Can't bind Wilink8 driver to MMC interface (AM335x, WL1835MOD, linux 4.4.8 with device tree)
Other Parts Discussed in Thread: WL1835MOD, WL1271
Hi
So I'm trying to get Wifi+BT functionality on a custom board using WiLink8 (WL1835MOD). The CPU is a TI AM335x. We use a custom distribution built with Yocto.
After enabling debug messages I finally solved a lot of errors, but now I'm stuck: everything seems to be correct, the wl18xx driver is loaded according to dmesg but it is not bound to the mmc interface. The wifi module is connected to mm2 (zero-based...) on the AM335x.
I could really use some help on this!
My device tree:
/dts-v1/;
#include "am335x-phycore-som.dtsi"
#include <dt-bindings/interrupt-controller/irq.h>
	model = "phyCORE-AM335x Amun";
	compatible = "phytec,am335x-wega", "phytec-am335x-phycore-som", "ti,am33xx";
	regulators {
		compatible = "simple-bus";
		vcc3v3: fixedregulator@1 {
			compatible = "regulator-fixed";
			regulator-name = "vcc3v3";
			regulator-min-microvolt = <3300000>;
			regulator-max-microvolt = <3300000>;
			regulator-boot-on;
		//wlan_en_reg: fixedregulator@5 {
		//	compatible = "regulator-fixed";
		//	regulator-name = "wlan-en-regulator";
		//	regulator-min-microvolt = <1800000>;
		//	regulator-max-microvolt = <1800000>;
		//	// gpio = <&gpio1 25 GPIO_ACTIVE_HIGH>;
		//	// enable-active-high;
		//	regulator-always-on;
&vdig1_reg {
/* SoM */
&i2c_eeprom {
    status = "okay";
&i2c_rtc {
    status = "okay";
/* uart1 is used by wifi/bluetooth chip (wilink8 */
&uart1 {
	status = "disabled";
&am33xx_pinmux {
        mmc1_pins: pinmux_mmc1 {
		pinctrl-single,pins = <
			/* Copied from am335x-wega.dtsi */
			0x0F0 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat3 */
			0x0F4 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat2 */
			0x0F8 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat1 */
			0x0FC (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat0 */
			0x100 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_clk */
			0x104 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_cmd */
			0x160 (PIN_INPUT_PULLUP | MUX_MODE7) /* mmc0_sdcd */
	uart0_pins: pinmux_uart0 {
			0x170 (PIN_INPUT_PULLUP | MUX_MODE0)    /* uart0_rxd */
			0x174 (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart0_txd */
	mrf24j40_pins_default: mrf24j40_pins_default {
			0x164 (PIN_INPUT | MUX_MODE7) /* C18: gpio0[7] */
            		0xE0  (PIN_INPUT | MUX_MODE7) /* U5:  gpio2[22] (!reset - not used) */
			0xE4  (PIN_INPUT | MUX_MODE7) /* R5:  gpio2[23] (wake - not used) */
			0x150 (PIN_INPUT_PULLDOWN | MUX_MODE0) /* A17: spi0_sclk */
			0x154 (PIN_INPUT_PULLDOWN | MUX_MODE0) /* B17: spi0_d0 */
			0x158 (PIN_INPUT_PULLUP | MUX_MODE0)   /* B16: spi0_d1 */
			0x15C (PIN_INPUT_PULLUP | MUX_MODE0)   /* A16: spi0_cs0 */
	// mrf24j40_pins_sleep: mrf24j40_pins_sleep {
	//	pinctrl-single,pins = <
	//		0x164 () /* C18: gpio0[7] */
	//		0xE0  () /* U5:  gpio2[22] (!reset - not used) */
	//		0xE4  () /* R5:  gpio2[23] (wake - not used) */
	//		0x150 () /* A17: spi0_sclk */
	//		0x154 () /* B17: spi0_d0 */
	//		0x158 () /* B16: spi0_d1 */
	//		0x15C () /* A16: spi0_cs0 */
	wilink_pins_default: wilink_pins_default {
			0x64 (PIN_INPUT | MUX_MODE7) /* U16: gpio1[25] */
			0x8C (PIN_INPUT_PULLUP | MUX_MODE3) /* V12: mmc2_clk */
			0x88 (PIN_INPUT_PULLUP | MUX_MODE3) /* T13: mmc2_cmd */
			0x44 (PIN_INPUT_PULLUP | MUX_MODE3) /* V14: mmc2_dat0 */
			0x48 (PIN_INPUT_PULLUP | MUX_MODE3) /* U14: mmc2_dat1 */
			0x4C (PIN_INPUT_PULLUP | MUX_MODE3) /* T14: mmc2_dat2 */
			0x78 (PIN_INPUT_PULLUP | MUX_MODE3) /* U18: mmc2_dat3 */
			0x58 (PIN_OUTPUT_PULLUP | MUX_MODE3) /* U15: mmc2_dat4 = bt_en */
			0x5C (PIN_INPUT | MUX_MODE3) /* T15: mmc2_dat5 */
			0x60 (PIN_OUTPUT_PULLUP | MUX_MODE3) /* V16: mmc2_dat6 = wlan_en */
			0x180 (PIN_INPUT_PULLUP | MUX_MODE0)  /* D16: uart1_rxd */
			0x184 (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* D15: uart1_txd */
			0x178 (PIN_INPUT | MUX_MODE0)  /* D18: uart1_ctsn */
			0x17C (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* D17: uart1_rtsn */
			0x190 (PIN_INPUT | MUX_MODE0) /* A13: mcasp0_aclkx */
			0x194 (PIN_INPUT | MUX_MODE0) /* B13: mcasp0_fsx */
			0x198 (PIN_INPUT | MUX_MODE0) /* D12: mcasp_axr0 */
			0x1a8 (PIN_INPUT | MUX_MODE0) /* D13: mcasp_axr1 */
    	// wilink_pins_sleep: wilink_pins_sleep {
	//	    0x64 () /* U16: gpio1[25] */
        //    0x8C () /* V12: mmc2_clk */
        //  0x88 () /* T13: mmc2_cmd */
        //  0x44 () /* V14: mmc2_dat0 */
        //  0x48 () /* U14: mmc2_dat1 */
        //  0x4C () /* T14: mmc2_dat2 */
        //  0x78 () /* U18: mmc2_dat3 */
        //  0x58 () /* U15: mmc2_dat4 */
        //  0x5C () /* T15: mmc2_dat5 */
        //  0x60 () /* V16: mmc2_dat6 */
        //  0x180 ()  /* D16: uart1_rxd */
        //  0x184 () /* D15: uart1_txd */
        //  0x178 ()  /* D18: uart1_ctsn */
        //  0x17C () /* D17: uart1_rtsn */
        //  0x190 () /* A13: mcasp0_aclkx */
        //  0x194 () /* B13: mcasp0_fsx */
        //  0x198 () /* D12: mcasp_axr0 */
        //  0x1a8 () /* D13: mcasp_axr1 */
&mmc1 {
	vmmc-supply = <&vcc3v3>;
	bus-width = <4>;
	pinctrl-names = "default";
	pinctrl-0 = <&mmc1_pins>;
	cd-gpios = <&gpio0 6 GPIO_ACTIVE_HIGH>;
	status = "okay";
&uart0 {
	pinctrl-0 = <&uart0_pins>;
	status = "okay";
&spi0 {
    status = "okay";
    mrf24j40@0 {
        status = "okay";
        compatible = "microchip,mrf24j40ma";
        spi-max-frequency = <10000>;
        reg = <0>; /* Hopefully CS0n */
        mode = <0>;
        interrupt-parent = <&gpio0>;
        interrupts = <7 8>;
        pinctrl-0 = <&mrf24j40_pins_default>;
&mac {
&mmc3 {
	status = "okay";
	vmmc-supply = <&vdig1_reg>;
	bus-width = <4>;
	pinctrl-0 = <&wilink_pins_default>;
	ti,non-removable;
	ti,needs-special-hs-handling;
	cap-power-off-card;
	keep-power-in-suspend;
	dmas = <&edma 32
	        &edma 33>;
	dma-names = "tx", "rx";
	#address-cells = <1>;
	#size-cells = <0>;
	wlcore: wlcore@2 {
		compatible = "ti,wl1835";
		status = "okay";
		reg = <2>;
		interrupt-parent = <&gpio1>;
		interrupts = <25 IRQ_TYPE_EDGE_RISING>;
/* USB */
&cppi41dma {
	status = "okay";
&usb_ctrl_mod {
	status = "okay";
&usb {
	status = "okay";
&usb0 {
	dr_mode = "peripheral";
	status = "okay";
&usb0_phy {
	status = "okay";
&usb1 {
	dr_mode = "host";
	status = "okay";
&usb1_phy {
	status = "okay";
Kernel config:
# Automatically generated file; DO NOT EDIT.
# Linux/arm 4.4.0 Kernel Configuration
CONFIG_ARM=y
CONFIG_ARM_HAS_SG_CHAIN=y
CONFIG_MIGHT_HAVE_PCI=y
CONFIG_SYS_SUPPORTS_APM_EMULATION=y
CONFIG_HAVE_PROC_CPU=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_HAVE_LATENCYTOP_SUPPORT=y
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
CONFIG_RWSEM_XCHGADD_ALGORITHM=y
CONFIG_ARCH_HAS_BANDGAP=y
CONFIG_FIX_EARLYCON_MEM=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_NEED_DMA_MAP_STATE=y
CONFIG_ARCH_SUPPORTS_UPROBES=y
CONFIG_VECTORS_BASE=0xffff0000
CONFIG_ARM_PATCH_PHYS_VIRT=y
CONFIG_GENERIC_BUG=y
CONFIG_PGTABLE_LEVELS=2
CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
CONFIG_IRQ_WORK=y
CONFIG_BUILDTIME_EXTABLE_SORT=y
# General setup
CONFIG_BROKEN_ON_SMP=y
CONFIG_INIT_ENV_ARG_LIMIT=32
CONFIG_CROSS_COMPILE=""
# CONFIG_COMPILE_TEST is not set
CONFIG_LOCALVERSION="-myeden-griffin-amun"
CONFIG_LOCALVERSION_AUTO=y
CONFIG_HAVE_KERNEL_GZIP=y
CONFIG_HAVE_KERNEL_LZMA=y
CONFIG_HAVE_KERNEL_XZ=y
CONFIG_HAVE_KERNEL_LZO=y
CONFIG_HAVE_KERNEL_LZ4=y
# CONFIG_KERNEL_GZIP is not set
CONFIG_KERNEL_LZMA=y
# CONFIG_KERNEL_XZ is not set
# CONFIG_KERNEL_LZO is not set
# CONFIG_KERNEL_LZ4 is not set
CONFIG_DEFAULT_HOSTNAME="(none)"
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
CONFIG_SYSVIPC_SYSCTL=y
CONFIG_POSIX_MQUEUE=y
CONFIG_POSIX_MQUEUE_SYSCTL=y
CONFIG_CROSS_MEMORY_ATTACH=y
CONFIG_FHANDLE=y
CONFIG_USELIB=y
CONFIG_AUDIT=y
CONFIG_HAVE_ARCH_AUDITSYSCALL=y
# CONFIG_AUDITSYSCALL is not set
# IRQ subsystem
CONFIG_GENERIC_IRQ_PROBE=y
CONFIG_GENERIC_IRQ_SHOW=y
CONFIG_GENERIC_IRQ_SHOW_LEVEL=y
CONFIG_HARDIRQS_SW_RESEND=y
CONFIG_GENERIC_IRQ_CHIP=y
CONFIG_IRQ_DOMAIN=y
CONFIG_HANDLE_DOMAIN_IRQ=y
# CONFIG_IRQ_DOMAIN_DEBUG is not set
CONFIG_IRQ_FORCED_THREADING=y
CONFIG_SPARSE_IRQ=y
CONFIG_GENERIC_TIME_VSYSCALL=y
CONFIG_GENERIC_CLOCKEVENTS=y
# Timers subsystem
CONFIG_TICK_ONESHOT=y
CONFIG_NO_HZ_COMMON=y
# CONFIG_HZ_PERIODIC is not set
CONFIG_NO_HZ_IDLE=y
# CONFIG_NO_HZ_FULL is not set
CONFIG_NO_HZ=y
CONFIG_HIGH_RES_TIMERS=y
# CPU/Task time and stats accounting
CONFIG_TICK_CPU_ACCOUNTING=y
# CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set
# CONFIG_IRQ_TIME_ACCOUNTING is not set
CONFIG_BSD_PROCESS_ACCT=y
# CONFIG_BSD_PROCESS_ACCT_V3 is not set
# CONFIG_TASKSTATS is not set
# RCU Subsystem
CONFIG_TINY_RCU=y
# CONFIG_RCU_EXPERT is not set
CONFIG_SRCU=y
# CONFIG_TASKS_RCU is not set
# CONFIG_RCU_STALL_COMMON is not set
# CONFIG_TREE_RCU_TRACE is not set
# CONFIG_RCU_EXPEDITE_BOOT is not set
CONFIG_BUILD_BIN2C=y
CONFIG_IKCONFIG=y
CONFIG_IKCONFIG_PROC=y
CONFIG_LOG_BUF_SHIFT=16
CONFIG_GENERIC_SCHED_CLOCK=y
CONFIG_CGROUPS=y
# CONFIG_CGROUP_DEBUG is not set
CONFIG_CGROUP_FREEZER=y
# CONFIG_CGROUP_PIDS is not set
CONFIG_CGROUP_DEVICE=y
CONFIG_CPUSETS=y
CONFIG_PROC_PID_CPUSET=y
CONFIG_CGROUP_CPUACCT=y
CONFIG_PAGE_COUNTER=y
CONFIG_MEMCG=y
CONFIG_MEMCG_SWAP=y
CONFIG_MEMCG_SWAP_ENABLED=y
CONFIG_MEMCG_KMEM=y
CONFIG_CGROUP_PERF=y
CONFIG_CGROUP_SCHED=y
CONFIG_FAIR_GROUP_SCHED=y
# CONFIG_CFS_BANDWIDTH is not set
# CONFIG_RT_GROUP_SCHED is not set
CONFIG_BLK_CGROUP=y
# CONFIG_DEBUG_BLK_CGROUP is not set
CONFIG_CGROUP_WRITEBACK=y
# CONFIG_CHECKPOINT_RESTORE is not set
CONFIG_NAMESPACES=y
CONFIG_UTS_NS=y
CONFIG_IPC_NS=y
# CONFIG_USER_NS is not set
CONFIG_PID_NS=y
CONFIG_NET_NS=y
# CONFIG_SCHED_AUTOGROUP is not set
# CONFIG_SYSFS_DEPRECATED is not set
# CONFIG_RELAY is not set
CONFIG_BLK_DEV_INITRD=y
CONFIG_INITRAMFS_SOURCE=""
CONFIG_RD_GZIP=y
CONFIG_RD_BZIP2=y
CONFIG_RD_LZMA=y
CONFIG_RD_XZ=y
CONFIG_RD_LZO=y
CONFIG_RD_LZ4=y
# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
CONFIG_SYSCTL=y
CONFIG_ANON_INODES=y
CONFIG_HAVE_UID16=y
CONFIG_BPF=y
CONFIG_EXPERT=y
CONFIG_UID16=y
CONFIG_MULTIUSER=y
# CONFIG_SGETMASK_SYSCALL is not set
CONFIG_SYSFS_SYSCALL=y
# CONFIG_SYSCTL_SYSCALL is not set
CONFIG_KALLSYMS=y
CONFIG_KALLSYMS_ALL=y
CONFIG_PRINTK=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
# CONFIG_BPF_SYSCALL is not set
CONFIG_SHMEM=y
CONFIG_AIO=y
CONFIG_ADVISE_SYSCALLS=y
# CONFIG_USERFAULTFD is not set
CONFIG_MEMBARRIER=y
# CONFIG_EMBEDDED is not set
CONFIG_HAVE_PERF_EVENTS=y
CONFIG_PERF_USE_VMALLOC=y
# Kernel Performance Events And Counters
CONFIG_PERF_EVENTS=y
# CONFIG_DEBUG_PERF_USE_VMALLOC is not set
CONFIG_VM_EVENT_COUNTERS=y
CONFIG_COMPAT_BRK=y
CONFIG_SLAB=y
# CONFIG_SLUB is not set
# CONFIG_SLOB is not set
# CONFIG_SYSTEM_DATA_VERIFICATION is not set
CONFIG_PROFILING=y
CONFIG_KEXEC_CORE=y
CONFIG_OPROFILE=y
CONFIG_HAVE_OPROFILE=y
CONFIG_KPROBES=y
CONFIG_JUMP_LABEL=y
# CONFIG_STATIC_KEYS_SELFTEST is not set
CONFIG_OPTPROBES=y
# CONFIG_UPROBES is not set
# CONFIG_HAVE_64BIT_ALIGNED_ACCESS is not set
CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y
CONFIG_ARCH_USE_BUILTIN_BSWAP=y
CONFIG_KRETPROBES=y
CONFIG_HAVE_KPROBES=y
CONFIG_HAVE_KRETPROBES=y
CONFIG_HAVE_OPTPROBES=y
CONFIG_HAVE_ARCH_TRACEHOOK=y
CONFIG_HAVE_DMA_ATTRS=y
CONFIG_HAVE_DMA_CONTIGUOUS=y
CONFIG_GENERIC_SMP_IDLE_THREAD=y
CONFIG_GENERIC_IDLE_POLL_SETUP=y
CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
CONFIG_HAVE_CLK=y
CONFIG_HAVE_DMA_API_DEBUG=y
CONFIG_HAVE_HW_BREAKPOINT=y
CONFIG_HAVE_PERF_REGS=y
CONFIG_HAVE_PERF_USER_STACK_DUMP=y
CONFIG_HAVE_ARCH_JUMP_LABEL=y
CONFIG_ARCH_WANT_IPC_PARSE_VERSION=y
CONFIG_HAVE_ARCH_SECCOMP_FILTER=y
CONFIG_SECCOMP_FILTER=y
CONFIG_HAVE_CC_STACKPROTECTOR=y
# CONFIG_CC_STACKPROTECTOR is not set
CONFIG_CC_STACKPROTECTOR_NONE=y
# CONFIG_CC_STACKPROTECTOR_REGULAR is not set
# CONFIG_CC_STACKPROTECTOR_STRONG is not set
CONFIG_HAVE_CONTEXT_TRACKING=y
CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y
CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y
CONFIG_HAVE_MOD_ARCH_SPECIFIC=y
CONFIG_MODULES_USE_ELF_REL=y
CONFIG_ARCH_HAS_ELF_RANDOMIZE=y
CONFIG_CLONE_BACKWARDS=y
CONFIG_OLD_SIGSUSPEND3=y
CONFIG_OLD_SIGACTION=y
# GCOV-based kernel profiling
# CONFIG_GCOV_KERNEL is not set
CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y
CONFIG_HAVE_GENERIC_DMA_COHERENT=y
CONFIG_SLABINFO=y
CONFIG_RT_MUTEXES=y
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
CONFIG_MODULE_FORCE_LOAD=y
CONFIG_MODULE_UNLOAD=y
CONFIG_MODULE_FORCE_UNLOAD=y
CONFIG_MODVERSIONS=y
CONFIG_MODULE_SRCVERSION_ALL=y
# CONFIG_MODULE_SIG is not set
# CONFIG_MODULE_COMPRESS is not set
CONFIG_MODULES_TREE_LOOKUP=y
CONFIG_BLOCK=y
CONFIG_LBDAF=y
# CONFIG_BLK_DEV_BSG is not set
# CONFIG_BLK_DEV_BSGLIB is not set
# CONFIG_BLK_DEV_INTEGRITY is not set
# CONFIG_BLK_DEV_THROTTLING is not set
# CONFIG_BLK_CMDLINE_PARSER is not set
# Partition Types
CONFIG_PARTITION_ADVANCED=y
# CONFIG_ACORN_PARTITION is not set
# CONFIG_AIX_PARTITION is not set
# CONFIG_OSF_PARTITION is not set
# CONFIG_AMIGA_PARTITION is not set
# CONFIG_ATARI_PARTITION is not set
# CONFIG_MAC_PARTITION is not set
CONFIG_MSDOS_PARTITION=y
# CONFIG_BSD_DISKLABEL is not set
# CONFIG_MINIX_SUBPARTITION is not set
# CONFIG_SOLARIS_X86_PARTITION is not set
# CONFIG_UNIXWARE_DISKLABEL is not set
# CONFIG_LDM_PARTITION is not set
# CONFIG_SGI_PARTITION is not set
# CONFIG_ULTRIX_PARTITION is not set
# CONFIG_SUN_PARTITION is not set
# CONFIG_KARMA_PARTITION is not set
CONFIG_EFI_PARTITION=y
# CONFIG_SYSV68_PARTITION is not set
# CONFIG_CMDLINE_PARTITION is not set
# IO Schedulers
CONFIG_IOSCHED_NOOP=y
CONFIG_IOSCHED_DEADLINE=y
CONFIG_IOSCHED_CFQ=y
# CONFIG_CFQ_GROUP_IOSCHED is not set
# CONFIG_DEFAULT_DEADLINE is not set
CONFIG_DEFAULT_CFQ=y
# CONFIG_DEFAULT_NOOP is not set
CONFIG_DEFAULT_IOSCHED="cfq"
CONFIG_UNINLINE_SPIN_UNLOCK=y
CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y
CONFIG_FREEZER=y
# System Type
CONFIG_MMU=y
CONFIG_ARCH_MULTIPLATFORM=y
# CONFIG_ARCH_REALVIEW is not set
# CONFIG_ARCH_VERSATILE is not set
# CONFIG_ARCH_CLPS711X is not set
# CONFIG_ARCH_GEMINI is not set
# CONFIG_ARCH_EBSA110 is not set
# CONFIG_ARCH_EP93XX is not set
# CONFIG_ARCH_FOOTBRIDGE is not set
# CONFIG_ARCH_NETX is not set
# CONFIG_ARCH_IOP13XX is not set
# CONFIG_ARCH_IOP32X is not set
# CONFIG_ARCH_IOP33X is not set
# CONFIG_ARCH_IXP4XX is not set
# CONFIG_ARCH_DOVE is not set
# CONFIG_ARCH_MV78XX0 is not set
# CONFIG_ARCH_ORION5X is not set
# CONFIG_ARCH_MMP is not set
# CONFIG_ARCH_KS8695 is not set
# CONFIG_ARCH_W90X900 is not set
# CONFIG_ARCH_LPC32XX is not set
# CONFIG_ARCH_PXA is not set
# CONFIG_ARCH_RPC is not set
# CONFIG_ARCH_SA1100 is not set
# CONFIG_ARCH_S3C24XX is not set
# CONFIG_ARCH_S3C64XX is not set
# CONFIG_ARCH_DAVINCI is not set
# CONFIG_ARCH_OMAP1 is not set
# Multiple platform selection
# CPU Core family selection
CONFIG_ARCH_MULTI_V6=y
CONFIG_ARCH_MULTI_V7=y
CONFIG_ARCH_MULTI_V6_V7=y
# CONFIG_ARCH_MULTI_CPU_AUTO is not set
# CONFIG_ARCH_VIRT is not set
# CONFIG_ARCH_MVEBU is not set
# CONFIG_ARCH_ALPINE is not set
# CONFIG_ARCH_AT91 is not set
# CONFIG_ARCH_BCM is not set
# CONFIG_ARCH_BERLIN is not set
# CONFIG_ARCH_CNS3XXX is not set
# CONFIG_ARCH_DIGICOLOR is not set
# CONFIG_ARCH_HIGHBANK is not set
# CONFIG_ARCH_HISI is not set
# CONFIG_ARCH_INTEGRATOR is not set
# CONFIG_ARCH_KEYSTONE is not set
# CONFIG_ARCH_MESON is not set
# CONFIG_ARCH_MXC is not set
# CONFIG_ARCH_MEDIATEK is not set
CONFIG_ARCH_OMAP=y
# TI OMAP Common Features
# OMAP Feature Selections
CONFIG_OMAP_RESET_CLOCKS=y
CONFIG_OMAP_MUX=y
CONFIG_OMAP_MUX_DEBUG=y
CONFIG_OMAP_MUX_WARNINGS=y
CONFIG_OMAP_32K_TIMER=y
CONFIG_OMAP_DM_TIMER=y
CONFIG_OMAP_PM_NOOP=y
CONFIG_MACH_OMAP_GENERIC=y
# TI OMAP/AM/DM/DRA Family
# CONFIG_ARCH_OMAP2 is not set
# CONFIG_ARCH_OMAP3 is not set
# CONFIG_ARCH_OMAP4 is not set
# CONFIG_SOC_OMAP5 is not set
CONFIG_SOC_AM33XX=y
# CONFIG_SOC_AM43XX is not set
# CONFIG_SOC_DRA7XX is not set
CONFIG_ARCH_OMAP2PLUS=y
# TI OMAP2/3/4 Specific Features
CONFIG_ARCH_OMAP2PLUS_TYPICAL=y
CONFIG_SOC_HAS_OMAP2_SDRC=y
# OMAP Legacy Platform Data Board Type
# CONFIG_ARCH_PICOXCELL is not set
# CONFIG_ARCH_QCOM is not set
# CONFIG_ARCH_ROCKCHIP is not set
# CONFIG_ARCH_SOCFPGA is not set
# CONFIG_PLAT_SPEAR is not set
# CONFIG_ARCH_STI is not set
# CONFIG_ARCH_S5PV210 is not set
# CONFIG_ARCH_EXYNOS is not set
# CONFIG_ARCH_SHMOBILE_MULTI is not set
# CONFIG_ARCH_SUNXI is not set
# CONFIG_ARCH_SIRF is not set
# CONFIG_ARCH_TEGRA is not set
# CONFIG_ARCH_UNIPHIER is not set
# CONFIG_ARCH_U8500 is not set
# CONFIG_ARCH_VEXPRESS is not set
# CONFIG_ARCH_WM8750 is not set
# CONFIG_ARCH_WM8850 is not set
# CONFIG_ARCH_ZX is not set
# CONFIG_ARCH_ZYNQ is not set
# Processor Type
CONFIG_CPU_V6K=y
CONFIG_CPU_V7=y
CONFIG_CPU_32v6=y
CONFIG_CPU_32v6K=y
CONFIG_CPU_32v7=y
CONFIG_CPU_ABRT_EV6=y
CONFIG_CPU_ABRT_EV7=y
CONFIG_CPU_PABRT_V6=y
CONFIG_CPU_PABRT_V7=y
CONFIG_CPU_CACHE_V6=y
CONFIG_CPU_CACHE_V7=y
CONFIG_CPU_CACHE_VIPT=y
CONFIG_CPU_COPY_V6=y
CONFIG_CPU_TLB_V6=y
CONFIG_CPU_TLB_V7=y
CONFIG_CPU_HAS_ASID=y
CONFIG_CPU_CP15=y
CONFIG_CPU_CP15_MMU=y
# Processor Features
# CONFIG_ARCH_PHYS_ADDR_T_64BIT is not set
CONFIG_ARM_THUMB=y
CONFIG_ARM_THUMBEE=y
CONFIG_ARM_VIRT_EXT=y
CONFIG_SWP_EMULATE=y
# CONFIG_CPU_ICACHE_DISABLE is not set
# CONFIG_CPU_DCACHE_DISABLE is not set
# CONFIG_CPU_BPREDICT_DISABLE is not set
CONFIG_KUSER_HELPERS=y
CONFIG_VDSO=y
CONFIG_OUTER_CACHE=y
CONFIG_OUTER_CACHE_SYNC=y
CONFIG_MIGHT_HAVE_CACHE_L2X0=y
CONFIG_CACHE_L2X0=y
CONFIG_PL310_ERRATA_588369=y
CONFIG_PL310_ERRATA_727915=y
# CONFIG_PL310_ERRATA_753970 is not set
# CONFIG_PL310_ERRATA_769419 is not set
CONFIG_ARM_L1_CACHE_SHIFT_6=y
CONFIG_ARM_L1_CACHE_SHIFT=6
CONFIG_ARM_DMA_MEM_BUFFERABLE=y
CONFIG_ARM_HEAVY_MB=y
# CONFIG_ARM_KERNMEM_PERMS is not set
CONFIG_MULTI_IRQ_HANDLER=y
CONFIG_ARM_ERRATA_411920=y
CONFIG_ARM_ERRATA_430973=y
CONFIG_ARM_ERRATA_720789=y
CONFIG_ARM_ERRATA_754322=y
CONFIG_ARM_ERRATA_775420=y
# CONFIG_ARM_ERRATA_773022 is not set
# Bus support
# CONFIG_PCI is not set
# CONFIG_PCI_DOMAINS_GENERIC is not set
# CONFIG_PCI_SYSCALL is not set
# CONFIG_PCIEASPM_DEFAULT is not set
# CONFIG_PCIEASPM_POWERSAVE is not set
# CONFIG_PCIEASPM_PERFORMANCE is not set
# CONFIG_PCCARD is not set
# Kernel Features
CONFIG_HAVE_SMP=y
# CONFIG_SMP is not set
CONFIG_HAVE_ARM_ARCH_TIMER=y
CONFIG_VMSPLIT_3G=y
# CONFIG_VMSPLIT_3G_OPT is not set
# CONFIG_VMSPLIT_2G is not set
# CONFIG_VMSPLIT_1G is not set
CONFIG_PAGE_OFFSET=0xC0000000
# CONFIG_ARM_PSCI is not set
CONFIG_ARCH_NR_GPIO=0
CONFIG_PREEMPT_NONE=y
# CONFIG_PREEMPT_VOLUNTARY is not set
# CONFIG_PREEMPT is not set
CONFIG_HZ_FIXED=0
CONFIG_HZ_100=y
# CONFIG_HZ_200 is not set
# CONFIG_HZ_250 is not set
# CONFIG_HZ_300 is not set
# CONFIG_HZ_500 is not set
# CONFIG_HZ_1000 is not set
CONFIG_HZ=100
CONFIG_SCHED_HRTICK=y
CONFIG_AEABI=y
# CONFIG_OABI_COMPAT is not set
CONFIG_ARCH_HAS_HOLES_MEMORYMODEL=y
# CONFIG_ARCH_SPARSEMEM_DEFAULT is not set
# CONFIG_ARCH_SELECT_MEMORY_MODEL is not set
CONFIG_HAVE_ARCH_PFN_VALID=y
CONFIG_HIGHMEM=y
CONFIG_HIGHPTE=y
CONFIG_CPU_SW_DOMAIN_PAN=y
CONFIG_HW_PERF_EVENTS=y
CONFIG_ARCH_WANT_GENERAL_HUGETLB=y
# CONFIG_ARM_MODULE_PLTS is not set
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
CONFIG_HAVE_MEMBLOCK=y
CONFIG_NO_BOOTMEM=y
CONFIG_MEMORY_ISOLATION=y
# CONFIG_HAVE_BOOTMEM_INFO_NODE is not set
CONFIG_SPLIT_PTLOCK_CPUS=4
CONFIG_COMPACTION=y
CONFIG_MIGRATION=y
# CONFIG_PHYS_ADDR_T_64BIT is not set
CONFIG_ZONE_DMA_FLAG=0
CONFIG_BOUNCE=y
# CONFIG_KSM is not set
CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
CONFIG_NEED_PER_CPU_KM=y
# CONFIG_CLEANCACHE is not set
# CONFIG_FRONTSWAP is not set
CONFIG_CMA=y
# CONFIG_CMA_DEBUG is not set
# CONFIG_CMA_DEBUGFS is not set
CONFIG_CMA_AREAS=7
# CONFIG_ZPOOL is not set
# CONFIG_ZBUD is not set
# CONFIG_ZSMALLOC is not set
# CONFIG_IDLE_PAGE_TRACKING is not set
CONFIG_FORCE_MAX_ZONEORDER=12
CONFIG_ALIGNMENT_TRAP=y
# CONFIG_UACCESS_WITH_MEMCPY is not set
CONFIG_SECCOMP=y
CONFIG_SWIOTLB=y
CONFIG_IOMMU_HELPER=y
# CONFIG_XEN is not set
# Boot options
CONFIG_USE_OF=y
CONFIG_ATAGS=y
# CONFIG_DEPRECATED_PARAM_STRUCT is not set
CONFIG_ZBOOT_ROM_TEXT=0x0
CONFIG_ZBOOT_ROM_BSS=0x0
CONFIG_ARM_APPENDED_DTB=y
CONFIG_ARM_ATAG_DTB_COMPAT=y
CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_FROM_BOOTLOADER=y
# CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_EXTEND is not set
CONFIG_CMDLINE="root=/dev/mmcblk0p2 rootwait console=ttyO0,115200 earlyprintk=serial,ttyO0,115200"
CONFIG_CMDLINE_FROM_BOOTLOADER=y
# CONFIG_CMDLINE_EXTEND is not set
# CONFIG_CMDLINE_FORCE is not set
CONFIG_KEXEC=y
CONFIG_ATAGS_PROC=y
# CONFIG_CRASH_DUMP is not set
CONFIG_AUTO_ZRELADDR=y
# CPU Power Management
# CPU Frequency scaling
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_GOV_COMMON=y
CONFIG_CPU_FREQ_STAT=y
CONFIG_CPU_FREQ_STAT_DETAILS=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=y
CONFIG_CPU_FREQ_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_ONDEMAND=y
CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
# CPU frequency scaling drivers
# CONFIG_CPUFREQ_DT is not set
# CONFIG_ARM_KIRKWOOD_CPUFREQ is not set
CONFIG_ARM_OMAP2PLUS_CPUFREQ=y
# CONFIG_QORIQ_CPUFREQ is not set
# CPU Idle
CONFIG_CPU_IDLE=y
CONFIG_CPU_IDLE_GOV_LADDER=y
CONFIG_CPU_IDLE_GOV_MENU=y
# ARM CPU Idle Drivers
# CONFIG_ARM_CPUIDLE is not set
# CONFIG_ARCH_NEEDS_CPU_IDLE_COUPLED is not set
# Floating point emulation
# At least one emulation must be selected
CONFIG_VFP=y
CONFIG_VFPv3=y
CONFIG_NEON=y
# CONFIG_KERNEL_MODE_NEON is not set
# Userspace binary formats
CONFIG_BINFMT_ELF=y
CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y
CONFIG_BINFMT_SCRIPT=y
# CONFIG_HAVE_AOUT is not set
CONFIG_BINFMT_MISC=y
CONFIG_COREDUMP=y
# Power management options
# CONFIG_SUSPEND is not set
# CONFIG_HIBERNATION is not set
CONFIG_PM=y
CONFIG_PM_DEBUG=y
# CONFIG_PM_ADVANCED_DEBUG is not set
# CONFIG_APM_EMULATION is not set
CONFIG_PM_CLK=y
# CONFIG_WQ_POWER_EFFICIENT_DEFAULT is not set
CONFIG_CPU_PM=y
CONFIG_ARCH_SUSPEND_POSSIBLE=y
CONFIG_ARM_CPU_SUSPEND=y
CONFIG_ARCH_HIBERNATION_POSSIBLE=y
CONFIG_NET=y
# Networking options
CONFIG_PACKET=y
# CONFIG_PACKET_DIAG is not set
CONFIG_UNIX=y
# CONFIG_UNIX_DIAG is not set
CONFIG_XFRM=y
CONFIG_XFRM_ALGO=y
CONFIG_XFRM_USER=y
# CONFIG_XFRM_SUB_POLICY is not set
CONFIG_XFRM_MIGRATE=y
# CONFIG_XFRM_STATISTICS is not set
CONFIG_NET_KEY=y
CONFIG_NET_KEY_MIGRATE=y
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
# CONFIG_IP_ADVANCED_ROUTER is not set
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_IP_PNP_BOOTP=y
CONFIG_IP_PNP_RARP=y
# CONFIG_NET_IPIP is not set
# CONFIG_NET_IPGRE_DEMUX is not set
CONFIG_NET_IP_TUNNEL=y
# CONFIG_IP_MROUTE is not set
# CONFIG_SYN_COOKIES is not set
# CONFIG_NET_IPVTI is not set
# CONFIG_NET_UDP_TUNNEL is not set
# CONFIG_NET_FOU is not set
# CONFIG_NET_FOU_IP_TUNNELS is not set
# CONFIG_INET_AH is not set
# CONFIG_INET_ESP is not set
# CONFIG_INET_IPCOMP is not set
# CONFIG_INET_XFRM_TUNNEL is not set
CONFIG_INET_TUNNEL=y
CONFIG_INET_XFRM_MODE_TRANSPORT=y
CONFIG_INET_XFRM_MODE_TUNNEL=y
CONFIG_INET_XFRM_MODE_BEET=y
# CONFIG_INET_LRO is not set
CONFIG_INET_DIAG=y
CONFIG_INET_TCP_DIAG=y
# CONFIG_INET_UDP_DIAG is not set
# CONFIG_TCP_CONG_ADVANCED is not set
CONFIG_TCP_CONG_CUBIC=y
# CONFIG_DEFAULT_CUBIC is not set
# CONFIG_DEFAULT_RENO is not set
CONFIG_DEFAULT_TCP_CONG="cubic"
# CONFIG_TCP_MD5SIG is not set
CONFIG_IPV6=y
# CONFIG_IPV6_ROUTER_PREF is not set
# CONFIG_IPV6_OPTIMISTIC_DAD is not set
# CONFIG_INET6_AH is not set
# CONFIG_INET6_ESP is not set
# CONFIG_INET6_IPCOMP is not set
# CONFIG_IPV6_MIP6 is not set
# CONFIG_IPV6_ILA is not set
# CONFIG_INET6_XFRM_TUNNEL is not set
# CONFIG_INET6_TUNNEL is not set
CONFIG_INET6_XFRM_MODE_TRANSPORT=y
CONFIG_INET6_XFRM_MODE_TUNNEL=y
CONFIG_INET6_XFRM_MODE_BEET=y
# CONFIG_INET6_XFRM_MODE_ROUTEOPTIMIZATION is not set
# CONFIG_IPV6_VTI is not set
CONFIG_IPV6_SIT=y
