdio_raw_read+0xb0/0x130 [wlcore_sdio]()
<4>[  342.624084] Modules linked in: wlcore_sdio(O) wl18xx(O) wl12xx(O) wlcore(O) mac80211(O) cfg80211(O) pvrsrvkm_sgx540_120(O) compat(O)
<4>[  342.638031] Backtrace:
<4>[  342.640869] [<c0017b74>] (dump_backtrace+0x0/0x10c) from [<c0687338>] (dump_stack+0x18/0x1c)
<4>[  342.650054]  r6:0000006a r5:bf002300 r4:00000000 r3:c09bee50
<4>[  342.656707] [<c0687320>] (dump_stack+0x0/0x1c) from [<c0046968>] (warn_slowpath_common+0x54/0x6c)
<4>[  342.666381] [<c0046914>] (warn_slowpath_common+0x0/0x6c) from [<c00469a4>] (warn_slowpath_null+0x24/0x2c)
<4>[  342.676879]  r8:000000e8 r7:cf454ec0 r6:cf4f9008 r5:000050f8 r4:d518ce00
<4>[  342.684478] r3:00000009
<4>[  342.687591] [<c0046980>] (warn_slowpath_null+0x0/0x2c) from [<bf002300>] (wl12xx_sdio_raw_read+0xb0/0x130 [wlcore_sdio])
<4>[  342.699554] [<bf002250>] (wl12xx_sdio_raw_read+0x0/0x130 [wlcore_sdio]) from [<bf14e300>] (wlcore_fw_status+0x70/0x45c [wlcore])
<4>[  342.712249]  r8:cf454f48 r7:cf119b80 r6:cf454ec0 r5:bf169d3c r4:cf119b60
<4>[  342.720245] [<bf14e290>] (wlcore_fw_status+0x0/0x45c [wlcore]) from [<bf14e764>] (wlcore_irq_locked+0x78/0x2ac [wlcore])
<4>[  342.732299] [<bf14e6ec>] (wlcore_irq_locked+0x0/0x2ac [wlcore]) from [<bf14eebc>] (wlcore_irq+0x40/0xe4 [wlcore])
<4>[  342.743621] [<bf14ee7c>] (wlcore_irq+0x0/0xe4 [wlcore]) from [<c00a9d6c>] (irq_thread+0xdc/0x178)
<4>[  342.753356] [<c00a9c90>] (irq_thread+0x0/0x178) from [<c00668d8>] (kthread+0x90/0x9c)
<4>[  342.762023] [<c0066848>] (kthread+0x0/0x9c) from [<c004a87c>] (do_exit+0x0/0x804)
<4>[  342.770294]  r6:c004a87c r5:c0066848 r4:cf537b0c
<4>[  342.775665] Board Information:
<4>[  342.775665]  Revision : 0010
<4>[  342.775665]  Serial    : 0000000000000000
<4>[  342.775665] SoC Information:
<4>[  342.775665]  CPU    : OMAP4460
<4>[  342.775665]  Rev    : ES1.1
<4>[  342.775665]  Type    : GP
<4>[  342.775665]  Production ID: 8001B94E-000200F0
<4>[  342.775695]  Die ID    : 77A60002-00000001-0158B420-0301800E
<4>[  342.775695]
<4>[  342.810699] ---[ end trace 325d57d5568b7f91 ]---
<3>[  342.815795] wl1271_sdio mmc2:0001:2: sdio read failed (-110)
<4>[  342.822052] ------------[ cut here ]------------
<4>[  342.827178] WARNING: at /home/hoavn/WORK/jorjin_bsp/mydroid/hardware/ti/wlan/mac80211/compat_wl18xx/drivers/net/wireless/ti/wlcore/main.c:818 wl12xx_queue_recovery_work+0x6c/0x74 [wlcore]()
<4>[  342.845672] Modules linked in: wlcore_sdio(O) wl18xx(O) wl12xx(O) wlcore(O) mac80211(O) cfg80211(O) pvrsrvkm_sgx540_120(O) compat(O)
<4>[  342.859344] Backtrace:
<4>[  342.862152] [<c0017b74>] (dump_backtrace+0x0/0x10c) from [<c0687338>] (dump_stack+0x18/0x1c)
<4>[  342.871429]  r6:00000332 r5:bf14ee74 r4:00000000 r3:c09bee50
<4>[  342.877960] [<c0687320>] (dump_stack+0x0/0x1c) from [<c0046968>] (warn_slowpath_common+0x54/0x6c)
<4>[  342.887695] [<c0046914>] (warn_slowpath_common+0x0/0x6c) from [<c00469a4>] (warn_slowpath_null+0x24/0x2c)
<4>[  342.898193]  r8:cf119d40 r7:d4e4ee40 r6:cf119b9c r5:cf119bb4 r4:cf119b60
<4>[  342.905639] r3:00000009
