Wl18xx Station mode use case:Connect to secured network - any WPA PSK
Expert 1985 points
Other Parts Discussed in Thread: WL1835MOD
Above use case from ti wiki fails with multiple standard AP's which we test. But we were able to connect to only mobile hotspots.
The error we get is beacon loss and authentication time out in 1 meter distance. similar is the situation in peak and off peak hours.
Driver version: 8.9.10
i.MX6SL Yocto build
log:
Configuring CLIENT!!!
Re - Configuring CLIENT!!!
wlan0: deauthenticating from 00:22:6b:6a:3f:f0 by local choice (Reason: 3=DEAUTH_LEAVING)
wlcore: down
cfg80211: Calling CRDA to update world regulatory domain
Debug calling wifi_configure_client
Debug Wifi Client mode
wpa_supplicant v2.1-devel
random: Trying to read entropy from /dev/random
Successfully initialized wpa_supplicant
Initializing interface 'wlan0' conf '/etc/wpa_supplicant.conf' driver 'nl80211' ctrl_interface 'N/A' bridge 'N/A'
Configuration file '/etc/wpa_supplicant.conf' -> '/etc/wpa_supplicant.conf'
Reading configuration file '/etc/wpa_supplicant.conf'
update_config=1
ctrl_interface='/var/run/wpa_supplicant'
eapol_version=1
ap_scan=1
fast_reauth=1
device_name='Blaze'
manufacturer='TI'
model_name='Wilink'
model_number='wl18xx'
serial_number='12345'
driver_param='use_multi_chan_concurrent=1 use_p2p_group_interface=1'
p2p_go_max_inactivity=60
p2p_go_ht40=1
disassoc_low_ack=1
concurrent_sched_scan=1
p2p_disabled=1
rfkill: initial event: idx=0 type=2 op=0 soft=0 hard=0
rfkill: initial event: idx=1 type=1 op=0 soft=0 hard=0
nl80211: Supports Probe Response offload in AP mode
nl80211: Using driver-based off-channel TX
nl80211: Use separate P2P group interface (driver advertised support)
nl80211: Enable multi-channel concurrent (driver advertised support)
nl80211: interface wlan0 in phy phy0
nl80211: Set mode ifindex 4 iftype 2 (STATION)
nl80211: Subscribe to mgmt frames with non-AP handle 0xe825f0
nl80211: Register frame type=0xd0 nl_handle=0xe825f0
nl80211: Register frame match - hexdump(len=2): 01 04
nl80211: Register frame match - hexdump(len=2): 04 0a
nl80211: Register frame match - hexdump(len=2): 04 0b
nl80211: Register frame match - hexdump(len=2): 04 0c
nl80211: Register frame match - hexdump(len=2): 04 0d
nl80211: Register frame match - hexdump(len=6): 04 09 50 6f 9a 09
nl80211: Register frame match - hexdump(len=5): 7f 50 6f 9a 09
nl80211: Register frame match - hexdump(len=2): 08 01
nl80211: Register frame match - hexdump(len=1): 06
nl80211: Register frame match - hexdump(len=2): 0a 07
nl80211: Register frame match - hexdump(len=2): 0a 11
wlcore: PHY firmware version: Rev 8.2.0.0.212
wlcore: firmware booted (Rev 8.9.0.0.17)
IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
netlink: Operstate: linkmode=1, operstate=5
nl80211: driver param='use_multi_chan_concurrent=1 use_p2p_group_interface=1'
Add interface wlan0 to a new radio phy0
nl80211: Regulatory information - country=00
nl80211: 2402-2472 @ 40 MHz
nl80211: 2402-2472 @ 20 mBm
nl80211: 2457-2482 @ 40 MHz
nl80211: 2457-2482 @ 20 mBm
nl80211: 2474-2494 @ 20 MHz
nl80211: 2474-2494 @ 20 mBm
nl80211: 5170-5250 @ 160 MHz
nl80211: 5170-5250 @ 20 mBm
nl80211: 5250-5330 @ 160 MHz
nl80211: 5250-5330 @ 20 mBm
nl80211: 5490-5730 @ 160 MHz
nl80211: 5490-5730 @ 20 mBm
nl80211: Added 802.11b mode based on 802.11g information
wlan0: Own MAC address: 78:a5:04:20:fc:04
wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=0 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=2 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=3 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=4 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=5 set_tx=0 seq_len=0 key_len=0
wlan0: RSN: flushing PMKID list in the driver
nl80211: Flush PMKIDs
wlan0: State: DISCONNECTED -> INACTIVE
TDLS: TDLS operation not supported by driver
TDLS: Driver uses internal link setup
WPS: Set UUID for interface wlan0
WPS: UUID based on MAC address - hexdump(len=16): 11 4e 37 e2 1e b2 5b 57 87 eb 01 51 9e 3e 83 46
EAPOL: SUPP_PAE entering state DISCONNECTED
EAPOL: Supplicant port status: Unauthorized
nl80211: Set supplicant port unauthorized for 00:00:00:00:00:00
EAPOL: KEY_RX entering state NO_KEY_RECEIVE
EAPOL: SUPP_BE entering state INITIALIZE
EAP: EAP entering state DISABLED
Using existing control interface directory.
ctrl_iface bind(PF_UNIX) failed: Address already in use
ctrl_iface exists, but does not allow connections - assuming it was leftover from forced program termination
Successfully replaced leftover ctrl_iface socket '/var/run/wpa_supplicant/wlan0'
wlan0: Added interface wlan0
wlan0: State: INACTIVE -> DISCONNECTED
wpa_driver_nl80211_set_operstate: operstate 0->0 (DORMANT)
netlink: Operstate: linkmode=-1, operstate=5
Daemonize..
Debug AP security check in client mode:SECURED_NETWORK_ANY_WPA_PSK
Debug Client connecting to SECURED_NETWORK_ANY_WPA_PSK
OK
0
OK
OK
OK
OK
OK
wlan0: authenticate with 00:22:6b:6a:3f:9c
wlan0: send auth to 00:22:6b:6a:3f:9c (try 1/3)
OK
OK
wlan0: send auth to 00:22:6b:6a:3f:9c (try 2/3)
OK
wlan0: send auth to 00:22:6b:6a:3f:9c (try 3/3)
wlan0: authentication with 00:22:6b:6a:3f:9c timed out
Debug Client to AP connection check.
udhcpc (v1.22.1) started
Sending discover...
Sending discover...
Sending discover...
Sending discover...
###################################################################################################3