# CONFIG_IPV6_SIT_6RD is not set
CONFIG_IPV6_NDISC_NODETYPE=y
# CONFIG_IPV6_TUNNEL is not set
# CONFIG_IPV6_GRE is not set
# CONFIG_IPV6_MULTIPLE_TABLES is not set
# CONFIG_IPV6_MROUTE is not set
# CONFIG_NETLABEL is not set
# CONFIG_NETWORK_SECMARK is not set
CONFIG_NET_PTP_CLASSIFY=y
# CONFIG_NETWORK_PHY_TIMESTAMPING is not set
# CONFIG_NETFILTER is not set
# CONFIG_IP_DCCP is not set
# CONFIG_IP_SCTP is not set
# CONFIG_SCTP_DEFAULT_COOKIE_HMAC_MD5 is not set
# CONFIG_SCTP_DEFAULT_COOKIE_HMAC_SHA1 is not set
# CONFIG_SCTP_DEFAULT_COOKIE_HMAC_NONE is not set
# CONFIG_RDS is not set
# CONFIG_TIPC is not set
# CONFIG_ATM is not set
# CONFIG_L2TP is not set
# CONFIG_BRIDGE is not set
CONFIG_HAVE_NET_DSA=y
# CONFIG_VLAN_8021Q is not set
# CONFIG_DECNET is not set
# CONFIG_LLC2 is not set
# CONFIG_IPX is not set
# CONFIG_ATALK is not set
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
# CONFIG_PHONET is not set
CONFIG_6LOWPAN=y
CONFIG_6LOWPAN_NHC=y
CONFIG_6LOWPAN_NHC_DEST=y
CONFIG_6LOWPAN_NHC_FRAGMENT=y
CONFIG_6LOWPAN_NHC_HOP=y
CONFIG_6LOWPAN_NHC_IPV6=y
CONFIG_6LOWPAN_NHC_MOBILITY=y
CONFIG_6LOWPAN_NHC_ROUTING=y
CONFIG_6LOWPAN_NHC_UDP=y
CONFIG_IEEE802154=y
CONFIG_IEEE802154_NL802154_EXPERIMENTAL=y
CONFIG_IEEE802154_SOCKET=y
# CONFIG_IEEE802154_6LOWPAN is not set
CONFIG_MAC802154=y
# CONFIG_NET_SCHED is not set
# CONFIG_DCB is not set
CONFIG_DNS_RESOLVER=y
# CONFIG_BATMAN_ADV is not set
# CONFIG_OPENVSWITCH is not set
# CONFIG_VSOCKETS is not set
# CONFIG_NETLINK_MMAP is not set
# CONFIG_NETLINK_DIAG is not set
# CONFIG_MPLS is not set
# CONFIG_HSR is not set
# CONFIG_NET_SWITCHDEV is not set
# CONFIG_NET_L3_MASTER_DEV is not set
# CONFIG_CGROUP_NET_PRIO is not set
# CONFIG_CGROUP_NET_CLASSID is not set
CONFIG_NET_RX_BUSY_POLL=y
CONFIG_BQL=y
# CONFIG_BPF_JIT is not set
# Network testing
# CONFIG_NET_PKTGEN is not set
# CONFIG_NET_TCPPROBE is not set
# CONFIG_HAMRADIO is not set
# CONFIG_CAN is not set
# CONFIG_IRDA is not set
CONFIG_BT=y
CONFIG_BT_BREDR=y
# CONFIG_BT_RFCOMM is not set
# CONFIG_BT_BNEP is not set
# CONFIG_BT_HIDP is not set
CONFIG_BT_HS=y
CONFIG_BT_LE=y
# CONFIG_BT_6LOWPAN is not set
# CONFIG_BT_SELFTEST is not set
CONFIG_BT_DEBUGFS=y
# Bluetooth device drivers
# CONFIG_BT_HCIBTUSB is not set
# CONFIG_BT_HCIBTSDIO is not set
CONFIG_BT_HCIUART=y
CONFIG_BT_HCIUART_H4=y
CONFIG_BT_HCIUART_BCSP=y
# CONFIG_BT_HCIUART_ATH3K is not set
CONFIG_BT_HCIUART_LL=y
# CONFIG_BT_HCIUART_3WIRE is not set
# CONFIG_BT_HCIUART_INTEL is not set
# CONFIG_BT_HCIUART_BCM is not set
# CONFIG_BT_HCIUART_QCA is not set
# CONFIG_BT_HCIBCM203X is not set
# CONFIG_BT_HCIBPA10X is not set
# CONFIG_BT_HCIBFUSB is not set
# CONFIG_BT_HCIVHCI is not set
# CONFIG_BT_MRVL is not set
# CONFIG_BT_WILINK is not set
# CONFIG_AF_RXRPC is not set
CONFIG_WIRELESS=y
CONFIG_WIRELESS_EXT=y
CONFIG_WEXT_CORE=y
CONFIG_WEXT_PROC=y
CONFIG_WEXT_SPY=y
CONFIG_CFG80211=y
CONFIG_NL80211_TESTMODE=y
# CONFIG_CFG80211_DEVELOPER_WARNINGS is not set
# CONFIG_CFG80211_REG_DEBUG is not set
# CONFIG_CFG80211_CERTIFICATION_ONUS is not set
CONFIG_CFG80211_DEFAULT_PS=y
# CONFIG_CFG80211_DEBUGFS is not set
# CONFIG_CFG80211_INTERNAL_REGDB is not set
CONFIG_CFG80211_CRDA_SUPPORT=y
# CONFIG_CFG80211_WEXT is not set
CONFIG_LIB80211=y
# CONFIG_LIB80211_DEBUG is not set
CONFIG_MAC80211=y
CONFIG_MAC80211_HAS_RC=y
CONFIG_MAC80211_RC_MINSTREL=y
CONFIG_MAC80211_RC_MINSTREL_HT=y
# CONFIG_MAC80211_RC_MINSTREL_VHT is not set
CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y
CONFIG_MAC80211_RC_DEFAULT="minstrel_ht"
# CONFIG_MAC80211_MESH is not set
# CONFIG_MAC80211_LEDS is not set
# CONFIG_MAC80211_DEBUGFS is not set
# CONFIG_MAC80211_MESSAGE_TRACING is not set
# CONFIG_MAC80211_DEBUG_MENU is not set
CONFIG_MAC80211_STA_HASH_MAX_SIZE=0
# CONFIG_WIMAX is not set
CONFIG_RFKILL=y
CONFIG_RFKILL_LEDS=y
# CONFIG_RFKILL_INPUT is not set
# CONFIG_RFKILL_REGULATOR is not set
# CONFIG_RFKILL_GPIO is not set
# CONFIG_NET_9P is not set
# CONFIG_CAIF is not set
# CONFIG_CEPH_LIB is not set
# CONFIG_NFC is not set
# CONFIG_LWTUNNEL is not set
CONFIG_HAVE_BPF_JIT=y
# Device Drivers
# Generic Driver Options
CONFIG_UEVENT_HELPER=y
CONFIG_UEVENT_HELPER_PATH=""
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
CONFIG_FW_LOADER=y
CONFIG_FIRMWARE_IN_KERNEL=y
CONFIG_EXTRA_FIRMWARE=""
# CONFIG_FW_LOADER_USER_HELPER_FALLBACK is not set
CONFIG_WANT_DEV_COREDUMP=y
CONFIG_ALLOW_DEV_COREDUMP=y
CONFIG_DEV_COREDUMP=y
# CONFIG_DEBUG_DRIVER is not set
# CONFIG_DEBUG_DEVRES is not set
# CONFIG_SYS_HYPERVISOR is not set
# CONFIG_GENERIC_CPU_DEVICES is not set
CONFIG_SOC_BUS=y
CONFIG_REGMAP=y
CONFIG_REGMAP_I2C=y
CONFIG_REGMAP_SPI=y
CONFIG_REGMAP_MMIO=y
CONFIG_REGMAP_IRQ=y
# CONFIG_DMA_SHARED_BUFFER is not set
CONFIG_DMA_CMA=y
# Default contiguous memory area size:
CONFIG_CMA_SIZE_MBYTES=24
CONFIG_CMA_SIZE_SEL_MBYTES=y
# CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set
# CONFIG_CMA_SIZE_SEL_MIN is not set
# CONFIG_CMA_SIZE_SEL_MAX is not set
CONFIG_CMA_ALIGNMENT=8
# Bus devices
# CONFIG_ARM_CCI400_PMU is not set
# CONFIG_ARM_CCI500_PMU is not set
# CONFIG_ARM_CCN is not set
# CONFIG_BRCMSTB_GISB_ARB is not set
CONFIG_OMAP_INTERCONNECT=y
CONFIG_OMAP_OCP2SCP=y
# CONFIG_VEXPRESS_CONFIG is not set
CONFIG_CONNECTOR=y
CONFIG_PROC_EVENTS=y
CONFIG_MTD=y
# CONFIG_MTD_TESTS is not set
# CONFIG_MTD_REDBOOT_PARTS is not set
CONFIG_MTD_CMDLINE_PARTS=y
# CONFIG_MTD_AFS_PARTS is not set
CONFIG_MTD_OF_PARTS=y
# CONFIG_MTD_AR7_PARTS is not set
# User Modules And Translation Layers
CONFIG_MTD_BLKDEVS=y
CONFIG_MTD_BLOCK=y
# CONFIG_FTL is not set
# CONFIG_NFTL is not set
# CONFIG_INFTL is not set
# CONFIG_RFD_FTL is not set
# CONFIG_SSFDC is not set
# CONFIG_SM_FTL is not set
CONFIG_MTD_OOPS=y
# CONFIG_MTD_SWAP is not set
# CONFIG_MTD_PARTITIONED_MASTER is not set
# RAM/ROM/Flash chip drivers
CONFIG_MTD_CFI=m
# CONFIG_MTD_JEDECPROBE is not set
CONFIG_MTD_GEN_PROBE=m
CONFIG_MTD_CFI_ADV_OPTIONS=y
CONFIG_MTD_CFI_NOSWAP=y
# CONFIG_MTD_CFI_BE_BYTE_SWAP is not set
# CONFIG_MTD_CFI_LE_BYTE_SWAP is not set
# CONFIG_MTD_CFI_GEOMETRY is not set
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
# CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
# CONFIG_MTD_CFI_I4 is not set
# CONFIG_MTD_CFI_I8 is not set
# CONFIG_MTD_OTP is not set
CONFIG_MTD_CFI_INTELEXT=m
# CONFIG_MTD_CFI_AMDSTD is not set
# CONFIG_MTD_CFI_STAA is not set
CONFIG_MTD_CFI_UTIL=m
# CONFIG_MTD_RAM is not set
# CONFIG_MTD_ROM is not set
# CONFIG_MTD_ABSENT is not set
# Mapping drivers for chip access
# CONFIG_MTD_COMPLEX_MAPPINGS is not set
CONFIG_MTD_PHYSMAP=m
# CONFIG_MTD_PHYSMAP_COMPAT is not set
# CONFIG_MTD_PHYSMAP_OF is not set
# CONFIG_MTD_PLATRAM is not set
# Self-contained MTD device drivers
# CONFIG_MTD_DATAFLASH is not set
# CONFIG_MTD_M25P80 is not set
# CONFIG_MTD_SST25L is not set
# CONFIG_MTD_SLRAM is not set
# CONFIG_MTD_PHRAM is not set
# CONFIG_MTD_MTDRAM is not set
# CONFIG_MTD_BLOCK2MTD is not set
# Disk-On-Chip Device Drivers
# CONFIG_MTD_DOCG3 is not set
CONFIG_MTD_NAND_ECC=y
# CONFIG_MTD_NAND_ECC_SMC is not set
CONFIG_MTD_NAND=y
CONFIG_MTD_NAND_BCH=y
CONFIG_MTD_NAND_ECC_BCH=y
# CONFIG_MTD_SM_COMMON is not set
# CONFIG_MTD_NAND_DENALI_DT is not set
# CONFIG_MTD_NAND_GPIO is not set
CONFIG_MTD_NAND_OMAP2=y
CONFIG_MTD_NAND_OMAP_BCH=y
CONFIG_MTD_NAND_OMAP_BCH_BUILD=y
CONFIG_MTD_NAND_IDS=y
# CONFIG_MTD_NAND_DISKONCHIP is not set
# CONFIG_MTD_NAND_DOCG4 is not set
# CONFIG_MTD_NAND_NANDSIM is not set
# CONFIG_MTD_NAND_BRCMNAND is not set
# CONFIG_MTD_NAND_PLATFORM is not set
# CONFIG_MTD_NAND_HISI504 is not set
CONFIG_MTD_ONENAND=y
CONFIG_MTD_ONENAND_VERIFY_WRITE=y
# CONFIG_MTD_ONENAND_GENERIC is not set
# CONFIG_MTD_ONENAND_OTP is not set
# CONFIG_MTD_ONENAND_2X_PROGRAM is not set
# LPDDR & LPDDR2 PCM memory drivers
# CONFIG_MTD_LPDDR is not set
# CONFIG_MTD_LPDDR2_NVM is not set
CONFIG_MTD_SPI_NOR=y
CONFIG_MTD_SPI_NOR_USE_4K_SECTORS=y
CONFIG_MTD_UBI=y
CONFIG_MTD_UBI_WL_THRESHOLD=4096
CONFIG_MTD_UBI_BEB_LIMIT=20
# CONFIG_MTD_UBI_FASTMAP is not set
# CONFIG_MTD_UBI_GLUEBI is not set
# CONFIG_MTD_UBI_BLOCK is not set
CONFIG_DTC=y
CONFIG_OF=y
# CONFIG_OF_UNITTEST is not set
CONFIG_OF_FLATTREE=y
CONFIG_OF_EARLY_FLATTREE=y
CONFIG_OF_DYNAMIC=y
CONFIG_OF_ADDRESS=y
CONFIG_OF_IRQ=y
CONFIG_OF_NET=y
CONFIG_OF_MDIO=y
CONFIG_OF_MTD=y
CONFIG_OF_RESERVED_MEM=y
CONFIG_OF_RESOLVE=y
CONFIG_OF_OVERLAY=y
CONFIG_ARCH_MIGHT_HAVE_PC_PARPORT=y
# CONFIG_PARPORT is not set
CONFIG_BLK_DEV=y
# CONFIG_BLK_DEV_NULL_BLK is not set
# CONFIG_BLK_DEV_COW_COMMON is not set
CONFIG_BLK_DEV_LOOP=y
CONFIG_BLK_DEV_LOOP_MIN_COUNT=8
# CONFIG_BLK_DEV_CRYPTOLOOP is not set
# CONFIG_BLK_DEV_DRBD is not set
# CONFIG_BLK_DEV_NBD is not set
CONFIG_BLK_DEV_RAM=y
CONFIG_BLK_DEV_RAM_COUNT=16
CONFIG_BLK_DEV_RAM_SIZE=4096
# CONFIG_CDROM_PKTCDVD is not set
# CONFIG_ATA_OVER_ETH is not set
# CONFIG_MG_DISK is not set
# CONFIG_BLK_DEV_RBD is not set
# Misc devices
# CONFIG_SENSORS_LIS3LV02D is not set
# CONFIG_AD525X_DPOT is not set
# CONFIG_DUMMY_IRQ is not set
# CONFIG_ICS932S401 is not set
# CONFIG_ENCLOSURE_SERVICES is not set
# CONFIG_APDS9802ALS is not set
# CONFIG_ISL29003 is not set
# CONFIG_ISL29020 is not set
# CONFIG_SENSORS_TSL2550 is not set
# CONFIG_SENSORS_BH1780 is not set
# CONFIG_SENSORS_BH1770 is not set
# CONFIG_SENSORS_APDS990X is not set
# CONFIG_HMC6352 is not set
# CONFIG_DS1682 is not set
# CONFIG_TI_DAC7512 is not set
# CONFIG_BMP085_I2C is not set
# CONFIG_BMP085_SPI is not set
# CONFIG_USB_SWITCH_FSA9480 is not set
# CONFIG_LATTICE_ECP3_CONFIG is not set
CONFIG_SRAM=y
# CONFIG_C2PORT is not set
# EEPROM support
CONFIG_EEPROM_AT24=y
# CONFIG_EEPROM_AT25 is not set
# CONFIG_EEPROM_LEGACY is not set
# CONFIG_EEPROM_MAX6875 is not set
CONFIG_EEPROM_93CX6=y
# CONFIG_EEPROM_93XX46 is not set
# Texas Instruments shared transport line discipline
CONFIG_TI_ST=y
# CONFIG_SENSORS_LIS3_SPI is not set
# CONFIG_SENSORS_LIS3_I2C is not set
# Altera FPGA firmware download module
# CONFIG_ALTERA_STAPL is not set
# Intel MIC Bus Driver
# SCIF Bus Driver
# Intel MIC Host Driver
# Intel MIC Card Driver
# SCIF Driver
# Intel MIC Coprocessor State Management (COSM) Drivers
# CONFIG_ECHO is not set
# CONFIG_CXL_BASE is not set
# CONFIG_CXL_KERNEL_API is not set
# CONFIG_CXL_EEH is not set
# SCSI device support
CONFIG_SCSI_MOD=y
# CONFIG_RAID_ATTRS is not set
CONFIG_SCSI=y
CONFIG_SCSI_DMA=y
# CONFIG_SCSI_NETLINK is not set
# CONFIG_SCSI_MQ_DEFAULT is not set
CONFIG_SCSI_PROC_FS=y
# SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=y
# CONFIG_CHR_DEV_ST is not set
# CONFIG_CHR_DEV_OSST is not set
# CONFIG_BLK_DEV_SR is not set
# CONFIG_CHR_DEV_SG is not set
# CONFIG_CHR_DEV_SCH is not set
# CONFIG_SCSI_CONSTANTS is not set
# CONFIG_SCSI_LOGGING is not set
CONFIG_SCSI_SCAN_ASYNC=y
# SCSI Transports
# CONFIG_SCSI_SPI_ATTRS is not set
# CONFIG_SCSI_FC_ATTRS is not set
# CONFIG_SCSI_ISCSI_ATTRS is not set
# CONFIG_SCSI_SAS_ATTRS is not set
# CONFIG_SCSI_SAS_LIBSAS is not set
# CONFIG_SCSI_SRP_ATTRS is not set
CONFIG_SCSI_LOWLEVEL=y
# CONFIG_ISCSI_TCP is not set
# CONFIG_ISCSI_BOOT_SYSFS is not set
# CONFIG_SCSI_UFSHCD is not set
# CONFIG_SCSI_DEBUG is not set
# CONFIG_SCSI_DH is not set
# CONFIG_SCSI_OSD_INITIATOR is not set
CONFIG_ATA=y
# CONFIG_ATA_NONSTANDARD is not set
CONFIG_ATA_VERBOSE_ERROR=y
CONFIG_SATA_PMP=y
# Controllers with non-SFF native interface
CONFIG_SATA_AHCI_PLATFORM=y
# CONFIG_AHCI_CEVA is not set
# CONFIG_AHCI_QORIQ is not set
CONFIG_ATA_SFF=y
# SFF controllers with custom DMA interface
CONFIG_ATA_BMDMA=y
# SATA SFF controllers with BMDMA
# PATA SFF controllers with BMDMA
# PIO-only SFF controllers
# CONFIG_PATA_PLATFORM is not set
# Generic fallback / legacy drivers
# CONFIG_MD is not set
# CONFIG_TARGET_CORE is not set
CONFIG_NETDEVICES=y
CONFIG_MII=y
CONFIG_NET_CORE=y
# CONFIG_BONDING is not set
# CONFIG_DUMMY is not set
# CONFIG_EQUALIZER is not set
# CONFIG_NET_TEAM is not set
# CONFIG_MACVLAN is not set
# CONFIG_IPVLAN is not set
# CONFIG_VXLAN is not set
# CONFIG_NETCONSOLE is not set
# CONFIG_NETPOLL is not set
# CONFIG_NET_POLL_CONTROLLER is not set
# CONFIG_TUN is not set
# CONFIG_TUN_VNET_CROSS_LE is not set
# CONFIG_VETH is not set
# CONFIG_NLMON is not set
# CAIF transport drivers
# Distributed Switch Architecture drivers
# CONFIG_NET_DSA_MV88E6XXX is not set
# CONFIG_NET_DSA_MV88E6XXX_NEED_PPU is not set
CONFIG_ETHERNET=y
# CONFIG_ALTERA_TSE is not set
# CONFIG_NET_VENDOR_ARC is not set
# CONFIG_NET_VENDOR_AURORA is not set
# CONFIG_NET_CADENCE is not set
# CONFIG_NET_VENDOR_BROADCOM is not set
CONFIG_NET_VENDOR_CIRRUS=y
# CONFIG_CS89x0 is not set
CONFIG_DM9000=y
CONFIG_DM9000_FORCE_SIMPLE_PHY_POLL=y
# CONFIG_DNET is not set
CONFIG_NET_VENDOR_EZCHIP=y
# CONFIG_EZCHIP_NPS_MANAGEMENT_ENET is not set
CONFIG_NET_VENDOR_FARADAY=y
# CONFIG_FTMAC100 is not set
# CONFIG_FTGMAC100 is not set
CONFIG_NET_VENDOR_HISILICON=y
# CONFIG_HIX5HD2_GMAC is not set
# CONFIG_HIP04_ETH is not set
# CONFIG_HNS is not set
# CONFIG_HNS_DSAF is not set
# CONFIG_HNS_ENET is not set
# CONFIG_NET_VENDOR_INTEL is not set
# CONFIG_NET_VENDOR_MARVELL is not set
CONFIG_NET_VENDOR_MICREL=y
# CONFIG_KS8842 is not set
# CONFIG_KS8851 is not set
CONFIG_KS8851_MLL=y
CONFIG_NET_VENDOR_MICROCHIP=y
# CONFIG_ENC28J60 is not set
# CONFIG_ENCX24J600 is not set
# CONFIG_NET_VENDOR_NATSEMI is not set
# CONFIG_ETHOC is not set
# CONFIG_NET_VENDOR_QUALCOMM is not set
CONFIG_NET_VENDOR_RENESAS=y
CONFIG_NET_VENDOR_ROCKER=y
# CONFIG_NET_VENDOR_SAMSUNG is not set
# CONFIG_NET_VENDOR_SEEQ is not set
CONFIG_NET_VENDOR_SMSC=y
CONFIG_SMC91X=y
# CONFIG_SMC911X is not set
CONFIG_SMSC911X=y
# CONFIG_SMSC911X_ARCH_HOOKS is not set
# CONFIG_NET_VENDOR_STMICRO is not set
CONFIG_NET_VENDOR_SYNOPSYS=y
# CONFIG_SYNOPSYS_DWC_ETH_QOS is not set
CONFIG_NET_VENDOR_TI=y
CONFIG_TI_DAVINCI_MDIO=y
CONFIG_TI_DAVINCI_CPDMA=y
CONFIG_TI_CPSW_PHY_SEL=y
CONFIG_TI_CPSW_ALE=y
CONFIG_TI_CPSW=y
CONFIG_TI_CPTS=y
# CONFIG_NET_VENDOR_VIA is not set
# CONFIG_NET_VENDOR_WIZNET is not set
CONFIG_PHYLIB=y
# MII PHY device drivers
# CONFIG_AQUANTIA_PHY is not set
CONFIG_AT803X_PHY=y
# CONFIG_AMD_PHY is not set
# CONFIG_MARVELL_PHY is not set
# CONFIG_DAVICOM_PHY is not set
# CONFIG_QSEMI_PHY is not set
# CONFIG_LXT_PHY is not set
# CONFIG_CICADA_PHY is not set
# CONFIG_VITESSE_PHY is not set
# CONFIG_TERANETICS_PHY is not set
CONFIG_SMSC_PHY=y
# CONFIG_BROADCOM_PHY is not set
# CONFIG_BCM7XXX_PHY is not set
# CONFIG_BCM87XX_PHY is not set
# CONFIG_ICPLUS_PHY is not set
# CONFIG_REALTEK_PHY is not set
# CONFIG_NATIONAL_PHY is not set
# CONFIG_STE10XP is not set
# CONFIG_LSI_ET1011C_PHY is not set
CONFIG_MICREL_PHY=y
# CONFIG_DP83848_PHY is not set
# CONFIG_DP83867_PHY is not set
# CONFIG_MICROCHIP_PHY is not set
# CONFIG_FIXED_PHY is not set
# CONFIG_MDIO_BITBANG is not set
# CONFIG_MDIO_BUS_MUX_GPIO is not set
# CONFIG_MDIO_BUS_MUX_MMIOREG is not set
# CONFIG_MDIO_BCM_UNIMAC is not set
# CONFIG_MICREL_KS8995MA is not set
# CONFIG_PPP is not set
# CONFIG_SLIP is not set
CONFIG_USB_NET_DRIVERS=y
# CONFIG_USB_CATC is not set
# CONFIG_USB_KAWETH is not set
# CONFIG_USB_PEGASUS is not set
# CONFIG_USB_RTL8150 is not set
# CONFIG_USB_RTL8152 is not set
# CONFIG_USB_LAN78XX is not set
# CONFIG_USB_USBNET is not set
# CONFIG_USB_HSO is not set
# CONFIG_USB_IPHETH is not set
CONFIG_WLAN=y
# CONFIG_LIBERTAS_THINFIRM is not set
# CONFIG_AT76C50X_USB is not set
# CONFIG_USB_ZD1201 is not set
# CONFIG_USB_NET_RNDIS_WLAN is not set
# CONFIG_RTL8187 is not set
# CONFIG_MAC80211_HWSIM is not set
# CONFIG_ATH_CARDS is not set
# CONFIG_B43 is not set
# CONFIG_B43_BUSES_BCMA_AND_SSB is not set
# CONFIG_B43_BUSES_BCMA is not set
# CONFIG_B43_BUSES_SSB is not set
# CONFIG_B43LEGACY is not set
# CONFIG_B43LEGACY_DMA_AND_PIO_MODE is not set
# CONFIG_B43LEGACY_DMA_MODE is not set
# CONFIG_B43LEGACY_PIO_MODE is not set
# CONFIG_BRCMSMAC is not set
# CONFIG_BRCMFMAC is not set
# CONFIG_HOSTAP is not set
CONFIG_LIBERTAS=y
CONFIG_LIBERTAS_USB=y
CONFIG_LIBERTAS_SDIO=y
# CONFIG_LIBERTAS_SPI is not set
CONFIG_LIBERTAS_DEBUG=y
# CONFIG_LIBERTAS_MESH is not set
# CONFIG_P54_COMMON is not set
# CONFIG_RT2X00 is not set
# CONFIG_WL_MEDIATEK is not set
CONFIG_RTL_CARDS=y
# CONFIG_RTL8192CU is not set
# CONFIG_RTL8XXXU is not set
CONFIG_WL_TI=y
CONFIG_WL1251=y
CONFIG_WL1251_SPI=y
CONFIG_WL1251_SDIO=y
CONFIG_WL12XX=y
CONFIG_WL18XX=y
CONFIG_WLCORE=y
# CONFIG_WLCORE_SPI is not set
CONFIG_WLCORE_SDIO=y
CONFIG_WILINK_PLATFORM_DATA=y
# CONFIG_ZD1211RW is not set
CONFIG_MWIFIEX=y
CONFIG_MWIFIEX_SDIO=y
CONFIG_MWIFIEX_USB=y
# CONFIG_CW1200 is not set
# CONFIG_RSI_91X is not set
# Enable WiMAX (Networking options) to see the WiMAX drivers
# CONFIG_WAN is not set
CONFIG_IEEE802154_DRIVERS=y
CONFIG_IEEE802154_FAKELB=n
# CONFIG_IEEE802154_AT86RF230 is not set
CONFIG_IEEE802154_MRF24J40=y
# CONFIG_IEEE802154_CC2520 is not set
# CONFIG_IEEE802154_ATUSB is not set
# CONFIG_ISDN is not set
# CONFIG_NVM is not set
# Input device support
CONFIG_INPUT=y
CONFIG_INPUT_LEDS=y
# CONFIG_INPUT_FF_MEMLESS is not set
# CONFIG_INPUT_POLLDEV is not set
# CONFIG_INPUT_SPARSEKMAP is not set
CONFIG_INPUT_MATRIXKMAP=y
# Userland interfaces
CONFIG_INPUT_MOUSEDEV=y
CONFIG_INPUT_MOUSEDEV_PSAUX=y
CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
# CONFIG_INPUT_JOYDEV is not set
CONFIG_INPUT_EVDEV=y
# CONFIG_INPUT_EVBUG is not set
# Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
# CONFIG_KEYBOARD_ADP5588 is not set
# CONFIG_KEYBOARD_ADP5589 is not set
CONFIG_KEYBOARD_ATKBD=y
# CONFIG_KEYBOARD_QT1070 is not set
# CONFIG_KEYBOARD_QT2160 is not set
# CONFIG_KEYBOARD_LKKBD is not set
CONFIG_KEYBOARD_GPIO=y
# CONFIG_KEYBOARD_GPIO_POLLED is not set
# CONFIG_KEYBOARD_TCA6416 is not set
# CONFIG_KEYBOARD_TCA8418 is not set
CONFIG_KEYBOARD_MATRIX=y
# CONFIG_KEYBOARD_LM8323 is not set
# CONFIG_KEYBOARD_LM8333 is not set
# CONFIG_KEYBOARD_MAX7359 is not set
# CONFIG_KEYBOARD_MCS is not set
# CONFIG_KEYBOARD_MPR121 is not set
# CONFIG_KEYBOARD_NEWTON is not set
# CONFIG_KEYBOARD_OPENCORES is not set
# CONFIG_KEYBOARD_SAMSUNG is not set
# CONFIG_KEYBOARD_STOWAWAY is not set
# CONFIG_KEYBOARD_SUNKBD is not set
CONFIG_KEYBOARD_OMAP4=y
CONFIG_KEYBOARD_TWL4030=y
# CONFIG_KEYBOARD_XTKBD is not set
# CONFIG_KEYBOARD_CAP11XX is not set
# CONFIG_KEYBOARD_BCM is not set
# CONFIG_INPUT_MOUSE is not set
# CONFIG_INPUT_JOYSTICK is not set
# CONFIG_INPUT_TABLET is not set
# CONFIG_INPUT_TOUCHSCREEN is not set
CONFIG_INPUT_MISC=y
# CONFIG_INPUT_AD714X is not set
# CONFIG_INPUT_BMA150 is not set
# CONFIG_INPUT_E3X0_BUTTON is not set
# CONFIG_INPUT_MMA8450 is not set
# CONFIG_INPUT_MPU3050 is not set
# CONFIG_INPUT_GP2A is not set
# CONFIG_INPUT_GPIO_BEEPER is not set
# CONFIG_INPUT_GPIO_TILT_POLLED is not set
# CONFIG_INPUT_ATI_REMOTE2 is not set
# CONFIG_INPUT_KEYSPAN_REMOTE is not set
# CONFIG_INPUT_KXTJ9 is not set
# CONFIG_INPUT_POWERMATE is not set
# CONFIG_INPUT_YEALINK is not set
# CONFIG_INPUT_CM109 is not set
# CONFIG_INPUT_REGULATOR_HAPTIC is not set
# CONFIG_INPUT_TPS65218_PWRBUTTON is not set
CONFIG_INPUT_TWL4030_PWRBUTTON=y
# CONFIG_INPUT_TWL4030_VIBRA is not set
# CONFIG_INPUT_TWL6040_VIBRA is not set
CONFIG_INPUT_UINPUT=y
# CONFIG_INPUT_PALMAS_PWRBUTTON is not set
# CONFIG_INPUT_PCF8574 is not set
CONFIG_INPUT_PWM_BEEPER=y
# CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set
# CONFIG_INPUT_ADXL34X is not set
# CONFIG_INPUT_IMS_PCU is not set
# CONFIG_INPUT_CMA3000 is not set
# CONFIG_INPUT_SOC_BUTTON_ARRAY is not set
# CONFIG_INPUT_DRV260X_HAPTICS is not set
# CONFIG_INPUT_DRV2665_HAPTICS is not set
# CONFIG_INPUT_DRV2667_HAPTICS is not set
# Hardware I/O ports
CONFIG_SERIO=y
CONFIG_SERIO_SERPORT=y
CONFIG_SERIO_LIBPS2=y
# CONFIG_SERIO_RAW is not set
# CONFIG_SERIO_ALTERA_PS2 is not set
# CONFIG_SERIO_PS2MULT is not set
# CONFIG_SERIO_ARC_PS2 is not set
# CONFIG_SERIO_APBPS2 is not set
# CONFIG_USERIO is not set
# CONFIG_GAMEPORT is not set
# Character devices
CONFIG_TTY=y
CONFIG_VT=y
CONFIG_CONSOLE_TRANSLATIONS=y
CONFIG_VT_CONSOLE=y
CONFIG_HW_CONSOLE=y
CONFIG_VT_HW_CONSOLE_BINDING=y
CONFIG_UNIX98_PTYS=y
# CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set
# CONFIG_LEGACY_PTYS is not set
# CONFIG_SERIAL_NONSTANDARD is not set
# CONFIG_N_GSM is not set
# CONFIG_TRACE_SINK is not set
CONFIG_DEVMEM=y
CONFIG_DEVKMEM=y
# Serial drivers
CONFIG_SERIAL_EARLYCON=y
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_DEPRECATED_OPTIONS=y
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_DMA=y
CONFIG_SERIAL_8250_NR_UARTS=32
CONFIG_SERIAL_8250_RUNTIME_UARTS=4
CONFIG_SERIAL_8250_EXTENDED=y
CONFIG_SERIAL_8250_MANY_PORTS=y
CONFIG_SERIAL_8250_SHARE_IRQ=y
CONFIG_SERIAL_8250_DETECT_IRQ=y
CONFIG_SERIAL_8250_RSA=y
CONFIG_SERIAL_8250_FSL=y
# CONFIG_SERIAL_8250_DW is not set
# CONFIG_SERIAL_8250_EM is not set
# CONFIG_SERIAL_8250_RT288X is not set
# CONFIG_SERIAL_8250_OMAP is not set
# CONFIG_SERIAL_8250_INGENIC is not set
# Non-8250 serial port support
# CONFIG_SERIAL_EARLYCON_ARM_SEMIHOST is not set
# CONFIG_SERIAL_MAX3100 is not set
# CONFIG_SERIAL_MAX310X is not set
# CONFIG_SERIAL_UARTLITE is not set
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
CONFIG_SERIAL_OF_PLATFORM=y
CONFIG_SERIAL_OMAP=y
CONFIG_SERIAL_OMAP_CONSOLE=y
# CONFIG_SERIAL_SCCNXP is not set
# CONFIG_SERIAL_SC16IS7XX is not set
# CONFIG_SERIAL_BCM63XX is not set
# CONFIG_SERIAL_ALTERA_JTAGUART is not set
# CONFIG_SERIAL_ALTERA_UART is not set
# CONFIG_SERIAL_IFX6X60 is not set
# CONFIG_SERIAL_XILINX_PS_UART is not set
# CONFIG_SERIAL_ARC is not set
# CONFIG_SERIAL_FSL_LPUART is not set
# CONFIG_SERIAL_CONEXANT_DIGICOLOR is not set
# CONFIG_SERIAL_ST_ASC is not set
# CONFIG_SERIAL_STM32 is not set
# CONFIG_TTY_PRINTK is not set
# CONFIG_HVC_DCC is not set
# CONFIG_IPMI_HANDLER is not set
CONFIG_HW_RANDOM=y
# CONFIG_HW_RANDOM_TIMERIOMEM is not set
CONFIG_HW_RANDOM_OMAP=y
# CONFIG_R3964 is not set
# CONFIG_RAW_DRIVER is not set
# CONFIG_TCG_TPM is not set
# CONFIG_XILLYBUS is not set
# I2C support
CONFIG_I2C=y
CONFIG_I2C_BOARDINFO=y
CONFIG_I2C_COMPAT=y
CONFIG_I2C_CHARDEV=y
# CONFIG_I2C_MUX is not set
CONFIG_I2C_HELPER_AUTO=y
# I2C Hardware Bus support
# I2C system bus drivers (mostly embedded / system-on-chip)
# CONFIG_I2C_CBUS_GPIO is not set
# CONFIG_I2C_DESIGNWARE_PLATFORM is not set
# CONFIG_I2C_EMEV2 is not set
# CONFIG_I2C_GPIO is not set
# CONFIG_I2C_OCORES is not set
CONFIG_I2C_OMAP=y
# CONFIG_I2C_PCA_PLATFORM is not set
# CONFIG_I2C_PXA_PCI is not set
# CONFIG_I2C_RK3X is not set
# CONFIG_I2C_SIMTEC is not set
# CONFIG_I2C_XILINX is not set
# External I2C/SMBus adapter drivers
# CONFIG_I2C_DIOLAN_U2C is not set
# CONFIG_I2C_PARPORT_LIGHT is not set
# CONFIG_I2C_ROBOTFUZZ_OSIF is not set
# CONFIG_I2C_TAOS_EVM is not set
# CONFIG_I2C_TINY_USB is not set
# Other I2C/SMBus bus drivers
# CONFIG_I2C_STUB is not set
# CONFIG_I2C_SLAVE is not set
# CONFIG_I2C_DEBUG_CORE is not set
# CONFIG_I2C_DEBUG_ALGO is not set
# CONFIG_I2C_DEBUG_BUS is not set
CONFIG_SPI=y
# CONFIG_SPI_DEBUG is not set
CONFIG_SPI_MASTER=y
# SPI Master Controller Drivers
# CONFIG_SPI_ALTERA is not set
# CONFIG_SPI_BITBANG is not set
# CONFIG_SPI_CADENCE is not set
# CONFIG_SPI_GPIO is not set
# CONFIG_SPI_FSL_SPI is not set
# CONFIG_SPI_OC_TINY is not set
CONFIG_SPI_OMAP24XX=y
CONFIG_SPI_TI_QSPI=y
# CONFIG_SPI_PXA2XX_PCI is not set
# CONFIG_SPI_ROCKCHIP is not set
# CONFIG_SPI_SC18IS602 is not set
# CONFIG_SPI_XCOMM is not set
# CONFIG_SPI_XILINX is not set
# CONFIG_SPI_ZYNQMP_GQSPI is not set
# CONFIG_SPI_DESIGNWARE is not set
# SPI Protocol Masters
CONFIG_SPI_SPIDEV=y
# CONFIG_SPI_TLE62X0 is not set
# CONFIG_SPMI is not set
# CONFIG_HSI is not set
# PPS support
CONFIG_PPS=y
# CONFIG_PPS_DEBUG is not set
# PPS clients support
# CONFIG_PPS_CLIENT_KTIMER is not set
# CONFIG_PPS_CLIENT_LDISC is not set
# CONFIG_PPS_CLIENT_GPIO is not set
# PPS generators support
# PTP clock support
CONFIG_PTP_1588_CLOCK=y
# Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks.
