Hi everyone,
we are trying to bring up the wlan on a custom i.mx6ul based board equipped with TI Wilink module WL1807MODGIMOCR.
we are using the SDK version 8.6_SP1 for wl18xx driver and firmware.
currently the state is that we are able to bring the wlan up when we boot the board using the usb ethernet dongle but when the board is booted with either usb mass storage or micro sd card the it fails we received the message "ERROR firmware boot failed despite 3 retries"
Following are the device tree nodes.
regulators {
compatible = "simple-bus";
#address-cells = <1>;
#size-cells = <0>;
wlan_en: fixedregulator@100 {
compatible = "regulator-fixed";
regulator-name = "wlan_en";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
gpio = <&gpio1 8 GPIO_ACTIVE_LOW>;
startup-delay-us = <70000>;
&iomuxc {
lccd-wl-ti {
pinctrl_usdhc2: usdhc2grp {
fsl,pins = <
MX6UL_PAD_CSI_VSYNC__USDHC2_CLK 0x17059 /* wifi_clk */
MX6UL_PAD_CSI_HSYNC__USDHC2_CMD 0x17059 /* wifi_cmd */
MX6UL_PAD_CSI_DATA00__USDHC2_DATA0 0x17059 /* wifi_data0 */
MX6UL_PAD_CSI_DATA01__USDHC2_DATA1 0x17059 /* wifi_data1 */
MX6UL_PAD_CSI_DATA02__USDHC2_DATA2 0x17059 /* wifi_data2 */
MX6UL_PAD_CSI_DATA03__USDHC2_DATA3 0x17059 /* wifi_data3 */
pinctrl_wifi: wifigrp {
fsl,pins = <
MX6UL_PAD_GPIO1_IO08__GPIO1_IO08 0x17059 /* gpio8 */
MX6UL_PAD_NAND_DATA03__GPIO4_IO05 0x17059 /* wifi_irq */
&usdhc2 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_usdhc2 &pinctrl_wifi>;
keep-power-in-suspend;
enable-sdio-wakeup;
bus-width = <4>;
no-1-8-v;
wifi-host;
non-removable;
vmmc-supply = <&wlan_en>;
status = "okay";
max-frequency = <40000000>;
#size-cells = <0>;
wlcore: wlcore@0 {
compatible = "ti,wl1807", "ti,wlcore";
reg = <2>;
interrupt-parent = <&gpio4>;
interrupts = <5 IRQ_TYPE_EDGE_RISING>;
Following are the boot logs with both successful and unsuccessful wlan init.
boot log with wlan init ok
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: no vqmmc regulator found
mmc0: no vmmc regulator found
mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
sdhci-esdhc-imx 2194000.usdhc: assigned as wifi host
mmc1: no vqmmc regulator found
mmc0: host does not support reading read-only switch. assuming write-enable.
mmc0: new high speed SDHC card at address aaaa
mmcblk0: mmc0:aaaa SU08G 7.40 GiB
mmcblk0: p1 p2
usb 1-1: new high-speed USB device number 2 using ci_hdrc
mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
caam 2140000.caam: Instantiated RNG4 SH0
sdhci-esdhc-imx 2194000.usdhc: card claims to support voltages below defined range
mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
caam 2140000.caam: Instantiated RNG4 SH1
mmc1: new high speed SDIO card at address 0001
caam 2140000.caam: device ID = 0x0a160300 (Era 8)
caam 2140000.caam: job rings = 3, qi = 0
caam algorithms registered in /proc/crypto
caam_jr 2141000.jr0: registering rng-caam
Loading modules backported from Linux version R8.6_SP1-0-g4d167bf
Backport generated by backports.git R8.6_SP1-0-g4677dc3
[ OK ] Listening on sshd.socket.
[ OK ] Started Restore Sound Card State.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting Login Service...
[ OK ] Started Kernel Logging Service.
[ OK ] Started D-Bus System Message Bus.
[ OK ] Started Getty on tty1.
[ OK ] Started System Logging Service.
Starting Network Manager...
Starting Avahi mDNS/DNS-SD Stack...
[ OK ] Started Serial Getty on ttymxc2.
EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
cfg80211: Calling CRDA to update world regulatory domain
FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
wl18xx_driver wl18xx.0.auto: Direct firmware load failed with error -2
wl18xx_driver wl18xx.0.auto: Falling back to user helper
wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
wlcore: loaded
wlcore: driver version:
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Login Service.
[ OK ] Created slice system-systemd\x2drfkill.slice.
Starting Load/Save RF Kill Switch Status of rfkill0...
[ OK ] Started Network Manager.
[ OK ] Reached target Network.
Starting Network Time Service...
Starting DNS forwarder and DHCP server...
[ OK ] Started Load/Save RF Kill Switch Status of rfkill0.
[ OK ] Started DNS forwarder and DHCP server.
lccd ttymxc2
Mentor Embedded Linux 2015.12 lccd ttymxc2
lccd login: wlcore: PHY firmware version: Rev 8.2.0.0.233
wlcore: firmware booted (Rev 8.9.0.1.55)
IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
flexcan 2090000.can can0: bit-timing not yet defined
lccd ttymxc2
lccd login: root
root@lccd:~#
root@lccd:~#
root@lccd:~#
root@lccd:~# cfg80211: Calling CRDA to update world regulatory domain
root@lccd:~#
root@lccd:~#
root@lccd:~# icfg80211: Calling CRDA to update world regulatory domain
fconfig wlancfg80211: Calling CRDA to update world regulatory domain
0
wlan0 Link encap:Ethernet HWaddr 74:da:ea:85:4e:ed
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
root@lccd:~#
root@lccd:~#
boot log with wlan init failure
mmcblk0: p1 p2
[ OK ] Found device /dev/ttymxc2.
[ OK ] Started Network Time Service.
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
asix 1-1:1.0 eth0: link down
wlcore: loaded
lccd ttymxc2
lccd login: wlcore: ERROR firmware boot failed despite 3 retries
IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
asix 1-1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
lccd ttymxc2
lccd login: root
root@lccd:~#