<4>[  342.908752] [<c0046980>] (warn_slowpath_null+0x0/0x2c) from [<bf14ee74>] (wl12xx_queue_recovery_work+0x6c/0x74 [wlcore])
<4>[  342.920684] [<bf14ee08>] (wl12xx_queue_recovery_work+0x0/0x74 [wlcore]) from [<bf14ef5c>] (wlcore_irq+0xe0/0xe4 [wlcore])
<4>[  342.932708]  r4:cf119b60 r3:00000300
<4>[  342.936798] [<bf14ee7c>] (wlcore_irq+0x0/0xe4 [wlcore]) from [<c00a9d6c>] (irq_thread+0xdc/0x178)
<4>[  342.946563] [<c00a9c90>] (irq_thread+0x0/0x178) from [<c00668d8>] (kthread+0x90/0x9c)
<4>[  342.955139] [<c0066848>] (kthread+0x0/0x9c) from [<c004a87c>] (do_exit+0x0/0x804)
<4>[  342.963378]  r6:c004a87c r5:c0066848 r4:cf537b0c
<4>[  342.968719] Board Information:
<4>[  342.968719]  Revision : 0010
<4>[  342.968719]  Serial    : 0000000000000000
<4>[  342.968719] SoC Information:
<4>[  342.968719]  CPU    : OMAP4460
<4>[  342.968719]  Rev    : ES1.1
<4>[  342.968719]  Type    : GP
<4>[  342.968719]  Production ID: 8001B94E-000200F0
<4>[  342.968719]  Die ID    : 77A60002-00000001-0158B420-0301800E
<4>[  342.968719]
<4>[  343.003570] ---[ end trace 325d57d5568b7f92 ]---
<6>[  343.008728] wlcore: Reading FW panic log
<6>[  343.013244] wlcore: Hardware recovery in progress. FW ver: Rev 8.5.0.0.53
<6>[  343.021057] wlcore: down
<6>[  343.024108] wlcore: down
<6>[  343.030364] ieee80211 phy0: Hardware restart was requested
<6>[  343.527221] wlcore: PHY firmware version: Rev 8.2.0.0.163
<6>[  343.645935] wlcore: firmware booted (Rev 8.5.0.0.53)
<3>[  344.344451] (stk) :response timeout during fw download
<3>[  344.352600] (stk) :download firmware failed
<6>[  344.357238] (stk) :ldisc_install = 0
<6>[  344.361541] (stc): st_tty_close
<6>[  344.477172] (stk) :ldisc_install = 1
<6>[  344.531646] (stc): st_tty_open
<6>[  344.535308] (stk) :line discipline installed
<6>[  344.540527] (stk) :TIInit_11.8.32.bts
<6>[  345.558715] (stc): add_channel_to_table: id 4
<6>[  345.564025] (stc): st_register(2)
<6>[  345.567840] (stc): add_channel_to_table: id 2
<6>[  345.572814] (stc): st_register(3)
<6>[  345.576690] (stc): add_channel_to_table: id 3
<6>[  347.991088] (hci_tty): inside hci_tty_release (d52981f8, d43e4300)
<6>[  347.997833] (stc): remove_channel_from_table: id 4
<6>[  348.003417] (stc): remove_channel_from_table: id 2
<6>[  348.008850] (stc): remove_channel_from_table: id 3
<6>[  348.014343] (stc):  all chnl_ids unregistered
<6>[  348.019439] (stk) :ldisc_install = 0
<6>[  348.048339] (stc): st_tty_close
<6>[  348.310302] (hci_tty): inside hci_tty_open (d52981f8, d47299c0)
<6>[  348.316833] (stc): st_register(4)
<6>[  348.320709] (stc):  chnl_id list empty :4
<6>[  348.325347] (stk) : st_kim_start
<6>[  348.438079] (stk) :ldisc_install = 1
<6>[  348.492919] (stc): st_tty_open
<6>[  348.496582] (stk) :line discipline installed
<6>[  348.508422] (stk) :TIInit_11.8.32.bts
<6>[  349.523803] (stc): add_channel_to_table: id 4
<6>[  349.529083] (stc): st_register(2)
<6>[  349.532745] (stc): add_channel_to_table: id 2
<6>[  349.537475] (stc): st_register(3)
<6>[  349.541168] (stc): add_channel_to_table: id 3
Any sugesstions for my issue ?
Best Regard!