CONFIG_PINCTRL=y
# Pin controllers
CONFIG_PINMUX=y
CONFIG_PINCONF=y
CONFIG_GENERIC_PINCONF=y
# CONFIG_DEBUG_PINCTRL is not set
# CONFIG_PINCTRL_AMD is not set
CONFIG_PINCTRL_SINGLE=y
CONFIG_PINCTRL_PALMAS=y
CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y
CONFIG_ARCH_WANT_OPTIONAL_GPIOLIB=y
CONFIG_ARCH_REQUIRE_GPIOLIB=y
CONFIG_GPIOLIB=y
CONFIG_GPIO_DEVRES=y
CONFIG_OF_GPIO=y
CONFIG_GPIOLIB_IRQCHIP=y
CONFIG_DEBUG_GPIO=y
CONFIG_GPIO_SYSFS=y
# Memory mapped GPIO drivers
# CONFIG_GPIO_74XX_MMIO is not set
# CONFIG_GPIO_ALTERA is not set
# CONFIG_GPIO_DWAPB is not set
# CONFIG_GPIO_EM is not set
# CONFIG_GPIO_GENERIC_PLATFORM is not set
# CONFIG_GPIO_GRGPIO is not set
CONFIG_GPIO_OMAP=y
# CONFIG_GPIO_SYSCON is not set
# CONFIG_GPIO_XILINX is not set
# CONFIG_GPIO_ZEVIO is not set
# CONFIG_GPIO_ZX is not set
# I2C GPIO expanders
# CONFIG_GPIO_ADP5588 is not set
# CONFIG_GPIO_ADNP is not set
# CONFIG_GPIO_MAX7300 is not set
# CONFIG_GPIO_MAX732X is not set
CONFIG_GPIO_PCA953X=y
CONFIG_GPIO_PCA953X_IRQ=y
CONFIG_GPIO_PCF857X=y
# CONFIG_GPIO_SX150X is not set
# MFD GPIO expanders
CONFIG_GPIO_PALMAS=y
# CONFIG_GPIO_TPS65910 is not set
CONFIG_GPIO_TWL4030=y
# CONFIG_GPIO_TWL6040 is not set
# SPI GPIO expanders
# CONFIG_GPIO_74X164 is not set
# CONFIG_GPIO_MAX7301 is not set
# CONFIG_GPIO_MC33880 is not set
# SPI or I2C GPIO expanders
# CONFIG_GPIO_MCP23S08 is not set
# USB GPIO expanders
# CONFIG_W1 is not set
CONFIG_POWER_SUPPLY=y
# CONFIG_POWER_SUPPLY_DEBUG is not set
# CONFIG_PDA_POWER is not set
# CONFIG_GENERIC_ADC_BATTERY is not set
# CONFIG_TEST_POWER is not set
# CONFIG_BATTERY_DS2780 is not set
# CONFIG_BATTERY_DS2781 is not set
# CONFIG_BATTERY_DS2782 is not set
# CONFIG_BATTERY_SBS is not set
# CONFIG_BATTERY_BQ27XXX is not set
# CONFIG_BATTERY_MAX17040 is not set
# CONFIG_BATTERY_MAX17042 is not set
# CONFIG_CHARGER_ISP1704 is not set
# CONFIG_CHARGER_MAX8903 is not set
# CONFIG_CHARGER_TWL4030 is not set
# CONFIG_CHARGER_LP8727 is not set
# CONFIG_CHARGER_GPIO is not set
# CONFIG_CHARGER_MANAGER is not set
# CONFIG_CHARGER_BQ2415X is not set
# CONFIG_CHARGER_BQ24190 is not set
# CONFIG_CHARGER_BQ24257 is not set
# CONFIG_CHARGER_BQ24735 is not set
# CONFIG_CHARGER_BQ25890 is not set
# CONFIG_CHARGER_SMB347 is not set
# CONFIG_CHARGER_TPS65217 is not set
# CONFIG_BATTERY_GAUGE_LTC2941 is not set
# CONFIG_CHARGER_RT9455 is not set
CONFIG_POWER_RESET=y
# CONFIG_POWER_RESET_BRCMSTB is not set
CONFIG_POWER_RESET_GPIO=y
# CONFIG_POWER_RESET_GPIO_RESTART is not set
# CONFIG_POWER_RESET_LTC2952 is not set
# CONFIG_POWER_RESET_RESTART is not set
# CONFIG_POWER_RESET_VERSATILE is not set
# CONFIG_POWER_RESET_SYSCON is not set
# CONFIG_POWER_RESET_SYSCON_POWEROFF is not set
CONFIG_POWER_AVS=y
CONFIG_HWMON=y
# CONFIG_HWMON_VID is not set
# CONFIG_HWMON_DEBUG_CHIP is not set
# Native drivers
# CONFIG_SENSORS_AD7314 is not set
# CONFIG_SENSORS_AD7414 is not set
# CONFIG_SENSORS_AD7418 is not set
# CONFIG_SENSORS_ADM1021 is not set
# CONFIG_SENSORS_ADM1025 is not set
# CONFIG_SENSORS_ADM1026 is not set
# CONFIG_SENSORS_ADM1029 is not set
# CONFIG_SENSORS_ADM1031 is not set
# CONFIG_SENSORS_ADM9240 is not set
# CONFIG_SENSORS_ADT7310 is not set
# CONFIG_SENSORS_ADT7410 is not set
# CONFIG_SENSORS_ADT7411 is not set
# CONFIG_SENSORS_ADT7462 is not set
# CONFIG_SENSORS_ADT7470 is not set
# CONFIG_SENSORS_ADT7475 is not set
# CONFIG_SENSORS_ASC7621 is not set
# CONFIG_SENSORS_ATXP1 is not set
# CONFIG_SENSORS_DS620 is not set
# CONFIG_SENSORS_DS1621 is not set
# CONFIG_SENSORS_F71805F is not set
# CONFIG_SENSORS_F71882FG is not set
# CONFIG_SENSORS_F75375S is not set
# CONFIG_SENSORS_GL518SM is not set
# CONFIG_SENSORS_GL520SM is not set
# CONFIG_SENSORS_G760A is not set
# CONFIG_SENSORS_G762 is not set
# CONFIG_SENSORS_GPIO_FAN is not set
# CONFIG_SENSORS_HIH6130 is not set
# CONFIG_SENSORS_IIO_HWMON is not set
# CONFIG_SENSORS_IT87 is not set
# CONFIG_SENSORS_JC42 is not set
# CONFIG_SENSORS_POWR1220 is not set
# CONFIG_SENSORS_LINEAGE is not set
# CONFIG_SENSORS_LTC2945 is not set
# CONFIG_SENSORS_LTC4151 is not set
# CONFIG_SENSORS_LTC4215 is not set
# CONFIG_SENSORS_LTC4222 is not set
# CONFIG_SENSORS_LTC4245 is not set
# CONFIG_SENSORS_LTC4260 is not set
# CONFIG_SENSORS_LTC4261 is not set
# CONFIG_SENSORS_MAX1111 is not set
# CONFIG_SENSORS_MAX16065 is not set
# CONFIG_SENSORS_MAX1619 is not set
# CONFIG_SENSORS_MAX1668 is not set
# CONFIG_SENSORS_MAX197 is not set
# CONFIG_SENSORS_MAX6639 is not set
# CONFIG_SENSORS_MAX6642 is not set
# CONFIG_SENSORS_MAX6650 is not set
# CONFIG_SENSORS_MAX6697 is not set
# CONFIG_SENSORS_MAX31790 is not set
# CONFIG_SENSORS_HTU21 is not set
# CONFIG_SENSORS_MCP3021 is not set
# CONFIG_SENSORS_ADCXX is not set
# CONFIG_SENSORS_LM63 is not set
# CONFIG_SENSORS_LM70 is not set
# CONFIG_SENSORS_LM73 is not set
# CONFIG_SENSORS_LM75 is not set
# CONFIG_SENSORS_LM77 is not set
# CONFIG_SENSORS_LM78 is not set
# CONFIG_SENSORS_LM80 is not set
# CONFIG_SENSORS_LM83 is not set
# CONFIG_SENSORS_LM85 is not set
# CONFIG_SENSORS_LM87 is not set
# CONFIG_SENSORS_LM90 is not set
# CONFIG_SENSORS_LM92 is not set
# CONFIG_SENSORS_LM93 is not set
# CONFIG_SENSORS_LM95234 is not set
# CONFIG_SENSORS_LM95241 is not set
# CONFIG_SENSORS_LM95245 is not set
# CONFIG_SENSORS_PC87360 is not set
# CONFIG_SENSORS_PC87427 is not set
# CONFIG_SENSORS_NTC_THERMISTOR is not set
# CONFIG_SENSORS_NCT6683 is not set
# CONFIG_SENSORS_NCT6775 is not set
# CONFIG_SENSORS_NCT7802 is not set
# CONFIG_SENSORS_NCT7904 is not set
# CONFIG_SENSORS_PCF8591 is not set
CONFIG_PMBUS=y
CONFIG_SENSORS_PMBUS=y
# CONFIG_SENSORS_ADM1275 is not set
# CONFIG_SENSORS_LM25066 is not set
# CONFIG_SENSORS_LTC2978 is not set
# CONFIG_SENSORS_MAX16064 is not set
# CONFIG_SENSORS_MAX20751 is not set
# CONFIG_SENSORS_MAX34440 is not set
# CONFIG_SENSORS_MAX8688 is not set
# CONFIG_SENSORS_TPS40422 is not set
# CONFIG_SENSORS_UCD9000 is not set
# CONFIG_SENSORS_UCD9200 is not set
# CONFIG_SENSORS_ZL6100 is not set
# CONFIG_SENSORS_PWM_FAN is not set
# CONFIG_SENSORS_SHT15 is not set
# CONFIG_SENSORS_SHT21 is not set
# CONFIG_SENSORS_SHTC1 is not set
# CONFIG_SENSORS_DME1737 is not set
# CONFIG_SENSORS_EMC1403 is not set
# CONFIG_SENSORS_EMC2103 is not set
# CONFIG_SENSORS_EMC6W201 is not set
# CONFIG_SENSORS_SMSC47M1 is not set
# CONFIG_SENSORS_SMSC47M192 is not set
# CONFIG_SENSORS_SMSC47B397 is not set
# CONFIG_SENSORS_SCH56XX_COMMON is not set
# CONFIG_SENSORS_SCH5627 is not set
# CONFIG_SENSORS_SCH5636 is not set
# CONFIG_SENSORS_SMM665 is not set
# CONFIG_SENSORS_ADC128D818 is not set
# CONFIG_SENSORS_ADS1015 is not set
# CONFIG_SENSORS_ADS7828 is not set
# CONFIG_SENSORS_ADS7871 is not set
# CONFIG_SENSORS_AMC6821 is not set
# CONFIG_SENSORS_INA209 is not set
# CONFIG_SENSORS_INA2XX is not set
# CONFIG_SENSORS_TC74 is not set
# CONFIG_SENSORS_THMC50 is not set
# CONFIG_SENSORS_TMP102 is not set
# CONFIG_SENSORS_TMP103 is not set
# CONFIG_SENSORS_TMP401 is not set
# CONFIG_SENSORS_TMP421 is not set
# CONFIG_SENSORS_VT1211 is not set
# CONFIG_SENSORS_W83781D is not set
# CONFIG_SENSORS_W83791D is not set
# CONFIG_SENSORS_W83792D is not set
# CONFIG_SENSORS_W83793 is not set
# CONFIG_SENSORS_W83795 is not set
# CONFIG_SENSORS_W83L785TS is not set
# CONFIG_SENSORS_W83L786NG is not set
# CONFIG_SENSORS_W83627HF is not set
# CONFIG_SENSORS_W83627EHF is not set
CONFIG_THERMAL=y
CONFIG_THERMAL_HWMON=y
CONFIG_THERMAL_OF=y
CONFIG_THERMAL_WRITABLE_TRIPS=y
CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y
# CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set
# CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set
# CONFIG_THERMAL_DEFAULT_GOV_POWER_ALLOCATOR is not set
CONFIG_THERMAL_GOV_FAIR_SHARE=y
CONFIG_THERMAL_GOV_STEP_WISE=y
# CONFIG_THERMAL_GOV_BANG_BANG is not set
CONFIG_THERMAL_GOV_USER_SPACE=y
# CONFIG_THERMAL_GOV_POWER_ALLOCATOR is not set
CONFIG_CPU_THERMAL=y
# CONFIG_THERMAL_EMULATION is not set
# CONFIG_IMX_THERMAL is not set
# Texas Instruments thermal drivers
CONFIG_TI_SOC_THERMAL=y
CONFIG_TI_THERMAL=y
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_CORE=y
# CONFIG_WATCHDOG_NOWAYOUT is not set
# Watchdog Device Drivers
# CONFIG_SOFT_WATCHDOG is not set
# CONFIG_GPIO_WATCHDOG is not set
# CONFIG_XILINX_WATCHDOG is not set
# CONFIG_CADENCE_WATCHDOG is not set
# CONFIG_DW_WATCHDOG is not set
CONFIG_OMAP_WATCHDOG=y
CONFIG_TWL4030_WATCHDOG=y
# CONFIG_MAX63XX_WATCHDOG is not set
# CONFIG_BCM7038_WDT is not set
# CONFIG_MEN_A21_WDT is not set
# USB-based Watchdog Cards
# CONFIG_USBPCWATCHDOG is not set
CONFIG_SSB_POSSIBLE=y
# Sonics Silicon Backplane
# CONFIG_SSB is not set
CONFIG_BCMA_POSSIBLE=y
# Broadcom specific AMBA
# CONFIG_BCMA is not set
# Multifunction device drivers
CONFIG_MFD_CORE=y
# CONFIG_MFD_AS3711 is not set
# CONFIG_MFD_AS3722 is not set
# CONFIG_PMIC_ADP5520 is not set
# CONFIG_MFD_AAT2870_CORE is not set
# CONFIG_MFD_ATMEL_FLEXCOM is not set
# CONFIG_MFD_ATMEL_HLCDC is not set
# CONFIG_MFD_BCM590XX is not set
# CONFIG_MFD_AXP20X is not set
# CONFIG_MFD_CROS_EC is not set
# CONFIG_MFD_ASIC3 is not set
# CONFIG_PMIC_DA903X is not set
# CONFIG_MFD_DA9052_SPI is not set
# CONFIG_MFD_DA9052_I2C is not set
# CONFIG_MFD_DA9055 is not set
# CONFIG_MFD_DA9062 is not set
# CONFIG_MFD_DA9063 is not set
# CONFIG_MFD_DA9150 is not set
# CONFIG_MFD_DLN2 is not set
# CONFIG_MFD_MC13XXX_SPI is not set
# CONFIG_MFD_MC13XXX_I2C is not set
# CONFIG_MFD_HI6421_PMIC is not set
# CONFIG_HTC_EGPIO is not set
# CONFIG_HTC_PASIC3 is not set
# CONFIG_HTC_I2CPLD is not set
# CONFIG_INTEL_SOC_PMIC is not set
# CONFIG_MFD_KEMPLD is not set
# CONFIG_MFD_88PM800 is not set
# CONFIG_MFD_88PM805 is not set
# CONFIG_MFD_88PM860X is not set
# CONFIG_MFD_MAX14577 is not set
# CONFIG_MFD_MAX77686 is not set
# CONFIG_MFD_MAX77693 is not set
# CONFIG_MFD_MAX77843 is not set
# CONFIG_MFD_MAX8907 is not set
# CONFIG_MFD_MAX8925 is not set
# CONFIG_MFD_MAX8997 is not set
# CONFIG_MFD_MAX8998 is not set
# CONFIG_MFD_MT6397 is not set
# CONFIG_MFD_MENF21BMC is not set
# CONFIG_EZX_PCAP is not set
# CONFIG_MFD_VIPERBOARD is not set
# CONFIG_MFD_RETU is not set
# CONFIG_MFD_PCF50633 is not set
# CONFIG_MFD_PM8921_CORE is not set
# CONFIG_MFD_RT5033 is not set
# CONFIG_MFD_RTSX_USB is not set
# CONFIG_MFD_RC5T583 is not set
# CONFIG_MFD_RK808 is not set
# CONFIG_MFD_RN5T618 is not set
# CONFIG_MFD_SEC_CORE is not set
# CONFIG_MFD_SI476X_CORE is not set
# CONFIG_MFD_SM501 is not set
# CONFIG_MFD_SKY81452 is not set
# CONFIG_MFD_SMSC is not set
# CONFIG_ABX500_CORE is not set
# CONFIG_MFD_STMPE is not set
CONFIG_MFD_SYSCON=y
CONFIG_MFD_TI_AM335X_TSCADC=y
# CONFIG_MFD_LP3943 is not set
# CONFIG_MFD_LP8788 is not set
CONFIG_MFD_OMAP_USB_HOST=y
CONFIG_MFD_PALMAS=y
# CONFIG_TPS6105X is not set
# CONFIG_TPS65010 is not set
# CONFIG_TPS6507X is not set
# CONFIG_MFD_TPS65090 is not set
CONFIG_MFD_TPS65217=y
CONFIG_MFD_TPS65218=y
# CONFIG_MFD_TPS6586X is not set
CONFIG_MFD_TPS65910=y
# CONFIG_MFD_TPS65912 is not set
# CONFIG_MFD_TPS65912_I2C is not set
# CONFIG_MFD_TPS65912_SPI is not set
# CONFIG_MFD_TPS80031 is not set
CONFIG_TWL4030_CORE=y
# CONFIG_TWL4030_POWER is not set
CONFIG_MFD_TWL4030_AUDIO=y
CONFIG_TWL6040_CORE=y
# CONFIG_MFD_WL1273_CORE is not set
# CONFIG_MFD_LM3533 is not set
# CONFIG_MFD_TC3589X is not set
# CONFIG_MFD_TMIO is not set
# CONFIG_MFD_T7L66XB is not set
# CONFIG_MFD_TC6387XB is not set
# CONFIG_MFD_TC6393XB is not set
# CONFIG_MFD_ARIZONA_I2C is not set
# CONFIG_MFD_ARIZONA_SPI is not set
# CONFIG_MFD_WM8400 is not set
# CONFIG_MFD_WM831X_I2C is not set
# CONFIG_MFD_WM831X_SPI is not set
# CONFIG_MFD_WM8350_I2C is not set
# CONFIG_MFD_WM8994 is not set
CONFIG_REGULATOR=y
# CONFIG_REGULATOR_DEBUG is not set
CONFIG_REGULATOR_FIXED_VOLTAGE=y
# CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
# CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
# CONFIG_REGULATOR_ACT8865 is not set
# CONFIG_REGULATOR_AD5398 is not set
# CONFIG_REGULATOR_ANATOP is not set
# CONFIG_REGULATOR_DA9210 is not set
# CONFIG_REGULATOR_DA9211 is not set
# CONFIG_REGULATOR_FAN53555 is not set
# CONFIG_REGULATOR_GPIO is not set
# CONFIG_REGULATOR_ISL9305 is not set
# CONFIG_REGULATOR_ISL6271A is not set
# CONFIG_REGULATOR_LP3971 is not set
# CONFIG_REGULATOR_LP3972 is not set
# CONFIG_REGULATOR_LP872X is not set
# CONFIG_REGULATOR_LP8755 is not set
# CONFIG_REGULATOR_LTC3589 is not set
# CONFIG_REGULATOR_MAX1586 is not set
# CONFIG_REGULATOR_MAX8649 is not set
# CONFIG_REGULATOR_MAX8660 is not set
# CONFIG_REGULATOR_MAX8952 is not set
# CONFIG_REGULATOR_MAX8973 is not set
# CONFIG_REGULATOR_MT6311 is not set
CONFIG_REGULATOR_PALMAS=y
# CONFIG_REGULATOR_PBIAS is not set
# CONFIG_REGULATOR_PFUZE100 is not set
# CONFIG_REGULATOR_PWM is not set
# CONFIG_REGULATOR_TI_ABB is not set
# CONFIG_REGULATOR_TPS51632 is not set
CONFIG_REGULATOR_TPS62360=y
CONFIG_REGULATOR_TPS65023=y
CONFIG_REGULATOR_TPS6507X=y
CONFIG_REGULATOR_TPS65217=y
CONFIG_REGULATOR_TPS65218=y
# CONFIG_REGULATOR_TPS6524X is not set
CONFIG_REGULATOR_TPS65910=y
CONFIG_REGULATOR_TWL4030=y
# CONFIG_MEDIA_SUPPORT is not set
# Graphics support
# CONFIG_DRM is not set
# Frame buffer Devices
CONFIG_FB=y
# CONFIG_FIRMWARE_EDID is not set
CONFIG_FB_CMDLINE=y
# CONFIG_FB_DDC is not set
# CONFIG_FB_BOOT_VESA_SUPPORT is not set
# CONFIG_FB_CFB_FILLRECT is not set
# CONFIG_FB_CFB_COPYAREA is not set
# CONFIG_FB_CFB_IMAGEBLIT is not set
# CONFIG_FB_CFB_REV_PIXELS_IN_BYTE is not set
# CONFIG_FB_SYS_FILLRECT is not set
# CONFIG_FB_SYS_COPYAREA is not set
# CONFIG_FB_SYS_IMAGEBLIT is not set
# CONFIG_FB_FOREIGN_ENDIAN is not set
# CONFIG_FB_SYS_FOPS is not set
# CONFIG_FB_SVGALIB is not set
# CONFIG_FB_MACMODES is not set
# CONFIG_FB_BACKLIGHT is not set
# CONFIG_FB_MODE_HELPERS is not set
# CONFIG_FB_TILEBLITTING is not set
# Frame buffer hardware drivers
# CONFIG_FB_UVESA is not set
# CONFIG_FB_OPENCORES is not set
# CONFIG_FB_S1D13XXX is not set
# CONFIG_FB_SMSCUFX is not set
# CONFIG_FB_UDL is not set
# CONFIG_FB_IBM_GXT4500 is not set
# CONFIG_FB_DA8XX is not set
# CONFIG_FB_VIRTUAL is not set
# CONFIG_FB_METRONOME is not set
# CONFIG_FB_MB862XX_PCI_GDC is not set
# CONFIG_FB_BROADSHEET is not set
# CONFIG_FB_AUO_K190X is not set
# CONFIG_FB_SIMPLE is not set
# CONFIG_OMAP2_DSS is not set
# CONFIG_FB_SSD1307 is not set
# CONFIG_BACKLIGHT_LCD_SUPPORT is not set
# CONFIG_VGASTATE is not set
# Console display driver support
CONFIG_DUMMY_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y
# CONFIG_FRAMEBUFFER_CONSOLE_ROTATION is not set
# CONFIG_LOGO is not set
CONFIG_SOUND=y
CONFIG_SOUND_OSS_CORE=y
CONFIG_SOUND_OSS_CORE_PRECLAIM=y
CONFIG_SND=m
CONFIG_SND_TIMER=m
CONFIG_SND_PCM=m
CONFIG_SND_JACK=y
# CONFIG_SND_SEQUENCER is not set
CONFIG_SND_OSSEMUL=y
CONFIG_SND_MIXER_OSS=m
CONFIG_SND_PCM_OSS=m
CONFIG_SND_PCM_OSS_PLUGINS=y
CONFIG_SND_PCM_TIMER=y
# CONFIG_SND_HRTIMER is not set
# CONFIG_SND_DYNAMIC_MINORS is not set
CONFIG_SND_SUPPORT_OLD_API=y
CONFIG_SND_PROC_FS=y
CONFIG_SND_VERBOSE_PROCFS=y
CONFIG_SND_VERBOSE_PRINTK=y
CONFIG_SND_DEBUG=y
# CONFIG_SND_DEBUG_VERBOSE is not set
# CONFIG_SND_PCM_XRUN_DEBUG is not set
# CONFIG_SND_RAWMIDI_SEQ is not set
# CONFIG_SND_OPL3_LIB_SEQ is not set
# CONFIG_SND_OPL4_LIB_SEQ is not set
# CONFIG_SND_SBAWE_SEQ is not set
# CONFIG_SND_EMU10K1_SEQ is not set
CONFIG_SND_DRIVERS=y
# CONFIG_SND_DUMMY is not set
# CONFIG_SND_ALOOP is not set
# CONFIG_SND_MTPAV is not set
# CONFIG_SND_SERIAL_U16550 is not set
# CONFIG_SND_MPU401 is not set
# HD-Audio
CONFIG_SND_HDA_PREALLOC_SIZE=64
CONFIG_SND_ARM=y
CONFIG_SND_SPI=y
CONFIG_SND_USB=y
# CONFIG_SND_USB_AUDIO is not set
# CONFIG_SND_USB_UA101 is not set
# CONFIG_SND_USB_CAIAQ is not set
# CONFIG_SND_USB_6FIRE is not set
# CONFIG_SND_USB_HIFACE is not set
# CONFIG_SND_BCD2000 is not set
# CONFIG_SND_USB_POD is not set
# CONFIG_SND_USB_PODHD is not set
# CONFIG_SND_USB_TONEPORT is not set
# CONFIG_SND_USB_VARIAX is not set
CONFIG_SND_SOC=m
# CONFIG_SND_ATMEL_SOC is not set
# CONFIG_SND_EDMA_SOC is not set
# CONFIG_SND_DESIGNWARE_I2S is not set
# SoC Audio for Freescale CPUs
# Common SoC Audio options for Freescale CPUs:
# CONFIG_SND_SOC_FSL_ASRC is not set
# CONFIG_SND_SOC_FSL_SAI is not set
# CONFIG_SND_SOC_FSL_SSI is not set
# CONFIG_SND_SOC_FSL_SPDIF is not set
# CONFIG_SND_SOC_FSL_ESAI is not set
# CONFIG_SND_SOC_IMX_AUDMUX is not set
# CONFIG_SND_OMAP_SOC is not set
# Allwinner SoC Audio support
# CONFIG_SND_SUN4I_CODEC is not set
# CONFIG_SND_SOC_XTFPGA_I2S is not set
CONFIG_SND_SOC_I2C_AND_SPI=m
# CODEC drivers
# CONFIG_SND_SOC_AC97_CODEC is not set
# CONFIG_SND_SOC_ADAU1701 is not set
# CONFIG_SND_SOC_AK4104 is not set
# CONFIG_SND_SOC_AK4554 is not set
# CONFIG_SND_SOC_AK4613 is not set
# CONFIG_SND_SOC_AK4642 is not set
# CONFIG_SND_SOC_AK5386 is not set
# CONFIG_SND_SOC_ALC5623 is not set
# CONFIG_SND_SOC_CS35L32 is not set
# CONFIG_SND_SOC_CS42L51_I2C is not set
# CONFIG_SND_SOC_CS42L52 is not set
# CONFIG_SND_SOC_CS42L56 is not set
# CONFIG_SND_SOC_CS42L73 is not set
# CONFIG_SND_SOC_CS4265 is not set
# CONFIG_SND_SOC_CS4270 is not set
# CONFIG_SND_SOC_CS4271_I2C is not set
# CONFIG_SND_SOC_CS4271_SPI is not set
# CONFIG_SND_SOC_CS42XX8_I2C is not set
# CONFIG_SND_SOC_CS4349 is not set
# CONFIG_SND_SOC_ES8328 is not set
# CONFIG_SND_SOC_GTM601 is not set
# CONFIG_SND_SOC_PCM1681 is not set
# CONFIG_SND_SOC_PCM1792A is not set
# CONFIG_SND_SOC_PCM512x_I2C is not set
# CONFIG_SND_SOC_PCM512x_SPI is not set
# CONFIG_SND_SOC_RT5631 is not set
# CONFIG_SND_SOC_RT5677_SPI is not set
# CONFIG_SND_SOC_SGTL5000 is not set
# CONFIG_SND_SOC_SIRF_AUDIO_CODEC is not set
# CONFIG_SND_SOC_SPDIF is not set
# CONFIG_SND_SOC_SSM2602_SPI is not set
# CONFIG_SND_SOC_SSM2602_I2C is not set
# CONFIG_SND_SOC_SSM4567 is not set
# CONFIG_SND_SOC_STA32X is not set
# CONFIG_SND_SOC_STA350 is not set
# CONFIG_SND_SOC_STI_SAS is not set
# CONFIG_SND_SOC_TAS2552 is not set
# CONFIG_SND_SOC_TAS5086 is not set
# CONFIG_SND_SOC_TAS571X is not set
# CONFIG_SND_SOC_TFA9879 is not set
# CONFIG_SND_SOC_TLV320AIC23_I2C is not set
# CONFIG_SND_SOC_TLV320AIC23_SPI is not set
# CONFIG_SND_SOC_TLV320AIC31XX is not set
CONFIG_SND_SOC_TLV320AIC3X=m
# CONFIG_SND_SOC_TS3A227E is not set
# CONFIG_SND_SOC_WM8510 is not set
# CONFIG_SND_SOC_WM8523 is not set
# CONFIG_SND_SOC_WM8580 is not set
# CONFIG_SND_SOC_WM8711 is not set
# CONFIG_SND_SOC_WM8728 is not set
# CONFIG_SND_SOC_WM8731 is not set
# CONFIG_SND_SOC_WM8737 is not set
# CONFIG_SND_SOC_WM8741 is not set
# CONFIG_SND_SOC_WM8750 is not set
# CONFIG_SND_SOC_WM8753 is not set
# CONFIG_SND_SOC_WM8770 is not set
# CONFIG_SND_SOC_WM8776 is not set
# CONFIG_SND_SOC_WM8804_I2C is not set
# CONFIG_SND_SOC_WM8804_SPI is not set
# CONFIG_SND_SOC_WM8903 is not set
# CONFIG_SND_SOC_WM8962 is not set
# CONFIG_SND_SOC_WM8978 is not set
# CONFIG_SND_SOC_TPA6130A2 is not set
CONFIG_SND_SIMPLE_CARD=m
# CONFIG_SOUND_PRIME is not set
# HID support
CONFIG_HID=y
# CONFIG_HID_BATTERY_STRENGTH is not set
# CONFIG_HIDRAW is not set
# CONFIG_UHID is not set
CONFIG_HID_GENERIC=y
# Special HID drivers
# CONFIG_HID_A4TECH is not set
# CONFIG_HID_ACRUX is not set
# CONFIG_HID_APPLE is not set
# CONFIG_HID_APPLEIR is not set
# CONFIG_HID_AUREAL is not set
# CONFIG_HID_BELKIN is not set
# CONFIG_HID_BETOP_FF is not set
# CONFIG_HID_CHERRY is not set
# CONFIG_HID_CHICONY is not set
# CONFIG_HID_CORSAIR is not set
# CONFIG_HID_PRODIKEYS is not set
# CONFIG_HID_CP2112 is not set
# CONFIG_HID_CYPRESS is not set
# CONFIG_HID_DRAGONRISE is not set
# CONFIG_HID_EMS_FF is not set
# CONFIG_HID_ELECOM is not set
# CONFIG_HID_ELO is not set
# CONFIG_HID_EZKEY is not set
# CONFIG_HID_GEMBIRD is not set
# CONFIG_HID_GFRM is not set
# CONFIG_HID_HOLTEK is not set
# CONFIG_HID_GT683R is not set
# CONFIG_HID_KEYTOUCH is not set
# CONFIG_HID_KYE is not set
# CONFIG_HID_UCLOGIC is not set
# CONFIG_HID_WALTOP is not set
# CONFIG_HID_GYRATION is not set
# CONFIG_HID_ICADE is not set
# CONFIG_HID_TWINHAN is not set
# CONFIG_HID_KENSINGTON is not set
# CONFIG_HID_LCPOWER is not set
# CONFIG_HID_LENOVO is not set
# CONFIG_HID_LOGITECH is not set
# CONFIG_HID_MAGICMOUSE is not set
# CONFIG_HID_MICROSOFT is not set
# CONFIG_HID_MONTEREY is not set
# CONFIG_HID_MULTITOUCH is not set
# CONFIG_HID_NTRIG is not set
# CONFIG_HID_ORTEK is not set
# CONFIG_HID_PANTHERLORD is not set
# CONFIG_HID_PENMOUNT is not set
# CONFIG_HID_PETALYNX is not set
# CONFIG_HID_PICOLCD is not set
# CONFIG_HID_PLANTRONICS is not set
# CONFIG_HID_PRIMAX is not set
# CONFIG_HID_ROCCAT is not set
# CONFIG_HID_SAITEK is not set
# CONFIG_HID_SAMSUNG is not set
# CONFIG_HID_SONY is not set
# CONFIG_HID_SPEEDLINK is not set
# CONFIG_HID_STEELSERIES is not set
# CONFIG_HID_SUNPLUS is not set
# CONFIG_HID_RMI is not set
# CONFIG_HID_GREENASIA is not set
# CONFIG_HID_SMARTJOYPLUS is not set
# CONFIG_HID_TIVO is not set
# CONFIG_HID_TOPSEED is not set
# CONFIG_HID_THINGM is not set
# CONFIG_HID_THRUSTMASTER is not set
# CONFIG_HID_WACOM is not set
# CONFIG_HID_WIIMOTE is not set
# CONFIG_HID_XINMO is not set
# CONFIG_HID_ZEROPLUS is not set
# CONFIG_HID_ZYDACRON is not set
# CONFIG_HID_SENSOR_HUB is not set
# USB HID support
CONFIG_USB_HID=y
