Hi, guy:
Now I tried to get the HTTP server Post function to work, I defined some POST token, and used them in the webpages like as:
<FORM method="POST" name="EcoParamsConfig" action="" target="_self">
<table>
<tr>
<td colspan="6" ><h3>Electric Meter Setup</h3>
</td>
</tr>
<tr>
<td colspan="3"><h4>Mains Power Setting</h4></td>
<td colspan="3"><h4>Graph Display Options</h4></td>
</tr>
<tr>
<td>
Mains Voltage:</td>
<td colspan="2">
<select id="id_svoltage" name="__SL_P_P01">
<option value="0" >100</option>
<option value="1" >120</option>
<option value="2" >220</option>
<option value="3" >230</option>
<option value="4" >240</option>
</select>
</span>
VAC
</td>
<td></td><td colspan="2"><h5>Mains</h5></td>
</tr>
<tr>
<td>CO2 per kWh:</td>
<td colspan="2">
<input size="8" maxlength="9" type="text" name="__SL_P_P02" value="__SL_G_P02"> kg
</td>
<td>Phase 1</td>
<td colspan="2">
<select id="id_ph1sel" name="__SL_P_P07=">
<option value="0" >---</option>
<option value="1" >CT1A</option>
<option value="2" >CT1B</option>
<option value="3" >CT2A</option>
<option value="4" >CT2B</option>
<option value="5" >CT3A</option>
<option value="6" >CT3B</option>
</select>
</td>
</tr>
</tr>
<tr>
<td>Cost per kWh:<select id="id_currency" name="__SL_P_P63">
<option value="0" >$</option>
<option value="1" >¥</option>
<option value="2" >€</option>
<option value="3" >£</option>
</select></td>
<td colspan="2">
<input size="8" maxlength="9" type="text" name="__SL_P_P03=" value="__SL_G_P03">
</td>
<td>Phase 2 </td>
<td colspan="2">
<select id="id_ph2sel" name="__SL_P_P08=">
</select>
</td>
</tr>
<tr>
<td colspan="2" align="left"><input type="reset" name="reset" value="Reset"></td>
<td colspan="5" align="right"><input type="submit" name="save" value="Save"></td>
</tr>
But when I submit these data, I get following info from the POST events:
SL_NETAPP_HTTPPOSTTOKENVALUE_EVENT:__SL_P_P013D2
SL_NETAPP_HTTPPOSTTOKENVALUE_EVENT:__SL_P_P023D120.00
SL_NETAPP_HTTPPOSTTOKENVALUE_EVENT:__SL_P_P221H3B
SL_NETAPP_HTTPPOSTTOKENVALUE_EVENT:__SL_P_P281500
SL_NETAPP_HTTPPOSTTOKENVALUE_EVENT:__SL_P_P34500.00?
SL_NETAPP_HTTPPOSTTOKENVALUE_EVENT:__SL_P_P401600.00z
Not all valid data was submitted, why is it?
Best Regards
Martin