# CONFIG_HID_PID is not set
CONFIG_USB_HIDDEV=y
# I2C HID support
# CONFIG_I2C_HID is not set
CONFIG_USB_OHCI_LITTLE_ENDIAN=y
CONFIG_USB_SUPPORT=y
CONFIG_USB_COMMON=y
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB=y
CONFIG_USB_ANNOUNCE_NEW_DEVICES=y
# Miscellaneous USB options
CONFIG_USB_DEFAULT_PERSIST=y
# CONFIG_USB_DYNAMIC_MINORS is not set
# CONFIG_USB_OTG is not set
# CONFIG_USB_OTG_WHITELIST is not set
# CONFIG_USB_OTG_BLACKLIST_HUB is not set
# CONFIG_USB_ULPI_BUS is not set
CONFIG_USB_MON=y
# CONFIG_USB_WUSB_CBAF is not set
# USB Host Controller Drivers
# CONFIG_USB_C67X00_HCD is not set
# CONFIG_USB_XHCI_HCD is not set
CONFIG_USB_EHCI_HCD=y
# CONFIG_USB_EHCI_ROOT_HUB_TT is not set
CONFIG_USB_EHCI_TT_NEWSCHED=y
CONFIG_USB_EHCI_HCD_OMAP=y
# CONFIG_USB_EHCI_HCD_PLATFORM is not set
# CONFIG_USB_OXU210HP_HCD is not set
# CONFIG_USB_ISP116X_HCD is not set
# CONFIG_USB_ISP1362_HCD is not set
# CONFIG_USB_FOTG210_HCD is not set
# CONFIG_USB_MAX3421_HCD is not set
CONFIG_USB_OHCI_HCD=y
# CONFIG_USB_OHCI_HCD_PLATFORM is not set
# CONFIG_USB_SL811_HCD is not set
# CONFIG_USB_R8A66597_HCD is not set
# CONFIG_USB_HCD_TEST_MODE is not set
# USB Device Class drivers
# CONFIG_USB_ACM is not set
# CONFIG_USB_PRINTER is not set
# CONFIG_USB_WDM is not set
# CONFIG_USB_TMC is not set
# NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
# also be needed; see USB_STORAGE Help for more info
CONFIG_USB_STORAGE=y
# CONFIG_USB_STORAGE_DEBUG is not set
# CONFIG_USB_STORAGE_REALTEK is not set
# CONFIG_USB_STORAGE_DATAFAB is not set
# CONFIG_USB_STORAGE_FREECOM is not set
# CONFIG_USB_STORAGE_ISD200 is not set
# CONFIG_USB_STORAGE_USBAT is not set
# CONFIG_USB_STORAGE_SDDR09 is not set
# CONFIG_USB_STORAGE_SDDR55 is not set
# CONFIG_USB_STORAGE_JUMPSHOT is not set
# CONFIG_USB_STORAGE_ALAUDA is not set
# CONFIG_USB_STORAGE_ONETOUCH is not set
# CONFIG_USB_STORAGE_KARMA is not set
# CONFIG_USB_STORAGE_CYPRESS_ATACB is not set
# CONFIG_USB_STORAGE_ENE_UB6250 is not set
# CONFIG_USB_UAS is not set
# USB Imaging devices
# CONFIG_USB_MDC800 is not set
# CONFIG_USB_MICROTEK is not set
# CONFIG_USBIP_CORE is not set
CONFIG_USB_MUSB_HDRC=y
CONFIG_USB_MUSB_HOST=y
# Platform Glue Layer
# CONFIG_USB_MUSB_TUSB6010 is not set
CONFIG_USB_MUSB_OMAP2PLUS=y
# CONFIG_USB_MUSB_AM35X is not set
# CONFIG_USB_MUSB_DSPS is not set
# MUSB DMA mode
# CONFIG_MUSB_PIO_ONLY is not set
# CONFIG_USB_INVENTRA_DMA is not set
# CONFIG_USB_TI_CPPI41_DMA is not set
# CONFIG_USB_DWC3 is not set
# CONFIG_USB_DWC2 is not set
# CONFIG_USB_CHIPIDEA is not set
# CONFIG_USB_ISP1760 is not set
# USB port drivers
# CONFIG_USB_SERIAL is not set
# USB Miscellaneous drivers
# CONFIG_USB_EMI62 is not set
# CONFIG_USB_EMI26 is not set
# CONFIG_USB_ADUTUX is not set
# CONFIG_USB_SEVSEG is not set
# CONFIG_USB_RIO500 is not set
# CONFIG_USB_LEGOTOWER is not set
# CONFIG_USB_LCD is not set
# CONFIG_USB_LED is not set
# CONFIG_USB_CYPRESS_CY7C63 is not set
# CONFIG_USB_CYTHERM is not set
# CONFIG_USB_IDMOUSE is not set
# CONFIG_USB_FTDI_ELAN is not set
# CONFIG_USB_APPLEDISPLAY is not set
# CONFIG_USB_SISUSBVGA is not set
# CONFIG_USB_LD is not set
# CONFIG_USB_TRANCEVIBRATOR is not set
# CONFIG_USB_IOWARRIOR is not set
# CONFIG_USB_TEST is not set
# CONFIG_USB_EHSET_TEST_FIXTURE is not set
# CONFIG_USB_ISIGHTFW is not set
# CONFIG_USB_YUREX is not set
# CONFIG_USB_EZUSB_FX2 is not set
# CONFIG_USB_HSIC_USB3503 is not set
# CONFIG_USB_LINK_LAYER_TEST is not set
# CONFIG_USB_CHAOSKEY is not set
# USB Physical Layer drivers
CONFIG_USB_PHY=y
CONFIG_NOP_USB_XCEIV=y
CONFIG_AM335X_CONTROL_USB=y
CONFIG_AM335X_PHY_USB=y
CONFIG_TWL6030_USB=y
# CONFIG_USB_GPIO_VBUS is not set
# CONFIG_USB_ISP1301 is not set
# CONFIG_USB_ULPI is not set
# CONFIG_USB_GADGET is not set
# CONFIG_USB_CONFIGFS is not set
# CONFIG_USB_ZERO is not set
# CONFIG_USB_AUDIO is not set
# CONFIG_USB_ETH is not set
# CONFIG_USB_G_NCM is not set
# CONFIG_USB_GADGETFS is not set
# CONFIG_USB_FUNCTIONFS is not set
# CONFIG_USB_MASS_STORAGE is not set
# CONFIG_USB_GADGET_TARGET is not set
# CONFIG_USB_G_SERIAL is not set
# CONFIG_USB_MIDI_GADGET is not set
# CONFIG_USB_G_PRINTER is not set
# CONFIG_USB_CDC_COMPOSITE is not set
# CONFIG_USB_G_NOKIA is not set
# CONFIG_USB_G_ACM_MS is not set
# CONFIG_USB_G_MULTI is not set
# CONFIG_USB_G_HID is not set
# CONFIG_USB_G_DBGP is not set
# CONFIG_USB_G_WEBCAM is not set
# CONFIG_USB_LED_TRIG is not set
# CONFIG_UWB is not set
CONFIG_MMC=y
# CONFIG_MMC_DEBUG=y
# MMC/SD/SDIO Card Drivers
CONFIG_MMC_BLOCK=y
CONFIG_MMC_BLOCK_MINORS=8
CONFIG_MMC_BLOCK_BOUNCE=y
CONFIG_SDIO_UART=y
# CONFIG_MMC_TEST is not set
# MMC/SD/SDIO Host Controller Drivers
# CONFIG_MMC_SDHCI is not set
CONFIG_MMC_OMAP=y
CONFIG_MMC_OMAP_HS=y
# CONFIG_MMC_DW is not set
# CONFIG_MMC_VUB300 is not set
# CONFIG_MMC_USHC is not set
# CONFIG_MMC_USDHI6ROL0 is not set
# CONFIG_MMC_MTK is not set
# CONFIG_MEMSTICK is not set
CONFIG_NEW_LEDS=y
CONFIG_LEDS_CLASS=y
# CONFIG_LEDS_CLASS_FLASH is not set
# LED drivers
# CONFIG_LEDS_BCM6328 is not set
# CONFIG_LEDS_BCM6358 is not set
# CONFIG_LEDS_LM3530 is not set
# CONFIG_LEDS_LM3642 is not set
CONFIG_LEDS_PCA9532=y
CONFIG_LEDS_PCA9532_GPIO=y
CONFIG_LEDS_GPIO=y
# CONFIG_LEDS_LP3944 is not set
# CONFIG_LEDS_LP5521 is not set
# CONFIG_LEDS_LP5523 is not set
# CONFIG_LEDS_LP5562 is not set
# CONFIG_LEDS_LP8501 is not set
# CONFIG_LEDS_LP8860 is not set
# CONFIG_LEDS_PCA955X is not set
# CONFIG_LEDS_PCA963X is not set
# CONFIG_LEDS_DAC124S085 is not set
CONFIG_LEDS_PWM=y
# CONFIG_LEDS_REGULATOR is not set
# CONFIG_LEDS_BD2802 is not set
# CONFIG_LEDS_LT3593 is not set
# CONFIG_LEDS_TCA6507 is not set
# CONFIG_LEDS_TLC591XX is not set
# CONFIG_LEDS_LM355x is not set
# LED driver for blink(1) USB RGB LED is under Special HID drivers (HID_THINGM)
# CONFIG_LEDS_BLINKM is not set
# CONFIG_LEDS_SYSCON is not set
# LED Triggers
CONFIG_LEDS_TRIGGERS=y
CONFIG_LEDS_TRIGGER_TIMER=y
CONFIG_LEDS_TRIGGER_ONESHOT=y
CONFIG_LEDS_TRIGGER_HEARTBEAT=y
# CONFIG_LEDS_TRIGGER_BACKLIGHT is not set
CONFIG_LEDS_TRIGGER_CPU=y
CONFIG_LEDS_TRIGGER_GPIO=y
CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
# iptables trigger is under Netfilter config (LED target)
# CONFIG_LEDS_TRIGGER_TRANSIENT is not set
# CONFIG_LEDS_TRIGGER_CAMERA is not set
# CONFIG_ACCESSIBILITY is not set
CONFIG_EDAC_ATOMIC_SCRUB=y
CONFIG_EDAC_SUPPORT=y
# CONFIG_EDAC is not set
CONFIG_RTC_LIB=y
CONFIG_RTC_CLASS=y
CONFIG_RTC_HCTOSYS=y
CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
CONFIG_RTC_SYSTOHC=y
CONFIG_RTC_SYSTOHC_DEVICE="rtc0"
# CONFIG_RTC_DEBUG is not set
# RTC interfaces
CONFIG_RTC_INTF_SYSFS=y
CONFIG_RTC_INTF_PROC=y
CONFIG_RTC_INTF_DEV=y
# CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
# CONFIG_RTC_DRV_TEST is not set
# I2C RTC drivers
# CONFIG_RTC_DRV_ABB5ZES3 is not set
# CONFIG_RTC_DRV_ABX80X is not set
CONFIG_RTC_DRV_DS1307=y
# CONFIG_RTC_DRV_DS1374 is not set
# CONFIG_RTC_DRV_DS1672 is not set
# CONFIG_RTC_DRV_DS3232 is not set
# CONFIG_RTC_DRV_HYM8563 is not set
# CONFIG_RTC_DRV_MAX6900 is not set
# CONFIG_RTC_DRV_RS5C372 is not set
# CONFIG_RTC_DRV_ISL1208 is not set
# CONFIG_RTC_DRV_ISL12022 is not set
# CONFIG_RTC_DRV_ISL12057 is not set
# CONFIG_RTC_DRV_X1205 is not set
CONFIG_RTC_DRV_PALMAS=y
# CONFIG_RTC_DRV_PCF2127 is not set
# CONFIG_RTC_DRV_PCF8523 is not set
CONFIG_RTC_DRV_PCF8563=y
# CONFIG_RTC_DRV_PCF85063 is not set
# CONFIG_RTC_DRV_PCF8583 is not set
CONFIG_RTC_DRV_M41T80=y
# CONFIG_RTC_DRV_M41T80_WDT is not set
# CONFIG_RTC_DRV_BQ32K is not set
CONFIG_RTC_DRV_TWL4030=y
CONFIG_RTC_DRV_TPS65910=y
# CONFIG_RTC_DRV_S35390A is not set
# CONFIG_RTC_DRV_FM3130 is not set
# CONFIG_RTC_DRV_RX8581 is not set
# CONFIG_RTC_DRV_RX8025 is not set
# CONFIG_RTC_DRV_EM3027 is not set
# CONFIG_RTC_DRV_RV3029C2 is not set
# CONFIG_RTC_DRV_RV8803 is not set
# SPI RTC drivers
# CONFIG_RTC_DRV_M41T93 is not set
# CONFIG_RTC_DRV_M41T94 is not set
# CONFIG_RTC_DRV_DS1305 is not set
# CONFIG_RTC_DRV_DS1343 is not set
# CONFIG_RTC_DRV_DS1347 is not set
# CONFIG_RTC_DRV_DS1390 is not set
# CONFIG_RTC_DRV_MAX6902 is not set
# CONFIG_RTC_DRV_R9701 is not set
# CONFIG_RTC_DRV_RS5C348 is not set
# CONFIG_RTC_DRV_DS3234 is not set
# CONFIG_RTC_DRV_PCF2123 is not set
# CONFIG_RTC_DRV_RX4581 is not set
# CONFIG_RTC_DRV_MCP795 is not set
# Platform RTC drivers
# CONFIG_RTC_DRV_CMOS is not set
# CONFIG_RTC_DRV_DS1286 is not set
# CONFIG_RTC_DRV_DS1511 is not set
# CONFIG_RTC_DRV_DS1553 is not set
# CONFIG_RTC_DRV_DS1685_FAMILY is not set
# CONFIG_RTC_DRV_DS1742 is not set
# CONFIG_RTC_DRV_DS2404 is not set
# CONFIG_RTC_DRV_STK17TA8 is not set
# CONFIG_RTC_DRV_M48T86 is not set
# CONFIG_RTC_DRV_M48T35 is not set
# CONFIG_RTC_DRV_M48T59 is not set
# CONFIG_RTC_DRV_MSM6242 is not set
# CONFIG_RTC_DRV_BQ4802 is not set
# CONFIG_RTC_DRV_RP5C01 is not set
# CONFIG_RTC_DRV_V3020 is not set
# CONFIG_RTC_DRV_ZYNQMP is not set
# on-CPU RTC drivers
CONFIG_RTC_DRV_OMAP=y
# CONFIG_RTC_DRV_SNVS is not set
# HID Sensor RTC drivers
# CONFIG_RTC_DRV_HID_SENSOR_TIME is not set
CONFIG_DMADEVICES=y
# CONFIG_DMADEVICES_DEBUG is not set
# DMA Devices
CONFIG_DMA_ENGINE=y
CONFIG_DMA_VIRTUAL_CHANNELS=y
CONFIG_DMA_OF=y
CONFIG_DMA_OMAP=y
# CONFIG_FSL_EDMA is not set
# CONFIG_INTEL_IDMA64 is not set
# CONFIG_NBPFAXI_DMA is not set
CONFIG_TI_CPPI41=y
CONFIG_TI_DMA_CROSSBAR=y
CONFIG_TI_EDMA=y
# CONFIG_DW_DMAC is not set
# DMA Clients
# CONFIG_ASYNC_TX_DMA is not set
# CONFIG_DMATEST is not set
# CONFIG_AUXDISPLAY is not set
# CONFIG_UIO is not set
# CONFIG_VIRT_DRIVERS is not set
# Virtio drivers
# CONFIG_VIRTIO_MMIO is not set
# Microsoft Hyper-V guest support
# CONFIG_STAGING is not set
# CONFIG_WIMAX_GDM72XX_USB is not set
# CONFIG_WIMAX_GDM72XX_SDIO is not set
# CONFIG_CHROME_PLATFORMS is not set
CONFIG_CLKDEV_LOOKUP=y
CONFIG_HAVE_CLK_PREPARE=y
CONFIG_COMMON_CLK=y
# Common Clock Framework
# CONFIG_COMMON_CLK_SI5351 is not set
# CONFIG_COMMON_CLK_SI514 is not set
# CONFIG_COMMON_CLK_SI570 is not set
# CONFIG_COMMON_CLK_CDCE925 is not set
# CONFIG_CLK_TWL6040 is not set
# CONFIG_CLK_QORIQ is not set
# CONFIG_COMMON_CLK_PALMAS is not set
# CONFIG_COMMON_CLK_PWM is not set
# CONFIG_COMMON_CLK_PXA is not set
# CONFIG_COMMON_CLK_CDCE706 is not set
# Hardware Spinlock drivers
# CONFIG_HWSPINLOCK_OMAP is not set
# Clock Source drivers
CONFIG_CLKSRC_OF=y
CONFIG_CLKSRC_PROBE=y
CONFIG_CLKSRC_MMIO=y
CONFIG_CLKSRC_TI_32K=y
CONFIG_ARM_ARCH_TIMER=y
CONFIG_ARM_ARCH_TIMER_EVTSTREAM=y
# CONFIG_ARM_TIMER_SP804 is not set
# CONFIG_ATMEL_PIT is not set
# CONFIG_SH_TIMER_CMT is not set
# CONFIG_SH_TIMER_MTU2 is not set
# CONFIG_SH_TIMER_TMU is not set
# CONFIG_EM_TIMER_STI is not set
# CONFIG_MAILBOX is not set
# CONFIG_IOMMU_SUPPORT is not set
# Remoteproc drivers
# CONFIG_STE_MODEM_RPROC is not set
# CONFIG_WKUP_M3_RPROC is not set
# Rpmsg drivers
# SOC (System On Chip) specific Drivers
# CONFIG_SOC_BRCMSTB is not set
# CONFIG_SUNXI_SRAM is not set
# CONFIG_SOC_TI is not set
# CONFIG_PM_DEVFREQ is not set
CONFIG_EXTCON=y
# Extcon Device Drivers
# CONFIG_EXTCON_ADC_JACK is not set
# CONFIG_EXTCON_GPIO is not set
CONFIG_EXTCON_PALMAS=y
# CONFIG_EXTCON_RT8973A is not set
# CONFIG_EXTCON_SM5502 is not set
CONFIG_EXTCON_USB_GPIO=y
CONFIG_MEMORY=y
CONFIG_TI_EMIF=y
CONFIG_OMAP_GPMC=y
# CONFIG_OMAP_GPMC_DEBUG is not set
CONFIG_IIO=y
CONFIG_IIO_BUFFER=y
CONFIG_IIO_BUFFER_CB=y
CONFIG_IIO_KFIFO_BUF=y
CONFIG_IIO_TRIGGERED_BUFFER=y
CONFIG_IIO_TRIGGER=y
CONFIG_IIO_CONSUMERS_PER_TRIGGER=2
# Accelerometers
# CONFIG_BMA180 is not set
# CONFIG_BMC150_ACCEL is not set
# CONFIG_IIO_ST_ACCEL_3AXIS is not set
# CONFIG_KXSD9 is not set
# CONFIG_KXCJK1013 is not set
# CONFIG_MMA8452 is not set
# CONFIG_MMA9551 is not set
# CONFIG_MMA9553 is not set
# CONFIG_MXC4005 is not set
# CONFIG_STK8312 is not set
# CONFIG_STK8BA50 is not set
# Analog to digital converters
# CONFIG_AD7266 is not set
# CONFIG_AD7291 is not set
# CONFIG_AD7298 is not set
# CONFIG_AD7476 is not set
# CONFIG_AD7791 is not set
# CONFIG_AD7793 is not set
# CONFIG_AD7887 is not set
# CONFIG_AD7923 is not set
# CONFIG_AD799X is not set
# CONFIG_CC10001_ADC is not set
# CONFIG_HI8435 is not set
# CONFIG_MAX1027 is not set
CONFIG_MAX1363=y
# CONFIG_MCP320X is not set
# CONFIG_MCP3422 is not set
# CONFIG_NAU7802 is not set
# CONFIG_TI_ADC081C is not set
# CONFIG_TI_ADC128S052 is not set
CONFIG_TI_AM335X_ADC=y
# CONFIG_TWL4030_MADC is not set
# CONFIG_TWL6030_GPADC is not set
# CONFIG_VF610_ADC is not set
# Amplifiers
# CONFIG_AD8366 is not set
# Chemical Sensors
# CONFIG_VZ89X is not set
# Hid Sensor IIO Common
# SSP Sensor Common
# CONFIG_IIO_SSP_SENSORHUB is not set
# Digital to analog converters
# CONFIG_AD5064 is not set
# CONFIG_AD5360 is not set
# CONFIG_AD5380 is not set
# CONFIG_AD5421 is not set
# CONFIG_AD5446 is not set
# CONFIG_AD5449 is not set
# CONFIG_AD5504 is not set
# CONFIG_AD5624R_SPI is not set
# CONFIG_AD5686 is not set
# CONFIG_AD5755 is not set
# CONFIG_AD5764 is not set
# CONFIG_AD5791 is not set
# CONFIG_AD7303 is not set
# CONFIG_M62332 is not set
# CONFIG_MAX517 is not set
# CONFIG_MAX5821 is not set
# CONFIG_MCP4725 is not set
# CONFIG_MCP4922 is not set
# Frequency Synthesizers DDS/PLL
# Clock Generator/Distribution
# CONFIG_AD9523 is not set
# Phase-Locked Loop (PLL) frequency synthesizers
# CONFIG_ADF4350 is not set
# Digital gyroscope sensors
# CONFIG_ADIS16080 is not set
# CONFIG_ADIS16130 is not set
# CONFIG_ADIS16136 is not set
# CONFIG_ADIS16260 is not set
# CONFIG_ADXRS450 is not set
# CONFIG_BMG160 is not set
# CONFIG_IIO_ST_GYRO_3AXIS is not set
# CONFIG_ITG3200 is not set
# Humidity sensors
# CONFIG_DHT11 is not set
# CONFIG_HDC100X is not set
# CONFIG_HTU21 is not set
# CONFIG_SI7005 is not set
# CONFIG_SI7020 is not set
# Inertial measurement units
# CONFIG_ADIS16400 is not set
# CONFIG_ADIS16480 is not set
# CONFIG_KMX61 is not set
# CONFIG_INV_MPU6050_IIO is not set
# Light sensors
# CONFIG_ADJD_S311 is not set
# CONFIG_AL3320A is not set
# CONFIG_APDS9300 is not set
# CONFIG_APDS9960 is not set
# CONFIG_BH1750 is not set
# CONFIG_CM32181 is not set
# CONFIG_CM3232 is not set
# CONFIG_CM3323 is not set
# CONFIG_CM36651 is not set
# CONFIG_GP2AP020A00F is not set
# CONFIG_ISL29125 is not set
# CONFIG_JSA1212 is not set
# CONFIG_RPR0521 is not set
# CONFIG_LTR501 is not set
# CONFIG_OPT3001 is not set
# CONFIG_PA12203001 is not set
# CONFIG_STK3310 is not set
# CONFIG_TCS3414 is not set
# CONFIG_TCS3472 is not set
# CONFIG_SENSORS_TSL2563 is not set
# CONFIG_TSL4531 is not set
# CONFIG_US5182D is not set
# CONFIG_VCNL4000 is not set
# Magnetometer sensors
# CONFIG_AK8975 is not set
# CONFIG_AK09911 is not set
# CONFIG_BMC150_MAGN is not set
# CONFIG_MAG3110 is not set
# CONFIG_MMC35240 is not set
# CONFIG_IIO_ST_MAGN_3AXIS is not set
# Inclinometer sensors
# Triggers - standalone
# CONFIG_IIO_INTERRUPT_TRIGGER is not set
# CONFIG_IIO_SYSFS_TRIGGER is not set
# Digital potentiometers
# CONFIG_MCP4531 is not set
# Pressure sensors
# CONFIG_BMP280 is not set
# CONFIG_MPL115 is not set
# CONFIG_MPL3115 is not set
# CONFIG_MS5611 is not set
# CONFIG_MS5637 is not set
# CONFIG_IIO_ST_PRESS is not set
# CONFIG_T5403 is not set
# Lightning sensors
# CONFIG_AS3935 is not set
# Proximity sensors
# CONFIG_LIDAR_LITE_V2 is not set
# CONFIG_SX9500 is not set
# Temperature sensors
# CONFIG_MLX90614 is not set
# CONFIG_TMP006 is not set
# CONFIG_TSYS01 is not set
# CONFIG_TSYS02D is not set
CONFIG_PWM=y
CONFIG_PWM_SYSFS=y
# CONFIG_PWM_FSL_FTM is not set
# CONFIG_PWM_PCA9685 is not set
# CONFIG_PWM_TIECAP is not set
# CONFIG_PWM_TIEHRPWM is not set
CONFIG_PWM_TWL=y
CONFIG_PWM_TWL_LED=y
CONFIG_IRQCHIP=y
CONFIG_OMAP_IRQCHIP=y
# CONFIG_IPACK_BUS is not set
# CONFIG_RESET_CONTROLLER is not set
# CONFIG_FMC is not set
# PHY Subsystem
CONFIG_GENERIC_PHY=y
CONFIG_PHY_DM816X_USB=y
# CONFIG_PHY_PXA_28NM_HSIC is not set
# CONFIG_PHY_PXA_28NM_USB2 is not set
CONFIG_OMAP_CONTROL_PHY=y
CONFIG_OMAP_USB2=y
CONFIG_TI_PIPE3=y
CONFIG_TWL4030_USB=y
# CONFIG_BCM_KONA_USB2_PHY is not set
# CONFIG_POWERCAP is not set
# CONFIG_MCB is not set
# Performance monitor support
CONFIG_ARM_PMU=y
# CONFIG_RAS is not set
# Android
# CONFIG_ANDROID is not set
# CONFIG_NVMEM is not set
# CONFIG_STM is not set
# CONFIG_STM_DUMMY is not set
# CONFIG_STM_SOURCE_CONSOLE is not set
# CONFIG_INTEL_TH is not set
# FPGA Configuration Support
# CONFIG_FPGA is not set
# Firmware Drivers
# CONFIG_FIRMWARE_MEMMAP is not set
# File systems
CONFIG_DCACHE_WORD_ACCESS=y
CONFIG_EXT2_FS=y
# CONFIG_EXT2_FS_XATTR is not set
CONFIG_EXT3_FS=y
# CONFIG_EXT3_FS_POSIX_ACL is not set
# CONFIG_EXT3_FS_SECURITY is not set
CONFIG_EXT4_FS=y
# CONFIG_EXT4_FS_POSIX_ACL is not set
# CONFIG_EXT4_FS_SECURITY is not set
# CONFIG_EXT4_ENCRYPTION is not set
# CONFIG_EXT4_DEBUG is not set
CONFIG_JBD2=y
# CONFIG_JBD2_DEBUG is not set
CONFIG_FS_MBCACHE=y
# CONFIG_REISERFS_FS is not set
# CONFIG_JFS_FS is not set
# CONFIG_XFS_FS is not set
# CONFIG_GFS2_FS is not set
# CONFIG_OCFS2_FS is not set
# CONFIG_BTRFS_FS is not set
# CONFIG_NILFS2_FS is not set
# CONFIG_F2FS_FS is not set
CONFIG_FS_POSIX_ACL=y
CONFIG_EXPORTFS=y
CONFIG_FILE_LOCKING=y
CONFIG_FSNOTIFY=y
CONFIG_DNOTIFY=y
CONFIG_INOTIFY_USER=y
CONFIG_FANOTIFY=y
# CONFIG_FANOTIFY_ACCESS_PERMISSIONS is not set
# CONFIG_QUOTA is not set
# CONFIG_QUOTACTL is not set
CONFIG_AUTOFS4_FS=y
# CONFIG_FUSE_FS is not set
# CONFIG_OVERLAY_FS is not set
# Caches
# CONFIG_FSCACHE is not set
# CD-ROM/DVD Filesystems
# CONFIG_ISO9660_FS is not set
# CONFIG_UDF_FS is not set
# DOS/FAT/NT Filesystems
CONFIG_FAT_FS=y
CONFIG_MSDOS_FS=y
CONFIG_VFAT_FS=y
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
# CONFIG_NTFS_FS is not set
# Pseudo filesystems
CONFIG_PROC_FS=y
CONFIG_PROC_SYSCTL=y
CONFIG_PROC_PAGE_MONITOR=y
# CONFIG_PROC_CHILDREN is not set
CONFIG_KERNFS=y
CONFIG_SYSFS=y
CONFIG_TMPFS=y
CONFIG_TMPFS_POSIX_ACL=y
CONFIG_TMPFS_XATTR=y
# CONFIG_HUGETLB_PAGE is not set
CONFIG_CONFIGFS_FS=y
CONFIG_MISC_FILESYSTEMS=y
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
# CONFIG_ECRYPT_FS is not set
# CONFIG_HFS_FS is not set
# CONFIG_HFSPLUS_FS is not set
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
# CONFIG_EFS_FS is not set
CONFIG_JFFS2_FS=m
CONFIG_JFFS2_FS_DEBUG=0
CONFIG_JFFS2_FS_WRITEBUFFER=y
# CONFIG_JFFS2_FS_WBUF_VERIFY is not set
CONFIG_JFFS2_SUMMARY=y
CONFIG_JFFS2_FS_XATTR=y
CONFIG_JFFS2_FS_POSIX_ACL=y
CONFIG_JFFS2_FS_SECURITY=y
CONFIG_JFFS2_COMPRESSION_OPTIONS=y
CONFIG_JFFS2_ZLIB=y
CONFIG_JFFS2_LZO=y
CONFIG_JFFS2_RTIME=y
CONFIG_JFFS2_RUBIN=y
# CONFIG_JFFS2_CMODE_NONE is not set
CONFIG_JFFS2_CMODE_PRIORITY=y
# CONFIG_JFFS2_CMODE_SIZE is not set
# CONFIG_JFFS2_CMODE_FAVOURLZO is not set
CONFIG_UBIFS_FS=m
# CONFIG_UBIFS_FS_ADVANCED_COMPR is not set
CONFIG_UBIFS_FS_LZO=y
CONFIG_UBIFS_FS_ZLIB=y
# CONFIG_UBIFS_ATIME_SUPPORT is not set
# CONFIG_LOGFS is not set
CONFIG_CRAMFS=y
# CONFIG_SQUASHFS is not set
# CONFIG_SQUASHFS_FILE_CACHE is not set
# CONFIG_SQUASHFS_FILE_DIRECT is not set
# CONFIG_SQUASHFS_DECOMP_SINGLE is not set
# CONFIG_SQUASHFS_DECOMP_MULTI is not set
# CONFIG_SQUASHFS_DECOMP_MULTI_PERCPU is not set
# CONFIG_VXFS_FS is not set
# CONFIG_MINIX_FS is not set
# CONFIG_OMFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
# CONFIG_QNX6FS_FS is not set
CONFIG_ROMFS_FS=y
CONFIG_ROMFS_BACKED_BY_BLOCK=y
# CONFIG_ROMFS_BACKED_BY_MTD is not set
# CONFIG_ROMFS_BACKED_BY_BOTH is not set
CONFIG_ROMFS_ON_BLOCK=y
# CONFIG_PSTORE is not set
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
CONFIG_NETWORK_FILESYSTEMS=y
CONFIG_NFS_FS=y
CONFIG_NFS_V2=y
CONFIG_NFS_V3=y
CONFIG_NFS_V3_ACL=y
CONFIG_NFS_V4=y
# CONFIG_NFS_SWAP is not set
# CONFIG_NFS_V4_1 is not set
CONFIG_ROOT_NFS=y
# CONFIG_NFS_USE_LEGACY_DNS is not set
CONFIG_NFS_USE_KERNEL_DNS=y
# CONFIG_NFSD is not set
CONFIG_GRACE_PERIOD=y
CONFIG_LOCKD=y
CONFIG_LOCKD_V4=y
CONFIG_NFS_ACL_SUPPORT=y
CONFIG_NFS_COMMON=y
CONFIG_SUNRPC=y
CONFIG_SUNRPC_GSS=y
# CONFIG_SUNRPC_DEBUG is not set
# CONFIG_CEPH_FS is not set
# CONFIG_CIFS is not set
# CONFIG_NCP_FS is not set
# CONFIG_CODA_FS is not set
# CONFIG_AFS_FS is not set
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="iso8859-1"
CONFIG_NLS_CODEPAGE_437=y
# CONFIG_NLS_CODEPAGE_737 is not set
# CONFIG_NLS_CODEPAGE_775 is not set
CONFIG_NLS_CODEPAGE_850=y
# CONFIG_NLS_CODEPAGE_852 is not set
# CONFIG_NLS_CODEPAGE_855 is not set
# CONFIG_NLS_CODEPAGE_857 is not set
# CONFIG_NLS_CODEPAGE_860 is not set
# CONFIG_NLS_CODEPAGE_861 is not set
# CONFIG_NLS_CODEPAGE_862 is not set
# CONFIG_NLS_CODEPAGE_863 is not set
# CONFIG_NLS_CODEPAGE_864 is not set
# CONFIG_NLS_CODEPAGE_865 is not set
# CONFIG_NLS_CODEPAGE_866 is not set
# CONFIG_NLS_CODEPAGE_869 is not set
# CONFIG_NLS_CODEPAGE_936 is not set
# CONFIG_NLS_CODEPAGE_950 is not set
# CONFIG_NLS_CODEPAGE_932 is not set
# CONFIG_NLS_CODEPAGE_949 is not set
# CONFIG_NLS_CODEPAGE_874 is not set
# CONFIG_NLS_ISO8859_8 is not set
# CONFIG_NLS_CODEPAGE_1250 is not set
# CONFIG_NLS_CODEPAGE_1251 is not set
# CONFIG_NLS_ASCII is not set
CONFIG_NLS_ISO8859_1=y
# CONFIG_NLS_ISO8859_2 is not set
# CONFIG_NLS_ISO8859_3 is not set
# CONFIG_NLS_ISO8859_4 is not set
# CONFIG_NLS_ISO8859_5 is not set
# CONFIG_NLS_ISO8859_6 is not set
# CONFIG_NLS_ISO8859_7 is not set
# CONFIG_NLS_ISO8859_9 is not set
# CONFIG_NLS_ISO8859_13 is not set
# CONFIG_NLS_ISO8859_14 is not set
# CONFIG_NLS_ISO8859_15 is not set
# CONFIG_NLS_KOI8_R is not set
# CONFIG_NLS_KOI8_U is not set
# CONFIG_NLS_MAC_ROMAN is not set
# CONFIG_NLS_MAC_CELTIC is not set
# CONFIG_NLS_MAC_CENTEURO is not set
# CONFIG_NLS_MAC_CROATIAN is not set
# CONFIG_NLS_MAC_CYRILLIC is not set
# CONFIG_NLS_MAC_GAELIC is not set
# CONFIG_NLS_MAC_GREEK is not set
# CONFIG_NLS_MAC_ICELAND is not set
# CONFIG_NLS_MAC_INUIT is not set
# CONFIG_NLS_MAC_ROMANIAN is not set
# CONFIG_NLS_MAC_TURKISH is not set
# CONFIG_NLS_UTF8 is not set
# CONFIG_DLM is not set
# Kernel hacking
# printk and dmesg options
CONFIG_PRINTK_TIME=y
CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4
# CONFIG_BOOT_PRINTK_DELAY is not set
CONFIG_DYNAMIC_DEBUG=y
# Compile-time checks and compiler options
CONFIG_DEBUG_INFO=y
# CONFIG_DEBUG_INFO_REDUCED is not set
# CONFIG_DEBUG_INFO_SPLIT is not set
# CONFIG_DEBUG_INFO_DWARF4 is not set
# CONFIG_GDB_SCRIPTS is not set
CONFIG_ENABLE_WARN_DEPRECATED=y
CONFIG_ENABLE_MUST_CHECK=y
CONFIG_FRAME_WARN=1024
# CONFIG_STRIP_ASM_SYMS is not set
# CONFIG_READABLE_ASM is not set
# CONFIG_UNUSED_SYMBOLS is not set
# CONFIG_PAGE_OWNER is not set
CONFIG_DEBUG_FS=y
# CONFIG_HEADERS_CHECK is not set
# CONFIG_DEBUG_SECTION_MISMATCH is not set
CONFIG_SECTION_MISMATCH_WARN_ONLY=y
# CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
CONFIG_MAGIC_SYSRQ=y
CONFIG_MAGIC_SYSRQ_DEFAULT_ENABLE=0x1
CONFIG_DEBUG_KERNEL=y
# Memory Debugging
# CONFIG_PAGE_EXTENSION is not set
# CONFIG_DEBUG_PAGEALLOC is not set
# CONFIG_DEBUG_OBJECTS is not set
# CONFIG_DEBUG_SLAB is not set
CONFIG_HAVE_DEBUG_KMEMLEAK=y
# CONFIG_DEBUG_KMEMLEAK is not set
# CONFIG_DEBUG_STACK_USAGE is not set
# CONFIG_DEBUG_VM is not set
# CONFIG_DEBUG_MEMORY_INIT is not set
# CONFIG_DEBUG_HIGHMEM is not set
# CONFIG_DEBUG_SHIRQ is not set
# Debug Lockups and Hangs
# CONFIG_LOCKUP_DETECTOR is not set
# CONFIG_DETECT_HUNG_TASK is not set
# CONFIG_PANIC_ON_OOPS is not set
CONFIG_PANIC_ON_OOPS_VALUE=0
CONFIG_PANIC_TIMEOUT=0
# CONFIG_SCHED_DEBUG is not set
CONFIG_SCHED_INFO=y
CONFIG_SCHEDSTATS=y
# CONFIG_SCHED_STACK_END_CHECK is not set
# CONFIG_DEBUG_TIMEKEEPING is not set
CONFIG_TIMER_STATS=y
# Lock Debugging (spinlocks, mutexes, etc...)
# CONFIG_DEBUG_RT_MUTEXES is not set
CONFIG_DEBUG_SPINLOCK=y
CONFIG_DEBUG_MUTEXES=y
# CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set
CONFIG_DEBUG_LOCK_ALLOC=y
CONFIG_PROVE_LOCKING=y
CONFIG_LOCKDEP=y
# CONFIG_LOCK_STAT is not set
# CONFIG_DEBUG_LOCKDEP is not set
# CONFIG_DEBUG_ATOMIC_SLEEP is not set
# CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
# CONFIG_LOCK_TORTURE_TEST is not set
CONFIG_TRACE_IRQFLAGS=y
CONFIG_STACKTRACE=y
# CONFIG_DEBUG_KOBJECT is not set
# CONFIG_DEBUG_BUGVERBOSE is not set
# CONFIG_DEBUG_LIST is not set
# CONFIG_DEBUG_PI_LIST is not set
# CONFIG_DEBUG_SG is not set
# CONFIG_DEBUG_NOTIFIERS is not set
# CONFIG_DEBUG_CREDENTIALS is not set
# RCU Debugging
CONFIG_PROVE_RCU=y
# CONFIG_PROVE_RCU_REPEATEDLY is not set
# CONFIG_SPARSE_RCU_POINTER is not set
# CONFIG_TORTURE_TEST is not set
# CONFIG_RCU_TORTURE_TEST is not set
# CONFIG_RCU_TRACE is not set
# CONFIG_RCU_EQS_DEBUG is not set
# CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
# CONFIG_NOTIFIER_ERROR_INJECTION is not set
# CONFIG_FAULT_INJECTION is not set
# CONFIG_LATENCYTOP is not set
CONFIG_HAVE_FUNCTION_TRACER=y
CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
CONFIG_HAVE_DYNAMIC_FTRACE=y
CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
CONFIG_HAVE_SYSCALL_TRACEPOINTS=y
CONFIG_HAVE_C_RECORDMCOUNT=y
CONFIG_TRACE_CLOCK=y
CONFIG_RING_BUFFER=y
CONFIG_RING_BUFFER_ALLOW_SWAP=y
CONFIG_TRACING_SUPPORT=y
# CONFIG_FTRACE is not set
# CONFIG_BRANCH_PROFILE_NONE is not set
# CONFIG_PROFILE_ANNOTATED_BRANCHES is not set
# CONFIG_PROFILE_ALL_BRANCHES is not set
# Runtime Testing
# CONFIG_LKDTM is not set
# CONFIG_TEST_LIST_SORT is not set
# CONFIG_KPROBES_SANITY_TEST is not set
# CONFIG_BACKTRACE_SELF_TEST is not set
# CONFIG_RBTREE_TEST is not set
# CONFIG_INTERVAL_TREE_TEST is not set
# CONFIG_PERCPU_TEST is not set
# CONFIG_ATOMIC64_SELFTEST is not set
# CONFIG_TEST_HEXDUMP is not set
# CONFIG_TEST_STRING_HELPERS is not set
# CONFIG_TEST_KSTRTOX is not set
# CONFIG_TEST_PRINTF is not set
# CONFIG_TEST_RHASHTABLE is not set
# CONFIG_DMA_API_DEBUG is not set
# CONFIG_TEST_LKM is not set
# CONFIG_TEST_USER_COPY is not set
# CONFIG_TEST_BPF is not set
# CONFIG_TEST_FIRMWARE is not set
# CONFIG_TEST_UDELAY is not set
# CONFIG_MEMTEST is not set
# CONFIG_TEST_STATIC_KEYS is not set
# CONFIG_SAMPLES is not set
CONFIG_HAVE_ARCH_KGDB=y
# CONFIG_KGDB is not set
# CONFIG_ARM_PTDUMP is not set
# CONFIG_STRICT_DEVMEM is not set
CONFIG_ARM_UNWIND=y
# CONFIG_DEBUG_USER is not set
CONFIG_DEBUG_LL=y
# CONFIG_DEBUG_OMAP2UART1 is not set
# CONFIG_DEBUG_OMAP2UART2 is not set
# CONFIG_DEBUG_OMAP2UART3 is not set
# CONFIG_DEBUG_OMAP3UART3 is not set
# CONFIG_DEBUG_OMAP4UART3 is not set
# CONFIG_DEBUG_OMAP3UART4 is not set
# CONFIG_DEBUG_OMAP4UART4 is not set
# CONFIG_DEBUG_TI81XXUART1 is not set
# CONFIG_DEBUG_TI81XXUART2 is not set
# CONFIG_DEBUG_TI81XXUART3 is not set
CONFIG_DEBUG_AM33XXUART1=y
# CONFIG_DEBUG_ZOOM_UART is not set
# CONFIG_DEBUG_ICEDCC is not set
# CONFIG_DEBUG_SEMIHOSTING is not set
# CONFIG_DEBUG_LL_UART_8250 is not set
# CONFIG_DEBUG_LL_UART_PL01X is not set
CONFIG_DEBUG_OMAP2PLUS_UART=y
CONFIG_DEBUG_LL_INCLUDE="debug/omap2plus.S"
# CONFIG_DEBUG_UART_8250 is not set
# CONFIG_DEBUG_UART_BCM63XX is not set
CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h"
CONFIG_EARLY_PRINTK=y
# CONFIG_ARM_KPROBES_TEST is not set
# CONFIG_PID_IN_CONTEXTIDR is not set
# CONFIG_DEBUG_SET_MODULE_RONX is not set
# CONFIG_CORESIGHT is not set
# Security options
CONFIG_KEYS=y
# CONFIG_PERSISTENT_KEYRINGS is not set
# CONFIG_BIG_KEYS is not set
# CONFIG_ENCRYPTED_KEYS is not set
# CONFIG_SECURITY_DMESG_RESTRICT is not set
CONFIG_SECURITY=y
# CONFIG_SECURITYFS is not set
# CONFIG_SECURITY_NETWORK is not set
# CONFIG_SECURITY_PATH is not set
# CONFIG_SECURITY_SMACK is not set
# CONFIG_SECURITY_TOMOYO is not set
# CONFIG_SECURITY_APPARMOR is not set
# CONFIG_SECURITY_YAMA is not set
CONFIG_INTEGRITY=y
# CONFIG_INTEGRITY_SIGNATURE is not set
CONFIG_INTEGRITY_AUDIT=y
# CONFIG_IMA is not set
# CONFIG_EVM is not set
# CONFIG_DEFAULT_SECURITY_SELINUX is not set
# CONFIG_DEFAULT_SECURITY_TOMOYO is not set
# CONFIG_DEFAULT_SECURITY_APPARMOR is not set
CONFIG_DEFAULT_SECURITY_DAC=y
CONFIG_DEFAULT_SECURITY=""
CONFIG_CRYPTO=y
# Crypto core or helper
CONFIG_CRYPTO_ALGAPI=y
CONFIG_CRYPTO_ALGAPI2=y
CONFIG_CRYPTO_AEAD=y
CONFIG_CRYPTO_AEAD2=y
CONFIG_CRYPTO_BLKCIPHER=y
CONFIG_CRYPTO_BLKCIPHER2=y
CONFIG_CRYPTO_HASH=y
CONFIG_CRYPTO_HASH2=y
CONFIG_CRYPTO_RNG=y
CONFIG_CRYPTO_RNG2=y
CONFIG_CRYPTO_RNG_DEFAULT=y
CONFIG_CRYPTO_PCOMP2=y
CONFIG_CRYPTO_AKCIPHER2=y
# CONFIG_CRYPTO_RSA is not set
CONFIG_CRYPTO_MANAGER=y
CONFIG_CRYPTO_MANAGER2=y
# CONFIG_CRYPTO_USER is not set
CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
CONFIG_CRYPTO_GF128MUL=y
CONFIG_CRYPTO_NULL=y
CONFIG_CRYPTO_NULL2=y
CONFIG_CRYPTO_WORKQUEUE=y
# CONFIG_CRYPTO_CRYPTD is not set
# CONFIG_CRYPTO_MCRYPTD is not set
CONFIG_CRYPTO_AUTHENC=y
CONFIG_CRYPTO_TEST=m
# Authenticated Encryption with Associated Data
CONFIG_CRYPTO_CCM=y
CONFIG_CRYPTO_GCM=y
# CONFIG_CRYPTO_CHACHA20POLY1305 is not set
CONFIG_CRYPTO_SEQIV=y
CONFIG_CRYPTO_ECHAINIV=m
# Block modes
# CONFIG_CRYPTO_CBC is not set
CONFIG_CRYPTO_CTR=y
# CONFIG_CRYPTO_CTS is not set
CONFIG_CRYPTO_ECB=y
# CONFIG_CRYPTO_LRW is not set
CONFIG_CRYPTO_PCBC=y
# CONFIG_CRYPTO_XTS is not set
# CONFIG_CRYPTO_KEYWRAP is not set
# Hash modes
CONFIG_CRYPTO_CMAC=y
CONFIG_CRYPTO_HMAC=y
# CONFIG_CRYPTO_XCBC is not set
# CONFIG_CRYPTO_VMAC is not set
# Digest
CONFIG_CRYPTO_CRC32C=y
# CONFIG_CRYPTO_CRC32 is not set
CONFIG_CRYPTO_CRCT10DIF=y
CONFIG_CRYPTO_GHASH=y
# CONFIG_CRYPTO_POLY1305 is not set
# CONFIG_CRYPTO_MD4 is not set
CONFIG_CRYPTO_MD5=y
CONFIG_CRYPTO_MICHAEL_MIC=y
# CONFIG_CRYPTO_RMD128 is not set
# CONFIG_CRYPTO_RMD160 is not set
# CONFIG_CRYPTO_RMD256 is not set
# CONFIG_CRYPTO_RMD320 is not set
CONFIG_CRYPTO_SHA1=y
CONFIG_CRYPTO_SHA256=y
CONFIG_CRYPTO_SHA512=y
# CONFIG_CRYPTO_TGR192 is not set
# CONFIG_CRYPTO_WP512 is not set
# Ciphers
CONFIG_CRYPTO_AES=y
# CONFIG_CRYPTO_ANUBIS is not set
CONFIG_CRYPTO_ARC4=y
# CONFIG_CRYPTO_BLOWFISH is not set
# CONFIG_CRYPTO_CAMELLIA is not set
# CONFIG_CRYPTO_CAST5 is not set
# CONFIG_CRYPTO_CAST6 is not set
CONFIG_CRYPTO_DES=y
CONFIG_CRYPTO_FCRYPT=y
# CONFIG_CRYPTO_KHAZAD is not set
# CONFIG_CRYPTO_SALSA20 is not set
# CONFIG_CRYPTO_CHACHA20 is not set
# CONFIG_CRYPTO_SEED is not set
# CONFIG_CRYPTO_SERPENT is not set
# CONFIG_CRYPTO_TEA is not set
# CONFIG_CRYPTO_TWOFISH is not set
# Compression
CONFIG_CRYPTO_DEFLATE=y
# CONFIG_CRYPTO_ZLIB is not set
CONFIG_CRYPTO_LZO=y
# CONFIG_CRYPTO_842 is not set
# CONFIG_CRYPTO_LZ4 is not set
# CONFIG_CRYPTO_LZ4HC is not set
# Random Number Generation
# CONFIG_CRYPTO_ANSI_CPRNG is not set
CONFIG_CRYPTO_DRBG_MENU=y
CONFIG_CRYPTO_DRBG_HMAC=y
# CONFIG_CRYPTO_DRBG_HASH is not set
# CONFIG_CRYPTO_DRBG_CTR is not set
CONFIG_CRYPTO_DRBG=y
CONFIG_CRYPTO_JITTERENTROPY=y
CONFIG_CRYPTO_USER_API=y
CONFIG_CRYPTO_USER_API_HASH=y
CONFIG_CRYPTO_USER_API_SKCIPHER=y
# CONFIG_CRYPTO_USER_API_RNG is not set
# CONFIG_CRYPTO_USER_API_AEAD is not set
CONFIG_CRYPTO_HW=y
# CONFIG_CRYPTO_DEV_OMAP_SHAM is not set
# CONFIG_CRYPTO_DEV_OMAP_AES is not set
# CONFIG_CRYPTO_DEV_OMAP_DES is not set
# CONFIG_ASYMMETRIC_KEY_TYPE is not set
# Certificates for signature checking
# CONFIG_SYSTEM_TRUSTED_KEYRING is not set
# CONFIG_ARM_CRYPTO is not set
# CONFIG_BINARY_PRINTF is not set
# Library routines
CONFIG_BITREVERSE=y
# CONFIG_HAVE_ARCH_BITREVERSE is not set
CONFIG_RATIONAL=y
CONFIG_GENERIC_STRNCPY_FROM_USER=y
CONFIG_GENERIC_STRNLEN_USER=y
CONFIG_GENERIC_NET_UTILS=y
CONFIG_GENERIC_PCI_IOMAP=y
CONFIG_GENERIC_IO=y
CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y
CONFIG_CRC_CCITT=y
CONFIG_CRC16=y
CONFIG_CRC_T10DIF=y
CONFIG_CRC_ITU_T=y
CONFIG_CRC32=y
# CONFIG_CRC32_SELFTEST is not set
CONFIG_CRC32_SLICEBY8=y
# CONFIG_CRC32_SLICEBY4 is not set
# CONFIG_CRC32_SARWATE is not set
# CONFIG_CRC32_BIT is not set
CONFIG_CRC7=y
CONFIG_LIBCRC32C=y
CONFIG_CRC8=y
CONFIG_AUDIT_GENERIC=y
# CONFIG_AUDIT_ARCH_COMPAT_GENERIC is not set
# CONFIG_RANDOM32_SELFTEST is not set
CONFIG_ZLIB_INFLATE=y
CONFIG_ZLIB_DEFLATE=y
CONFIG_LZO_COMPRESS=y
CONFIG_LZO_DECOMPRESS=y
CONFIG_LZ4_DECOMPRESS=y
CONFIG_XZ_DEC=y
CONFIG_XZ_DEC_X86=y
CONFIG_XZ_DEC_POWERPC=y
CONFIG_XZ_DEC_IA64=y
CONFIG_XZ_DEC_ARM=y
CONFIG_XZ_DEC_ARMTHUMB=y
CONFIG_XZ_DEC_SPARC=y
CONFIG_XZ_DEC_BCJ=y
# CONFIG_XZ_DEC_TEST is not set
CONFIG_DECOMPRESS_GZIP=y
CONFIG_DECOMPRESS_BZIP2=y
CONFIG_DECOMPRESS_LZMA=y
CONFIG_DECOMPRESS_XZ=y
CONFIG_DECOMPRESS_LZO=y
CONFIG_DECOMPRESS_LZ4=y
CONFIG_GENERIC_ALLOCATOR=y
CONFIG_BCH=y
CONFIG_ASSOCIATIVE_ARRAY=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_IOPORT_MAP=y
CONFIG_HAS_DMA=y
CONFIG_DQL=y
CONFIG_GLOB=y
# CONFIG_GLOB_SELFTEST is not set
CONFIG_NLATTR=y
CONFIG_ARCH_HAS_ATOMIC64_DEC_IF_POSITIVE=y
# CONFIG_CORDIC is not set
CONFIG_DDR=y
CONFIG_LIBFDT=y
CONFIG_OID_REGISTRY=y
CONFIG_FONT_SUPPORT=y
CONFIG_FONTS=y
CONFIG_FONT_8x8=y
CONFIG_FONT_8x16=y
# CONFIG_FONT_6x11 is not set
# CONFIG_FONT_7x14 is not set
# CONFIG_FONT_PEARL_8x8 is not set
# CONFIG_FONT_ACORN_8x8 is not set
# CONFIG_FONT_MINI_4x6 is not set
# CONFIG_FONT_6x10 is not set
# CONFIG_FONT_SUN8x16 is not set
# CONFIG_FONT_SUN12x22 is not set
# CONFIG_FONT_10x18 is not set
# CONFIG_SG_SPLIT is not set
CONFIG_ARCH_HAS_SG_CHAIN=y
# CONFIG_VIRTUALIZATION is not set
Finally, output from dmesg:
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 475496K/524288K available (7433K kernel code, 400K rwdata, 2536K rodata, 268K init, 8240K bss, 24216K reserved, 24576K cma-reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xe0800000 - 0xff800000   ( 496 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc09c4840   (9971 kB)
[    0.000000]       .init : 0xc09c5000 - 0xc0a08000   ( 268 kB)
[    0.000000]       .data : 0xc0a08000 - 0xc0a6c218   ( 401 kB)
[    0.000000]        .bss : 0xc0a6f000 - 0xc127b168   (8241 kB)
[    0.000000] Running RCU self tests
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[    0.000000] OMAP clockevent source: timer2 at 25000000 Hz
[    0.000021] sched_clock: 32 bits at 25MHz, resolution 40ns, wraps every 85899345900ns
[    0.000052] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
[    0.000110] OMAP clocksource: timer1 at 25000000 Hz
[    0.001119] Console: colour dummy device 80x30
[    0.001192] Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar
[    0.001205] ... MAX_LOCKDEP_SUBCLASSES:  8
[    0.001214] ... MAX_LOCK_DEPTH:          48
[    0.001225] ... MAX_LOCKDEP_KEYS:        8191
[    0.001234] ... CLASSHASH_SIZE:          4096
[    0.001244] ... MAX_LOCKDEP_ENTRIES:     32768
[    0.001254] ... MAX_LOCKDEP_CHAINS:      65536
[    0.001263] ... CHAINHASH_SIZE:          32768
[    0.001273]  memory used by lock dependency info: 5167 kB
[    0.001283]  per task-struct memory footprint: 1536 bytes
[    0.001313] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
[    0.098240] pid_max: default: 32768 minimum: 301
[    0.098540] Security Framework initialized
[    0.098677] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.098695] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.102841] Initializing cgroup subsys io
[    0.102983] Initializing cgroup subsys memory
[    0.103084] Initializing cgroup subsys devices
[    0.103204] Initializing cgroup subsys freezer
[    0.103372] Initializing cgroup subsys perf_event
[    0.103470] CPU: Testing write buffer coherency: ok
[    0.105705] Setting up static identity map for 0x800082c0 - 0x80008330
[    0.121395] devtmpfs: initialized
[    0.121633] device: 'platform': device_add
[    0.122234] device: 'cpu': device_add
[    0.122638] device: 'container': device_add
[    0.165699] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    0.223852] omap_hwmod: tptc0 using broken dt data from edma
[    0.224479] omap_hwmod: tptc1 using broken dt data from edma
[    0.225071] omap_hwmod: tptc2 using broken dt data from edma
[    0.236257] omap_hwmod: debugss: _wait_target_disable failed
[    0.293702] device: 'workqueue': device_add
[    0.294327] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.297744] pinctrl core: initialized pinctrl subsystem
[    0.299217] device: 'reg-dummy': device_add
[    0.299936] bus: 'platform': add driver reg-dummy
[    0.300004] bus: 'platform': driver_probe_device: matched device reg-dummy with driver reg-dummy
[    0.300032] bus: 'platform': really_probe: probing driver reg-dummy with device reg-dummy
[    0.300561] device: 'regulator.0': device_add
[    0.302076] driver: 'reg-dummy': driver_bound: bound to device 'reg-dummy'
[    0.302195] bus: 'platform': really_probe: bound device reg-dummy to driver reg-dummy
[    0.305033] NET: Registered protocol family 16
[    0.313137] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.313753] bus: 'platform': add driver omap_gpio
[    0.314081] device: 'vtcon0': device_add
[    0.314781] bus: 'platform': add driver sram
[    0.314948] bus: 'platform': add driver syscon
[    0.315544] bus: 'i2c': add driver dummy
[    0.315838] cpuidle: using governor ladder
[    0.315868] cpuidle: using governor menu
[    0.315903] bus: 'platform': add driver omap-gpmc
[    0.316042] bus: 'platform': add driver omap_l3_smx
[    0.316170] bus: 'platform': add driver omap_l3_noc
[    0.316708] of_platform_bus_create() - skipping /chosen, no compatible prop
[    0.316736] of_platform_bus_create() - skipping /aliases, no compatible prop
[    0.316754] of_platform_bus_create() - skipping /memory, no compatible prop
[    0.316772] of_platform_bus_create() - skipping /cpus, no compatible prop
[    0.317213] device: 'pmu': device_add
[    0.317767] device: 'soc': device_add
[    0.318137]    create child: /soc/mpu
[    0.318327] device: 'soc:mpu': device_add
[    0.319125] device: 'ocp': device_add
[    0.319652]    create child: /ocp/l4_wkup@44c00000
[    0.319743] device: 'ocp:l4_wkup@44c00000': device_add
[    0.320115]    create child: /ocp/l4_wkup@44c00000/wkup_m3@100000
[    0.320356] device: '44d00000.wkup_m3': device_add
[    0.320781]    create child: /ocp/l4_wkup@44c00000/prcm@200000
[    0.320950] device: '44e00000.prcm': device_add
[    0.321321]    create child: /ocp/l4_wkup@44c00000/scm@210000
[    0.321499] device: '44e10000.scm': device_add
[    0.321864]    create child: /ocp/l4_wkup@44c00000/scm@210000/pinmux@800
[    0.322056] device: '44e10800.pinmux': device_add
[    0.322397]    create child: /ocp/l4_wkup@44c00000/scm@210000/scm_conf@0
[    0.322590] device: '44e10000.scm_conf': device_add
[    0.322945]    create child: /ocp/l4_wkup@44c00000/scm@210000/wkup_m3_ipc@1324
[    0.323356] device: '44e11324.wkup_m3_ipc': device_add
[    0.323717]    create child: /ocp/l4_wkup@44c00000/scm@210000/clockdomains
[    0.323738] of_platform_bus_create() - skipping /ocp/l4_wkup@44c00000/scm@210000/clockdomains, no compatible prop
[    0.323757]    create child: /ocp/interrupt-controller@48200000
[    0.323912] device: '48200000.interrupt-controller': device_add
[    0.324261]    create child: /ocp/edma@49000000
[    0.324823] device: '49000000.edma': device_add
[    0.325306]    create child: /ocp/gpio@44e07000
[    0.325613] device: '44e07000.gpio': device_add
[    0.326027] bus: 'platform': driver_probe_device: matched device 44e07000.gpio with driver omap_gpio
[    0.326052] bus: 'platform': really_probe: probing driver omap_gpio with device 44e07000.gpio
[    0.326912] device: 'gpiochip0': device_add
[    0.327579] gpiochip_add: registered GPIOs 0 to 31 on device: gpio
[    0.329169] OMAP GPIO hardware version 0.1
[    0.329318] driver: 'omap_gpio': driver_bound: bound to device '44e07000.gpio'
[    0.329352] bus: 'platform': really_probe: bound device 44e07000.gpio to driver omap_gpio
[    0.329399]    create child: /ocp/gpio@4804c000
[    0.329764] device: '4804c000.gpio': device_add
[    0.330252] bus: 'platform': driver_probe_device: matched device 4804c000.gpio with driver omap_gpio
[    0.330277] bus: 'platform': really_probe: probing driver omap_gpio with device 4804c000.gpio
[    0.330689] device: 'gpiochip32': device_add
[    0.331051] gpiochip_add: registered GPIOs 32 to 63 on device: gpio
[    0.332451] driver: 'omap_gpio': driver_bound: bound to device '4804c000.gpio'
[    0.332481] bus: 'platform': really_probe: bound device 4804c000.gpio to driver omap_gpio
[    0.332525]    create child: /ocp/gpio@481ac000
[    0.332852] device: '481ac000.gpio': device_add
[    0.333276] bus: 'platform': driver_probe_device: matched device 481ac000.gpio with driver omap_gpio
[    0.333300] bus: 'platform': really_probe: probing driver omap_gpio with device 481ac000.gpio
[    0.333703] device: 'gpiochip64': device_add
[    0.334075] gpiochip_add: registered GPIOs 64 to 95 on device: gpio
[    0.335389] driver: 'omap_gpio': driver_bound: bound to device '481ac000.gpio'
[    0.335419] bus: 'platform': really_probe: bound device 481ac000.gpio to driver omap_gpio
[    0.335461]    create child: /ocp/gpio@481ae000
[    0.335783] device: '481ae000.gpio': device_add
[    0.336199] bus: 'platform': driver_probe_device: matched device 481ae000.gpio with driver omap_gpio
[    0.336222] bus: 'platform': really_probe: probing driver omap_gpio with device 481ae000.gpio
[    0.336603] device: 'gpiochip96': device_add
[    0.336960] gpiochip_add: registered GPIOs 96 to 127 on device: gpio
[    0.338338] driver: 'omap_gpio': driver_bound: bound to device '481ae000.gpio'
[    0.338370] bus: 'platform': really_probe: bound device 481ae000.gpio to driver omap_gpio
[    0.338412]    create child: /ocp/serial@44e09000
[    0.338753] device: '44e09000.serial': device_add
[    0.339297]    create child: /ocp/serial@48022000
[    0.339330]    create child: /ocp/serial@48024000
[    0.339357]    create child: /ocp/serial@481a6000
[    0.339382]    create child: /ocp/serial@481a8000
[    0.339407]    create child: /ocp/serial@481aa000
[    0.339431]    create child: /ocp/i2c@44e0b000
[    0.339745] device: '44e0b000.i2c': device_add
[    0.340167]    create child: /ocp/i2c@4802a000
[    0.340197]    create child: /ocp/i2c@4819c000
[    0.340222]    create child: /ocp/mmc@48060000
[    0.340498] device: '48060000.mmc': device_add
[    0.340909]    create child: /ocp/mmc@481d8000
[    0.340939]    create child: /ocp/mmc@47810000
[    0.341247] device: '47810000.mmc': device_add
[    0.341669]    create child: /ocp/spinlock@480ca000
[    0.341816] device: '480ca000.spinlock': device_add
[    0.342219]    create child: /ocp/wdt@44e35000
[    0.342517] device: '44e35000.wdt': device_add
[    0.342917]    create child: /ocp/can@481cc000
[    0.342947]    create child: /ocp/can@481d0000
[    0.342973]    create child: /ocp/mailbox@480C8000
[    0.343270] device: '480c8000.mailbox': device_add
[    0.343690]    create child: /ocp/timer@44e31000
[    0.343720]    create child: /ocp/timer@48040000
[    0.343745]    create child: /ocp/timer@48042000
[    0.344047] device: '48042000.timer': device_add
[    0.344450]    create child: /ocp/timer@48044000
[    0.344744] device: '48044000.timer': device_add
[    0.345141]    create child: /ocp/timer@48046000
[    0.345433] device: '48046000.timer': device_add
[    0.345848]    create child: /ocp/timer@48048000
[    0.346142] device: '48048000.timer': device_add
[    0.346553]    create child: /ocp/timer@4804a000
[    0.346857] device: '4804a000.timer': device_add
[    0.347258]    create child: /ocp/rtc@44e3e000
[    0.347662] device: '44e3e000.rtc': device_add
[    0.348069]    create child: /ocp/spi@48030000
[    0.348470] device: '48030000.spi': device_add
[    0.348920]    create child: /ocp/spi@481a0000
[    0.348953]    create child: /ocp/usb@47400000
[    0.349099] device: '47400000.usb': device_add
[    0.349502]    create child: /ocp/epwmss@48300000
[    0.349532]    create child: /ocp/epwmss@48302000
[    0.349558]    create child: /ocp/epwmss@48304000
[    0.349582]    create child: /ocp/ethernet@4a100000
[    0.349612]    create child: /ocp/ocmcram@40300000
[    0.349766] device: '40300000.ocmcram': device_add
[    0.350094] bus: 'platform': driver_probe_device: matched device 40300000.ocmcram with driver sram
[    0.350117] bus: 'platform': really_probe: probing driver sram with device 40300000.ocmcram
[    0.350343] driver: 'sram': driver_bound: bound to device '40300000.ocmcram'
[    0.350372] bus: 'platform': really_probe: bound device 40300000.ocmcram to driver sram
[    0.350411]    create child: /ocp/elm@48080000
[    0.350731] device: '48080000.elm': device_add
[    0.351174]    create child: /ocp/lcdc@4830e000
[    0.351206]    create child: /ocp/tscadc@44e0d000
[    0.351232]    create child: /ocp/gpmc@50000000
[    0.351537] device: '50000000.gpmc': device_add
[    0.352025] bus: 'platform': driver_probe_device: matched device 50000000.gpmc with driver omap-gpmc
[    0.352050] bus: 'platform': really_probe: probing driver omap-gpmc with device 50000000.gpmc
[    0.352332] omap-gpmc 50000000.gpmc: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_nandflash, deferring probe
[    0.352383] platform 50000000.gpmc: Driver omap-gpmc requests probe deferral
[    0.352403] platform 50000000.gpmc: Added to deferred list
[    0.352454]    create child: /ocp/sham@53100000
[    0.352779] device: '53100000.sham': device_add
[    0.353225]    create child: /ocp/aes@53500000
[    0.353548] device: '53500000.aes': device_add
[    0.353978]    create child: /ocp/mcasp@48038000
[    0.354008]    create child: /ocp/mcasp@4803C000
[    0.354032]    create child: /ocp/rng@48310000
[    0.354329] device: '48310000.rng': device_add
[    0.354801] device: 'regulators': device_add
[    0.355153]    create child: /regulators/fixedregulator@0
[    0.355248] device: 'regulators:fixedregulator@0': device_add
[    0.355614]    create child: /regulators/fixedregulator@1
[    0.355716] device: 'regulators:fixedregulator@1': device_add
[    0.356980] No ATAGs?
[    0.357015] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.357231] device: 'omap-pcm-audio': device_add
[    0.358379] bus: 'platform': add driver omap_dma_system
[    0.358907] bus: 'platform': add driver ti-dma-crossbar
[    0.359675] device: 'cpu0': device_add
[    0.390506] device: 'writeback': device_add
[    0.392990] bus: 'platform': add driver omap-control-phy
[    0.393502] bus: 'platform': add driver twl4030_usb
[    0.393934] bus: 'i2c': add driver pca953x
[    0.394082] bus: 'i2c': add driver pcf857x
[    0.394230] bus: 'platform': add driver palmas-gpio
[    0.394592] bus: 'platform': add driver twl4030_gpio
[    0.395224] bus: 'platform': add driver omap-dma-engine
[    0.395639] bus: 'platform': add driver edma3-tptc
[    0.395920] bus: 'platform': add driver edma
[    0.396031] bus: 'platform': driver_probe_device: matched device 49000000.edma with driver edma
[    0.396057] bus: 'platform': really_probe: probing driver edma with device 49000000.edma
[    0.397022] edma 49000000.edma: Legacy memcpy is enabled, things might not work
[    0.397368] device: 'dma0chan0': device_add
[    0.397967] device: 'dma0chan1': device_add
[    0.398472] device: 'dma0chan2': device_add
[    0.398814] device: 'dma0chan3': device_add
[    0.399173] device: 'dma0chan4': device_add
[    0.399519] device: 'dma0chan5': device_add
[    0.399852] device: 'dma0chan6': device_add
[    0.400184] device: 'dma0chan7': device_add
[    0.400538] device: 'dma0chan8': device_add
[    0.400872] device: 'dma0chan9': device_add
[    0.401206] device: 'dma0chan10': device_add
[    0.401554] device: 'dma0chan11': device_add
[    0.401898] device: 'dma0chan12': device_add
[    0.402234] device: 'dma0chan13': device_add
[    0.402582] device: 'dma0chan14': device_add
[    0.402918] device: 'dma0chan15': device_add
[    0.403262] device: 'dma0chan16': device_add
[    0.403610] device: 'dma0chan17': device_add
[    0.403946] device: 'dma0chan18': device_add
[    0.404283] device: 'dma0chan19': device_add
[    0.404639] device: 'dma0chan20': device_add
[    0.404975] device: 'dma0chan21': device_add
[    0.405326] device: 'dma0chan22': device_add
[    0.405677] device: 'dma0chan23': device_add
[    0.406038] device: 'dma0chan24': device_add
[    0.406375] device: 'dma0chan25': device_add
[    0.406725] device: 'dma0chan26': device_add
[    0.407064] device: 'dma0chan27': device_add
[    0.407411] device: 'dma0chan28': device_add
[    0.407761] device: 'dma0chan29': device_add
[    0.408098] device: 'dma0chan30': device_add
[    0.408525] device: 'dma0chan31': device_add
[    0.408896] device: 'dma0chan32': device_add
[    0.409238] device: 'dma0chan33': device_add
[    0.409579] device: 'dma0chan34': device_add
[    0.409948] device: 'dma0chan35': device_add
[    0.410302] device: 'dma0chan36': device_add
[    0.410645] device: 'dma0chan37': device_add
[    0.411001] device: 'dma0chan38': device_add
[    0.411345] device: 'dma0chan39': device_add
[    0.411698] device: 'dma0chan40': device_add
[    0.412054] device: 'dma0chan41': device_add
[    0.412399] device: 'dma0chan42': device_add
[    0.412755] device: 'dma0chan43': device_add
[    0.413119] device: 'dma0chan44': device_add
[    0.413461] device: 'dma0chan45': device_add
[    0.413804] device: 'dma0chan46': device_add
[    0.414160] device: 'dma0chan47': device_add
[    0.414514] device: 'dma0chan48': device_add
[    0.414859] device: 'dma0chan49': device_add
[    0.415215] device: 'dma0chan50': device_add
[    0.415560] device: 'dma0chan51': device_add
[    0.415913] device: 'dma0chan52': device_add
[    0.416283] device: 'dma0chan53': device_add
[    0.416628] device: 'dma0chan54': device_add
[    0.416976] device: 'dma0chan55': device_add
[    0.417344] device: 'dma0chan56': device_add
[    0.417691] device: 'dma0chan57': device_add
[    0.418038] device: 'dma0chan58': device_add
[    0.418479] device: 'dma0chan59': device_add
[    0.418842] device: 'dma0chan60': device_add
[    0.419193] device: 'dma0chan61': device_add
[    0.419555] device: 'dma0chan62': device_add
[    0.419915] device: 'dma0chan63': device_add
[    0.420450] edma 49000000.edma: TI EDMA DMA engine driver
[    0.420474] driver: 'edma': driver_bound: bound to device '49000000.edma'
[    0.420506] bus: 'platform': really_probe: bound device 49000000.edma to driver edma
[    0.420852] bus: 'platform': add driver reg-fixed-voltage
[    0.421087] bus: 'platform': driver_probe_device: matched device regulators:fixedregulator@0 with driver reg-fixed-voltage
[    0.421115] bus: 'platform': really_probe: probing driver reg-fixed-voltage with device regulators:fixedregulator@0
[    0.421350] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/fixedregulator@0[0]'
[    0.421439] device: 'regulator.1': device_add
[    0.422312] driver: 'reg-fixed-voltage': driver_bound: bound to device 'regulators:fixedregulator@0'
[    0.422344] bus: 'platform': really_probe: bound device regulators:fixedregulator@0 to driver reg-fixed-voltage
[    0.422385] bus: 'platform': driver_probe_device: matched device regulators:fixedregulator@1 with driver reg-fixed-voltage
[    0.422406] bus: 'platform': really_probe: probing driver reg-fixed-voltage with device regulators:fixedregulator@1
[    0.422594] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/fixedregulator@1[0]'
[    0.422657] device: 'regulator.2': device_add
[    0.423405] driver: 'reg-fixed-voltage': driver_bound: bound to device 'regulators:fixedregulator@1'
[    0.423434] bus: 'platform': really_probe: bound device regulators:fixedregulator@1 to driver reg-fixed-voltage
[    0.423572] bus: 'platform': add driver palmas-pmic
[    0.424070] bus: 'i2c': add driver tps62360
[    0.424212] bus: 'i2c': add driver tps65023
[    0.424348] bus: 'platform': add driver tps6507x-pmic
[    0.424546] bus: 'platform': add driver tps65217-pmic
[    0.424738] bus: 'platform': add driver tps65910-pmic
[    0.424928] bus: 'platform': add driver twl_reg
[    0.426417] bus: 'i2c': add driver tps65217
[    0.426567] bus: 'i2c': add driver tps65910
[    0.426704] bus: 'i2c': add driver palmas
[    0.427543] SCSI subsystem initialized
[    0.428554] libata version 3.00 loaded.
[    0.428859] bus: 'mdio_bus': add driver Generic PHY
[    0.428989] bus: 'mdio_bus': add driver Generic 10G PHY
[    0.429372] bus: 'usb': add driver usbfs
[    0.429631] usbcore: registered new interface driver usbfs
[    0.429664] bus: 'usb': add driver hub
[    0.429854] usbcore: registered new interface driver hub
[    0.429947] bus: 'usb': add driver usb
[    0.430061] usbcore: registered new device driver usb
[    0.430102] bus: 'platform': add driver usb_phy_generic
[    0.430457] bus: 'platform': add driver twl6030_usb
[    0.430747] bus: 'platform': add driver musb-omap2430
[    0.431396] bus: 'platform': add driver omap_i2c
[    0.431562] bus: 'platform': driver_probe_device: matched device 44e0b000.i2c with driver omap_i2c
[    0.431589] bus: 'platform': really_probe: probing driver omap_i2c with device 44e0b000.i2c
[    0.431701] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0, deferring probe
[    0.431752] platform 44e0b000.i2c: Driver omap_i2c requests probe deferral
[    0.431772] platform 44e0b000.i2c: Added to deferred list
[    0.432084] pps_core: LinuxPPS API ver. 1 registered
[    0.432099] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.432184] PTP clock support registered
[    0.433667] device: 'lo': device_add
[    0.436619] Bluetooth: Core ver 2.21
[    0.436771] NET: Registered protocol family 31
[    0.436787] Bluetooth: HCI device and connection manager initialized
[    0.436919] Bluetooth: HCI socket layer initialized
[    0.436957] Bluetooth: L2CAP socket layer initialized
[    0.437214] Bluetooth: SCO socket layer initialized
[    0.437830] device: 'regulatory.0': device_add
[    0.439856] device: 'rfkill': device_add
[    0.442479] clocksource: Switched to clocksource timer1
[    0.444454] device: 'fbcon': device_add
[    0.445426] device: 'mem': device_add
[    0.446103] device: 'kmem': device_add
[    0.446579] device: 'null': device_add
[    0.447060] device: 'zero': device_add
[    0.447598] device: 'full': device_add
[    0.448040] device: 'random': device_add
[    0.448647] device: 'urandom': device_add
[    0.449105] device: 'kmsg': device_add
[    0.449556] device: 'tty': device_add
[    0.450183] device: 'console': device_add
[    0.450737] device: 'tty0': device_add
[    0.451278] device: 'vcs': device_add
[    0.451871] device: 'vcsa': device_add
[    0.452351] device: 'vcs1': device_add
[    0.452875] device: 'vcsa1': device_add
[    0.453463] device: 'tty1': device_add
[    0.454001] device: 'tty2': device_add
[    0.454453] device: 'tty3': device_add
[    0.454918] device: 'tty4': device_add
[    0.455398] device: 'tty5': device_add
[    0.455863] device: 'tty6': device_add
[    0.456312] device: 'tty7': device_add
[    0.456807] device: 'tty8': device_add
[    0.457279] device: 'tty9': device_add
[    0.457726] device: 'tty10': device_add
[    0.458179] device: 'tty11': device_add
[    0.458658] device: 'tty12': device_add
[    0.459127] device: 'tty13': device_add
[    0.459614] device: 'tty14': device_add
[    0.460062] device: 'tty15': device_add
[    0.460526] device: 'tty16': device_add
[    0.460986] device: 'tty17': device_add
[    0.461440] device: 'tty18': device_add
[    0.461890] device: 'tty19': device_add
[    0.462388] device: 'tty20': device_add
[    0.462971] device: 'tty21': device_add
[    0.463448] device: 'tty22': device_add
[    0.463915] device: 'tty23': device_add
[    0.464368] device: 'tty24': device_add
[    0.464831] device: 'tty25': device_add
[    0.465319] device: 'tty26': device_add
[    0.465788] device: 'tty27': device_add
[    0.466239] device: 'tty28': device_add
[    0.466701] device: 'tty29': device_add
[    0.467167] device: 'tty30': device_add
[    0.467622] device: 'tty31': device_add
[    0.468128] device: 'tty32': device_add
[    0.468594] device: 'tty33': device_add
[    0.469070] device: 'tty34': device_add
[    0.469535] device: 'tty35': device_add
[    0.469988] device: 'tty36': device_add
[    0.470465] device: 'tty37': device_add
[    0.470958] device: 'tty38': device_add
[    0.471412] device: 'tty39': device_add
[    0.471871] device: 'tty40': device_add
[    0.472351] device: 'tty41': device_add
[    0.472939] device: 'tty42': device_add
[    0.473399] device: 'tty43': device_add
[    0.473911] device: 'tty44': device_add
[    0.474377] device: 'tty45': device_add
[    0.474835] device: 'tty46': device_add
[    0.475293] device: 'tty47': device_add
[    0.475763] device: 'tty48': device_add
[    0.476228] device: 'tty49': device_add
[    0.476723] device: 'tty50': device_add
[    0.477191] device: 'tty51': device_add
[    0.477661] device: 'tty52': device_add
[    0.478113] device: 'tty53': device_add
[    0.478557] device: 'tty54': device_add
[    0.479011] device: 'tty55': device_add
[    0.479501] device: 'tty56': device_add
[    0.479959] device: 'tty57': device_add
[    0.480414] device: 'tty58': device_add
[    0.480862] device: 'tty59': device_add
[    0.481302] device: 'tty60': device_add
[    0.481757] device: 'tty61': device_add
[    0.482267] device: 'tty62': device_add
[    0.482816] device: 'tty63': device_add
[    0.484012] bus: 'platform': add driver usbhs_tll
[    0.485529] NET: Registered protocol family 2
[    0.488017] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.488153] TCP bind hash table entries: 4096 (order: 5, 147456 bytes)
[    0.490135] TCP: Hash tables configured (established 4096 bind 4096)
[    0.490419] UDP hash table entries: 256 (order: 2, 20480 bytes)
[    0.490702] UDP-Lite hash table entries: 256 (order: 2, 20480 bytes)
[    0.491894] NET: Registered protocol family 1
[    0.494370] RPC: Registered named UNIX socket transport module.
[    0.494400] RPC: Registered udp transport module.
[    0.494414] RPC: Registered tcp transport module.
[    0.494428] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.494498] bus: 'platform': add driver usbhs_omap
[    0.497071] bus: 'platform': add driver armv6-pmu
[    0.497494] bus: 'platform': add driver armv7-pmu
[    0.497572] bus: 'platform': driver_probe_device: matched device pmu with driver armv7-pmu
[    0.497600] bus: 'platform': really_probe: probing driver armv7-pmu with device pmu
[    0.497917] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[    0.498086] driver: 'armv7-pmu': driver_bound: bound to device 'pmu'
[    0.498117] bus: 'platform': really_probe: bound device pmu to driver armv7-pmu
[    0.498611] bus: 'platform': add driver omap_timer
[    0.498847] bus: 'platform': driver_probe_device: matched device 48042000.timer with driver omap_timer
[    0.498872] bus: 'platform': really_probe: probing driver omap_timer with device 48042000.timer
[    0.499345] driver: 'omap_timer': driver_bound: bound to device '48042000.timer'
[    0.499380] bus: 'platform': really_probe: bound device 48042000.timer to driver omap_timer
[    0.499420] bus: 'platform': driver_probe_device: matched device 48044000.timer with driver omap_timer
[    0.499442] bus: 'platform': really_probe: probing driver omap_timer with device 48044000.timer
[    0.499689] driver: 'omap_timer': driver_bound: bound to device '48044000.timer'
[    0.499717] bus: 'platform': really_probe: bound device 48044000.timer to driver omap_timer
[    0.499754] bus: 'platform': driver_probe_device: matched device 48046000.timer with driver omap_timer
[    0.499775] bus: 'platform': really_probe: probing driver omap_timer with device 48046000.timer
[    0.499993] driver: 'omap_timer': driver_bound: bound to device '48046000.timer'
[    0.500020] bus: 'platform': really_probe: bound device 48046000.timer to driver omap_timer
[    0.500056] bus: 'platform': driver_probe_device: matched device 48048000.timer with driver omap_timer
[    0.500076] bus: 'platform': really_probe: probing driver omap_timer with device 48048000.timer
[    0.500293] driver: 'omap_timer': driver_bound: bound to device '48048000.timer'
[    0.500319] bus: 'platform': really_probe: bound device 48048000.timer to driver omap_timer
[    0.500355] bus: 'platform': driver_probe_device: matched device 4804a000.timer with driver omap_timer
[    0.500376] bus: 'platform': really_probe: probing driver omap_timer with device 4804a000.timer
[    0.500589] driver: 'omap_timer': driver_bound: bound to device '4804a000.timer'
[    0.500615] bus: 'platform': really_probe: bound device 4804a000.timer to driver omap_timer
[    0.501287] device: 'clocksource': device_add
[    0.501477] device: 'clocksource0': device_add
[    0.502100] bus: 'platform': add driver alarmtimer
[    0.502338] device: 'alarmtimer': device_add
[    0.502848] bus: 'platform': driver_probe_device: matched device alarmtimer with driver alarmtimer
[    0.502874] bus: 'platform': really_probe: probing driver alarmtimer with device alarmtimer
[    0.502984] driver: 'alarmtimer': driver_bound: bound to device 'alarmtimer'
[    0.503010] bus: 'platform': really_probe: bound device alarmtimer to driver alarmtimer
[    0.503233] device: 'clockevents': device_add
[    0.503409] device: 'clockevent0': device_add
[    0.503907] futex hash table entries: 256 (order: 1, 11264 bytes)
[    0.504219] audit: initializing netlink subsys (disabled)
[    0.504524] audit: type=2000 audit(0.500:1): initialized
[    0.505070] device: 'armv7_cortex_a8': device_add
[    0.505572] device: 'breakpoint': device_add
[    0.505930] device: 'software': device_add
[    0.511954] NFS: Registering the id_resolver key type
[    0.512611] Key type id_resolver registered
[    0.512636] Key type id_legacy registered
[    0.512944] romfs: ROMFS MTD (C) 2007 Red Hat, Inc.
[    0.513054] device: 'autofs': device_add
[    0.532567] NET: Registered protocol family 38
[    0.532932] io scheduler noop registered
[    0.532962] io scheduler deadline registered
[    0.533024] io scheduler cfq registered (default)
[    0.533189] bus: 'platform': add driver omap-ocp2scp
[    0.533721] bus: 'platform': add driver dm816x-usb-phy
[    0.534030] bus: 'platform': add driver omap-usb2
[    0.534413] bus: 'platform': add driver ti-pipe3
[    0.534770] bus: 'platform': add driver palmas-pinctrl
[    0.535113] bus: 'platform': add driver pinctrl-single
[    0.535234] bus: 'platform': driver_probe_device: matched device 44e10800.pinmux with driver pinctrl-single
[    0.535261] bus: 'platform': really_probe: probing driver pinctrl-single with device 44e10800.pinmux
[    0.536250] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[    0.536274] driver: 'pinctrl-single': driver_bound: bound to device '44e10800.pinmux'
[    0.536305] bus: 'platform': really_probe: bound device 44e10800.pinmux to driver pinctrl-single
[    0.536692] bus: 'platform': add driver twl-pwm
[    0.537019] bus: 'platform': add driver twl-pwmled
[    0.537335] bus: 'platform': add driver cppi41-dma-engine
[    0.537637] bus: 'platform': add driver tps65218-pmic
[    0.538114] device: 'ptmx': device_add
[    0.538829] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.539072] device: 'serial8250': device_add
[    0.539921] device: 'ttyS0': device_add
[    0.541384] device: 'ttyS1': device_add
[    0.542314] device: 'ttyS2': device_add
[    0.543306] device: 'ttyS3': device_add
[    0.544140] bus: 'platform': add driver serial8250
[    0.544297] bus: 'platform': driver_probe_device: matched device serial8250 with driver serial8250
[    0.544325] bus: 'platform': really_probe: probing driver serial8250 with device serial8250
[    0.544445] driver: 'serial8250': driver_bound: bound to device 'serial8250'
[    0.544473] bus: 'platform': really_probe: bound device serial8250 to driver serial8250
[    0.544616] bus: 'platform': add driver of_serial
[    0.545296] bus: 'platform': add driver omap_uart
[    0.545452] bus: 'platform': driver_probe_device: matched device 44e09000.serial with driver omap_uart
[    0.545475] bus: 'platform': really_probe: probing driver omap_uart with device 44e09000.serial
[    0.546291] omap_uart 44e09000.serial: no wakeirq for uart0
[    0.546326] of_get_named_gpiod_flags: can't parse 'rts-gpio' property of node '/ocp/serial@44e09000[0]'
[    0.546496] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 155, base_baud = 3000000) is a OMAP UART0
[    3.701020] console [ttyO0] enabled
[    3.704793] device: 'ttyO0': device_add
[    3.710356] driver: 'omap_uart': driver_bound: bound to device '44e09000.serial'
[    3.718217] bus: 'platform': really_probe: bound device 44e09000.serial to driver omap_uart
[    3.727369] device: 'hw_random': device_add
[    3.732462] bus: 'platform': add driver omap_rng
[    3.737668] bus: 'platform': driver_probe_device: matched device 48310000.rng with driver omap_rng
[    3.747137] bus: 'platform': really_probe: probing driver omap_rng with device 48310000.rng
[    3.757096] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[    3.764143] driver: 'omap_rng': driver_bound: bound to device '48310000.rng'
[    3.771587] bus: 'platform': really_probe: bound device 48310000.rng to driver omap_rng
[    3.787702] device: '1:0': device_add
[    3.792407] device: 'ram0': device_add
[    3.799548] device: '1:1': device_add
[    3.803943] device: 'ram1': device_add
[    3.809668] device: '1:2': device_add
[    3.814005] device: 'ram2': device_add
[    3.819595] device: '1:3': device_add
[    3.823968] device: 'ram3': device_add
[    3.829541] device: '1:4': device_add
[    3.833844] device: 'ram4': device_add
[    3.839431] device: '1:5': device_add
[    3.843737] device: 'ram5': device_add
[    3.849414] device: '1:6': device_add
[    3.853751] device: 'ram6': device_add
[    3.859320] device: '1:7': device_add
[    3.863657] device: 'ram7': device_add
[    3.869218] device: '1:8': device_add
[    3.873525] device: 'ram8': device_add
[    3.879070] device: '1:9': device_add
[    3.883369] device: 'ram9': device_add
[    3.888897] device: '1:10': device_add
[    3.893305] device: 'ram10': device_add
[    3.898920] device: '1:11': device_add
[    3.903341] device: 'ram11': device_add
[    3.908959] device: '1:12': device_add
[    3.913357] device: 'ram12': device_add
[    3.918987] device: '1:13': device_add
[    3.923375] device: 'ram13': device_add
[    3.929066] device: '1:14': device_add
[    3.933457] device: 'ram14': device_add
[    3.939086] device: '1:15': device_add
[    3.943518] device: 'ram15': device_add
[    3.949154] brd: module loaded
[    3.952432] device: 'loop-control': device_add
[    3.959914] device: '7:0': device_add
[    3.964750] device: 'loop0': device_add
[    3.971604] device: '7:1': device_add
[    3.976057] device: 'loop1': device_add
[    3.982561] device: '7:2': device_add
[    3.986889] device: 'loop2': device_add
[    3.993452] device: '7:3': device_add
[    3.997824] device: 'loop3': device_add
[    4.004332] device: '7:4': device_add
[    4.008655] device: 'loop4': device_add
[    4.015064] device: '7:5': device_add
[    4.019375] device: 'loop5': device_add
[    4.025733] device: '7:6': device_add
[    4.030045] device: 'loop6': device_add
[    4.036415] device: '7:7': device_add
[    4.040789] device: 'loop7': device_add
[    4.046808] loop: module loaded
[    4.050174] bus: 'i2c': add driver at24
[    4.054437] bus: 'platform': add driver kim
[    4.059081] bus: 'platform': add driver ti_am3359-tscadc
[    4.065067] bus: 'i2c': add driver tps65218
[    4.069616] bus: 'i2c': add driver twl
[    4.073733] bus: 'platform': add driver twl4030-audio
[    4.079343] bus: 'i2c': add driver twl6040
[    4.084018] bus: 'scsi': add driver sd
[    4.088094] bus: 'platform': add driver ahci
[    4.093075] device: 'mtd': device_add
[    4.097857] mtdoops: mtd device (mtddev=name/number) must be supplied
[    4.104789] bus: 'platform': add driver omap2-nand
[    4.110111] bus: 'platform': add driver omap-elm
[    4.115216] bus: 'platform': driver_probe_device: matched device 48080000.elm with driver omap-elm
[    4.124681] bus: 'platform': really_probe: probing driver omap-elm with device 48080000.elm
[    4.133878] driver: 'omap-elm': driver_bound: bound to device '48080000.elm'
[    4.141312] bus: 'platform': really_probe: bound device 48080000.elm to driver omap-elm
[    4.150019] bus: 'spi': add driver spidev
[    4.154411] bus: 'platform': add driver omap2_mcspi
[    4.159743] bus: 'platform': driver_probe_device: matched device 48030000.spi with driver omap2_mcspi
[    4.169484] bus: 'platform': really_probe: probing driver omap2_mcspi with device 48030000.spi
[    4.179149] device: 'spi1': device_add
[    4.185598] device: 'spi1.0': device_add
[    4.191229] driver: 'omap2_mcspi': driver_bound: bound to device '48030000.spi'
[    4.199037] bus: 'platform': really_probe: bound device 48030000.spi to driver omap2_mcspi
[    4.208146] bus: 'platform': add driver ti-qspi
[    4.213365] bus: 'mdio_bus': add driver SMSC LAN83C185
[    4.218885] bus: 'mdio_bus': add driver SMSC LAN8187
[    4.224259] bus: 'mdio_bus': add driver SMSC LAN8700
[    4.229583] bus: 'mdio_bus': add driver SMSC LAN911x Internal PHY
[    4.236126] bus: 'mdio_bus': add driver SMSC LAN8710/LAN8720
[    4.242202] bus: 'mdio_bus': add driver Micrel KS8737
[    4.247672] bus: 'mdio_bus': add driver Micrel KSZ8021 or KSZ8031
[    4.254215] bus: 'mdio_bus': add driver Micrel KSZ8031
[    4.259723] bus: 'mdio_bus': add driver Micrel KSZ8041
[    4.265260] bus: 'mdio_bus': add driver Micrel KSZ8041RNLI
[    4.271134] bus: 'mdio_bus': add driver Micrel KSZ8051
[    4.276673] bus: 'mdio_bus': add driver Micrel KSZ8001 or KS8721
[    4.283124] bus: 'mdio_bus': add driver Micrel KSZ8081 or KSZ8091
[    4.289636] bus: 'mdio_bus': add driver Micrel KSZ8061
[    4.295174] bus: 'mdio_bus': add driver Micrel KSZ9021 Gigabit PHY
[    4.301779] bus: 'mdio_bus': add driver Micrel KSZ9031 Gigabit PHY
[    4.308413] bus: 'mdio_bus': add driver Micrel KSZ8873MLL Switch
[    4.314877] bus: 'mdio_bus': add driver Micrel KSZ886X Switch
[    4.321039] bus: 'mdio_bus': add driver Atheros 8035 ethernet
[    4.327219] bus: 'mdio_bus': add driver Atheros 8030 ethernet
[    4.333395] bus: 'mdio_bus': add driver Atheros 8031 ethernet
[    4.339567] bus: 'platform': add driver dm9000
[    4.344584] bus: 'platform': add driver ks8851_mll
[    4.349910] bus: 'platform': add driver smc91x
[    4.354932] bus: 'platform': add driver smsc911x
[    4.360069] bus: 'platform': add driver davinci_mdio
[    4.365612] bus: 'platform': add driver cpsw-phy-sel
[    4.371198] bus: 'platform': add driver cpsw
[    4.376188] bus: 'usb': add driver usb8xxx
[    4.380681] usbcore: registered new interface driver usb8xxx
[    4.386686] libertas_sdio: Libertas SDIO driver
[    4.391449] libertas_sdio: Copyright Pierre Ossman
[    4.396519] bus: 'sdio': add driver libertas_sdio
[    4.401602] bus: 'sdio': add driver wl1271_sdio
[    4.406522] bus: 'platform': add driver wl12xx_driver
[    4.412028] bus: 'spi': add driver wl1251
[    4.416399] bus: 'sdio': add driver wl1251_sdio
[    4.421283] bus: 'platform': add driver wl18xx_driver
[    4.426892] bus: 'sdio': add driver mwifiex_sdio
[    4.431877] bus: 'usb': add driver mwifiex_usb
[    4.436817] usbcore: registered new interface driver mwifiex_usb
[    4.443181] bus: 'spi': add driver mrf24j40
[    4.447637] bus: 'spi': driver_probe_device: matched device spi1.0 with driver mrf24j40
[    4.456092] bus: 'spi': really_probe: probing driver mrf24j40 with device spi1.0
[    4.464067] pinctrl-single 44e10800.pinmux: pin 44e10950.0 already requested by 48030000.spi; cannot claim for spi1.0
[    4.475267] pinctrl-single 44e10800.pinmux: pin-84 (spi1.0) status -22
[    4.482141] pinctrl-single 44e10800.pinmux: could not request pin 84 (44e10950.0) from group mrf24j40_pins_default  on device pinctrl-single
[    4.495428] mrf24j40 spi1.0: Error applying setting, reverse things back
[    4.502900] mrf24j40 spi1.0: probe(). IRQ: 31
[    4.568339] device: 'phy0': device_add
[    4.573863] device: 'wpan0': device_add
[    4.580227] driver: 'mrf24j40': driver_bound: bound to device 'spi1.0'
[    4.587213] bus: 'spi': really_probe: bound device spi1.0 to driver mrf24j40
[    4.594836] bus: 'platform': add driver am335x-control-usb
[    4.601001] bus: 'platform': add driver am335x-phy-driver
[    4.607346] device: 'usbmon0': device_add
[    4.612703] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.619649] ehci-omap: OMAP-EHCI Host Controller driver
[    4.625225] bus: 'platform': add driver ehci-omap
[    4.630532] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    4.637144] bus: 'usb': add driver usb-storage
[    4.642089] usbcore: registered new interface driver usb-storage
[    4.648469] bus: 'platform': add driver musb-hdrc
[    4.654015] device: 'mice': device_add
[    4.659000] device: 'psaux': device_add
[    4.663629] mousedev: PS/2 mouse device common for all mice
[    4.669531] bus: 'serio': add driver atkbd
[    4.674434] bus: 'platform': add driver matrix-keypad
[    4.680125] bus: 'platform': add driver omap4-keypad
[    4.685733] bus: 'platform': add driver twl4030_keypad
[    4.691452] bus: 'platform': add driver pwm-beeper
[    4.696821] bus: 'platform': add driver twl4030_pwrbutton
[    4.702834] device: 'uinput': device_add
[    4.707956] bus: 'i2c': add driver rtc-ds1307
[    4.712765] bus: 'i2c': add driver rtc-m41t80
[    4.717491] bus: 'platform': add driver omap_rtc
[    4.722621] bus: 'platform': driver_probe_device: matched device 44e3e000.rtc with driver omap_rtc
[    4.732055] bus: 'platform': really_probe: probing driver omap_rtc with device 44e3e000.rtc
[    4.741952] device: 'rtc1': device_add
[    4.746921] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc1
[    4.754567] driver: 'omap_rtc': driver_bound: bound to device '44e3e000.rtc'
[    4.761998] bus: 'platform': really_probe: bound device 44e3e000.rtc to driver omap_rtc
[    4.770695] bus: 'platform': add driver palmas-rtc
[    4.776127] bus: 'i2c': add driver rtc-pcf8563
[    4.780941] bus: 'platform': add driver tps65910-rtc
[    4.786403] bus: 'platform': add driver twl_rtc
[    4.791450] i2c /dev entries driver
[    4.795291] bus: 'platform': add driver poweroff-gpio
[    4.800893] bus: 'i2c': add driver pmbus
[    4.805195] bus: 'platform': add driver ti-soc-thermal
[    4.810858] bus: 'platform': add driver omap_wdt
[    4.815882] bus: 'platform': driver_probe_device: matched device 44e35000.wdt with driver omap_wdt
[    4.825341] bus: 'platform': really_probe: probing driver omap_wdt with device 44e35000.wdt
[    4.835394] device: 'watchdog': device_add
[    4.840866] device: 'watchdog0': device_add
[    4.846757] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    4.854123] driver: 'omap_wdt': driver_bound: bound to device '44e35000.wdt'
[    4.861575] bus: 'platform': really_probe: bound device 44e35000.wdt to driver omap_wdt
[    4.870317] bus: 'platform': add driver twl4030_wdt
[    4.875821] Bluetooth: HCI UART driver ver 2.3
[    4.880504] Bluetooth: HCI UART protocol H4 registered
[    4.885944] Bluetooth: HCI UART protocol BCSP registered
[    4.891529] Bluetooth: HCI UART protocol LL registered
[    4.897179] bus: 'platform': add driver omap-cpufreq
[    4.902711] bus: 'mmc': add driver mmcblk
[    4.907110] bus: 'sdio': add driver sdio_uart
[    4.911829] bus: 'platform': add driver mmci-omap
[    4.917159] bus: 'platform': add driver omap_hsmmc
[    4.922370] bus: 'platform': driver_probe_device: matched device 48060000.mmc with driver omap_hsmmc
[    4.932017] bus: 'platform': really_probe: probing driver omap_hsmmc with device 48060000.mmc
[    4.941684] omap_hsmmc 48060000.mmc: GPIO lookup for consumer cd
[    4.948085] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup
[    4.955039] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/ocp/mmc@48060000[0]' - status (0)
[    4.965455] omap_hsmmc 48060000.mmc: Got CD GPIO
[    4.970333] omap_hsmmc 48060000.mmc: GPIO lookup for consumer wp
[    4.976690] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup
[    4.983598] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@48060000[0]'
[    4.993249] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@48060000[0]'
[    5.002810] omap_hsmmc 48060000.mmc: using lookup tables for GPIO lookup
[    5.010045] omap_hsmmc 48060000.mmc: lookup for GPIO wp failed
[    5.017543] device: 'mmc0': device_add
[    5.022406]
[    5.023983] =====================================
[    5.028937] [ BUG: bad unlock balance detected! ]
[    5.033899] 4.4.8-amun-phycore-am335x #1 Not tainted
[    5.039124] -------------------------------------
[    5.044078] swapper/1 is trying to release lock (&rdev->mutex) at:
[    5.050630] [<c02dca88>] regulator_set_voltage+0x40/0x54
[    5.056225] but there are no more locks to release!
[    5.061359]
[    5.061359] other info that might help us debug this:
[    5.068237] 2 locks held by swapper/1:
[    5.072183]  #0:  (&dev->mutex){......}, at: [<c03197d8>] __driver_attach+0x48/0x98
[    5.080290]  #1:  (&dev->mutex){......}, at: [<c03197e8>] __driver_attach+0x58/0x98
[    5.088387]
[    5.088387] stack backtrace:
[    5.092985] CPU: 0 PID: 1 Comm: swapper Not tainted 4.4.8-amun-phycore-am335x #1
[    5.100776] Hardware name: Generic AM33XX (Flattened Device Tree)
[    5.107227] [<c0016300>] (unwind_backtrace) from [<c0014144>] (show_stack+0x10/0x14)
[    5.115403] [<c0014144>] (show_stack) from [<c0060678>] (print_unlock_imbalance_bug+0xac/0xdc)
[    5.124488] [<c0060678>] (print_unlock_imbalance_bug) from [<c0064900>] (lock_release+0x23c/0x360)
[    5.133943] [<c0064900>] (lock_release) from [<c0712860>] (__mutex_unlock_slowpath+0x78/0x154)
[    5.143026] [<c0712860>] (__mutex_unlock_slowpath) from [<c02dca88>] (regulator_set_voltage+0x40/0x54)
[    5.152847] [<c02dca88>] (regulator_set_voltage) from [<c04ac8f8>] (mmc_regulator_set_ocr+0x40/0xc8)
[    5.162480] [<c04ac8f8>] (mmc_regulator_set_ocr) from [<c04c5348>] (omap_hsmmc_set_power+0xc8/0x1ec)
[    5.172110] [<c04c5348>] (omap_hsmmc_set_power) from [<c04c5608>] (omap_hsmmc_set_ios+0x19c/0x2ec)
[    5.181560] [<c04c5608>] (omap_hsmmc_set_ios) from [<c04ae020>] (mmc_power_up.part.6+0x34/0x1f0)
[    5.190803] [<c04ae020>] (mmc_power_up.part.6) from [<c04af324>] (mmc_start_host+0x8c/0xa4)
[    5.199588] [<c04af324>] (mmc_start_host) from [<c04b0420>] (mmc_add_host+0x58/0x78)
[    5.207735] [<c04b0420>] (mmc_add_host) from [<c04c4c54>] (omap_hsmmc_probe+0x4fc/0xb28)
[    5.216249] [<c04c4c54>] (omap_hsmmc_probe) from [<c031add4>] (platform_drv_probe+0x4c/0xb0)
[    5.225126] [<c031add4>] (platform_drv_probe) from [<c0319534>] (driver_probe_device+0x21c/0x478)
[    5.234459] [<c0319534>] (driver_probe_device) from [<c0319824>] (__driver_attach+0x94/0x98)
[    5.243334] [<c0319824>] (__driver_attach) from [<c0317638>] (bus_for_each_dev+0x6c/0xa0)
[    5.251936] [<c0317638>] (bus_for_each_dev) from [<c0318a84>] (bus_add_driver+0x1b8/0x26c)
[    5.260629] [<c0318a84>] (bus_add_driver) from [<c0319dd8>] (driver_register+0x78/0xf8)
[    5.269050] [<c0319dd8>] (driver_register) from [<c0009730>] (do_one_initcall+0xa8/0x1fc)
[    5.277661] [<c0009730>] (do_one_initcall) from [<c09c5e8c>] (kernel_init_freeable+0x1e8/0x2b4)
[    5.286812] [<c09c5e8c>] (kernel_init_freeable) from [<c070ee40>] (kernel_init+0x8/0xec)
[    5.295324] [<c070ee40>] (kernel_init) from [<c0010290>] (ret_from_fork+0x14/0x24)
[    5.342927] driver: 'omap_hsmmc': driver_bound: bound to device '48060000.mmc'
[    5.350546] bus: 'platform': really_probe: bound device 48060000.mmc to driver omap_hsmmc
[    5.359232] bus: 'platform': driver_probe_device: matched device 47810000.mmc with driver omap_hsmmc
[    5.368869] bus: 'platform': really_probe: probing driver omap_hsmmc with device 47810000.mmc
[    5.378249] omap_hsmmc 47810000.mmc: GPIO lookup for consumer cd
[    5.384622] omap_hsmmc 47810000.mmc: using device tree for GPIO lookup
[    5.391498] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/mmc@47810000[0]'
[    5.401132] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/mmc@47810000[0]'
[    5.410668] omap_hsmmc 47810000.mmc: using lookup tables for GPIO lookup
[    5.417744] omap_hsmmc 47810000.mmc: lookup for GPIO cd failed
[    5.423908] omap_hsmmc 47810000.mmc: GPIO lookup for consumer wp
[    5.430226] omap_hsmmc 47810000.mmc: using device tree for GPIO lookup
[    5.437115] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@47810000[0]'
[    5.446748] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@47810000[0]'
[    5.456283] omap_hsmmc 47810000.mmc: using lookup tables for GPIO lookup
[    5.463355] omap_hsmmc 47810000.mmc: lookup for GPIO wp failed
[    5.469962] platform 47810000.mmc: Driver omap_hsmmc requests probe deferral
[    5.477437] platform 47810000.mmc: Added to deferred list
[    5.483396] bus: 'i2c': add driver leds-pca953x
[    5.488295] bus: 'platform': add driver leds-gpio
[    5.493524] bus: 'platform': add driver leds_pwm
[    5.498609] ledtrig-cpu: registered to indicate activity on CPUs
[    5.505152] bus: 'hid': add driver hid-generic
[    5.509958] bus: 'usb': add driver usbhid
[    5.514364] usbcore: registered new interface driver usbhid
[    5.520221] usbhid: USB HID core driver
[    5.524373] bus: 'platform': add driver palmas-usb
[    5.529682] bus: 'platform': add driver extcon-usb-gpio
[    5.535430] bus: 'platform': add driver emif
[    5.540153] bus: 'i2c': add driver max1363
[    5.544597] bus: 'platform': add driver TI-am335x-adc
[    5.550102] bus: 'platform': add driver oprofile-perf
[    5.555578] device: 'oprofile-perf.0': device_add
[    5.560846] bus: 'platform': driver_probe_device: matched device oprofile-perf.0 with driver oprofile-perf
[    5.571053] bus: 'platform': really_probe: probing driver oprofile-perf with device oprofile-perf.0
[    5.580659] driver: 'oprofile-perf': driver_bound: bound to device 'oprofile-perf.0'
[    5.588837] bus: 'platform': really_probe: bound device oprofile-perf.0 to driver oprofile-perf
[    5.598025] oprofile: using arm/armv7
[    5.602376] Initializing XFRM netlink socket
[    5.607068] NET: Registered protocol family 10
[    5.613854] sit: IPv6 over IPv4 tunneling driver
[    5.618817] device: 'sit0': device_add
[    5.624074] NET: Registered protocol family 17
[    5.628815] NET: Registered protocol family 15
[    5.633675] lib80211: common routines for IEEE802.11 drivers
[    5.639631] lib80211_crypt: registered algorithm 'NULL'
[    5.651166] NET: Registered protocol family 36
[    5.655990] Key type dns_resolver registered
[    5.660951] omap_voltage_late_init: Voltage driver support not added
[    5.667704] device: 'cpufreq-dt.0': device_add
[    5.672836] device: 'soc0': device_add
[    5.677002] ThumbEE CPU extension supported.
[    5.681527] Registering SWP/SWPB emulation handler
[    5.686763] device: 'cpu_dma_latency': device_add
[    5.692172] device: 'network_latency': device_add
[    5.697506] device: 'network_throughput': device_add
[    5.704124] device: 'memory_bandwidth': device_add
[    5.712136] platform 50000000.gpmc: Retrying from deferred list
[    5.718479] bus: 'platform': driver_probe_device: matched device 50000000.gpmc with driver omap-gpmc
[    5.728114] bus: 'platform': really_probe: probing driver omap-gpmc with device 50000000.gpmc
[    5.737427] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[    5.742889] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[    5.749698] device: 'omap2-nand.0': device_add
[    5.754699] bus: 'platform': driver_probe_device: matched device omap2-nand.0 with driver omap2-nand
[    5.764347] bus: 'platform': really_probe: probing driver omap2-nand with device omap2-nand.0
[    5.773859] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xdc
[    5.780544] nand: Micron MT29F4G08ABADAH4
[    5.784799] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[    5.792821] nand: using OMAP_ECC_BCH8_CODE_HW ECC scheme
[    5.798562] 9 ofpart partitions found on MTD device omap2-nand.0
[    5.804909] Creating 9 MTD partitions on "omap2-nand.0":
[    5.810504] 0x000000000000-0x000000020000 : "xload"
[    5.815801] device: 'mtd0': device_add
[    5.820375] device: 'mtd0ro': device_add
[    5.825311] device: '31:0': device_add
[    5.829516] device: 'mtdblock0': device_add
[    5.834903] 0x000000020000-0x000000040000 : "xload_backup1"
[    5.840899] device: 'mtd1': device_add
[    5.845391] device: 'mtd1ro': device_add
[    5.850198] device: '31:1': device_add
[    5.854445] device: 'mtdblock1': device_add
[    5.859722] 0x000000040000-0x000000060000 : "xload_backup2"
[    5.865766] device: 'mtd2': device_add
[    5.870196] device: 'mtd2ro': device_add
[    5.875054] device: '31:2': device_add
[    5.879263] device: 'mtdblock2': device_add
[    5.884649] 0x000000060000-0x000000080000 : "xload_backup3"
[    5.890644] device: 'mtd3': device_add
[    5.895108] device: 'mtd3ro': device_add
[    5.899946] device: '31:3': device_add
[    5.904224] device: 'mtdblock3': device_add
[    5.909609] 0x000000080000-0x000000100000 : "barebox"
[    5.915456] device: 'mtd4': device_add
[    5.919918] device: 'mtd4ro': device_add
[    5.924831] device: '31:4': device_add
[    5.929071] device: 'mtdblock4': device_add
[    5.934491] 0x000000100000-0x000000140000 : "bareboxenv"
[    5.940350] device: 'mtd5': device_add
[    5.944692] mmc0: host does not support reading read-only switch, assuming write-enable
[    5.953310] device: 'mtd5ro': device_add
[    5.957858] mmc0: new high speed SDHC card at address aaaa
[    5.963737] device: 'mmc0:aaaa': device_add
[    5.968446] bus: 'mmc': driver_probe_device: matched device mmc0:aaaa with driver mmcblk
[    5.976994] bus: 'mmc': really_probe: probing driver mmcblk with device mmc0:aaaa
[    5.985567] device: '31:5': device_add
[    5.989793] device: 'mtdblock5': device_add
[    5.995203] 0x000000140000-0x000000180000 : "oftree"
[    6.000666] device: 'mtd6': device_add
[    6.005160] device: 'mtd6ro': device_add
[    6.010146] device: '31:6': device_add
[    6.014409] device: 'mtdblock6': device_add
[    6.019274] mmcblk0: mmc0:aaaa SL08G 7.40 GiB
[    6.024017] device: '179:0': device_add
[    6.028293] device: 'mmcblk0': device_add
[    6.033398] 0x000000180000-0x000000980000 : "kernel"
[    6.045442] device: 'mtd7': device_add
[    6.050456] device: 'mtd7ro': device_add
[    6.055069]  mmcblk0: p1 p2
[    6.058050] device: 'mmcblk0p1': device_add
[    6.063337] device: '31:7': device_add
[    6.067550] device: 'mtdblock7': device_add
[    6.072385] device: 'mmcblk0p2': device_add
[    6.077665] 0x000000980000-0x000020000000 : "root"
[    6.505508] device: 'mtd8': device_add
[    6.510625] driver: 'mmcblk': driver_bound: bound to device 'mmc0:aaaa'
[    6.517673] bus: 'mmc': really_probe: bound device mmc0:aaaa to driver mmcblk
[    6.525440] device: 'mtd8ro': device_add
[    6.530268] device: '31:8': device_add
[    6.534561] device: 'mtdblock8': device_add
[    6.539858] driver: 'omap2-nand': driver_bound: bound to device 'omap2-nand.0'
[    6.547515] bus: 'platform': really_probe: bound device omap2-nand.0 to driver omap2-nand
[    6.556160] driver: 'omap-gpmc': driver_bound: bound to device '50000000.gpmc'
[    6.563783] bus: 'platform': really_probe: bound device 50000000.gpmc to driver omap-gpmc
[    6.572399] platform 44e0b000.i2c: Retrying from deferred list
[    6.578736] bus: 'platform': driver_probe_device: matched device 44e0b000.i2c with driver omap_i2c
[    6.588191] bus: 'platform': really_probe: probing driver omap_i2c with device 44e0b000.i2c
[    6.597723] device: 'i2c-0': device_add
[    6.601979] device: 'i2c-0': device_add
[    6.606645] device: '0-002d': device_add
[    6.611046] bus: 'i2c': driver_probe_device: matched device 0-002d with driver tps65910
[    6.619518] bus: 'i2c': really_probe: probing driver tps65910 with device 0-002d
[    6.642851] tps65910 0-002d: No interrupt support, no core IRQ
[    6.649022] device: 'tps65910-gpio': device_add
[    6.654171] device: 'tps65910-pmic': device_add
[    6.659125] bus: 'platform': driver_probe_device: matched device tps65910-pmic with driver tps65910-pmic
[    6.669138] bus: 'platform': really_probe: probing driver tps65910-pmic with device tps65910-pmic
[    6.680171] device: 'regulator.3': device_add
[    6.688747] device: 'regulator.4': device_add
[    6.695249] device: 'regulator.5': device_add
[    6.702098] device: 'regulator.6': device_add
[    6.708970] device: 'regulator.7': device_add
[    6.715580] device: 'regulator.8': device_add
[    6.721965] device: 'regulator.9': device_add
[    6.728354] device: 'regulator.10': device_add
[    6.734873] device: 'regulator.11': device_add
[    6.741322] device: 'regulator.12': device_add
[    6.747845] device: 'regulator.13': device_add
[    6.754204] device: 'regulator.14': device_add
[    6.760567] device: 'regulator.15': device_add
[    6.767182] device: 'regulator.16': device_add
[    6.772699] driver: 'tps65910-pmic': driver_bound: bound to device 'tps65910-pmic'
[    6.780676] bus: 'platform': really_probe: bound device tps65910-pmic to driver tps65910-pmic
[    6.789709] device: 'tps65910-rtc': device_add
[    6.794690] bus: 'platform': driver_probe_device: matched device tps65910-rtc with driver tps65910-rtc
[    6.804516] bus: 'platform': really_probe: probing driver tps65910-rtc with device tps65910-rtc
[    6.814939] tps65910-rtc tps65910-rtc: IRQ is not free.
[    6.820463] tps65910-rtc: probe of tps65910-rtc failed with error -22
[    6.827315] device: 'tps65910-power': device_add
[    6.832438] driver: 'tps65910': driver_bound: bound to device '0-002d'
[    6.839348] bus: 'i2c': really_probe: bound device 0-002d to driver tps65910
[    6.846841] device: '0-0052': device_add
[    6.851239] bus: 'i2c': driver_probe_device: matched device 0-0052 with driver at24
[    6.859334] bus: 'i2c': really_probe: probing driver at24 with device 0-0052
[    6.866880] at24 0-0052: 4096 byte 24c32 EEPROM, writable, 32 bytes/write
[    6.874050] driver: 'at24': driver_bound: bound to device '0-0052'
[    6.880556] bus: 'i2c': really_probe: bound device 0-0052 to driver at24
[    6.887660] device: '0-0068': device_add
[    6.892029] bus: 'i2c': driver_probe_device: matched device 0-0068 with driver rtc-m41t80
[    6.900666] bus: 'i2c': really_probe: probing driver rtc-m41t80 with device 0-0068
[    6.909128] device: 'rtc0': device_add
[    6.913592] rtc-m41t80 0-0068: rtc core: registered rv4162 as rtc0
[    6.920526] driver: 'rtc-m41t80': driver_bound: bound to device '0-0068'
[    6.927617] bus: 'i2c': really_probe: bound device 0-0068 to driver rtc-m41t80
[    6.935281] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[    6.941154] driver: 'omap_i2c': driver_bound: bound to device '44e0b000.i2c'
[    6.948595] bus: 'platform': really_probe: bound device 44e0b000.i2c to driver omap_i2c
[    6.957061] platform 47810000.mmc: Retrying from deferred list
[    6.963627] bus: 'platform': driver_probe_device: matched device 47810000.mmc with driver omap_hsmmc
[    6.973278] bus: 'platform': really_probe: probing driver omap_hsmmc with device 47810000.mmc
[    6.982700] omap_hsmmc 47810000.mmc: GPIO lookup for consumer cd
[    6.989029] omap_hsmmc 47810000.mmc: using device tree for GPIO lookup
[    6.995941] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/mmc@47810000[0]'
[    7.005583] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/mmc@47810000[0]'
[    7.015120] omap_hsmmc 47810000.mmc: using lookup tables for GPIO lookup
[    7.022172] omap_hsmmc 47810000.mmc: lookup for GPIO cd failed
[    7.028335] omap_hsmmc 47810000.mmc: GPIO lookup for consumer wp
[    7.034675] omap_hsmmc 47810000.mmc: using device tree for GPIO lookup
[    7.041543] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@47810000[0]'
[    7.051183] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@47810000[0]'
[    7.060719] omap_hsmmc 47810000.mmc: using lookup tables for GPIO lookup
[    7.067789] omap_hsmmc 47810000.mmc: lookup for GPIO wp failed
[    7.074278] vdig1_1p8v: supplied by vcc5v
[    7.078827] device: 'mmc1': device_add
[    7.122572] driver: 'omap_hsmmc': driver_bound: bound to device '47810000.mmc'
[    7.130187] bus: 'platform': really_probe: bound device 47810000.mmc to driver omap_hsmmc
[    7.139062] device: 'ubi_ctrl': device_add
[    7.143942] bus: 'platform': add driver gpio-keys
[    7.152767] rtc-m41t80 0-0068: setting system clock to 2016-04-29 14:20:21 UTC (1461939621)
[    7.173104] omap_hsmmc 47810000.mmc: card claims to support voltages below defined range
[    7.185859] EXT4-fs: Warning: mounting with data=journal disables delayed allocation and O_DIRECT support!
[    7.196096] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    7.214070] EXT4-fs (mmcblk0p2): mounted filesystem with journalled data mode. Opts: data=journal
[    7.223591] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    7.234308] devtmpfs: mounted
[    7.237960] Freeing unused kernel memory: 268K (c09c5000 - c0a08000)
[    7.247262] mmc1: error -84 whilst initialising SDIO card
[    8.025732] udevd[129]: starting version 182
[    9.547299] EXT4-fs (mmcblk0p2): re-mounted. Opts: nodelalloc,data=journal
[    9.723121] random: dd urandom read with 41 bits of entropy available
[   25.550247] random: nonblocking pool is initialized
  • Moving this wo the WLAN forum.
    It looks like the dts changes are not correct.
    Please refer to: processors.wiki.ti.com/.../WL18xx_Platform_Integration_Guide for all the dts changes that are required.
    Gigi Joseph.
    Yes, I started with something similar to that, but failed to get power to the card. So I modified it to always enable power, but I've since understood that this probably mess up the start sequence.
    So I'm back to something very similar to what's described in the platform integration guide. Still nothing though: driver is loaded but not bound to any device, and no the wlan_en_reg fixedregulator is disabled.
    How come wlan_en_reg is disabled? It is required by wlcore in the device tree. Could it be that the module is not detected? How is wl18xx detected? For SD-cards there's an sd-gpio option, but there's no such thing for wl18xx.
    Still banging my head on this... I will upload my new device tree and dmesg output in next post.
  • Here's my current device tree:
    /dts-v1/;
    #include "am335x-phycore-som.dtsi"
    #include <dt-bindings/interrupt-controller/irq.h>
    	model = "MyEden phyCORE-AM335x Amun";
    	compatible = "phytec,am335x-wega", "phytec-am335x-phycore-som", "ti,am33xx";
    	regulators {
    		compatible = "simple-bus";
    		vcc3v3: fixedregulator@1 {
    			compatible = "regulator-fixed";
    			regulator-name = "vcc3v3";
    			regulator-min-microvolt = <3300000>;
    			regulator-max-microvolt = <3300000>;
    			regulator-boot-on;
    		wlan_en_reg: fixedregulator@2 {
    			regulator-name = "wlan-en-regulator";
    			regulator-min-microvolt = <1800000>;
    			regulator-max-microvolt = <1800000>;
    			gpio = <&gpio1 24 GPIO_ACTIVE_HIGH>;
    			enable-active-high;
    &vdig1_reg {
    	regulator-always-on;
    /* SoM */
    &i2c_eeprom {
        status = "okay";
    &i2c_rtc {
        status = "okay";
    /* uart1 is used by wifi/bluetooth chip (wilink8 */
    &uart1 {
    	status = "disabled";
    &am33xx_pinmux {
    	/* Copied from am335x-wega.dtsi */
            mmc1_pins: pinmux_mmc1 {
    		pinctrl-single,pins = <
    			0x0F0 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat3 */
    			0x0F4 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat2 */
    			0x0F8 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat1 */
    			0x0FC (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat0 */
    			0x100 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_clk */
    			0x104 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_cmd */
    			0x160 (PIN_INPUT_PULLUP | MUX_MODE7) /* mmc0_sdcd */
    	uart0_pins: pinmux_uart0 {
    			0x170 (PIN_INPUT_PULLUP | MUX_MODE0)    /* uart0_rxd */
    			0x174 (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart0_txd */
    	mrf24j40_pins_default: mrf24j40_pins_default {
    			0x164 (PIN_INPUT | MUX_MODE7) /* C18: gpio0[7] */
                		0xE0  (PIN_INPUT | MUX_MODE7) /* U5:  gpio2[22] (!reset - not used) */
    			0xE4  (PIN_INPUT | MUX_MODE7) /* R5:  gpio2[23] (wake - not used) */
    			// 0x150 (PIN_INPUT_PULLDOWN | MUX_MODE0) /* A17: spi0_sclk */
    			// 0x154 (PIN_INPUT_PULLDOWN | MUX_MODE0) /* B17: spi0_d0 */
    			// 0x158 (PIN_INPUT_PULLUP | MUX_MODE0)   /* B16: spi0_d1 */
    			// 0x15C (PIN_INPUT_PULLUP | MUX_MODE0)   /* A16: spi0_cs0 */
    	mrf24j40_pins_sleep: mrf24j40_pins_sleep {
    	wilink_pins_default: wilink_pins_default {
    			0x8C (PIN_INPUT_PULLUP | MUX_MODE3)     /* V12: mmc2_clk */
    			0x88 (PIN_INPUT_PULLUP | MUX_MODE3)     /* T13: mmc2_cmd */
    			0x44 (PIN_INPUT_PULLUP | MUX_MODE3)     /* V14: mmc2_dat0 */
    			0x48 (PIN_INPUT_PULLUP | MUX_MODE3)     /* U14: mmc2_dat1 */
    			0x4C (PIN_INPUT_PULLUP | MUX_MODE3)     /* T14: mmc2_dat2 */
    			0x78 (PIN_INPUT_PULLUP | MUX_MODE3)     /* U18: mmc2_dat3 */
    			0x58 (PIN_OUTPUT_PULLDOWN | MUX_MODE7)  /* U15: gpio1[22] = bt_en */
    			0x60 (PIN_OUTPUT_PULLDOWN | MUX_MODE7)  /* V16: gpio1[24] = wlan_en */
    			0x64 (PIN_INPUT | MUX_MODE7)            /* U16: gpio1[25] = wlan_irq */
    			// BT_LINK is not used
    			// 0x5C (PIN_INPUT | MUX_MODE7)         /* T15: gpio1[23] = bt_link */
    			0x178 (PIN_INPUT | MUX_MODE0)           /* D18: uart1_ctsn */
    			0x17C (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* D17: uart1_rtsn */
    			0x180 (PIN_INPUT_PULLUP | MUX_MODE0)    /* D16: uart1_rxd */
    			0x184 (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* D15: uart1_txd */
    			// For audio. Not used currently.
    			// 0x190 (PIN_INPUT | MUX_MODE0)        /* A13: mcasp0_aclkx */
    			// 0x194 (PIN_INPUT | MUX_MODE0)        /* B13: mcasp0_fsx */
    			// 0x198 (PIN_INPUT | MUX_MODE0)        /* D12: mcasp_axr0 */
    			// 0x1a8 (PIN_INPUT | MUX_MODE0)        /* D13: mcasp_axr1 */
    	wilink_pins_sleep: wilink_pins_sleep {
    			0x8C (PIN_INPUT_PULLDOWN | MUX_MODE7)   /* V12: mmc2_clk */
    			0x88 (PIN_INPUT_PULLDOWN | MUX_MODE7)   /* T13: mmc2_cmd */
    			0x44 (PIN_INPUT_PULLDOWN | MUX_MODE7)   /* V14: mmc2_dat0 */
    			0x48 (PIN_INPUT_PULLDOWN | MUX_MODE7)   /* U14: mmc2_dat1 */
    			0x4C (PIN_INPUT_PULLDOWN | MUX_MODE7)   /* T14: mmc2_dat2 */
    			0x78 (PIN_INPUT_PULLDOWN | MUX_MODE7)   /* U18: mmc2_dat3 */
    			0x58 (PIN_OUTPUT_PULLUP | MUX_MODE7)    /* U15: gpio1[22] = bt_en */
    			// 0x190 ()                             /* A13: mcasp0_aclkx */
    			// 0x194 ()                             /* B13: mcasp0_fsx */
    			// 0x198 ()                             /* D12: mcasp_axr0 */
    			// 0x1A8 ()                             /* D13: mcasp_axr1 */
    &mmc1 {
    	vmmc-supply = <&vcc3v3>;
    	bus-width = <4>;
    	pinctrl-names = "default";
    	pinctrl-0 = <&mmc1_pins>;
    	cd-gpios = <&gpio0 6 GPIO_ACTIVE_HIGH>;
    	status = "okay";
    &uart0 {
    	pinctrl-0 = <&uart0_pins>;
    	status = "okay";
    &spi0 {
        status = "okay";
        mrf24j40@0 {
            status = "okay";
            compatible = "microchip,mrf24j40ma";
            spi-max-frequency = <10000>;
            reg = <0>; /* Hopefully CS0n */
            mode = <0>;
            interrupt-parent = <&gpio0>;
            interrupts = <7 8>;
            pinctrl-0 = <&mrf24j40_pins_default>;
    &mac {
    &mmc3 {
    	status = "okay";
    	vmmc-supply = <&wlan_en_reg>;
    	bus-width = <4>;
    	pinctrl-names = "default", "sleep";
    	pinctrl-0 = <&wilink_pins_default>;
    	pinctrl-1 = <&wilink_pins_sleep>;
    	ti,non-removable;
    	ti,needs-special-hs-handling;
    	cap-power-off-card;
    	keep-power-in-suspend;
    	// dmas = <&edma 32
    	//         &edma 33>;
    	// dma-names = "tx", "rx";
    	#address-cells = <1>;
    	#size-cells = <0>;
    	wlcore: wlcore@0 {
    		compatible = "ti,wl1835";
    		status = "okay";
    		reg = <2>;
    		interrupt-parent = <&gpio1>;
    		interrupts = <25 IRQ_TYPE_LEVEL_HIGH>;
    /* USB */
    &cppi41dma {
    	status = "okay";
    &usb_ctrl_mod {
    	status = "okay";
    &usb {
    	status = "okay";
    &usb0 {
    	dr_mode = "peripheral";
    	status = "okay";
    &usb0_phy {
    	status = "okay";
    &usb1 {
    	dr_mode = "host";
    	status = "okay";
    &usb1_phy {
    	status = "okay";
    Any here's the current dmesg output:
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Initializing cgroup subsys cpuset
    [    0.000000] Initializing cgroup subsys cpuacct
    [    0.000000] Linux version 4.4.8-amun-phycore-am335x (jonatan@babbage) (gcc version 4.9.2 (GCC) ) #1 Wed May 4 14:28:47 CEST 2016
    [    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [    0.000000] Machine model: MyEden phyCORE-AM335x Amun
    [    0.000000] cma: Reserved 24 MiB at 0x9e800000
    [    0.000000] Memory policy: Data cache writeback
    [    0.000000] On node 0 totalpages: 131072
    [    0.000000] free_area_init_node: node 0, pgdat c0a58ab0, node_mem_map de36d000
    [    0.000000]   Normal zone: 1152 pages used for memmap
    [    0.000000]   Normal zone: 0 pages reserved
    [    0.000000]   Normal zone: 131072 pages, LIFO batch:31
    [    0.000000] CPU: All CPU(s) started in SVC mode.
    [    0.000000] AM335X ES2.1 (sgx neon )
    [    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
    [    0.000000] pcpu-alloc: [0] 0
    [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 129920
    [    0.000000] Kernel command line: consoleblank=0 console=ttyO0,115200n8  root=/dev/mmcblk0p2 rootflags=data=journal debug dyndbg="func of_platform_bus_create +p" dyndbg="func bus_add_driver +p" dyndbg="func device_add +p" dyndbg="func driver_probe_device +p" dyndbg="func really_probe +p" dyndbg="func driver_bound +p" dyndbg="func deferred_probe_work_func +p" dyndbg="func driver_deferred_probe_add +p" dyndbg="func driver_deferred_probe_del +p" rootwait ro fsck.repair=yes
    [    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
    [    0.000000] Memory: 475496K/524288K available (7433K kernel code, 400K rwdata, 2536K rodata, 268K init, 8240K bss, 24216K reserved, 24576K cma-reserved, 0K highmem)
    [    0.000000] Virtual kernel memory layout:
    [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    [    0.000000]     vmalloc : 0xe0800000 - 0xff800000   ( 496 MB)
    [    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
    [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
    [    0.000000]       .text : 0xc0008000 - 0xc09c4840   (9971 kB)
    [    0.000000]       .init : 0xc09c5000 - 0xc0a08000   ( 268 kB)
    [    0.000000]       .data : 0xc0a08000 - 0xc0a6c218   ( 401 kB)
    [    0.000000]        .bss : 0xc0a6f000 - 0xc127b168   (8241 kB)
    [    0.000000] Running RCU self tests
    [    0.000000] NR_IRQS:16 nr_irqs:16 16
    [    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
    [    0.000000] OMAP clockevent source: timer2 at 25000000 Hz
    [    0.000021] sched_clock: 32 bits at 25MHz, resolution 40ns, wraps every 85899345900ns
    [    0.000051] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
    [    0.000107] OMAP clocksource: timer1 at 25000000 Hz
    [    0.001116] Console: colour dummy device 80x30
    [    0.001190] Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar
    [    0.001203] ... MAX_LOCKDEP_SUBCLASSES:  8
    [    0.001213] ... MAX_LOCK_DEPTH:          48
    [    0.001223] ... MAX_LOCKDEP_KEYS:        8191
    [    0.001233] ... CLASSHASH_SIZE:          4096
    [    0.001243] ... MAX_LOCKDEP_ENTRIES:     32768
    [    0.001252] ... MAX_LOCKDEP_CHAINS:      65536
    [    0.001262] ... CHAINHASH_SIZE:          32768
    [    0.001271]  memory used by lock dependency info: 5167 kB
    [    0.001281]  per task-struct memory footprint: 1536 bytes
    [    0.001311] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
    [    0.098235] pid_max: default: 32768 minimum: 301
    [    0.098531] Security Framework initialized
    [    0.098667] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [    0.098686] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [    0.102817] Initializing cgroup subsys io
    [    0.102960] Initializing cgroup subsys memory
    [    0.103062] Initializing cgroup subsys devices
    [    0.103182] Initializing cgroup subsys freezer
    [    0.103352] Initializing cgroup subsys perf_event
    [    0.103450] CPU: Testing write buffer coherency: ok
    [    0.105684] Setting up static identity map for 0x800082c0 - 0x80008330
    [    0.121369] devtmpfs: initialized
    [    0.121605] device: 'platform': device_add
    [    0.122206] device: 'cpu': device_add
    [    0.122608] device: 'container': device_add
    [    0.165939] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
    [    0.224636] omap_hwmod: tptc0 using broken dt data from edma
    [    0.225268] omap_hwmod: tptc1 using broken dt data from edma
    [    0.225869] omap_hwmod: tptc2 using broken dt data from edma
    [    0.237108] omap_hwmod: debugss: _wait_target_disable failed
    [    0.294548] device: 'workqueue': device_add
    [    0.295154] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.298717] pinctrl core: initialized pinctrl subsystem
    [    0.300084] device: 'reg-dummy': device_add
    [    0.300820] bus: 'platform': add driver reg-dummy
    [    0.300889] bus: 'platform': driver_probe_device: matched device reg-dummy with driver reg-dummy
    [    0.300917] bus: 'platform': really_probe: probing driver reg-dummy with device reg-dummy
    [    0.301442] device: 'regulator.0': device_add
    [    0.302902] driver: 'reg-dummy': driver_bound: bound to device 'reg-dummy'
    [    0.303023] bus: 'platform': really_probe: bound device reg-dummy to driver reg-dummy
    [    0.305802] NET: Registered protocol family 16
    [    0.313908] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.314513] bus: 'platform': add driver omap_gpio
    [    0.314850] device: 'vtcon0': device_add
    [    0.315531] bus: 'platform': add driver sram
    [    0.315698] bus: 'platform': add driver syscon
    [    0.316289] bus: 'i2c': add driver dummy
    [    0.316596] cpuidle: using governor ladder
    [    0.316627] cpuidle: using governor menu
    [    0.316662] bus: 'platform': add driver omap-gpmc
    [    0.316801] bus: 'platform': add driver omap_l3_smx
    [    0.316932] bus: 'platform': add driver omap_l3_noc
    [    0.317471] of_platform_bus_create() - skipping /chosen, no compatible prop
    [    0.317499] of_platform_bus_create() - skipping /aliases, no compatible prop
    [    0.317517] of_platform_bus_create() - skipping /memory, no compatible prop
    [    0.317536] of_platform_bus_create() - skipping /cpus, no compatible prop
    [    0.317974] device: 'pmu': device_add
    [    0.318620] device: 'soc': device_add
    [    0.319002]    create child: /soc/mpu
    [    0.319091] device: 'soc:mpu': device_add
    [    0.319899] device: 'ocp': device_add
    [    0.320367]    create child: /ocp/l4_wkup@44c00000
    [    0.320455] device: 'ocp:l4_wkup@44c00000': device_add
    [    0.320825]    create child: /ocp/l4_wkup@44c00000/wkup_m3@100000
    [    0.321065] device: '44d00000.wkup_m3': device_add
    [    0.321487]    create child: /ocp/l4_wkup@44c00000/prcm@200000
    [    0.321658] device: '44e00000.prcm': device_add
    [    0.322013]    create child: /ocp/l4_wkup@44c00000/scm@210000
    [    0.322193] device: '44e10000.scm': device_add
    [    0.322543]    create child: /ocp/l4_wkup@44c00000/scm@210000/pinmux@800
    [    0.322736] device: '44e10800.pinmux': device_add
    [    0.323092]    create child: /ocp/l4_wkup@44c00000/scm@210000/scm_conf@0
    [    0.323285] device: '44e10000.scm_conf': device_add
    [    0.323628]    create child: /ocp/l4_wkup@44c00000/scm@210000/wkup_m3_ipc@1324
    [    0.324040] device: '44e11324.wkup_m3_ipc': device_add
    [    0.324402]    create child: /ocp/l4_wkup@44c00000/scm@210000/clockdomains
    [    0.324422] of_platform_bus_create() - skipping /ocp/l4_wkup@44c00000/scm@210000/clockdomains, no compatible prop
    [    0.324442]    create child: /ocp/interrupt-controller@48200000
    [    0.324599] device: '48200000.interrupt-controller': device_add
    [    0.324959]    create child: /ocp/edma@49000000
    [    0.325520] device: '49000000.edma': device_add
    [    0.326008]    create child: /ocp/gpio@44e07000
    [    0.326315] device: '44e07000.gpio': device_add
    [    0.326707] bus: 'platform': driver_probe_device: matched device 44e07000.gpio with driver omap_gpio
    [    0.326733] bus: 'platform': really_probe: probing driver omap_gpio with device 44e07000.gpio
    [    0.327621] device: 'gpiochip0': device_add
    [    0.328405] gpiochip_add: registered GPIOs 0 to 31 on device: gpio
    [    0.329881] OMAP GPIO hardware version 0.1
    [    0.330028] driver: 'omap_gpio': driver_bound: bound to device '44e07000.gpio'
    [    0.330062] bus: 'platform': really_probe: bound device 44e07000.gpio to driver omap_gpio
    [    0.330111]    create child: /ocp/gpio@4804c000
    [    0.330479] device: '4804c000.gpio': device_add
    [    0.330943] bus: 'platform': driver_probe_device: matched device 4804c000.gpio with driver omap_gpio
    [    0.330967] bus: 'platform': really_probe: probing driver omap_gpio with device 4804c000.gpio
    [    0.331378] device: 'gpiochip32': device_add
    [    0.331745] gpiochip_add: registered GPIOs 32 to 63 on device: gpio
    [    0.333137] driver: 'omap_gpio': driver_bound: bound to device '4804c000.gpio'
    [    0.333169] bus: 'platform': really_probe: bound device 4804c000.gpio to driver omap_gpio
    [    0.333211]    create child: /ocp/gpio@481ac000
    [    0.333540] device: '481ac000.gpio': device_add
    [    0.333987] bus: 'platform': driver_probe_device: matched device 481ac000.gpio with driver omap_gpio
    [    0.334011] bus: 'platform': really_probe: probing driver omap_gpio with device 481ac000.gpio
    [    0.334420] device: 'gpiochip64': device_add
    [    0.334780] gpiochip_add: registered GPIOs 64 to 95 on device: gpio
    [    0.336095] driver: 'omap_gpio': driver_bound: bound to device '481ac000.gpio'
    [    0.336126] bus: 'platform': really_probe: bound device 481ac000.gpio to driver omap_gpio
    [    0.336170]    create child: /ocp/gpio@481ae000
    [    0.336488] device: '481ae000.gpio': device_add
    [    0.336906] bus: 'platform': driver_probe_device: matched device 481ae000.gpio with driver omap_gpio
    [    0.336930] bus: 'platform': really_probe: probing driver omap_gpio with device 481ae000.gpio
    [    0.337331] device: 'gpiochip96': device_add
    [    0.337703] gpiochip_add: registered GPIOs 96 to 127 on device: gpio
    [    0.339101] driver: 'omap_gpio': driver_bound: bound to device '481ae000.gpio'
    [    0.339132] bus: 'platform': really_probe: bound device 481ae000.gpio to driver omap_gpio
    [    0.339175]    create child: /ocp/serial@44e09000
    [    0.339513] device: '44e09000.serial': device_add
    [    0.340027]    create child: /ocp/serial@48022000
    [    0.340059]    create child: /ocp/serial@48024000
    [    0.340085]    create child: /ocp/serial@481a6000
    [    0.340110]    create child: /ocp/serial@481a8000
    [    0.340134]    create child: /ocp/serial@481aa000
    [    0.340159]    create child: /ocp/i2c@44e0b000
    [    0.340473] device: '44e0b000.i2c': device_add
    [    0.340895]    create child: /ocp/i2c@4802a000
    [    0.340925]    create child: /ocp/i2c@4819c000
    [    0.340951]    create child: /ocp/mmc@48060000
    [    0.341225] device: '48060000.mmc': device_add
    [    0.341677]    create child: /ocp/mmc@481d8000
    [    0.341709]    create child: /ocp/mmc@47810000
    [    0.341999] device: '47810000.mmc': device_add
    [    0.342406]    create child: /ocp/spinlock@480ca000
    [    0.342555] device: '480ca000.spinlock': device_add
    [    0.342958]    create child: /ocp/wdt@44e35000
    [    0.343258] device: '44e35000.wdt': device_add
    [    0.343671]    create child: /ocp/can@481cc000
    [    0.343701]    create child: /ocp/can@481d0000
    [    0.343727]    create child: /ocp/mailbox@480C8000
    [    0.344022] device: '480c8000.mailbox': device_add
    [    0.344426]    create child: /ocp/timer@44e31000
    [    0.344457]    create child: /ocp/timer@48040000
    [    0.344482]    create child: /ocp/timer@48042000
    [    0.344787] device: '48042000.timer': device_add
    [    0.345264]    create child: /ocp/timer@48044000
    [    0.345562] device: '48044000.timer': device_add
    [    0.345968]    create child: /ocp/timer@48046000
    [    0.346259] device: '48046000.timer': device_add
    [    0.346671]    create child: /ocp/timer@48048000
    [    0.346963] device: '48048000.timer': device_add
    [    0.347362]    create child: /ocp/timer@4804a000
    [    0.347664] device: '4804a000.timer': device_add
    [    0.348062]    create child: /ocp/rtc@44e3e000
    [    0.348565] device: '44e3e000.rtc': device_add
    [    0.348999]    create child: /ocp/spi@48030000
    [    0.349308] device: '48030000.spi': device_add
    [    0.349725]    create child: /ocp/spi@481a0000
    [    0.349757]    create child: /ocp/usb@47400000
    [    0.349902] device: '47400000.usb': device_add
    [    0.350300]    create child: /ocp/epwmss@48300000
    [    0.350329]    create child: /ocp/epwmss@48302000
    [    0.350354]    create child: /ocp/epwmss@48304000
    [    0.350378]    create child: /ocp/ethernet@4a100000
    [    0.350408]    create child: /ocp/ocmcram@40300000
    [    0.350562] device: '40300000.ocmcram': device_add
    [    0.350900] bus: 'platform': driver_probe_device: matched device 40300000.ocmcram with driver sram
    [    0.350924] bus: 'platform': really_probe: probing driver sram with device 40300000.ocmcram
    [    0.351164] driver: 'sram': driver_bound: bound to device '40300000.ocmcram'
    [    0.351195] bus: 'platform': really_probe: bound device 40300000.ocmcram to driver sram
    [    0.351234]    create child: /ocp/elm@48080000
    [    0.351549] device: '48080000.elm': device_add
    [    0.351973]    create child: /ocp/lcdc@4830e000
    [    0.352003]    create child: /ocp/tscadc@44e0d000
    [    0.352028]    create child: /ocp/gpmc@50000000
    [    0.352332] device: '50000000.gpmc': device_add
    [    0.352793] bus: 'platform': driver_probe_device: matched device 50000000.gpmc with driver omap-gpmc
    [    0.352818] bus: 'platform': really_probe: probing driver omap-gpmc with device 50000000.gpmc
    [    0.353098] omap-gpmc 50000000.gpmc: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_nandflash, deferring probe
    [    0.353147] platform 50000000.gpmc: Driver omap-gpmc requests probe deferral
    [    0.353167] platform 50000000.gpmc: Added to deferred list
    [    0.353218]    create child: /ocp/sham@53100000
    [    0.353538] device: '53100000.sham': device_add
    [    0.354007]    create child: /ocp/aes@53500000
    [    0.354323] device: '53500000.aes': device_add
    [    0.354736]    create child: /ocp/mcasp@48038000
    [    0.354766]    create child: /ocp/mcasp@4803C000
    [    0.354791]    create child: /ocp/rng@48310000
    [    0.355082] device: '48310000.rng': device_add
    [    0.355547] device: 'regulators': device_add
    [    0.355914]    create child: /regulators/fixedregulator@0
    [    0.356008] device: 'regulators:fixedregulator@0': device_add
    [    0.356360]    create child: /regulators/fixedregulator@1
    [    0.356465] device: 'regulators:fixedregulator@1': device_add
    [    0.356816]    create child: /regulators/fixedregulator@2
    [    0.356909] device: 'regulators:fixedregulator@2': device_add
    [    0.358281] No ATAGs?
    [    0.358322] hw-breakpoint: debug architecture 0x4 unsupported.
    [    0.358584] device: 'omap-pcm-audio': device_add
    [    0.359632] bus: 'platform': add driver omap_dma_system
    [    0.360141] bus: 'platform': add driver ti-dma-crossbar
    [    0.360911] device: 'cpu0': device_add
    [    0.391785] device: 'writeback': device_add
    [    0.394300] bus: 'platform': add driver omap-control-phy
    [    0.394815] bus: 'platform': add driver twl4030_usb
    [    0.395248] bus: 'i2c': add driver pca953x
    [    0.395396] bus: 'i2c': add driver pcf857x
    [    0.395534] bus: 'platform': add driver palmas-gpio
    [    0.395911] bus: 'platform': add driver twl4030_gpio
    [    0.396536] bus: 'platform': add driver omap-dma-engine
    [    0.396972] bus: 'platform': add driver edma3-tptc
    [    0.397254] bus: 'platform': add driver edma
    [    0.397363] bus: 'platform': driver_probe_device: matched device 49000000.edma with driver edma
    [    0.397390] bus: 'platform': really_probe: probing driver edma with device 49000000.edma
    [    0.398500] edma 49000000.edma: Legacy memcpy is enabled, things might not work
    [    0.398836] device: 'dma0chan0': device_add
    [    0.399424] device: 'dma0chan1': device_add
    [    0.399768] device: 'dma0chan2': device_add
    [    0.400132] device: 'dma0chan3': device_add
    [    0.400467] device: 'dma0chan4': device_add
    [    0.400801] device: 'dma0chan5': device_add
    [    0.401147] device: 'dma0chan6': device_add
    [    0.401492] device: 'dma0chan7': device_add
    [    0.401827] device: 'dma0chan8': device_add
    [    0.402170] device: 'dma0chan9': device_add
    [    0.402505] device: 'dma0chan10': device_add
    [    0.402849] device: 'dma0chan11': device_add
    [    0.403197] device: 'dma0chan12': device_add
    [    0.403531] device: 'dma0chan13': device_add
    [    0.403869] device: 'dma0chan14': device_add
    [    0.404227] device: 'dma0chan15': device_add
    [    0.404562] device: 'dma0chan16': device_add
    [    0.404898] device: 'dma0chan17': device_add
    [    0.405257] device: 'dma0chan18': device_add
    [    0.405602] device: 'dma0chan19': device_add
    [    0.405940] device: 'dma0chan20': device_add
    [    0.406301] device: 'dma0chan21': device_add
    [    0.406641] device: 'dma0chan22': device_add
    [    0.406989] device: 'dma0chan23': device_add
    [    0.407339] device: 'dma0chan24': device_add
    [    0.407676] device: 'dma0chan25': device_add
    [    0.408014] device: 'dma0chan26': device_add
    [    0.408475] device: 'dma0chan27': device_add
    [    0.408819] device: 'dma0chan28': device_add
    [    0.409160] device: 'dma0chan29': device_add
    [    0.409515] device: 'dma0chan30': device_add
    [    0.409865] device: 'dma0chan31': device_add
    [    0.410207] device: 'dma0chan32': device_add
    [    0.410576] device: 'dma0chan33': device_add
    [    0.410920] device: 'dma0chan34': device_add
    [    0.411274] device: 'dma0chan35': device_add
    [    0.411628] device: 'dma0chan36': device_add
    [    0.411973] device: 'dma0chan37': device_add
    [    0.412326] device: 'dma0chan38': device_add
    [    0.412691] device: 'dma0chan39': device_add
    [    0.413035] device: 'dma0chan40': device_add
    [    0.413379] device: 'dma0chan41': device_add
    [    0.413734] device: 'dma0chan42': device_add
    [    0.414088] device: 'dma0chan43': device_add
    [    0.414434] device: 'dma0chan44': device_add
    [    0.414789] device: 'dma0chan45': device_add
    [    0.415134] device: 'dma0chan46': device_add
    [    0.415486] device: 'dma0chan47': device_add
    [    0.415844] device: 'dma0chan48': device_add
    [    0.416187] device: 'dma0chan49': device_add
    [    0.416532] device: 'dma0chan50': device_add
    [    0.416898] device: 'dma0chan51': device_add
    [    0.417253] device: 'dma0chan52': device_add
    [    0.417600] device: 'dma0chan53': device_add
    [    0.417962] device: 'dma0chan54': device_add
    [    0.418407] device: 'dma0chan55': device_add
    [    0.418764] device: 'dma0chan56': device_add
    [    0.419136] device: 'dma0chan57': device_add
    [    0.419485] device: 'dma0chan58': device_add
    [    0.419843] device: 'dma0chan59': device_add
    [    0.420202] device: 'dma0chan60': device_add
    [    0.420549] device: 'dma0chan61': device_add
    [    0.420898] device: 'dma0chan62': device_add
    [    0.421270] device: 'dma0chan63': device_add
    [    0.421798] edma 49000000.edma: TI EDMA DMA engine driver
    [    0.421824] driver: 'edma': driver_bound: bound to device '49000000.edma'
    [    0.421858] bus: 'platform': really_probe: bound device 49000000.edma to driver edma
    [    0.422206] bus: 'platform': add driver reg-fixed-voltage
    [    0.422443] bus: 'platform': driver_probe_device: matched device regulators:fixedregulator@0 with driver reg-fixed-voltage
    [    0.422471] bus: 'platform': really_probe: probing driver reg-fixed-voltage with device regulators:fixedregulator@0
    [    0.422688] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/fixedregulator@0[0]'
    [    0.422763] device: 'regulator.1': device_add
    [    0.423698] driver: 'reg-fixed-voltage': driver_bound: bound to device 'regulators:fixedregulator@0'
    [    0.423732] bus: 'platform': really_probe: bound device regulators:fixedregulator@0 to driver reg-fixed-voltage
    [    0.423772] bus: 'platform': driver_probe_device: matched device regulators:fixedregulator@1 with driver reg-fixed-voltage
    [    0.423794] bus: 'platform': really_probe: probing driver reg-fixed-voltage with device regulators:fixedregulator@1
    [    0.423981] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/fixedregulator@1[0]'
    [    0.424043] device: 'regulator.2': device_add
    [    0.424775] driver: 'reg-fixed-voltage': driver_bound: bound to device 'regulators:fixedregulator@1'
    [    0.424806] bus: 'platform': really_probe: bound device regulators:fixedregulator@1 to driver reg-fixed-voltage
    [    0.424842] bus: 'platform': driver_probe_device: matched device regulators:fixedregulator@2 with driver reg-fixed-voltage
    [    0.424863] bus: 'platform': really_probe: probing driver reg-fixed-voltage with device regulators:fixedregulator@2
    [    0.425092] of_get_named_gpiod_flags: parsed 'gpio' property of node '/regulators/fixedregulator@2[0]' - status (0)
    [    0.425156] device: 'regulator.3': device_add
    [    0.426146] driver: 'reg-fixed-voltage': driver_bound: bound to device 'regulators:fixedregulator@2'
    [    0.426178] bus: 'platform': really_probe: bound device regulators:fixedregulator@2 to driver reg-fixed-voltage
    [    0.426330] bus: 'platform': add driver palmas-pmic
    [    0.426851] bus: 'i2c': add driver tps62360
    [    0.426996] bus: 'i2c': add driver tps65023
    [    0.427136] bus: 'platform': add driver tps6507x-pmic
    [    0.427328] bus: 'platform': add driver tps65217-pmic
    [    0.427516] bus: 'platform': add driver tps65910-pmic
    [    0.427703] bus: 'platform': add driver twl_reg
    [    0.429362] bus: 'i2c': add driver tps65217
    [    0.429525] bus: 'i2c': add driver tps65910
    [    0.429668] bus: 'i2c': add driver palmas
    [    0.430488] SCSI subsystem initialized
    [    0.431385] libata version 3.00 loaded.
    [    0.431666] bus: 'mdio_bus': add driver Generic PHY
    [    0.431787] bus: 'mdio_bus': add driver Generic 10G PHY
    [    0.432178] bus: 'usb': add driver usbfs
    [    0.432434] usbcore: registered new interface driver usbfs
    [    0.432467] bus: 'usb': add driver hub
    [    0.432656] usbcore: registered new interface driver hub
    [    0.432745] bus: 'usb': add driver usb
    [    0.432863] usbcore: registered new device driver usb
    [    0.432905] bus: 'platform': add driver usb_phy_generic
    [    0.433260] bus: 'platform': add driver twl6030_usb
    [    0.433555] bus: 'platform': add driver musb-omap2430
    [    0.434212] bus: 'platform': add driver omap_i2c
    [    0.434378] bus: 'platform': driver_probe_device: matched device 44e0b000.i2c with driver omap_i2c
    [    0.434404] bus: 'platform': really_probe: probing driver omap_i2c with device 44e0b000.i2c
    [    0.434514] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0, deferring probe
    [    0.434564] platform 44e0b000.i2c: Driver omap_i2c requests probe deferral
    [    0.434588] platform 44e0b000.i2c: Added to deferred list
    [    0.434892] pps_core: LinuxPPS API ver. 1 registered
    [    0.434907] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.434992] PTP clock support registered
    [    0.436486] device: 'lo': device_add
    [    0.439574] Bluetooth: Core ver 2.21
    [    0.439732] NET: Registered protocol family 31
    [    0.439747] Bluetooth: HCI device and connection manager initialized
    [    0.439880] Bluetooth: HCI socket layer initialized
    [    0.439917] Bluetooth: L2CAP socket layer initialized
    [    0.440129] Bluetooth: SCO socket layer initialized
    [    0.440751] device: 'regulatory.0': device_add
    [    0.442631] device: 'rfkill': device_add
    [    0.445297] clocksource: Switched to clocksource timer1
    [    0.447356] device: 'fbcon': device_add
    [    0.448454] device: 'mem': device_add
    [    0.449165] device: 'kmem': device_add
    [    0.449655] device: 'null': device_add
    [    0.450101] device: 'zero': device_add
    [    0.450634] device: 'full': device_add
    [    0.451087] device: 'random': device_add
    [    0.451551] device: 'urandom': device_add
    [    0.451987] device: 'kmsg': device_add
    [    0.452436] device: 'tty': device_add
    [    0.453074] device: 'console': device_add
    [    0.453620] device: 'tty0': device_add
    [    0.454150] device: 'vcs': device_add
    [    0.454762] device: 'vcsa': device_add
    [    0.455241] device: 'vcs1': device_add
    [    0.455777] device: 'vcsa1': device_add
    [    0.456371] device: 'tty1': device_add
    [    0.456970] device: 'tty2': device_add
    [    0.457445] device: 'tty3': device_add
    [    0.457898] device: 'tty4': device_add
    [    0.458366] device: 'tty5': device_add
    [    0.458815] device: 'tty6': device_add
    [    0.459287] device: 'tty7': device_add
    [    0.459788] device: 'tty8': device_add
    [    0.460257] device: 'tty9': device_add
    [    0.460712] device: 'tty10': device_add
    [    0.461173] device: 'tty11': device_add
    [    0.461634] device: 'tty12': device_add
    [    0.462087] device: 'tty13': device_add
    [    0.462576] device: 'tty14': device_add
    [    0.463036] device: 'tty15': device_add
    [    0.463503] device: 'tty16': device_add
    [    0.463970] device: 'tty17': device_add
    [    0.464424] device: 'tty18': device_add
    [    0.464899] device: 'tty19': device_add
    [    0.465498] device: 'tty20': device_add
    [    0.465961] device: 'tty21': device_add
    [    0.466413] device: 'tty22': device_add
    [    0.466893] device: 'tty23': device_add
    [    0.467348] device: 'tty24': device_add
    [    0.467795] device: 'tty25': device_add
    [    0.468297] device: 'tty26': device_add
    [    0.468771] device: 'tty27': device_add
    [    0.469226] device: 'tty28': device_add
    [    0.469681] device: 'tty29': device_add
    [    0.470163] device: 'tty30': device_add
    [    0.470632] device: 'tty31': device_add
    [    0.471136] device: 'tty32': device_add
    [    0.471603] device: 'tty33': device_add
    [    0.472058] device: 'tty34': device_add
    [    0.472526] device: 'tty35': device_add
    [    0.472985] device: 'tty36': device_add
    [    0.473473] device: 'tty37': device_add
    [    0.473973] device: 'tty38': device_add
    [    0.474455] device: 'tty39': device_add
    [    0.474926] device: 'tty40': device_add
    [    0.475484] device: 'tty41': device_add
    [    0.475952] device: 'tty42': device_add
    [    0.476423] device: 'tty43': device_add
    [    0.476935] device: 'tty44': device_add
    [    0.477391] device: 'tty45': device_add
    [    0.477849] device: 'tty46': device_add
    [    0.478346] device: 'tty47': device_add
    [    0.478804] device: 'tty48': device_add
    [    0.479245] device: 'tty49': device_add
    [    0.479727] device: 'tty50': device_add
    [    0.480193] device: 'tty51': device_add
    [    0.480648] device: 'tty52': device_add
    [    0.481092] device: 'tty53': device_add
    [    0.481552] device: 'tty54': device_add
    [    0.482005] device: 'tty55': device_add
    [    0.482486] device: 'tty56': device_add
    [    0.482933] device: 'tty57': device_add
    [    0.483407] device: 'tty58': device_add
    [    0.483868] device: 'tty59': device_add
    [    0.484315] device: 'tty60': device_add
    [    0.484769] device: 'tty61': device_add
    [    0.485264] device: 'tty62': device_add
    [    0.485799] device: 'tty63': device_add
    [    0.486979] bus: 'platform': add driver usbhs_tll
    [    0.488536] NET: Registered protocol family 2
    [    0.491110] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
    [    0.491244] TCP bind hash table entries: 4096 (order: 5, 147456 bytes)
    [    0.493227] TCP: Hash tables configured (established 4096 bind 4096)
    [    0.493470] UDP hash table entries: 256 (order: 2, 20480 bytes)
    [    0.493752] UDP-Lite hash table entries: 256 (order: 2, 20480 bytes)
    [    0.494957] NET: Registered protocol family 1
    [    0.497419] RPC: Registered named UNIX socket transport module.
    [    0.497450] RPC: Registered udp transport module.
    [    0.497463] RPC: Registered tcp transport module.
    [    0.497476] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.497545] bus: 'platform': add driver usbhs_omap
    [    0.500044] bus: 'platform': add driver armv6-pmu
    [    0.500471] bus: 'platform': add driver armv7-pmu
    [    0.500547] bus: 'platform': driver_probe_device: matched device pmu with driver armv7-pmu
    [    0.500574] bus: 'platform': really_probe: probing driver armv7-pmu with device pmu
    [    0.500873] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
    [    0.501039] driver: 'armv7-pmu': driver_bound: bound to device 'pmu'
    [    0.501070] bus: 'platform': really_probe: bound device pmu to driver armv7-pmu
    [    0.501575] bus: 'platform': add driver omap_timer
    [    0.501810] bus: 'platform': driver_probe_device: matched device 48042000.timer with driver omap_timer
    [    0.501837] bus: 'platform': really_probe: probing driver omap_timer with device 48042000.timer
    [    0.502295] driver: 'omap_timer': driver_bound: bound to device '48042000.timer'
    [    0.502331] bus: 'platform': really_probe: bound device 48042000.timer to driver omap_timer
    [    0.502373] bus: 'platform': driver_probe_device: matched device 48044000.timer with driver omap_timer
    [    0.502394] bus: 'platform': really_probe: probing driver omap_timer with device 48044000.timer
    [    0.502646] driver: 'omap_timer': driver_bound: bound to device '48044000.timer'
    [    0.502675] bus: 'platform': really_probe: bound device 48044000.timer to driver omap_timer
    [    0.502712] bus: 'platform': driver_probe_device: matched device 48046000.timer with driver omap_timer
    [    0.502732] bus: 'platform': really_probe: probing driver omap_timer with device 48046000.timer
    [    0.502953] driver: 'omap_timer': driver_bound: bound to device '48046000.timer'
    [    0.502979] bus: 'platform': really_probe: bound device 48046000.timer to driver omap_timer
    [    0.503015] bus: 'platform': driver_probe_device: matched device 48048000.timer with driver omap_timer
    [    0.503036] bus: 'platform': really_probe: probing driver omap_timer with device 48048000.timer
    [    0.503255] driver: 'omap_timer': driver_bound: bound to device '48048000.timer'
    [    0.503282] bus: 'platform': really_probe: bound device 48048000.timer to driver omap_timer
    [    0.503318] bus: 'platform': driver_probe_device: matched device 4804a000.timer with driver omap_timer
    [    0.503339] bus: 'platform': really_probe: probing driver omap_timer with device 4804a000.timer
    [    0.503551] driver: 'omap_timer': driver_bound: bound to device '4804a000.timer'
    [    0.503578] bus: 'platform': really_probe: bound device 4804a000.timer to driver omap_timer
    [    0.504280] device: 'clocksource': device_add
    [    0.504474] device: 'clocksource0': device_add
    [    0.505099] bus: 'platform': add driver alarmtimer
    [    0.505484] device: 'alarmtimer': device_add
    [    0.505850] bus: 'platform': driver_probe_device: matched device alarmtimer with driver alarmtimer
    [    0.505876] bus: 'platform': really_probe: probing driver alarmtimer with device alarmtimer
    [    0.505986] driver: 'alarmtimer': driver_bound: bound to device 'alarmtimer'
    [    0.506011] bus: 'platform': really_probe: bound device alarmtimer to driver alarmtimer
    [    0.506223] device: 'clockevents': device_add
    [    0.506424] device: 'clockevent0': device_add
    [    0.506906] futex hash table entries: 256 (order: 1, 11264 bytes)
    [    0.507219] audit: initializing netlink subsys (disabled)
    [    0.507522] audit: type=2000 audit(0.500:1): initialized
    [    0.508077] device: 'armv7_cortex_a8': device_add
    [    0.508589] device: 'breakpoint': device_add
    [    0.508918] device: 'software': device_add
    [    0.514864] NFS: Registering the id_resolver key type
    [    0.515533] Key type id_resolver registered
    [    0.515558] Key type id_legacy registered
    [    0.515839] romfs: ROMFS MTD (C) 2007 Red Hat, Inc.
    [    0.515949] device: 'autofs': device_add
    [    0.535544] NET: Registered protocol family 38
    [    0.535906] io scheduler noop registered
    [    0.535935] io scheduler deadline registered
    [    0.535997] io scheduler cfq registered (default)
    [    0.536164] bus: 'platform': add driver omap-ocp2scp
    [    0.536709] bus: 'platform': add driver dm816x-usb-phy
    [    0.537024] bus: 'platform': add driver omap-usb2
    [    0.537413] bus: 'platform': add driver ti-pipe3
    [    0.537777] bus: 'platform': add driver palmas-pinctrl
    [    0.538116] bus: 'platform': add driver pinctrl-single
    [    0.538237] bus: 'platform': driver_probe_device: matched device 44e10800.pinmux with driver pinctrl-single
    [    0.538265] bus: 'platform': really_probe: probing driver pinctrl-single with device 44e10800.pinmux
    [    0.539237] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
    [    0.539261] driver: 'pinctrl-single': driver_bound: bound to device '44e10800.pinmux'
    [    0.539290] bus: 'platform': really_probe: bound device 44e10800.pinmux to driver pinctrl-single
    [    0.539691] bus: 'platform': add driver twl-pwm
    [    0.540022] bus: 'platform': add driver twl-pwmled
    [    0.540339] bus: 'platform': add driver cppi41-dma-engine
    [    0.540646] bus: 'platform': add driver tps65218-pmic
    [    0.541143] device: 'ptmx': device_add
    [    0.541925] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    0.542171] device: 'serial8250': device_add
    [    0.542976] device: 'ttyS0': device_add
    [    0.544452] device: 'ttyS1': device_add
    [    0.545580] device: 'ttyS2': device_add
    [    0.546466] device: 'ttyS3': device_add
    [    0.547286] bus: 'platform': add driver serial8250
    [    0.547442] bus: 'platform': driver_probe_device: matched device serial8250 with driver serial8250
    [    0.547469] bus: 'platform': really_probe: probing driver serial8250 with device serial8250
    [    0.547588] driver: 'serial8250': driver_bound: bound to device 'serial8250'
    [    0.547616] bus: 'platform': really_probe: bound device serial8250 to driver serial8250
    [    0.547759] bus: 'platform': add driver of_serial
    [    0.548480] bus: 'platform': add driver omap_uart
    [    0.548635] bus: 'platform': driver_probe_device: matched device 44e09000.serial with driver omap_uart
    [    0.548660] bus: 'platform': really_probe: probing driver omap_uart with device 44e09000.serial
    [    0.549431] omap_uart 44e09000.serial: no wakeirq for uart0
    [    0.549465] of_get_named_gpiod_flags: can't parse 'rts-gpio' property of node '/ocp/serial@44e09000[0]'
    [    0.549634] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 155, base_baud = 3000000) is a OMAP UART0
    [    3.774044] console [ttyO0] enabled
    [    3.777817] device: 'ttyO0': device_add
    [    3.783345] driver: 'omap_uart': driver_bound: bound to device '44e09000.serial'
    [    3.791222] bus: 'platform': really_probe: bound device 44e09000.serial to driver omap_uart
    [    3.800427] device: 'hw_random': device_add
    [    3.805542] bus: 'platform': add driver omap_rng
    [    3.810672] bus: 'platform': driver_probe_device: matched device 48310000.rng with driver omap_rng
    [    3.820149] bus: 'platform': really_probe: probing driver omap_rng with device 48310000.rng
    [    3.830107] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
    [    3.837163] driver: 'omap_rng': driver_bound: bound to device '48310000.rng'
    [    3.844593] bus: 'platform': really_probe: bound device 48310000.rng to driver omap_rng
    [    3.860684] device: '1:0': device_add
    [    3.865538] device: 'ram0': device_add
    [    3.872623] device: '1:1': device_add
    [    3.877053] device: 'ram1': device_add
    [    3.882792] device: '1:2': device_add
    [    3.887134] device: 'ram2': device_add
    [    3.892736] device: '1:3': device_add
    [    3.897054] device: 'ram3': device_add
    [    3.902629] device: '1:4': device_add
    [    3.906955] device: 'ram4': device_add
    [    3.912627] device: '1:5': device_add
    [    3.916994] device: 'ram5': device_add
    [    3.922596] device: '1:6': device_add
    [    3.926914] device: 'ram6': device_add
    [    3.932446] device: '1:7': device_add
    [    3.936735] device: 'ram7': device_add
    [    3.942298] device: '1:8': device_add
    [    3.946611] device: 'ram8': device_add
    [    3.952142] device: '1:9': device_add
    [    3.956491] device: 'ram9': device_add
    [    3.962051] device: '1:10': device_add
    [    3.966446] device: 'ram10': device_add
    [    3.972077] device: '1:11': device_add
    [    3.976472] device: 'ram11': device_add
    [    3.982137] device: '1:12': device_add
    [    3.986522] device: 'ram12': device_add
    [    3.992151] device: '1:13': device_add
    [    3.996592] device: 'ram13': device_add
    [    4.002262] device: '1:14': device_add
    [    4.006661] device: 'ram14': device_add
    [    4.012304] device: '1:15': device_add
    [    4.016709] device: 'ram15': device_add
    [    4.022329] brd: module loaded
    [    4.025748] device: 'loop-control': device_add
    [    4.033178] device: '7:0': device_add
    [    4.038039] device: 'loop0': device_add
    [    4.044854] device: '7:1': device_add
    [    4.049332] device: 'loop1': device_add
    [    4.056152] device: '7:2': device_add
    [    4.060492] device: 'loop2': device_add
    [    4.067187] device: '7:3': device_add
    [    4.071528] device: 'loop3': device_add
    [    4.078068] device: '7:4': device_add
    [    4.082397] device: 'loop4': device_add
    [    4.088775] device: '7:5': device_add
    [    4.093128] device: 'loop5': device_add
    [    4.099492] device: '7:6': device_add
    [    4.103821] device: 'loop6': device_add
    [    4.110179] device: '7:7': device_add
    [    4.114519] device: 'loop7': device_add
    [    4.120251] loop: module loaded
    [    4.123618] bus: 'i2c': add driver at24
    [    4.127878] bus: 'platform': add driver kim
    [    4.132537] bus: 'platform': add driver ti_am3359-tscadc
    [    4.138528] bus: 'i2c': add driver tps65218
    [    4.143057] bus: 'i2c': add driver twl
    [    4.147174] bus: 'platform': add driver twl4030-audio
    [    4.152786] bus: 'i2c': add driver twl6040
    [    4.157553] bus: 'scsi': add driver sd
    [    4.161634] bus: 'platform': add driver ahci
    [    4.166640] device: 'mtd': device_add
    [    4.171412] mtdoops: mtd device (mtddev=name/number) must be supplied
    [    4.178348] bus: 'platform': add driver omap2-nand
    [    4.183634] bus: 'platform': add driver omap-elm
    [    4.188729] bus: 'platform': driver_probe_device: matched device 48080000.elm with driver omap-elm
    [    4.198193] bus: 'platform': really_probe: probing driver omap-elm with device 48080000.elm
    [    4.207455] driver: 'omap-elm': driver_bound: bound to device '48080000.elm'
    [    4.214889] bus: 'platform': really_probe: bound device 48080000.elm to driver omap-elm
    [    4.223606] bus: 'spi': add driver spidev
    [    4.228005] bus: 'platform': add driver omap2_mcspi
    [    4.233337] bus: 'platform': driver_probe_device: matched device 48030000.spi with driver omap2_mcspi
    [    4.243078] bus: 'platform': really_probe: probing driver omap2_mcspi with device 48030000.spi
    [    4.252747] device: 'spi1': device_add
    [    4.259140] device: 'spi1.0': device_add
    [    4.264830] driver: 'omap2_mcspi': driver_bound: bound to device '48030000.spi'
    [    4.272651] bus: 'platform': really_probe: bound device 48030000.spi to driver omap2_mcspi
    [    4.281771] bus: 'platform': add driver ti-qspi
    [    4.286999] bus: 'mdio_bus': add driver SMSC LAN83C185
    [    4.292521] bus: 'mdio_bus': add driver SMSC LAN8187
    [    4.297894] bus: 'mdio_bus': add driver SMSC LAN8700
    [    4.303220] bus: 'mdio_bus': add driver SMSC LAN911x Internal PHY
    [    4.309784] bus: 'mdio_bus': add driver SMSC LAN8710/LAN8720
    [    4.315891] bus: 'mdio_bus': add driver Micrel KS8737
    [    4.321309] bus: 'mdio_bus': add driver Micrel KSZ8021 or KSZ8031
    [    4.327853] bus: 'mdio_bus': add driver Micrel KSZ8031
    [    4.333358] bus: 'mdio_bus': add driver Micrel KSZ8041
    [    4.338895] bus: 'mdio_bus': add driver Micrel KSZ8041RNLI
    [    4.344767] bus: 'mdio_bus': add driver Micrel KSZ8051
    [    4.350306] bus: 'mdio_bus': add driver Micrel KSZ8001 or KS8721
    [    4.356754] bus: 'mdio_bus': add driver Micrel KSZ8081 or KSZ8091
    [    4.363265] bus: 'mdio_bus': add driver Micrel KSZ8061
    [    4.368802] bus: 'mdio_bus': add driver Micrel KSZ9021 Gigabit PHY
    [    4.375448] bus: 'mdio_bus': add driver Micrel KSZ9031 Gigabit PHY
    [    4.382053] bus: 'mdio_bus': add driver Micrel KSZ8873MLL Switch
    [    4.388504] bus: 'mdio_bus': add driver Micrel KSZ886X Switch
    [    4.394666] bus: 'mdio_bus': add driver Atheros 8035 ethernet
    [    4.400845] bus: 'mdio_bus': add driver Atheros 8030 ethernet
    [    4.407022] bus: 'mdio_bus': add driver Atheros 8031 ethernet
    [    4.413192] bus: 'platform': add driver dm9000
    [    4.418211] bus: 'platform': add driver ks8851_mll
    [    4.423541] bus: 'platform': add driver smc91x
    [    4.428559] bus: 'platform': add driver smsc911x
    [    4.433714] bus: 'platform': add driver davinci_mdio
    [    4.439267] bus: 'platform': add driver cpsw-phy-sel
    [    4.444837] bus: 'platform': add driver cpsw
    [    4.449807] bus: 'usb': add driver usb8xxx
    [    4.454302] usbcore: registered new interface driver usb8xxx
    [    4.460302] libertas_sdio: Libertas SDIO driver
    [    4.465065] libertas_sdio: Copyright Pierre Ossman
    [    4.470134] bus: 'sdio': add driver libertas_sdio
    [    4.475200] bus: 'sdio': add driver wl1271_sdio
    [    4.480116] bus: 'platform': add driver wl12xx_driver
    [    4.485654] bus: 'spi': add driver wl1251
    [    4.489988] bus: 'sdio': add driver wl1251_sdio
    [    4.494868] bus: 'platform': add driver wl18xx_driver
    [    4.500539] bus: 'sdio': add driver mwifiex_sdio
    [    4.505566] bus: 'usb': add driver mwifiex_usb
    [    4.510450] usbcore: registered new interface driver mwifiex_usb
    [    4.516815] bus: 'spi': add driver mrf24j40
    [    4.521266] bus: 'spi': driver_probe_device: matched device spi1.0 with driver mrf24j40
    [    4.529719] bus: 'spi': really_probe: probing driver mrf24j40 with device spi1.0
    [    4.537984] mrf24j40 spi1.0: probe(). IRQ: 31
    [    4.603410] device: 'phy0': device_add
    [    4.608907] device: 'wpan0': device_add
    [    4.615216] driver: 'mrf24j40': driver_bound: bound to device 'spi1.0'
    [    4.622209] bus: 'spi': really_probe: bound device spi1.0 to driver mrf24j40
    [    4.629831] bus: 'platform': add driver am335x-control-usb
    [    4.636051] bus: 'platform': add driver am335x-phy-driver
    [    4.642267] device: 'usbmon0': device_add
    [    4.647590] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    4.654530] ehci-omap: OMAP-EHCI Host Controller driver
    [    4.660118] bus: 'platform': add driver ehci-omap
    [    4.665502] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    [    4.672075] bus: 'usb': add driver usb-storage
    [    4.677037] usbcore: registered new interface driver usb-storage
    [    4.683381] bus: 'platform': add driver musb-hdrc
    [    4.688941] device: 'mice': device_add
    [    4.693946] device: 'psaux': device_add
    [    4.698604] mousedev: PS/2 mouse device common for all mice
    [    4.704507] bus: 'serio': add driver atkbd
    [    4.709407] bus: 'platform': add driver matrix-keypad
    [    4.715113] bus: 'platform': add driver omap4-keypad
    [    4.720729] bus: 'platform': add driver twl4030_keypad
    [    4.726476] bus: 'platform': add driver pwm-beeper
    [    4.731803] bus: 'platform': add driver twl4030_pwrbutton
    [    4.737822] device: 'uinput': device_add
    [    4.742944] bus: 'i2c': add driver rtc-ds1307
    [    4.747760] bus: 'i2c': add driver rtc-m41t80
    [    4.752488] bus: 'platform': add driver omap_rtc
    [    4.757590] bus: 'platform': driver_probe_device: matched device 44e3e000.rtc with driver omap_rtc
    [    4.767057] bus: 'platform': really_probe: probing driver omap_rtc with device 44e3e000.rtc
    [    4.776970] device: 'rtc1': device_add
    [    4.781889] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc1
    [    4.789583] driver: 'omap_rtc': driver_bound: bound to device '44e3e000.rtc'
    [    4.797069] bus: 'platform': really_probe: bound device 44e3e000.rtc to driver omap_rtc
    [    4.805789] bus: 'platform': add driver palmas-rtc
    [    4.811183] bus: 'i2c': add driver rtc-pcf8563
    [    4.816056] bus: 'platform': add driver tps65910-rtc
    [    4.821503] bus: 'platform': add driver twl_rtc
    [    4.826599] i2c /dev entries driver
    [    4.830387] bus: 'platform': add driver poweroff-gpio
    [    4.836029] bus: 'i2c': add driver pmbus
    [    4.840291] bus: 'platform': add driver ti-soc-thermal
    [    4.845990] bus: 'platform': add driver omap_wdt
    [    4.850979] bus: 'platform': driver_probe_device: matched device 44e35000.wdt with driver omap_wdt
    [    4.860437] bus: 'platform': really_probe: probing driver omap_wdt with device 44e35000.wdt
    [    4.870455] device: 'watchdog': device_add
    [    4.876030] device: 'watchdog0': device_add
    [    4.881862] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [    4.889235] driver: 'omap_wdt': driver_bound: bound to device '44e35000.wdt'
    [    4.896716] bus: 'platform': really_probe: bound device 44e35000.wdt to driver omap_wdt
    [    4.905490] bus: 'platform': add driver twl4030_wdt
    [    4.910956] Bluetooth: HCI UART driver ver 2.3
    [    4.915680] Bluetooth: HCI UART protocol H4 registered
    [    4.921084] Bluetooth: HCI UART protocol BCSP registered
    [    4.926692] Bluetooth: HCI UART protocol LL registered
    [    4.932320] bus: 'platform': add driver omap-cpufreq
    [    4.937823] bus: 'mmc': add driver mmcblk
    [    4.942234] bus: 'sdio': add driver sdio_uart
    [    4.947001] bus: 'platform': add driver mmci-omap
    [    4.952274] bus: 'platform': add driver omap_hsmmc
    [    4.957528] bus: 'platform': driver_probe_device: matched device 48060000.mmc with driver omap_hsmmc
    [    4.967168] bus: 'platform': really_probe: probing driver omap_hsmmc with device 48060000.mmc
    [    4.976821] omap_hsmmc 48060000.mmc: GPIO lookup for consumer cd
    [    4.983151] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup
    [    4.990117] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/ocp/mmc@48060000[0]' - status (0)
    [    5.000507] omap_hsmmc 48060000.mmc: Got CD GPIO
    [    5.005403] omap_hsmmc 48060000.mmc: GPIO lookup for consumer wp
    [    5.011722] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup
    [    5.018616] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@48060000[0]'
    [    5.028248] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@48060000[0]'
    [    5.037784] omap_hsmmc 48060000.mmc: using lookup tables for GPIO lookup
    [    5.044998] omap_hsmmc 48060000.mmc: lookup for GPIO wp failed
    [    5.052575] device: 'mmc0': device_add
    [    5.057494]
    [    5.059075] =====================================
    [    5.064031] [ BUG: bad unlock balance detected! ]
    [    5.068993] 4.4.8-amun-phycore-am335x #1 Not tainted
    [    5.074224] -------------------------------------
    [    5.079181] swapper/1 is trying to release lock (&rdev->mutex) at:
    [    5.085733] [<c02dca88>] regulator_set_voltage+0x40/0x54
    [    5.091331] but there are no more locks to release!
    [    5.096468]
    [    5.096468] other info that might help us debug this:
    [    5.103352] 2 locks held by swapper/1:
    [    5.107298]  #0:  (&dev->mutex){......}, at: [<c03197d8>] __driver_attach+0x48/0x98
    [    5.115409]  #1:  (&dev->mutex){......}, at: [<c03197e8>] __driver_attach+0x58/0x98
    [    5.123512]
    [    5.123512] stack backtrace:
    [    5.128112] CPU: 0 PID: 1 Comm: swapper Not tainted 4.4.8-amun-phycore-am335x #1
    [    5.135905] Hardware name: Generic AM33XX (Flattened Device Tree)
    [    5.142359] [<c0016300>] (unwind_backtrace) from [<c0014144>] (show_stack+0x10/0x14)
    [    5.150542] [<c0014144>] (show_stack) from [<c0060678>] (print_unlock_imbalance_bug+0xac/0xdc)
    [    5.159633] [<c0060678>] (print_unlock_imbalance_bug) from [<c0064900>] (lock_release+0x23c/0x360)
    [    5.169094] [<c0064900>] (lock_release) from [<c0712860>] (__mutex_unlock_slowpath+0x78/0x154)
    [    5.178181] [<c0712860>] (__mutex_unlock_slowpath) from [<c02dca88>] (regulator_set_voltage+0x40/0x54)
    [    5.188005] [<c02dca88>] (regulator_set_voltage) from [<c04ac8f8>] (mmc_regulator_set_ocr+0x40/0xc8)
    [    5.197641] [<c04ac8f8>] (mmc_regulator_set_ocr) from [<c04c5348>] (omap_hsmmc_set_power+0xc8/0x1ec)
    [    5.207274] [<c04c5348>] (omap_hsmmc_set_power) from [<c04c5608>] (omap_hsmmc_set_ios+0x19c/0x2ec)
    [    5.216727] [<c04c5608>] (omap_hsmmc_set_ios) from [<c04ae020>] (mmc_power_up.part.6+0x34/0x1f0)
    [    5.225995] [<c04ae020>] (mmc_power_up.part.6) from [<c04af324>] (mmc_start_host+0x8c/0xa4)
    [    5.234808] [<c04af324>] (mmc_start_host) from [<c04b0420>] (mmc_add_host+0x58/0x78)
    [    5.242976] [<c04b0420>] (mmc_add_host) from [<c04c4c54>] (omap_hsmmc_probe+0x4fc/0xb28)
    [    5.251514] [<c04c4c54>] (omap_hsmmc_probe) from [<c031add4>] (platform_drv_probe+0x4c/0xb0)
    [    5.260415] [<c031add4>] (platform_drv_probe) from [<c0319534>] (driver_probe_device+0x21c/0x478)
    [    5.269775] [<c0319534>] (driver_probe_device) from [<c0319824>] (__driver_attach+0x94/0x98)
    [    5.278675] [<c0319824>] (__driver_attach) from [<c0317638>] (bus_for_each_dev+0x6c/0xa0)
    [    5.287301] [<c0317638>] (bus_for_each_dev) from [<c0318a84>] (bus_add_driver+0x1b8/0x26c)
    [    5.296017] [<c0318a84>] (bus_add_driver) from [<c0319dd8>] (driver_register+0x78/0xf8)
    [    5.304460] [<c0319dd8>] (driver_register) from [<c0009730>] (do_one_initcall+0xa8/0x1fc)
    [    5.313095] [<c0009730>] (do_one_initcall) from [<c09c5e8c>] (kernel_init_freeable+0x1e8/0x2b4)
    [    5.322273] [<c09c5e8c>] (kernel_init_freeable) from [<c070ee40>] (kernel_init+0x8/0xec)
    [    5.330810] [<c070ee40>] (kernel_init) from [<c0010290>] (ret_from_fork+0x14/0x24)
    [    5.375776] driver: 'omap_hsmmc': driver_bound: bound to device '48060000.mmc'
    [    5.383394] bus: 'platform': really_probe: bound device 48060000.mmc to driver omap_hsmmc
    [    5.392085] bus: 'platform': driver_probe_device: matched device 47810000.mmc with driver omap_hsmmc
    [    5.401718] bus: 'platform': really_probe: probing driver omap_hsmmc with device 47810000.mmc
    [    5.411102] omap_hsmmc 47810000.mmc: GPIO lookup for consumer cd
    [    5.417475] omap_hsmmc 47810000.mmc: using device tree for GPIO lookup
    [    5.424351] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/mmc@47810000[0]'
    [    5.433981] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/mmc@47810000[0]'
    [    5.443517] omap_hsmmc 47810000.mmc: using lookup tables for GPIO lookup
    [    5.450589] omap_hsmmc 47810000.mmc: lookup for GPIO cd failed
    [    5.456752] omap_hsmmc 47810000.mmc: GPIO lookup for consumer wp
    [    5.463069] omap_hsmmc 47810000.mmc: using device tree for GPIO lookup
    [    5.469956] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@47810000[0]'
    [    5.479590] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@47810000[0]'
    [    5.489124] omap_hsmmc 47810000.mmc: using lookup tables for GPIO lookup
    [    5.496195] omap_hsmmc 47810000.mmc: lookup for GPIO wp failed
    [    5.502545] omap_hsmmc 47810000.mmc: unable to obtain RX DMA engine channel 0
    [    5.510197] omap_hsmmc: probe of 47810000.mmc rejects match -6
    [    5.516630] bus: 'i2c': add driver leds-pca953x
    [    5.521528] bus: 'platform': add driver leds-gpio
    [    5.526769] bus: 'platform': add driver leds_pwm
    [    5.531855] ledtrig-cpu: registered to indicate activity on CPUs
    [    5.538436] bus: 'hid': add driver hid-generic
    [    5.543246] bus: 'usb': add driver usbhid
    [    5.547654] usbcore: registered new interface driver usbhid
    [    5.553512] usbhid: USB HID core driver
    [    5.557679] bus: 'platform': add driver palmas-usb
    [    5.563000] bus: 'platform': add driver extcon-usb-gpio
    [    5.568723] bus: 'platform': add driver emif
    [    5.573445] bus: 'i2c': add driver max1363
    [    5.577879] bus: 'platform': add driver TI-am335x-adc
    [    5.583376] bus: 'platform': add driver oprofile-perf
    [    5.588855] device: 'oprofile-perf.0': device_add
    [    5.594108] bus: 'platform': driver_probe_device: matched device oprofile-perf.0 with driver oprofile-perf
    [    5.604302] bus: 'platform': really_probe: probing driver oprofile-perf with device oprofile-perf.0
    [    5.613903] driver: 'oprofile-perf': driver_bound: bound to device 'oprofile-perf.0'
    [    5.622083] bus: 'platform': really_probe: bound device oprofile-perf.0 to driver oprofile-perf
    [    5.631271] oprofile: using arm/armv7
    [    5.635653] Initializing XFRM netlink socket
    [    5.640320] NET: Registered protocol family 10
    [    5.647083] sit: IPv6 over IPv4 tunneling driver
    [    5.652047] device: 'sit0': device_add
    [    5.657285] NET: Registered protocol family 17
    [    5.662021] NET: Registered protocol family 15
    [    5.666887] lib80211: common routines for IEEE802.11 drivers
    [    5.672843] lib80211_crypt: registered algorithm 'NULL'
    [    5.684389] NET: Registered protocol family 36
    [    5.689205] Key type dns_resolver registered
    [    5.694163] omap_voltage_late_init: Voltage driver support not added
    [    5.700916] device: 'cpufreq-dt.0': device_add
    [    5.706033] device: 'soc0': device_add
    [    5.710205] ThumbEE CPU extension supported.
    [    5.714731] Registering SWP/SWPB emulation handler
    [    5.719947] device: 'cpu_dma_latency': device_add
    [    5.725404] device: 'network_latency': device_add
    [    5.730699] device: 'network_throughput': device_add
    [    5.737284] device: 'memory_bandwidth': device_add
    [    5.745421] platform 50000000.gpmc: Retrying from deferred list
    [    5.751713] bus: 'platform': driver_probe_device: matched device 50000000.gpmc with driver omap-gpmc
    [    5.761353] bus: 'platform': really_probe: probing driver omap-gpmc with device 50000000.gpmc
    [    5.770666] omap-gpmc 50000000.gpmc: GPMC revision 6.0
    [    5.776131] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
    [    5.782948] device: 'omap2-nand.0': device_add
    [    5.787960] bus: 'platform': driver_probe_device: matched device omap2-nand.0 with driver omap2-nand
    [    5.797608] bus: 'platform': really_probe: probing driver omap2-nand with device omap2-nand.0
    [    5.807121] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xdc
    [    5.813805] nand: Micron MT29F4G08ABADAH4
    [    5.818055] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
    [    5.826078] nand: using OMAP_ECC_BCH8_CODE_HW ECC scheme
    [    5.831817] 9 ofpart partitions found on MTD device omap2-nand.0
    [    5.838166] Creating 9 MTD partitions on "omap2-nand.0":
    [    5.843768] 0x000000000000-0x000000020000 : "xload"
    [    5.849066] device: 'mtd0': device_add
    [    5.853654] device: 'mtd0ro': device_add
    [    5.858598] device: '31:0': device_add
    [    5.862812] device: 'mtdblock0': device_add
    [    5.868181] 0x000000020000-0x000000040000 : "xload_backup1"
    [    5.874182] device: 'mtd1': device_add
    [    5.878668] device: 'mtd1ro': device_add
    [    5.883485] device: '31:1': device_add
    [    5.887743] device: 'mtdblock1': device_add
    [    5.893035] 0x000000040000-0x000000060000 : "xload_backup2"
    [    5.899081] device: 'mtd2': device_add
    [    5.903518] device: 'mtd2ro': device_add
    [    5.908364] device: '31:2': device_add
    [    5.912574] device: 'mtdblock2': device_add
    [    5.917975] 0x000000060000-0x000000080000 : "xload_backup3"
    [    5.923970] device: 'mtd3': device_add
    [    5.928437] device: 'mtd3ro': device_add
    [    5.933258] device: '31:3': device_add
    [    5.937516] device: 'mtdblock3': device_add
    [    5.942930] 0x000000080000-0x000000100000 : "barebox"
    [    5.948785] device: 'mtd4': device_add
    [    5.953251] device: 'mtd4ro': device_add
    [    5.958151] device: '31:4': device_add
    [    5.962388] device: 'mtdblock4': device_add
    [    5.967824] 0x000000100000-0x000000140000 : "bareboxenv"
    [    5.973688] device: 'mtd5': device_add
    [    5.978016] mmc0: host does not support reading read-only switch, assuming write-enable
    [    5.986641] device: 'mtd5ro': device_add
    [    5.991199] mmc0: new high speed SDHC card at address aaaa
    [    5.997087] device: 'mmc0:aaaa': device_add
    [    6.001788] bus: 'mmc': driver_probe_device: matched device mmc0:aaaa with driver mmcblk
    [    6.010343] bus: 'mmc': really_probe: probing driver mmcblk with device mmc0:aaaa
    [    6.018900] device: '31:5': device_add
    [    6.023128] device: 'mtdblock5': device_add
    [    6.028512] 0x000000140000-0x000000180000 : "oftree"
    [    6.033976] device: 'mtd6': device_add
    [    6.038456] device: 'mtd6ro': device_add
    [    6.043415] device: '31:6': device_add
    [    6.047690] device: 'mtdblock6': device_add
    [    6.052666] mmcblk0: mmc0:aaaa SL08G 7.40 GiB
    [    6.057416] device: '179:0': device_add
    [    6.061715] device: 'mmcblk0': device_add
    [    6.066836] 0x000000180000-0x000000980000 : "kernel"
    [    6.078853] device: 'mtd7': device_add
    [    6.083719] device: 'mtd7ro': device_add
    [    6.088332]  mmcblk0: p1 p2
    [    6.091314] device: 'mmcblk0p1': device_add
    [    6.096599] device: '31:7': device_add
    [    6.100793] device: 'mtdblock7': device_add
    [    6.105702] device: 'mmcblk0p2': device_add
    [    6.110919] 0x000000980000-0x000020000000 : "root"
    [    6.538757] device: 'mtd8': device_add
    [    6.543870] driver: 'mmcblk': driver_bound: bound to device 'mmc0:aaaa'
    [    6.550920] bus: 'mmc': really_probe: bound device mmc0:aaaa to driver mmcblk
    [    6.558674] device: 'mtd8ro': device_add
    [    6.563496] device: '31:8': device_add
    [    6.567752] device: 'mtdblock8': device_add
    [    6.573066] driver: 'omap2-nand': driver_bound: bound to device 'omap2-nand.0'
    [    6.580724] bus: 'platform': really_probe: bound device omap2-nand.0 to driver omap2-nand
    [    6.589371] driver: 'omap-gpmc': driver_bound: bound to device '50000000.gpmc'
    [    6.596996] bus: 'platform': really_probe: bound device 50000000.gpmc to driver omap-gpmc
    [    6.605633] platform 44e0b000.i2c: Retrying from deferred list
    [    6.611947] bus: 'platform': driver_probe_device: matched device 44e0b000.i2c with driver omap_i2c
    [    6.621402] bus: 'platform': really_probe: probing driver omap_i2c with device 44e0b000.i2c
    [    6.630950] device: 'i2c-0': device_add
    [    6.635183] device: 'i2c-0': device_add
    [    6.639854] device: '0-002d': device_add
    [    6.644240] bus: 'i2c': driver_probe_device: matched device 0-002d with driver tps65910
    [    6.652706] bus: 'i2c': really_probe: probing driver tps65910 with device 0-002d
    [    6.675677] tps65910 0-002d: No interrupt support, no core IRQ
    [    6.681869] device: 'tps65910-gpio': device_add
    [    6.687038] device: 'tps65910-pmic': device_add
    [    6.691991] bus: 'platform': driver_probe_device: matched device tps65910-pmic with driver tps65910-pmic
    [    6.702004] bus: 'platform': really_probe: probing driver tps65910-pmic with device tps65910-pmic
    [    6.713030] device: 'regulator.4': device_add
    [    6.721662] device: 'regulator.5': device_add
    [    6.728168] device: 'regulator.6': device_add
    [    6.735019] device: 'regulator.7': device_add
    [    6.741898] device: 'regulator.8': device_add
    [    6.748498] device: 'regulator.9': device_add
    [    6.754876] device: 'regulator.10': device_add
    [    6.761266] device: 'regulator.11': device_add
    [    6.767901] device: 'regulator.12': device_add
    [    6.774356] device: 'regulator.13': device_add
    [    6.780839] device: 'regulator.14': device_add
    [    6.787315] device: 'regulator.15': device_add
    [    6.793752] device: 'regulator.16': device_add
    [    6.800252] device: 'regulator.17': device_add
    [    6.805724] driver: 'tps65910-pmic': driver_bound: bound to device 'tps65910-pmic'
    [    6.813700] bus: 'platform': really_probe: bound device tps65910-pmic to driver tps65910-pmic
    [    6.822746] device: 'tps65910-rtc': device_add
    [    6.827733] bus: 'platform': driver_probe_device: matched device tps65910-rtc with driver tps65910-rtc
    [    6.837560] bus: 'platform': really_probe: probing driver tps65910-rtc with device tps65910-rtc
    [    6.848013] tps65910-rtc tps65910-rtc: IRQ is not free.
    [    6.853539] tps65910-rtc: probe of tps65910-rtc failed with error -22
    [    6.860391] device: 'tps65910-power': device_add
    [    6.865559] driver: 'tps65910': driver_bound: bound to device '0-002d'
    [    6.872436] bus: 'i2c': really_probe: bound device 0-002d to driver tps65910
    [    6.879925] device: '0-0052': device_add
    [    6.884321] bus: 'i2c': driver_probe_device: matched device 0-0052 with driver at24
    [    6.892412] bus: 'i2c': really_probe: probing driver at24 with device 0-0052
    [    6.899962] at24 0-0052: 4096 byte 24c32 EEPROM, writable, 32 bytes/write
    [    6.907131] driver: 'at24': driver_bound: bound to device '0-0052'
    [    6.913638] bus: 'i2c': really_probe: bound device 0-0052 to driver at24
    [    6.920743] device: '0-0068': device_add
    [    6.925119] bus: 'i2c': driver_probe_device: matched device 0-0068 with driver rtc-m41t80
    [    6.933755] bus: 'i2c': really_probe: probing driver rtc-m41t80 with device 0-0068
    [    6.942226] device: 'rtc0': device_add
    [    6.946684] rtc-m41t80 0-0068: rtc core: registered rv4162 as rtc0
    [    6.953621] driver: 'rtc-m41t80': driver_bound: bound to device '0-0068'
    [    6.960712] bus: 'i2c': really_probe: bound device 0-0068 to driver rtc-m41t80
    [    6.968375] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
    [    6.974246] driver: 'omap_i2c': driver_bound: bound to device '44e0b000.i2c'
    [    6.981685] bus: 'platform': really_probe: bound device 44e0b000.i2c to driver omap_i2c
    [    6.990337] device: 'ubi_ctrl': device_add
    [    6.995073] bus: 'platform': add driver gpio-keys
    [    7.000799] rtc-m41t80 0-0068: setting system clock to 2016-05-04 12:28:29 UTC (1462364909)
    [    7.020226] wlan-en-regulator: disabling
    [    7.029329] EXT4-fs: Warning: mounting with data=journal disables delayed allocation and O_DIRECT support!
    [    7.039588] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
    [    7.057662] EXT4-fs (mmcblk0p2): mounted filesystem with journalled data mode. Opts: data=journal
    [    7.067191] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [    7.077870] devtmpfs: mounted
    [    7.081525] Freeing unused kernel memory: 268K (c09c5000 - c0a08000)
    [    7.740359] udevd[129]: starting version 182
    [    9.329230] EXT4-fs (mmcblk0p2): re-mounted. Opts: nodelalloc,data=journal
    [    9.507809] random: dd urandom read with 40 bits of entropy available
    [   44.078092] random: nonblocking pool is initialized
    I see in the log above too many sdio drivers being loaded:
    Can you make sure you disable in your kernel .config all other sdio controller drivers (mwifiex_sdio, libertas_sdio)?
    I have a feeling they are conflicting.
    The message you got below is normal at this point:
    Eyal Reizer
  • Ok, I've tried disabling mwifiex and libertas as you said, but sadly it did not help.
    Some week ago I sprinkled the firmware loading code with printk's and found that it did not find valid firmware. I fixed that problem, which was basically two problems:
    First, I did not build wl18xx as a module, so when the driver was loaded the root filesystem was not yet mounted.
    Second, the firmware was of wrong size, so I installed the newest I could find and there was no more complaints.
    Btw, at some point the output of "ifconfig wlan0" changed from:
    SIOCGIFFLAGS: No such device
    to:
    ifconfig: wlan0: error fetching interface information: Device not found
    Please share the full boot logs.
    Gigi Joseph.
